commit 47c2199b6eb5fbe38ddb844db7cdbd914d304f9c upstream.
Currently, the state manager may continue to try recovering state forever
even after the last filesystem to reference that nfs_client has umounted.
Signed-off-by: Trond Myklebust <Trond.Myklebust@netapp.com>
Commit 76db6d9500caeaa774a3e32a997eba30bbdc176b (nfs41: add session setup
to the state manager) introduces an infinite loop possibility in the NFSv4
state manager. By first checking nfs4_has_session() before clearing the
NFS4CLNT_SESSION_SETUP flag, it allows for a situation where someone sets
that flag, but it never gets cleared, and so the state manager loops.
In fact commit c3fad1b1aaf850bf692642642ace7cd0d64af0a3 (nfs41: add session
reset to state manager) causes this to happen every time we get a network
partition error.
Tested-by: Daniel J Blueman <daniel.blueman@gmail.com>
The oops http://www.kerneloops.org/raw.php?rawid=537858&msgid= appears to
be due to the nfs4_lock_state->ls_state field being uninitialised. This
happens if the call to nfs4_free_lock_state() is triggered at the end of
nfs4_get_lock_state().
The fix is to move the initialisation of ls_state into the allocator.
fs/nfs/client.c
fs/nfs/super.c
It is possible for servers to return NFS4ERR_BAD_STATEID when
the state management code is recovering locks or is reclaiming state when
returning a delegation. Ensure that we handle that case.
While we're at it, add in handlers for NFS4ERR_STALE,
NFS4ERR_ADMIN_REVOKED, NFS4ERR_OPENMODE, NFS4ERR_DENIED and
NFS4ERR_STALE_STATEID, since the protocol appears to allow for them too.
Also handle ENOMEM...
Finally, rather than add new NFSv4.0-specific errors and error handling into
the generic delegation code, move that open file and locking state error
handling into the NFSv4 layer.
Unlike minorversion0, in nfsv4.1 the open and lock seqids need
not be incremented by the client and should always be set to zero.
This is implemented using a new nfs_rpc_ops methods -
increment_open_seqid and increment_lock_seqid
Signed-off-by: Rahul Iyer <iyer@netapp.com>
Signed-off-by: Benny Halevy <bhalevy@panasas.com>
[nfs41: check for session not minorversion]
Signed-off-by: Andy Adamson <andros@netapp.com>
Stops an infinite loop of EXCHANGE_ID.
[fixed checkpatch warnings]
Unlike SETCLIENTID, EXCHANGE_ID requires a machine credential. Do not search
for credentials other than the machine credential.
EXCHANGE_ID has different credential requirements than SETCLIENTID.
Prepare for a separate credential function.
nfsv4.1 clientid is established via EXCHANGE_ID rather than
SETCLIENTID{,_CONFIRM}
This is implemented using a new establish_clid method in
nfs4_state_recovery_ops.
nfs41: establish clientid via exchange id only if cred != NULL
>From 2.6.26 reclaimer() uses machine cred for setting up the client id
therefore it is never expected to be NULL.
[removed dprintk]
[nfs41: lease renewal]
[revamped patch for new nfs4_state_manager design]
Use the machine cred for sending SEQUENCE to renew
the client's lease.
[revamp patch for new state management design starting 2.6.29]
[nfs41: support minorversion 1 for nfs4_check_lease]
[nfs41: get cred in exchange_id when cred arg is NULL]
[nfs41: use cl_machined_cred instead of cl_ex_cred]
Since EXCHANGE_ID insists on using the machine credential, cl_ex_cred is
not needed. nfs4_proc_exchange_id() is only called if the machine credential
is available. Remove the credential logic from nfs4_proc_exchange_id.
[moved nfs4_get_renew_cred related changes to
"nfs41: introduce get_state_renewal_cred"]
Move the code to reset a session from the session_reclaimer to the
nfs4_state_manager. Destroy the session, and create a new one. Treat
NFS4ERR_BADSESSION and NFS4ERR_DEADSESSION as a successful
nfs4_proc_destroy_session. Signal nfs4_proc_create_session that this is a
session reset so that the session slot table is re-used.
If the clientid is stale, set both NFS4CLNT_LEASE_EXPIRED and
NFS4CLNT_SESSION_SETUP bits and retry.
Use a switch statement in nfs4_session_recovery_handle_error for future
patche which will add handling for other errors.
[nfs41: session reset in nfs4_recovery_handle_error]
[nfs41: reset session on nfs4_do_reclaim session reset error]
If nfs4_do_reclaim gets a session reset error, nfs4_recovery_handle_error
will set the NFS4CLNT_SESSION_SETUP bit, and the state manager should
continue processing to reset the session.
[move nfs4_proc_destroy_session declaration here]
At mount, nfs_alloc_client sets the cl_state NFS4CLNT_LEASE_EXPIRED bit
and nfs4_alloc_session sets the NFS4CLNT_SESSION_SETUP bit, so both bits are
set when nfs4_lookup_root calls nfs4_recover_expired_lease which schedules
the nfs4_state_manager and waits for it to complete.
Place the session setup after the clientid establishment in nfs4_state_manager
so that the session is setup right after the clientid has been established
without rescheduling the state manager.
Unlike nfsv4.0, the nfs_client struct is not ready to use until the session
has been established. Postpone marking the nfs_client struct to NFS_CS_READY
until after a successful CREATE_SESSION call so that other threads cannot use
the client until the session is established.
If the EXCHANGE_ID call fails and the session has not been setup (the
NFS4CLNT_SESSION_SETUP bit is set), mark the client with the error and return.
If the session setup CREATE_SESSION call fails with NFS4ERR_STALE_CLIENTID
which could occur due to server reboot or network partition inbetween the
EXCHANGE_ID and CREATE_SESSION call, reset the NFS4CLNT_LEASE_EXPIRED and
NFS4CLNT_SESSION_SETUP bits and try again.
If the CREATE_SESSION call fails with other errors, mark the client with
[nfs41: NFS_CS_SESSION_SETUP cl_cons_state for back channel setup]
On session setup, the CREATE_SESSION reply races with the server back channel
probe which needs to succeed to setup the back channel. Set a new
cl_cons_state NFS_CS_SESSION_SETUP just prior to the CREATE_SESSION call
and add it as a valid state to nfs_find_client so that the client back channel
can find the nfs_client struct and won't drop the server backchannel probe.
Use a new cl_cons_state so that NFSv4.0 back channel behaviour which only
sets NFS_CS_READY is unchanged.
Adjust waiting on the nfs_client_active_wq accordingly.
[nfs41: rename NFS_CS_SESSION_SETUP to NFS_CS_SESSION_INITING]
[nfs41: set NFS_CL_SESSION_INITING in alloc_session]
[nfs41: move session setup into a function]
[moved nfs4_proc_create_session declaration here]
To be returned to the mount command when trying to mount a v4 server
using minorversion 1.
Apparently a lot of people need to disable IPv6 completely on their
distributor-built systems, which have CONFIG_IPV6_MODULE enabled at
build time.
They do this by blacklisting the ipv6.ko module. This causes the
creation of the NFSv4 callback service listener to fail if
CONFIG_IPV6_MODULE is set, but the module cannot be loaded.
Now that the kernel's PF_INET6 RPC listeners are completely separate
from PF_INET listeners, we can always start PF_INET. Then the NFS
client can try to start a PF_INET6 listener, but it isn't required
to be available.
Signed-off-by: Chuck Lever <chuck.lever@oracle.com>
Let the actual delegreturn stuff be run in the state manager thread rather
than allocating a separate kthread.
We really shouldn't be resetting the sequence ids when doing state
expiration recovery, since we don't know if the server still remembers our
previous state owners. There are servers out there that do attempt to
preserve client state even if the lease has expired. Such a server would
only release that state if a conflicting OPEN request occurs.
Fix up a potential race...
It is really a more general purpose state management thread at this point.
Add a delegation cleanup phase to the state management loop, and do the
NFS4ERR_CB_PATH_DOWN recovery there.
NFSv4 defines a number of state errors which the client does not currently
handle. Among those we should worry about are:
NFS4ERR_ADMIN_REVOKED - the server's administrator revoked our locks
and/or delegations.
NFS4ERR_BAD_STATEID - the client and server are out of sync, possibly
due to a delegation return racing with an OPEN
request.
NFS4ERR_OPENMODE - the client attempted to do something not sanctioned
by the open mode of the stateid. Should normally just
occur as a result of a delegation return race.
Now that we're using the flags to indicate state that needs to be
recovered, as well as having implemented proper refcounting and spinlocking
on the state and open_owners, we can get rid of nfs_client->cl_sem. The
only remaining case that was dubious was the file locking, and that case is
now covered by the nfsi->rwsem.
The unlock path is currently failing to take the nfs_client->cl_sem read
lock, and hence the recovery path may see locks disappear from underneath
it.
Also ensure that it takes the nfs_inode->rwsem read lock so that it there
is no conflict with delegation recalls.
Instead of doing a full setclientid, try doing a RENEW call first.
If the client for some reason is not able to recover all its state within
the time allotted for the grace period, and the server reboots again, the
client is not allowed to recover the state that was 'lost' using reboot
recovery.
Ditto for nfs4_get_setclientid_cred().
nfs4_drop_state_owner() can now become static.
Signed-off-by: Adrian Bunk <bunk@kernel.org>
__FUNCTION__ is gcc-specific, use __func__
Signed-off-by: Harvey Harrison <harvey.harrison@gmail.com>
Cc: Trond Myklebust <trond.myklebust@fys.uio.no>
Cc: "J. Bruce Fields" <bfields@fieldses.org>
An audit of the current RPC timeout functions shows that they don't really
ever need to run in the softirq context. As long as the softirq is
able to signal that the wakeup is due to a timeout (which it can do by
setting task->tk_status to -ETIMEDOUT) then the callback functions can just
run as standard task->tk_callback functions (in the rpciod/process
context).
The only possible border-line case would be xprt_timer() for the case of
UDP, when the callback is used to reduce the size of the transport
congestion window. In testing, however, the effect of moving that update
to a callback would appear to be minor.
fs/nfs/nfs4state.c:788:34: warning: Using plain integer as NULL pointer
fs/nfs/delegation.c:52:34: warning: Using plain integer as NULL pointer
fs/nfs/idmap.c:312:12: warning: Using plain integer as NULL pointer
fs/nfs/callback_xdr.c:257:6: warning: Using plain integer as NULL pointer
fs/nfs/callback_xdr.c:270:6: warning: Using plain integer as NULL pointer
fs/nfs/callback_xdr.c:281:6: warning: Using plain integer as NULL pointer
The warning message for a v4 server returning various bad sequence-ids is
missing spaces.
Signed-off-by: Dan Muntz <dmuntz@netapp.com>
To ensure the NFS client displays IPv6 addresses properly, replace
address family-specific NIPQUAD() invocations with a call to the RPC
client to get a formatted string representing the remote peer's
address.
Cc: Aurelien Charbon <aurelien.charbon@ext.bull.net>
Reduce the time spent locking the rpc_sequence structure by queuing the
nfs_seqid only when we are ready to take the lock (when calling
nfs_wait_on_sequence).
Sharing the open sequence queue causes a deadlock when we try to take
both a lock sequence id and and open sequence id.
This fixes the regression reported by Dimitri Puzin and Jeff Garzik: See
http://bugzilla.kernel.org/show_bug.cgi?id=9712
for details.
Reported-and-tested-by: Dimitri Puzin <bugs@psycast.de>
Tested-by: Jeff Garzik <jgarzik@redhat.com>
Otherwise, we do end up breaking close-to-open semantics. We also end up
breaking some of the silly-rename tests in Connectathon on some setups.
Please refer to the bug-report at
http://bugzilla.linux-nfs.org/show_bug.cgi?id=150
We don't really need to clear &state->inode_states inside
nfs4_set_mode_locked, and doing so without holding the inode->i_lock would
in any case be a bug...
Consider the case where the user has mounted the remote filesystem
server:/foo on the two local directories /bar and /baz using the
nosharedcache mount option. The files /bar/file and /baz/file are
represented by different inodes in the local namespace, but refer to the
same file /foo/file on the server.
Consider the case where a process opens both /bar/file and /baz/file, then
closes /bar/file: because the nfs4_state is not shared between /bar/file
and /baz/file, the kernel will see that the nfs4_state for /bar/file is no
longer referenced, so it will send off a CLOSE rpc call. Unless the
open_owners differ, then that CLOSE call will invalidate the open state on
/baz/file too.
Conclusion: we cannot share open state owners between two different
non-shared mount instances of the same filesystem.
We really don't need to grab both the state->so_owner and the
inode->i_lock.
