[ Upstream commit ad3cba223ac02dc769c3bbe88efe277bbb457566 ]
When we use direct_IO with an NFS backing store, we can trigger a
WARNING in __set_page_dirty(), as below, since we're dirtying the page
unnecessarily in nfs_direct_read_completion().
To fix, replicate the logic in commit 53cbf3b157a0 ("fs: direct-io:
don't dirtying pages for ITER_BVEC/ITER_KVEC direct read").
Other filesystems that implement direct_IO handle this; most use
blockdev_direct_IO(). ceph and cifs have similar logic.
mount 127.0.0.1:/export /nfs
dd if=/dev/zero of=/nfs/image bs=1M count=200
losetup --direct-io=on -f /nfs/image
mkfs.btrfs /dev/loop0
mount -t btrfs /dev/loop0 /mnt/
kernel: WARNING: CPU: 0 PID: 8067 at fs/buffer.c:580 __set_page_dirty+0xaf/0xd0
kernel: Modules linked in: loop(E) nfsv3(E) rpcsec_gss_krb5(E) nfsv4(E) dns_resolver(E) nfs(E) fscache(E) nfsd(E) auth_rpcgss(E) nfs_acl(E) lockd(E) grace(E) fuse(E) tun(E) ip6t_rpfilter(E) ipt_REJECT(E) nf_
kernel: snd_seq(E) snd_seq_device(E) snd_pcm(E) video(E) snd_timer(E) snd(E) soundcore(E) ip_tables(E) xfs(E) libcrc32c(E) sd_mod(E) sr_mod(E) cdrom(E) ata_generic(E) pata_acpi(E) crc32c_intel(E) ahci(E) li
kernel: CPU: 0 PID: 8067 Comm: kworker/0:2 Tainted: G E 4.20.0-rc1.master.20181111.ol7.x86_64 #1
kernel: Hardware name: innotek GmbH VirtualBox/VirtualBox, BIOS VirtualBox 12/01/2006
kernel: Workqueue: nfsiod rpc_async_release [sunrpc]
kernel: RIP: 0010:__set_page_dirty+0xaf/0xd0
kernel: Code: c3 48 8b 02 f6 c4 04 74 d4 48 89 df e8 ba 05 f7 ff 48 89 c6 eb cb 48 8b 43 08 a8 01 75 1f 48 89 d8 48 8b 00 a8 04 74 02 eb 87 <0f> 0b eb 83 48 83 e8 01 eb 9f 48 83 ea 01 0f 1f 00 eb 8b 48 83 e8
kernel: RSP: 0000:ffffc1c8825b7d78 EFLAGS: 00013046
kernel: RAX: 000fffffc0020089 RBX: fffff2b603308b80 RCX: 0000000000000001
kernel: RDX: 0000000000000001 RSI: ffff9d11478115c8 RDI: ffff9d11478115d0
kernel: RBP: ffffc1c8825b7da0 R08: 0000646f6973666e R09: 8080808080808080
kernel: R10: 0000000000000001 R11: 0000000000000000 R12: ffff9d11478115d0
kernel: R13: ffff9d11478115c8 R14: 0000000000003246 R15: 0000000000000001
kernel: FS: 0000000000000000(0000) GS:ffff9d115ba00000(0000) knlGS:0000000000000000
kernel: CS: 0010 DS: 0000 ES: 0000 CR0: 0000000080050033
kernel: CR2: 00007f408686f640 CR3: 0000000104d8e004 CR4: 00000000000606f0
kernel: DR0: 0000000000000000 DR1: 0000000000000000 DR2: 0000000000000000
kernel: DR3: 0000000000000000 DR6: 00000000fffe0ff0 DR7: 0000000000000400
kernel: Call Trace:
kernel: __set_page_dirty_buffers+0xb6/0x110
kernel: set_page_dirty+0x52/0xb0
kernel: nfs_direct_read_completion+0xc4/0x120 [nfs]
kernel: nfs_pgio_release+0x10/0x20 [nfs]
kernel: rpc_free_task+0x30/0x70 [sunrpc]
kernel: rpc_async_release+0x12/0x20 [sunrpc]
kernel: process_one_work+0x174/0x390
kernel: worker_thread+0x4f/0x3e0
kernel: kthread+0x102/0x140
kernel: ? drain_workqueue+0x130/0x130
kernel: ? kthread_stop+0x110/0x110
kernel: ret_from_fork+0x35/0x40
kernel: ---[ end trace 01341980905412c9 ]---
Signed-off-by: Dave Kleikamp <dave.kleikamp@oracle.com>
Signed-off-by: Santosh Shilimkar <santosh.shilimkar@oracle.com>
[forward-ported to v4.20]
Signed-off-by: Calum Mackay <calum.mackay@oracle.com>
Reviewed-by: Dave Kleikamp <dave.kleikamp@oracle.com>
Reviewed-by: Chuck Lever <chuck.lever@oracle.com>
Signed-off-by: Trond Myklebust <trond.myklebust@hammerspace.com>
commit d9ee65539d3eabd9ade46cca1780e3309ad0f907 upstream.
The start offset needs to be of type loff_t.
Fixed: 5fadeb47dcc5c ("nfs: count DIO good bytes correctly with mirroring")
Cc: stable@vger.kernel.org # v4.0+
Signed-off-by: Trond Myklebust <trond.myklebust@primarydata.com>
commit 1b8d97b0a837beaf48a8449955b52c650a7114b4 upstream.
If some of the WRITE calls making up an O_DIRECT write syscall fail,
we neglect to commit, even if some of the WRITEs succeed.
We also depend on the commit code to free the reference count on the
nfs_page taken in the "if (request_commit)" case at the end of
nfs_direct_write_completion(). The problem was originally noticed
because ENOSPC's encountered partway through a write would result in a
closed file being sillyrenamed when it should have been unlinked.
Signed-off-by: J. Bruce Fields <bfields@redhat.com>
The commit lists can get very large, so using the inode->i_lock can
end up affecting general metadata performance.
Pull NFS client updates from Trond Myklebust:
"Highlights include:
Stable bugfixes:
- Fix use after free in write error path
- Use GFP_NOIO for two allocations in writeback
- Fix a hang in OPEN related to server reboot
- Check the result of nfs4_pnfs_ds_connect
- Fix an rcu lock leak
Features:
- Removal of the unmaintained and unused OSD pNFS layout
- Cleanup and removal of lots of unnecessary dprintk()s
- Cleanup and removal of some memory failure paths now that GFP_NOFS
is guaranteed to never fail.
- Remove the v3-only data server limitation on pNFS/flexfiles
Bugfixes:
- RPC/RDMA connection handling bugfixes
- Copy offload: fixes to ensure the copied data is COMMITed to disk.
- Readdir: switch back to using the ->iterate VFS interface
- File locking fixes from Ben Coddington
- Various use-after-free and deadlock issues in pNFS
- Write path bugfixes"
* tag 'nfs-for-4.12-1' of git://git.linux-nfs.org/projects/trondmy/linux-nfs: (89 commits)
pNFS/flexfiles: Always attempt to call layoutstats when flexfiles is enabled
NFSv4.1: Work around a Linux server bug...
NFS append COMMIT after synchronous COPY
NFSv4: Fix exclusive create attributes encoding
NFSv4: Fix an rcu lock leak
nfs: use kmap/kunmap directly
NFS: always treat the invocation of nfs_getattr as cache hit when noac is on
Fix nfs_client refcounting if kmalloc fails in nfs4_proc_exchange_id and nfs4_proc_async_renew
NFSv4.1: RECLAIM_COMPLETE must handle NFS4ERR_CONN_NOT_BOUND_TO_SESSION
pNFS: Fix NULL dereference in pnfs_generic_alloc_ds_commits
pNFS: Fix a typo in pnfs_generic_alloc_ds_commits
pNFS: Fix a deadlock when coalescing writes and returning the layout
pNFS: Don't clear the layout return info if there are segments to return
pNFS: Ensure we commit the layout if it has been invalidated
pNFS: Don't send COMMITs to the DSes if the server invalidated our layout
pNFS/flexfiles: Fix up the ff_layout_write_pagelist failure path
pNFS: Ensure we check layout validity before marking it for return
NFS4.1 handle interrupted slot reuse from ERR_DELAY
NFSv4: check return value of xdr_inline_decode
nfs/filelayout: fix NULL pointer dereference in fl_pnfs_update_layout()
Signed-off-by: Anna Schumaker <Anna.Schumaker@Netapp.com>
Just remove the function and have the caller use nfs_release_request()
instead.
It leaves the iterator advanced by the amount of IO it has requested
instead of the amount actually transferred. Among other things,
that confuses the hell out of generic_file_splice_read().
This was entirely automated, using the script by Al:
PATT='^[[:blank:]]*#[[:blank:]]*include[[:blank:]]*<asm/uaccess.h>'
sed -i -e "s!$PATT!#include <linux/uaccess.h>!" \
$(git grep -l "$PATT"|grep -v ^include/linux/uaccess.h)
to do the replacement at the end of the merge window.
Requested-by: Al Viro <viro@zeniv.linux.org.uk>
This parameter hasn't been used since 2a009ec9 (Linux 3.13-rc3), so
let's remove it from this function.
There is only one waiter for the completion, therefore there
is no need to use complete_all(). Let's make that clear by
using complete() instead of complete_all().
nfs_file_direct_write() or nfs_file_direct_read() allocated a request
object via nfs_direct_req_alloc(), which initializes the
completion. The request object then is freed later in the exit path.
Between the initialization and the release either
nfs_direct_write_schedule_iovec() resp
nfs_direct_read_schedule_iovec() are called which will asynchronously
process the request. The calling function waits via nfs_direct_wait()
till the async work has been done. Thus there is only one waiter on
the completion.
nfs_direct_pgio_init() and nfs_direct_read_completion() are passed via
function pointers to nfs pageio. The first function does a ref
counting (get_dreq() and put_dreq()) which ensures that
nfs_direct_read_completion() and nfs_direct_read_schedule_iovec() only
call the completion path once.
The usage pattern of the completion is:
waiter context waker context
dreq = nfs_direct_req_alloc()
init_completion()
nfs_direct_wait()
wait_for_completion_killable()
nfs_direct_write_schedule_work()
nfs_direct_complete()
complete()
dreq = nfs_direct_req_all()
init_completion()
nfs_direct_wait()
complete()
complete()
Signed-off-by: Daniel Wagner <daniel.wagner@bmw-carit.de>
Stable bugfixes:
- nfs: don't create zero-length requests
- several LAYOUTGET bugfixes
Features:
- several performance related features
- more aggressive caching when we can rely on close-to-open
cache consistency
- remove serialisation of O_DIRECT reads and writes
- optimise several code paths to not flush to disk unnecessarily.
However allow for the idiosyncracies of pNFS for those layout
types that need to issue a LAYOUTCOMMIT before the metadata can
be updated on the server.
- SUNRPC updates to the client data receive path
- pNFS/SCSI support RH/Fedora dm-mpath device nodes
- pNFS files/flexfiles can now use unprivileged ports when
the generic NFS mount options allow it.
Bugfixes:
- Don't use RDMA direct data placement together with data
integrity or privacy security flavours
- Remove the RDMA ALLPHYSICAL memory registration mode as
it has potential security holes.
- Several layout recall fixes to improve NFSv4.1 protocol
compliance.
- Fix an Oops in the pNFS files and flexfiles connection
setup to the DS
- Allow retry of operations that used a returned delegation
stateid
- Don't mark the inode as revalidated if a LAYOUTCOMMIT is
outstanding
- Fix writeback races in nfs4_copy_range() and
nfs42_proc_deallocate()"
* tag 'nfs-for-4.8-1' of git://git.linux-nfs.org/projects/trondmy/linux-nfs: (104 commits)
pNFS: Actively set attributes as invalid if LAYOUTCOMMIT is outstanding
NFSv4: Clean up lookup of SECINFO_NO_NAME
NFSv4.2: Fix warning "variable ‘stateids’ set but not used"
NFSv4: Fix warning "no previous prototype for ‘nfs4_listxattr’"
SUNRPC: Fix a compiler warning in fs/nfs/clnt.c
pNFS: Remove redundant smp_mb() from pnfs_init_lseg()
pNFS: Cleanup - do layout segment initialisation in one place
pNFS: Remove redundant stateid invalidation
pNFS: Remove redundant pnfs_mark_layout_returned_if_empty()
pNFS: Clear the layout metadata if the server changed the layout stateid
pNFS: Cleanup - don't open code pnfs_mark_layout_stateid_invalid()
NFS: pnfs_mark_matching_lsegs_return() should match the layout sequence id
pNFS: Do not set plh_return_seq for non-callback related layoutreturns
pNFS: Ensure layoutreturn acts as a completion for layout callbacks
pNFS: Fix CB_LAYOUTRECALL stateid verification
pNFS: Always update the layout barrier seqid on LAYOUTGET
pNFS: Always update the layout stateid if NFS_LAYOUT_INVALID_STID is set
pNFS: Clear the layout return tracking on layout reinitialisation
pNFS: LAYOUTRETURN should only update the stateid if the layout is valid
Pull vfs updates from Al Viro:
"Assorted cleanups and fixes.
Probably the most interesting part long-term is ->d_init() - that will
have a bunch of followups in (at least) ceph and lustre, but we'll
need to sort the barrier-related rules before it can get used for
really non-trivial stuff.
Another fun thing is the merge of ->d_iput() callers (dentry_iput()
and dentry_unlink_inode()) and a bunch of ->d_compare() ones (all
except the one in __d_lookup_lru())"
* 'work.misc' of git://git.kernel.org/pub/scm/linux/kernel/git/viro/vfs: (26 commits)
fs/dcache.c: avoid soft-lockup in dput()
vfs: new d_init method
vfs: Update lookup_dcache() comment
bdev: get rid of ->bd_inodes
Remove last traces of ->sync_page
new helper: d_same_name()
dentry_cmp(): use lockless_dereference() instead of smp_read_barrier_depends()
vfs: clean up documentation
vfs: document ->d_real()
vfs: merge .d_select_inode() into .d_real()
unify dentry_iput() and dentry_unlink_inode()
binfmt_misc: ->s_root is not going anywhere
drop redundant ->owner initializations
ufs: get rid of redundant checks
orangefs: constify inode_operations
missed comment updates from ->direct_IO() prototype change
file_inode(f)->i_mapping is f->f_mapping
trim fsnotify hooks a bit
9p: new helper - v9fs_parent_fid()
debugfs: ->d_parent is never NULL or negative
There is only one caller that sets the "write" argument to true,
so just move the call to nfs_zap_mapping() and get rid of the
now redundant argument.
Allow dio requests to be scheduled in parallel, but ensuring that they
do not conflict with buffered I/O.
On success, the RPC callbacks will ensure that we make the appropriate calls
to nfs_writeback_update_inode()
We should not be interested in looking at the value of the stable field,
since that could take any value.
if we read or wrote something, we must report it
Reviewed-by: Jeff Layton <jlayton@poochiereds.net>
Pull NFS client updates from Anna Schumaker:
Features:
- Add support for the NFS v4.2 COPY operation
- Add support for NFS/RDMA over IPv6
Bugfixes and cleanups:
- Avoid race that crashes nfs_init_commit()
- Fix oops in callback path
- Fix LOCK/OPEN race when unlinking an open file
- Choose correct stateids when using delegations in setattr, read and
write
- Don't send empty SETATTR after OPEN_CREATE
- xprtrdma: Prevent server from writing a reply into memory client
has released
- xprtrdma: Support using Read list and Reply chunk in one RPC call"
* tag 'nfs-for-4.7-1' of git://git.linux-nfs.org/projects/anna/linux-nfs: (61 commits)
pnfs: pnfs_update_layout needs to consider if strict iomode checking is on
nfs/flexfiles: Use the layout segment for reading unless it a IOMODE_RW and reading is disabled
nfs/flexfiles: Helper function to detect FF_FLAGS_NO_READ_IO
nfs: avoid race that crashes nfs_init_commit
NFS: checking for NULL instead of IS_ERR() in nfs_commit_file()
pnfs: make pnfs_layout_process more robust
pnfs: rework LAYOUTGET retry handling
pnfs: lift retry logic from send_layoutget to pnfs_update_layout
pnfs: fix bad error handling in send_layoutget
flexfiles: add kerneldoc header to nfs4_ff_layout_prepare_ds
flexfiles: remove pointless setting of NFS_LAYOUT_RETURN_REQUESTED
pnfs: only tear down lsegs that precede seqid in LAYOUTRETURN args
pnfs: keep track of the return sequence number in pnfs_layout_hdr
pnfs: record sequence in pnfs_layout_segment when it's created
pnfs: don't merge new ff lsegs with ones that have LAYOUTRETURN bit set
pNFS/flexfiles: When initing reads or writes, we might have to retry connecting to DSes
pNFS/flexfiles: When checking for available DSes, conditionally check for MDS io
pNFS/flexfile: Fix erroneous fall back to read/write through the MDS
NFS: Reclaim writes via writepage are opportunistic
NFSv4: Use the right stateid for delegations in setattr, read and write
Pull vfs cleanups from Al Viro:
"More cleanups from Christoph"
* 'work.preadv2' of git://git.kernel.org/pub/scm/linux/kernel/git/viro/vfs:
nfsd: use RWF_SYNC
fs: add RWF_DSYNC aand RWF_SYNC
ceph: use generic_write_sync
fs: simplify the generic_write_sync prototype
fs: add IOCB_SYNC and IOCB_DSYNC
direct-io: remove the offset argument to dio_complete
direct-io: eliminate the offset argument to ->direct_IO
xfs: eliminate the pos variable in xfs_file_dio_aio_write
filemap: remove the pos argument to generic_file_direct_write
filemap: remove pos variables in generic_file_read_iter
Commit ea2cf22 created nfs_commit_info and saved &inode->i_lock inside
this NFS specific structure. This obscures the usage of i_lock.
Instead, save struct inode * so later it's clear the spinlock taken is
i_lock.
Should be no functional change.
Signed-off-by: Dave Wysochanski <dwysocha@redhat.com>
This will pop a warning if we count too many good bytes.
Signed-off-by: Weston Andros Adamson <dros@primarydata.com>
The rest of work.xattr stuff isn't needed for this branch
The kiocb already has the new position, so use that. The only interesting
case is AIO, where we currently don't bother updating ki_pos. We're about
to free the kiocb after we're done, so we might as well update it to make
everyone's life simpler.
While we're at it also return the bytes written argument passed in if
we were successful so that the boilerplate error switch code in the
callers can go away.
This will allow us to do per-I/O sync file writes, as required by a lot
of fileservers or storage targets.
XXX: Will need a few additional audits for O_DSYNC
Including blkdev_direct_IO and dax_do_io. It has to be ki_pos to actually
work, so eliminate the superflous argument.
... and neither can ever be NULL
PAGE_CACHE_{SIZE,SHIFT,MASK,ALIGN} macros were introduced *long* time
ago with promise that one day it will be possible to implement page
cache with bigger chunks than PAGE_SIZE.
This promise never materialized. And unlikely will.
We have many places where PAGE_CACHE_SIZE assumed to be equal to
PAGE_SIZE. And it's constant source of confusion on whether
PAGE_CACHE_* or PAGE_* constant should be used in a particular case,
especially on the border between fs and mm.
Global switching to PAGE_CACHE_SIZE != PAGE_SIZE would cause to much
breakage to be doable.
Let's stop pretending that pages in page cache are special. They are
not.
The changes are pretty straight-forward:
- <foo> << (PAGE_CACHE_SHIFT - PAGE_SHIFT) -> <foo>;
- <foo> >> (PAGE_CACHE_SHIFT - PAGE_SHIFT) -> <foo>;
- PAGE_CACHE_{SIZE,SHIFT,MASK,ALIGN} -> PAGE_{SIZE,SHIFT,MASK,ALIGN};
- page_cache_get() -> get_page();
- page_cache_release() -> put_page();
This patch contains automated changes generated with coccinelle using
script below. For some reason, coccinelle doesn't patch header files.
I've called spatch for them manually.
The only adjustment after coccinelle is revert of changes to
PAGE_CAHCE_ALIGN definition: we are going to drop it later.
There are few places in the code where coccinelle didn't reach. I'll
fix them manually in a separate patch. Comments and documentation also
will be addressed with the separate patch.
virtual patch
expression E;
- E << (PAGE_CACHE_SHIFT - PAGE_SHIFT)
+ E
expression E;
- E >> (PAGE_CACHE_SHIFT - PAGE_SHIFT)
+ E
- PAGE_CACHE_SHIFT
+ PAGE_SHIFT
- PAGE_CACHE_SIZE
+ PAGE_SIZE
- PAGE_CACHE_MASK
+ PAGE_MASK
expression E;
- PAGE_CACHE_ALIGN(E)
+ PAGE_ALIGN(E)
expression E;
- page_cache_get(E)
+ get_page(E)
expression E;
- page_cache_release(E)
+ put_page(E)
parallel to mutex_{lock,unlock,trylock,is_locked,lock_nested},
inode_foo(inode) being mutex_foo(&inode->i_mutex).
Please, use those for access to ->i_mutex; over the coming cycle
->i_mutex will become rwsem, with ->lookup() done with it held
only shared.
* pnfs_generic:
NFSv4.1/pNFS: Cleanup constify struct pnfs_layout_range arguments
NFSv4.1/pnfs: Cleanup copying of pnfs_layout_range structures
NFSv4.1/pNFS: Cleanup pnfs_mark_matching_lsegs_invalid()
NFSv4.1/pNFS: Fix a race in initiate_file_draining()
NFSv4.1/pNFS: pnfs_error_mark_layout_for_return() must always return layout
NFSv4.1/pNFS: pnfs_mark_matching_lsegs_return() should set the iomode
NFSv4.1/pNFS: Use nfs4_stateid_copy for copying stateids
NFSv4.1/pNFS: Don't pass stateids by value to pnfs_send_layoutreturn()
NFS: Relax requirements in nfs_flush_incompatible
NFSv4.1/pNFS: Don't queue up a new commit if the layout segment is invalid
NFS: Allow multiple commit requests in flight per file
NFS/pNFS: Fix up pNFS write reschedule layering violations and bugs
NFSv4: List stateid information in the callback tracepoints
NFSv4.1/pNFS: Don't return NFS4ERR_DELAY unnecessarily in CB_LAYOUTRECALL
NFSv4.1/pNFS: Ensure we enforce RFC5661 Section 12.5.5.2.1
pNFS: If we have to delay the layout callback, mark the layout for return
NFSv4.1/pNFS: Add a helper to mark the layout as returned
pNFS: Ensure nfs4_layoutget_prepare returns the correct error
If the layout segment is invalid, then we should not be adding more
write requests to the commit list. Instead, those writes should be
replayed after requesting a new layout.
Allow synchronous RPC calls to wait for pending RPC calls to finish,
but also allow asynchronous ones to just fire off another commit.
With this patch, the xfstests generic/074 test completes in 226s
instead of 242s
The flexfiles layout in particular, seems to want to poke around in the
O_DIRECT flags when retransmitting.
This patch sets up an interface to allow it to call back into O_DIRECT
to handle retransmission correctly. It also fixes a potential bug whereby
we could change the behaviour of O_DIRECT if an error is already pending.
For ERESTARTSYS/EIO/EROFS/ENOSPC/E2BIG in layoutget, we
should just bail out instead of hiding the error and
retrying inband IO.
Change all the call sites to pop the error all the way up.
Signed-off-by: Peng Tao <tao.peng@primarydata.com>
When lseg's commit_through_mds is set, pnfs client always WARN once
in nfs_direct_select_verf after checking ds_cinfo.nbuckets.
nfs should use the DS verf except commit_through_mds is set for
layout segment where nbuckets is zero.
[17844.666094] ------------[ cut here ]------------
[17844.667071] WARNING: CPU: 0 PID: 21758 at /root/source/linux-pnfs/fs/nfs/direct.c:174 nfs_direct_select_verf+0x5a/0x70 [nfs]()
[17844.668650] Modules linked in: nfs_layout_nfsv41_files(OE) nfsv4(OE) nfs(OE) fscache(E) nfsd(OE) xfs libcrc32c btrfs ppdev coretemp crct10dif_pclmul auth_rpcgss crc32_pclmul crc32c_intel nfs_acl ghash_clmulni_intel lockd vmw_balloon xor vmw_vmci grace raid6_pq shpchp sunrpc parport_pc i2c_piix4 parport vmwgfx drm_kms_helper ttm drm serio_raw mptspi e1000 scsi_transport_spi mptscsih mptbase ata_generic pata_acpi [last unloaded: fscache]
[17844.686676] CPU: 0 PID: 21758 Comm: kworker/0:1 Tainted: G W OE 4.3.0-rc1-pnfs+ #245
[17844.687352] Hardware name: VMware, Inc. VMware Virtual Platform/440BX Desktop Reference Platform, BIOS 6.00 05/20/2014
[17844.698502] Workqueue: nfsiod rpc_async_release [sunrpc]
[17844.699212] 0000000000000009 0000000043e58010 ffff8800454fbc10 ffffffff813680c4
[17844.699990] ffff8800454fbc48 ffffffff8108b49d ffff88004eb20000 ffff88004eb20000
[17844.700844] ffff880062e26000 0000000000000000 0000000000000001 ffff8800454fbc58
[17844.701637] Call Trace:
[17844.725252] [<ffffffff813680c4>] dump_stack+0x19/0x25
[17844.732693] [<ffffffff8108b49d>] warn_slowpath_common+0x7d/0xb0
[17844.733855] [<ffffffff8108b5da>] warn_slowpath_null+0x1a/0x20
[17844.735015] [<ffffffffa04a27ca>] nfs_direct_select_verf+0x5a/0x70 [nfs]
[17844.735999] [<ffffffffa04a2b83>] nfs_direct_set_hdr_verf+0x23/0x90 [nfs]
[17844.736846] [<ffffffffa04a2e17>] nfs_direct_write_completion+0x227/0x260 [nfs]
[17844.737782] [<ffffffffa04a433c>] nfs_pgio_release+0x1c/0x20 [nfs]
[17844.738597] [<ffffffffa0502df3>] pnfs_generic_rw_release+0x23/0x30 [nfsv4]
[17844.739486] [<ffffffffa01cbbea>] rpc_free_task+0x2a/0x70 [sunrpc]
[17844.740326] [<ffffffffa01cbcd5>] rpc_async_release+0x15/0x20 [sunrpc]
[17844.741173] [<ffffffff810a387c>] process_one_work+0x21c/0x4c0
[17844.741984] [<ffffffff810a37cd>] ? process_one_work+0x16d/0x4c0
[17844.742837] [<ffffffff810a3b6a>] worker_thread+0x4a/0x440
[17844.743639] [<ffffffff810a3b20>] ? process_one_work+0x4c0/0x4c0
[17844.744399] [<ffffffff810a3b20>] ? process_one_work+0x4c0/0x4c0
[17844.745176] [<ffffffff810a8d75>] kthread+0xf5/0x110
[17844.745927] [<ffffffff810a8c80>] ? kthread_create_on_node+0x240/0x240
[17844.747105] [<ffffffff8172ce1f>] ret_from_fork+0x3f/0x70
[17844.747856] [<ffffffff810a8c80>] ? kthread_create_on_node+0x240/0x240
[17844.748642] ---[ end trace 336a2845d42b83f0 ]---
Signed-off-by: Kinglong Mee <kinglongmee@gmail.com>
"Another set of mainly bugfixes and a couple of cleanups. No new
functionality in this round.
Highlights include:
Stable patches:
- Fix a regression in /proc/self/mountstats
- Fix the pNFS flexfiles O_DIRECT support
- Fix high load average due to callback thread sleeping
Bugfixes:
- Various patches to fix the pNFS layoutcommit support
- Do not cache pNFS deviceids unless server notifications are enabled
- Fix a SUNRPC transport reconnection regression
- make debugfs file creation failure non-fatal in SUNRPC
- Another fix for circular directory warnings on NFSv4 "junctioned"
mountpoints
- Fix locking around NFSv4.2 fallocate() support
- Truncating NFSv4 file opens should also sync O_DIRECT writes
- Prevent infinite loop in rpcrdma_ep_create()
Features:
- Various improvements to the RDMA transport code's handling of
memory registration
- Various code cleanups"
* tag 'nfs-for-4.1-1' of git://git.linux-nfs.org/projects/trondmy/linux-nfs: (55 commits)
fs/nfs: fix new compiler warning about boolean in switch
nfs: Remove unneeded casts in nfs
NFS: Don't attempt to decode missing directory entries
Revert "nfs: replace nfs_add_stats with nfs_inc_stats when add one"
NFS: Rename idmap.c to nfs4idmap.c
NFS: Move nfs_idmap.h into fs/nfs/
NFS: Remove CONFIG_NFS_V4 checks from nfs_idmap.h
NFS: Add a stub for GETDEVICELIST
nfs: remove WARN_ON_ONCE from nfs_direct_good_bytes
nfs: fix DIO good bytes calculation
nfs: Fetch MOUNTED_ON_FILEID when updating an inode
sunrpc: make debugfs file creation failure non-fatal
nfs: fix high load average due to callback thread sleeping
NFS: Reduce time spent holding the i_mutex during fallocate()
NFS: Don't zap caches on fallocate()
xprtrdma: Make rpcrdma_{un}map_one() into inline functions
xprtrdma: Handle non-SEND completions via a callout
xprtrdma: Add "open" memreg op
xprtrdma: Add "destroy MRs" memreg op
xprtrdma: Add "reset MRs" memreg op
do_blockdev_direct_IO() increments and decrements the inode
->i_dio_count for each IO operation. It does this to protect against
truncate of a file. Block devices don't need this sort of protection.
For a capable multiqueue setup, this atomic int is the only shared
state between applications accessing the device for O_DIRECT, and it
presents a scaling wall for that. In my testing, as much as 30% of
system time is spent incrementing and decrementing this value. A mixed
read/write workload improved from ~2.5M IOPS to ~9.6M IOPS, with
better latencies too. Before:
clat percentiles (usec):
| 1.00th=[ 33], 5.00th=[ 34], 10.00th=[ 34], 20.00th=[ 34],
| 30.00th=[ 34], 40.00th=[ 34], 50.00th=[ 35], 60.00th=[ 35],
| 70.00th=[ 35], 80.00th=[ 35], 90.00th=[ 37], 95.00th=[ 80],
| 99.00th=[ 98], 99.50th=[ 151], 99.90th=[ 155], 99.95th=[ 155],
| 99.99th=[ 165]
After:
| 1.00th=[ 95], 5.00th=[ 108], 10.00th=[ 129], 20.00th=[ 149],
| 30.00th=[ 155], 40.00th=[ 161], 50.00th=[ 167], 60.00th=[ 171],
| 70.00th=[ 177], 80.00th=[ 185], 90.00th=[ 201], 95.00th=[ 270],
| 99.00th=[ 390], 99.50th=[ 398], 99.90th=[ 418], 99.95th=[ 422],
| 99.99th=[ 438]
In other setups, Robert Elliott reported seeing good performance
improvements:
https://lkml.org/lkml/2015/4/3/557
The more applications accessing the device, the worse it gets.
Add a new direct-io flags, DIO_SKIP_DIO_COUNT, which tells
do_blockdev_direct_IO() that it need not worry about incrementing
or decrementing the inode i_dio_count for this caller.
Cc: Theodore Ts'o <tytso@mit.edu>
Cc: Elliott, Robert (Server Storage) <elliott@hp.com>
Signed-off-by: Jens Axboe <axboe@fb.com>
For flexfiles driver, we might choose to read from mirror index other
than 0 while mirror_count is always 1 for read.
Reported-by: Jean Spector <jean@primarydata.com>
Cc: <stable@vger.kernel.org> # v3.19+
Cc: Weston Andros Adamson <dros@primarydata.com>
For direct read that has IO size larger than rsize, we'll split
it into several READ requests and nfs_direct_good_bytes() would
count completed bytes incorrectly by eating last zero count reply.
Fix it by handling mirror and non-mirror cases differently such that
we only count mirrored writes differently.
This fixes 5fadeb47("nfs: count DIO good bytes correctly with mirroring").
that's the bulk of filesystem drivers dealing with inodes of their own
... returning -E... upon error and amount of data left in iter after
(possible) truncation upon success. Note, that normal case gives
a non-zero (positive) return value, so any tests for != 0 _must_ be
updated.
fs/ext4/file.c
all remaining callers are passing 0; some just obscure that fact.
Now that no one is using rw, remove it completely.
Signed-off-by: Omar Sandoval <osandov@osandov.com>
The rw parameter to direct_IO is redundant with iov_iter->type, and
treated slightly differently just about everywhere it's used: some users
do rw & WRITE, and others do rw == WRITE where they should be doing a
bitwise check. Simplify this with the new iov_iter_rw() helper, which
always returns either READ or WRITE.
