path: root/fs/nfs/direct.c
2006-12-08[PATCH] nfs: change uses of f_{dentry,vfsmnt} to use f_pathJosef "Jeff" Sipek
Change all the uses of f_{dentry,vfsmnt} to f_path.{dentry,mnt} in the nfs client code. Signed-off-by: Josef "Jeff" Sipek <jsipek@cs.sunysb.edu> Signed-off-by: Andrew Morton <akpm@osdl.org> Signed-off-by: Linus Torvalds <torvalds@osdl.org>
2006-12-07Merge branch 'master' of /home/trondmy/kernel/linux-2.6/ into merge_linusTrond Myklebust
2006-12-06NFS: Remove use of the Big Kernel Lock around calls to rpc_execute.Frank Filz
Remove use of the Big Kernel Lock around calls to rpc_execute. Signed-off-by: Frank Filz <ffilz@us.ibm.com> Signed-off-by: Trond Myklebust <Trond.Myklebust@netapp.com>
2006-10-20[PATCH] NFS: Deal with failure of invalidate_inode_pages2()Trond Myklebust
If invalidate_inode_pages2() fails, then it should in principle just be because the current process was signalled. In that case, we just want to ensure that the inode's page cache remains marked as invalid. Also add a helper to allow the O_DIRECT code to simply mark the page cache as invalid once it is finished writing, instead of calling invalidate_inode_pages2() itself. Signed-off-by: Trond Myklebust <Trond.Myklebust@netapp.com> Signed-off-by: Andrew Morton <akpm@osdl.org> Signed-off-by: Linus Torvalds <torvalds@osdl.org>
2006-10-20[PATCH] NFS: Fix error handling in nfs_direct_write_result()Trond Myklebust
If the RPC call tanked, we should not be checking the return value of data->res.verf->committed, since it is unlikely to even be initialised. Signed-off-by: Trond Myklebust <Trond.Myklebust@netapp.com> Signed-off-by: Andrew Morton <akpm@osdl.org> Signed-off-by: Linus Torvalds <torvalds@osdl.org>
2006-10-01[PATCH] Vectorize aio_read/aio_write fileop methodsBadari Pulavarty
This patch vectorizes aio_read() and aio_write() methods to prepare for collapsing all aio & vectored operations into one interface - which is aio_read()/aio_write(). Signed-off-by: Badari Pulavarty <pbadari@us.ibm.com> Signed-off-by: Christoph Hellwig <hch@lst.de> Cc: Michael Holzheu <HOLZHEU@de.ibm.com> Signed-off-by: Andrew Morton <akpm@osdl.org> Signed-off-by: Linus Torvalds <torvalds@osdl.org>
2006-09-27[PATCH] Really ignore kmem_cache_destroy return valueAlexey Dobriyan
* Rougly half of callers already do it by not checking return value * Code in drivers/acpi/osl.c does the following to be sure: (void)kmem_cache_destroy(cache); * Those who check it printk something, however, slab_error already printed the name of failed cache. * XFS BUGs on failed kmem_cache_destroy which is not the decision low-level filesystem driver should make. Converted to ignore. Signed-off-by: Alexey Dobriyan <adobriyan@gmail.com> Signed-off-by: Andrew Morton <akpm@osdl.org> Signed-off-by: Linus Torvalds <torvalds@osdl.org>
2006-09-08[PATCH] NFS: large non-page-aligned direct I/O clobbers memoryTrond Myklebust
The logic in nfs_direct_read_schedule and nfs_direct_write_schedule can allow data->npages to be one larger than rpages. This causes a page pointer to be written beyond the end of the pagevec in nfs_read_data (or nfs_write_data). Fix this by making nfs_(read|write)_alloc() calculate the size of the pagevec array, and initialise data->npages. Also get rid of the redundant argument to nfs_commit_alloc(). Signed-off-by: Trond Myklebust <Trond.Myklebust@netapp.com> Cc: Chuck Lever <chuck.lever@oracle.com> Signed-off-by: Andrew Morton <akpm@osdl.org> Signed-off-by: Linus Torvalds <torvalds@osdl.org>
2006-07-03Merge branch 'master' of /home/trondmy/kernel/linux-2.6/Trond Myklebust
2006-06-28Revert "Merge branch 'odirect'"Trond Myklebust
This reverts ccf01ef7aa9c6c293a1c64c27331a2ce227916ec commit. No idea how git managed this one: when I asked it to merge the odirect topic branch it actually generated a patch which reverted the change. Reverting the 'merge' will once again reveal Chuck's recent NFS/O_DIRECT work to the world. Signed-off-by: Trond Myklebust <Trond.Myklebust@netapp.com>
2006-06-27[PATCH] fix static linking of NFSDavid Brownell
Builds on ARM report link problems with common configurations like statically linked NFS (for nfsroot). The symptom is that __init section code references __exit section code; that won't work since the exit sections are discarded (since they can never be called). The best fix for these particular cases would be an "__init_or_exit" section annotation. Signed-off-by: David Brownell <dbrownell@users.sourceforge.net> Acked-by: Trond Myklebust <trond.myklebust@fys.uio.no> Signed-off-by: Linus Torvalds <torvalds@osdl.org>
2006-06-25Merge branch 'odirect'Trond Myklebust
2006-06-24NFS: alloc nfs_read/write_data as direct I/O is scheduledChuck Lever
Re-arrange the logic in the NFS direct I/O path so that nfs_read/write_data structs are allocated just before they are scheduled, rather than allocating them all at once before we start scheduling requests. Signed-off-by: Chuck Lever <cel@netapp.com> Signed-off-by: Trond Myklebust <Trond.Myklebust@netapp.com>
2006-06-24NFS: Eliminate nfs_get_user_pages()Chuck Lever
Neil Brown observed that the kmalloc() in nfs_get_user_pages() is more likely to fail if the I/O is large enough to require the allocation of more than a single page to keep track of all the pinned pages in the user's buffer. Instead of tracking one large page array per dreq/iocb, track pages per nfs_read/write_data, just like the cached I/O path does. An array for pages is already allocated for us by nfs_readdata_alloc() (and the write and commit equivalents). This is also required for adding support for vectored I/O to the NFS direct I/O path. The original reason to pin the user buffer and allocate all the NFS data structures before trying to schedule I/O was to ensure all needed resources are allocated on the client before starting to send requests. This reduces the chance that resource exhaustion on the client will cause a short read or write. On the other hand, for an application making very large application I/O requests, this means that it will be nearly impossible for the application to make forward progress on a resource-limited client. Thus, moving the buffer pinning functionality into the I/O scheduling loops should be good for scalability. The next patch will do the same for NFS data structure allocation. Signed-off-by: Chuck Lever <cel@netapp.com> Signed-off-by: Trond Myklebust <Trond.Myklebust@netapp.com>
2006-06-24NFS: refactor nfs_direct_free_user_pagesChuck Lever
Clean-up and fix a minor bug: the logic was dirtying page cache pages on both read and write operations. Signed-off-by: Chuck Lever <cel@netapp.com> Signed-off-by: Trond Myklebust <Trond.Myklebust@netapp.com>
2006-06-24NFS: remove user_addr, user_count, and pos from nfs_direct_reqChuck Lever
Make the user_addr, user_count, and pos parameters explicit to the scheduler routines, and remove the fields from nfs_direct_req. The iovec API will be passing in a series of these, not just one set. Signed-off-by: Chuck Lever <cel@netapp.com> Signed-off-by: Trond Myklebust <Trond.Myklebust@netapp.com>
2006-06-24NFS: "open code" the NFS direct write reschedulerChuck Lever
An NFSv3/v4 client must reschedule on-the-wire writes if the writes are UNSTABLE, and the server reboots before the client can complete a subsequent COMMIT request. To support direct asynchronous scatter-gather writes, the write rescheduler in fs/nfs/direct.c must not depend on the I/O parameters in the controlling nfs_direct_req structure. iovecs can be somewhat arbitrarily complex, so there could be an unbounded amount of information to save for a rarely encountered requirement. Refactor the direct write rescheduler so it uses information from each nfs_write_data structure to reschedule writes, instead of caching that information in the controlling nfs_direct_req structure. Signed-off-by: Chuck Lever <cel@netapp.com> Signed-off-by: Trond Myklebust <Trond.Myklebust@netapp.com>
2006-06-24NFS: Separate functions for counting outstanding NFS direct I/OsChuck Lever
Factor out the logic that increments and decrements the outstanding I/O count. This will be a commonly used bit of code in upcoming patches. Also make this an atomic_t again, since it will be very often manipulated outside dreq->spin lock. Signed-off-by: Chuck Lever <cel@netapp.com> Signed-off-by: Trond Myklebust <Trond.Myklebust@netapp.com>
2006-06-09NFS: Split fs/nfs/inode.cDavid Howells
As fs/nfs/inode.c is rather large, heterogenous and unwieldy, the attached patch splits it up into a number of files: (*) fs/nfs/inode.c Strictly inode specific functions. (*) fs/nfs/super.c Superblock management functions for NFS and NFS4, normal access, clones and referrals. The NFS4 superblock functions _could_ move out into a separate conditionally compiled file, but it's probably not worth it as there're so many common bits. (*) fs/nfs/namespace.c Some namespace-specific functions have been moved here. (*) fs/nfs/nfs4namespace.c NFS4-specific namespace functions (this could be merged into the previous file). This file is conditionally compiled. (*) fs/nfs/internal.h Inter-file declarations, plus a few simple utility functions moved from fs/nfs/inode.c. Additionally, all the in-.c-file externs have been moved here, and those files they were moved from now includes this file. For the most part, the functions have not been changed, only some multiplexor functions have changed significantly. I've also: (*) Added some extra banner comments above some functions. (*) Rearranged the function order within the files to be more logical and better grouped (IMO), though someone may prefer a different order. (*) Reduced the number of #ifdefs in .c files. (*) Added missing __init and __exit directives. Signed-Off-By: David Howells <dhowells@redhat.com>
2006-04-19NFS,SUNRPC: Fix compiler warnings if CONFIG_PROC_FS & CONFIG_SYSCTL are unsetTrond Myklebust
2006-03-25Merge git://git.linux-nfs.org/pub/linux/nfs-2.6Linus Torvalds
* git://git.linux-nfs.org/pub/linux/nfs-2.6: (103 commits) SUNRPC,RPCSEC_GSS: spkm3--fix config dependencies SUNRPC,RPCSEC_GSS: spkm3: import contexts using NID_cast5_cbc LOCKD: Make nlmsvc_traverse_shares return void LOCKD: nlmsvc_traverse_blocks return is unused SUNRPC,RPCSEC_GSS: fix krb5 sequence numbers. NFSv4: Dont list system.nfs4_acl for filesystems that don't support it. SUNRPC,RPCSEC_GSS: remove unnecessary kmalloc of a checksum SUNRPC: Ensure rpc_call_async() always calls tk_ops->rpc_release() SUNRPC: Fix memory barriers for req->rq_received NFS: Fix a race in nfs_sync_inode() NFS: Clean up nfs_flush_list() NFS: Fix a race with PG_private and nfs_release_page() NFSv4: Ensure the callback daemon flushes signals SUNRPC: Fix a 'Busy inodes' error in rpc_pipefs NFS, NLM: Allow blocking locks to respect signals NFS: Make nfs_fhget() return appropriate error values NFSv4: Fix an oops in nfs4_fill_super lockd: blocks should hold a reference to the nlm_file NFSv4: SETCLIENTID_CONFIRM should handle NFS4ERR_DELAY/NFS4ERR_RESOURCE NFSv4: Send the delegation stateid for SETATTR calls ...
2006-03-24[PATCH] cpuset memory spread: slab cache formatPaul Jackson
Rewrap the overly long source code lines resulting from the previous patch's addition of the slab cache flag SLAB_MEM_SPREAD. This patch contains only formatting changes, and no function change. Signed-off-by: Paul Jackson <pj@sgi.com> Signed-off-by: Andrew Morton <akpm@osdl.org> Signed-off-by: Linus Torvalds <torvalds@osdl.org>
2006-03-24[PATCH] cpuset memory spread: slab cache filesystemsPaul Jackson
Mark file system inode and similar slab caches subject to SLAB_MEM_SPREAD memory spreading. If a slab cache is marked SLAB_MEM_SPREAD, then anytime that a task that's in a cpuset with the 'memory_spread_slab' option enabled goes to allocate from such a slab cache, the allocations are spread evenly over all the memory nodes (task->mems_allowed) allowed to that task, instead of favoring allocation on the node local to the current cpu. The following inode and similar caches are marked SLAB_MEM_SPREAD: file cache ==== ===== fs/adfs/super.c adfs_inode_cache fs/affs/super.c affs_inode_cache fs/befs/linuxvfs.c befs_inode_cache fs/bfs/inode.c bfs_inode_cache fs/block_dev.c bdev_cache fs/cifs/cifsfs.c cifs_inode_cache fs/coda/inode.c coda_inode_cache fs/dquot.c dquot fs/efs/super.c efs_inode_cache fs/ext2/super.c ext2_inode_cache fs/ext2/xattr.c (fs/mbcache.c) ext2_xattr fs/ext3/super.c ext3_inode_cache fs/ext3/xattr.c (fs/mbcache.c) ext3_xattr fs/fat/cache.c fat_cache fs/fat/inode.c fat_inode_cache fs/freevxfs/vxfs_super.c vxfs_inode fs/hpfs/super.c hpfs_inode_cache fs/isofs/inode.c isofs_inode_cache fs/jffs/inode-v23.c jffs_fm fs/jffs2/super.c jffs2_i fs/jfs/super.c jfs_ip fs/minix/inode.c minix_inode_cache fs/ncpfs/inode.c ncp_inode_cache fs/nfs/direct.c nfs_direct_cache fs/nfs/inode.c nfs_inode_cache fs/ntfs/super.c ntfs_big_inode_cache_name fs/ntfs/super.c ntfs_inode_cache fs/ocfs2/dlm/dlmfs.c dlmfs_inode_cache fs/ocfs2/super.c ocfs2_inode_cache fs/proc/inode.c proc_inode_cache fs/qnx4/inode.c qnx4_inode_cache fs/reiserfs/super.c reiser_inode_cache fs/romfs/inode.c romfs_inode_cache fs/smbfs/inode.c smb_inode_cache fs/sysv/inode.c sysv_inode_cache fs/udf/super.c udf_inode_cache fs/ufs/super.c ufs_inode_cache net/socket.c sock_inode_cache net/sunrpc/rpc_pipe.c rpc_inode_cache The choice of which slab caches to so mark was quite simple. I marked those already marked SLAB_RECLAIM_ACCOUNT, except for fs/xfs, dentry_cache, inode_cache, and buffer_head, which were marked in a previous patch. Even though SLAB_RECLAIM_ACCOUNT is for a different purpose, it marks the same potentially large file system i/o related slab caches as we need for memory spreading. Given that the rule now becomes "wherever you would have used a SLAB_RECLAIM_ACCOUNT slab cache flag before (usually the inode cache), use the SLAB_MEM_SPREAD flag too", this should be easy enough to maintain. Future file system writers will just copy one of the existing file system slab cache setups and tend to get it right without thinking. Signed-off-by: Paul Jackson <pj@sgi.com> Signed-off-by: Andrew Morton <akpm@osdl.org> Signed-off-by: Linus Torvalds <torvalds@osdl.org>
2006-03-20NFS: O_DIRECT needs to use a completionTrond Myklebust
Now that we have aio writes, it is possible for dreq->outstanding to be zero, but for the I/O not to have completed. Convert struct nfs_direct_req to use a completion to signal when the I/O is done. Signed-off-by: Trond Myklebust <Trond.Myklebust@netapp.com>
2006-03-20NFS: Clean up nfs_get_user_pagesTrond Myklebust
2006-03-20NFS: fix compiler warnings on 64-bit platformsChuck Lever
Introduced by NFS aio+dio patches. Test plan: Compile kernel with CONFIG_NFS enabled on 64-bit hardware. Signed-off-by: Chuck Lever <cel@netapp.com> Signed-off-by: Trond Myklebust <Trond.Myklebust@netapp.com>
2006-03-20NFS: Debugging code for nfs_direct_(read|write)_schedule()Trond Myklebust
Make sure that we're doing our list accounting correctly. Signed-off-by: Trond Myklebust <Trond.Myklebust@netapp.com>
2006-03-20NFS: O_DIRECT async IO may lose contextTrond Myklebust
The struct nfs_direct_req currently keeps a pointer to the file descriptor without referencing it. This may cause problems if the parent process is killed. The nfs_open_context should normally have all the information that we're currently using the filp for, and unlike fput(), is safe to release from an rpciod process context. Signed-off-by: Trond Myklebust <Trond.Myklebust@netapp.com>
2006-03-20nfs: Use UNSTABLE + COMMIT for NFS O_DIRECT writesTrond Myklebust
Currently NFS O_DIRECT writes use FILE_SYNC so that a COMMIT is not necessary. This simplifies the internal logic, but this could be a difficult workload for some servers. Instead, let's send UNSTABLE writes, and after they all complete, send a COMMIT for the dirty range. After the COMMIT returns successfully, then do the wake_up or fire off aio_complete(). Test plan: Async direct I/O tests against Solaris (or any server that requires committed unstable writes). Reboot server during test. Based on an earlier patch by Chuck Lever <cel@netapp.com> Signed-off-by: Trond Myklebust <Trond.Myklebust@netapp.com>
2006-03-20NFS: fix data_update accounting in NFS direct I/O pathChuck Lever
^C against "iozone -I" is hitting the assertion in nfs_clear_inode(). Test plan: "iozone -i0 -I -a -c" against a slow server, then control C. This should not cause an oops. Signed-off-by: Chuck Lever <cel@netapp.com> Signed-off-by: Trond Myklebust <Trond.Myklebust@netapp.com>
2006-03-20NFS: Replace atomic_t variables in nfs_direct_req with a single spin lockChuck Lever
Three atomic_t variables cause a lot of bus locking. Because they are all used in the same places in the code, just use a single spin lock. Now that the atomic_t variables are gone, we can remove the request size limitation since the code no longer depends on the limited width of atomic_t on some platforms. Test plan: Compile with CONFIG_NFS and CONFIG_NFS_DIRECTIO enabled. Millions of fsx operations, iozone, OraSim. Signed-off-by: Chuck Lever <cel@netapp.com> Signed-off-by: Trond Myklebust <Trond.Myklebust@netapp.com>
2006-03-20NFS: clean up comments and tab damage in direct.cChuck Lever
Clean up tab damage and comments. Replace "file_offset" with more commonly used "pos". Test plan: Compile with CONFIG_NFS and CONFIG_NFS_DIRECTIO enabled. Signed-off-by: Chuck Lever <cel@netapp.com> Signed-off-by: Trond Myklebust <Trond.Myklebust@netapp.com>
2006-03-20NFS: support EIOCBQUEUED return in direct write pathChuck Lever
For async iocb's, the NFS direct write path now returns EIOCBQUEUED, and calls aio_complete when all the requested writes are finished. The synchronous part of the NFS direct write path behaves exactly as it was before. Shared mapped NFS files will have some coherency difficulties when accessed concurrently with aio+dio. Will need to explore how this is handled in the local file system case. Test plan: aio-stress with "-O". OraSim. Signed-off-by: Chuck Lever <cel@netapp.com> Signed-off-by: Trond Myklebust <Trond.Myklebust@netapp.com>
2006-03-20NFS: make iocb available everywhere in direct write pathChuck Lever
Pass the iocb argument all the way down to the direct write request scheduler, and make it available in nfs_direct_write_result. Test plan: Compile the kernel with CONFIG_NFS and CONFIG_NFS_DIRECTIO enabled. Millions of fsx-odirect ops. OraSim. Signed-off-by: Chuck Lever <cel@netapp.com> Signed-off-by: Trond Myklebust <Trond.Myklebust@netapp.com>
2006-03-20NFS: remove support for multi-segment iovs in the direct write pathChuck Lever
Eliminate the persistent use of automatic storage in all parts of the NFS client's direct write path to pave the way for introducing support for aio against files opened with the O_DIRECT flag. Test plan: Compile the kernel with CONFIG_NFS and CONFIG_NFS_DIRECTIO enabled. Millions of fsx-odirect ops. OraSim. Signed-off-by: Chuck Lever <cel@netapp.com> Signed-off-by: Trond Myklebust <Trond.Myklebust@netapp.com>
2006-03-20NFS: make direct write path generate write requests concurrentlyChuck Lever
Duplicate infrastructure from direct read path that will allow write path to generate multiple write requests concurrently. This will enable us to add support for aio in this path. Temporarily we will lose the ability to do UNSTABLE writes followed by a COMMIT in the direct write path. However, all applications I am aware of that use NFS O_DIRECT currently write in relatively small chunks, so this should not be inconvenient in any way. Test plan: Millions of fsx-odirect ops. OraSim. Signed-off-by: Chuck Lever <cel@netapp.com> Signed-off-by: Trond Myklebust <Trond.Myklebust@netapp.com>
2006-03-20NFS: create common routine for handling direct I/O completionChuck Lever
Factor out the common piece of completing an NFS direct I/O request. Test plan: Compile kernel with CONFIG_NFS and CONFIG_NFS_DIRECTIO enabled. Signed-off-by: Chuck Lever <cel@netapp.com> Signed-off-by: Trond Myklebust <Trond.Myklebust@netapp.com>
2006-03-20NFS: create common routine for allocating nfs_direct_reqChuck Lever
Factor out a small common piece of the path that allocate nfs_direct_req structures. Test plan: Compile kernel with CONFIG_NFS and CONFIG_NFS_DIRECTIO enabled. Signed-off-by: Chuck Lever <cel@netapp.com> Signed-off-by: Trond Myklebust <Trond.Myklebust@netapp.com>
2006-03-20NFS: create common routine for waiting for direct I/O to completeChuck Lever
We're about to add asynchrony to the NFS direct write path. Begin by abstracting out the common pieces in the read path. The first piece is nfs_direct_read_wait, which works the same whether the process is waiting for a read or a write. Test plan: Compile kernel with CONFIG_NFS and CONFIG_NFS_DIRECTIO enabled. Signed-off-by: Chuck Lever <cel@netapp.com> Signed-off-by: Trond Myklebust <Trond.Myklebust@netapp.com>
2006-03-20NFS: support EIOCBQUEUED return in direct read pathChuck Lever
For async iocb's, the NFS direct read path should return EIOCBQUEUED and call aio_complete when all the requested reads are finished. The synchronous part of the NFS direct read path behaves exactly as it was before. Test plan: aio-stress with "-O". OraSim. Signed-off-by: Chuck Lever <cel@netapp.com> Signed-off-by: Trond Myklebust <Trond.Myklebust@netapp.com>
2006-03-20NFS: make iocb available everywhere in direct read pathChuck Lever
Pass the iocb argument all the way down to the direct read request scheduler, and make it available in nfs_direct_read_result. Test plan: Compile the kernel with CONFIG_NFS and CONFIG_NFS_DIRECTIO enabled. Millions of fsx-odirect ops. OraSim. Signed-off-by: Chuck Lever <cel@netapp.com> Signed-off-by: Trond Myklebust <Trond.Myklebust@netapp.com>
2006-03-20NFS: remove support for multi-segment iovs in the direct read pathChuck Lever
Eliminate the persistent use of automatic storage in all parts of the NFS client's direct read path to pave the way for introducing support for aio against files opened with the O_DIRECT flag. Test plan: Compile the kernel with CONFIG_NFS and CONFIG_NFS_DIRECTIO enabled. Millions of fsx-odirect ops. OraSim. Signed-off-by: Chuck Lever <cel@netapp.com> Signed-off-by: Trond Myklebust <Trond.Myklebust@netapp.com>
2006-03-20NFS: use size_t type for holding rsize bytes in NFS O_DIRECT read pathChuck Lever
size_t is used for holding byte counts, so use it for variables storing rsize. Note that the write path will be updated as we add support for async O_DIRECT writes. Test plan: Need to verify that existing comparisons against new size_t variables behave correctly. Signed-off-by: Chuck Lever <cel@netapp.com> Signed-off-by: Trond Myklebust <Trond.Myklebust@netapp.com>
2006-03-20NFS: update comments and function definitions in fs/nfs/direct.cChuck Lever
Update to latest coding style standards. Remove block comments on statically defined functions, and place function definitions all on one line. Test plan: Compile kernel with CONFIG_NFS and CONFIG_NFS_DIRECTIO. Signed-off-by: Chuck Lever <cel@netapp.com> Signed-off-by: Trond Myklebust <Trond.Myklebust@netapp.com>
2006-03-20NFS: clean up NFS client's a_ops->direct_IO methodChuck Lever
The NFS client's a_ops->direct_IO method, nfs_direct_IO, is required to be present to allow NFS files to be opened with O_DIRECT, but is never called because the NFS client shunts reads and writes to files opened with O_DIRECT directly to its own routines. Gut the nfs_direct_IO function. This eliminates the only part of the NFS client's direct I/O path that requires support for multi-segment iovs, allowing further simplification in subsequent patches. Test plan: Compile the kernel with CONFIG_NFS and CONFIG_NFS_DIRECTIO enabled. Millions of fsx-odirect ops. OraSim. Signed-off-by: Chuck Lever <cel@netapp.com> Signed-off-by: Trond Myklebust <Trond.Myklebust@netapp.com>
2006-03-20NFS: Cleanup of NFS read codeTrond Myklebust
Same callback hierarchy inversion as for the NFS write calls. This patch is not strictly speaking needed by the O_DIRECT code, but avoids confusing differences between the asynchronous read and write code. Signed-off-by: Trond Myklebust <Trond.Myklebust@netapp.com>
2006-03-20NFS: add I/O performance countersChuck Lever
Invoke the byte and event counter macros where we want to count bytes and events. Clean-up: fix a possible NULL dereference in nfs_lock, and simplify nfs_file_open. Test-plan: fsx and iozone on UP and SMP systems, with and without pre-emption. Watch for memory overwrite bugs, and performance loss (significantly more CPU required per op). Signed-off-by: Chuck Lever <cel@netapp.com> Signed-off-by: Trond Myklebust <Trond.Myklebust@netapp.com>
