path: root/fs/ncpfs
2010-11-17BKL: remove extraneous #include <smp_lock.h>Arnd Bergmann
The big kernel lock has been removed from all these files at some point, leaving only the #include. Remove this too as a cleanup. Signed-off-by: Arnd Bergmann <arnd@arndb.de> Signed-off-by: Linus Torvalds <torvalds@linux-foundation.org>
2010-10-29convert get_sb_nodev() usersAl Viro
2010-10-05ncpfs: Lock socket in ncpfs while setting its callbacksPetr Vandrovec
Otherwise partially updated pointers could be seen if pointer update is not atomic. Signed-off-by: Petr Vandrovec <petr@vandrovec.name> Signed-off-by: Arnd Bergmann <arnd@arndb.de>
2010-10-04BKL: Remove BKL from ncpfsPetr Vandrovec
Dozen of changes in ncpfs to provide some locking other than BKL. In readdir cache unlock and mark complete first page as last operation, so it can be used for synchronization, as code intended. When updating dentry name on case insensitive filesystems do at least some basic locking... Hold i_mutex when updating inode fields. Push some ncp_conn_is_valid down to ncp_request. Connection can become invalid at any moment, and fewer error code paths to test the better. Use i_size_{read,write} to modify file size. Set inode's backing_dev_info as ncpfs has its own special bdi. In ioctl unbreak ioctls invoked on filesystem mounted 'ro' - tests are for inode writeable or owner match, but were turned to filesystem writeable and inode writeable or owner match. Also collect all permission checks in single place. Add some locking, and remove comments saying that it would be cool to add some locks to the code. Constify some pointers. Signed-off-by: Petr Vandrovec <petr@vandrovec.name> Signed-off-by: Arnd Bergmann <arnd@arndb.de>
2010-08-10Merge branch 'bkl/ioctl' of ↵Linus Torvalds
git://git.kernel.org/pub/scm/linux/kernel/git/frederic/random-tracing * 'bkl/ioctl' of git://git.kernel.org/pub/scm/linux/kernel/git/frederic/random-tracing: staging: Pushdown bkl to easycap ioctl handlers autofs/autofs4: Move compat_ioctl handling into fs v4l: Convert v4l2-dev to unlocked_ioctl ia64/perfmon: Convert to unlocked_ioctl sunrpc: Remove duplicated #include ncpfs: Remove duplicated #include
2010-08-10Merge branch 'for-linus' of ↵Linus Torvalds
git://git.kernel.org/pub/scm/linux/kernel/git/viro/vfs-2.6 * 'for-linus' of git://git.kernel.org/pub/scm/linux/kernel/git/viro/vfs-2.6: (96 commits) no need for list_for_each_entry_safe()/resetting with superblock list Fix sget() race with failing mount vfs: don't hold s_umount over close_bdev_exclusive() call sysv: do not mark superblock dirty on remount sysv: do not mark superblock dirty on mount btrfs: remove junk sb_dirt change BFS: clean up the superblock usage AFFS: wait for sb synchronization when needed AFFS: clean up dirty flag usage cifs: truncate fallout mbcache: fix shrinker function return value mbcache: Remove unused features add f_flags to struct statfs(64) pass a struct path to vfs_statfs update VFS documentation for method changes. All filesystems that need invalidate_inode_buffers() are doing that explicitly convert remaining ->clear_inode() to ->evict_inode() Make ->drop_inode() just return whether inode needs to be dropped fs/inode.c:clear_inode() is gone fs/inode.c:evict() doesn't care about delete vs. non-delete paths now ... Fix up trivial conflicts in fs/nilfs2/super.c
2010-08-09switch ncpfs to ->evict_inode()Al Viro
2010-08-09remove inode_setattrChristoph Hellwig
Replace inode_setattr with opencoded variants of it in all callers. This moves the remaining call to vmtruncate into the filesystem methods where it can be replaced with the proper truncate sequence. In a few cases it was obvious that we would never end up calling vmtruncate so it was left out in the opencoded variant: spufs: explicitly checks for ATTR_SIZE earlier btrfs,hugetlbfs,logfs,dlmfs: explicitly clears ATTR_SIZE earlier ufs: contains an opencoded simple_seattr + truncate that sets the filesize just above In addition to that ncpfs called inode_setattr with handcrafted iattrs, which allowed to trim down the opencoded variant. Signed-off-by: Christoph Hellwig <hch@lst.de> Signed-off-by: Al Viro <viro@zeniv.linux.org.uk>
2010-08-09Merge commit 'linus/master' into bkl/coreFrederic Weisbecker
Merge reason: The staging tree has introduced the easycap driver lately. We need the latest updates to pushdown the bkl in its ioctl helper.
2010-07-05ncpfs: Remove duplicated #includeHuang Weiyi
Remove duplicated #include('s) in fs/ncpfs/ioctl.c Signed-off-by: Huang Weiyi <weiyi.huang@gmail.com> Signed-off-by: Frederic Weisbecker <fweisbec@gmail.com>
2010-06-28Fix comment spelling errors in ncpfs/inode.cMatthew Whitworth
2010-05-27drop unused dentry argument to ->fsyncChristoph Hellwig
2010-05-27fs/: do not fallback to default_llseek() when readdir() uses BKLjan Blunck
Do not use the fallback default_llseek() if the readdir operation of the filesystem still uses the big kernel lock. Since llseek() modifies file->f_pos of the directory directly it may need locking to not confuse readdir which usually uses file->f_pos directly as well Since the special characteristics of the BKL (unlocked on schedule) are not necessary in this case, the inode mutex can be used for locking as provided by generic_file_llseek(). This is only possible since all filesystems, except reiserfs, either use a directory as a flat file or with disk address offsets. Reiserfs on the other hand uses a 32bit hash off the filename as the offset so generic_file_llseek() can get used as well since the hash is always smaller than sb->s_maxbytes (= (512 << 32) - blocksize). Signed-off-by: Jan Blunck <jblunck@suse.de> Acked-by: Jan Kara <jack@suse.cz> Acked-by: Anders Larsen <al@alarsen.net> Cc: Frederic Weisbecker <fweisbec@gmail.com> Signed-off-by: Andrew Morton <akpm@linux-foundation.org> Signed-off-by: Linus Torvalds <torvalds@linux-foundation.org>
2010-05-17ncpfs: BKL ioctl pushdownJohn Kacur
Convert ncp_ioctl to an unlocked_ioctl and push down the bkl into it. Signed-off-by: John Kacur <jkacur@redhat.com> Cc: Arnd Bergmann <arnd@arndb.de> Cc: Thomas Gleixner <tglx@linutronix.de> Cc: Ingo Molnar <mingo@elte.hu> Cc: Petr Vandrovec <vandrove@vc.cvut.cz> Signed-off-by: Frederic Weisbecker <fweisbec@gmail.com>
2010-04-22ncpfs: add bdi backing to mount sessionJens Axboe
This ensures that dirty data gets flushed properly. Signed-off-by: Jens Axboe <jens.axboe@oracle.com>
implicit slab.h inclusion from percpu.h percpu.h is included by sched.h and module.h and thus ends up being included when building most .c files. percpu.h includes slab.h which in turn includes gfp.h making everything defined by the two files universally available and complicating inclusion dependencies. percpu.h -> slab.h dependency is about to be removed. Prepare for this change by updating users of gfp and slab facilities include those headers directly instead of assuming availability. As this conversion needs to touch large number of source files, the following script is used as the basis of conversion. http://userweb.kernel.org/~tj/misc/slabh-sweep.py The script does the followings. * Scan files for gfp and slab usages and update includes such that only the necessary includes are there. ie. if only gfp is used, gfp.h, if slab is used, slab.h. * When the script inserts a new include, it looks at the include blocks and try to put the new include such that its order conforms to its surrounding. It's put in the include block which contains core kernel includes, in the same order that the rest are ordered - alphabetical, Christmas tree, rev-Xmas-tree or at the end if there doesn't seem to be any matching order. * If the script can't find a place to put a new include (mostly because the file doesn't have fitting include block), it prints out an error message indicating which .h file needs to be added to the file. The conversion was done in the following steps. 1. The initial automatic conversion of all .c files updated slightly over 4000 files, deleting around 700 includes and adding ~480 gfp.h and ~3000 slab.h inclusions. The script emitted errors for ~400 files. 2. Each error was manually checked. Some didn't need the inclusion, some needed manual addition while adding it to implementation .h or embedding .c file was more appropriate for others. This step added inclusions to around 150 files. 3. The script was run again and the output was compared to the edits from #2 to make sure no file was left behind. 4. Several build tests were done and a couple of problems were fixed. e.g. lib/decompress_*.c used malloc/free() wrappers around slab APIs requiring slab.h to be added manually. 5. The script was run on all .h files but without automatically editing them as sprinkling gfp.h and slab.h inclusions around .h files could easily lead to inclusion dependency hell. Most gfp.h inclusion directives were ignored as stuff from gfp.h was usually wildly available and often used in preprocessor macros. Each slab.h inclusion directive was examined and added manually as necessary. 6. percpu.h was updated not to include slab.h. 7. Build test were done on the following configurations and failures were fixed. CONFIG_GCOV_KERNEL was turned off for all tests (as my distributed build env didn't work with gcov compiles) and a few more options had to be turned off depending on archs to make things build (like ipr on powerpc/64 which failed due to missing writeq). * x86 and x86_64 UP and SMP allmodconfig and a custom test config. * powerpc and powerpc64 SMP allmodconfig * sparc and sparc64 SMP allmodconfig * ia64 SMP allmodconfig * s390 SMP allmodconfig * alpha SMP allmodconfig * um on x86_64 SMP allmodconfig 8. percpu.h modifications were reverted so that it could be applied as a separate patch and serve as bisection point. Given the fact that I had only a couple of failures from tests on step 6, I'm fairly confident about the coverage of this conversion patch. If there is a breakage, it's likely to be something in one of the arch headers which should be easily discoverable easily on most builds of the specific arch. Signed-off-by: Tejun Heo <tj@kernel.org> Guess-its-ok-by: Christoph Lameter <cl@linux-foundation.org> Cc: Ingo Molnar <mingo@redhat.com> Cc: Lee Schermerhorn <Lee.Schermerhorn@hp.com>
2009-12-04tree-wide: fix assorted typos all over the placeAndré Goddard Rosa
That is "success", "unknown", "through", "performance", "[re|un]mapping" , "access", "default", "reasonable", "[con]currently", "temperature" , "channel", "[un]used", "application", "example","hierarchy", "therefore" , "[over|under]flow", "contiguous", "threshold", "enough" and others. Signed-off-by: André Goddard Rosa <andre.goddard@gmail.com> Signed-off-by: Jiri Kosina <jkosina@suse.cz>
2009-09-27const: mark struct vm_struct_operationsAlexey Dobriyan
* mark struct vm_area_struct::vm_ops as const * mark vm_ops in AGP code But leave TTM code alone, something is fishy there with global vm_ops being used. Signed-off-by: Alexey Dobriyan <adobriyan@gmail.com> Signed-off-by: Linus Torvalds <torvalds@linux-foundation.org>
2009-09-24fs: Make unload_nls() NULL pointer safeThomas Gleixner
Most call sites of unload_nls() do: if (nls) unload_nls(nls); Check the pointer inside unload_nls() like we do in kfree() and simplify the call sites. Signed-off-by: Thomas Gleixner <tglx@linutronix.de> Cc: Steve French <sfrench@us.ibm.com> Cc: OGAWA Hirofumi <hirofumi@mail.parknet.co.jp> Cc: Roman Zippel <zippel@linux-m68k.org> Cc: Dave Kleikamp <shaggy@linux.vnet.ibm.com> Cc: Petr Vandrovec <vandrove@vc.cvut.cz> Cc: Anton Altaparmakov <aia21@cantab.net> Signed-off-by: Al Viro <viro@zeniv.linux.org.uk>
2009-09-23ncpfs: fix wrong check in __ncp_ioctl()Bartlomiej Zolnierkiewicz
We want to check for s_inode's existence, not inode's one (inode is always valid in this function). This takes care of the following entry from Dan's list: fs/ncpfs/ioctl.c +445 __ncp_ioctl(180) warning: variable derefenced before check 'inode' Reported-by: Dan Carpenter <error27@gmail.com> Cc: Julia Lawall <julia@diku.dk> Signed-off-by: Bartlomiej Zolnierkiewicz <bzolnier@gmail.com> Cc: Petr Vandrovec <vandrove@vc.cvut.cz> Signed-off-by: Andrew Morton <akpm@linux-foundation.org> Signed-off-by: Linus Torvalds <torvalds@linux-foundation.org>
2009-09-23ncpfs: read buffer overflowRoel Kluin
This function uses signed integers for the unix_date and local variables - if a negative number is supplied and the leap-year condition is not met, month will be 0, leading to a later read of day_n[-1] Signed-off-by: Roel Kluin <roel.kluin@gmail.com> Cc: Petr Vandrovec <VANDROVE@vc.cvut.cz> Signed-off-by: Andrew Morton <akpm@linux-foundation.org> Signed-off-by: Linus Torvalds <torvalds@linux-foundation.org>
2009-06-15NLS: update handling of UnicodeAlan Stern
This patch (as1239) updates the kernel's treatment of Unicode. The character-set conversion routines are well behind the current state of the Unicode specification: They don't recognize the existence of code points beyond plane 0 or of surrogate pairs in the UTF-16 encoding. The old wchar_t 16-bit type is retained because it's still used in lots of places. This shouldn't cause any new problems; if a conversion now results in an invalid 16-bit code then before it must have yielded an undefined code. Difficult-to-read names like "utf_mbstowcs" are replaced with more transparent names like "utf8s_to_utf16s" and the ordering of the parameters is rationalized (buffer lengths come immediate after the pointers they refer to, and the inputs precede the outputs). Fortunately the low-level conversion routines are used in only a few places; the interfaces to the higher-level uni2char and char2uni methods have been left unchanged. Signed-off-by: Alan Stern <stern@rowland.harvard.edu> Acked-by: Clemens Ladisch <clemens@ladisch.de> Signed-off-by: Greg Kroah-Hartman <gregkh@suse.de>
2009-06-11push BKL down into ->put_superChristoph Hellwig
Move BKL into ->put_super from the only caller. A couple of filesystems had trivial enough ->put_super (only kfree and NULLing of s_fs_info + stuff in there) to not get any locking: coda, cramfs, efs, hugetlbfs, omfs, qnx4, shmem, all others got the full treatment. Most of them probably don't need it, but I'd rather sort that out individually. Preferably after all the other BKL pushdowns in that area. [AV: original used to move lock_super() down as well; these changes are removed since we don't do lock_super() at all in generic_shutdown_super() now] [AV: fuse, btrfs and xfs are known to need no damn BKL, exempt] Signed-off-by: Christoph Hellwig <hch@lst.de> Signed-off-by: Al Viro <viro@zeniv.linux.org.uk>
2009-04-20ncpfs: use memdup_user()Li Zefan
Remove open-coded memdup_user() Signed-off-by: Li Zefan <lizf@cn.fujitsu.com> Signed-off-by: Al Viro <viro@zeniv.linux.org.uk>
2009-03-27constify dentry_operations: misc filesystemsAl Viro
2009-01-22fs/Kconfig: move the rest of ncpfs outAlexey Dobriyan
2009-01-07Merge branch 'for-linus' of ↵Linus Torvalds
git://git.kernel.org/pub/scm/linux/kernel/git/jikos/trivial * 'for-linus' of git://git.kernel.org/pub/scm/linux/kernel/git/jikos/trivial: (24 commits) trivial: chack -> check typo fix in main Makefile trivial: Add a space (and a comma) to a printk in 8250 driver trivial: Fix misspelling of "firmware" in docs for ncr53c8xx/sym53c8xx trivial: Fix misspelling of "firmware" in powerpc Makefile trivial: Fix misspelling of "firmware" in usb.c trivial: Fix misspelling of "firmware" in qla1280.c trivial: Fix misspelling of "firmware" in a100u2w.c trivial: Fix misspelling of "firmware" in megaraid.c trivial: Fix misspelling of "firmware" in ql4_mbx.c trivial: Fix misspelling of "firmware" in acpi_memhotplug.c trivial: Fix misspelling of "firmware" in ipw2100.c trivial: Fix misspelling of "firmware" in atmel.c trivial: Fix misspelled firmware in Kconfig trivial: fix an -> a typos in documentation and comments trivial: fix then -> than typos in comments and documentation trivial: update Jesper Juhl CREDITS entry with new email trivial: fix singal -> signal typo trivial: Fix incorrect use of "loose" in event.c trivial: printk: fix indentation of new_text_line declaration trivial: rtc-stk17ta8: fix sparse warning ...
2009-01-06fs/ncpfs/getopt.c: cleanup keneldocQinghuang Feng
There are no argument named @flag in ncp_getopt(), remove it. Signed-off-by: Qinghuang Feng <qhfeng.kernel@gmail.com> Cc: Randy Dunlap <randy.dunlap@oracle.com> Cc: Petr Vandrovec <VANDROVE@vc.cvut.cz> Signed-off-by: Andrew Morton <akpm@linux-foundation.org> Signed-off-by: Linus Torvalds <torvalds@linux-foundation.org>
2009-01-06trivial: fix an -> a typos in documentation and commentsFrederik Schwarzer
It is always "an" if there is a vowel _spoken_ (not written). So it is: "an hour" (spoken vowel) but "a uniform" (spoken 'j') Signed-off-by: Frederik Schwarzer <schwarzerf@gmail.com> Signed-off-by: Jiri Kosina <jkosina@suse.cz>
2008-11-14CRED: Wrap task credential accesses in the NCPFS filesystemDavid Howells
Wrap access to task credentials so that they can be separated more easily from the task_struct during the introduction of COW creds. Change most current->(|e|s|fs)[ug]id to current_(|e|s|fs)[ug]id(). Change some task->e?[ug]id to task_e?[ug]id(). In some places it makes more sense to use RCU directly rather than a convenient wrapper; these will be addressed by later patches. Signed-off-by: David Howells <dhowells@redhat.com> Reviewed-by: James Morris <jmorris@namei.org> Acked-by: Serge Hallyn <serue@us.ibm.com> Acked-by: Petr Vandrovec <vandrove@vc.cvut.cz> Signed-off-by: James Morris <jmorris@namei.org>
2008-07-26[PATCH] don't pass nameidata to __ncp_lookup_validate()Al Viro
2008-07-26SL*B: drop kmem cache argument from constructorAlexey Dobriyan
Kmem cache passed to constructor is only needed for constructors that are themselves multiplexeres. Nobody uses this "feature", nor does anybody uses passed kmem cache in non-trivial way, so pass only pointer to object. Non-trivial places are: arch/powerpc/mm/init_64.c arch/powerpc/mm/hugetlbpage.c This is flag day, yes. Signed-off-by: Alexey Dobriyan <adobriyan@gmail.com> Acked-by: Pekka Enberg <penberg@cs.helsinki.fi> Acked-by: Christoph Lameter <cl@linux-foundation.org> Cc: Jon Tollefson <kniht@linux.vnet.ibm.com> Cc: Nick Piggin <nickpiggin@yahoo.com.au> Cc: Matt Mackall <mpm@selenic.com> [akpm@linux-foundation.org: fix arch/powerpc/mm/hugetlbpage.c] [akpm@linux-foundation.org: fix mm/slab.c] [akpm@linux-foundation.org: fix ubifs] Signed-off-by: Andrew Morton <akpm@linux-foundation.org> Signed-off-by: Linus Torvalds <torvalds@linux-foundation.org>
2008-07-02Remove BKL from remote_llseek v2Andi Kleen
- Replace remote_llseek with generic_file_llseek_unlocked (to force compilation failures in all users) - Change all users to either use generic_file_llseek_unlocked directly or take the BKL around. I changed the file systems who don't use the BKL for anything (CIFS, GFS) to call it directly. NCPFS and SMBFS and NFS take the BKL, but explicitely in their own source now. I moved them all over in a single patch to avoid unbisectable sections. Open problem: 32bit kernels can corrupt fpos because its modification is not atomic, but they can do that anyways because there's other paths who modify it without BKL. Do we need a special lock for the pos/f_version = 0 checks? Trond says the NFS BKL is likely not needed, but keep it for now until his full audit. v2: Use generic_file_llseek_unlocked instead of remote_llseek_unlocked and factor duplicated code (suggested by hch) Cc: Trond.Myklebust@netapp.com Cc: swhiteho@redhat.com Cc: sfrench@samba.org Cc: vandrove@vc.cvut.cz Signed-off-by: Andi Kleen <ak@suse.de> Signed-off-by: Andi Kleen <ak@linux.intel.com> Signed-off-by: Jonathan Corbet <corbet@lwn.net>
2008-04-29ncpfs: use get/put_unaligned_* helpersHarvey Harrison
[akpm@linux-foundation.org: coding-style fixes] Signed-off-by: Harvey Harrison <harvey.harrison@gmail.com> Cc: Al Viro <viro@zeniv.linux.org.uk> Signed-off-by: Andrew Morton <akpm@linux-foundation.org> Signed-off-by: Linus Torvalds <torvalds@linux-foundation.org>
2008-04-28ncpfs: fix sparse warning in ncpsign_kernel.cHarvey Harrison
We're casting anyway, might as well cast to the correct sign. Specific to i386 (ifdef __i386__) fs/ncpfs/ncpsign_kernel.c:58:23: warning: incorrect type in initializer (different signedness) fs/ncpfs/ncpsign_kernel.c:58:23: expected unsigned int *data2 fs/ncpfs/ncpsign_kernel.c:58:23: got int *<noident> Signed-off-by: Harvey Harrison <harvey.harrison@gmail.com> Acked-by: Petr Vandrovec <VANDROVE@vc.cvut.cz> Signed-off-by: Andrew Morton <akpm@linux-foundation.org> Signed-off-by: Linus Torvalds <torvalds@linux-foundation.org>
2008-04-28ncpfs: fix sparse warnings in ioctl.cHarvey Harrison
In both cases, these inode variables arebeing used to test the server's root inode against NULL. Change them to s_inode. fs/ncpfs/ioctl.c:391:18: warning: symbol 'inode' shadows an earlier one fs/ncpfs/ioctl.c:264:28: originally declared here fs/ncpfs/ioctl.c:441:17: warning: symbol 'inode' shadows an earlier one fs/ncpfs/ioctl.c:264:28: originally declared here In this case, we are about to return anyway, just reuse result. fs/ncpfs/ioctl.c:521:8: warning: symbol 'result' shadows an earlier one fs/ncpfs/ioctl.c:268:6: originally declared here Signed-off-by: Harvey Harrison <harvey.harrison@gmail.com> Acked-by: Petr Vandrovec <VANDROVE@vc.cvut.cz> Signed-off-by: Andrew Morton <akpm@linux-foundation.org> Signed-off-by: Linus Torvalds <torvalds@linux-foundation.org>
2008-04-28ncpfs: add prototypes to ncp_fs.hHarvey Harrison
Removes some externs from C files, noticed from the sparse warnings: fs/ncpfs/dir.c:90:26: warning: symbol 'ncp_root_dentry_operations' was not declared. Should it be static? fs/ncpfs/symlink.c:107:5: warning: symbol 'ncp_symlink' was not declared. Should it be static? fs/ncpfs/symlink.c:101:39: warning: symbol 'ncp_symlink_aops' was not declared. Should it be static? Signed-off-by: Harvey Harrison <harvey.harrison@gmail.com> Acked-by: Petr Vandrovec <VANDROVE@vc.cvut.cz> Signed-off-by: Andrew Morton <akpm@linux-foundation.org> Signed-off-by: Linus Torvalds <torvalds@linux-foundation.org>
2008-04-19[PATCH] r/o bind mounts: elevate write count for ncp_ioctl()Dave Hansen
Acked-by: Al Viro <viro@ZenIV.linux.org.uk> Signed-off-by: Christoph Hellwig <hch@lst.de> Signed-off-by: Andrew Morton <akpm@linux-foundation.org> Signed-off-by: Dave Hansen <haveblue@us.ibm.com> Signed-off-by: Al Viro <viro@zeniv.linux.org.uk>
2008-02-08mount options: fix ncpfsMiklos Szeredi
Add a .show_options super operation to ncpfs. Small fix: add FS_BINARY_MOUNTDATA to the filesystem type flags, since it can take binary data, as well as text (similarly to NFS). Signed-off-by: Miklos Szeredi <mszeredi@suse.cz> Signed-off-by: Andrew Morton <akpm@linux-foundation.org> Signed-off-by: Linus Torvalds <torvalds@linux-foundation.org>
2008-02-06NCPFS: update diagnostic strings to match routine names.Robert P. J. Day
Signed-off-by: Robert P. J. Day <rpjday@crashcourse.ca> Cc: Petr Vandrovec <VANDROVE@vc.cvut.cz> Signed-off-by: Andrew Morton <akpm@linux-foundation.org> Signed-off-by: Linus Torvalds <torvalds@linux-foundation.org>
2008-02-04vm audit: add VM_DONTEXPAND to mmap for drivers that need itNick Piggin
Drivers that register a ->fault handler, but do not range-check the offset argument, must set VM_DONTEXPAND in the vm_flags in order to prevent an expanding mremap from overflowing the resource. I've audited the tree and attempted to fix these problems (usually by adding VM_DONTEXPAND where it is not obvious). Signed-off-by: Nick Piggin <npiggin@suse.de> Signed-off-by: Linus Torvalds <torvalds@linux-foundation.org>
2007-10-17Slab API: remove useless ctor parameter and reorder parametersChristoph Lameter
Slab constructors currently have a flags parameter that is never used. And the order of the arguments is opposite to other slab functions. The object pointer is placed before the kmem_cache pointer. Convert ctor(void *object, struct kmem_cache *s, unsigned long flags) to ctor(struct kmem_cache *s, void *object) throughout the kernel [akpm@linux-foundation.org: coupla fixes] Signed-off-by: Christoph Lameter <clameter@sgi.com> Signed-off-by: Andrew Morton <akpm@linux-foundation.org> Signed-off-by: Linus Torvalds <torvalds@linux-foundation.org>
2007-07-31NCP: delete test of long-deceased CONFIG_NCPFS_DEBUGDENTRYRobert P. J. Day
Signed-off-by: Robert P. J. Day <rpjday@mindspring.com> Acked-by: Petr Vandrovec <petr@vandrovec.name> Signed-off-by: Andrew Morton <akpm@linux-foundation.org> Signed-off-by: Linus Torvalds <torvalds@linux-foundation.org>
2007-07-19mm: fault feedback #1Nick Piggin
Change ->fault prototype. We now return an int, which contains VM_FAULT_xxx code in the low byte, and FAULT_RET_xxx code in the next byte. FAULT_RET_ code tells the VM whether a page was found, whether it has been locked, and potentially other things. This is not quite the way he wanted it yet, but that's changed in the next patch (which requires changes to arch code). This means we no longer set VM_CAN_INVALIDATE in the vma in order to say that a page is locked which requires filemap_nopage to go away (because we can no longer remain backward compatible without that flag), but we were going to do that anyway. struct fault_data is renamed to struct vm_fault as Linus asked. address is now a void __user * that we should firmly encourage drivers not to use without really good reason. The page is now returned via a page pointer in the vm_fault struct. Signed-off-by: Nick Piggin <npiggin@suse.de> Signed-off-by: Andrew Morton <akpm@linux-foundation.org> Signed-off-by: Linus Torvalds <torvalds@linux-foundation.org>
2007-07-19mm: merge populate and nopage into fault (fixes nonlinear)Nick Piggin
Nonlinear mappings are (AFAIKS) simply a virtual memory concept that encodes the virtual address -> file offset differently from linear mappings. ->populate is a layering violation because the filesystem/pagecache code should need to know anything about the virtual memory mapping. The hitch here is that the ->nopage handler didn't pass down enough information (ie. pgoff). But it is more logical to pass pgoff rather than have the ->nopage function calculate it itself anyway (because that's a similar layering violation). Having the populate handler install the pte itself is likewise a nasty thing to be doing. This patch introduces a new fault handler that replaces ->nopage and ->populate and (later) ->nopfn. Most of the old mechanism is still in place so there is a lot of duplication and nice cleanups that can be removed if everyone switches over. The rationale for doing this in the first place is that nonlinear mappings are subject to the pagefault vs invalidate/truncate race too, and it seemed stupid to duplicate the synchronisation logic rather than just consolidate the two. After this patch, MAP_NONBLOCK no longer sets up ptes for pages present in pagecache. Seems like a fringe functionality anyway. NOPAGE_REFAULT is removed. This should be implemented with ->fault, and no users have hit mainline yet. [akpm@linux-foundation.org: cleanup] [randy.dunlap@oracle.com: doc. fixes for readahead] [akpm@linux-foundation.org: build fix] Signed-off-by: Nick Piggin <npiggin@suse.de> Signed-off-by: Randy Dunlap <randy.dunlap@oracle.com> Cc: Mark Fasheh <mark.fasheh@oracle.com> Signed-off-by: Andrew Morton <akpm@linux-foundation.org> Signed-off-by: Linus Torvalds <torvalds@linux-foundation.org>
2007-07-19mm: fix fault vs invalidate race for linear mappingsNick Piggin
Fix the race between invalidate_inode_pages and do_no_page. Andrea Arcangeli identified a subtle race between invalidation of pages from pagecache with userspace mappings, and do_no_page. The issue is that invalidation has to shoot down all mappings to the page, before it can be discarded from the pagecache. Between shooting down ptes to a particular page, and actually dropping the struct page from the pagecache, do_no_page from any process might fault on that page and establish a new mapping to the page just before it gets discarded from the pagecache. The most common case where such invalidation is used is in file truncation. This case was catered for by doing a sort of open-coded seqlock between the file's i_size, and its truncate_count. Truncation will decrease i_size, then increment truncate_count before unmapping userspace pages; do_no_page will read truncate_count, then find the page if it is within i_size, and then check truncate_count under the page table lock and back out and retry if it had subsequently been changed (ptl will serialise against unmapping, and ensure a potentially updated truncate_count is actually visible). Complexity and documentation issues aside, the locking protocol fails in the case where we would like to invalidate pagecache inside i_size. do_no_page can come in anytime and filemap_nopage is not aware of the invalidation in progress (as it is when it is outside i_size). The end result is that dangling (->mapping == NULL) pages that appear to be from a particular file may be mapped into userspace with nonsense data. Valid mappings to the same place will see a different page. Andrea implemented two working fixes, one using a real seqlock, another using a page->flags bit. He also proposed using the page lock in do_no_page, but that was initially considered too heavyweight. However, it is not a global or per-file lock, and the page cacheline is modified in do_no_page to increment _count and _mapcount anyway, so a further modification should not be a large performance hit. Scalability is not an issue. This patch implements this latter approach. ->nopage implementations return with the page locked if it is possible for their underlying file to be invalidated (in that case, they must set a special vm_flags bit to indicate so). do_no_page only unlocks the page after setting up the mapping completely. invalidation is excluded because it holds the page lock during invalidation of each page (and ensures that the page is not mapped while holding the lock). This also allows significant simplifications in do_no_page, because we have the page locked in the right place in the pagecache from the start. Signed-off-by: Nick Piggin <npiggin@suse.de> Signed-off-by: Andrew Morton <akpm@linux-foundation.org> Signed-off-by: Linus Torvalds <torvalds@linux-foundation.org>
2007-07-16Only send SIGXFSZ when exceeding rlimits.Micah Cowan
Some users have been having problems with utilities like cp or dd dumping core when they try to copy a file that's too large for the destination filesystem (typically, > 4gb). Apparently, some defunct standards required SIGXFSZ to be sent in such circumstances, but SUS only requires/allows it for when a written file exceeds the process's resource limits. I'd like to limit SIGXFSZs to the bare minimum required by SUS. Patch sent per http://lkml.org/lkml/2007/4/10/302 Signed-off-by: Micah Cowan <micahcowan@ubuntu.com> Acked-by: Alan Cox <alan@redhat.com> Cc: <reiserfs-dev@namesys.com> Signed-off-by: Andrew Morton <akpm@linux-foundation.org> Signed-off-by: Linus Torvalds <torvalds@linux-foundation.org>
2007-05-21Detach sched.h from mm.hAlexey Dobriyan
First thing mm.h does is including sched.h solely for can_do_mlock() inline function which has "current" dereference inside. By dealing with can_do_mlock() mm.h can be detached from sched.h which is good. See below, why. This patch a) removes unconditional inclusion of sched.h from mm.h b) makes can_do_mlock() normal function in mm/mlock.c c) exports can_do_mlock() to not break compilation d) adds sched.h inclusions back to files that were getting it indirectly. e) adds less bloated headers to some files (asm/signal.h, jiffies.h) that were getting them indirectly Net result is: a) mm.h users would get less code to open, read, preprocess, parse, ... if they don't need sched.h b) sched.h stops being dependency for significant number of files: on x86_64 allmodconfig touching sched.h results in recompile of 4083 files, after patch it's only 3744 (-8.3%). Cross-compile tested on all arm defconfigs, all mips defconfigs, all powerpc defconfigs, alpha alpha-up arm i386 i386-up i386-defconfig i386-allnoconfig ia64 ia64-up m68k mips parisc parisc-up powerpc powerpc-up s390 s390-up sparc sparc-up sparc64 sparc64-up um-x86_64 x86_64 x86_64-up x86_64-defconfig x86_64-allnoconfig as well as my two usual configs. Signed-off-by: Alexey Dobriyan <adobriyan@gmail.com> Signed-off-by: Linus Torvalds <torvalds@linux-foundation.org>
