path: root/fs/nfs/nfs3proc.c
2010-05-14NFS: Reduce the stack footprint of nfs_rmdirTrond Myklebust
Signed-off-by: Trond Myklebust <Trond.Myklebust@netapp.com>
2010-05-14NFS: Reduce stack footprint of nfs_proc_remove()Trond Myklebust
2010-05-14NFS: Reduce stack footprint of nfs3_proc_readlink()Trond Myklebust
2010-05-14NFS: Reduce the stack footprint of nfs_link()Trond Myklebust
2010-05-14NFS: Reduce stack footprint of nfs_readdir()Trond Myklebust
2010-05-14NFS: Reduce stack footprint of nfs3_proc_rename() and nfs4_proc_rename()Trond Myklebust
2010-05-14NFSv4: Reduce stack footprint of nfs4_proc_access() and nfs3_proc_access()Trond Myklebust
2010-05-14NFS: Reduce the stack footprint of nfs_lookupTrond Myklebust
implicit slab.h inclusion from percpu.h percpu.h is included by sched.h and module.h and thus ends up being included when building most .c files. percpu.h includes slab.h which in turn includes gfp.h making everything defined by the two files universally available and complicating inclusion dependencies. percpu.h -> slab.h dependency is about to be removed. Prepare for this change by updating users of gfp and slab facilities include those headers directly instead of assuming availability. As this conversion needs to touch large number of source files, the following script is used as the basis of conversion. http://userweb.kernel.org/~tj/misc/slabh-sweep.py The script does the followings. * Scan files for gfp and slab usages and update includes such that only the necessary includes are there. ie. if only gfp is used, gfp.h, if slab is used, slab.h. * When the script inserts a new include, it looks at the include blocks and try to put the new include such that its order conforms to its surrounding. It's put in the include block which contains core kernel includes, in the same order that the rest are ordered - alphabetical, Christmas tree, rev-Xmas-tree or at the end if there doesn't seem to be any matching order. * If the script can't find a place to put a new include (mostly because the file doesn't have fitting include block), it prints out an error message indicating which .h file needs to be added to the file. The conversion was done in the following steps. 1. The initial automatic conversion of all .c files updated slightly over 4000 files, deleting around 700 includes and adding ~480 gfp.h and ~3000 slab.h inclusions. The script emitted errors for ~400 files. 2. Each error was manually checked. Some didn't need the inclusion, some needed manual addition while adding it to implementation .h or embedding .c file was more appropriate for others. This step added inclusions to around 150 files. 3. The script was run again and the output was compared to the edits from #2 to make sure no file was left behind. 4. Several build tests were done and a couple of problems were fixed. e.g. lib/decompress_*.c used malloc/free() wrappers around slab APIs requiring slab.h to be added manually. 5. The script was run on all .h files but without automatically editing them as sprinkling gfp.h and slab.h inclusions around .h files could easily lead to inclusion dependency hell. Most gfp.h inclusion directives were ignored as stuff from gfp.h was usually wildly available and often used in preprocessor macros. Each slab.h inclusion directive was examined and added manually as necessary. 6. percpu.h was updated not to include slab.h. 7. Build test were done on the following configurations and failures were fixed. CONFIG_GCOV_KERNEL was turned off for all tests (as my distributed build env didn't work with gcov compiles) and a few more options had to be turned off depending on archs to make things build (like ipr on powerpc/64 which failed due to missing writeq). * x86 and x86_64 UP and SMP allmodconfig and a custom test config. * powerpc and powerpc64 SMP allmodconfig * sparc and sparc64 SMP allmodconfig * ia64 SMP allmodconfig * s390 SMP allmodconfig * alpha SMP allmodconfig * um on x86_64 SMP allmodconfig 8. percpu.h modifications were reverted so that it could be applied as a separate patch and serve as bisection point. Given the fact that I had only a couple of failures from tests on step 6, I'm fairly confident about the coverage of this conversion patch. If there is a breakage, it's likely to be something in one of the arch headers which should be easily discoverable easily on most builds of the specific arch. Signed-off-by: Tejun Heo <tj@kernel.org> Guess-its-ok-by: Christoph Lameter <cl@linux-foundation.org> Cc: Ingo Molnar <mingo@redhat.com> Cc: Lee Schermerhorn <Lee.Schermerhorn@hp.com>
2010-02-10nfs: handle NFSv3 -EKEYEXPIRED errors as we would -EJUKEBOXJeff Layton
We're using -EKEYEXPIRED to indicate that a krb5 credcache contains an expired ticket and that we should have the NFS layer retry the RPC call instead of returning an error back to the caller. Handle this as we would an -EJUKEBOX error return. Signed-off-by: Jeff Layton <jlayton@redhat.com> Signed-off-by: Trond Myklebust <Trond.Myklebust@netapp.com>
2009-09-23headers: utsname.h reduxAlexey Dobriyan
* remove asm/atomic.h inclusion from linux/utsname.h -- not needed after kref conversion * remove linux/utsname.h inclusion from files which do not need it NOTE: it looks like fs/binfmt_elf.c do not need utsname.h, however due to some personality stuff it _is_ needed -- cowardly leave ELF-related headers and files alone. Signed-off-by: Alexey Dobriyan <adobriyan@gmail.com> Signed-off-by: Linus Torvalds <torvalds@linux-foundation.org>
2009-09-08NFS: out of date comment regarding O_EXCL above nfs3_proc_create()Harshula Jayasuriya
Hi Trond, Recently we were observing the behaviour difference between a 2.4.x and 2.6.x kernel with respect to O_EXCL. A comment from 2.4.x era, "For now, we don't implement O_EXCL." seems inaccurate in TOT. If so, here's a patch to remove the comment. This patch is against: git://git.kernel.org/pub/scm/linux/kernel/git/torvalds/linux-2.6 Signed-off-by: Harshula Jayasuriya <harshula@redhat.com> Signed-off-by: Trond Myklebust <Trond.Myklebust@netapp.com>
2009-04-02Merge branch 'for-linus' of ↵Linus Torvalds
git://git.kernel.org/pub/scm/linux/kernel/git/viro/vfs-2.6 * 'for-linus' of git://git.kernel.org/pub/scm/linux/kernel/git/viro/vfs-2.6: Remove two unneeded exports and make two symbols static in fs/mpage.c Cleanup after commit 585d3bc06f4ca57f975a5a1f698f65a45ea66225 Trim includes of fdtable.h Don't crap into descriptor table in binfmt_som Trim includes in binfmt_elf Don't mess with descriptor table in load_elf_binary() Get rid of indirect include of fs_struct.h New helper - current_umask() check_unsafe_exec() doesn't care about signal handlers sharing New locking/refcounting for fs_struct Take fs_struct handling to new file (fs/fs_struct.c) Get rid of bumping fs_struct refcount in pivot_root(2) Kill unsharing fs_struct in __set_personality()
2009-03-31New helper - current_umask()Al Viro
current->fs->umask is what most of fs_struct users are doing. Put that into a helper function. Signed-off-by: Al Viro <viro@zeniv.linux.org.uk>
2009-03-19NFS: Optimise NFS close()Trond Myklebust
Close-to-open cache consistency rules really only require us to flush out writes on calls to close(), and require us to revalidate attributes on the very last close of the file. Currently we appear to be doing a lot of extra attribute revalidation and cache flushes. Signed-off-by: Trond Myklebust <Trond.Myklebust@netapp.com>
2008-10-07nfs: authenticated deep mountingEG Keizer
Allow mount to do authenticated mounts below the root of the exported tree. The wording in RFC 2623, sec 2.3.2. allows fsinfo with UNIX authentication on the root of the export. Mounts are not always done on the root of the exported tree. Especially autoumounts often mount below the root of the exported tree. Some server implementations (justly) require full authentication for the so-called deep mounts. The old code used AUTH_SYS only. This caused deep mounts to fail on systems requiring stronger authentication.. The client should try both authentication types and use the first one that succeeds. This method was already partially implemented. This patch completes the implementation for NFS2 and NFS3. This patch was developed to allow Debian systems to automount home directories on Solaris servers with krb5 authentication. Tested on kernel 2.6.24-etchnhalf.1 Signed-off-by: E.G. Keizer <keie@few.vu.nl> Signed-off-by: J. Bruce Fields <bfields@citi.umich.edu> Signed-off-by: Trond Myklebust <Trond.Myklebust@netapp.com>
2008-07-09NFS: Remove the redundant file_open entry from struct nfs_rpc_opsTrond Myklebust
All instances are set to nfs_open(), so we should just remove the redundant indirection. Ditto for the file_release op Signed-off-by: Trond Myklebust <Trond.Myklebust@netapp.com>
2008-07-09NFS: Fix the ftruncate() credential problemTrond Myklebust
ftruncate() access checking is supposed to be performed at open() time, just like reads and writes. Signed-off-by: Trond Myklebust <Trond.Myklebust@netapp.com>
2008-07-09NFS: Reduce the stack usage in NFSv3 create operationsTrond Myklebust
2008-05-16nfs: replace remaining __FUNCTION__ occurrencesHarvey Harrison
__FUNCTION__ is gcc-specific, use __func__ Signed-off-by: Harvey Harrison <harvey.harrison@gmail.com> Cc: Trond Myklebust <trond.myklebust@fys.uio.no> Cc: "J. Bruce Fields" <bfields@fieldses.org> Signed-off-by: Andrew Morton <akpm@linux-foundation.org> Signed-off-by: Trond Myklebust <Trond.Myklebust@netapp.com>
2008-02-01Merge branch 'task_killable' of ↵Linus Torvalds
git://git.kernel.org/pub/scm/linux/kernel/git/willy/misc * 'task_killable' of git://git.kernel.org/pub/scm/linux/kernel/git/willy/misc: (22 commits) Remove commented-out code copied from NFS NFS: Switch from intr mount option to TASK_KILLABLE Add wait_for_completion_killable Add wait_event_killable Add schedule_timeout_killable Use mutex_lock_killable in vfs_readdir Add mutex_lock_killable Use lock_page_killable Add lock_page_killable Add fatal_signal_pending Add TASK_WAKEKILL exit: Use task_is_* signal: Use task_is_* sched: Use task_contributes_to_load, TASK_ALL and TASK_NORMAL ptrace: Use task_is_* power: Use task_is_* wait: Use TASK_NORMAL proc/base.c: Use task_is_* proc/array.c: Use TASK_REPORT perfmon: Use task_is_* ... Fixed up conflicts in NFS/sunrpc manually..
2008-01-30NLM/NFS: Use cached nlm_host when calling nlmclnt_proc()Chuck Lever
Now that each NFS mount point caches its own nlm_host structure, it can be passed to nlmclnt_proc() for each lock request. By pinning an nlm_host for each mount point, we trade the overhead of looking up or creating a fresh nlm_host struct during every NLM procedure call for a little extra memory. We also restrict the nlmclnt_proc symbol to limit the use of this call to in-tree modules. Note that nlm_lookup_host() (just removed from the client's per-request NLM processing) could also trigger an nlm_host garbage collection. Now client-side nlm_host garbage collection occurs only during NFS mount processing. Since the NFS client now holds a reference on these nlm_host structures, they wouldn't have been affected by garbage collection anyway. Given that nlm_lookup_host() reorders the global nlm_host chain after every successful lookup, and that a garbage collection could be triggered during the call, we've removed a significant amount of per-NLM-request CPU processing overhead. Sidebar: there are only a few remaining references to the internals of NFS inodes in the client-side NLM code. The only references I found are related to extracting or comparing the inode's file handle via NFS_FH(). One is in nlmclnt_grant(); the other is in nlmclnt_setlockargs(). Signed-off-by: Chuck Lever <chuck.lever@oracle.com> Signed-off-by: Trond Myklebust <Trond.Myklebust@netapp.com>
2008-01-30NFS: Clean up the (commit|read|write)_setup() callback routinesTrond Myklebust
Move the common code for setting up the nfs_write_data and nfs_read_data structures into fs/nfs/read.c, fs/nfs/write.c and fs/nfs/direct.c. Signed-off-by: Trond Myklebust <Trond.Myklebust@netapp.com>
2007-12-06NFS: Switch from intr mount option to TASK_KILLABLEMatthew Wilcox
By using the TASK_KILLABLE infrastructure, we can get rid of the 'intr' mount option. We have to use _killable everywhere instead of _interruptible as we get rid of rpc_clnt_sigmask/sigunmask. Signed-off-by: Liam R. Howlett <howlett@gmail.com> Signed-off-by: Matthew Wilcox <willy@linux.intel.com>
2007-10-09NFS: Use nfs_refresh_inode() in ops that aren't expected to change the inodeTrond Myklebust
nfs_post_op_update_inode() is really only meant to be used if we expect the inode and its attributes to have changed in some way. Signed-off-by: Trond Myklebust <Trond.Myklebust@netapp.com>
2007-10-09NFSv3: Always use directory post-op attributes in nfs3_proc_lookupTrond Myklebust
LOOKUP returns the directory post-op attributes whether or not the operation was successful. Signed-off-by: Trond Myklebust <Trond.Myklebust@netapp.com>
2007-10-09NFS: Fake up 'wcc' attributes to prevent cache invalidation after writeTrond Myklebust
NFSv2 and v4 don't offer weak cache consistency attributes on WRITE calls. In NFSv3, returning wcc data is optional. In all cases, we want to prevent the client from invalidating our cached data whenever ->write_done() attempts to update the inode attributes. Signed-off-by: Trond Myklebust <Trond.Myklebust@netapp.com>
2007-10-09NFS: Fix atime revalidation in read()Trond Myklebust
NFSv3 will correctly update atime on a read() call, so there is no need to set the NFS_INO_INVALID_ATIME flag unless the call to nfs_refresh_inode() fails. Signed-off-by: Trond Myklebust <Trond.Myklebust@netapp.com>
2007-10-09NFS: Fix atime revalidation in readdir()Trond Myklebust
NFSv3 will correctly update atime on a readdir call, so there is no need to set the NFS_INO_INVALID_ATIME flag unless the call to nfs_refresh_inode() fails. Signed-off-by: Trond Myklebust <Trond.Myklebust@netapp.com>
2007-07-19SUNRPC: Clean up the sillyrename codeTrond Myklebust
Fix a couple of bugs: - Don't rely on the parent dentry still being valid when the call completes. Fixes a race with shrink_dcache_for_umount_subtree() - Don't remove the file if the filehandle has been labelled as stale. Fix a couple of inefficiencies - Remove the global list of sillyrenamed files. Instead we can cache the sillyrename information in the dentry->d_fsdata - Move common code from unlink_setup/unlink_done into fs/nfs/unlink.c Signed-off-by: Trond Myklebust <Trond.Myklebust@netapp.com>
2007-07-19NFS: Introduce struct nfs_removeargs+nfs_removeresTrond Myklebust
We need a common structure for setting up an unlink() rpc call in order to fix the asynchronous unlink code. Signed-off-by: Trond Myklebust <Trond.Myklebust@netapp.com>
2007-07-10NFS: nfs3_proc_create() should use nfs_post_op_update_inode()Trond Myklebust
Also get rid of a redundant call to nfs_setattr_update_inode(). The call to nfs3_proc_setattr() already takes care of that. Signed-off-by: Trond Myklebust <Trond.Myklebust@netapp.com>
2007-02-03NFS: Remove nfs_readpage_sync()Trond Myklebust
It makes no sense to maintain 2 parallel systems for reading in pages. Signed-off-by: Trond Myklebust <Trond.Myklebust@netapp.com>
2006-12-08[PATCH] nfs: change uses of f_{dentry,vfsmnt} to use f_pathJosef "Jeff" Sipek
Change all the uses of f_{dentry,vfsmnt} to f_path.{dentry,mnt} in the nfs client code. Signed-off-by: Josef "Jeff" Sipek <jsipek@cs.sunysb.edu> Signed-off-by: Andrew Morton <akpm@osdl.org> Signed-off-by: Linus Torvalds <torvalds@osdl.org>
2006-12-06NFS: Remove nfs_writepage_sync()Trond Myklebust
Maintaining two parallel ways of doing synchronous writes is rather pointless. This patch gets rid of the legacy nfs_writepage_sync(), and replaces it with the faster asynchronous writes. Signed-off-by: Trond Myklebust <Trond.Myklebust@netapp.com>
2006-12-06NFS: Remove use of the Big Kernel Lock around calls to rpc_call_syncFrank Filz
Remove use of the Big Kernel Lock around calls to rpc_call_sync. Signed-off-by: Frank Filz <ffilz@us.ibm.com> Signed-off-by: Trond Myklebust <Trond.Myklebust@netapp.com>
2006-12-06NFS Exclusive open not supported bugAndy Ryan
When trying to open a file with the O_EXCL flag over NFS on a server that does not support exclusive mode, the file does not open. The reason, rpc_call_sync returns a errno number, and not the nfs error number. I fixed it by changing the status check in nfs3proc.c. Either this is how it should be fixed, or rpc_call_sync should be fixed to return the NFS error. Signed-off-by: Andy Ryan <genanr@allantgroup.com> Signed-off-by: Trond Myklebust <Trond.Myklebust@netapp.com>
2006-10-20[PATCH] nfs: verifier is network-endianAl Viro
Signed-off-by: Al Viro <viro@zeniv.linux.org.uk> Acked-by: Trond Myklebust <trond.myklebust@fys.uio.no> Acked-by: Neil Brown <neilb@suse.de> Signed-off-by: Andrew Morton <akpm@osdl.org> Signed-off-by: Linus Torvalds <torvalds@osdl.org>
2006-09-27[PATCH] fs: Removing useless castsPanagiotis Issaris
* Removing useless casts * Removing useless wrapper * Conversion from kmalloc+memset to kzalloc Signed-off-by: Panagiotis Issaris <takis@issaris.org> Acked-by: Dave Kleikamp <shaggy@austin.ibm.com> Signed-off-by: Andrew Morton <akpm@osdl.org> Signed-off-by: Linus Torvalds <torvalds@osdl.org>
2006-09-22NFS: Use cached page as buffer for NFS symlink requestsChuck Lever
Now that we have a copy of the symlink path in the page cache, we can pass a struct page down to the XDR routines instead of a string buffer. Test plan: Connectathon, all NFS versions. Signed-off-by: Chuck Lever <chuck.lever@oracle.com> Signed-off-by: Trond Myklebust <Trond.Myklebust@netapp.com>
2006-09-22NFS: Fix double d_drop in nfs_instantiate() error pathChuck Lever
If the LOOKUP or GETATTR in nfs_instantiate fail, nfs_instantiate will do a d_drop before returning. But some callers already do a d_drop in the case of an error return. Make certain we do only one d_drop in all error paths. This issue was introduced because over time, the symlink proc API diverged slightly from the create/mkdir/mknod proc API. To prevent other coding mistakes of this type, change the symlink proc API to be more like create/mkdir/mknod and move the nfs_instantiate call into the symlink proc routines so it is used in exactly the same way for create, mkdir, mknod, and symlink. Test plan: Connectathon, all versions of NFS. Signed-off-by: Chuck Lever <chuck.lever@oracle.com> Signed-off-by: Trond Myklebust <Trond.Myklebust@netapp.com>
2006-09-22NFS: Share NFS superblocks per-protocol per-server per-FSIDDavid Howells
The attached patch makes NFS share superblocks between mounts from the same server and FSID over the same protocol. It does this by creating each superblock with a false root and returning the real root dentry in the vfsmount presented by get_sb(). The root dentry set starts off as an anonymous dentry if we don't already have the dentry for its inode, otherwise it simply returns the dentry we already have. We may thus end up with several trees of dentries in the superblock, and if at some later point one of anonymous tree roots is discovered by normal filesystem activity to be located in another tree within the superblock, the anonymous root is named and materialises attached to the second tree at the appropriate point. Why do it this way? Why not pass an extra argument to the mount() syscall to indicate the subpath and then pathwalk from the server root to the desired directory? You can't guarantee this will work for two reasons: (1) The root and intervening nodes may not be accessible to the client. With NFS2 and NFS3, for instance, mountd is called on the server to get the filehandle for the tip of a path. mountd won't give us handles for anything we don't have permission to access, and so we can't set up NFS inodes for such nodes, and so can't easily set up dentries (we'd have to have ghost inodes or something). With this patch we don't actually create dentries until we get handles from the server that we can use to set up their inodes, and we don't actually bind them into the tree until we know for sure where they go. (2) Inaccessible symbolic links. If we're asked to mount two exports from the server, eg: mount warthog:/warthog/aaa/xxx /mmm mount warthog:/warthog/bbb/yyy /nnn We may not be able to access anything nearer the root than xxx and yyy, but we may find out later that /mmm/www/yyy, say, is actually the same directory as the one mounted on /nnn. What we might then find out, for example, is that /warthog/bbb was actually a symbolic link to /warthog/aaa/xxx/www, but we can't actually determine that by talking to the server until /warthog is made available by NFS. This would lead to having constructed an errneous dentry tree which we can't easily fix. We can end up with a dentry marked as a directory when it should actually be a symlink, or we could end up with an apparently hardlinked directory. With this patch we need not make assumptions about the type of a dentry for which we can't retrieve information, nor need we assume we know its place in the grand scheme of things until we actually see that place. This patch reduces the possibility of aliasing in the inode and page caches for inodes that may be accessed by more than one NFS export. It also reduces the number of superblocks required for NFS where there are many NFS exports being used from a server (home directory server + autofs for example). This in turn makes it simpler to do local caching of network filesystems, as it can then be guaranteed that there won't be links from multiple inodes in separate superblocks to the same cache file. Obviously, cache aliasing between different levels of NFS protocol could still be a problem, but at least that gives us another key to use when indexing the cache. This patch makes the following changes: (1) The server record construction/destruction has been abstracted out into its own set of functions to make things easier to get right. These have been moved into fs/nfs/client.c. All the code in fs/nfs/client.c has to do with the management of connections to servers, and doesn't touch superblocks in any way; the remaining code in fs/nfs/super.c has to do with VFS superblock management. (2) The sequence of events undertaken by NFS mount is now reordered: (a) A volume representation (struct nfs_server) is allocated. (b) A server representation (struct nfs_client) is acquired. This may be allocated or shared, and is keyed on server address, port and NFS version. (c) If allocated, the client representation is initialised. The state member variable of nfs_client is used to prevent a race during initialisation from two mounts. (d) For NFS4 a simple pathwalk is performed, walking from FH to FH to find the root filehandle for the mount (fs/nfs/getroot.c). For NFS2/3 we are given the root FH in advance. (e) The volume FSID is probed for on the root FH. (f) The volume representation is initialised from the FSINFO record retrieved on the root FH. (g) sget() is called to acquire a superblock. This may be allocated or shared, keyed on client pointer and FSID. (h) If allocated, the superblock is initialised. (i) If the superblock is shared, then the new nfs_server record is discarded. (j) The root dentry for this mount is looked up from the root FH. (k) The root dentry for this mount is assigned to the vfsmount. (3) nfs_readdir_lookup() creates dentries for each of the entries readdir() returns; this function now attaches disconnected trees from alternate roots that happen to be discovered attached to a directory being read (in the same way nfs_lookup() is made to do for lookup ops). The new d_materialise_unique() function is now used to do this, thus permitting the whole thing to be done under one set of locks, and thus avoiding any race between mount and lookup operations on the same directory. (4) The client management code uses a new debug facility: NFSDBG_CLIENT which is set by echoing 1024 to /proc/net/sunrpc/nfs_debug. (5) Clone mounts are now called xdev mounts. (6) Use the dentry passed to the statfs() op as the handle for retrieving fs statistics rather than the root dentry of the superblock (which is now a dummy). Signed-Off-By: David Howells <dhowells@redhat.com> Signed-off-by: Trond Myklebust <Trond.Myklebust@netapp.com>
2006-09-22NFS: Eliminate client_sys in favour of cl_rpcclientDavid Howells
Eliminate nfs_server::client_sys in favour of nfs_client::cl_rpcclient as we only really need one per server that we're talking to since it doesn't have any security on it. The retransmission management variables are also moved to the common struct as they're required to set up the cl_rpcclient connection. The NFS2/3 client and client_acl connections are thenceforth derived by cloning the cl_rpcclient connection and post-applying the authorisation flavour. The code for setting up the initial common connection has been moved to client.c as nfs_create_rpc_client(). All the NFS program definition tables are also moved there as that's where they're now required rather than super.c. Signed-Off-By: David Howells <dhowells@redhat.com> Signed-off-by: Trond Myklebust <Trond.Myklebust@netapp.com>
2006-09-22NFS: Add extra const qualifiersDavid Howells
Add some extra const qualifiers into NFS. Signed-Off-By: David Howells <dhowells@redhat.com> Signed-off-by: Trond Myklebust <Trond.Myklebust@netapp.com>
2006-06-09NFS: Split fs/nfs/inode.cDavid Howells
As fs/nfs/inode.c is rather large, heterogenous and unwieldy, the attached patch splits it up into a number of files: (*) fs/nfs/inode.c Strictly inode specific functions. (*) fs/nfs/super.c Superblock management functions for NFS and NFS4, normal access, clones and referrals. The NFS4 superblock functions _could_ move out into a separate conditionally compiled file, but it's probably not worth it as there're so many common bits. (*) fs/nfs/namespace.c Some namespace-specific functions have been moved here. (*) fs/nfs/nfs4namespace.c NFS4-specific namespace functions (this could be merged into the previous file). This file is conditionally compiled. (*) fs/nfs/internal.h Inter-file declarations, plus a few simple utility functions moved from fs/nfs/inode.c. Additionally, all the in-.c-file externs have been moved here, and those files they were moved from now includes this file. For the most part, the functions have not been changed, only some multiplexor functions have changed significantly. I've also: (*) Added some extra banner comments above some functions. (*) Rearranged the function order within the files to be more logical and better grouped (IMO), though someone may prefer a different order. (*) Reduced the number of #ifdefs in .c files. (*) Added missing __init and __exit directives. Signed-Off-By: David Howells <dhowells@redhat.com>
2006-03-20NFS: Cleanup of NFS read codeTrond Myklebust
Same callback hierarchy inversion as for the NFS write calls. This patch is not strictly speaking needed by the O_DIRECT code, but avoids confusing differences between the asynchronous read and write code. Signed-off-by: Trond Myklebust <Trond.Myklebust@netapp.com>
2006-03-20NFS: Cleanup of NFS write code in preparation for asynchronous o_directTrond Myklebust
This patch inverts the callback hierarchy for NFS write calls. Instead of having the NFSv2/v3/v4-specific code set up the RPC callback ops, we allow the original caller to do so. This allows for more flexibility w.r.t. how to set up and tear down the nfs_write_data structure while still allowing the NFSv3/v4 code to perform error handling. The greater flexibility is needed by the asynchronous O_DIRECT code, which wants to be able to hold on to the original nfs_write_data structures after the WRITE RPC call has completed in order to be able to replay them if the COMMIT call determines that the server has rebooted. Signed-off-by: Trond Myklebust <Trond.Myklebust@netapp.com>
2006-03-20SUNRPC: eliminate rpc_call()Chuck Lever
Clean-up: replace rpc_call() helper with direct call to rpc_call_sync. This makes NFSv2 and NFSv3 synchronous calls more computationally efficient, and reduces stack consumption in functions that used to invoke rpc_call more than once. Test plan: Compile kernel with CONFIG_NFS enabled. Connectathon on NFS version 2, version 3, and version 4 mount points. Signed-off-by: Chuck Lever <cel@netapp.com> Signed-off-by: Trond Myklebust <Trond.Myklebust@netapp.com>
2006-03-20NFS: add hooks to account for NFSERR_JUKEBOX errorsChuck Lever
Make an inode or an nfs_server struct available in the logic that handles JUKEBOX/DELAY type errors so the NFS client can account for them. This patch is split out from the main nfs iostat patch to highlight minor architectural changes required to support this statistic. Test plan: None. Signed-off-by: Chuck Lever <cel@netapp.com> Signed-off-by: Trond Myklebust <Trond.Myklebust@netapp.com>
