path: root/fs/nfs/callback.c
2008-05-16nfs: replace remaining __FUNCTION__ occurrencesHarvey Harrison
__FUNCTION__ is gcc-specific, use __func__ Signed-off-by: Harvey Harrison <harvey.harrison@gmail.com> Cc: Trond Myklebust <trond.myklebust@fys.uio.no> Cc: "J. Bruce Fields" <bfields@fieldses.org> Signed-off-by: Andrew Morton <akpm@linux-foundation.org> Signed-off-by: Trond Myklebust <Trond.Myklebust@netapp.com>
2008-04-23NFS: don't let nfs_callback_svc exit on unexpected svc_recv errors (try #2)Jeff Layton
When svc_recv returns an unexpected error, nfs_callback_svc will print a warning and exit. This problematic for several reasons. In particular, it will cause the reference counts for the thread to be wrong, and no new thread will be started until all nfs4 mounts are unmounted. Rather than exiting on error from svc_recv, have the thread do a 1s sleep and then retry the loop. This is unlikely to cause any harm, and if the error turns out to be something temporary then it may be able to recover. Signed-off-by: Jeff Layton <jlayton@redhat.com> Signed-off-by: J. Bruce Fields <bfields@citi.umich.edu>
2008-04-23nfsd: fix commentJ. Bruce Fields
Obvious comment nit. Signed-off-by: J. Bruce Fields <bfields@citi.umich.edu>
2008-04-23NFS: convert nfs4 callback thread to kthread APIJeff Layton
There's a general push to convert kernel threads to use the (much cleaner) kthread API. This patch converts the NFSv4 callback kernel thread to the kthread API. In addition to being generally cleaner this also removes the dependency on signals when shutting down the thread. Note that this patch depends on the recent patches to svc_recv() to make it check kthread_should_stop() periodically. Those patches are in Bruce's tree at the moment and are slated for 2.6.26 along with the lockd conversion, so this conversion is probably also appropriate for 2.6.26. Signed-off-by: Jeff Layton <jlayton@redhat.com> Acked-by: Trond Myklebust <Trond.Myklebust@netapp.com> Signed-off-by: J. Bruce Fields <bfields@citi.umich.edu>
2008-02-21Wrap buffers used for rpc debug printks into RPC_IFDEBUGPavel Emelyanov
Sorry for the noise, but here's the v3 of this compilation fix :) There are some places, which declare the char buf[...] on the stack to push it later into dprintk(). Since the dprintk sometimes (if the CONFIG_SYSCTL=n) becomes an empty do { } while (0) stub, these buffers cause gcc to produce appropriate warnings. Wrap these buffers with RPC_IFDEBUG macro, as Trond proposed, to compile them out when not needed. Signed-off-by: Pavel Emelyanov <xemul@openvz.org> Acked-by: J. Bruce Fields <bfields@citi.umich.edu> Signed-off-by: Trond Myklebust <Trond.Myklebust@netapp.com>
2008-02-20NFS: flush signals before taking down callback threadJeff Layton
Now that the reference counting on the callback thread is working as expected, it uncovers another problem. Peter Staubach noticed while testing that patch on an older kernel that he would occasionally see this printk in rpc_register fire: "RPC: failed to contact portmap (errno -512). The NFSv4 callback thread is signaled by nfs_callback_down(), but never flushes that signal. All of the shutdown processing is done with that signal pending. This makes it fail the call to unregister the port with the portmapper. In actuality, this rpc_register call isn't necessary at all since the port isn't actually registered with the portmapper anymore. Regardless, there doesn't seem to be any reason to leave the signal pending while the thread is being shut down and flushing it should generally silence that printk. Signed-off-by: Jeff Layton <jlayton@redhat.com> Signed-off-by: Trond Myklebust <Trond.Myklebust@netapp.com>
2008-02-13NFS: fix reference counting for NFSv4 callback threadJeff Layton
The reference counting for the NFSv4 callback thread stays artificially high. When this thread comes down, it doesn't properly tear down the svc_serv, causing a memory leak. In my testing on an older kernel on x86_64, memory would leak out of the 8k kmalloc slab. So, we're leaking at least a page of memory every time the thread comes down. svc_create() creates the svc_serv with a sv_nrthreads count of 1, and then svc_create_thread() increments that count. Whenever the callback thread is started it has a sv_nrthreads count of 2. When coming down, it calls svc_exit_thread() which decrements that count and if it hits 0, it tears everything down. That never happens here since the count is always at 2 when the thread exits. The problem is that nfs_callback_up() should be calling svc_destroy() on the svc_serv on both success and failure. This is how lockd_up_proto() handles the reference counting, and doing that here fixes the leak. Signed-off-by: Jeff Layton <jlayton@redhat.com> Signed-off-by: Trond Myklebust <Trond.Myklebust@netapp.com>
2008-02-01svc: Change services to use new svc_create_xprt serviceTom Tucker
Modify the various kernel RPC svcs to use the svc_create_xprt service. Signed-off-by: Tom Tucker <tom@opengridcomputing.com> Acked-by: Neil Brown <neilb@suse.de> Reviewed-by: Chuck Lever <chuck.lever@oracle.com> Reviewed-by: Greg Banks <gnb@sgi.com> Signed-off-by: J. Bruce Fields <bfields@citi.umich.edu>
2008-01-30NFS: Change nfs_find_client() to take "struct sockaddr *"Chuck Lever
Adjust arguments and callers of nfs_find_client() to pass a "struct sockaddr *" instead of "struct sockaddr_in *" to support non-IPv4 addresses. Signed-off-by: Chuck Lever <chuck.lever@oracle.com> Cc: Aurelien Charbon <aurelien.charbon@ext.bull.net> Trond: Also fix up protocol version number argument in nfs_find_client() to use the correct u32 type. Signed-off-by: Trond Myklebust <Trond.Myklebust@netapp.com>
2008-01-30NFS: Move dprintks from callback.c to callback_proc.cChuck Lever
Clean up: The client side peer address is available in callback_proc.c, so move a dprintk out of fs/nfs/callback.c and into fs/nfs/callback_proc.c. This is more consistent with other debugging messages, and the proc routines have more information about each request to display. Signed-off-by: Chuck Lever <chuck.lever@oracle.com> Cc: Aurelien Charbon <aurelien.charbon@ext.bull.net> Signed-off-by: Trond Myklebust <Trond.Myklebust@netapp.com>
2007-07-17Freezer: make kernel threads nonfreezable by defaultRafael J. Wysocki
Currently, the freezer treats all tasks as freezable, except for the kernel threads that explicitly set the PF_NOFREEZE flag for themselves. This approach is problematic, since it requires every kernel thread to either set PF_NOFREEZE explicitly, or call try_to_freeze(), even if it doesn't care for the freezing of tasks at all. It seems better to only require the kernel threads that want to or need to be frozen to use some freezer-related code and to remove any freezer-related code from the other (nonfreezable) kernel threads, which is done in this patch. The patch causes all kernel threads to be nonfreezable by default (ie. to have PF_NOFREEZE set by default) and introduces the set_freezable() function that should be called by the freezable kernel threads in order to unset PF_NOFREEZE. It also makes all of the currently freezable kernel threads call set_freezable(), so it shouldn't cause any (intentional) change of behaviour to appear. Additionally, it updates documentation to describe the freezing of tasks more accurately. [akpm@linux-foundation.org: build fixes] Signed-off-by: Rafael J. Wysocki <rjw@sisk.pl> Acked-by: Nigel Cunningham <nigel@nigel.suspend2.net> Cc: Pavel Machek <pavel@ucw.cz> Cc: Oleg Nesterov <oleg@tv-sign.ru> Cc: Gautham R Shenoy <ego@in.ibm.com> Signed-off-by: Andrew Morton <akpm@linux-foundation.org> Signed-off-by: Linus Torvalds <torvalds@linux-foundation.org>
2007-02-12[PATCH] knfsd: SUNRPC: Provide room in svc_rqst for larger addressesChuck Lever
Expand the rq_addr field to allow it to contain larger addresses. Specifically, we replace a 'sockaddr_in' with a 'sockaddr_storage', then everywhere the 'sockaddr_in' was referenced, we use instead an accessor function (svc_addr_in) which safely casts the _storage to _in. Signed-off-by: Chuck Lever <chuck.lever@oracle.com> Cc: Aurelien Charbon <aurelien.charbon@ext.bull.net> Signed-off-by: Neil Brown <neilb@suse.de> Signed-off-by: Andrew Morton <akpm@linux-foundation.org> Signed-off-by: Linus Torvalds <torvalds@linux-foundation.org>
2007-02-12[PATCH] knfsd: SUNRPC: Add a function to format the address in an svc_rqst ↵Chuck Lever
for printing There are loads of places where the RPC server assumes that the rq_addr fields contains an IPv4 address. Top among these are error and debugging messages that display the server's IP address. Let's refactor the address printing into a separate function that's smart enough to figure out the difference between IPv4 and IPv6 addresses. Signed-off-by: Chuck Lever <chuck.lever@oracle.com> Cc: Aurelien Charbon <aurelien.charbon@ext.bull.net> Signed-off-by: Neil Brown <neilb@suse.de> Signed-off-by: Andrew Morton <akpm@linux-foundation.org> Signed-off-by: Linus Torvalds <torvalds@linux-foundation.org>
2007-02-12[PATCH] knfsd: SUNRPC: allow creating an RPC service without registering ↵Chuck Lever
with portmapper Sometimes we need to create an RPC service but not register it with the local portmapper. NFSv4 delegation callback, for example. Change the svc_makesock() API to allow optionally creating temporary or permanent sockets, optionally registering with the local portmapper, and make it return the ephemeral port of the new socket. Signed-off-by: Chuck Lever <chuck.lever@oracle.com> Cc: Aurelien Charbon <aurelien.charbon@ext.bull.net> Signed-off-by: Neil Brown <neilb@suse.de> Signed-off-by: Andrew Morton <akpm@linux-foundation.org> Signed-off-by: Linus Torvalds <torvalds@linux-foundation.org>
2006-10-02[PATCH] knfsd: Drop 'serv' option to svc_recv and svc_processNeilBrown
It isn't needed as it is available in rqstp->rq_server, and dropping it allows some local vars to be dropped. [akpm@osdl.org: build fix] Cc: "J. Bruce Fields" <bfields@fieldses.org> Signed-off-by: Neil Brown <neilb@suse.de> Signed-off-by: Andrew Morton <akpm@osdl.org> Signed-off-by: Linus Torvalds <torvalds@osdl.org>
2006-10-02[PATCH] knfsd: add a callback for when last rpc thread finishesNeilBrown
nfsd has some cleanup that it wants to do when the last thread exits, and there will shortly be some more. So collect this all into one place and define a callback for an rpc service to call when the service is about to be destroyed. [akpm@osdl.org: cleanups, build fix] Signed-off-by: Neil Brown <neilb@suse.de> Signed-off-by: Andrew Morton <akpm@osdl.org> Signed-off-by: Linus Torvalds <torvalds@osdl.org>
2006-09-22NFS: Generalise the nfs_client structureDavid Howells
Generalise the nfs_client structure by: (1) Moving nfs_client to a more general place (nfs_fs_sb.h). (2) Renaming its maintenance routines to be non-NFS4 specific. (3) Move those maintenance routines to a new non-NFS4 specific file (client.c) and move the declarations to internal.h. (4) Make nfs_find/get_client() take a full sockaddr_in to include the port number (will be required for NFS2/3). (5) Make nfs_find/get_client() take the NFS protocol version (again will be required to differentiate NFS2, 3 & 4 client records). Also: (6) Make nfs_client construction proceed akin to inodes, marking them as under construction and providing a function to indicate completion. (7) Make nfs_get_client() wait interruptibly if it finds a client that it can share, but that client is currently being constructed. (8) Make nfs4_create_client() use (6) and (7) instead of locking cl_sem. Signed-Off-By: David Howells <dhowells@redhat.com> Signed-off-by: Trond Myklebust <Trond.Myklebust@netapp.com>
2006-09-22NFS: Rename struct nfs4_client to struct nfs_clientDavid Howells
Rename struct nfs4_client to struct nfs_client so that it can become the basis for a general client record for NFS2 and NFS3 in addition to NFS4. Signed-Off-By: David Howells <dhowells@redhat.com> Signed-off-by: Trond Myklebust <Trond.Myklebust@netapp.com>
2006-09-22NFS: Fix NFS4 callback up/down prototypesDavid Howells
Make the nfs_callback_up()/down() prototypes just do nothing if NFS4 is not enabled. Also make the down function void type since we can't really do anything if it fails. Signed-Off-By: David Howells <dhowells@redhat.com> Signed-off-by: Trond Myklebust <Trond.Myklebust@netapp.com>
2006-09-22NFS: Fix up split of fs/nfs/inode.cDavid Howells
Fix ups for the splitting of the superblock stuff out of fs/nfs/inode.c, including: (*) Move the callback tcpport module param into callback.c. (*) Move the idmap cache timeout module param into idmap.c. (*) Changes to internal.h: (*) namespace-nfs4.c was renamed to nfs4namespace.c. (*) nfs_stat_to_errno() is in nfs2xdr.c, not nfs4xdr.c. (*) nfs4xdr.c is contingent on CONFIG_NFS_V4. (*) nfs4_path() is only uses if CONFIG_NFS_V4 is set. Plus also: (*) The sec_flavours[] table should really be const. Signed-Off-By: David Howells <dhowells@redhat.com> Signed-off-by: Trond Myklebust <Trond.Myklebust@netapp.com>
2006-06-09NFS: Split fs/nfs/inode.cDavid Howells
As fs/nfs/inode.c is rather large, heterogenous and unwieldy, the attached patch splits it up into a number of files: (*) fs/nfs/inode.c Strictly inode specific functions. (*) fs/nfs/super.c Superblock management functions for NFS and NFS4, normal access, clones and referrals. The NFS4 superblock functions _could_ move out into a separate conditionally compiled file, but it's probably not worth it as there're so many common bits. (*) fs/nfs/namespace.c Some namespace-specific functions have been moved here. (*) fs/nfs/nfs4namespace.c NFS4-specific namespace functions (this could be merged into the previous file). This file is conditionally compiled. (*) fs/nfs/internal.h Inter-file declarations, plus a few simple utility functions moved from fs/nfs/inode.c. Additionally, all the in-.c-file externs have been moved here, and those files they were moved from now includes this file. For the most part, the functions have not been changed, only some multiplexor functions have changed significantly. I've also: (*) Added some extra banner comments above some functions. (*) Rearranged the function order within the files to be more logical and better grouped (IMO), though someone may prefer a different order. (*) Reduced the number of #ifdefs in .c files. (*) Added missing __init and __exit directives. Signed-Off-By: David Howells <dhowells@redhat.com>
2006-03-26[PATCH] sem2mutex: fs/Ingo Molnar
Semaphore to mutex conversion. The conversion was generated via scripts, and the result was validated automatically via a script as well. Signed-off-by: Ingo Molnar <mingo@elte.hu> Cc: Eric Van Hensbergen <ericvh@ericvh.myip.org> Cc: Robert Love <rml@tech9.net> Cc: Thomas Gleixner <tglx@linutronix.de> Cc: David Woodhouse <dwmw2@infradead.org> Cc: Neil Brown <neilb@cse.unsw.edu.au> Cc: Trond Myklebust <trond.myklebust@fys.uio.no> Cc: Dave Kleikamp <shaggy@austin.ibm.com> Signed-off-by: Andrew Morton <akpm@osdl.org> Signed-off-by: Linus Torvalds <torvalds@osdl.org>
2006-03-20NFSv4: Ensure the callback daemon flushes signalsTrond Myklebust
If the callback daemon is signalled, but is unable to exit because it still has users, then we need to flush signals. If not, then svc_recv() can never sleep, and so we hang. If we flush signals, then we also have to be prepared to resend them when we want the thread to exit. Signed-off-by: Trond Myklebust <Trond.Myklebust@netapp.com>
2006-03-20NFSv4: Ensure nfs_callback_down() calls svc_destroy()Trond Myklebust
2006-01-06NFSv4: Allow user to set the port used by the NFSv4 callback channelTrond Myklebust
2006-01-03[INET_SOCK]: Move struct inet_sock & helper functions to net/inet_sock.hArnaldo Carvalho de Melo
To help in reducing the number of include dependencies, several files were touched as they were getting needed headers indirectly for stuff they use. Thanks also to Alan Menegotto for pointing out that net/dccp/proto.c had linux/dccp.h include twice. Signed-off-by: Arnaldo Carvalho de Melo <acme@mandriva.com> Signed-off-by: David S. Miller <davem@davemloft.net>
2005-06-22[PATCH] NFS: Header file cleanup...Trond Myklebust
- Move NFSv4 state definitions into a private header file. - Clean up gunk in nfs_fs.h Signed-off-by: Trond Myklebust <Trond.Myklebust@netapp.com>
