path: root/fs/namei.c
2012-06-01vfs: retry last component if opening stale dentryMiklos Szeredi
NFS optimizes away d_revalidates for last component of open. This means that open itself can find the dentry stale. This patch allows the filesystem to return EOPENSTALE and the VFS will retry the lookup on just the last component if possible. If the lookup was done using RCU mode, including the last component, then this is not possible since the parent dentry is lost. In this case fall back to non-RCU lookup. Currently this is not used since NFS will always leave RCU mode. Signed-off-by: Miklos Szeredi <mszeredi@suse.cz> Signed-off-by: Al Viro <viro@zeniv.linux.org.uk>
2012-06-01vfs: do_last() common post lookupMiklos Szeredi
Now the post lookup code can be shared between O_CREAT and plain opens since they are essentially the same. Signed-off-by: Miklos Szeredi <mszeredi@suse.cz> Signed-off-by: Al Viro <viro@zeniv.linux.org.uk>
2012-06-01vfs: do_last(): add audit_inode before openMiklos Szeredi
This allows this code to be shared between O_CREAT and plain opens. Signed-off-by: Miklos Szeredi <mszeredi@suse.cz> Signed-off-by: Al Viro <viro@zeniv.linux.org.uk>
2012-06-01vfs: do_last(): only return EISDIR for O_CREATMiklos Szeredi
2012-06-01vfs: do_last(): check LOOKUP_DIRECTORYMiklos Szeredi
Check for ENOTDIR before finishing open. This allows this code to be shared between O_CREAT and plain opens. Signed-off-by: Miklos Szeredi <mszeredi@suse.cz> Signed-off-by: Al Viro <viro@zeniv.linux.org.uk>
2012-06-01vfs: do_last(): make ENOENT exit RCU safeMiklos Szeredi
This will allow this code to be used in RCU mode. Signed-off-by: Miklos Szeredi <mszeredi@suse.cz> Signed-off-by: Al Viro <viro@zeniv.linux.org.uk>
2012-06-01vfs: make follow_link check RCU safeMiklos Szeredi
2012-06-01vfs: do_last(): use inode variableMiklos Szeredi
Use helper variable instead of path->dentry->d_inode before complete_walk(). This will allow this code to be used in RCU mode. Signed-off-by: Miklos Szeredi <mszeredi@suse.cz> Signed-off-by: Al Viro <viro@zeniv.linux.org.uk>
2012-06-01vfs: do_last(): inline walk_component()Miklos Szeredi
Copy walk_component() into do_lookup(). Signed-off-by: Miklos Szeredi <mszeredi@suse.cz> Signed-off-by: Al Viro <viro@zeniv.linux.org.uk>
2012-06-01vfs: do_last(): make exit RCU safeMiklos Szeredi
Allow returning from do_last() with LOOKUP_RCU still set on the "out:" and "exit:" labels. Signed-off-by: Miklos Szeredi <mszeredi@suse.cz> Signed-off-by: Al Viro <viro@zeniv.linux.org.uk>
2012-06-01vfs: split do_lookup()Miklos Szeredi
Split do_lookup() into two functions: lookup_fast() - does cached lookup without i_mutex lookup_slow() - does lookup with i_mutex Both follow managed dentries. The new functions are needed by atomic_open. Signed-off-by: Miklos Szeredi <mszeredi@suse.cz> Signed-off-by: Al Viro <viro@zeniv.linux.org.uk>
2012-05-29brlocks/lglocks: API cleanupsAndi Kleen
lglocks and brlocks are currently generated with some complicated macros in lglock.h. But there's no reason to not just use common utility functions and put all the data into a common data structure. In preparation, this patch changes the API to look more like normal function calls with pointers, not magic macros. The patch is rather large because I move over all users in one go to keep it bisectable. This impacts the VFS somewhat in terms of lines changed. But no actual behaviour change. [akpm@linux-foundation.org: checkpatch fixes] Signed-off-by: Andi Kleen <ak@linux.intel.com> Cc: Al Viro <viro@zeniv.linux.org.uk> Cc: Rusty Russell <rusty@rustcorp.com.au> Signed-off-by: Andrew Morton <akpm@linux-foundation.org> Signed-off-by: Rusty Russell <rusty@rustcorp.com.au> Signed-off-by: Al Viro <viro@zeniv.linux.org.uk>
2012-05-26word-at-a-time: make the interfaces truly genericLinus Torvalds
This changes the interfaces in <asm/word-at-a-time.h> to be a bit more complicated, but a lot more generic. In particular, it allows us to really do the operations efficiently on both little-endian and big-endian machines, pretty much regardless of machine details. For example, if you can rely on a fast population count instruction on your architecture, this will allow you to make your optimized <asm/word-at-a-time.h> file with that. NOTE! The "generic" version in include/asm-generic/word-at-a-time.h is not truly generic, it actually only works on big-endian. Why? Because on little-endian the generic algorithms are wasteful, since you can inevitably do better. The x86 implementation is an example of that. (The only truly non-generic part of the asm-generic implementation is the "find_zero()" function, and you could make a little-endian version of it. And if the Kbuild infrastructure allowed us to pick a particular header file, that would be lovely) The <asm/word-at-a-time.h> functions are as follows: - WORD_AT_A_TIME_CONSTANTS: specific constants that the algorithm uses. - has_zero(): take a word, and determine if it has a zero byte in it. It gets the word, the pointer to the constant pool, and a pointer to an intermediate "data" field it can set. This is the "quick-and-dirty" zero tester: it's what is run inside the hot loops. - "prep_zero_mask()": take the word, the data that has_zero() produced, and the constant pool, and generate an *exact* mask of which byte had the first zero. This is run directly *outside* the loop, and allows the "has_zero()" function to answer the "is there a zero byte" question without necessarily getting exactly *which* byte is the first one to contain a zero. If you do multiple byte lookups concurrently (eg "hash_name()", which looks for both NUL and '/' bytes), after you've done the prep_zero_mask() phase, the result of those can be or'ed together to get the "either or" case. - The result from "prep_zero_mask()" can then be fed into "find_zero()" (to find the byte offset of the first byte that was zero) or into "zero_bytemask()" (to find the bytemask of the bytes preceding the zero byte). The existence of zero_bytemask() is optional, and is not necessary for the normal string routines. But dentry name hashing needs it, so if you enable DENTRY_WORD_AT_A_TIME you need to expose it. This changes the generic strncpy_from_user() function and the dentry hashing functions to use these modified word-at-a-time interfaces. This gets us back to the optimized state of the x86 strncpy that we lost in the previous commit when moving over to the generic version. Signed-off-by: Linus Torvalds <torvalds@linux-foundation.org>
2012-05-24Merge git://git.kernel.org/pub/scm/linux/kernel/git/davem/sparcLinus Torvalds
Pull sparc changes from David S. Miller: "This has the generic strncpy_from_user() implementation architectures can now use, which we've been developing on linux-arch over the past few days. For good measure I ran both a 32-bit and a 64-bit glibc testsuite run, and the latter of which pointed out an adjustment I needed to make to sparc's user_addr_max() definition. Linus, you were right, STACK_TOP was not the right thing to use, even on sparc itself :-) From Sam Ravnborg, we have a conversion of sparc32 over to the common alloc_thread_info_node(), since the aspect which originally blocked our doing so (sun4c) has been removed." Fix up trivial arch/sparc/Kconfig and lib/Makefile conflicts. * git://git.kernel.org/pub/scm/linux/kernel/git/davem/sparc: sparc: Fix user_addr_max() definition. lib: Sparc's strncpy_from_user is generic enough, move under lib/ kernel: Move REPEAT_BYTE definition into linux/kernel.h sparc: Increase portability of strncpy_from_user() implementation. sparc: Optimize strncpy_from_user() zero byte search. sparc: Add full proper error handling to strncpy_from_user(). sparc32: use the common implementation of alloc_thread_info_node()
2012-05-24kernel: Move REPEAT_BYTE definition into linux/kernel.hDavid S. Miller
And make sure that everything using it explicitly includes that header file. Signed-off-by: David S. Miller <davem@davemloft.net>
2012-05-23Merge branch 'for-linus' of ↵Linus Torvalds
git://git.kernel.org/pub/scm/linux/kernel/git/ebiederm/user-namespace Pull user namespace enhancements from Eric Biederman: "This is a course correction for the user namespace, so that we can reach an inexpensive, maintainable, and reasonably complete implementation. Highlights: - Config guards make it impossible to enable the user namespace and code that has not been converted to be user namespace safe. - Use of the new kuid_t type ensures the if you somehow get past the config guards the kernel will encounter type errors if you enable user namespaces and attempt to compile in code whose permission checks have not been updated to be user namespace safe. - All uids from child user namespaces are mapped into the initial user namespace before they are processed. Removing the need to add an additional check to see if the user namespace of the compared uids remains the same. - With the user namespaces compiled out the performance is as good or better than it is today. - For most operations absolutely nothing changes performance or operationally with the user namespace enabled. - The worst case performance I could come up with was timing 1 billion cache cold stat operations with the user namespace code enabled. This went from 156s to 164s on my laptop (or 156ns to 164ns per stat operation). - (uid_t)-1 and (gid_t)-1 are reserved as an internal error value. Most uid/gid setting system calls treat these value specially anyway so attempting to use -1 as a uid would likely cause entertaining failures in userspace. - If setuid is called with a uid that can not be mapped setuid fails. I have looked at sendmail, login, ssh and every other program I could think of that would call setuid and they all check for and handle the case where setuid fails. - If stat or a similar system call is called from a context in which we can not map a uid we lie and return overflowuid. The LFS experience suggests not lying and returning an error code might be better, but the historical precedent with uids is different and I can not think of anything that would break by lying about a uid we can't map. - Capabilities are localized to the current user namespace making it safe to give the initial user in a user namespace all capabilities. My git tree covers all of the modifications needed to convert the core kernel and enough changes to make a system bootable to runlevel 1." Fix up trivial conflicts due to nearby independent changes in fs/stat.c * 'for-linus' of git://git.kernel.org/pub/scm/linux/kernel/git/ebiederm/user-namespace: (46 commits) userns: Silence silly gcc warning. cred: use correct cred accessor with regards to rcu read lock userns: Convert the move_pages, and migrate_pages permission checks to use uid_eq userns: Convert cgroup permission checks to use uid_eq userns: Convert tmpfs to use kuid and kgid where appropriate userns: Convert sysfs to use kgid/kuid where appropriate userns: Convert sysctl permission checks to use kuid and kgids. userns: Convert proc to use kuid/kgid where appropriate userns: Convert ext4 to user kuid/kgid where appropriate userns: Convert ext3 to use kuid/kgid where appropriate userns: Convert ext2 to use kuid/kgid where appropriate. userns: Convert devpts to use kuid/kgid where appropriate userns: Convert binary formats to use kuid/kgid where appropriate userns: Add negative depends on entries to avoid building code that is userns unsafe userns: signal remove unnecessary map_cred_ns userns: Teach inode_capable to understand inodes whose uids map to other namespaces. userns: Fail exec for suid and sgid binaries with ids outside our user namespace. userns: Convert stat to return values mapped from kuids and kgids userns: Convert user specfied uids and gids in chown into kuids and kgid userns: Use uid_eq gid_eq helpers when comparing kuids and kgids in the vfs ...
2012-05-21Merge branch 'dentry-cleanups' (dcache access cleanups and optimizations)Linus Torvalds
This branch simplifies and clarifies the dcache lookup, and allows us to do certain nice optimizations when comparing dentries. It also cleans up the interface to __d_lookup_rcu(), especially around passing the inode information around. * dentry-cleanups: vfs: make it possible to access the dentry hash/len as one 64-bit entry vfs: move dentry name length comparison from dentry_cmp() into callers vfs: do the careful dentry name access for all dentry_cmp cases vfs: remove unnecessary d_unhashed() check from __d_lookup_rcu vfs: clean up __d_lookup_rcu() and dentry_cmp() interfaces
2012-05-21Merge branch 'vfs-cleanups' (random vfs cleanups)Linus Torvalds
This teaches vfs_fstat() to use the appropriate f[get|put]_light functions, allowing it to avoid some unnecessary locking for the common case. More noticeably, it also cleans up and simplifies the "getname_flags()" function, which now relies on the architecture strncpy_from_user() doing all the user access checks properly, instead of hacking around the fact that on x86 it didn't use to do it right (see commit 92ae03f2ef99: "x86: merge 32/64-bit versions of 'strncpy_from_user()' and speed it up"). * vfs-cleanups: VFS: make vfs_fstat() use f[get|put]_light() VFS: clean up and simplify getname_flags() x86: make word-at-a-time strncpy_from_user clear bytes at the end
2012-05-04vfs: clean up __d_lookup_rcu() and dentry_cmp() interfacesLinus Torvalds
The calling conventions for __d_lookup_rcu() and dentry_cmp() are annoying in different ways, and there is actually one single underlying reason for both of the annoyances. The fundamental reason is that we do the returned dentry sequence number check inside __d_lookup_rcu() instead of doing it in the caller. This results in two annoyances: - __d_lookup_rcu() now not only needs to return the dentry and the sequence number that goes along with the lookup, it also needs to return the inode pointer that was validated by that sequence number check. - and because we did the sequence number check early (to validate the name pointer and length) we also couldn't just pass the dentry itself to dentry_cmp(), we had to pass the counted string that contained the name. So that sequence number decision caused two separate ugly calling conventions. Both of these problems would be solved if we just did the sequence number check in the caller instead. There's only one caller, and that caller already has to do the sequence number check for the parent anyway, so just do that. That allows us to stop returning the dentry->d_inode in that in-out argument (pointer-to-pointer-to-inode), so we can make the inode argument just a regular input inode pointer. The caller can just load the inode from dentry->d_inode, and then do the sequence number check after that to make sure that it's synchronized with the name we looked up. And it allows us to just pass in the dentry to dentry_cmp(), which is what all the callers really wanted. Sure, dentry_cmp() has to be a bit careful about the dentry (which is not stable during RCU lookup), but that's actually very simple. And now that dentry_cmp() can clearly see that the first string argument is a dentry, we can use the direct word access for that, instead of the careful unaligned zero-padding. The dentry name is always properly aligned, since it is a single path component that is either embedded into the dentry itself, or was allocated with kmalloc() (see __d_alloc). Finally, this also uninlines the nasty slow-case for dentry comparisons: that one *does* need to do a sequence number check, since it will call in to the low-level filesystems, and we want to give those a stable inode pointer and path component length/start arguments. Doing an extra sequence check for that slow case is not a problem, though. Signed-off-by: Linus Torvalds <torvalds@linux-foundation.org>
2012-05-03vfs: make word-at-a-time accesses handle a non-existing pageLinus Torvalds
It turns out that there are more cases than CONFIG_DEBUG_PAGEALLOC that can have holes in the kernel address space: it seems to happen easily with Xen, and it looks like the AMD gart64 code will also punch holes dynamically. Actually hitting that case is still very unlikely, so just do the access, and take an exception and fix it up for the very unlikely case of it being a page-crosser with no next page. And hey, this abstraction might even help other architectures that have other issues with unaligned word accesses than the possible missing next page. IOW, this could do the byte order magic too. Peter Anvin fixed a thinko in the shifting for the exception case. Reported-and-tested-by: Jana Saout <jana@saout.de> Cc: Peter Anvin <hpa@zytor.com> Signed-off-by: Linus Torvalds <torvalds@linux-foundation.org>
2012-05-03userns: Use uid_eq gid_eq helpers when comparing kuids and kgids in the vfsEric W. Biederman
Acked-by: Serge Hallyn <serge.hallyn@canonical.com> Signed-off-by: Eric W. Biederman <ebiederm@xmission.com>
2012-04-28VFS: clean up and simplify getname_flags()Linus Torvalds
This removes a number of silly games around strncpy_from_user() in do_getname(), and removes that helper function entirely. We instead make getname_flags() just use strncpy_from_user() properly directly. Removing the wrapper function simplifies things noticeably, mostly because we no longer play the unnecessary games with segments (x86 strncpy_from_user() no longer needs the hack), but also because the empty path handling is just much more obvious. The return value of "strncpy_to_user()" is much more obvious than checking an odd error return case from do_getname(). [ non-x86 architectures were notified of this change several weeks ago, since it is possible that they have copied the old broken x86 strncpy_from_user. But nobody reacted, so .. See http://www.spinics.net/lists/linux-arch/msg17313.html for details ] Cc: linux-arch@vger.kernel.org Signed-off-by: Linus Torvalds <torvalds@linux-foundation.org>
2012-04-07userns: Replace the hard to write inode_userns with inode_capable.Eric W. Biederman
This represents a change in strategy of how to handle user namespaces. Instead of tagging everything explicitly with a user namespace and bulking up all of the comparisons of uids and gids in the kernel, all uids and gids in use will have a mapping to a flat kuid and kgid spaces respectively. This allows much more of the existing logic to be preserved and in general allows for faster code. In this new and improved world we allow someone to utiliize capabilities over an inode if the inodes owner mapps into the capabilities holders user namespace and the user has capabilities in their user namespace. Which is simple and efficient. Moving the fs uid comparisons to be comparisons in a flat kuid space follows in later patches, something that is only significant if you are using user namespaces. Acked-by: Serge Hallyn <serge.hallyn@canonical.com> Signed-off-by: Eric W. Biederman <ebiederm@xmission.com>
2012-04-06Make the "word-at-a-time" helper functions more commonly usableLinus Torvalds
I have a new optimized x86 "strncpy_from_user()" that will use these same helper functions for all the same reasons the name lookup code uses them. This is preparation for that. This moves them into an architecture-specific header file. It's architecture-specific for two reasons: - some of the functions are likely to want architecture-specific implementations. Even if the current code happens to be "generic" in the sense that it should work on any little-endian machine, it's likely that the "multiply by a big constant and shift" implementation is less than optimal for an architecture that has a guaranteed fast bit count instruction, for example. - I expect that if architectures like sparc want to start playing around with this, we'll need to abstract out a few more details (in particular the actual unaligned accesses). So we're likely to have more architecture-specific stuff if non-x86 architectures start using this. (and if it turns out that non-x86 architectures don't start using this, then having it in an architecture-specific header is still the right thing to do, of course) Signed-off-by: Linus Torvalds <torvalds@linux-foundation.org>
2012-04-03vfs: Don't allow a user namespace root to make device nodesEric W. Biederman
Safely making device nodes in a container is solvable but simply having the capability in a user namespace is not sufficient to make this work. Acked-by: Serge Hallyn <serge.hallyn@canonical.com> Signed-off-by: Eric W. Biederman <ebiederm@xmission.com>
2012-03-31vfs: fix out-of-date dentry_unhash() commentJ. Bruce Fields
64252c75a2196a0cf1e0d3777143ecfe0e3ae650 "vfs: remove dget() from dentry_unhash()" changed the implementation but not the comment. Cc: Sage Weil <sage@newdream.net> Signed-off-by: J. Bruce Fields <bfields@redhat.com> Signed-off-by: Al Viro <viro@zeniv.linux.org.uk>
2012-03-31vfs: split __lookup_hashMiklos Szeredi
Split __lookup_hash into two component functions: lookup_dcache - tries cached lookup, returns whether real lookup is needed lookup_real - calls i_op->lookup This eliminates code duplication between d_alloc_and_lookup() and d_inode_lookup(). Signed-off-by: Miklos Szeredi <mszeredi@suse.cz> Signed-off-by: Al Viro <viro@zeniv.linux.org.uk>
2012-03-31untangling do_lookup() - take __lookup_hash()-calling case out of line.Al Viro
2012-03-31untangling do_lookup() - switch to calling __lookup_hash()Al Viro
now we have __lookup_hash() open-coded if !dentry case; just call the damn thing instead... Signed-off-by: Al Viro <viro@zeniv.linux.org.uk>
2012-03-31untangling do_lookup() - merge d_alloc_and_lookup() callersAl Viro
2012-03-31untangling do_lookup() - merge failure exits in !dentry caseAl Viro
2012-03-31untangling do_lookup() - massage !dentry case towards __lookup_hash()Al Viro
Reorder if-else cases for starters... Signed-off-by: Al Viro <viro@zeniv.linux.org.uk>
2012-03-31untangling do_lookup() - get rid of need_reval in !dentry caseAl Viro
Everything arriving into if (!dentry) will have need_reval = 1. Indeed, the only way to get there with need_reval reset to 0 would be via if (unlikely(d_need_lookup(dentry))) goto unlazy; if (unlikely(dentry->d_flags & DCACHE_OP_REVALIDATE)) { status = d_revalidate(dentry, nd); if (unlikely(status <= 0)) { if (status != -ECHILD) need_reval = 0; goto unlazy; ... unlazy: /* no assignments to dentry */ if (dentry && unlikely(d_need_lookup(dentry))) { dput(dentry); dentry = NULL; } and if d_need_lookup() had already been false the first time around, it will remain false on the second call as well. Signed-off-by: Al Viro <viro@zeniv.linux.org.uk>
2012-03-31untangling do_lookup() - eliminate a loop.Al Viro
d_lookup() *will* fail after successful d_invalidate(), if we are holding i_mutex all along. IOW, we don't need to jump back to l: - we know what path will be taken there and can do that (i.e. d_alloc_and_lookup()) directly. Signed-off-by: Al Viro <viro@zeniv.linux.org.uk>
2012-03-31untangling do_lookup() - expand the area under ->i_mutexAl Viro
keep holding ->i_mutex over revalidation parts Signed-off-by: Al Viro <viro@zeniv.linux.org.uk>
2012-03-31untangling do_lookup() - isolate !dentry stuff from the rest of it.Al Viro
Duplicate the revalidation-related parts into if (!dentry) branch. Next step will be to pull them under i_mutex. This and the next 8 commits are more or less a splitup of patch by Miklos; folks, when you are working with something that convoluted, carve your patches up into easily reviewed steps, especially when a lot of codepaths involved are rarely hit... Signed-off-by: Al Viro <viro@zeniv.linux.org.uk>
2012-03-31vfs: move MAY_EXEC check from __lookup_hash()Miklos Szeredi
The only caller of __lookup_hash() that needs the exec permission check on parent is lookup_one_len(). All lookup_hash() callers already checked permission in LOOKUP_PARENT walk. Signed-off-by: Miklos Szeredi <mszeredi@suse.cz> Signed-off-by: Al Viro <viro@zeniv.linux.org.uk>
2012-03-31vfs: don't revalidate just looked up dentryMiklos Szeredi
__lookup_hash() calls ->lookup() if the dentry needs lookup and on success revalidates the dentry (all under dir->i_mutex). While this is harmless it doesn't make a lot of sense. Signed-off-by: Miklos Szeredi <mszeredi@suse.cz> Signed-off-by: Al Viro <viro@zeniv.linux.org.uk>
2012-03-31vfs: fix d_need_lookup/d_revalidate order in do_lookupMiklos Szeredi
Doing revalidate on a dentry which has not yet been looked up makes no sense. Move the d_need_lookup() check before d_revalidate(). Signed-off-by: Miklos Szeredi <mszeredi@suse.cz> Signed-off-by: Al Viro <viro@zeniv.linux.org.uk>
2012-03-24Merge tag 'module-for-3.4' of ↵Linus Torvalds
git://git.kernel.org/pub/scm/linux/kernel/git/paulg/linux Pull cleanup of fs/ and lib/ users of module.h from Paul Gortmaker: "Fix up files in fs/ and lib/ dirs to only use module.h if they really need it. These are trivial in scope vs the work done previously. We now have things where any few remaining cleanups can be farmed out to arch or subsystem maintainers, and I have done so when possible. What is remaining here represents the bits that don't clearly lie within a single arch/subsystem boundary, like the fs dir and the lib dir. Some duplicate includes arising from overlapping fixes from independent subsystem maintainer submissions are also quashed." Fix up trivial conflicts due to clashes with other include file cleanups (including some due to the previous bug.h cleanup pull). * tag 'module-for-3.4' of git://git.kernel.org/pub/scm/linux/kernel/git/paulg/linux: lib: reduce the use of module.h wherever possible fs: reduce the use of module.h wherever possible includecheck: delete any duplicate instances of module.h
2012-03-22vfs: tidy up sparse warnings in fs/namei.cLinus Torvalds
While doing the fs/namei.c cleanups, I ran sparse on it, and it pointed out other large integers and a couple of cases of us using '0' instead of the proper 'NULL'. Sparse still doesn't understand some of the conditional locking going on, but that's no excuse for not fixing up the trivial stuff. Signed-off-by: Linus Torvalds <torvalds@linux-foundation.org>
2012-03-22vfs: tidy up fs/namei.c byte-repeat word constantsLinus Torvalds
In commit commit 1de5b41cd3b2 ("fs/namei.c: fix warnings on 32-bit") Andrew said that there must be a tidier way of doing this. This is that tidier way. Signed-off-by: Linus Torvalds <torvalds@linux-foundation.org>
2012-03-22Fix full_name_hash() behaviour when length is a multiple of 8Al Viro
We want it to match what hash_name() is doing, which means extra multiply by 9 in this case... Reported-and-Tested-by: Konrad Rzeszutek Wilk <konrad.wilk@oracle.com> Signed-off-by: Al Viro <viro@zeniv.linux.org.uk> Signed-off-by: Linus Torvalds <torvalds@linux-foundation.org>
2012-03-22Merge branch 'akpm' (Andrew's patch-bomb)Linus Torvalds
Merge first batch of patches from Andrew Morton: "A few misc things and all the MM queue" * emailed from Andrew Morton <akpm@linux-foundation.org>: (92 commits) memcg: avoid THP split in task migration thp: add HPAGE_PMD_* definitions for !CONFIG_TRANSPARENT_HUGEPAGE memcg: clean up existing move charge code mm/memcontrol.c: remove unnecessary 'break' in mem_cgroup_read() mm/memcontrol.c: remove redundant BUG_ON() in mem_cgroup_usage_unregister_event() mm/memcontrol.c: s/stealed/stolen/ memcg: fix performance of mem_cgroup_begin_update_page_stat() memcg: remove PCG_FILE_MAPPED memcg: use new logic for page stat accounting memcg: remove PCG_MOVE_LOCK flag from page_cgroup memcg: simplify move_account() check memcg: remove EXPORT_SYMBOL(mem_cgroup_update_page_stat) memcg: kill dead prev_priority stubs memcg: remove PCG_CACHE page_cgroup flag memcg: let css_get_next() rely upon rcu_read_lock() cgroup: revert ss_id_lock to spinlock idr: make idr_get_next() good for rcu_read_lock() memcg: remove unnecessary thp check in page stat accounting memcg: remove redundant returns memcg: enum lru_list lru ...
2012-03-21fs/namei.c: fix warnings on 32-bitAndrew Morton
i386 allnoconfig: fs/namei.c: In function 'has_zero': fs/namei.c:1617: warning: integer constant is too large for 'unsigned long' type fs/namei.c:1617: warning: integer constant is too large for 'unsigned long' type fs/namei.c: In function 'hash_name': fs/namei.c:1635: warning: integer constant is too large for 'unsigned long' type There must be a tidier way of doing this. Signed-off-by: Andrew Morton <akpm@linux-foundation.org> Signed-off-by: Linus Torvalds <torvalds@linux-foundation.org>
2012-03-21Merge branch 'for-linus' of ↵Linus Torvalds
git://git.kernel.org/pub/scm/linux/kernel/git/viro/vfs Pull vfs pile 1 from Al Viro: "This is _not_ all; in particular, Miklos' and Jan's stuff is not there yet." * 'for-linus' of git://git.kernel.org/pub/scm/linux/kernel/git/viro/vfs: (64 commits) ext4: initialization of ext4_li_mtx needs to be done earlier debugfs-related mode_t whack-a-mole hfsplus: add an ioctl to bless files hfsplus: change finder_info to u32 hfsplus: initialise userflags qnx4: new helper - try_extent() qnx4: get rid of qnx4_bread/qnx4_getblk take removal of PF_FORKNOEXEC to flush_old_exec() trim includes in inode.c um: uml_dup_mmap() relies on ->mmap_sem being held, but activate_mm() doesn't hold it um: embed ->stub_pages[] into mmu_context gadgetfs: list_for_each_safe() misuse ocfs2: fix leaks on failure exits in module_init ecryptfs: make register_filesystem() the last potential failure exit ntfs: forgets to unregister sysctls on register_filesystem() failure logfs: missing cleanup on register_filesystem() failure jfs: mising cleanup on register_filesystem() failure make configfs_pin_fs() return root dentry on success configfs: configfs_create_dir() has parent dentry in dentry->d_parent configfs: sanitize configfs_create() ...
2012-03-21Merge branch 'kmap_atomic' of git://github.com/congwang/linuxLinus Torvalds
Pull kmap_atomic cleanup from Cong Wang. It's been in -next for a long time, and it gets rid of the (no longer used) second argument to k[un]map_atomic(). Fix up a few trivial conflicts in various drivers, and do an "evil merge" to catch some new uses that have come in since Cong's tree. * 'kmap_atomic' of git://github.com/congwang/linux: (59 commits) feature-removal-schedule.txt: schedule the deprecated form of kmap_atomic() for removal highmem: kill all __kmap_atomic() [swarren@nvidia.com: highmem: Fix ARM build break due to __kmap_atomic rename] drbd: remove the second argument of k[un]map_atomic() zcache: remove the second argument of k[un]map_atomic() gma500: remove the second argument of k[un]map_atomic() dm: remove the second argument of k[un]map_atomic() tomoyo: remove the second argument of k[un]map_atomic() sunrpc: remove the second argument of k[un]map_atomic() rds: remove the second argument of k[un]map_atomic() net: remove the second argument of k[un]map_atomic() mm: remove the second argument of k[un]map_atomic() lib: remove the second argument of k[un]map_atomic() power: remove the second argument of k[un]map_atomic() kdb: remove the second argument of k[un]map_atomic() udf: remove the second argument of k[un]map_atomic() ubifs: remove the second argument of k[un]map_atomic() squashfs: remove the second argument of k[un]map_atomic() reiserfs: remove the second argument of k[un]map_atomic() ocfs2: remove the second argument of k[un]map_atomic() ntfs: remove the second argument of k[un]map_atomic() ...
2012-03-20switch touch_atime to struct pathAl Viro
2012-03-20vfs: check i_nlink limits in vfs_{mkdir,rename_dir,link}Al Viro
New field of struct super_block - ->s_max_links. Maximal allowed value of ->i_nlink or 0; in the latter case all checks still need to be done in ->link/->mkdir/->rename instances. Note that this limit applies both to directoris and to non-directories. Signed-off-by: Al Viro <viro@zeniv.linux.org.uk>
2012-03-20fs: remove the second argument of k[un]map_atomic()Cong Wang
Acked-by: Benjamin LaHaise <bcrl@kvack.org> Signed-off-by: Cong Wang <amwang@redhat.com>
