commit 7bd88377d482e1eae3c5329b12e33cfd664fa6a9 upstream.
return the value instead, and have path_init() do the assignment. Broken by
"vfs: Fix absolute RCU path walk failures due to uninitialized seq number",
which was Cc-stable with 2.6.38+ as destination. This one should go where
it went.
To avoid dummy value returned in case when root is already set (it would do
no harm, actually, since the only caller that doesn't ignore the return value
is guaranteed to have nd->root *not* set, but it's more obvious that way),
lift the check into callers. And do the same to set_root(), to keep them
in sync.
commit 99d263d4c5b2f541dfacb5391e22e8c91ea982a6 upstream.
Josef Bacik found a performance regression between 3.2 and 3.10 and
narrowed it down to commit bfcfaa77bdf0 ("vfs: use 'unsigned long'
accesses for dcache name comparison and hashing"). He reports:
"The test case is essentially
for (i = 0; i < 1000000; i++)
mkdir("a$i");
On xfs on a fio card this goes at about 20k dir/sec with 3.2, and 12k
dir/sec with 3.10. This is because we spend waaaaay more time in
__d_lookup on 3.10 than in 3.2.
The new hashing function for strings is suboptimal for <
sizeof(unsigned long) string names (and hell even > sizeof(unsigned
long) string names that I've tested). I broke out the old hashing
function and the new one into a userspace helper to get real numbers
and this is what I'm getting:
Old hash table had 1000000 entries, 0 dupes, 0 max dupes
New hash table had 12628 entries, 987372 dupes, 900 max dupes
We had 11400 buckets with a p50 of 30 dupes, p90 of 240 dupes, p99 of 567 dupes for the new hash
My test does the hash, and then does the d_hash into a integer pointer
array the same size as the dentry hash table on my system, and then
just increments the value at the address we got to see how many
entries we overlap with.
As you can see the old hash function ended up with all 1 million
entries in their own bucket, whereas the new one they are only
distributed among ~12.5k buckets, which is why we're using so much
more CPU in __d_lookup".
The reason for this hash regression is two-fold:
- On 64-bit architectures the down-mixing of the original 64-bit
word-at-a-time hash into the final 32-bit hash value is very
simplistic and suboptimal, and just adds the two 32-bit parts
together.
In particular, because there is no bit shuffling and the mixing
boundary is also a byte boundary, similar character patterns in the
low and high word easily end up just canceling each other out.
- the old byte-at-a-time hash mixed each byte into the final hash as it
hashed the path component name, resulting in the low bits of the hash
generally being a good source of hash data. That is not true for the
word-at-a-time case, and the hash data is distributed among all the
bits.
The fix is the same in both cases: do a better job of mixing the bits up
and using as much of the hash data as possible. We already have the
"hash_32|64()" functions to do that.
Reported-by: Josef Bacik <jbacik@fb.com>
Cc: Chris Mason <clm@fb.com>
Cc: linux-fsdevel@vger.kernel.org
commit 295dc39d941dc2ae53d5c170365af4c9d5c16212 upstream.
Currently umount on symlink blocks following umount:
/vz is separate mount
# ls /vz/ -al | grep test
drwxr-xr-x. 2 root root 4096 Jul 19 01:14 testdir
lrwxrwxrwx. 1 root root 11 Jul 19 01:16 testlink -> /vz/testdir
# umount -l /vz/testlink
umount: /vz/testlink: not mounted (expected)
# lsof /vz
# umount /vz
umount: /vz: device is busy. (unexpected)
In this case mountpoint_last() gets an extra refcount on path->mnt
Signed-off-by: Vasily Averin <vvs@openvz.org>
Acked-by: Ian Kent <raven@themaw.net>
Acked-by: Jeff Layton <jlayton@primarydata.com>
commit 23adbe12ef7d3d4195e80800ab36b37bee28cd03 upstream.
The kernel has no concept of capabilities with respect to inodes; inodes
exist independently of namespaces. For example, inode_capable(inode,
CAP_LINUX_IMMUTABLE) would be nonsense.
This patch changes inode_capable to check for uid and gid mappings and
renames it to capable_wrt_inode_uidgid, which should make it more
obvious what it does.
Fixes CVE-2014-4014.
Cc: Theodore Ts'o <tytso@mit.edu>
Cc: Serge Hallyn <serge.hallyn@ubuntu.com>
Cc: "Eric W. Biederman" <ebiederm@xmission.com>
Signed-off-by: Andy Lutomirski <luto@amacapital.net>
commit d22e6338db7f613dd4f6095c190682fcc519e4b7 upstream.
Recent changes to retry on ESTALE in linkat
(commit 442e31ca5a49e398351b2954b51f578353fdf210)
introduced a mountpoint reference leak and a small memory
leak in case a filesystem link operation returns ESTALE
which is pretty normal for distributed filesystems like
lustre, nfs and so on.
Free old_path in such a case.
[AV: there was another missing path_put() nearby - on the previous
goto retry]
[js: the second path_put is not in 3.12 yet, hunk removed]
Signed-off-by: Oleg Drokin: <green@linuxhacker.ru>
commit 14e972b4517128ac8e30e3de2ee4fbd995084223 upstream.
Historically, when a syscall that creates a dentry fails, you get an audit
record that looks something like this (when trying to create a file named
"new" in "/tmp/tmp.SxiLnCcv63"):
type=PATH msg=audit(1366128956.279:965): item=0 name="/tmp/tmp.SxiLnCcv63/new" inode=2138308 dev=fd:02 mode=040700 ouid=0 ogid=0 rdev=00:00 obj=staff_u:object_r:user_tmp_t:s15:c0.c1023
This record makes no sense since it's associating the inode information for
"/tmp/tmp.SxiLnCcv63" with the path "/tmp/tmp.SxiLnCcv63/new". The recent
patch I posted to fix the audit_inode call in do_last fixes this, by making it
look more like this:
type=PATH msg=audit(1366128765.989:13875): item=0 name="/tmp/tmp.DJ1O8V3e4f/" inode=141 dev=fd:02 mode=040700 ouid=0 ogid=0 rdev=00:00 obj=staff_u:object_r:user_tmp_t:s15:c0.c1023
While this is more correct, if the creation of the file fails, then we
have no record of the filename that the user tried to create.
This patch adds a call to audit_inode_child to may_create. This creates
an AUDIT_TYPE_CHILD_CREATE record that will sit in place until the
create succeeds. When and if the create does succeed, then this record
will be updated with the correct inode info from the create.
This fixes what was broken in commit bfcec708.
Commit 79f6530c should also be backported to stable v3.7+.
Signed-off-by: Jeff Layton <jlayton@redhat.com>
Signed-off-by: Eric Paris <eparis@redhat.com>
Signed-off-by: Richard Guy Briggs <rgb@redhat.com>
Add @path parameter to fix kernel-doc warning.
Also fix a spello/typo.
Warning(fs/namei.c:2304): No description found for parameter 'path'
fs/namei.c
If O_CREAT|O_EXCL are passed to open, then we know that either
- the file is successfully created, or
- the operation fails in some way.
So previously we set FILE_CREATED before calling ->atomic_open() so the
filesystem doesn't have to. This, however, led to bugs in the
implementation that went unnoticed when the filesystem didn't check for
existence, yet returned success. To prevent this kind of bug, require
filesystems to always explicitly set FILE_CREATED on O_CREAT|O_EXCL and
verify this in the VFS.
Also added a couple more verifications for the result of atomic_open():
- Warn if filesystem set FILE_CREATED despite the lack of O_CREAT.
- Warn if filesystem set FILE_CREATED but gave a negative dentry.
Signed-off-by: Miklos Szeredi <mszeredi@suse.cz>
Signed-off-by: Dave Jones <davej@fedoraproject.org>
For a long time no filesystem has been using vfs_follow_link, and as seen
by recent filesystem submissions any new use is accidental as well.
Remove vfs_follow_link, document the replacement in
Documentation/filesystems/porting and also rename __vfs_follow_link
to match its only caller better.
Pull vfs pile 3 (of many) from Al Viro:
"Waiman's conversion of d_path() and bits related to it,
kern_path_mountpoint(), several cleanups and fixes (exportfs
one is -stable fodder, IMO).
There definitely will be more... ;-/"
* 'for-linus' of git://git.kernel.org/pub/scm/linux/kernel/git/viro/vfs:
split read_seqretry_or_unlock(), convert d_walk() to resulting primitives
dcache: Translating dentry into pathname without taking rename_lock
autofs4 - fix device ioctl mount lookup
introduce kern_path_mountpoint()
rename user_path_umountat() to user_path_mountpoint_at()
take unlazy_walk() into umount_lookup_last()
Kill indirect include of file.h from eventfd.h, use fdget() in cgroup.c
prune_super(): sb->s_op is never NULL
exportfs: don't assume that ->iterate() won't feed us too long entries
afs: get rid of redundant ->d_name.len checks
When I moved the RCU walk termination into unlazy_walk(), I didn't copy
quite all of it: for the successful RCU termination we properly add the
necessary reference counts to our temporary copy of the root path, but
for the failure case we need to make sure that any temporary root path
information is cleared out (since it does _not_ have the proper
reference counts from the RCU lookup).
We could clean up this mess by just always dropping the temporary root
information, but Al points out that that would mean that a single lookup
through symlinks could see multiple different root entries if it races
with another thread doing chroot. Not that I think we should really
care (we had that before too, back before we had a copy of the root path
in the nameidata).
Al says he has a cunning plan. In the meantime, this is the minimal fix
for the problem, even if it's not all that pretty.
Reported-by: Mace Moneta <moneta.mace@gmail.com>
Acked-by: Al Viro <viro@zeniv.linux.org.uk>
This is the fix that the last two commits indirectly led up to - making
sure that we don't call dput() in a bad context on the dentries we've
looked up in RCU mode after the sequence count validation fails.
This basically expands d_rcu_to_refcount() into the callers, and then
fixes the callers to delay the dput() in the failure case until _after_
we've dropped all locks and are no longer in an RCU-locked region.
The case of 'complete_walk()' was trivial, since its failure case did
the unlock_rcu_walk() directly after the call to d_rcu_to_refcount(),
and as such that is just a pure expansion of the function with a trivial
movement of the resulting dput() to after 'unlock_rcu_walk()'.
In contrast, the unlazy_walk() case was much more complicated, because
not only does convert two different dentries from RCU to be reference
counted, but it used to not call unlock_rcu_walk() at all, and instead
just returned an error and let the caller clean everything up in
"terminate_walk()".
Happily, one of the dentries in question (called "parent" inside
unlazy_walk()) is the dentry of "nd->path", which terminate_walk() wants
a refcount to anyway for the non-RCU case.
So what the new and improved unlazy_walk() does is to first turn that
dentry into a refcounted one, and once that is set up, the error cases
can continue to use the terminate_walk() helper for cleanup, but for the
non-RCU case. Which makes it possible to drop out of RCU mode if we
actually hit the sequence number failure case.
... and move the extern from linux/namei.h to fs/internal.h,
along with that of vfs_path_lookup().
... and massage it a bit to reduce nesting
This simplifies the RCU to refcounting code in particular.
I was originally intending to leave this for later, but walking through
all the dput() logic (see previous commit), I realized that the dput()
"might_sleep()" check was misleadingly weak. And I removed it as
misleading, both for performance profiling and for debugging.
However, the might_sleep() debugging case is actually true: the final
dput() can indeed sleep, if the inode of the dentry that you are
releasing ends up sleeping at iput time (see dentry_iput()). So the
problem with the might_sleep() in dput() wasn't that it wasn't true, it
was that it wasn't actually testing and triggering on the interesting
case.
In particular, just about *any* dput() can indeed sleep, if you happen
to race with another thread deleting the file in question, and you then
lose the race to the be the last dput() for that file. But because it's
a very rare race, the debugging code would never trigger it in practice.
Why is this problematic? The new d_rcu_to_refcount() (see commit
15570086b590: "vfs: reimplement d_rcu_to_refcount() using
lockref_get_or_lock()") does a dput() for the failure case, and it does
it under the RCU lock. So potentially sleeping really is a bug.
But there's no way I'm going to fix this with the previous complicated
"lockref_get_or_lock()" interface. And rather than revert to the old
and crufty nested dentry locking code (which did get this right by
delaying the reference count updates until they were verified to be
safe), let's make forward progress.
Pull vfs pile 1 from Al Viro:
"Unfortunately, this merge window it'll have a be a lot of small piles -
my fault, actually, for not keeping #for-next in anything that would
resemble a sane shape ;-/
This pile: assorted fixes (the first 3 are -stable fodder, IMO) and
cleanups + %pd/%pD formats (dentry/file pathname, up to 4 last
components) + several long-standing patches from various folks.
There definitely will be a lot more (starting with Miklos'
check_submount_and_drop() series)"
* 'for-linus' of git://git.kernel.org/pub/scm/linux/kernel/git/viro/vfs: (26 commits)
direct-io: Handle O_(D)SYNC AIO
direct-io: Implement generic deferred AIO completions
add formats for dentry/file pathnames
kvm eventfd: switch to fdget
powerpc kvm: use fdget
switch fchmod() to fdget
switch epoll_ctl() to fdget
switch copy_module_from_fd() to fdget
git simplify nilfs check for busy subtree
ibmasmfs: don't bother passing superblock when not needed
don't pass superblock to hypfs_{mkdir,create*}
don't pass superblock to hypfs_diag_create_files
don't pass superblock to hypfs_vm_create_files()
oprofile: get rid of pointless forward declarations of struct super_block
oprofilefs_create_...() do not need superblock argument
oprofilefs_mkdir() doesn't need superblock argument
don't bother with passing superblock to oprofile_create_stats_files()
oprofile: don't bother with passing superblock to ->create_files()
don't bother passing sb to oprofile_create_files()
coh901318: don't open-code simple_read_from_buffer()
Christopher reported a regression where he was unable to unmount a NFS
filesystem where the root had gone stale. The problem is that
d_revalidate handles the root of the filesystem differently from other
dentries, but d_weak_revalidate does not. We could simply fix this by
making d_weak_revalidate return success on IS_ROOT dentries, but there
are cases where we do want to revalidate the root of the fs.
A umount is really a special case. We generally aren't interested in
anything but the dentry and vfsmount that's attached at that point. If
the inode turns out to be stale we just don't care since the intent is
to stop using it anyway.
Try to handle this situation better by treating umount as a special
case in the lookup code. Have it resolve the parent using normal
means, and then do a lookup of the final dentry without revalidating
it. In most cases, the final lookup will come out of the dcache, but
the case where there's a trailing symlink or !LAST_NORM entry on the
end complicates things a bit.
Cc: Neil Brown <neilb@suse.de>
Reported-by: Christopher T Vogan <cvogan@us.ibm.com>
This moves __d_rcu_to_refcount() from <linux/dcache.h> into fs/namei.c
and re-implements it using the lockref infrastructure instead. It also
adds a lot of comments about what is actually going on, because turning
a dentry that was looked up using RCU into a long-lived reference
counted entry is one of the more subtle parts of the rcu walk.
We also used to be _particularly_ subtle in unlazy_walk() where we
re-validate both the dentry and its parent using the same sequence
count. We used to do it by nesting the locks and then verifying the
sequence count just once.
That was silly, because nested locking is expensive, but the sequence
count check is not. So this just re-validates the dentry and the parent
separately, avoiding the nested locking, and making the lockref lookup
possible.
Acked-by: Waiman Long <waiman.long@hp.com>
This just replaces the dentry count/lock combination with the lockref
structure that contains both a count and a spinlock, and does the
mechanical conversion to use the lockref infrastructure.
There are no semantic changes here, it's purely syntactic. The
reference lockref implementation uses the spinlock exactly the same way
that the old dcache code did, and the bulk of this patch is just
expanding the internal "d_count" use in the dcache code to use
"d_lockref.count" instead.
This is purely preparation for the real change to make the reference
count updates be lockless during the 3.12 merge window.
[ As with the previous commit, this is a rewritten version of a concept
originally from Waiman, so credit goes to him, blame for any errors
goes to me.
Waiman's patch had some semantic differences for taking advantage of
the lockless update in dget_parent(), while this patch is
intentionally a pure search-and-replace change with no semantic
changes. - Linus ]
Signed-off-by: Waiman Long <Waiman.Long@hp.com>
This reverts commit bb2314b47996491bbc5add73633905c3120b6268.
It wasn't necessarily wrong per se, but we're still busily discussing
the exact details of this all, so I'm going to revert it for now.
It's true that you can already do flink() through /proc and that flink()
isn't new. But as Brad Spengler points out, some secure environments do
not mount proc, and flink adds a new interface that can avoid path
lookup of the source for those kinds of environments.
We may re-do this (and even mark it for stable backporting back in 3.11
and possibly earlier) once the whole discussion about the interface is done.
Cc: Brad Spengler <spender@grsecurity.net>
Every now and then someone proposes a new flink syscall, and this spawns
a long discussion of whether it would be a security problem. I think
that this is missing the point: flink is *already* allowed without
privilege as long as /proc is mounted -- it's called AT_SYMLINK_FOLLOW.
Now that O_TMPFILE is here, the ability to create a file with O_TMPFILE,
write it, and link it in is very convenient. The only problem is that
it requires that /proc be mounted so that you can do:
linkat(AT_FDCWD, "/proc/self/fd/<tmpfd>", dfd, path, AT_SYMLINK_NOFOLLOW)
This sucks -- it's much nicer to do:
linkat(tmpfd, "", dfd, path, AT_EMPTY_PATH)
Let's allow it.
If this turns out to be excessively scary, it we could instead require
that the inode in question be I_LINKABLE, but this seems pointless given
the /proc situation
[suggested by Rasmus Villemoes] make O_DIRECTORY | O_RDWR part of O_TMPFILE;
that will fail on old kernels in a lot more cases than what I came up with.
And make sure O_CREAT doesn't get there...
Instances either don't look at it at all (the majority of cases) or
only want it to find the superblock (which can be had as dentry->d_sb).
A few cases that want more are actually safe with dentry->d_inode -
the only precaution needed is the check that it hadn't been replaced with
NULL by rmdir() or by overwriting rename(), which case should be simply
treated as cache miss.
O_TMPFILE | O_CREAT => linkat() with AT_SYMLINK_FOLLOW and /proc/self/fd/<n>
as oldpath (i.e. flink()) will create a link
O_TMPFILE | O_CREAT | O_EXCL => ENOENT on attempt to link those guys
now...
/proc/self/cwd with O_CREAT should fail with EISDIR. /proc/self/exe, OTOH,
should fail with ENOTDIR when opened with O_DIRECTORY.
a couple of places got missed back when Linus has introduced that one...
Pull audit changes from Eric Paris:
"Al used to send pull requests every couple of years but he told me to
just start pushing them to you directly.
Our touching outside of core audit code is pretty straight forward. A
couple of interface changes which hit net/. A simple argument bug
calling audit functions in namei.c and the removal of some assembly
branch prediction code on ppc"
* git://git.infradead.org/users/eparis/audit: (31 commits)
audit: fix message spacing printing auid
Revert "audit: move kaudit thread start from auditd registration to kaudit init"
audit: vfs: fix audit_inode call in O_CREAT case of do_last
audit: Make testing for a valid loginuid explicit.
audit: fix event coverage of AUDIT_ANOM_LINK
audit: use spin_lock in audit_receive_msg to process tty logging
audit: do not needlessly take a lock in tty_audit_exit
audit: do not needlessly take a spinlock in copy_signal
audit: add an option to control logging of passwords with pam_tty_audit
audit: use spin_lock_irqsave/restore in audit tty code
helper for some session id stuff
audit: use a consistent audit helper to log lsm information
audit: push loginuid and sessionid processing down
audit: stop pushing loginid, uid, sessionid as arguments
audit: remove the old depricated kernel interface
audit: make validity checking generic
audit: allow checking the type of audit message in the user filter
audit: fix build break when AUDIT_DEBUG == 2
audit: remove duplicate export of audit_enabled
Audit: do not print error when LSMs disabled
Jiri reported a regression in auditing of open(..., O_CREAT) syscalls.
In older kernels, creating a file with open(..., O_CREAT) created
audit_name records that looked like this:
type=PATH msg=audit(1360255720.628:64): item=1 name="/abc/foo" inode=138810 dev=fd:00 mode=0100640 ouid=0 ogid=0 rdev=00:00 obj=unconfined_u:object_r:default_t:s0
type=PATH msg=audit(1360255720.628:64): item=0 name="/abc/" inode=138635 dev=fd:00 mode=040750 ouid=0 ogid=0 rdev=00:00 obj=unconfined_u:object_r:default_t:s0
...in recent kernels though, they look like this:
type=PATH msg=audit(1360255402.886:12574): item=2 name=(null) inode=264599 dev=fd:00 mode=0100640 ouid=0 ogid=0 rdev=00:00 obj=unconfined_u:object_r:default_t:s0
type=PATH msg=audit(1360255402.886:12574): item=1 name=(null) inode=264598 dev=fd:00 mode=040750 ouid=0 ogid=0 rdev=00:00 obj=unconfined_u:object_r:default_t:s0
type=PATH msg=audit(1360255402.886:12574): item=0 name="/abc/foo" inode=264598 dev=fd:00 mode=040750 ouid=0 ogid=0 rdev=00:00 obj=unconfined_u:object_r:default_t:s0
Richard bisected to determine that the problems started with commit
bfcec708, but the log messages have changed with some later
audit-related patches.
The problem is that this audit_inode call is passing in the parent of
the dentry being opened, but audit_inode is being called with the parent
flag false. This causes later audit_inode and audit_inode_child calls to
match the wrong entry in the audit_names list.
This patch simply sets the flag to properly indicate that this inode
represents the parent. With this, the audit_names entries are back to
looking like they did before.
Cc: <stable@vger.kernel.org> # v3.7+
Reported-by: Jiri Jaburek <jjaburek@redhat.com>
Test By: Richard Guy Briggs <rbriggs@redhat.com>
It's "normal" - it can happen if the file descriptor you followed was
opened with O_NOFOLLOW.
Reported-by: Dave Jones <davej@redhat.com>
Cc: stable@kernel.org
The following set of operations on a NFS client and server will cause
server# mkdir a
client# cd a
server# mv a a.bak
client# sleep 30 # (or whatever the dir attrcache timeout is)
client# stat .
stat: cannot stat `.': Stale NFS file handle
Obviously, we should not be getting an ESTALE error back there since the
inode still exists on the server. The problem is that the lookup code
will call d_revalidate on the dentry that "." refers to, because NFS has
FS_REVAL_DOT set.
nfs_lookup_revalidate will see that the parent directory has changed and
will try to reverify the dentry by redoing a LOOKUP. That of course
fails, so the lookup code returns ESTALE.
The problem here is that d_revalidate is really a bad fit for this case.
What we really want to know at this point is whether the inode is still
good or not, but we don't really care what name it goes by or whether
the dcache is still valid.
Add a new d_op->d_weak_revalidate operation and have complete_walk call
that instead of d_revalidate. The intent there is to allow for a
"weaker" d_revalidate that just checks to see whether the inode is still
good. This is also gives us an opportunity to kill off the FS_REVAL_DOT
special casing.
[AV: changed method name, added note in porting, fixed confusion re
having it possibly called from RCU mode (it won't be)]
Cc: NeilBrown <neilb@suse.de>
... always can be found in nameidata now.
... and clean the main loop a bit
Based on parts from Anatol's patch (the rest is the next commit).
...as always, rename is the messiest of the bunch. We have to track
whether to retry or not via a separate flag since the error handling
is already quite complex.
...so we can pass in LOOKUP_REVAL. For now, nothing does yet.
