path: root/fs/nfs/iostat.h
2014-11-24nfs: define nfs_inc_fscache_stats and using it as possibleLi RongQing
Define and use nfs_inc_fscache_stats when plus one, which can save to pass one parameter. Signed-off-by: Li RongQing <roy.qing.li@gmail.com> Signed-off-by: Trond Myklebust <trond.myklebust@primarydata.com>
2010-05-14NFS: Squelch compiler warning in nfs_add_server_stats()Chuck Lever
Clean up: fs/nfs/iostat.h: In function ‘nfs_add_server_stats’: fs/nfs/iostat.h:41: warning: comparison between signed and unsigned integer expressions fs/nfs/iostat.h:41: warning: comparison between signed and unsigned integer expressions fs/nfs/iostat.h:41: warning: comparison between signed and unsigned integer expressions fs/nfs/iostat.h:41: warning: comparison between signed and unsigned integer expressions Commit fce22848 replaced the open-coded per-cpu logic in several functions in fs/nfs/iostat.h with a single invocation of this_cpu_ptr(). This macro assumes its second argument is signed, not unsigned. Signed-off-by: Chuck Lever <chuck.lever@oracle.com> Signed-off-by: Trond Myklebust <Trond.Myklebust@netapp.com>
2010-02-17percpu: add __percpu sparse annotations to fsTejun Heo
Add __percpu sparse annotations to fs. These annotations are to make sparse consider percpu variables to be in a different address space and warn if accessed without going through percpu accessors. This patch doesn't affect normal builds. Signed-off-by: Tejun Heo <tj@kernel.org> Cc: "Theodore Ts'o" <tytso@mit.edu> Cc: Trond Myklebust <Trond.Myklebust@netapp.com> Cc: Alex Elder <aelder@sgi.com> Cc: Christoph Hellwig <hch@infradead.org> Cc: Alexander Viro <viro@zeniv.linux.org.uk>
2009-10-03this_cpu: Use this_cpu operations for NFS statisticsChristoph Lameter
Simplify NFS statistics and allow the use of optimized arch instructions. Acked-by: Tejun Heo <tj@kernel.org> CC: Trond Myklebust <trond.myklebust@fys.uio.no> Signed-off-by: Christoph Lameter <cl@linux-foundation.org> Signed-off-by: Tejun Heo <tj@kernel.org>
2009-06-16remove put_cpu_no_resched()Thomas Gleixner
put_cpu_no_resched() is an optimization of put_cpu() which unfortunately can cause high latencies. The nfs iostats code uses put_cpu_no_resched() in a code sequence where a reschedule request caused by an interrupt between the get_cpu() and the put_cpu_no_resched() can delay the reschedule for at least HZ. The other users of put_cpu_no_resched() optimize correctly in interrupt code, but there is no real harm in using the put_cpu() function which is an alias for preempt_enable(). The extra check of the preemmpt count is not as critical as the potential source of missing a reschedule. Debugged in the preempt-rt tree and verified in mainline. Impact: remove a high latency source [akpm@linux-foundation.org: build fix] Signed-off-by: Thomas Gleixner <tglx@linutronix.de> Acked-by: Ingo Molnar <mingo@elte.hu> Cc: Tony Luck <tony.luck@intel.com> Cc: Trond Myklebust <Trond.Myklebust@netapp.com> Cc: "J. Bruce Fields" <bfields@fieldses.org> Signed-off-by: Andrew Morton <akpm@linux-foundation.org> Signed-off-by: Linus Torvalds <torvalds@linux-foundation.org>
2009-04-03NFS: Add some new I/O counters for FS-Cache doing things for NFSDavid Howells
Add some new NFS I/O counters for FS-Cache doing things for NFS. A new line is emitted into /proc/pid/mountstats if caching is enabled that looks like: fsc: <rok> <rfl> <wok> <wfl> <unc> Where <rok> is the number of pages read successfully from the cache, <rfl> is the number of failed page reads against the cache, <wok> is the number of successful page writes to the cache, <wfl> is the number of failed page writes to the cache, and <unc> is the number of NFS pages that have been disconnected from the cache. Signed-off-by: David Howells <dhowells@redhat.com> Acked-by: Steve Dickson <steved@redhat.com> Acked-by: Trond Myklebust <Trond.Myklebust@netapp.com> Acked-by: Al Viro <viro@zeniv.linux.org.uk> Tested-by: Daire Byrne <Daire.Byrne@framestore.com>
2008-07-09NFS: Fix a warning in nfs4_async_handle_errorTrond Myklebust
We're not modifying the nfs_server when we call nfs_inc_server_stats and friends, so allow the compiler to pass 'const' pointers too. Signed-off-by: Trond Myklebust <Trond.Myklebust@netapp.com>
2008-07-09NFS: Move fs/nfs/iostat.h to include/linuxChuck Lever
The fs/nfs/iostat.h header has definitions that were designed to be exposed to user space. Move these definitions under include/linux so user space can use the definitions in applications that read /proc/self/mountstats. Also address a handful of coding style issues called out by checkpatch.pl in fs/nfs/iostat.h. Signed-off-by: Chuck Lever <chuck.lever@oracle.com> Signed-off-by: Trond Myklebust <Trond.Myklebust@netapp.com>
2006-03-20NFSv4: Fix an oops in nfs4_fill_superTrond Myklebust
The mount statistics patches introduced a call to nfs_free_iostats that is not only redundant, but actually causes an oops. Also fix a memory leak due to the lack of a call to nfs_free_iostats on unmount. Signed-off-by: Trond Myklebust <Trond.Myklebust@netapp.com>
2006-03-20NFS: add hooks to account for NFSERR_JUKEBOX errorsChuck Lever
Make an inode or an nfs_server struct available in the logic that handles JUKEBOX/DELAY type errors so the NFS client can account for them. This patch is split out from the main nfs iostat patch to highlight minor architectural changes required to support this statistic. Test plan: None. Signed-off-by: Chuck Lever <cel@netapp.com> Signed-off-by: Trond Myklebust <Trond.Myklebust@netapp.com>
2006-03-20NFS: introduce mechanism for tracking NFS client metricsChuck Lever
Add a per-superblock performance counter facility to the NFS client. This facility mimics the counters available for block devices and for networking. Expose these new counters via the new /proc/self/mountstats interface. Thanks to Andrew Morton and Trond Myklebust for their review and comments. Test plan: fsx and iozone on UP and SMP systems, with and without pre-emption. Watch for memory overwrite bugs, and performance loss (significantly more CPU required per op). Signed-off-by: Chuck Lever <cel@netapp.com> Signed-off-by: Trond Myklebust <Trond.Myklebust@netapp.com>
