commit 1788ea6e3b2a58cf4fb00206e362d9caff8d86a7 upstream.
commit d953126 changed how nfs_atomic_lookup handles an -EISDIR return
from an OPEN call. Prior to that patch, that caused the client to fall
back to doing a normal lookup. When that patch went in, the code began
returning that error to userspace. The d_revalidate codepath however
never had the corresponding change, so it was still possible to end up
with a NULL ctx->state pointer after that.
That patch caused a regression. When we attempt to open a directory that
does not have a cached dentry, that open now errors out with EISDIR. If
you attempt the same open with a cached dentry, it will succeed.
Fix this by reverting the change in nfs_atomic_lookup and allowing
attempts to open directories to fall back to a normal lookup
Also, add a NFSv4-specific f_ops->open routine that just returns
-ENOTDIR. This should never be called if things are working properly,
but if it ever is, then the dprintk may help in debugging.
To facilitate this, a new file_operations field is also added to the
nfs_rpc_ops struct.
Signed-off-by: Jeff Layton <jlayton@redhat.com>
Signed-off-by: Trond Myklebust <Trond.Myklebust@netapp.com>
commit a9bae5666d0510ad69bdb437371c9a3e6b770705 upstream.
There can be multiple lseg per file, so layoutcommit should be
able to handle it.
[Needed in v3.0]
Signed-off-by: Peng Tao <peng_tao@emc.com>
Signed-off-by: Boaz Harrosh <bharrosh@panasas.com>
Signed-off-by: Jim Rees <rees@umich.edu>
_pnfs_return_layout had the following problems:
- it did not call pnfs_free_lseg_list on all paths
- it unintentionally did a forgetful return when there was no outstanding io
- it raced with concurrent LAYOUTGETS
Signed-off-by: Fred Isaman <iisaman@netapp.com>
Commit 28331a46d88459788c8fca72dbb0415cd7f514c9 "Ensure we request the
ordinary fileid when doing readdirplus"
changed the meaning of NFS_ATTR_FATTR_FILEID which used to be set when
FATTR4_WORD1_MOUNTED_ON_FILED was requested.
Allow nfs_fhget to succeed with only a mounted on fileid when crossing
a mountpoint or a referral.
Ask for the fileid of the absent file system if mounted_on_fileid is not
supported.
Signed-off-by: Andy Adamson <andros@netapp.com>
cc:stable@kernel.org [2.6.39]
We don't support header padding yet so better off ditching it
Reported-by: Sid Moore <learnmost@gmail.com>
Signed-off-by: Benny Halevy <benny@tonian.com>
* 'pnfs-submit' of git://git.open-osd.org/linux-open-osd: (32 commits)
pnfs-obj: pg_test check for max_io_size
NFSv4.1: define nfs_generic_pg_test
NFSv4.1: use pnfs_generic_pg_test directly by layout driver
NFSv4.1: change pg_test return type to bool
NFSv4.1: unify pnfs_pageio_init functions
pnfs-obj: objlayout_encode_layoutcommit implementation
pnfs: encode_layoutcommit
pnfs-obj: report errors and .encode_layoutreturn Implementation.
pnfs: encode_layoutreturn
pnfs: layoutret_on_setattr
pnfs: layoutreturn
pnfs-obj: osd raid engine read/write implementation
pnfs: support for non-rpc layout drivers
pnfs-obj: define per-inode private structure
pnfs: alloc and free layout_hdr layoutdriver methods
pnfs-obj: objio_osd device information retrieval and caching
pnfs-obj: decode layout, alloc/free lseg
pnfs-obj: pnfs_osd XDR client implementation
pnfs-obj: pnfs_osd XDR definitions
pnfs-obj: objlayoutdriver module skeleton
With the objects layout security model, we have object capabilities
that are associated with the layout and we anticipate that the server
will issue a cb_layoutrecall for any setattr that changes security
related attributes (user/group/mode/acl) or truncates the file.
Therefore, the layout is returned before issuing the setattr to avoid
the anticipated cb_layoutrecall.
Signed-off-by: Benny Halevy <bhalevy@panasas.com>
NFSv4.1 LAYOUTRETURN implementation
Currently, does not support layout-type payload encoding.
Signed-off-by: Alexandros Batsakis <batsakis@netapp.com>
Signed-off-by: Andy Adamson <andros@citi.umich.edu>
Signed-off-by: Dean Hildebrand <dhildeb@us.ibm.com>
Signed-off-by: Fred Isaman <iisaman@citi.umich.edu>
Signed-off-by: Marc Eshel <eshel@almaden.ibm.com>
Signed-off-by: Zhang Jingwang <zhangjingwang@nrchpc.ac.cn>
[call pnfs_return_layout right before pnfs_destroy_layout]
[remove assert_spin_locked from pnfs_clear_lseg_list]
[remove wait parameter from the layoutreturn path.]
[remove return_type field from nfs4_layoutreturn_args]
[remove range from nfs4_layoutreturn_args]
[no need to send layoutcommit from _pnfs_return_layout]
[don't wait on sync layoutreturn]
[fix layout stateid in layoutreturn args]
[fixed NULL deref in _pnfs_return_layout]
[removed recaim member of nfs4_layoutreturn_args]
Non-rpc layout driver such as for objects and blocks
implement their own I/O path and error handling logic.
Therefore bypass NFS-based error handling for these layout drivers.
[fix lseg ref-count bugs, and null de-refs]
[Fall out from: non-rpc layout drivers]
[get rid of PNFS_USE_RPC_CODE]
[get rid of __nfs4_write_done_cb]
[revert useless change in nfs4_write_done_cb]
Currently, if the server returns NFS4ERR_EXPIRED in reply to a READ or
WRITE, but the RENEW test determines that the lease is still active, we
fail to recover and end up looping forever in a READ/WRITE + RENEW death
spiral.
Cc: stable@kernel.org
Free the slot and resend the RPC with new session <slot#,seq#>.
For nfs4_async_handle_error, return -EAGAIN and set the task->tk_status to 0
to restart the async rpc in the rpc_restart_call_prepare state which resets
the slot.
For nfs4_handle_exception, retrying a call that uses nfs4_call_sync will
reset the slot via nfs41_call_sync_prepare.
For open/close/lock/locku/delegreturn/layoutcommit/unlink/rename/write
cachethis is true, so these operations will not trigger an
NFS4ERR_RETRY_UNCACHED_REP.
The following patch ensures that we do not get permanently trapped in
the RPC layer when trying to establish a new client id or session.
This again ensures that the state manager can finish in a timely
fashion when the last filesystem to reference the nfs_client exits.
If a server for some reason keeps sending NFS4ERR_DELAY errors, we can end
up looping forever inside nfs4_proc_create_session, and so the usual
mechanisms for detecting if the nfs_client is dead don't work.
Fix this by ensuring that we loop inside the nfs4_state_manager thread
instead.
I only want to try other secflavors during an initial mount if
NFS4ERR_WRONGSEC is returned. nfs4_handle_exception() could
potentially map other errors to EPERM, so we should handle this
error specially for correctness.
Signed-off-by: Bryan Schumaker <bjschuma@netapp.com>
If we fail to contact the gss upcall program, then no message will
be sent to the server. The client still updated the sequence number,
however, and this lead to NFS4ERR_SEQ_MISMATCH for the next several
RPC calls.
We were always attempting sec flavor negotiation, even if the user
told us a specific sec flavor to use. If that sec flavor fails,
we should return an error rather than continuing with sec flavor
negotiation.
nfs4_lookup_root() is already configured to use either RPC_AUTH_UNIX
or a user specified flavor (through -o sec=<whatever>). We should
use this flavor first, and only attempt negotiation if it fails
with -EPERM.
NFS_MAX_SECFLAVORS should already take into account RPC_AUTH_UNIX
and RPC_AUTH_NULL, so we don't need to set aside extra slots
for them.
There can be an infinite loop if gss_create_upcall() is called without
the userspace program running. To prevent this, we return -EACCES if
we notice that pipe_version hasn't changed (indicating that the pipe
has not been opened).
When attempting an initial mount, we should only attempt other
authflavors if AUTH_UNIX receives a NFS4ERR_WRONGSEC error.
This allows other errors to be passed back to userspace programs.
changes LAYOUTGET and GETDEVICEINFO XDR parsing to:
- not use vmap, which doesn't work on incoherent archs
- use xdr_stream parsing for all xdr
Signed-off-by: Weston Andros Adamson <dros@netapp.com>
When sec=<something> is not presented as a mount option,
we should attempt to determine what security flavor the
server is using.
A submount may use different security than the parent
mount does. We should figure out what sec flavor the
submount uses at mount time.
This patch adds the nfs4 operation secinfo as a
valid nfs rpc operation.
A later patch will need to perform a lookup using an
alternate client with a different security flavor.
This patch adds support for doing that on NFS v4.
This patch changes nfs4_call_sync() from a macro into a
static inline function. As a macro, the call_sync()
function will not do any type checking and depends
on the sequence arguments always having the same name.
As a function, we get to have type checking and can
rename the arguments if we so choose.
The filelayout driver sends LAYOUTCOMMIT only when COMMIT goes to
the data server (as opposed to the MDS) and the data server WRITE
is not NFS_FILE_SYNC.
Only whole file layout support means that there is only one IOMODE_RW layout
segment.
Signed-off-by: Mingyang Guo <guomingyang@nrchpc.ac.cn>
Signed-off-by: Tao Guo <guotao@nrchpc.ac.cn>
Tested-by: Boaz Harrosh <bharrosh@panasas.com>
Any COMMIT compound directed to a data server needs to have the
GETATTR calls suppressed. We here, make sure the field we are testing
(data->lseg) is set and refcounted correctly.
Add a callback that the pnfs layout driver can use to do its own
error handling of the data server's COMMIT response.
The new behaviour is enabled using the new module parameter
'nfs4_disable_idmapping'.
Note that if the server rejects an unmapped uid or gid, then
the client will automatically switch back to using the idmapper.
This will be required in order to switch uid/gid mapping back on if the
admin has tried to disable it.
Note that we also propagate NFS4ERR_BADNAME at the same time, in order to
work around a Linux server bug.
Allows the pnfs filelayout driver to write to the data servers.
Note that COMMIT to data servers will be implemented in a future
patch. To avoid improper behavior, for the moment any WRITE to a data
server that would also require a COMMIT to the data server is sent
NFS_FILE_SYNC.
Signed-off-by: Oleg Drokin <green@linuxhacker.ru>
Signed-off-by: Ricardo Labiaga <Ricardo.Labiaga@netapp.com>
Any WRITE compound directed to a data server needs to have the
Add callback that pnfs layout driver can use to do its own handling
of data server WRITE response.
Use our own async error handler.
Mark the layout as failed and retry i/o through the MDS on specified errors.
Update the mds_offset in nfs_readpage_retry so that a failed short-read retry
to a DS gets correctly resent through the MDS.
Attempt a pNFS file layout read by setting up the nfs_read_data struct and
calling nfs_initiate_read with the data server rpc client and the
filelayout rpc call ops.
Error handling is implemented in a subsequent patch.
Tested-by: Guo Mingyang <guomingyang@nrchpc.ac.cn>
Introduce a data server set_client and init session following the
nfs4_set_client and nfs4_init_session convention.
Once a new nfs_client is on the nfs_client_list, the nfs_client cl_cons_state
serializes access to creating an nfs_client struct with matching properties.
Use the new nfs_get_client() that initializes new clients.
Now nfs_get_client returns an nfs_client ready to be used no matter if it was
found or created.
Remove duplicated #include('s) in
fs/nfs/nfs4proc.c
Signed-off-by: Huang Weiyi <weiyi.huang@gmail.com>
We want SEQUENCE status bits to be handled by the state manager in order
to avoid threading issues.
nfs4_schedule_state_recovery() should only be used when we need to force
the state manager to check the lease. If we just want to start the
state manager in order to handle a state recovery situation, we should be
using nfs4_schedule_state_manager().
This patch fixes the abuses of nfs4_schedule_state_recovery() by replacing
its use with a set of helper functions that do the right thing.
[Trond: fix whitespace errors]
Fix bug where we currently retry the EXCHANGEID call again, eventhough
we already have a valid clientid. Instead, delay and retry the CREATE_SESSION
call.
this commit fix compilation warning as following:
linux-2.6/fs/nfs/nfs4proc.c:3265: warning: comparison of distinct pointer types lacks a cast
Signed-off-by: Jovi Zhang <bookjovi@gmail.com>
Although they run as rpciod background tasks, under normal operation
(i.e. no SIGKILL), functions like nfs_sillyrename(), nfs4_proc_unlck()
and nfs4_do_close() want to be fully synchronous. This means that when we
exit, we want all references to the rpc_task to be gone, and we want
any dentry references etc. held by that task to be released.
For this reason these functions call __rpc_wait_for_completion_task(),
followed by rpc_put_task() in the expectation that the latter will be
releasing the last reference to the rpc_task, and thus ensuring that the
callback_ops->rpc_release() has been called synchronously.
This patch fixes a race which exists due to the fact that
rpciod calls rpc_complete_task() (in order to wake up the callers of
__rpc_wait_for_completion_task()) and then subsequently calls
rpc_put_task() without ensuring that these two steps are done atomically.
In order to avoid adding new spin locks, the patch uses the existing
waitqueue spin lock to order the rpc_task reference count releases between
the waiting process and rpciod.
The common case where nobody is waiting for completion is optimised for by
checking if the RPC_TASK_ASYNC flag is cleared and/or if the rpc_task
reference count is 1: in those cases we drop trying to grab the spin lock,
and immediately free up the rpc_task.
Those few processes that need to put the rpc_task from inside an
asynchronous context and that do not care about ordering are given a new
helper: rpc_put_task_async().
The "bad_page()" page allocator sanity check was reported recently (call
chain as follows):
bad_page+0x69/0x91
free_hot_cold_page+0x81/0x144
skb_release_data+0x5f/0x98
__kfree_skb+0x11/0x1a
tcp_ack+0x6a3/0x1868
tcp_rcv_established+0x7a6/0x8b9
tcp_v4_do_rcv+0x2a/0x2fa
tcp_v4_rcv+0x9a2/0x9f6
do_timer+0x2df/0x52c
ip_local_deliver+0x19d/0x263
ip_rcv+0x539/0x57c
netif_receive_skb+0x470/0x49f
:virtio_net:virtnet_poll+0x46b/0x5c5
net_rx_action+0xac/0x1b3
__do_softirq+0x89/0x133
call_softirq+0x1c/0x28
do_softirq+0x2c/0x7d
do_IRQ+0xec/0xf5
default_idle+0x0/0x50
ret_from_intr+0x0/0xa
default_idle+0x29/0x50
cpu_idle+0x95/0xb8
start_kernel+0x220/0x225
_sinittext+0x22f/0x236
It occurs because an skb with a fraglist was freed from the tcp
retransmit queue when it was acked, but a page on that fraglist had
PG_Slab set (indicating it was allocated from the Slab allocator (which
means the free path above can't safely free it via put_page.
We tracked this back to an nfsv4 setacl operation, in which the nfs code
attempted to fill convert the passed in buffer to an array of pages in
__nfs4_proc_set_acl, which gets used by the skb->frags list in
xs_sendpages. __nfs4_proc_set_acl just converts each page in the buffer
to a page struct via virt_to_page, but the vfs allocates the buffer via
kmalloc, meaning the PG_slab bit is set. We can't create a buffer with
kmalloc and free it later in the tcp ack path with put_page, so we need
to either:
1) ensure that when we create the list of pages, no page struct has
PG_Slab set
or
2) not use a page list to send this data
Given that these buffers can be multiple pages and arbitrarily sized, I
think (1) is the right way to go. I've written the below patch to
allocate a page from the buddy allocator directly and copy the data over
to it. This ensures that we have a put_page free-able page for every
entry that winds up on an skb frag list, so it can be safely freed when
the frame is acked. We do a put page on each entry after the
rpc_call_sync call so as to drop our own reference count to the page,
leaving only the ref count taken by tcp_sendpages. This way the data
will be properly freed when the ack comes in
Successfully tested by myself to solve the above oops.
Note, as this is the result of a setacl operation that exceeded a page
of data, I think this amounts to a local DOS triggerable by an
uprivlidged user, so I'm CCing security on this as well.
Signed-off-by: Neil Horman <nhorman@tuxdriver.com>
CC: Trond Myklebust <Trond.Myklebust@netapp.com>
CC: security@kernel.org
CC: Jeff Layton <jlayton@redhat.com>
As stated in section 2.4 of RFC 5661, subsequent instances of the client need
to present the same co_ownerid. Concatinate the client's IP dot address,
host name, and the rpc_auth pseudoflavor to form the co_ownerid.
