commit 946e51f2bf37f1656916eb75bd0742ba33983c28 upstream.
sys_tz is already declared in include/linux/time.h
Signed-off-by: Fabian Frederick <fabf@skynet.be>
Cc: Petr Vandrovec <petr@vandrovec.name>
Remove obsolete simple_strtoul in ncp_getopt
Pull yet more networking updates from David Miller:
1) Various fixes to the new Redpine Signals wireless driver, from
Fariya Fatima.
2) L2TP PPP connect code takes PMTU from the wrong socket, fix from
Dmitry Petukhov.
3) UFO and TSO packets differ in whether they include the protocol
header in gso_size, account for that in skb_gso_transport_seglen().
From Florian Westphal.
4) If VLAN untagging fails, we double free the SKB in the bridging
output path. From Toshiaki Makita.
5) Several call sites of sk->sk_data_ready() were referencing an SKB
just added to the socket receive queue in order to calculate the
second argument via skb->len. This is dangerous because the moment
the skb is added to the receive queue it can be consumed in another
context and freed up.
It turns out also that none of the sk->sk_data_ready()
implementations even care about this second argument.
So just kill it off and thus fix all these use-after-free bugs as a
side effect.
6) Fix inverted test in tcp_v6_send_response(), from Lorenzo Colitti.
7) pktgen needs to do locking properly for LLTX devices, from Daniel
Borkmann.
8) xen-netfront driver initializes TX array entries in RX loop :-) From
Vincenzo Maffione.
9) After refactoring, some tunnel drivers allow a tunnel to be
configured on top itself. Fix from Nicolas Dichtel.
* git://git.kernel.org/pub/scm/linux/kernel/git/davem/net: (46 commits)
vti: don't allow to add the same tunnel twice
gre: don't allow to add the same tunnel twice
drivers: net: xen-netfront: fix array initialization bug
pktgen: be friendly to LLTX devices
r8152: check RTL8152_UNPLUG
net: sun4i-emac: add promiscuous support
net/apne: replace IS_ERR and PTR_ERR with PTR_ERR_OR_ZERO
net: ipv6: Fix oif in TCP SYN+ACK route lookup.
drivers: net: cpsw: enable interrupts after napi enable and clearing previous interrupts
drivers: net: cpsw: discard all packets received when interface is down
net: Fix use after free by removing length arg from sk_data_ready callbacks.
Drivers: net: hyperv: Address UDP checksum issues
Drivers: net: hyperv: Negotiate suitable ndis version for offload support
Drivers: net: hyperv: Allocate memory for all possible per-pecket information
bridge: Fix double free and memory leak around br_allowed_ingress
bonding: Remove debug_fs files when module init fails
i40evf: program RSS LUT correctly
i40evf: remove open-coded skb_cow_head
ixgb: remove open-coded skb_cow_head
igbvf: remove open-coded skb_cow_head
Pull vfs updates from Al Viro:
"The first vfs pile, with deep apologies for being very late in this
window.
Assorted cleanups and fixes, plus a large preparatory part of iov_iter
work. There's a lot more of that, but it'll probably go into the next
merge window - it *does* shape up nicely, removes a lot of
boilerplate, gets rid of locking inconsistencie between aio_write and
splice_write and I hope to get Kent's direct-io rewrite merged into
the same queue, but some of the stuff after this point is having
(mostly trivial) conflicts with the things already merged into
mainline and with some I want more testing.
This one passes LTP and xfstests without regressions, in addition to
usual beating. BTW, readahead02 in ltp syscalls testsuite has started
giving failures since "mm/readahead.c: fix readahead failure for
memoryless NUMA nodes and limit readahead pages" - might be a false
positive, might be a real regression..."
* 'for-linus' of git://git.kernel.org/pub/scm/linux/kernel/git/viro/vfs: (63 commits)
missing bits of "splice: fix racy pipe->buffers uses"
cifs: fix the race in cifs_writev()
ceph_sync_{,direct_}write: fix an oops on ceph_osdc_new_request() failure
kill generic_file_buffered_write()
ocfs2_file_aio_write(): switch to generic_perform_write()
ceph_aio_write(): switch to generic_perform_write()
xfs_file_buffered_aio_write(): switch to generic_perform_write()
export generic_perform_write(), start getting rid of generic_file_buffer_write()
generic_file_direct_write(): get rid of ppos argument
btrfs_file_aio_write(): get rid of ppos
kill the 5th argument of generic_file_buffered_write()
kill the 4th argument of __generic_file_aio_write()
lustre: don't open-code kernel_recvmsg()
ocfs2: don't open-code kernel_recvmsg()
drbd: don't open-code kernel_recvmsg()
constify blk_rq_map_user_iov() and friends
lustre: switch to kernel_sendmsg()
ocfs2: don't open-code kernel_sendmsg()
take iov_iter stuff to mm/iov_iter.c
process_vm_access: tidy up a bit
Several spots in the kernel perform a sequence like:
skb_queue_tail(&sk->s_receive_queue, skb);
sk->sk_data_ready(sk, skb->len);
But at the moment we place the SKB onto the socket receive queue it
can be consumed and freed up. So this skb->len access is potentially
to freed up memory.
Furthermore, the skb->len can be modified by the consumer so it is
possible that the value isn't accurate.
And finally, no actual implementation of this callback actually uses
the length argument. And since nobody actually cared about it's
value, lots of call sites pass arbitrary values in such as '0' and
even '1'.
So just remove the length argument from the callback, that way there
is no confusion whatsoever and all of these use-after-free cases get
fixed as a side effect.
Based upon a patch by Eric Dumazet and his suggestion to audit this
issue tree-wide.
My static checker suggests adding curly braces here. Probably that was
the intent, but actually the code works the same either way. I've just
changed the indenting and left the code as-is.
Acked-by: Dave Chiluk <chiluk@canonical.com>
Conversions to ncp_dbg showed some format/argument mismatches so fix
them.
Uses are gone, remove the macro.
Use a more current logging style.
Convert the paranoia debug statement to vdbg.
Remove the embedded function names as dynamic_debug can do that.
Use a more current logging style and enable use of dynamic debugging.
Remove embedded function names, dynamic debug can add this instead.
Convert to a more current logging style.
Add pr_fmt to prefix with "ncpfs: ".
Remove the embedded function names and use "%s: ", __func__
Some previously unprefixed messages now have "ncpfs: "
git://git.kernel.org/pub/scm/linux/kernel/git/tytso/ext4
Pull ext4 updates from Ted Ts'o:
"Major changes for 3.14 include support for the newly added ZERO_RANGE
and COLLAPSE_RANGE fallocate operations, and scalability improvements
in the jbd2 layer and in xattr handling when the extended attributes
spill over into an external block.
Other than that, the usual clean ups and minor bug fixes"
* tag 'ext4_for_linus' of git://git.kernel.org/pub/scm/linux/kernel/git/tytso/ext4: (42 commits)
ext4: fix premature freeing of partial clusters split across leaf blocks
ext4: remove unneeded test of ret variable
ext4: fix comment typo
ext4: make ext4_block_zero_page_range static
ext4: atomically set inode->i_flags in ext4_set_inode_flags()
ext4: optimize Hurd tests when reading/writing inodes
ext4: kill i_version support for Hurd-castrated file systems
ext4: each filesystem creates and uses its own mb_cache
fs/mbcache.c: doucple the locking of local from global data
fs/mbcache.c: change block and index hash chain to hlist_bl_node
ext4: Introduce FALLOC_FL_ZERO_RANGE flag for fallocate
ext4: refactor ext4_fallocate code
ext4: Update inode i_size after the preallocation
ext4: fix partial cluster handling for bigalloc file systems
ext4: delete path dealloc code in ext4_ext_handle_uninitialized_extents
ext4: only call sync_filesystm() when remounting read-only
fs: push sync_filesystem() down to the file system's remount_fs()
jbd2: improve error messages for inconsistent journal heads
jbd2: minimize region locked by j_list_lock in jbd2_journal_forget()
jbd2: minimize region locked by j_list_lock in journal_get_create_access()
Reclaim will be leaving shadow entries in the page cache radix tree upon
evicting the real page. As those pages are found from the LRU, an
iput() can lead to the inode being freed concurrently. At this point,
reclaim must no longer install shadow pages because the inode freeing
code needs to ensure the page tree is really empty.
Add an address_space flag, AS_EXITING, that the inode freeing code sets
under the tree lock before doing the final truncate. Reclaim will check
for this flag before installing shadow pages.
Signed-off-by: Johannes Weiner <hannes@cmpxchg.org>
Reviewed-by: Minchan Kim <minchan@kernel.org>
Cc: Bob Liu <bob.liu@oracle.com>
Cc: Jan Kara <jack@suse.cz>
Cc: Luigi Semenzato <semenzato@google.com>
Cc: Metin Doslu <metin@citusdata.com>
Cc: Michel Lespinasse <walken@google.com>
Cc: Ozgun Erdogan <ozgun@citusdata.com>
Cc: Roman Gushchin <klamm@yandex-team.ru>
Cc: Ryan Mallon <rmallon@gmail.com>
Cc: Tejun Heo <tj@kernel.org>
Previously, the no-op "mount -o mount /dev/xxx" operation when the
file system is already mounted read-write causes an implied,
unconditional syncfs(). This seems pretty stupid, and it's certainly
documented or guaraunteed to do this, nor is it particularly useful,
except in the case where the file system was mounted rw and is getting
remounted read-only.
However, it's possible that there might be some file systems that are
actually depending on this behavior. In most file systems, it's
probably fine to only call sync_filesystem() when transitioning from
read-write to read-only, and there are some file systems where this is
not needed at all (for example, for a pseudo-filesystem or something
like romfs).
Signed-off-by: "Theodore Ts'o" <tytso@mit.edu>
Cc: linux-fsdevel@vger.kernel.org
Cc: Artem Bityutskiy <dedekind1@gmail.com>
Cc: Adrian Hunter <adrian.hunter@intel.com>
Cc: Evgeniy Dushistov <dushistov@mail.ru>
Cc: OGAWA Hirofumi <hirofumi@mail.parknet.co.jp>
Cc: Anders Larsen <al@alarsen.net>
Cc: Phillip Lougher <phillip@squashfs.org.uk>
Cc: Mikulas Patocka <mikulas@artax.karlin.mff.cuni.cz>
Cc: xfs@oss.sgi.com
Cc: linux-btrfs@vger.kernel.org
Cc: linux-cifs@vger.kernel.org
Cc: samba-technical@lists.samba.org
Cc: codalist@coda.cs.cmu.edu
Cc: linux-ext4@vger.kernel.org
Cc: linux-f2fs-devel@lists.sourceforge.net
Cc: fuse-devel@lists.sourceforge.net
Cc: cluster-devel@redhat.com
Cc: linux-mtd@lists.infradead.org
Cc: jfs-discussion@lists.sourceforge.net
Cc: linux-nfs@vger.kernel.org
Cc: linux-nilfs@vger.kernel.org
Cc: linux-ntfs-dev@lists.sourceforge.net
Cc: ocfs2-devel@oss.oracle.com
Cc: reiserfs-devel@vger.kernel.org
makes ->d_hash() and ->d_compare() safety in RCU mode independent
from vfsmount_lock.
Fix to return -EINVAL from the option parse error handling
case instead of 0, as done elsewhere in this function.
Signed-off-by: Wei Yongjun <yongjun_wei@trendmicro.com.cn>
(*->vm_end - *->vm_start) >> PAGE_SHIFT operation is implemented
as a inline funcion vma_pages() in linux/mm.h, so using it.
Signed-off-by: Libin <huawei.libin@huawei.com>
Instances either don't look at it at all (the majority of cases) or
only want it to find the superblock (which can be had as dentry->d_sb).
A few cases that want more are actually safe with dentry->d_inode -
the only precaution needed is the check that it hadn't been replaced with
NULL by rmdir() or by overwriting rename(), which case should be simply
treated as cache miss.
the only remaining caller (in ncpfs) is guaranteed to return 0 -
we only hit it if we'd just checked that there's no dentry with
such name.
1d2ef5901483004d74947bbf78d5146c24038fe7 caused a regression in ncpfs such that
directories could no longer be removed. This was because ncp_rmdir checked
to see if a dentry could be unhashed before allowing it to be removed. Since
1d2ef5901483004d74947bbf78d5146c24038fe7 introduced a change that incremented
dentry->d_count causing it to always be greater than 1 unhash would always
fail. Thus causing the error path in ncp_rmdir to always be taken. Removing
this error path is safe as unhashing is still accomplished by calls to dput
from vfs_rmdir.
Signed-off-by: Dave Chiluk <chiluk@canonical.com>
Signed-off-by: Petr Vandrovec <petr@vandrovec.name>
Modify the request_module to prefix the file system type with "fs-"
and add aliases to all of the filesystems that can be built as modules
to match.
A common practice is to build all of the kernel code and leave code
that is not commonly needed as modules, with the result that many
users are exposed to any bug anywhere in the kernel.
Looking for filesystems with a fs- prefix limits the pool of possible
modules that can be loaded by mount to just filesystems trivially
making things safer with no real cost.
Using aliases means user space can control the policy of which
filesystem modules are auto-loaded by editing /etc/modprobe.d/*.conf
with blacklist and alias directives. Allowing simple, safe,
well understood work-arounds to known problematic software.
This also addresses a rare but unfortunate problem where the filesystem
name is not the same as it's module name and module auto-loading
would not work. While writing this patch I saw a handful of such
cases. The most significant being autofs that lives in the module
autofs4.
This is relevant to user namespaces because we can reach the request
module in get_fs_type() without having any special permissions, and
people get uncomfortable when a user specified string (in this case
the filesystem type) goes all of the way to request_module.
After having looked at this issue I don't think there is any
particular reason to perform any filtering or permission checks beyond
making it clear in the module request that we want a filesystem
module. The common pattern in the kernel is to call request_module()
without regards to the users permissions. In general all a filesystem
module does once loaded is call register_filesystem() and go to sleep.
Which means there is not much attack surface exposed by loading a
filesytem module unless the filesystem is mounted. In a user
namespace filesystems are not mounted unless .fs_flags = FS_USERNS_MOUNT,
which most filesystems do not set today.
Acked-by: Serge Hallyn <serge.hallyn@canonical.com>
Reported-by: Kees Cook <keescook@google.com>
Pull vfs pile (part one) from Al Viro:
"Assorted stuff - cleaning namei.c up a bit, fixing ->d_name/->d_parent
locking violations, etc.
The most visible changes here are death of FS_REVAL_DOT (replaced with
"has ->d_weak_revalidate()") and a new helper getting from struct file
to inode. Some bits of preparation to xattr method interface changes.
Misc patches by various people sent this cycle *and* ocfs2 fixes from
several cycles ago that should've been upstream right then.
PS: the next vfs pile will be xattr stuff."
* 'for-linus' of git://git.kernel.org/pub/scm/linux/kernel/git/viro/vfs: (46 commits)
saner proc_get_inode() calling conventions
proc: avoid extra pde_put() in proc_fill_super()
fs: change return values from -EACCES to -EPERM
fs/exec.c: make bprm_mm_init() static
ocfs2/dlm: use GFP_ATOMIC inside a spin_lock
ocfs2: fix possible use-after-free with AIO
ocfs2: Fix oops in ocfs2_fast_symlink_readpage() code path
get_empty_filp()/alloc_file() leave both ->f_pos and ->f_version zero
target: writev() on single-element vector is pointless
export kernel_write(), convert open-coded instances
fs: encode_fh: return FILEID_INVALID if invalid fid_type
kill f_vfsmnt
vfs: kill FS_REVAL_DOT by adding a d_weak_revalidate dentry op
nfsd: handle vfs_getattr errors in acl protocol
switch vfs_getattr() to struct path
default SET_PERSONALITY() in linux/elf.h
ceph: prepopulate inodes only when request is aborted
d_hash_and_lookup(): export, switch open-coded instances
9p: switch v9fs_set_create_acl() to inode+fid, do it before d_instantiate()
9p: split dropping the acls from v9fs_set_create_acl()
According to SUSv3:
[EACCES] Permission denied. An attempt was made to access a file in a way
forbidden by its file access permissions.
[EPERM] Operation not permitted. An attempt was made to perform an operation
limited to processes with appropriate privileges or to the owner of a file
or other resource.
So -EPERM should be returned if capability checks fails.
Strictly speaking this is an API change since the error code user sees is
altered.
Signed-off-by: Zhao Hongjiang <zhaohongjiang@huawei.com>
Acked-by: Jan Kara <jack@suse.cz>
Acked-by: Steven Whitehouse <swhiteho@redhat.com>
Acked-by: Ian Kent <raven@themaw.net>
* calling conventions change - ERR_PTR() is returned on ->d_hash() errors;
NULL is just for dcache miss now.
* exported, open-coded instances in ncpfs and cifs converted.
ncpfs does not natively support uids and gids so this conversion was
simply a matter of updating the the type of the mounteduid, the uid
and the gid on the superblock. Fixing the ioctls that read them,
updating the mount option parser and the mount option printer.
Removed vmtruncate
Signed-off-by: Marco Stornelli <marco.stornelli@gmail.com>
I've legally changed my name with New York State, the US Social Security
Administration, et al. This patch propagates the name change and change
in initials and login to comments in the kernel source as well.
Signed-off-by: Nadia Yvette Chambers <nyc@holomorphy.com>
Pull vfs update from Al Viro:
- big one - consolidation of descriptor-related logics; almost all of
that is moved to fs/file.c
(BTW, I'm seriously tempted to rename the result to fd.c. As it is,
we have a situation when file_table.c is about handling of struct
file and file.c is about handling of descriptor tables; the reasons
are historical - file_table.c used to be about a static array of
struct file we used to have way back).
A lot of stray ends got cleaned up and converted to saner primitives,
disgusting mess in android/binder.c is still disgusting, but at least
doesn't poke so much in descriptor table guts anymore. A bunch of
relatively minor races got fixed in process, plus an ext4 struct file
leak.
- related thing - fget_light() partially unuglified; see fdget() in
there (and yes, it generates the code as good as we used to have).
- also related - bits of Cyrill's procfs stuff that got entangled into
that work; _not_ all of it, just the initial move to fs/proc/fd.c and
switch of fdinfo to seq_file.
- Alex's fs/coredump.c spiltoff - the same story, had been easier to
take that commit than mess with conflicts. The rest is a separate
pile, this was just a mechanical code movement.
- a few misc patches all over the place. Not all for this cycle,
there'll be more (and quite a few currently sit in akpm's tree)."
Fix up trivial conflicts in the android binder driver, and some fairly
simple conflicts due to two different changes to the sock_alloc_file()
interface ("take descriptor handling from sock_alloc_file() to callers"
vs "net: Providing protocol type via system.sockprotoname xattr of
/proc/PID/fd entries" adding a dentry name to the socket)
* 'for-linus' of git://git.kernel.org/pub/scm/linux/kernel/git/viro/vfs: (72 commits)
MAX_LFS_FILESIZE should be a loff_t
compat: fs: Generic compat_sys_sendfile implementation
fs: push rcu_barrier() from deactivate_locked_super() to filesystems
btrfs: reada_extent doesn't need kref for refcount
coredump: move core dump functionality into its own file
coredump: prevent double-free on an error path in core dumper
usb/gadget: fix misannotations
fcntl: fix misannotations
ceph: don't abuse d_delete() on failure exits
hypfs: ->d_parent is never NULL or negative
vfs: delete surplus inode NULL check
switch simple cases of fget_light to fdget
new helpers: fdget()/fdput()
switch o2hb_region_dev_write() to fget_light()
proc_map_files_readdir(): don't bother with grabbing files
make get_file() return its argument
vhost_set_vring(): turn pollstart/pollstop into bool
switch prctl_set_mm_exe_file() to fget_light()
switch xfs_find_handle() to fget_light()
switch xfs_swapext() to fget_light()
There's no reason to call rcu_barrier() on every
deactivate_locked_super(). We only need to make sure that all delayed rcu
free inodes are flushed before we destroy related cache.
Removing rcu_barrier() from deactivate_locked_super() affects some fast
paths. E.g. on my machine exit_group() of a last process in IPC
namespace takes 0.07538s. rcu_barrier() takes 0.05188s of that time.
flush[_delayed]_work_sync() are now spurious. Mark them deprecated
and convert all users to flush[_delayed]_work().
If you're cc'd and wondering what's going on: Now all workqueues are
non-reentrant and the regular flushes guarantee that the work item is
not pending or running on any CPU on return, so there's no reason to
use the sync flushes at all and they're going away.
This patch doesn't make any functional difference.
Cc: Ian Campbell <ian.campbell@citrix.com>
Cc: Mattia Dongili <malattia@linux.it>
Cc: Kent Yoder <key@linux.vnet.ibm.com>
Cc: David Airlie <airlied@linux.ie>
Cc: Jiri Kosina <jkosina@suse.cz>
Cc: Karsten Keil <isdn@linux-pingi.de>
Cc: Bryan Wu <bryan.wu@canonical.com>
Cc: Alasdair Kergon <agk@redhat.com>
Cc: Mauro Carvalho Chehab <mchehab@infradead.org>
Cc: Florian Tobias Schandinat <FlorianSchandinat@gmx.de>
Cc: linux-wireless@vger.kernel.org
Cc: Anton Vorontsov <cbou@mail.ru>
Cc: Sangbeom Kim <sbkim73@samsung.com>
Cc: "James E.J. Bottomley" <James.Bottomley@HansenPartnership.com>
Cc: Eric Van Hensbergen <ericvh@gmail.com>
Cc: Takashi Iwai <tiwai@suse.de>
Cc: Steven Whitehouse <swhiteho@redhat.com>
Cc: Mark Fasheh <mfasheh@suse.com>
Cc: Avi Kivity <avi@redhat.com>
boolean "does it have to be exclusive?" flag is passed instead;
Local filesystem should just ignore it - the object is guaranteed
not to be there yet.
Just the flags; only NFS cares even about that, but there are
legitimate uses for such argument. And getting rid of that
completely would require splitting ->lookup() into a couple
of methods (at least), so let's leave that alone for now...
Just the lookup flags. Die, bastard, die...
Btrfs has to make sure we have space to allocate new blocks in order to modify
the inode, so updating time can fail. We've gotten around this by having our
own file_update_time but this is kind of a pain, and Christoph has indicated he
would like to make xfs do something different with atime updates. So introduce
->update_time, where we will deal with i_version an a/m/c time updates and
indicate which changes need to be made. The normal version just does what it
has always done, updates the time and marks the inode dirty, and then
filesystems can choose to do something different.
I've gone through all of the users of file_update_time and made them check for
errors with the exception of the fault code since it's complicated and I wasn't
quite sure what to do there, also Jan is going to be pushing the file time
updates into page_mkwrite for those who have it so that should satisfy btrfs and
make it not a big deal to check the file_update_time() return code in the
generic fault path. Thanks,
Signed-off-by: Josef Bacik <josef@redhat.com>
structure
After we moved inode_sync_wait() from end_writeback() it doesn't make sense
to call the function end_writeback() anymore. Rename it to clear_inode()
which well says what the function really does - set I_CLEAR flag.
Signed-off-by: Fengguang Wu <fengguang.wu@intel.com>
Remove all #inclusions of asm/system.h preparatory to splitting and killing
it. Performed with the following command:
perl -p -i -e 's!^#\s*include\s*<asm/system[.]h>.*\n!!' `grep -Irl '^#\s*include\s*<asm/system[.]h>' *`
vfs_create() ignores everything outside of 16bit subset of its
mode argument; switching it to umode_t is obviously equivalent
and it's the only caller of the method
vfs_mkdir() gets int, but immediately drops everything that might not
fit into umode_t and that's the only caller of ->mkdir()...
