path: root/fs/nfs/nfs4state.c
2014-09-30Merge branch 'bugfixes' into linux-nextTrond Myklebust
* bugfixes: NFSv4.1: Fix an NFSv4.1 state renewal regression NFSv4: fix open/lock state recovery error handling NFSv4: Fix lock recovery when CREATE_SESSION/SETCLIENTID_CONFIRM fails NFS: Fabricate fscache server index key correctly SUNRPC: Add missing support for RPC_CLNT_CREATE_NO_RETRANS_TIMEOUT nfs: fix duplicate proc entries
2014-09-28NFSv4: fix open/lock state recovery error handlingTrond Myklebust
The current open/lock state recovery unfortunately does not handle errors such as NFS4ERR_CONN_NOT_BOUND_TO_SESSION correctly. Instead of looping, just proceeds as if the state manager is finished recovering. This patch ensures that we loop back, handle higher priority errors and complete the open/lock state recovery. Cc: stable@vger.kernel.org Signed-off-by: Trond Myklebust <trond.myklebust@primarydata.com>
2014-09-28NFSv4: Fix lock recovery when CREATE_SESSION/SETCLIENTID_CONFIRM failsTrond Myklebust
If a NFSv4.x server returns NFS4ERR_STALE_CLIENTID in response to a CREATE_SESSION or SETCLIENTID_CONFIRM in order to tell us that it rebooted a second time, then the client will currently take this to mean that it must declare all locks to be stale, and hence ineligible for reboot recovery. RFC3530 and RFC5661 both suggest that the client should instead rely on the server to respond to inelegible open share, lock and delegation reclaim requests with NFS4ERR_NO_GRACE in this situation. Cc: stable@vger.kernel.org Signed-off-by: Trond Myklebust <trond.myklebust@primarydata.com>
2014-09-24Fixing lease renewalOlga Kornievskaia
Commit c9fdeb28 removed a 'continue' after checking if the lease needs to be renewed. However, if client hasn't moved, the code falls down to starting reboot recovery erroneously (ie., sends open reclaim and gets back stale_clientid error) before recovering from getting stale_clientid on the renew operation. Signed-off-by: Olga Kornievskaia <kolga@netapp.com> Fixes: c9fdeb280b8c (NFS: Add basic migration support to state manager thread) Cc: stable@vger.kernel.org # 3.13+ Signed-off-by: Trond Myklebust <trond.myklebust@primarydata.com>
2014-09-08nfs: revert "nfs4: queue free_lock_state job submission to nfsiod"Jeff Layton
This reverts commit 49a4bda22e186c4d0eb07f4a36b5b1a378f9398d. Christoph reported an oops due to the above commit: generic/089 242s ...[ 2187.041239] general protection fault: 0000 [#1] SMP [ 2187.042899] Modules linked in: [ 2187.044000] CPU: 0 PID: 11913 Comm: kworker/0:1 Not tainted 3.16.0-rc6+ #1151 [ 2187.044287] Hardware name: Bochs Bochs, BIOS Bochs 01/01/2007 [ 2187.044287] Workqueue: nfsiod free_lock_state_work [ 2187.044287] task: ffff880072b50cd0 ti: ffff88007a4ec000 task.ti: ffff88007a4ec000 [ 2187.044287] RIP: 0010:[<ffffffff81361ca6>] [<ffffffff81361ca6>] free_lock_state_work+0x16/0x30 [ 2187.044287] RSP: 0018:ffff88007a4efd58 EFLAGS: 00010296 [ 2187.044287] RAX: 6b6b6b6b6b6b6b6b RBX: ffff88007a947ac0 RCX: 8000000000000000 [ 2187.044287] RDX: ffffffff826af9e0 RSI: ffff88007b093c00 RDI: ffff88007b093db8 [ 2187.044287] RBP: ffff88007a4efd58 R08: ffffffff832d3e10 R09: 000001c40efc0000 [ 2187.044287] R10: 0000000000000000 R11: 0000000000059e30 R12: ffff88007fc13240 [ 2187.044287] R13: ffff88007fc18b00 R14: ffff88007b093db8 R15: 0000000000000000 [ 2187.044287] FS: 0000000000000000(0000) GS:ffff88007fc00000(0000) knlGS:0000000000000000 [ 2187.044287] CS: 0010 DS: 0000 ES: 0000 CR0: 000000008005003b [ 2187.044287] CR2: 00007f93ec33fb80 CR3: 0000000079dc2000 CR4: 00000000000006f0 [ 2187.044287] Stack: [ 2187.044287] ffff88007a4efdd8 ffffffff810cc877 ffffffff810cc80d ffff88007fc13258 [ 2187.044287] 000000007a947af0 0000000000000000 ffffffff8353ccc8 ffffffff82b6f3d0 [ 2187.044287] 0000000000000000 ffffffff82267679 ffff88007a4efdd8 ffff88007fc13240 [ 2187.044287] Call Trace: [ 2187.044287] [<ffffffff810cc877>] process_one_work+0x1c7/0x490 [ 2187.044287] [<ffffffff810cc80d>] ? process_one_work+0x15d/0x490 [ 2187.044287] [<ffffffff810cd569>] worker_thread+0x119/0x4f0 [ 2187.044287] [<ffffffff810fbbad>] ? trace_hardirqs_on+0xd/0x10 [ 2187.044287] [<ffffffff810cd450>] ? init_pwq+0x190/0x190 [ 2187.044287] [<ffffffff810d3c6f>] kthread+0xdf/0x100 [ 2187.044287] [<ffffffff810d3b90>] ? __init_kthread_worker+0x70/0x70 [ 2187.044287] [<ffffffff81d9873c>] ret_from_fork+0x7c/0xb0 [ 2187.044287] [<ffffffff810d3b90>] ? __init_kthread_worker+0x70/0x70 [ 2187.044287] Code: 0f 1f 44 00 00 31 c0 5d c3 66 66 66 2e 0f 1f 84 00 00 00 00 00 55 48 8d b7 48 fe ff ff 48 8b 87 58 fe ff ff 48 89 e5 48 8b 40 30 <48> 8b 00 48 8b 10 48 89 c7 48 8b 92 90 03 00 00 ff 52 28 5d c3 [ 2187.044287] RIP [<ffffffff81361ca6>] free_lock_state_work+0x16/0x30 [ 2187.044287] RSP <ffff88007a4efd58> [ 2187.103626] ---[ end trace 0f11326d28e5d8fa ]--- The original reason for this patch was because the fl_release_private operation couldn't sleep. With commit ed9814d85810 (locks: defer freeing locks in locks_delete_lock until after i_lock has been dropped), this is no longer a problem so we can revert this patch. Reported-by: Christoph Hellwig <hch@infradead.org> Signed-off-by: Jeff Layton <jlayton@primarydata.com> Reviewed-by: Christoph Hellwig <hch@lst.de> Tested-by: Christoph Hellwig <hch@lst.de> Signed-off-by: Trond Myklebust <trond.myklebust@primarydata.com>
2014-08-13Merge tag 'nfs-for-3.17-1' of git://git.linux-nfs.org/projects/trondmy/linux-nfsLinus Torvalds
Pull NFS client updates from Trond Myklebust: "Highlights include: - stable fix for a bug in nfs3_list_one_acl() - speed up NFS path walks by supporting LOOKUP_RCU - more read/write code cleanups - pNFS fixes for layout return on close - fixes for the RCU handling in the rpcsec_gss code - more NFS/RDMA fixes" * tag 'nfs-for-3.17-1' of git://git.linux-nfs.org/projects/trondmy/linux-nfs: (79 commits) nfs: reject changes to resvport and sharecache during remount NFS: Avoid infinite loop when RELEASE_LOCKOWNER getting expired error SUNRPC: remove all refcounting of groupinfo from rpcauth_lookupcred NFS: fix two problems in lookup_revalidate in RCU-walk NFS: allow lockless access to access_cache NFS: teach nfs_lookup_verify_inode to handle LOOKUP_RCU NFS: teach nfs_neg_need_reval to understand LOOKUP_RCU NFS: support RCU_WALK in nfs_permission() sunrpc/auth: allow lockless (rcu) lookup of credential cache. NFS: prepare for RCU-walk support but pushing tests later in code. NFS: nfs4_lookup_revalidate: only evaluate parent if it will be used. NFS: add checks for returned value of try_module_get() nfs: clear_request_commit while holding i_lock pnfs: add pnfs_put_lseg_async pnfs: find swapped pages on pnfs commit lists too nfs: fix comment and add warn_on for PG_INODE_REF nfs: check wait_on_bit_lock err in page_group_lock sunrpc: remove "ec" argument from encrypt_v2 operation sunrpc: clean up sparse endianness warnings in gss_krb5_wrap.c sunrpc: clean up sparse endianness warnings in gss_krb5_seal.c ...
2014-07-16sched: Remove proliferation of wait_on_bit() action functionsNeilBrown
The current "wait_on_bit" interface requires an 'action' function to be provided which does the actual waiting. There are over 20 such functions, many of them identical. Most cases can be satisfied by one of just two functions, one which uses io_schedule() and one which just uses schedule(). So: Rename wait_on_bit and wait_on_bit_lock to wait_on_bit_action and wait_on_bit_lock_action to make it explicit that they need an action function. Introduce new wait_on_bit{,_lock} and wait_on_bit{,_lock}_io which are *not* given an action function but implicitly use a standard one. The decision to error-out if a signal is pending is now made based on the 'mode' argument rather than being encoded in the action function. All instances of the old wait_on_bit and wait_on_bit_lock which can use the new version have been changed accordingly and their action functions have been discarded. wait_on_bit{_lock} does not return any specific error code in the event of a signal so the caller must check for non-zero and interpolate their own error code as appropriate. The wait_on_bit() call in __fscache_wait_on_invalidate() was ambiguous as it specified TASK_UNINTERRUPTIBLE but used fscache_wait_bit_interruptible as an action function. David Howells confirms this should be uniformly "uninterruptible" The main remaining user of wait_on_bit{,_lock}_action is NFS which needs to use a freezer-aware schedule() call. A comment in fs/gfs2/glock.c notes that having multiple 'action' functions is useful as they display differently in the 'wchan' field of 'ps'. (and /proc/$PID/wchan). As the new bit_wait{,_io} functions are tagged "__sched", they will not show up at all, but something higher in the stack. So the distinction will still be visible, only with different function names (gds2_glock_wait versus gfs2_glock_dq_wait in the gfs2/glock.c case). Since first version of this patch (against 3.15) two new action functions appeared, on in NFS and one in CIFS. CIFS also now uses an action function that makes the same freezer aware schedule call as NFS. Signed-off-by: NeilBrown <neilb@suse.de> Acked-by: David Howells <dhowells@redhat.com> (fscache, keys) Acked-by: Steven Whitehouse <swhiteho@redhat.com> (gfs2) Acked-by: Peter Zijlstra <peterz@infradead.org> Cc: Oleg Nesterov <oleg@redhat.com> Cc: Steve French <sfrench@samba.org> Cc: Linus Torvalds <torvalds@linux-foundation.org> Link: http://lkml.kernel.org/r/20140707051603.28027.72349.stgit@notabene.brown Signed-off-by: Ingo Molnar <mingo@kernel.org>
2014-07-12nfs4: queue free_lock_state job submission to nfsiodJeff Layton
We got a report of the following warning in Fedora: BUG: sleeping function called from invalid context at mm/slub.c:969 in_atomic(): 1, irqs_disabled(): 0, pid: 533, name: bash 3 locks held by bash/533: #0: (&sp->so_delegreturn_mutex){+.+...}, at: [<ffffffffa033da62>] nfs4_proc_lock+0x262/0x910 [nfsv4] #1: (&nfsi->rwsem){.+.+.+}, at: [<ffffffffa033da6a>] nfs4_proc_lock+0x26a/0x910 [nfsv4] #2: (&sb->s_type->i_lock_key#23){+.+...}, at: [<ffffffff812998dc>] flock_lock_file_wait+0x8c/0x3a0 CPU: 0 PID: 533 Comm: bash Not tainted 3.15.0-0.rc1.git1.1.fc21.x86_64 #1 Hardware name: Bochs Bochs, BIOS Bochs 01/01/2011 0000000000000000 00000000d664ff3c ffff880078b69a70 ffffffff817e82e0 0000000000000000 ffff880078b69a98 ffffffff810cf1a4 0000000000000050 0000000000000050 ffff88007cc01a00 ffff880078b69ad8 ffffffff8121449e Call Trace: [<ffffffff817e82e0>] dump_stack+0x4d/0x66 [<ffffffff810cf1a4>] __might_sleep+0x184/0x240 [<ffffffff8121449e>] kmem_cache_alloc_trace+0x4e/0x330 [<ffffffffa0331124>] ? nfs4_release_lockowner+0x74/0x110 [nfsv4] [<ffffffffa0331124>] nfs4_release_lockowner+0x74/0x110 [nfsv4] [<ffffffffa0352340>] nfs4_put_lock_state+0x90/0xb0 [nfsv4] [<ffffffffa0352375>] nfs4_fl_release_lock+0x15/0x20 [nfsv4] [<ffffffff81297515>] locks_free_lock+0x45/0x90 [<ffffffff8129996c>] flock_lock_file_wait+0x11c/0x3a0 [<ffffffffa033da6a>] ? nfs4_proc_lock+0x26a/0x910 [nfsv4] [<ffffffffa033301e>] do_vfs_lock+0x1e/0x30 [nfsv4] [<ffffffffa033da79>] nfs4_proc_lock+0x279/0x910 [nfsv4] [<ffffffff810dbb26>] ? local_clock+0x16/0x30 [<ffffffff810f5a3f>] ? lock_release_holdtime.part.28+0xf/0x200 [<ffffffffa02f820c>] do_unlk+0x8c/0xc0 [nfs] [<ffffffffa02f85c5>] nfs_flock+0xa5/0xf0 [nfs] [<ffffffff8129a6f6>] locks_remove_file+0xb6/0x1e0 [<ffffffff812159d8>] ? kfree+0xd8/0x2d0 [<ffffffff8123bc63>] __fput+0xd3/0x210 [<ffffffff8123bdee>] ____fput+0xe/0x10 [<ffffffff810bfb6d>] task_work_run+0xcd/0xf0 [<ffffffff81019cd1>] do_notify_resume+0x61/0x90 [<ffffffff817fbea2>] int_signal+0x12/0x17 The problem is that NFSv4 is trying to do an allocation from fl_release_private (in order to send a RELEASE_LOCKOWNER call). That function can be called while holding the inode->i_lock, and it's currently set up to do __GFP_WAIT allocations. v4.1 code has a similar problem. This patch adds a work_struct to the nfs4_lock_state and has the code queue the free_lock_state operation to nfsiod. Reported-by: Josh Stone <jistone@redhat.com> Signed-off-by: Jeff Layton <jlayton@poochiereds.net> Signed-off-by: Trond Myklebust <trond.myklebust@primarydata.com>
2014-07-12nfs4: treat lock owners as opaque valuesJeff Layton
Do the following set of ops with a file on a NFSv4 mount: exec 3>>/file/on/nfsv4 flock -x 3 exec 3>&- You'll see the LOCK request go across the wire, but no LOCKU when the file is closed. What happens is that the fd is passed across a fork, and the final close is done in a different process than the opener. That makes __nfs4_find_lock_state miss finding the correct lock state because it uses the fl_pid as a search key. A new one is created, and the locking code treats it as a delegation stateid (because NFS_LOCK_INITIALIZED isn't set). The root cause of this breakage seems to be commit 77041ed9b49a9e (NFSv4: Ensure the lockowners are labelled using the fl_owner and/or fl_pid). That changed it so that flock lockowners are allocated based on the fl_pid. I think this is incorrect. flock locks should be "owned" by the struct file, and that is already accounted for in the fl_owner field of the lock request when it comes through nfs_flock. This patch basically reverts the above commit and with it, a LOCKU is sent in the above reproducer. Signed-off-by: Jeff Layton <jlayton@poochiereds.net> Signed-off-by: Trond Myklebust <trond.myklebust@primarydata.com>
2014-06-10Merge tag 'nfs-for-3.16-1' of git://git.linux-nfs.org/projects/trondmy/linux-nfsLinus Torvalds
Pull NFS client updates from Trond Myklebust: "Highlights include: - massive cleanup of the NFS read/write code by Anna and Dros - support multiple NFS read/write requests per page in order to deal with non-page aligned pNFS striping. Also cleans up the r/wsize < page size code nicely. - stable fix for ensuring inode is declared uptodate only after all the attributes have been checked. - stable fix for a kernel Oops when remounting - NFS over RDMA client fixes - move the pNFS files layout driver into its own subdirectory" * tag 'nfs-for-3.16-1' of git://git.linux-nfs.org/projects/trondmy/linux-nfs: (79 commits) NFS: populate ->net in mount data when remounting pnfs: fix lockup caused by pnfs_generic_pg_test NFSv4.1: Fix typo in dprintk NFSv4.1: Comment is now wrong and redundant to code NFS: Use raw_write_seqcount_begin/end int nfs4_reclaim_open_state xprtrdma: Disconnect on registration failure xprtrdma: Remove BUG_ON() call sites xprtrdma: Avoid deadlock when credit window is reset SUNRPC: Move congestion window constants to header file xprtrdma: Reset connection timeout after successful reconnect xprtrdma: Use macros for reconnection timeout constants xprtrdma: Allocate missing pagelist xprtrdma: Remove Tavor MTU setting xprtrdma: Ensure ia->ri_id->qp is not NULL when reconnecting xprtrdma: Reduce the number of hardway buffer allocations xprtrdma: Limit work done by completion handler xprtrmda: Reduce calls to ib_poll_cq() in completion handlers xprtrmda: Reduce lock contention in completion handlers xprtrdma: Split the completion queue xprtrdma: Make rpcrdma_ep_destroy() return void ...
2014-06-05NFS: Use raw_write_seqcount_begin/end int nfs4_reclaim_open_stateTrond Myklebust
The addition of lockdep code to write_seqcount_begin/end has lead to a bunch of false positive claims of ABBA deadlocks with the so_lock spinlock. Audits show that this simply cannot happen because the read side code does not spin while holding so_lock. Cc: <stable@vger.kernel.org> # 3.13.x Signed-off-by: Trond Myklebust <trond.myklebust@primarydata.com>
2014-04-18arch: Mass conversion of smp_mb__*()Peter Zijlstra
Mostly scripted conversion of the smp_mb__* barriers. Signed-off-by: Peter Zijlstra <peterz@infradead.org> Acked-by: Paul E. McKenney <paulmck@linux.vnet.ibm.com> Link: http://lkml.kernel.org/n/tip-55dhyhocezdw1dg7u19hmh1u@git.kernel.org Cc: Linus Torvalds <torvalds@linux-foundation.org> Cc: linux-arch@vger.kernel.org Signed-off-by: Ingo Molnar <mingo@kernel.org>
2014-03-19NFSv4: Ensure we respect soft mount timeouts during trunking discoveryTrond Myklebust
Tested-by: Steve Dickson <steved@redhat.com> Signed-off-by: Trond Myklebust <trond.myklebust@primarydata.com>
2014-03-17Merge branch 'devel' into linux-nextTrond Myklebust
2014-03-05NFSv4: Fix the return value of nfs4_select_rw_stateidTrond Myklebust
In commit 5521abfdcf4d6 (NFSv4: Resend the READ/WRITE RPC call if a stateid change causes an error), we overloaded the return value of nfs4_select_rw_stateid() to cause it to return -EWOULDBLOCK if an RPC call is outstanding that would cause the NFSv4 lock or open stateid to change. That is all redundant when we actually copy the stateid used in the read/write RPC call that failed, and check that against the current stateid. It is doubly so, when we consider that in the NFSv4.1 case, we also set the stateid's seqid to the special value '0', which means 'match the current valid stateid'. Reported-by: Andy Adamson <andros@netapp.com> Link: http://lkml.kernel.org/r/1393954269-3974-1-git-send-email-andros@netapp.com Signed-off-by: Trond Myklebust <trond.myklebust@primarydata.com>
2014-02-19NFSv4: Clear the open state flags if the new stateid does not matchTrond Myklebust
RFC3530 and RFC5661 both prescribe that the 'opaque' field of the open stateid returned by new OPEN/OPEN_DOWNGRADE/CLOSE calls for the same file and open owner should match. If this is not the case, assume that the open state has been lost, and that we need to recover it. Signed-off-by: Trond Myklebust <trond.myklebust@primarydata.com>
2014-02-19NFS fix error return in nfs4_select_rw_stateidAndy Adamson
Do not return an error when nfs4_copy_delegation_stateid succeeds. Signed-off-by: Andy Adamson <andros@netapp.com> Link: http://lkml.kernel.org/r/1392737765-41942-1-git-send-email-andros@netapp.com Fixes: ef1820f9be27b (NFSv4: Don't try to recover NFSv4 locks when...) Cc: NeilBrown <neilb@suse.de> Cc: stable@vger.kernel.org # 3.12+ Signed-off-by: Trond Myklebust <trond.myklebust@primarydata.com>
2014-01-05point to the right include file in a comment (left over from a9004abc3)Toralf Förster
Signed-off-by: Toralf Förster <toralf.foerster@gmx.de> Signed-off-by: Trond Myklebust <trond.myklebust@primarydata.com>
2013-11-16Merge tag 'nfs-for-3.13-2' of git://git.linux-nfs.org/projects/trondmy/linux-nfsLinus Torvalds
Pull NFS client bugfixes: - Stable fix for data corruption when retransmitting O_DIRECT writes - Stable fix for a deep recursion/stack overflow bug in rpc_release_client - Stable fix for infinite looping when mounting a NFSv4.x volume - Fix a typo in the nfs mount option parser - Allow pNFS layouts to be compiled into the kernel when NFSv4.1 is * tag 'nfs-for-3.13-2' of git://git.linux-nfs.org/projects/trondmy/linux-nfs: nfs: fix pnfs Kconfig defaults NFS: correctly report misuse of "migration" mount option. nfs: don't retry detect_trunking with RPC_AUTH_UNIX more than once SUNRPC: Avoid deep recursion in rpc_release_client SUNRPC: Fix a data corruption issue when retransmitting RPC calls
2013-11-15tree-wide: use reinit_completion instead of INIT_COMPLETIONWolfram Sang
Use this new function to make code more comprehensible, since we are reinitialzing the completion, not initializing. [akpm@linux-foundation.org: linux-next resyncs] Signed-off-by: Wolfram Sang <wsa@the-dreams.de> Acked-by: Linus Walleij <linus.walleij@linaro.org> (personally at LCE13) Cc: Ingo Molnar <mingo@kernel.org> Signed-off-by: Andrew Morton <akpm@linux-foundation.org> Signed-off-by: Linus Torvalds <torvalds@linux-foundation.org>
2013-11-13nfs: don't retry detect_trunking with RPC_AUTH_UNIX more than onceJeff Layton
Currently, when we try to mount and get back NFS4ERR_CLID_IN_USE or NFS4ERR_WRONGSEC, we create a new rpc_clnt and then try the call again. There is no guarantee that doing so will work however, so we can end up retrying the call in an infinite loop. Worse yet, we create the new client using rpc_clone_client_set_auth, which creates the new client as a child of the old one. Thus, we can end up with a *very* long lineage of rpc_clnts. When we go to put all of the references to them, we can end up with a long call chain that can smash the stack as each rpc_free_client() call can recurse back into itself. This patch fixes this by simply ensuring that the SETCLIENTID call will only be retried in this situation if the last attempt did not use RPC_AUTH_UNIX. Note too that with this change, we don't need the (i > 2) check in the -EACCES case since we now have a more reliable test as to whether we should reattempt. Cc: stable@vger.kernel.org # v3.10+ Cc: Chuck Lever <chuck.lever@oracle.com> Tested-by/Acked-by: Weston Andros Adamson <dros@netapp.com> Signed-off-by: Jeff Layton <jlayton@redhat.com> Signed-off-by: Trond Myklebust <Trond.Myklebust@netapp.com>
2013-10-31nfs: fix inverted test for delegation in nfs4_reclaim_open_stateJeff Layton
commit 6686390bab6a0e0 (NFS: remove incorrect "Lock reclaim failed!" warning.) added a test for a delegation before checking to see if any reclaimed locks failed. The test however is backward and is only doing that check when a delegation is held instead of when one isn't. Cc: NeilBrown <neilb@suse.de> Signed-off-by: Jeff Layton <jlayton@redhat.com> Fixes: 6686390bab6a: NFS: remove incorrect "Lock reclaim failed!" warning. Cc: stable@vger.kernel.org # 3.12 Signed-off-by: Trond Myklebust <Trond.Myklebust@netapp.com>
2013-10-28NFS: Fix possible endless state recovery waitChuck Lever
In nfs4_wait_clnt_recover(), hold a reference to the clp being waited on. The state manager can reduce clp->cl_count to 1, in which case the nfs_put_client() in nfs4_run_state_manager() can free *clp before wait_on_bit() returns and allows nfs4_wait_clnt_recover() to run again. The behavior at that point is non-deterministic. If the waited-on bit still happens to be zero, wait_on_bit() will wake the waiter as expected. If the bit is set again (say, if the memory was poisoned when freed) wait_on_bit() can leave the waiter asleep. This is a narrow fix which ensures the safety of accessing *clp in nfs4_wait_clnt_recover(), but does not address the continued use of a possibly freed *clp after nfs4_wait_clnt_recover() returns (see nfs_end_delegation_return(), for example). Signed-off-by: Chuck Lever <chuck.lever@oracle.com> Signed-off-by: Trond Myklebust <Trond.Myklebust@netapp.com>
2013-10-28NFS: Handle SEQ4_STATUS_LEASE_MOVEDChuck Lever
With the advent of NFSv4 sessions in NFSv4.1 and following, a "lease moved" condition is reported differently than it is in NFSv4.0. NFSv4 minor version 0 servers return an error status code, NFS4ERR_LEASE_MOVED, to signal that a lease has moved. This error causes the whole compound operation to fail. Normal compounds against this server continue to fail until the client performs migration recovery on the migrated share. Minor version 1 and later servers assert a bit flag in the reply to a compound's SEQUENCE operation to signal LEASE_MOVED. This is not a fatal condition: operations against this server continue normally. The server asserts this flag until the client performs migration recovery on the migrated share. Note that servers MUST NOT return NFS4ERR_LEASE_MOVED to NFSv4 clients not using NFSv4.0. After the server asserts any of the sr_status_flags in the SEQUENCE operation in a typical compound, our client initiates standard lease recovery. For NFSv4.1+, a stand-alone SEQUENCE operation is performed to discover what recovery is needed. If SEQ4_STATUS_LEASE_MOVED is asserted in this stand-alone SEQUENCE operation, our client attempts to discover which FSIDs have been migrated, and then performs migration recovery on each. Signed-off-by: Chuck Lever <chuck.lever@oracle.com> Signed-off-by: Trond Myklebust <Trond.Myklebust@netapp.com>
2013-10-28NFS: Support NFS4ERR_LEASE_MOVED recovery in state managerChuck Lever
A migration on the FSID in play for the current NFS operation is reported via the error status code NFS4ERR_MOVED. "Lease moved" means that a migration has occurred on some other FSID than the one for the current operation. It's a signal that the client should take action immediately to handle a migration that it may not have noticed otherwise. This is so that the client's lease does not expire unnoticed on the destination server. In NFSv4.0, a moved lease is reported with the NFS4ERR_LEASE_MOVED error status code. To recover from NFS4ERR_LEASE_MOVED, check each FSID for that server to see if it is still present. Invoke nfs4_try_migration() if the FSID is no longer present on the server. Signed-off-by: Chuck Lever <chuck.lever@oracle.com> Signed-off-by: Trond Myklebust <Trond.Myklebust@netapp.com>
2013-10-28NFS: Add basic migration support to state manager threadChuck Lever
Migration recovery and state recovery must be serialized, so handle both in the state manager thread. Signed-off-by: Chuck Lever <chuck.lever@oracle.com> Signed-off-by: Trond Myklebust <Trond.Myklebust@netapp.com>
2013-10-28NFSv4 Remove zeroing state kern warningsAndy Adamson
As of commit 5d422301f97b821301efcdb6fc9d1a83a5c102d6 we no longer zero the state. Signed-off-by: Andy Adamson <andros@netapp.com> Signed-off-by: Trond Myklebust <Trond.Myklebust@netapp.com>
2013-09-04NFSv4: Don't try to recover NFSv4 locks when they are lost.NeilBrown
When an NFSv4 client loses contact with the server it can lose any locks that it holds. Currently when it reconnects to the server it simply tries to reclaim those locks. This might succeed even though some other client has held and released a lock in the mean time. So the first client might think the file is unchanged, but it isn't. This isn't good. If, when recovery happens, the locks cannot be claimed because some other client still holds the lock, then we get a message in the kernel logs, but the client can still write. So two clients can both think they have a lock and can both write at the same time. This is equally not good. There was a patch a while ago http://comments.gmane.org/gmane.linux.nfs/41917 which tried to address some of this, but it didn't seem to go anywhere. That patch would also send a signal to the process. That might be useful but for now this patch just causes writes to fail. For NFSv4 (unlike v2/v3) there is a strong link between the lock and the write request so we can fairly easily fail any IO of the lock is gone. While some applications might not expect this, it is still safer than allowing the write to succeed. Because this is a fairly big change in behaviour a module parameter, "recover_locks", is introduced which defaults to true (the current behaviour) but can be set to "false" to tell the client not to try to recover things that were lost. Signed-off-by: NeilBrown <neilb@suse.de> Signed-off-by: Trond Myklebust <Trond.Myklebust@netapp.com>
2013-09-04NFS: Fix warning introduced by NFSv4.0 transport blocking patchesChuck Lever
When CONFIG_NFS_V4_1 is not enabled, gcc emits this warning: linux/fs/nfs/nfs4state.c:255:12: warning: ‘nfs4_begin_drain_session’ defined but not used [-Wunused-function] static int nfs4_begin_drain_session(struct nfs_client *clp) ^ Eventually NFSv4.0 migration recovery will invoke this function, but that has not yet been merged. Hide nfs4_begin_drain_session() behind CONFIG_NFS_V4_1 for now. Signed-off-by: Chuck Lever <chuck.lever@oracle.com> Signed-off-by: Trond Myklebust <Trond.Myklebust@netapp.com>
2013-09-03NFS: Update session draining barriers for NFSv4.0 transport blockingChuck Lever
2013-09-03NFS: Enable slot table helpers for NFSv4.0Chuck Lever
I'd like to re-use NFSv4.1's slot table machinery for NFSv4.0 transport blocking. Re-organize some of nfs4session.c so the slot table code is built even when NFS_V4_1 is disabled. Signed-off-by: Chuck Lever <chuck.lever@oracle.com> Signed-off-by: Trond Myklebust <Trond.Myklebust@netapp.com>
2013-08-22NFS: remove incorrect "Lock reclaim failed!" warning.NeilBrown
After reclaiming state that was lost, the NFS client tries to reclaim any locks, and then checks that each one has NFS_LOCK_INITIALIZED set (which means that the server has confirmed the lock). However if the client holds a delegation, nfs_reclaim_locks() simply aborts (or more accurately it called nfs_lock_reclaim() and that returns without doing anything). This is because when a delegation is held, the server doesn't need to know about locks. So if a delegation is held, NFS_LOCK_INITIALIZED is not expected, and its absence is certainly not an error. So don't print the warnings if NFS_DELGATED_STATE is set. Signed-off-by: NeilBrown <neilb@suse.de> Signed-off-by: Trond Myklebust <Trond.Myklebust@netapp.com>
2013-08-07NFS: Never use user credentials for lease renewalChuck Lever
Never try to use a non-UID 0 user credential for lease management, as that credential can change out from under us. The server will block NFSv4 lease recovery with NFS4ERR_CLID_INUSE. Since the mechanism to acquire a credential for lease management is now the same for all minor versions, replace the minor version- specific callout with a single function. Signed-off-by: Chuck Lever <chuck.lever@oracle.com> Signed-off-by: Trond Myklebust <Trond.Myklebust@netapp.com>
2013-08-07NFS: Use root's credential for lease management when keytab is missingChuck Lever
Commit 05f4c350 "NFS: Discover NFSv4 server trunking when mounting" Fri Sep 14 17:24:32 2012 introduced Uniform Client String support, which forces our NFS client to establish a client ID immediately during a mount operation rather than waiting until a user wants to open a file. Normally machine credentials (eg. from a keytab) are used to perform a mount operation that is protected by Kerberos. Before 05fc350, SETCLIENTID used a machine credential, or fell back to a regular user's credential if no keytab is available. On clients that don't have a keytab, performing SETCLIENTID early means there's no user credential to fall back on, since no regular user has kinit'd yet. 05f4c350 seems to have broken the ability to mount with sec=krb5 on clients that don't have a keytab in kernels 3.7 - 3.10. To address this regression, commit 4edaa308 (NFS: Use "krb5i" to establish NFSv4 state whenever possible), Sat Mar 16 15:56:20 2013, was merged in 3.10. This commit forces the NFS client to fall back to AUTH_SYS for lease management operations if no keytab is available. Neil Brown noticed that, since root is required to kinit to do a sec=krb5 mount when a client doesn't have a keytab, we can try to use root's Kerberos credential before AUTH_SYS. Now, when determining a principal and flavor to use for lease management, the NFS client tries in this order: 1. Flavor: AUTH_GSS, krb5i Principal: service principal (via keytab) 2. Flavor: AUTH_GSS, krb5i Principal: user principal established for UID 0 (via kinit) 3. Flavor: AUTH_SYS Principal: UID 0 / GID 0 Signed-off-by: Chuck Lever <chuck.lever@oracle.com> Signed-off-by: Trond Myklebust <Trond.Myklebust@netapp.com>
2013-07-23NFS: Fix return type of nfs4_end_drain_session() stubChuck Lever
Clean up: when NFSv4.1 support is compiled out, nfs4_end_drain_session() becomes a stub. Make the synopsis of the stub match the synopsis of the real version of the function. Signed-off-by: Chuck Lever <chuck.lever@oracle.com> Signed-off-by: Trond Myklebust <Trond.Myklebust@netapp.com>
2013-07-09Merge tag 'nfs-for-3.11-1' of git://git.linux-nfs.org/projects/trondmy/linux-nfsLinus Torvalds
Pull NFS client updates from Trond Myklebust: "Feature highlights include: - Add basic client support for NFSv4.2 - Add basic client support for Labeled NFS (selinux for NFSv4.2) - Fix the use of credentials in NFSv4.1 stateful operations, and add support for NFSv4.1 state protection. Bugfix highlights: - Fix another NFSv4 open state recovery race - Fix an NFSv4.1 back channel session regression - Various rpc_pipefs races - Fix another issue with NFSv3 auth negotiation Please note that Labeled NFS does require some additional support from the security subsystem. The relevant changesets have all been reviewed and acked by James Morris." * tag 'nfs-for-3.11-1' of git://git.linux-nfs.org/projects/trondmy/linux-nfs: (54 commits) NFS: Set NFS_CS_MIGRATION for NFSv4 mounts NFSv4.1 Refactor nfs4_init_session and nfs4_init_channel_attrs nfs: have NFSv3 try server-specified auth flavors in turn nfs: have nfs_mount fake up a auth_flavs list when the server didn't provide it nfs: move server_authlist into nfs_try_mount_request nfs: refactor "need_mount" code out of nfs_try_mount SUNRPC: PipeFS MOUNT notification optimization for dying clients SUNRPC: split client creation routine into setup and registration SUNRPC: fix races on PipeFS UMOUNT notifications SUNRPC: fix races on PipeFS MOUNT notifications NFSv4.1 use pnfs_device maxcount for the objectlayout gdia_maxcount NFSv4.1 use pnfs_device maxcount for the blocklayout gdia_maxcount NFSv4.1 Fix gdia_maxcount calculation to fit in ca_maxresponsesize NFS: Improve legacy idmapping fallback NFSv4.1 end back channel session draining NFS: Apply v4.1 capabilities to v4.2 NFSv4.1: Clean up layout segment comparison helper names NFSv4.1: layout segment comparison helpers should take 'const' parameters NFSv4: Move the DNS resolver into the NFSv4 module rpc_pipefs: only set rpc_dentry_ops if d_op isn't already set ...
2013-07-03drivers: avoid parsing names as kthread_run() format stringsKees Cook
Calling kthread_run with a single name parameter causes it to be handled as a format string. Many callers are passing potentially dynamic string content, so use "%s" in those cases to avoid any potential accidents. Signed-off-by: Kees Cook <keescook@chromium.org> Signed-off-by: Andrew Morton <akpm@linux-foundation.org> Signed-off-by: Linus Torvalds <torvalds@linux-foundation.org>
2013-06-29locks: protect most of the file_lock handling with i_lockJeff Layton
Having a global lock that protects all of this code is a clear scalability problem. Instead of doing that, move most of the code to be protected by the i_lock instead. The exceptions are the global lists that the ->fl_link sits on, and the ->fl_block list. ->fl_link is what connects these structures to the global lists, so we must ensure that we hold those locks when iterating over or updating these lists. Furthermore, sound deadlock detection requires that we hold the blocked_list state steady while checking for loops. We also must ensure that the search and update to the list are atomic. For the checking and insertion side of the blocked_list, push the acquisition of the global lock into __posix_lock_file and ensure that checking and update of the blocked_list is done without dropping the lock in between. On the removal side, when waking up blocked lock waiters, take the global lock before walking the blocked list and dequeue the waiters from the global list prior to removal from the fl_block list. With this, deadlock detection should be race free while we minimize excessive file_lock_lock thrashing. Finally, in order to avoid a lock inversion problem when handling /proc/locks output we must ensure that manipulations of the fl_block list are also protected by the file_lock_lock. Signed-off-by: Jeff Layton <jlayton@redhat.com> Signed-off-by: Al Viro <viro@zeniv.linux.org.uk>
2013-06-20NFSv4.1 end back channel session drainingAndy Adamson
We need to ensure that we clear NFS4_SLOT_TBL_DRAINING on the back channel when we're done recovering the session. Regression introduced by commit 774d5f14e (NFSv4.1 Fix a pNFS session draining deadlock) Signed-off-by: Andy Adamson <andros@netapp.com> [Trond: Changed order to start back-channel first. Minor code cleanup] Signed-off-by: Trond Myklebust <Trond.Myklebust@netapp.com> Cc: stable@vger.kernel.org [>=3.10]
2013-06-06NFSv4.1: Ensure that reclaim_complete uses the right credentialTrond Myklebust
We want to use the same credential for reclaim_complete as we used for the exchange_id call. Signed-off-by: Trond Myklebust <Trond.Myklebust@netapp.com>
2013-05-20NFSv4.1 Fix a pNFS session draining deadlockAndy Adamson
On a CB_RECALL the callback service thread flushes the inode using filemap_flush prior to scheduling the state manager thread to return the delegation. When pNFS is used and I/O has not yet gone to the data server servicing the inode, a LAYOUTGET can preceed the I/O. Unlike the async filemap_flush call, the LAYOUTGET must proceed to completion. If the state manager starts to recover data while the inode flush is sending the LAYOUTGET, a deadlock occurs as the callback service thread holds the single callback session slot until the flushing is done which blocks the state manager thread, and the state manager thread has set the session draining bit which puts the inode flush LAYOUTGET RPC to sleep on the forechannel slot table waitq. Separate the draining of the back channel from the draining of the fore channel by moving the NFS4_SESSION_DRAINING bit from session scope into the fore and back slot tables. Drain the back channel first allowing the LAYOUTGET call to proceed (and fail) so the callback service thread frees the callback slot. Then proceed with draining the forechannel. Signed-off-by: Andy Adamson <andros@netapp.com> Signed-off-by: Trond Myklebust <Trond.Myklebust@netapp.com>
2013-05-06NFSv4.1: Ensure that we free the lock stateid on the serverTrond Myklebust
This ensures that the server doesn't need to keep huge numbers of lock stateids waiting around for the final CLOSE. See section 8.2.4 in RFC5661. Signed-off-by: Trond Myklebust <Trond.Myklebust@netapp.com>
2013-04-23Merge branch 'bugfixes' into linux-nextTrond Myklebust
Fix up a conflict between the linux-next branch and mainline. Conflicts: fs/nfs/nfs4proc.c
2013-04-23Merge branch 'rpcsec_gss-from_cel' into linux-nextTrond Myklebust
* rpcsec_gss-from_cel: (21 commits) NFS: Retry SETCLIENTID with AUTH_SYS instead of AUTH_NONE NFSv4: Don't clear the machine cred when client establish returns EACCES NFSv4: Fix issues in nfs4_discover_server_trunking NFSv4: Fix the fallback to AUTH_NULL if krb5i is not available NFS: Use server-recommended security flavor by default (NFSv3) SUNRPC: Don't recognize RPC_AUTH_MAXFLAVOR NFS: Use "krb5i" to establish NFSv4 state whenever possible NFS: Try AUTH_UNIX when PUTROOTFH gets NFS4ERR_WRONGSEC NFS: Use static list of security flavors during root FH lookup recovery NFS: Avoid PUTROOTFH when managing leases NFS: Clean up nfs4_proc_get_rootfh NFS: Handle missing rpc.gssd when looking up root FH SUNRPC: Remove EXPORT_SYMBOL_GPL() from GSS mech switch SUNRPC: Make gss_mech_get() static SUNRPC: Refactor nfsd4_do_encode_secinfo() SUNRPC: Consider qop when looking up pseudoflavors SUNRPC: Load GSS kernel module by OID SUNRPC: Introduce rpcauth_get_pseudoflavor() SUNRPC: Define rpcsec_gss_info structure NFS: Remove unneeded forward declaration ...
2013-04-22NFS: Retry SETCLIENTID with AUTH_SYS instead of AUTH_NONEChuck Lever
Recently I changed the SETCLIENTID code to use AUTH_GSS(krb5i), and then retry with AUTH_NONE if that didn't work. This was to enable Kerberos NFS mounts to work without forcing Linux NFS clients to have a keytab on hand. Rick Macklem reports that the FreeBSD server accepts AUTH_NONE only for NULL operations (thus certainly not for SETCLIENTID). Falling back to AUTH_NONE means our proposed 3.10 NFS client will not interoperate with FreeBSD servers over NFSv4 unless Kerberos is fully configured on both ends. If the Linux client falls back to using AUTH_SYS instead for SETCLIENTID, all should work fine as long as the NFS server is configured to allow AUTH_SYS for SETCLIENTID. This may still prevent access to Kerberos-only FreeBSD servers by Linux clients with no keytab. Rick is of the opinion that the security settings the server applies to its pseudo-fs should also apply to the SETCLIENTID operation. Linux and Solaris NFS servers do not place that limitation on SETCLIENTID. The security settings for the server's pseudo-fs are determined automatically as the union of security flavors allowed on real exports, as recommended by RFC 3530bis; and the flavors allowed for SETCLIENTID are all flavors supported by the respective server implementation. Signed-off-by: Chuck Lever <chuck.lever@oracle.com> Signed-off-by: Trond Myklebust <Trond.Myklebust@netapp.com>
2013-04-20NFSv4: Use the open stateid if the delegation has the wrong modeTrond Myklebust
Fix nfs4_select_rw_stateid() so that it chooses the open stateid (or an all-zero stateid) if the delegation does not match the selected read/write mode. Signed-off-by: Trond Myklebust <Trond.Myklebust@netapp.com>
2013-04-08NFSv4: Handle timeouts correctly when probing for lease validityTrond Myklebust
When we send a RENEW or SEQUENCE operation in order to probe if the lease is still valid, we want it to be able to time out since the lease we are probing is likely to time out too. Currently, because we use soft mount semantics for these RPC calls, the return value is EIO, which causes the state manager to exit with an "unhandled error" message. This patch changes the call semantics, so that the RPC layer returns ETIMEDOUT instead of EIO. We then have the state manager default to a simple retry instead of exiting. Signed-off-by: Trond Myklebust <Trond.Myklebust@netapp.com>
2013-04-05NFSv4: Fix a memory leak in nfs4_discover_server_trunkingTrond Myklebust
When we assign a new rpc_client to clp->cl_rpcclient, we need to destroy the old one. Signed-off-by: Trond Myklebust <Trond.Myklebust@netapp.com> Cc: Chuck Lever <chuck.lever@oracle.com> Cc: stable@vger.kernel.org [>=3.7]
2013-04-05NFSv4: Don't clear the machine cred when client establish returns EACCESTrond Myklebust
The expected behaviour is that the client will decide at mount time whether or not to use a krb5i machine cred, or AUTH_NULL. Signed-off-by: Trond Myklebust <Trond.Myklebust@netapp.com> Cc: Chuck Lever <chuck.lever@oracle.com> Cc: Bryan Schumaker <bjschuma@netapp.com>
2013-04-05NFSv4: Fix issues in nfs4_discover_server_trunkingTrond Myklebust
- Ensure that we exit with ENOENT if the call to ops->get_clid_cred() fails. - Handle the case where ops->detect_trunking() exits with an unexpected error, and return EIO. Signed-off-by: Trond Myklebust <Trond.Myklebust@netapp.com>
