commit ed1e6211a0a134ff23592c6f057af982ad5dab52 upstream.
nfs_mark_return_delegation() is usually called without any locking, and
so it is not safe to dereference delegation->inode. Since the inode is
only used to discover the nfs_client anyway, it makes more sense to
have the callers pass a valid pointer to the nfs_server as a parameter.
Reported-by: Ian Kent <raven@themaw.net>
Signed-off-by: Trond Myklebust <Trond.Myklebust@netapp.com>
The rcu callback nfs_free_delegation_callback() just calls a kfree(),
so we use kfree_rcu() instead of the call_rcu(nfs_free_delegation_callback).
Signed-off-by: Lai Jiangshan <laijs@cn.fujitsu.com>
Cc: Trond Myklebust <Trond.Myklebust@netapp.com>
There is no reason to be freeing the delegation cred in the rcu callback,
and doing so is resulting in a lockdep complaint that rpc_credcache_lock
is being called from both softirq and non-softirq contexts.
Reported-by: Chuck Lever <chuck.lever@oracle.com>
Cc: stable@kernel.org
Delegations are per-inode, not per-nfs_client. When a server file
system is migrated, delegations on the client must be moved from the
source to the destination nfs_server. Make it easier to manage a
mount point's delegation list across a migration event by moving the
list to the nfs_server struct.
Clean up: I added documenting comments to public functions I changed
in this patch. For consistency I added comments to all the other
public functions in fs/nfs/delegation.c.
Signed-off-by: Chuck Lever <chuck.lever@oracle.com>
Clean up: Refactor code that takes clp->cl_lock and calls
nfs_detach_delegations_locked() into its own function.
While we're changing the call sites, get rid of the second parameter
and the logic in nfs_detach_delegations_locked() that uses it, since
callers always set that parameter of nfs_detach_delegations_locked()
to NULL.
The big kernel lock has been removed from all these files at some point,
leaving only the #include.
Remove this too as a cleanup.
This prepares the removal of the big kernel lock from the
file locking code. We still use the BKL as long as fs/lockd
uses it and ceph might sleep, but we can flip the definition
to a private spinlock as soon as that's done.
All users outside of fs/lockd get converted to use
lock_flocks() instead of lock_kernel() where appropriate.
Based on an earlier patch to use a spinlock from Matthew
Wilcox, who has attempted this a few times before, the
earliest patch from over 10 years ago turned it into
a semaphore, which ended up being slower than the BKL
and was subsequently reverted.
Someone should do some serious performance testing when
this becomes a spinlock, since this has caused problems
before. Using a spinlock should be at least as good
as the BKL in theory, but who knows...
Acked-by: Matthew Wilcox <willy@linux.intel.com>
Cc: Trond Myklebust <trond.myklebust@fys.uio.no>
Cc: "J. Bruce Fields" <bfields@fieldses.org>
Cc: Miklos Szeredi <mszeredi@suse.cz>
Cc: John Kacur <jkacur@redhat.com>
Cc: Sage Weil <sage@newdream.net>
Cc: linux-fsdevel@vger.kernel.org
There is no need to flush out writes before calling nfs_wb_all().
We do not want to have the state recovery thread kick off and wait for a
memory reclaim, since that may deadlock when the writebacks end up
waiting for the state recovery thread to complete.
The safe thing is therefore to use GFP_NOFS in all open, close,
delegation return, lock, etc. operations that may be called by the
state recovery thread.
Fix a number of RCU issues in the NFSv4 delegation code.
(1) delegation->cred doesn't need to be RCU protected as it's essentially an
invariant refcounted structure.
By the time we get to nfs_free_delegation(), the delegation is being
released, so no one else should be attempting to use the saved
credentials, and they can be cleared.
However, since the list of delegations could still be under traversal at
this point by such as nfs_client_return_marked_delegations(), the cred
should be released in nfs_do_free_delegation() rather than in
nfs_free_delegation(). Simply using rcu_assign_pointer() to clear it is
insufficient as that doesn't stop the cred from being destroyed, and nor
does calling put_rpccred() after call_rcu(), given that the latter is
asynchronous.
(2) nfs_detach_delegation_locked() and nfs_inode_set_delegation() should use
rcu_derefence_protected() because they can only be called if
nfs_client::cl_lock is held, and that guards against anyone changing
nfsi->delegation under it. Furthermore, the barrier imposed by
rcu_dereference() is superfluous, given that the spin_lock() is also a
barrier.
(3) nfs_detach_delegation_locked() is now passed a pointer to the nfs_client
struct so that it can issue lockdep advice based on clp->cl_lock for (2).
(4) nfs_inode_return_delegation_noreclaim() and nfs_inode_return_delegation()
should use rcu_access_pointer() outside the spinlocked region as they
merely examine the pointer and don't follow it, thus rendering unnecessary
the need to impose a partial ordering over the one item of interest.
These result in an RCU warning like the following:
[ INFO: suspicious rcu_dereference_check() usage. ]
fs/nfs/delegation.c:332 invoked rcu_dereference_check() without protection!
rcu_scheduler_active = 1, debug_locks = 0
2 locks held by mount.nfs4/2281:
#0: (&type->s_umount_key#34){+.+...}, at: [<ffffffff810b25b4>] deactivate_super+0x60/0x80
#1: (iprune_sem){+.+...}, at: [<ffffffff810c332a>] invalidate_inodes+0x39/0x13a
stack backtrace:
Pid: 2281, comm: mount.nfs4 Not tainted 2.6.34-rc1-cachefs #110
Call Trace:
[<ffffffff8105149f>] lockdep_rcu_dereference+0xaa/0xb2
[<ffffffffa00b4591>] nfs_inode_return_delegation_noreclaim+0x5b/0xa0 [nfs]
[<ffffffffa0095d63>] nfs4_clear_inode+0x11/0x1e [nfs]
[<ffffffff810c2d92>] clear_inode+0x9e/0xf8
[<ffffffff810c3028>] dispose_list+0x67/0x10e
[<ffffffff810c340d>] invalidate_inodes+0x11c/0x13a
[<ffffffff810b1dc1>] generic_shutdown_super+0x42/0xf4
[<ffffffff810b1ebe>] kill_anon_super+0x11/0x4f
[<ffffffffa009893c>] nfs4_kill_super+0x3f/0x72 [nfs]
[<ffffffff810b25bc>] deactivate_super+0x68/0x80
[<ffffffff810c6744>] mntput_no_expire+0xbb/0xf8
[<ffffffff810c681b>] release_mounts+0x9a/0xb0
[<ffffffff810c689b>] put_mnt_ns+0x6a/0x79
[<ffffffffa00983a1>] nfs_follow_remote_path+0x5a/0x146 [nfs]
[<ffffffffa0098334>] ? nfs_do_root_mount+0x82/0x95 [nfs]
[<ffffffffa00985a9>] nfs4_try_mount+0x75/0xaf [nfs]
[<ffffffffa0098874>] nfs4_get_sb+0x291/0x31a [nfs]
[<ffffffff810b2059>] vfs_kern_mount+0xb8/0x177
[<ffffffff810b2176>] do_kern_mount+0x48/0xe8
[<ffffffff810c810b>] do_mount+0x782/0x7f9
[<ffffffff810c8205>] sys_mount+0x83/0xbe
[<ffffffff81001eeb>] system_call_fastpath+0x16/0x1b
Also on:
fs/nfs/delegation.c:215 invoked rcu_dereference_check() without protection!
[<ffffffffa00b4223>] nfs_inode_set_delegation+0xfe/0x219 [nfs]
[<ffffffffa00a9c6f>] nfs4_opendata_to_nfs4_state+0x2c2/0x30d [nfs]
[<ffffffffa00aa15d>] nfs4_do_open+0x2a6/0x3a6 [nfs]
And:
fs/nfs/delegation.c:40 invoked rcu_dereference_check() without protection!
[<ffffffffa00b3bef>] nfs_free_delegation+0x3d/0x6e [nfs]
[<ffffffffa00b3e71>] nfs_do_return_delegation+0x26/0x30 [nfs]
[<ffffffffa00b406a>] __nfs_inode_return_delegation+0x1ef/0x1fe [nfs]
[<ffffffffa00b448a>] nfs_client_return_marked_delegations+0xc9/0x124 [nfs]
Ensure that we correctly rcu-dereference the delegation itself, and that we
protect against removal while we're changing the contents.
file.
files.
necessary.
* ia64 SMP allmodconfig
* s390 SMP allmodconfig
* alpha SMP allmodconfig
the specific arch.
in NFSv4.1 the seqid part of a stateid in CB_RECALL must be 0
Signed-off-by: Alexandros Batsakis <batsakis@netapp.com>
For now the clients returns _all_ the delegations of the specificed type
it holds
The nfsv4 state manager could potentially deadlock inside
__nfs_inode_return_delegation() if the server reboots, so that the calls to
nfs_msync_inode() end up waiting on state recovery to complete.
Also ensure that if a server reboot or network partition causes us to have
to stop returning delegations, that NFS4CLNT_DELEGRETURN is set so that
the state manager can resume any outstanding delegation returns after it
has dealt with the state recovery situation.
Finally, ensure that the state manager doesn't wait for the DELEGRETURN
call to complete. It doesn't need to, and that too can cause a deadlock.
* Remove smp_lock.h from files which don't need it (including some headers!)
* Add smp_lock.h to files which do need it
* Make smp_lock.h include conditional in hardirq.h
It's needed only for one kernel_locked() usage which is under CONFIG_PREEMPT
This will make hardirq.h inclusion cheaper for every PREEMPT=n config
(which includes allmodconfig/allyesconfig, BTW)
The NFSv4 delegation recovery code is required by the protocol to handle
more errors. Rather than add NFSv4.0 specific errors into 'generic'
delegation code, we should move the error handling into the NFSv4 layer.
If the client is not using a delegation, the right thing to do is to return
it as soon as possible. This helps reduce the amount of state the server
has to track, as well as reducing the potential for conflicts with other
clients.
Reuse the state management thread in order to return delegations when we
get a callback.
Let the actual delegreturn stuff be run in the state manager thread rather
than allocating a separate kthread.
It is really a more general purpose state management thread at this point.
Add a delegation cleanup phase to the state management loop, and do the
NFS4ERR_CB_PATH_DOWN recovery there.
Add a flag to mark delegations as requiring return, then run a garbage
collector. In the future, this will allow for more flexible delegation
management, where delegations may be marked for return if it turns out
that they are not being referenced.
Now that we're using the flags to indicate state that needs to be
recovered, as well as having implemented proper refcounting and spinlocking
on the state and open_owners, we can get rid of nfs_client->cl_sem. The
only remaining case that was dubious was the file locking, and that case is
now covered by the nfsi->rwsem.
Without an extra lock, we cannot just assume that the delegation->inode is
valid when we're traversing the rcu-protected nfs_client lists. Use the
delegation->lock to ensure that it is truly valid.
When we can update_open_stateid(), we need to be certain that we don't
race with a delegation return. While we could do this by grabbing the
nfs_client->cl_lock, a dedicated spin lock in the delegation structure
will scale better.
__FUNCTION__ is gcc-specific, use __func__
Signed-off-by: Harvey Harrison <harvey.harrison@gmail.com>
fs/nfs/nfs4state.c:788:34: warning: Using plain integer as NULL pointer
fs/nfs/delegation.c:52:34: warning: Using plain integer as NULL pointer
fs/nfs/idmap.c:312:12: warning: Using plain integer as NULL pointer
fs/nfs/callback_xdr.c:257:6: warning: Using plain integer as NULL pointer
fs/nfs/callback_xdr.c:270:6: warning: Using plain integer as NULL pointer
fs/nfs/callback_xdr.c:281:6: warning: Using plain integer as NULL pointer
If a (broken?) server hands out two different delegations for the same
file, then we should return one of them.
Otherwise, there is a potential deadlock if the last dput() from an NFSv4
close() or other asynchronous operation leads to nfs_clear_inode calling
the synchronous delegreturn.
To ensure the NFS client displays IPv6 addresses properly, replace
address family-specific NIPQUAD() invocations with a call to the RPC
client to get a formatted string representing the remote peer's
address.
Cc: Aurelien Charbon <aurelien.charbon@ext.bull.net>
We were intending to put the previous instance of delegation->cred
before setting a new one.
Thanks to David Howells for spotting this.
Doing so would require us to introduce bh-safe locks into put_rpccred().
This patch fixes the lockdep complaint reported by Marc Dietrich:
inconsistent {softirq-on-W} -> {in-softirq-W} usage.
swapper/0 [HC0[0]:SC1[1]:HE1:SE0] takes:
(rpc_credcache_lock){-+..}, at: [<c01dc487>]
_atomic_dec_and_lock+0x17/0x60
{softirq-on-W} state was registered at:
[<c013e870>] __lock_acquire+0x650/0x1030
[<c013f2b1>] lock_acquire+0x61/0x80
[<c02db9ac>] _spin_lock+0x2c/0x40
[<c01dc487>] _atomic_dec_and_lock+0x17/0x60
[<dced55fd>] put_rpccred+0x5d/0x100 [sunrpc]
[<dced56c1>] rpcauth_unbindcred+0x21/0x60 [sunrpc]
[<dced3fd4>] a0 [sunrpc]
[<dcecefe0>] rpc_call_sync+0x30/0x40 [sunrpc]
[<dcedc73b>] rpcb_register+0xdb/0x180 [sunrpc]
[<dced65b3>] svc_register+0x93/0x160 [sunrpc]
[<dced6ebe>] __svc_create+0x1ee/0x220 [sunrpc]
[<dced7053>] svc_create+0x13/0x20 [sunrpc]
[<dcf6d722>] nfs_callback_up+0x82/0x120 [nfs]
[<dcf48f36>] nfs_get_client+0x176/0x390 [nfs]
[<dcf49181>] nfs4_set_client+0x31/0x190 [nfs]
[<dcf49983>] nfs4_create_server+0x63/0x3b0 [nfs]
[<dcf52426>] nfs4_get_sb+0x346/0x5b0 [nfs]
[<c017b444>] vfs_kern_mount+0x94/0x110
[<c0190a62>] do_mount+0x1f2/0x7d0
[<c01910a6>] sys_mount+0x66/0xa0
[<c0104046>] syscall_call+0x7/0xb
[<ffffffff>] 0xffffffff
irq event stamp: 5277830
hardirqs last enabled at (5277830): [<c017530a>] kmem_cache_free+0x8a/0xc0
hardirqs last disabled at (5277829): [<c01752d2>] kmem_cache_free+0x52/0xc0
softirqs last enabled at (5277798): [<c0124173>] __do_softirq+0xa3/0xc0
softirqs last disabled at (5277817): [<c01241d7>] do_softirq+0x47/0x50
no locks held by swapper/0.
stack backtrace:
[<c0104fda>] show_trace_log_lvl+0x1a/0x30
[<c0105c02>] show_trace+0x12/0x20
[<c0105d15>] dump_stack+0x15/0x20
[<c013ccc3>] print_usage_bug+0x153/0x160
[<c013d8b9>] mark_lock+0x449/0x620
[<c013e824>] __lock_acquire+0x604/0x1030
[<dcf6bf83>] nfs_free_delegation_callback+0x13/0x20 [nfs]
[<c012f9ea>] __rcu_process_callbacks+0x6a/0x1c0
[<c012fb52>] rcu_process_callbacks+0x12/0x30
[<c0124218>] tasklet_action+0x38/0x80
[<c0124125>] __do_softirq+0x55/0xc0
[<c0124605>] irq_exit+0x35/0x40
[<c0112463>] smp_apic_timer_interrupt+0x43/0x80
[<c0104a77>] apic_timer_interrupt+0x33/0x38
[<c02690df>] cpuidle_idle_call+0x6f/0x90
[<c01023c3>] cpu_idle+0x43/0x70
[<c02d8c27>] rest_init+0x47/0x50
[<c03bcb6a>] start_kernel+0x22a/0x2b0
[<00000000>] 0x0
Currently we force a synchronous call to __nfs_revalidate_inode() in
nfs_inode_set_delegation(). This not only ensures that we cannot call
nfs_inode_set_delegation from an asynchronous context, but it also slows
down any call to open().
There appear to be some rogue servers out there that issue multiple
delegations with different stateids for the same file. Ensure that when we
return delegations, we do so on a per-stateid basis rather than a per-file
basis.
- fs/nfs/dir.c:610:8: warning: symbol 'nfs_llseek_dir' was not declared.
Should it be static?
- fs/nfs/dir.c:636:5: warning: symbol 'nfs_fsync_dir' was not declared.
- fs/nfs/write.c:925:19: warning: symbol 'req' shadows an earlier one
- fs/nfs/write.c:61:6: warning: symbol 'nfs_commit_rcu_free' was not
declared. Should it be static?
- fs/nfs/nfs4proc.c:793:5: warning: symbol 'nfs4_recover_expired_lease'
was not declared. Should it be static?
* Removing useless casts
* Removing useless wrapper
* Conversion from kmalloc+memset to kzalloc
Signed-off-by: Panagiotis Issaris <takis@issaris.org>
Acked-by: Dave Kleikamp <shaggy@austin.ibm.com>
Generalise the nfs_client structure by:
(1) Moving nfs_client to a more general place (nfs_fs_sb.h).
(2) Renaming its maintenance routines to be non-NFS4 specific.
(3) Move those maintenance routines to a new non-NFS4 specific file (client.c)
and move the declarations to internal.h.
(4) Make nfs_find/get_client() take a full sockaddr_in to include the port
number (will be required for NFS2/3).
(5) Make nfs_find/get_client() take the NFS protocol version (again will be
required to differentiate NFS2, 3 & 4 client records).
Also:
(6) Make nfs_client construction proceed akin to inodes, marking them as under
construction and providing a function to indicate completion.
(7) Make nfs_get_client() wait interruptibly if it finds a client that it can
share, but that client is currently being constructed.
(8) Make nfs4_create_client() use (6) and (7) instead of locking cl_sem.
Signed-Off-By: David Howells <dhowells@redhat.com>
