Jan Stancek reported that I wrecked things for him by fixing things for
Vladimir :/
His report was due to an UNINTERRUPTIBLE wait getting -EINTR, which
should not be possible, however my previous patch made this possible by
unconditionally checking signal_pending().
We cannot use current->state as was done previously, because the
instruction after the store to that variable it can be changed. We must
instead pass the initial state along and use that.
Fixes: 68985633bccb ("sched/wait: Fix signal handling in bit wait helpers")
Reported-by: Jan Stancek <jstancek@redhat.com>
Reported-by: Chris Mason <clm@fb.com>
Tested-by: Jan Stancek <jstancek@redhat.com>
Tested-by: Vladimir Murzin <vladimir.murzin@arm.com>
Tested-by: Chris Mason <clm@fb.com>
Reviewed-by: Paul Turner <pjt@google.com>
Cc: tglx@linutronix.de
Cc: hpa@zytor.com
based upon the corresponding patch from Neil's March patchset,
again with kmap-related horrors removed.
kmap() in page_follow_link_light() needed to go - allowing to hold
an arbitrary number of kmaps for long is a great way to deadlocking
the system.
new helper (inode_nohighmem(inode)) needs to be used for pagecache
symlinks inodes; done for all in-tree cases. page_follow_link_light()
instrumented to yell about anything missed.
If we pass in an empty nfs_fattr struct to nfs_update_inode, it will
(correctly) not update any of the attributes, but it then clears the
NFS_INO_INVALID_ATTR flag, which indicates that the attributes are
up to date. Don't clear the flag if the fattr struct has no valid
attrs to apply.
Reviewed-by: Steve French <steve.french@primarydata.com>
Signed-off-by: Jeff Layton <jeff.layton@primarydata.com>
Cc: stable@vger.kernel.org
Signed-off-by: Trond Myklebust <trond.myklebust@primarydata.com>
If we get no post-op attributes back from a SETATTR operation, then no
attributes will of course be updated during the call to
nfs_update_inode.
We know however that the attributes are invalid at that point, since we
just changed some of them. At the very least, the ctime will be bogus.
If we get no post-op attributes back on the call, mark the attrcache
invalid to reflect that fact.
This reverts commit f895c53f8ace3c3e49ebf9def90e63fc6d46d2bf.
This commit causes a NFSv4 regression in that close()+unlink() can end
up failing. The reason is that we no longer have a guarantee that the
CLOSE has completed on the server, meaning that the subsequent call to
REMOVE may fail with NFS4ERR_FILE_OPEN if the server implements Windows
unlink() semantics.
Reported-by: <Olga Kornievskaia <aglo@umich.edu>
Cc: Chuck Lever <chuck.lever@oracle.com>
If there is no cached data, then there is no need to track the file
change attribute on close.
Set rlimit for NFS's files is useless right now.
For local process's rlimit, it should be checked by nfs client.
The same, CIFS also call inode_change_ok checking rlimit at its client
in cifs_setattr_nounix() and cifs_setattr_unix().
v3, fix bad using of error
Signed-off-by: Kinglong Mee <kinglongmee@gmail.com>
If the ctime or mtime or change attribute have changed because
of an operation we initiated, we should make sure that we force
an attribute update. However we do not want to mark the page cache
for revalidation.
Cc: stable@vger.kernel.org # v4.0+
Chuck reports seeing cases where a GETATTR that happens to race
with an asynchronous WRITE is overriding the file size, despite
the attribute barrier being set by the writeback code.
The culprit turns out to be the check in nfs_ctime_need_update(),
which sees that the ctime is newer than the cached ctime, and
assumes that it is safe to override the attribute barrier.
This patch removes that override, and ensures that attribute
barriers are always respected.
Reported-by: Chuck Lever <chuck.lever@oracle.com>
Fixes: a08a8cd375db9 ("NFS: Add attribute update barriers to NFS writebacks")
And call nfs_file_clear_open_context() directly. This makes it obvious
that nfs_file_release() will always return 0.
Signed-off-by: Anna Schumaker <Anna.Schumaker@Netapp.com>
Setting the change attribute has been mandatory for all NFS versions, since
commit 3a1556e8662c ("NFSv2/v3: Simulate the change attribute"). We should
therefore not have anything be conditional on it being set/unset.
We can't allow caching of data until the change attribute has been
initialised correctly.
If we've ensured that the size and the change attribute are both correct,
then there is no point in marking those attributes as needing revalidation
again. Only do so if we know the size is incorrect and was not updated.
Fixes: f2467b6f64da ("NFS: Clear NFS_INO_REVAL_PAGECACHE when...")
Have checking CONFIG_PROC_FS in include/linux/sunrpc/stats.h.
In glibc 2.21 (and several previous), a call to opendir() will
result in a 32K (BUFSIZ*4) buffer being allocated and passed to
getdents.
However a call to fdopendir() results in an 'fstat' request to
determine block size and a matching buffer allocated for subsequent
use with getdents. This will typically be 1M.
The first getdents call on an NFS directory will always use
READDIR_PLUS (or NFSv4 equivalent) if available. Subsequent getdents
calls only use this more expensive version if some 'stat' requests are
made between the getdents calls.
For this reason it is good to keep at least that first getdents call
relatively short. When fdopendir() and readdir() is used on a large
directory, it takes approximately 32 times as long to complete as
using "opendir". Current versions of 'find' use fdopendir() and
demonstrate this slowness.
'stat' on a directory currently returns the 'wsize'. This number has
no meaning on directories.
Actual READDIR requests are limited to ->dtsize, which itself is
capped at 4 pages, coincidently the same as BUFSIZ*4.
So this is a meaningful number to use as the blocksize on directories,
and has the effect of making 'find' on large directories go a lot
faster.
Signed-off-by: NeilBrown <neilb@suse.de>
Pull NFS client updates from Trond Myklebust:
"Another set of mainly bugfixes and a couple of cleanups. No new
functionality in this round.
Highlights include:
Stable patches:
- Fix a regression in /proc/self/mountstats
- Fix the pNFS flexfiles O_DIRECT support
- Fix high load average due to callback thread sleeping
Bugfixes:
- Various patches to fix the pNFS layoutcommit support
- Do not cache pNFS deviceids unless server notifications are enabled
- Fix a SUNRPC transport reconnection regression
- make debugfs file creation failure non-fatal in SUNRPC
- Another fix for circular directory warnings on NFSv4 "junctioned"
mountpoints
- Fix locking around NFSv4.2 fallocate() support
- Truncating NFSv4 file opens should also sync O_DIRECT writes
- Prevent infinite loop in rpcrdma_ep_create()
Features:
- Various improvements to the RDMA transport code's handling of
memory registration
- Various code cleanups"
* tag 'nfs-for-4.1-1' of git://git.linux-nfs.org/projects/trondmy/linux-nfs: (55 commits)
fs/nfs: fix new compiler warning about boolean in switch
nfs: Remove unneeded casts in nfs
NFS: Don't attempt to decode missing directory entries
Revert "nfs: replace nfs_add_stats with nfs_inc_stats when add one"
NFS: Rename idmap.c to nfs4idmap.c
NFS: Move nfs_idmap.h into fs/nfs/
NFS: Remove CONFIG_NFS_V4 checks from nfs_idmap.h
NFS: Add a stub for GETDEVICELIST
nfs: remove WARN_ON_ONCE from nfs_direct_good_bytes
nfs: fix DIO good bytes calculation
nfs: Fetch MOUNTED_ON_FILEID when updating an inode
sunrpc: make debugfs file creation failure non-fatal
nfs: fix high load average due to callback thread sleeping
NFS: Reduce time spent holding the i_mutex during fallocate()
NFS: Don't zap caches on fallocate()
xprtrdma: Make rpcrdma_{un}map_one() into inline functions
xprtrdma: Handle non-SEND completions via a callout
xprtrdma: Add "open" memreg op
xprtrdma: Add "destroy MRs" memreg op
xprtrdma: Add "reset MRs" memreg op
Don't unnecessarily cast allocation return value in
fs/nfs/inode.c::nfs_alloc_inode().
Signed-off-by: Firo Yang <firogm@gmail.com>
2ef47eb1 (NFS: Fix use of nfs_attr_use_mounted_on_fileid()) was a good
start to fixing a circular directory structure warning for NFS v4
"junctioned" mountpoints. Unfortunately, further testing continued to
generate this error.
My server is configured like this:
anna@nfsd ~ % df
Filesystem Size Used Avail Use% Mounted on
/dev/vda1 9.1G 2.0G 6.5G 24% /
/dev/vdc1 1014M 33M 982M 4% /exports
/dev/vdc2 1014M 33M 982M 4% /exports/vol1
/dev/vdc3 1014M 33M 982M 4% /exports/vol1/vol2
anna@nfsd ~ % cat /etc/exports
/exports/ *(rw,async,no_subtree_check,no_root_squash)
/exports/vol1/ *(rw,async,no_subtree_check,no_root_squash)
/exports/vol1/vol2 *(rw,async,no_subtree_check,no_root_squash)
I've been running chown across the entire mountpoint twice in a row to
hit this problem. The first run succeeds, but the second one fails with
the circular directory warning along with:
anna@client ~ % dmesg
[Apr 3 14:28] NFS: server 192.168.100.204 error: fileid changed
fsid 0:39: expected fileid 0x100080, got 0x80
WHere 0x80 is the mountpoint's fileid and 0x100080 is the mounted-on
fileid.
This patch fixes the issue by requesting an updated mounted-on fileid
from the server during nfs_update_inode(), and then checking that the
fileid stored in the nfs_inode matches either the fileid or mounted-on
fileid returned by the server.
This patch adds a GETATTR to the end of ALLOCATE and DEALLOCATE
operations so we can set the updated inode size and change attribute
directly. DEALLOCATE will still need to release pagecache pages, so
nfs42_proc_deallocate() now calls truncate_pagecache_range() before
contacting the server.
that's the bulk of filesystem drivers dealing with inodes of their own
We don't just want to sync out buffered writes, but also O_DIRECT ones.
Then apply it to nfs_setattr() and nfs_getattr().
nfs_vm_page_mkwrite() should wait until the page cache invalidation
is finished. This is the second patch in a 2 patch series to deprecate
the NFS client's reliance on nfs_release_page() in the context of
nfs_invalidate_mapping().
When invalidating the page cache for a regular file, we want to first
sync all dirty data to disk and then call invalidate_inode_pages2().
The latter relies on nfs_launder_page() and nfs_release_page() to deal
respectively with dirty pages, and unstable written pages.
When commit 9590544694bec ("NFS: avoid deadlocks with loop-back mounted
NFS filesystems.") changed the behaviour of nfs_release_page(), then it
made it possible for invalidate_inode_pages2() to fail with an EBUSY.
Unfortunately, that error is then propagated back to read().
Let's therefore work around the problem for now by protecting the call
to sync the data and invalidate_inode_pages2() so that they are atomic
w.r.t. the addition of new writes.
Later on, we can revisit whether or not we still need nfs_launder_page()
and nfs_release_page().
Ensure that we don't regress the changes that were made to the
directory.
Tested-by: Chuck Lever <chuck.lever@oracle.com>
nfs_post_op_update_inode() is called after a self-induced attribute
update. Ensure that it also sets the barrier.
Prior to this patch, we used to always OK attribute updates that extended
the file size on the assumption that we might be performing writeback.
Now that we have attribute barriers to protect the writeback related updates,
we should remove this hack, as it can cause truncate() operations to
apparently be reverted if/when a readahead or getattr RPC call races
with our on-the-wire SETATTR.
Ensure that other operations that race with delegreturn and layoutcommit
cannot revert the attribute updates that were made on the server.
Ensure that other operations that race with our write RPC calls
cannot revert the file size updates that were made on the server.
Ensure that we update the attribute barrier even if there were no
invalidations, provided that this value is newer than the old one.
Ensure that other operations which raced with our setattr RPC call
cannot revert the file attribute changes that were made on the server.
To do so, we artificially bump the attribute generation counter on
the inode so that all calls to nfs_fattr_init() that precede ours
will be dropped.
The motivation for the patch came from Chuck Lever's reports of readaheads
racing with truncate operations and causing the file size to be reverted.
Merge cleanups requested by Linus.
* cleanups: (3 commits)
pnfs: Refactor the *_layout_mark_request_commit to use pnfs_layout_mark_request_commit
nfs: Can call nfs_clear_page_commit() instead
nfs: Provide and use helper functions for marking a page as unstable
Pull backing device changes from Jens Axboe:
"This contains a cleanup of how the backing device is handled, in
preparation for a rework of the life time rules. In this part, the
most important change is to split the unrelated nommu mmap flags from
it, but also removing a backing_dev_info pointer from the
address_space (and inode), and a cleanup of other various minor bits.
Christoph did all the work here, I just fixed an oops with pages that
have a swap backing. Arnd fixed a missing export, and Oleg killed the
lustre backing_dev_info from staging. Last patch was from Al,
unexporting parts that are now no longer needed outside"
* 'for-3.20/bdi' of git://git.kernel.dk/linux-block:
Make super_blocks and sb_lock static
mtd: export new mtd_mmap_capabilities
fs: make inode_to_bdi() handle NULL inode
staging/lustre/llite: get rid of backing_dev_info
fs: remove default_backing_dev_info
fs: don't reassign dirty inodes to default_backing_dev_info
nfs: don't call bdi_unregister
ceph: remove call to bdi_unregister
fs: remove mapping->backing_dev_info
fs: export inode_to_bdi and use it in favor of mapping->backing_dev_info
nilfs2: set up s_bdi like the generic mount_bdev code
block_dev: get bdev inode bdi directly from the block device
block_dev: only write bdev inode on close
fs: introduce f_op->mmap_capabilities for nommu mmap support
fs: kill BDI_CAP_SWAP_BACKED
fs: deduplicate noop_backing_dev_info
Most filesystems prevent truncation of an active swapfile by way of
inode_newsize_ok, called from inode_change_ok. NFS doesn't call either
from nfs_setattr, presumably because most of these checks are expected
to be done server-side. However, the IS_SWAPFILE check can only be done
client-side, and truncating a swapfile can't possibly be good.
Signed-off-by: Omar Sandoval <osandov@osandov.com>
This function call was being optimized out during nfs_fhget(), leading
to situations where we have a valid fileid but still want to use the
mounted_on_fileid. For example, imagine we have our server configured
like this:
server % df
/dev/vda1 9.1G 6.5G 1.9G 78% /
/dev/vdb1 487M 2.3M 456M 1% /exports
/dev/vdc1 487M 2.3M 456M 1% /exports/vol1
/dev/vdd1 487M 2.3M 456M 1% /exports/vol2
If our client mounts /exports and tries to do a "chown -R" across the
entire mountpoint, we will get a nasty message warning us about a circular
directory structure. Running chown with strace tells me that each directory
has the same device and inode number:
newfstatat(AT_FDCWD, "/nfs/", {st_dev=makedev(0, 38), st_ino=2, ...}) = 0
newfstatat(4, "vol1", {st_dev=makedev(0, 38), st_ino=2, ...}) = 0
newfstatat(4, "vol2", {st_dev=makedev(0, 38), st_ino=2, ...}) = 0
With this patch the mounted_on_fileid values are used for st_ino, so the
directory loop warning isn't reported.
Now that we never use the backing_dev_info pointer in struct address_space
we can simply remove it and save 4 to 8 bytes in every inode.
Acked-by: Ryusuke Konishi <konishi.ryusuke@lab.ntt.co.jp>
Reviewed-by: Tejun Heo <tj@kernel.org>
Signed-off-by: Jens Axboe <axboe@fb.com>
This patch adds support for using the NFS v4.2 operation ALLOCATE to
preallocate data in a file.
Recent work in the pgio layer made it possible for there to be more than one
request per page. This caused a subtle change in commit behavior, because
write.c:nfs_commit_unstable_pages compares the number of *pages* waiting for
writeback against the number of requests on a commit list to choose when to
send a COMMIT in a non-blocking flush.
This is probably hard to hit in normal operation - you have to be using
rsize/wsize < PAGE_SIZE, or pnfs with lots of boundaries that are not page
aligned to have a noticeable change in behavior.
Signed-off-by: Weston Andros Adamson <dros@primarydata.com>
Variable 'err' needn't be initialized when nfs_getattr() uses it to
check whether it should call generic_fillattr() or not. That can result
in spurious error returns. Initialize 'err' properly.
Merge NFSv4.2 client SEEK implementation from Anna
* client-4.2: (55 commits)
NFS: Implement SEEK
NFSD: Implement SEEK
NFSD: Add generic v4.2 infrastructure
svcrdma: advertise the correct max payload
nfsd: introduce nfsd4_callback_ops
nfsd: split nfsd4_callback initialization and use
nfsd: introduce a generic nfsd4_cb
nfsd: remove nfsd4_callback.cb_op
nfsd: do not clear rpc_resp in nfsd4_cb_done_sequence
nfsd: fix nfsd4_cb_recall_done error handling
nfsd4: clarify how grace period ends
nfsd4: stop grace_time update at end of grace period
nfsd: skip subsequent UMH "create" operations after the first one for v4.0 clients
nfsd: set and test NFSD4_CLIENT_STABLE bit to reduce nfsdcltrack upcalls
nfsd: serialize nfsdcltrack upcalls for a particular client
nfsd: pass extra info in env vars to upcalls to allow for early grace period end
nfsd: add a v4_end_grace file to /proc/fs/nfsd
lockd: add a /proc/fs/lockd/nlm_end_grace file
nfsd: reject reclaim request when client has already sent RECLAIM_COMPLETE
nfsd: remove redundant boot_time parm from grace_done client tracking op
The SEEK operation is used when an application makes an lseek call with
either the SEEK_HOLE or SEEK_DATA flags set. I fall back on
nfs_file_llseek() if the server does not have SEEK support.
The VFS never calls setattr with ATTR_SIZE on anything but regular
files. Remove the if check and turn it into an assert similar to
what some other file systems do.
"Highlights include:
- stable fix for a bug in nfs3_list_one_acl()
- speed up NFS path walks by supporting LOOKUP_RCU
- more read/write code cleanups
- pNFS fixes for layout return on close
- fixes for the RCU handling in the rpcsec_gss code
- more NFS/RDMA fixes"
* tag 'nfs-for-3.17-1' of git://git.linux-nfs.org/projects/trondmy/linux-nfs: (79 commits)
nfs: reject changes to resvport and sharecache during remount
NFS: Avoid infinite loop when RELEASE_LOCKOWNER getting expired error
SUNRPC: remove all refcounting of groupinfo from rpcauth_lookupcred
NFS: fix two problems in lookup_revalidate in RCU-walk
NFS: allow lockless access to access_cache
NFS: teach nfs_lookup_verify_inode to handle LOOKUP_RCU
NFS: teach nfs_neg_need_reval to understand LOOKUP_RCU
NFS: support RCU_WALK in nfs_permission()
sunrpc/auth: allow lockless (rcu) lookup of credential cache.
NFS: prepare for RCU-walk support but pushing tests later in code.
NFS: nfs4_lookup_revalidate: only evaluate parent if it will be used.
NFS: add checks for returned value of try_module_get()
nfs: clear_request_commit while holding i_lock
pnfs: add pnfs_put_lseg_async
pnfs: find swapped pages on pnfs commit lists too
nfs: fix comment and add warn_on for PG_INODE_REF
nfs: check wait_on_bit_lock err in page_group_lock
sunrpc: remove "ec" argument from encrypt_v2 operation
sunrpc: clean up sparse endianness warnings in gss_krb5_wrap.c
sunrpc: clean up sparse endianness warnings in gss_krb5_seal.c
git://git.kernel.org/pub/scm/linux/kernel/git/ebiederm/user-namespace
Pull namespace updates from Eric Biederman:
"This is a bunch of small changes built against 3.16-rc6. The most
significant change for users is the first patch which makes setns
drmatically faster by removing unneded rcu handling.
The next chunk of changes are so that "mount -o remount,.." will not
allow the user namespace root to drop flags on a mount set by the
system wide root. Aks this forces read-only mounts to stay read-only,
no-dev mounts to stay no-dev, no-suid mounts to stay no-suid, no-exec
mounts to stay no exec and it prevents unprivileged users from messing
with a mounts atime settings. I have included my test case as the
last patch in this series so people performing backports can verify
this change works correctly.
The next change fixes a bug in NFS that was discovered while auditing
nsproxy users for the first optimization. Today you can oops the
kernel by reading /proc/fs/nfsfs/{servers,volumes} if you are clever
with pid namespaces. I rebased and fixed the build of the
!CONFIG_NFS_FS case yesterday when a build bot caught my typo. Given
that no one to my knowledge bases anything on my tree fixing the typo
in place seems more responsible that requiring a typo-fix to be
backported as well.
The last change is a small semantic cleanup introducing
/proc/thread-self and pointing /proc/mounts and /proc/net at it. This
prevents several kinds of problemantic corner cases. It is a
user-visible change so it has a minute chance of causing regressions
so the change to /proc/mounts and /proc/net are individual one line
commits that can be trivially reverted. Unfortunately I lost and
could not find the email of the original reporter so he is not
credited. From at least one perspective this change to /proc/net is a
refgression fix to allow pthread /proc/net uses that were broken by
the introduction of the network namespace"
* 'for-linus' of git://git.kernel.org/pub/scm/linux/kernel/git/ebiederm/user-namespace:
proc: Point /proc/mounts at /proc/thread-self/mounts instead of /proc/self/mounts
proc: Point /proc/net at /proc/thread-self/net instead of /proc/self/net
proc: Implement /proc/thread-self to point at the directory of the current thread
proc: Have net show up under /proc/<tgid>/task/<tid>
NFS: Fix /proc/fs/nfsfs/servers and /proc/fs/nfsfs/volumes
mnt: Add tests for unprivileged remount cases that have found to be faulty
mnt: Change the default remount atime from relatime to the existing value
mnt: Correct permission checks in do_remount
mnt: Move the test for MNT_LOCK_READONLY from change_mount_flags into do_remount
mnt: Only change user settable mount flags in remount
namespaces: Use task_lock and not rcu to protect nsproxy
The usage of pid_ns->child_reaper->nsproxy->net_ns in
nfs_server_list_open and nfs_client_list_open is not safe.
/proc for a pid namespace can remain mounted after the all of the
process in that pid namespace have exited. There are also times
before the initial process in a pid namespace has started or after the
initial process in a pid namespace has exited where
pid_ns->child_reaper can be NULL or stale. Making the idiom
pid_ns->child_reaper->nsproxy a double whammy of problems.
Luckily all that needs to happen is to move /proc/fs/nfsfs/servers and
/proc/fs/nfsfs/volumes under /proc/net to /proc/net/nfsfs/servers and
/proc/net/nfsfs/volumes and add a symlink from the original location,
and to use seq_open_net as it has been designed.
Cc: Trond Myklebust <trond.myklebust@primarydata.com>
Cc: Stanislav Kinsbursky <skinsbursky@parallels.com>
This requires nfs_check_verifier to take an rcu_walk flag, and requires
an rcu version of nfs_revalidate_inode which returns -ECHILD rather
than making an RPC call.
With this, nfs_lookup_revalidate can call nfs_neg_need_reval in
RCU-walk mode.
We can also move the LOOKUP_RCU check past the nfs_check_verifier()
call in nfs_lookup_revalidate.
If RCU_WALK prevents nfs_check_verifier or nfs_neg_need_reval from
doing a full check, they return a status indicating that a revalidation
is required. As this revalidation will not be possible in RCU_WALK
mode, -ECHILD will ultimately be returned, which is the desired result.
