path: root/fs/nfs/nfs3xdr.c
2008-04-19nfs: return negative error value from nfs{,4}_stat_to_errnoBenny Halevy
All use sites for nfs{,4}_stat_to_errno negate their return value. It's more efficient to return a negative error from the stat_to_errno convertors rather than negating its return value everywhere. This also produces slightly smaller code. Signed-off-by: Benny Halevy <bhalevy@panasas.com> Signed-off-by: Trond Myklebust <Trond.Myklebust@netapp.com>
2008-03-19NFS: clean up short packet handling for NFSv3 readdirJeff Layton
Currently, the NFS readdir decoders have a workaround for buggy servers that send an empty readdir response with the EOF bit unset. If the server sends a malformed response in some cases, this workaround kicks in and just returns an empty response rather than returning a proper error to the caller. This patch does 3 things: 1) have malformed responses with no entries return error (-EIO) 2) preserve existing workaround for servers that send empty responses with the EOF marker unset. 3) Add some comments to clarify the logic in nfs3_xdr_readdirres(). Signed-off-by: Jeff Layton <jlayton@redhat.com> Signed-off-by: Trond Myklebust <Trond.Myklebust@netapp.com>
2008-01-30NFS: Use unsigned intermediates for manipulating header lengths (NFSv3 XDR)Chuck Lever
Clean up: prevent length underflow and mixed sign comparisons when unmarshalling NFS version 3 read, readdir, and readlink replies. Signed-off-by: Chuck Lever <chuck.lever@oracle.com> Signed-off-by: Trond Myklebust <Trond.Myklebust@netapp.com>
2007-10-09SUNRPC: mark bulk read/write data in xdrbuf\"Talpey, Thomas\
Adds a flag word to the xdrbuf struct which indicates any bulk disposition of the data. This enables RPC transport providers to marshal it efficiently/appropriately, and may enable other optimizations. Signed-off-by: Tom Talpey <tmt@netapp.com> Signed-off-by: Trond Myklebust <Trond.Myklebust@netapp.com>
2007-10-09NFS: Convert printk's to dprintk's in fs/nfs/nfs?xdr.cChuck Lever
Due to recent edict to replace or remove printk's that can be triggered en masse by remote misbehavior. Left a few that only occur just before a BUG. Signed-off-by: Chuck Lever <chuck.lever@oracle.com> Signed-off-by: Trond Myklebust <Trond.Myklebust@netapp.com>
2007-07-19NFS: Introduce struct nfs_removeargs+nfs_removeresTrond Myklebust
We need a common structure for setting up an unlink() rpc call in order to fix the asynchronous unlink code. Signed-off-by: Trond Myklebust <Trond.Myklebust@netapp.com>
2007-07-10SUNRPC: Remove the tk_auth macro...Trond Myklebust
We should almost always be deferencing the rpc_auth struct by means of the credential's cr_auth field instead of the rpc_clnt->cl_auth anyway. Fix up that historical mistake, and remove the macro that propagated it. Signed-off-by: Trond Myklebust <Trond.Myklebust@netapp.com>
2007-04-30SUNRPC: RPC buffer size estimates are too largeChuck Lever
The RPC buffer size estimation logic in net/sunrpc/clnt.c always significantly overestimates the requirements for the buffer size. A little instrumentation demonstrated that in fact rpc_malloc was never allocating the buffer from the mempool, but almost always called kmalloc. To compute the size of the RPC buffer more precisely, split p_bufsiz into two fields; one for the argument size, and one for the result size. Then, compute the sum of the exact call and reply header sizes, and split the RPC buffer precisely between the two. That should keep almost all RPC buffers within the 2KiB buffer mempool limit. And, we can finally be rid of RPC_SLACK_SPACE! Signed-off-by: Chuck Lever <chuck.lever@oracle.com> Signed-off-by: Trond Myklebust <Trond.Myklebust@netapp.com>
2006-10-20[PATCH] xdr annotations: NFS readdir entriesAl Viro
on-the-wire data is big-endian [in large part pulled from Alexey's patch] Signed-off-by: Al Viro <viro@zeniv.linux.org.uk> Acked-by: Trond Myklebust <trond.myklebust@fys.uio.no> Acked-by: Neil Brown <neilb@suse.de> Signed-off-by: Andrew Morton <akpm@osdl.org> Signed-off-by: Linus Torvalds <torvalds@osdl.org>
2006-10-20[PATCH] xdr annotations: NFSv3Al Viro
2006-09-22NFS: Use cached page as buffer for NFS symlink requestsChuck Lever
Now that we have a copy of the symlink path in the page cache, we can pass a struct page down to the XDR routines instead of a string buffer. Test plan: Connectathon, all NFS versions. Signed-off-by: Chuck Lever <chuck.lever@oracle.com> Signed-off-by: Trond Myklebust <Trond.Myklebust@netapp.com>
2006-06-09NFS: Split fs/nfs/inode.cDavid Howells
As fs/nfs/inode.c is rather large, heterogenous and unwieldy, the attached patch splits it up into a number of files: (*) fs/nfs/inode.c Strictly inode specific functions. (*) fs/nfs/super.c Superblock management functions for NFS and NFS4, normal access, clones and referrals. The NFS4 superblock functions _could_ move out into a separate conditionally compiled file, but it's probably not worth it as there're so many common bits. (*) fs/nfs/namespace.c Some namespace-specific functions have been moved here. (*) fs/nfs/nfs4namespace.c NFS4-specific namespace functions (this could be merged into the previous file). This file is conditionally compiled. (*) fs/nfs/internal.h Inter-file declarations, plus a few simple utility functions moved from fs/nfs/inode.c. Additionally, all the in-.c-file externs have been moved here, and those files they were moved from now includes this file. For the most part, the functions have not been changed, only some multiplexor functions have changed significantly. I've also: (*) Added some extra banner comments above some functions. (*) Rearranged the function order within the files to be more logical and better grouped (IMO), though someone may prefer a different order. (*) Reduced the number of #ifdefs in .c files. (*) Added missing __init and __exit directives. Signed-Off-By: David Howells <dhowells@redhat.com>
2006-06-09NFS: Store the file system "fsid" value in the NFS super block.Trond Myklebust
This should enable us to detect if we are crossing a mountpoint in the case where the server is exporting "nohide" mounts. Signed-off-by: Trond Myklebust <Trond.Myklebust@netapp.com>
2006-03-25Merge git://git.linux-nfs.org/pub/linux/nfs-2.6Linus Torvalds
* git://git.linux-nfs.org/pub/linux/nfs-2.6: (103 commits) SUNRPC,RPCSEC_GSS: spkm3--fix config dependencies SUNRPC,RPCSEC_GSS: spkm3: import contexts using NID_cast5_cbc LOCKD: Make nlmsvc_traverse_shares return void LOCKD: nlmsvc_traverse_blocks return is unused SUNRPC,RPCSEC_GSS: fix krb5 sequence numbers. NFSv4: Dont list system.nfs4_acl for filesystems that don't support it. SUNRPC,RPCSEC_GSS: remove unnecessary kmalloc of a checksum SUNRPC: Ensure rpc_call_async() always calls tk_ops->rpc_release() SUNRPC: Fix memory barriers for req->rq_received NFS: Fix a race in nfs_sync_inode() NFS: Clean up nfs_flush_list() NFS: Fix a race with PG_private and nfs_release_page() NFSv4: Ensure the callback daemon flushes signals SUNRPC: Fix a 'Busy inodes' error in rpc_pipefs NFS, NLM: Allow blocking locks to respect signals NFS: Make nfs_fhget() return appropriate error values NFSv4: Fix an oops in nfs4_fill_super lockd: blocks should hold a reference to the nlm_file NFSv4: SETCLIENTID_CONFIRM should handle NFS4ERR_DELAY/NFS4ERR_RESOURCE NFSv4: Send the delegation stateid for SETATTR calls ...
2006-03-24[PATCH] fs: Use ARRAY_SIZE macroTobias Klauser
Use ARRAY_SIZE macro instead of sizeof(x)/sizeof(x[0]) and remove a duplicate of ARRAY_SIZE. Some trailing whitespaces are also deleted. Signed-off-by: Tobias Klauser <tklauser@nuerscht.ch> Cc: David Howells <dhowells@redhat.com> Cc: Dave Kleikamp <shaggy@austin.ibm.com> Acked-by: Trond Myklebust <trond.myklebust@fys.uio.no> Cc: Neil Brown <neilb@cse.unsw.edu.au> Cc: Chris Mason <mason@suse.com> Cc: Jeff Mahoney <jeffm@suse.com> Cc: Christoph Hellwig <hch@lst.de> Cc: Nathan Scott <nathans@sgi.com> Signed-off-by: Andrew Morton <akpm@osdl.org> Signed-off-by: Linus Torvalds <torvalds@osdl.org>
2006-03-20SUNRPC: display human-readable procedure name in rpc_iostats outputChuck Lever
Add fields to the rpc_procinfo struct that allow the display of a human-readable name for each procedure in the rpc_iostats output. Also fix it so that the NFSv4 stats are broken up correctly by sub-procedure number. NFSv4 uses only two real RPC procedures: NULL, and COMPOUND. Test plan: Mount with NFSv2, NFSv3, and NFSv4, and do "cat /proc/self/mountstats". Signed-off-by: Chuck Lever <cel@netapp.com> Signed-off-by: Trond Myklebust <Trond.Myklebust@netapp.com>
2006-01-06NFS: Send valid mode bits to the serverTrond Myklebust
inode->i_mode contains a lot more than just the mode bits. Make sure that we mask away this extra stuff in SETATTR calls to the server. Signed-off-by: Trond Myklebust <Trond.Myklebust@netapp.com>
2005-10-27NFS: Optimise inode attribute cache updatesTrond Myklebust
Allow nfs_refresh_inode() also to update attributes on the inode if the RPC call was sent after the last call to nfs_update_inode(). Signed-off-by: Trond Myklebust <Trond.Myklebust@netapp.com>
2005-06-22[PATCH] fix nfsacl pointer arithmetic and pg_class initialization bugsAndreas Gruenbacher
* Pointer arithmetic bug: p is in word units. This fixes a memory corruption with big acls. * Initialize pg_class to prevent a NULL pointer access. Signed-off-by: Andreas Gruenbacher <agruen@suse.de> Signed-off-by: Trond Myklebust <Trond.Myklebust@netapp.com>
2005-06-22[PATCH] NFS: Add support for NFSv3 ACLsAndreas Gruenbacher
This adds acl support fo nfs clients via the NFSACL protocol extension, by implementing the getxattr, listxattr, setxattr, and removexattr iops for the system.posix_acl_access and system.posix_acl_default attributes. This patch implements a dumb version that uses no caching (and thus adds some overhead). (Another patch in this patchset adds caching as well.) Signed-off-by: Andreas Gruenbacher <agruen@suse.de> Acked-by: Olaf Kirch <okir@suse.de> Signed-off-by: Andrew Morton <akpm@osdl.org> Signed-off-by: Trond Myklebust <Trond.Myklebust@netapp.com>
