path: root/fs/nfs/callback_proc.c
2013-02-14NFSv4.1: Fix bulk recall and destroy of layoutsTrond Myklebust
The current code in pnfs_destroy_all_layouts() assumes that removing the layout from the server->layouts list is sufficient to make it invisible to other processes. This ignores the fact that most users access the layout through the nfs_inode->layout... There is further breakage due to lack of reference counting of the layouts, meaning that the whole thing Oopses at the drop of a hat. The code in initiate_bulk_draining() is almost correct, and can be used as a model for pnfs_destroy_all_layouts(), so move that code to pnfs.c, and refactor the code to allow us to choose between a single filesystem bulk recall, and a recall of all layouts. Also note that initiate_bulk_draining() currently calls iput() while holding locks. Fix that too. Signed-off-by: Trond Myklebust <Trond.Myklebust@netapp.com> Cc: stable@vger.kernel.org
2013-01-05nfs: avoid dereferencing null pointer in initiate_bulk_drainingNickolai Zeldovich
Fix an inverted null pointer check in initiate_bulk_draining(). Signed-off-by: Nickolai Zeldovich <nickolai@csail.mit.edu> Signed-off-by: Trond Myklebust <Trond.Myklebust@netapp.com> Cc: stable@vger.kernel.org [>= 3.7]
2012-12-06NFSv4.1: Cleanup move session slot management to fs/nfs/nfs4session.cTrond Myklebust
NFSv4.1 session management is getting complex enough to deserve a separate file. Signed-off-by: Trond Myklebust <Trond.Myklebust@netapp.com>
2012-12-06NFSv4.1: CB_RECALL_SLOT must schedule a sequence op after updating targetsTrond Myklebust
RFC5661 requires us to make sure that the server knows we've updated our slot table size by sending at least one SEQUENCE op containing the new 'highest_slotid' value. We can do so using the 'CHECK_LEASE' functionality of the state manager. Signed-off-by: Trond Myklebust <Trond.Myklebust@netapp.com>
2012-12-06NFSv4.1: Remove the state manager code to resize the slot tableTrond Myklebust
The state manager no longer needs any special machinery to stop the session flow and resize the slot table. It is all done on the fly by the SEQUENCE op code now. Signed-off-by: Trond Myklebust <Trond.Myklebust@netapp.com>
2012-12-06NFSv4.1: Allow the server to recall all but one slotTrond Myklebust
If the server wants to leave us with only one slot, or it wants to "shrink" our slot table to something larger than we have now, then so be it. Signed-off-by: Trond Myklebust <Trond.Myklebust@netapp.com>
2012-12-06NFSv4.1: Don't confuse target_highest_slotid and max_slots in cb_recall_slotTrond Myklebust
Don't confuse the table size and the target_highest_slotid... Signed-off-by: Trond Myklebust <Trond.Myklebust@netapp.com>
2012-12-06NFSv4.1: Fix nfs4_callback_recallslot to work with dynamic slot allocationTrond Myklebust
Ensure that the NFSv4.1 CB_RECALL_SLOT callback updates the slot table target max slotid safely. Signed-off-by: Trond Myklebust <Trond.Myklebust@netapp.com>
2012-12-06NFSv4.1: Ensure that the client tracks the server target_highest_slotidTrond Myklebust
Dynamic slot allocation in NFSv4.1 depends on the client being able to track the server's target value for the highest slotid in the slot table. See the reference in Section 2.10.6.1 of RFC5661. To avoid ordering problems in the case where 2 SEQUENCE replies contain conflicting updates to this target value, we also introduce a generation counter, to track whether or not an RPC containing a SEQUENCE operation was launched before or after the last update. Also rename the nfs4_slot_table target_max_slots field to 'target_highest_slotid' to avoid confusion with a slot table size or number of slots. Signed-off-by: Trond Myklebust <Trond.Myklebust@netapp.com>
2012-11-04NFSv4: Get rid of unnecessary BUG_ON()sTrond Myklebust
2012-09-28NFSv4.1: Clean up the removal of pnfs_layout_hdr from the server listTrond Myklebust
Move the code into pnfs_free_layout_hdr(), and add checks to get_layout_by_fh_locked to ensure that they don't reference a layout that is being freed. Signed-off-by: Trond Myklebust <Trond.Myklebust@netapp.com>
2012-09-28NFSv4.1: Cleanup; add "pnfs_" prefix to get_layout_hdr() and put_layout_hdr()Trond Myklebust
2012-09-28NFSv4.1: Cleanup add a "pnfs_" prefix to mark_matching_lsegs_invalidTrond Myklebust
2012-03-06NFSv4: Further clean-ups of delegation stateid validationTrond Myklebust
Change the name to reflect what we're really doing: testing two stateids for whether or not they match according the the rules in RFC3530 and RFC5661. Move the code from callback_proc.c to nfs4proc.c Signed-off-by: Trond Myklebust <Trond.Myklebust@netapp.com>
2012-03-06NFSv4.1: Fix matching of the stateids when returning a delegationTrond Myklebust
nfs41_validate_delegation_stateid is broken if we supply a stateid with a non-zero sequence id. Instead of trying to match the sequence id, the function assumes that we always want to error. While this is true for a delegation callback, it is not true in general. Also fix a typo in nfs4_callback_recall. Reported-by: Andy Adamson <andros@netapp.com> Signed-off-by: Trond Myklebust <Trond.Myklebust@netapp.com>
2012-03-02SUNRPC: Use RCU to dereference the rpc_clnt.cl_xprt fieldTrond Myklebust
A migration event will replace the rpc_xprt used by an rpc_clnt. To ensure this can be done safely, all references to cl_xprt must now use a form of rcu_dereference(). Special care is taken with rpc_peeraddr2str(), which returns a pointer to memory whose lifetime is the same as the rpc_xprt. Signed-off-by: Trond Myklebust <Trond.Myklebust@netapp.com> [ cel: fix lockdep splats and layering violations ] [ cel: forward ported to 3.4 ] [ cel: remove rpc_max_reqs(), add rpc_net_ns() ] Signed-off-by: Chuck Lever <chuck.lever@oracle.com> Signed-off-by: Trond Myklebust <Trond.Myklebust@netapp.com>
2012-03-01NFSv4.1: Get rid of NFS4CLNT_LAYOUTRECALLTrond Myklebust
The NFS4CLNT_LAYOUTRECALL bit is a long-term impediment to scalability. It basically stops all other recalls by a given server once any layout recall is requested. If the recall is for a different file, then we don't care. If the recall applies to the same file, then we're in one of two situations: Either we are in the case of a replay of an existing request, in which case the session is supposed to deal with matters, or we are dealing with a completely different request, in which case we should just try to process it. Signed-off-by: Trond Myklebust <Trond.Myklebust@netapp.com>
2012-02-06NFS: search for client session id in proper network namespaceStanislav Kinsbursky
Network namespace is taken from request transport and passed as a part of cb_process_state structure. Signed-off-by: Stanislav Kinsbursky <skinsbursky@parallels.com> Signed-off-by: Trond Myklebust <Trond.Myklebust@netapp.com>
2012-01-31pnfs: clean up initiate_file_draining layout lookupBenny Halevy
Fixes the following compiler warning: fs/nfs/callback_proc.c: In function 'do_callback_layoutrecall': fs/nfs/callback_proc.c:115:26: warning: 'lo' may be used uninitialized in this function Reported-by: Jim Rees <rees@umich.edu> Signed-off-by: Benny Halevy <bhalevy@tonian.com> Signed-off-by: Trond Myklebust <Trond.Myklebust@netapp.com>
2012-01-05NFSv4.1: fix backchannel slotid off-by-one bugAndy Adamson
Cc:stable@kernel.org Signed-off-by: Andy Adamson <andros@netapp.com> Signed-off-by: Trond Myklebust <Trond.Myklebust@netapp.com>
2011-08-04NFSv4.1: Return NFS4ERR_BADSESSION to callbacks during session resetsTrond Myklebust
If the client is in the process of resetting the session when it receives a callback, then returning NFS4ERR_DELAY may cause a deadlock with the DESTROY_SESSION call. Basically, if the client returns NFS4ERR_DELAY in response to the CB_SEQUENCE call, then the server is entitled to believe that the client is busy because it is already processing that call. In that case, the server is perfectly entitled to respond with a NFS4ERR_BACK_CHAN_BUSY to any DESTROY_SESSION call. Fix this by having the client reply with a NFS4ERR_BADSESSION in response to the callback if it is resetting the session. Cc: stable@kernel.org [2.6.38+] Signed-off-by: Trond Myklebust <Trond.Myklebust@netapp.com>
2011-08-04NFSv4.1: Fix the callback 'highest_used_slotid' behaviourTrond Myklebust
Currently, there is no guarantee that we will call nfs4_cb_take_slot() even though nfs4_callback_compound() will consistently call nfs4_cb_free_slot() provided the cb_process_state has set the 'clp' field. The result is that we can trigger the BUG_ON() upon the next call to nfs4_cb_take_slot(). This patch fixes the above problem by using the slot id that was taken in the CB_SEQUENCE operation as a flag for whether or not we need to call nfs4_cb_free_slot(). It also fixes an atomicity problem: we need to set tbl->highest_used_slotid atomically with the check for NFS4_SESSION_DRAINING, otherwise we end up racing with the various tests in nfs4_begin_drain_session(). Cc: stable@kernel.org [2.6.38+] Signed-off-by: Trond Myklebust <Trond.Myklebust@netapp.com>
2011-07-12NFS: move pnfs layouts to nfs_server structureWeston Andros Adamson
Layouts should be tracked per nfs_server (aka superblock) instead of per struct nfs_client, which may have multiple FSIDs associated with it. Signed-off-by: Weston Andros Adamson <dros@netapp.com> Signed-off-by: Trond Myklebust <Trond.Myklebust@netapp.com>
2011-05-29pnfs: Use byte-range for cb_layoutrecallBenny Halevy
Use recalled range to invalidate particular layout segments in the layout cache. Signed-off-by: Benny Halevy <bhalevy@panasas.com>
2011-05-29NFSv4.1: use layout driver in global device cacheBenny Halevy
pnfs deviceids are unique per server, per layout type. struct nfs_client is currently used to distinguish deviceids from different nfs servers, yet these may clash between different layout types on the same server. Therefore, use the layout driver associated with each deviceid at insertion time to look it up, unhash, or delete it. Signed-off-by: Benny Halevy <bhalevy@panasas.com>
2011-05-29pnfs: CB_NOTIFY_DEVICEIDMarc Eshel
Note: This functionlaity is incomplete as all layout segments referring to the 'to be removed device id' need to be reaped, and all in flight I/O drained. [use be32 res in nfs4_callback_devicenotify] [use nfs_client to qualify deviceid for cb_notify_deviceid] [use global deviceid cache for CB_NOTIFY_DEVICEID] [refactor device cache _lookup_deviceid] [refactor device cache _find_get_deviceid] Signed-off-by: Benny Halevy <bhalevy@panasas.com> [Bug in new global-device-cache code] [layout_driver MUST set free_deviceid_node if using dev-cache] Signed-off-by: Boaz Harrosh <bharrosh@panasas.com> Signed-off-by: Benny Halevy <bhalevy@panasas.com>
2011-03-11pnfs: fix pnfs lock inversion of i_lock and cl_lockFred Isaman
The pnfs code was using throughout the lock order i_lock, cl_lock. This conflicts with the nfs delegation code. Rework the pnfs code to avoid taking both locks simultaneously. Currently the code takes the double lock to add/remove the layout to a nfs_client list, while atomically checking that the list of lsegs is empty. To avoid this, we rely on existing serializations. When a layout is initialized with lseg count equal zero, LAYOUTGET's openstateid serialization is in effect, making it safe to assume it stays zero unless we change it. And once a layout's lseg count drops to zero, it is set as DESTROYED and so will stay at zero. Signed-off-by: Fred Isaman <iisaman@netapp.com> Signed-off-by: Trond Myklebust <Trond.Myklebust@netapp.com>
2011-01-25NFS fix cb_sequence error processingAndy Adamson
Always assign the cb_process_state nfs_client pointer so a processing error in cb_sequence after the nfs_client is found and referenced returns a non-NULL cb_process_state nfs_client and the matching nfs_put_client in nfs4_callback_compound dereferences the client. Signed-off-by: Andy Adamson <andros@netapp.com> Signed-off-by: Trond Myklebust <Trond.Myklebust@netapp.com>
2011-01-25NFS do not find client in NFSv4 pg_authenticateAndy Adamson
The information required to find the nfs_client cooresponding to the incoming back channel request is contained in the NFS layer. Perform minimal checking in the RPC layer pg_authenticate method, and push more detailed checking into the NFS layer where the nfs_client can be found. Signed-off-by: Andy Adamson <andros@netapp.com> Signed-off-by: Trond Myklebust <Trond.Myklebust@netapp.com>
2011-01-06pnfs: update nfs4_callback_recallany to handle layoutsAlexandros Batsakis
While here, update the code a bit. Signed-off-by: Alexandros Batsakis <batsakis@netapp.com> Signed-off-by: Fred Isaman <iisaman@netapp.com> Signed-off-by: Trond Myklebust <Trond.Myklebust@netapp.com>
2011-01-06pnfs: add CB_LAYOUTRECALL handlingFred Isaman
This is the heart of the wave 2 submission. Add the code to trigger drain and forget of any afected layouts. In addition, we set a "barrier", below which any LAYOUTGET reply is ignored. This is to compensate for the fact that we do not wait for outstanding LAYOUTGETs to complete as per section 12.5.5.2.1 of RFC 5661. Signed-off-by: Fred Isaman <iisaman@netapp.com> Signed-off-by: Trond Myklebust <Trond.Myklebust@netapp.com>
2011-01-06pnfs: CB_LAYOUTRECALL xdr codeFred Isaman
This is the xdr decoding for CB_LAYOUTRECALL. Signed-off-by: Alexandros Batsakis <batsakis@netapp.com> Signed-off-by: Dean Hildebrand <dhildeb@us.ibm.com> Signed-off-by: Marc Eshel <eshel@almaden.ibm.com> Signed-off-by: Andy Adamson <andros@netapp.com> Signed-off-by: Benny Halevy <bhalevy@panasas.com> Signed-off-by: Fred Isaman <iisaman@netapp.com> Signed-off-by: Trond Myklebust <Trond.Myklebust@netapp.com>
2011-01-06NFS add session back channel drainingAndy Adamson
Currently session draining only drains the fore channel. The back channel processing must also be drained. Use the back channel highest_slot_used to indicate that a callback is being processed by the callback thread. Move the session complete to be per channel. When the session is draininig, wait for any current back channel processing to complete and stop all new back channel processing by returning NFS4ERR_DELAY to the back channel client. Drain the back channel, then the fore channel. Signed-off-by: Andy Adamson <andros@netapp.com> Signed-off-by: Trond Myklebust <Trond.Myklebust@netapp.com>
2011-01-06NFS refactor nfs_find_client and reference client across callback processingAndy Adamson
Fixes a bug where the nfs_client could be freed during callback processing. Refactor nfs_find_client to use minorversion specific means to locate the correct nfs_client structure. In the NFS layer, V4.0 clients are found using the callback_ident field in the CB_COMPOUND header. V4.1 clients are found using the sessionID in the CB_SEQUENCE operation which is also compared against the sessionID associated with the back channel thread after a successful CREATE_SESSION. Each of these methods finds the one an only nfs_client associated with the incoming callback request - so nfs_find_client_next is not needed. In the RPC layer, the pg_authenticate call needs to find the nfs_client. For the v4.0 callback service, the callback identifier has not been decoded so a search by address, version, and minorversion is used. The sessionid for the sessions based callback service has (usually) not been set for the pg_authenticate on a CB_NULL call which can be sent prior to the return of a CREATE_SESSION call, so the sessionid associated with the back channel thread is not used to find the client in pg_authenticate for CB_NULL calls. Pass the referenced nfs_client to each CB_COMPOUND operation being proceesed via the new cb_process_state structure. The reference is held across cb_compound processing. Use the new cb_process_state struct to move the NFS4ERR_RETRY_UNCACHED_REP processing from process_op into nfs4_callback_sequence where it belongs. Signed-off-by: Andy Adamson <andros@netapp.com> Signed-off-by: Trond Myklebust <Trond.Myklebust@netapp.com>
2010-10-24NFS: change stateid to be a unionAlexandros Batsakis
In NFSv4.1 the stateid consists of the other and seqid fields. For layout processing we need to numerically compare the seqid value of layout stateids. To do so, introduce a union to nfs4_stateid to switch between opaque(16 bytes) and opaque(12 bytes) / __be32 Signed-off-by: Alexandros Batsakis <batsakis@netapp.com> Signed-off-by: Benny Halevy <bhalevy@panasas.com> Signed-off-by: Fred Isaman <iisaman@netapp.com> Signed-off-by: Trond Myklebust <Trond.Myklebust@netapp.com>
2010-08-06NFS: Fix the locking in nfs4_callback_getattrTrond Myklebust
The delegation is protected by RCU now, so we need to replace the nfsi->rwsem protection with an rcu protected section. Reported-by: Fred Isaman <iisaman@netapp.com> Signed-off-by: Trond Myklebust <Trond.Myklebust@netapp.com>
2010-06-22NFSv41: Fix nfs_async_inode_return_delegation() uglinessTrond Myklebust
implicit slab.h inclusion from percpu.h percpu.h is included by sched.h and module.h and thus ends up being included when building most .c files. percpu.h includes slab.h which in turn includes gfp.h making everything defined by the two files universally available and complicating inclusion dependencies. percpu.h -> slab.h dependency is about to be removed. Prepare for this change by updating users of gfp and slab facilities include those headers directly instead of assuming availability. As this conversion needs to touch large number of source files, the following script is used as the basis of conversion. http://userweb.kernel.org/~tj/misc/slabh-sweep.py The script does the followings. * Scan files for gfp and slab usages and update includes such that only the necessary includes are there. ie. if only gfp is used, gfp.h, if slab is used, slab.h. * When the script inserts a new include, it looks at the include blocks and try to put the new include such that its order conforms to its surrounding. It's put in the include block which contains core kernel includes, in the same order that the rest are ordered - alphabetical, Christmas tree, rev-Xmas-tree or at the end if there doesn't seem to be any matching order. * If the script can't find a place to put a new include (mostly because the file doesn't have fitting include block), it prints out an error message indicating which .h file needs to be added to the file. The conversion was done in the following steps. 1. The initial automatic conversion of all .c files updated slightly over 4000 files, deleting around 700 includes and adding ~480 gfp.h and ~3000 slab.h inclusions. The script emitted errors for ~400 files. 2. Each error was manually checked. Some didn't need the inclusion, some needed manual addition while adding it to implementation .h or embedding .c file was more appropriate for others. This step added inclusions to around 150 files. 3. The script was run again and the output was compared to the edits from #2 to make sure no file was left behind. 4. Several build tests were done and a couple of problems were fixed. e.g. lib/decompress_*.c used malloc/free() wrappers around slab APIs requiring slab.h to be added manually. 5. The script was run on all .h files but without automatically editing them as sprinkling gfp.h and slab.h inclusions around .h files could easily lead to inclusion dependency hell. Most gfp.h inclusion directives were ignored as stuff from gfp.h was usually wildly available and often used in preprocessor macros. Each slab.h inclusion directive was examined and added manually as necessary. 6. percpu.h was updated not to include slab.h. 7. Build test were done on the following configurations and failures were fixed. CONFIG_GCOV_KERNEL was turned off for all tests (as my distributed build env didn't work with gcov compiles) and a few more options had to be turned off depending on archs to make things build (like ipr on powerpc/64 which failed due to missing writeq). * x86 and x86_64 UP and SMP allmodconfig and a custom test config. * powerpc and powerpc64 SMP allmodconfig * sparc and sparc64 SMP allmodconfig * ia64 SMP allmodconfig * s390 SMP allmodconfig * alpha SMP allmodconfig * um on x86_64 SMP allmodconfig 8. percpu.h modifications were reverted so that it could be applied as a separate patch and serve as bisection point. Given the fact that I had only a couple of failures from tests on step 6, I'm fairly confident about the coverage of this conversion patch. If there is a breakage, it's likely to be something in one of the arch headers which should be easily discoverable easily on most builds of the specific arch. Signed-off-by: Tejun Heo <tj@kernel.org> Guess-its-ok-by: Christoph Lameter <cl@linux-foundation.org> Cc: Ingo Molnar <mingo@redhat.com> Cc: Lee Schermerhorn <Lee.Schermerhorn@hp.com>
2010-02-10nfs41: cleanup callback code to use __be32 typeAndy Adamson
2010-02-10nfs41: fix nfs4_callback_recallslotAndy Adamson
Return NFS4_OK if target high slotid equals enforced high slotid. Fix nfs_client reference leak. Signed-off-by: Andy Adamson <andros@netapp.com> Signed-off-by: Trond Myklebust <Trond.Myklebust@netapp.com>
2010-02-10nfs41: implement cb_recall_slotAndy Adamson
Drain the fore channel and reset the max_slots to the new value. Signed-off-by: Andy Adamson <andros@netapp.com> Signed-off-by: Trond Myklebust <Trond.Myklebust@netapp.com>
2010-02-10nfs41: back channel drc minimal implementationAndy Adamson
For now the back channel ca_maxresponsesize_cached is 0 and there is no backchannel DRC. Return NFS4ERR_REP_TOO_BIG_TO_CACHE when a cb_sequence cachethis is true. When it is false, return NFS4ERR_RETRY_UNCACHED_REP as the next operation error. Remember the replay error accross compound operation processing. Signed-off-by: Andy Adamson <andros@netapp.com> Signed-off-by: Trond Myklebust <Trond.Myklebust@netapp.com>
2010-02-10nfs41: prepare for back channel drcAndy Adamson
Make all cb_sequence arguments available to verify_seqid which will make replay decisions. Signed-off-by: Andy Adamson <andros@netapp.com> Signed-off-by: Trond Myklebust <Trond.Myklebust@netapp.com>
2010-02-10nfs41: Process callback's referring call listMike Sager
If a CB_SEQUENCE referring call triple matches a slot table entry, the client is still waiting for a response to the original request. In this case, return NFS4ERR_DELAY as the response to the callback. Signed-off-by: Mike Sager <sager@netapp.com> Signed-off-by: Trond Myklebust <Trond.Myklebust@netapp.com>
2010-02-10nfs41: Check slot table for referring callsMike Sager
Traverse a list of referring calls and look for a session/slot/seq number match. Signed-off-by: Mike Sager <sager@netapp.com> Signed-off-by: Trond Myklebust <Trond.Myklebust@netapp.com>
2009-12-05nfs41: v2 fix cb_recall bugAlexandros Batsakis
in NFSv4.1 the seqid part of a stateid in CB_RECALL must be 0 Signed-off-by: Alexandros Batsakis <batsakis@netapp.com> Signed-off-by: Trond Myklebust <Trond.Myklebust@netapp.com>
2009-12-05nfs41: V2 initial support for CB_RECALL_ANYAlexandros Batsakis
For now the clients returns _all_ the delegations of the specificed type it holds Signed-off-by: Alexandros Batsakis <batsakis@netapp.com> Signed-off-by: Trond Myklebust <Trond.Myklebust@netapp.com>
2009-06-17nfs41: Backchannel: CB_SEQUENCE validationRicardo Labiaga
Validates the callback's sessionID, the slot number, and the sequence ID. Increments the slot's sequence. Detects replays, but simply prints a debug message (if debugging is enabled since we don't yet implement a duplicate request cache for the backchannel. This should not present a problem, since only idempotent callbacks are currently implemented. Signed-off-by: Ricardo Labiaga <Ricardo.Labiaga@netapp.com> Signed-off-by: Benny Halevy <bhalevy@panasas.com> [nfs41: Backchannel: Be more obvious about the return value] [nfs41: Backchannel: dprink in host order] Signed-off-by: Ricardo Labiaga <Ricardo.Labiaga@netapp.com> Signed-off-by: Benny Halevy <bhalevy@panasas.com>
2009-06-17nfs41: Backchannel: New find_client_with_session()Ricardo Labiaga
Finds the 'struct nfs_client' that matches the server's address, major version number, and session ID. Signed-off-by: Ricardo Labiaga <Ricardo.Labiaga@netapp.com> Signed-off-by: Benny Halevy <bhalevy@panasas.com>
2009-06-17nfs41: cb_sequence proc implementationBenny Halevy
Currently, just free up any referring calls information. Signed-off-by: Benny Halevy <bhalevy@panasas.com> [nfs41: fix csr_{,target}highestslotid] Signed-off-by: Benny Halevy <bhalevy@panasas.com>
