commit 698b8223631472bf982ed570b0812faa61955683 upstream.
1d2ef5901483004d74947bbf78d5146c24038fe7 caused a regression in ncpfs such that
directories could no longer be removed. This was because ncp_rmdir checked
to see if a dentry could be unhashed before allowing it to be removed. Since
1d2ef5901483004d74947bbf78d5146c24038fe7 introduced a change that incremented
dentry->d_count causing it to always be greater than 1 unhash would always
fail. Thus causing the error path in ncp_rmdir to always be taken. Removing
this error path is safe as unhashing is still accomplished by calls to dput
from vfs_rmdir.
Signed-off-by: Dave Chiluk <chiluk@canonical.com>
Signed-off-by: Petr Vandrovec <petr@vandrovec.name>
Cc: Rui Xiang <rui.xiang@huawei.com>
Remove all #inclusions of asm/system.h preparatory to splitting and killing
it. Performed with the following command:
perl -p -i -e 's!^#\s*include\s*<asm/system[.]h>.*\n!!' `grep -Irl '^#\s*include\s*<asm/system[.]h>' *`
vfs_create() ignores everything outside of 16bit subset of its
mode argument; switching it to umode_t is obviously equivalent
and it's the only caller of the method
vfs_mkdir() gets int, but immediately drops everything that might not
fit into umode_t and that's the only caller of ->mkdir()...
Seeing that just about every destructor got that INIT_LIST_HEAD() copied into
it, there is no point whatsoever keeping this INIT_LIST_HEAD in inode_init_once();
the cost of taking it into inode_init_always() will be negligible for pipes
and sockets and negative for everything else. Not to mention the removal of
boilerplate code from ->destroy_inode() instances...
new helper (wrapper around mnt_drop_write()) to be used in pair with
mnt_want_write_file().
The label 'out_bdi' should be followed by bdi_destroy() instead of
fput() which should be after the 'out_fput' label.
If bdi_setup_and_register() fails then jump to the 'out_fput' label
instead of the 'out_bdi' one.
If fget(data.info_fd) fails then jump to the previously fixed 'out_bdi'
label to call bdi_destroy() otherwise the bdi object will not be
destroyed.
Compile tested only.
Signed-off-by: Djalal Harouni <tixxdz@opendz.org>
Replace remaining direct i_nlink updates with a new set_nlink()
updater function.
Signed-off-by: Miklos Szeredi <mszeredi@suse.cz>
Tested-by: Toshiyuki Okajima <toshi.okajima@jp.fujitsu.com>
Btrfs needs to be able to control how filemap_write_and_wait_range() is called
in fsync to make it less of a painful operation, so push down taking i_mutex and
the calling of filemap_write_and_wait() down into the ->fsync() handlers. Some
file systems can drop taking the i_mutex altogether it seems, like ext3 and
ocfs2. For correctness sake I just pushed everything down in all cases to make
sure that we keep the current behavior the same for everybody, and then each
individual fs maintainer can make up their mind about what to do from there.
Thanks,
Acked-by: Jan Kara <jack@suse.cz>
Signed-off-by: Josef Bacik <josef@redhat.com>
ncpfs does not handle references to unlinked directories (or so it would
seem given the ncp_rmdir check). Since it is also possible to rename over
an empty directory, perform the same check here.
CC: Petr Vandrovec <petr@vandrovec.name>
CC: linux-kernel@vger.kernel.org
Signed-off-by: Sage Weil <sage@newdream.net>
ncpfs returns EBUSY if there are any references to the directory. The
dentry_unhash call only unhashes the dentry if there are no references.
Two new stats in per-memcg memory.stat which tracks the number of page
faults and number of major page faults.
"pgfault"
"pgmajfault"
They are different from "pgpgin"/"pgpgout" stat which count number of
pages charged/discharged to the cgroup and have no meaning of reading/
writing page to disk.
It is valuable to track the two stats for both measuring application's
performance as well as the efficiency of the kernel page reclaim path.
Counting pagefaults per process is useful, but we also need the aggregated
value since processes are monitored and controlled in cgroup basis in
memcg.
Functional test: check the total number of pgfault/pgmajfault of all
memcgs and compare with global vmstat value:
$ cat /proc/vmstat | grep fault
pgfault 1070751
pgmajfault 553
$ cat /dev/cgroup/memory.stat | grep fault
pgfault 1071138
pgmajfault 553
total_pgfault 1071142
total_pgmajfault 553
$ cat /dev/cgroup/A/memory.stat | grep fault
pgfault 199
pgmajfault 0
total_pgfault 199
total_pgmajfault 0
Performance test: run page fault test(pft) wit 16 thread on faulting in
15G anon pages in 16G container. There is no regression noticed on the
"flt/cpu/s"
Sample output from pft:
TAG pft:anon-sys-default:
Gb Thr CLine User System Wall flt/cpu/s fault/wsec
15 16 1 0.67s 233.41s 14.76s 16798.546 266356.260
N Min Max Median Avg Stddev
x 10 16682.962 17344.027 16913.524 16928.812 166.5362
+ 10 16695.568 16923.896 16820.604 16824.652 84.816568
No difference proven at 95.0% confidence
[akpm@linux-foundation.org: fix build]
[hughd@google.com: shmem fix]
Signed-off-by: Ying Han <yinghan@google.com>
Acked-by: KAMEZAWA Hiroyuki <kamezawa.hiroyu@jp.fujitsu.com>
Reviewed-by: Minchan Kim <minchan.kim@gmail.com>
Cc: Daisuke Nishimura <nishimura@mxp.nes.nec.co.jp>
Acked-by: Balbir Singh <balbir@linux.vnet.ibm.com>
git://git.kernel.org/pub/scm/linux/kernel/git/viro/vfs-2.6
* 'for-linus' of git://git.kernel.org/pub/scm/linux/kernel/git/viro/vfs-2.6: (25 commits)
cifs: remove unnecessary dentry_unhash on rmdir/rename_dir
ocfs2: remove unnecessary dentry_unhash on rmdir/rename_dir
exofs: remove unnecessary dentry_unhash on rmdir/rename_dir
nfs: remove unnecessary dentry_unhash on rmdir/rename_dir
ext2: remove unnecessary dentry_unhash on rmdir/rename_dir
ext3: remove unnecessary dentry_unhash on rmdir/rename_dir
ext4: remove unnecessary dentry_unhash on rmdir/rename_dir
btrfs: remove unnecessary dentry_unhash in rmdir/rename_dir
ceph: remove unnecessary dentry_unhash calls
vfs: clean up vfs_rename_other
vfs: clean up vfs_rename_dir
vfs: clean up vfs_rmdir
vfs: fix vfs_rename_dir for FS_RENAME_DOES_D_MOVE filesystems
libfs: drop unneeded dentry_unhash
vfs: update dentry_unhash() comment
vfs: push dentry_unhash on rename_dir into file systems
vfs: push dentry_unhash on rmdir into file systems
vfs: remove dget() from dentry_unhash()
vfs: dentry_unhash immediately prior to rmdir
vfs: Block mmapped writes while the fs is frozen
Only a few file systems need this. Start by pushing it down into each
rename method (except gfs2 and xfs) so that it can be dealt with on a
per-fs basis.
Acked-by: Christoph Hellwig <hch@lst.de>
fs rmdir method (except gfs2 and xfs) so it can be dealt with on a per-fs
basis.
This does not change behavior for any in-tree file systems.
We get this spurious warning:
fs/ncpfs/inode.c: In function 'ncp_fill_super':
fs/ncpfs/inode.c:451: warning: 'data.mounted_vol[1u]' may be used uninitialized in this function
fs/ncpfs/inode.c:451: warning: 'data.mounted_vol[2u]' may be used uninitialized in this function
fs/ncpfs/inode.c:451: warning: 'data.mounted_vol[3u]' may be used uninitialized in this function
It's notabug, but we can easily fix it with a memset().
Reported-by: Harry Wei <jiaweiwei.xiyou@gmail.com>
Cc: Petr Vandrovec <petr@vandrovec.name>
Replace EXTRA_CFLAGS with ccflags-y. And change ntfs-objs to ntfs-y
for cleaner conditional inclusion.
Signed-off-by: matt mooney <mfm@muteddisk.com>
Acked-by: WANG Cong <xiyou.wangcong@gmail.com>
merge dentry_operations for root and non-root
* 'for-2.6.38' of git://git.kernel.org/pub/scm/linux/kernel/git/tj/wq: (33 commits)
usb: don't use flush_scheduled_work()
speedtch: don't abuse struct delayed_work
media/video: don't use flush_scheduled_work()
media/video: explicitly flush request_module work
ioc4: use static work_struct for ioc4_load_modules()
init: don't call flush_scheduled_work() from do_initcalls()
s390: don't use flush_scheduled_work()
rtc: don't use flush_scheduled_work()
mmc: update workqueue usages
mfd: update workqueue usages
dvb: don't use flush_scheduled_work()
leds-wm8350: don't use flush_scheduled_work()
mISDN: don't use flush_scheduled_work()
macintosh/ams: don't use flush_scheduled_work()
vmwgfx: don't use flush_scheduled_work()
tpm: don't use flush_scheduled_work()
sonypi: don't use flush_scheduled_work()
hvsi: don't use flush_scheduled_work()
xen: don't use flush_scheduled_work()
gdrom: don't use flush_scheduled_work()
Fixed up trivial conflict in drivers/media/video/bt8xx/bttv-input.c
as per Tejun.
Require filesystems be aware of .d_revalidate being called in rcu-walk
mode (nd->flags & LOOKUP_RCU). For now do a simple push down, returning
-ECHILD from all implementations.
Signed-off-by: Nick Piggin <npiggin@kernel.dk>
Reduce some branches and memory accesses in dcache lookup by adding dentry
flags to indicate common d_ops are set, rather than having to check them.
This saves a pointer memory access (dentry->d_op) in common path lookup
situations, and saves another pointer load and branch in cases where we
have d_op but not the particular operation.
Patched with:
git grep -E '[.>]([[:space:]])*d_op([[:space:]])*=' | xargs sed -e 's/\([^\t ]*\)->d_op = \(.*\);/d_set_d_op(\1, \2);/' -e 's/\([^\t ]*\)\.d_op = \(.*\);/d_set_d_op(\&\1, \2);/' -i
RCU free the struct inode. This will allow:
- Subsequent store-free path walking patch. The inode must be consulted for
permissions when walking, so an RCU inode reference is a must.
- sb_inode_list_lock to be moved inside i_lock because sb list walkers who want
to take i_lock no longer need to take sb_inode_list_lock to walk the list in
the first place. This will simplify and optimize locking.
- Could remove some nested trylock loops in dcache code
- Could potentially simplify things a bit in VM land. Do not need to take the
page lock to follow page->mapping.
The downsides of this is the performance cost of using RCU. In a simple
creat/unlink microbenchmark, performance drops by about 10% due to inability to
reuse cache-hot slab objects. As iterations increase and RCU freeing starts
kicking over, this increases to about 20%.
In cases where inode lifetimes are longer (ie. many inodes may be allocated
during the average life span of a single inode), a lot of this cache reuse is
not applicable, so the regression caused by this patch is smaller.
The cache-hot regression could largely be avoided by using SLAB_DESTROY_BY_RCU,
however this adds some complexity to list walking and store-free path walking,
so I prefer to implement this at a later date, if it is shown to be a win in
real situations. I haven't found a regression in any non-micro benchmark so I
doubt it will be a problem.
dget_locked was a shortcut to avoid the lazy lru manipulation when we already
held dcache_lock (lru manipulation was relatively cheap at that point).
However, how that the lru lock is an innermost one, we never hold it at any
caller, so the lock cost can now be avoided. We already have well working lazy
dcache LRU, so it should be fine to defer LRU manipulations to scan time.
dcache_lock no longer protects anything. remove it.
Protect d_subdirs and d_child with d_lock, except in filesystems that aren't
using dcache_lock for these anyway (eg. using i_mutex).
Note: if we change the locking rule in future so that ->d_child protection is
provided only with ->d_parent->d_lock, it may allow us to reduce some locking.
But it would be an exception to an otherwise regular locking scheme, so we'd
have to see some good results. Probably not worthwhile.
Change d_hash so it may be called from lock-free RCU lookups. See similar
patch for d_compare for details.
For in-tree filesystems, this is just a mechanical change.
Change d_compare so it may be called from lock-free RCU lookups. This
does put significant restrictions on what may be done from the callback,
however there don't seem to have been any problems with in-tree fses.
If some strange use case pops up that _really_ cannot cope with the
rcu-walk rules, we can just add new rcu-unaware callbacks, which would
cause name lookup to drop out of rcu-walk mode.
smpfs and ncpfs want to update a live dentry name in-place. Rather than
have them open code the locking, provide a documented dcache API.
Change d_delete from a dentry deletion notification to a dentry caching
advise, more like ->drop_inode. Require it to be constant and idempotent,
and not take d_lock. This is how all existing filesystems use the callback
anyway.
This makes fine grained dentry locking of dput and dentry lru scanning
much simpler.
flush_scheduled_work() is deprecated and scheduled to be removed.
Directly flush the used works on stop instead.
The big kernel lock has been removed from all these files at some point,
leaving only the #include.
Remove this too as a cleanup.
Otherwise partially updated pointers could be seen if
pointer update is not atomic.
Dozen of changes in ncpfs to provide some locking other than BKL.
In readdir cache unlock and mark complete first page as last operation,
so it can be used for synchronization, as code intended.
When updating dentry name on case insensitive filesystems do at least
some basic locking...
Hold i_mutex when updating inode fields.
Push some ncp_conn_is_valid down to ncp_request. Connection can become
invalid at any moment, and fewer error code paths to test the better.
Use i_size_{read,write} to modify file size.
Set inode's backing_dev_info as ncpfs has its own special bdi.
In ioctl unbreak ioctls invoked on filesystem mounted 'ro' - tests are
for inode writeable or owner match, but were turned to filesystem
writeable and inode writeable or owner match. Also collect all permission
checks in single place.
Add some locking, and remove comments saying that it would be cool to
add some locks to the code.
Constify some pointers.
git://git.kernel.org/pub/scm/linux/kernel/git/frederic/random-tracing
* 'bkl/ioctl' of git://git.kernel.org/pub/scm/linux/kernel/git/frederic/random-tracing:
staging: Pushdown bkl to easycap ioctl handlers
autofs/autofs4: Move compat_ioctl handling into fs
v4l: Convert v4l2-dev to unlocked_ioctl
ia64/perfmon: Convert to unlocked_ioctl
sunrpc: Remove duplicated #include
ncpfs: Remove duplicated #include
* 'for-linus' of git://git.kernel.org/pub/scm/linux/kernel/git/viro/vfs-2.6: (96 commits)
no need for list_for_each_entry_safe()/resetting with superblock list
Fix sget() race with failing mount
vfs: don't hold s_umount over close_bdev_exclusive() call
sysv: do not mark superblock dirty on remount
sysv: do not mark superblock dirty on mount
btrfs: remove junk sb_dirt change
BFS: clean up the superblock usage
AFFS: wait for sb synchronization when needed
AFFS: clean up dirty flag usage
cifs: truncate fallout
mbcache: fix shrinker function return value
mbcache: Remove unused features
add f_flags to struct statfs(64)
pass a struct path to vfs_statfs
update VFS documentation for method changes.
All filesystems that need invalidate_inode_buffers() are doing that explicitly
convert remaining ->clear_inode() to ->evict_inode()
Make ->drop_inode() just return whether inode needs to be dropped
fs/inode.c:clear_inode() is gone
fs/inode.c:evict() doesn't care about delete vs. non-delete paths now
Fix up trivial conflicts in fs/nilfs2/super.c
Replace inode_setattr with opencoded variants of it in all callers. This
moves the remaining call to vmtruncate into the filesystem methods where it
can be replaced with the proper truncate sequence.
In a few cases it was obvious that we would never end up calling vmtruncate
so it was left out in the opencoded variant:
spufs: explicitly checks for ATTR_SIZE earlier
btrfs,hugetlbfs,logfs,dlmfs: explicitly clears ATTR_SIZE earlier
ufs: contains an opencoded simple_seattr + truncate that sets the filesize just above
In addition to that ncpfs called inode_setattr with handcrafted iattrs,
which allowed to trim down the opencoded variant.
Merge reason: The staging tree has introduced the easycap
driver lately. We need the latest updates to pushdown the
bkl in its ioctl helper.
Remove duplicated #include('s) in
fs/ncpfs/ioctl.c
Signed-off-by: Huang Weiyi <weiyi.huang@gmail.com>
Do not use the fallback default_llseek() if the readdir operation of the
filesystem still uses the big kernel lock.
Since llseek() modifies
file->f_pos of the directory directly it may need locking to not confuse
readdir which usually uses file->f_pos directly as well
Since the special characteristics of the BKL (unlocked on schedule) are
not necessary in this case, the inode mutex can be used for locking as
provided by generic_file_llseek(). This is only possible since all
filesystems, except reiserfs, either use a directory as a flat file or
with disk address offsets. Reiserfs on the other hand uses a 32bit hash
off the filename as the offset so generic_file_llseek() can get used as
well since the hash is always smaller than sb->s_maxbytes (= (512 << 32) -
blocksize).
Signed-off-by: Jan Blunck <jblunck@suse.de>
Acked-by: Anders Larsen <al@alarsen.net>
Convert ncp_ioctl to an unlocked_ioctl and push down the bkl into it.
Signed-off-by: John Kacur <jkacur@redhat.com>
Cc: Petr Vandrovec <vandrove@vc.cvut.cz>
