path: root/fs/nfs/fscache-index.c
2014-09-25NFS: Fabricate fscache server index key correctlyDavid Howells
When fabricating a server index key for fscache, we should clear the index key buffer before starting to fill it in, not in the middle. Reported-by: James Pearson <james-p@moving-picture.com> Signed-off-by: David Howells <dhowells@redhat.com> Acked-by: Steve Dickson <steved@redhat.com> Signed-off-by: Trond Myklebust <trond.myklebust@primarydata.com>
2011-10-18NFS: Use the inode->i_version to cache NFSv4 change attribute informationTrond Myklebust
Signed-off-by: Trond Myklebust <Trond.Myklebust@netapp.com>
2009-04-03NFS: Add read context retention for FS-Cache to call back withDavid Howells
Add read context retention so that FS-Cache can call back into NFS when a read operation on the cache fails EIO rather than reading data. This permits NFS to then fetch the data from the server instead using the appropriate security context. Signed-off-by: David Howells <dhowells@redhat.com> Acked-by: Steve Dickson <steved@redhat.com> Acked-by: Trond Myklebust <Trond.Myklebust@netapp.com> Acked-by: Al Viro <viro@zeniv.linux.org.uk> Tested-by: Daire Byrne <Daire.Byrne@framestore.com>
2009-04-03NFS: Invalidate FsCache page flags when cache removedDavid Howells
Invalidate the FsCache page flags on the pages belonging to an inode when the cache backing that NFS inode is removed. This allows a live cache to be withdrawn. Signed-off-by: David Howells <dhowells@redhat.com> Acked-by: Steve Dickson <steved@redhat.com> Acked-by: Trond Myklebust <Trond.Myklebust@netapp.com> Acked-by: Al Viro <viro@zeniv.linux.org.uk> Tested-by: Daire Byrne <Daire.Byrne@framestore.com>
2009-04-03NFS: Define and create inode-level cache objectsDavid Howells
Define and create inode-level cache data storage objects (as managed by nfs_inode structs). Each inode-level object is created in a superblock-level index object and is itself a data storage object into which pages from the inode are stored. The inode object key is the NFS file handle for the inode. The inode object is given coherency data to carry in the auxiliary data permitted by the cache. This is a sequence made up of: (1) i_mtime from the NFS inode. (2) i_ctime from the NFS inode. (3) i_size from the NFS inode. (4) change_attr from the NFSv4 attribute data. As the cache is a persistent cache, the auxiliary data is checked when a new NFS in-memory inode is set up that matches an already existing data storage object in the cache. If the coherency data is the same, the on-disk object is retained and used; if not, it is scrapped and a new one created. Signed-off-by: David Howells <dhowells@redhat.com> Acked-by: Steve Dickson <steved@redhat.com> Acked-by: Trond Myklebust <Trond.Myklebust@netapp.com> Acked-by: Al Viro <viro@zeniv.linux.org.uk> Tested-by: Daire Byrne <Daire.Byrne@framestore.com>
2009-04-03NFS: Define and create superblock-level objectsDavid Howells
Define and create superblock-level cache index objects (as managed by nfs_server structs). Each superblock object is created in a server level index object and is itself an index into which inode-level objects are inserted. Ideally there would be one superblock-level object per server, and the former would be folded into the latter; however, since the "nosharecache" option exists this isn't possible. The superblock object key is a sequence consisting of: (1) Certain superblock s_flags. (2) Various connection parameters that serve to distinguish superblocks for sget(). (3) The volume FSID. (4) The security flavour. (5) The uniquifier length. (6) The uniquifier text. This is normally an empty string, unless the fsc=xyz mount option was used to explicitly specify a uniquifier. The key blob is of variable length, depending on the length of (6). The superblock object is given no coherency data to carry in the auxiliary data permitted by the cache. It is assumed that the superblock is always coherent. This patch also adds uniquification handling such that two otherwise identical superblocks, at least one of which is marked "nosharecache", won't end up trying to share the on-disk cache. It will be possible to manually provide a uniquifier through a mount option with a later patch to avoid the error otherwise produced. Signed-off-by: David Howells <dhowells@redhat.com> Acked-by: Steve Dickson <steved@redhat.com> Acked-by: Trond Myklebust <Trond.Myklebust@netapp.com> Acked-by: Al Viro <viro@zeniv.linux.org.uk> Tested-by: Daire Byrne <Daire.Byrne@framestore.com>
2009-04-03NFS: Define and create server-level objectsDavid Howells
Define and create server-level cache index objects (as managed by nfs_client structs). Each server object is created in the NFS top-level index object and is itself an index into which superblock-level objects are inserted. Ideally there would be one superblock-level object per server, and the former would be folded into the latter; however, since the "nosharecache" option exists this isn't possible. The server object key is a sequence consisting of: (1) NFS version (2) Server address family (eg: AF_INET or AF_INET6) (3) Server port. (4) Server IP address. The key blob is of variable length, depending on the length of (4). The server object is given no coherency data to carry in the auxiliary data permitted by the cache. Signed-off-by: David Howells <dhowells@redhat.com> Acked-by: Steve Dickson <steved@redhat.com> Acked-by: Trond Myklebust <Trond.Myklebust@netapp.com> Acked-by: Al Viro <viro@zeniv.linux.org.uk> Tested-by: Daire Byrne <Daire.Byrne@framestore.com>
2009-04-03NFS: Register NFS for caching and retrieve the top-level indexDavid Howells
Register NFS for caching and retrieve the top-level cache index object cookie. Signed-off-by: David Howells <dhowells@redhat.com> Acked-by: Steve Dickson <steved@redhat.com> Acked-by: Trond Myklebust <Trond.Myklebust@netapp.com> Acked-by: Al Viro <viro@zeniv.linux.org.uk> Tested-by: Daire Byrne <Daire.Byrne@framestore.com>
