path: root/fs/nfs/proc.c
2006-01-06NFS: Send valid mode bits to the serverTrond Myklebust
inode->i_mode contains a lot more than just the mode bits. Make sure that we mask away this extra stuff in SETATTR calls to the server. Signed-off-by: Trond Myklebust <Trond.Myklebust@netapp.com>
2006-01-06RPC: Clean up RPC task structureTrond Myklebust
Shrink the RPC task structure. Instead of storing separate pointers for task->tk_exit and task->tk_release, put them in a structure. Also pass the user data pointer as a parameter instead of passing it via task->tk_calldata. This enables us to nest callbacks. Signed-off-by: Trond Myklebust <Trond.Myklebust@netapp.com>
2005-12-03NFS: Fix post-op attribute revalidation...Trond Myklebust
- Missing nfs_mark_for_revalidate in nfs_proc_link() - Missing nfs_mark_for_revalidate in nfs_rename() Signed-off-by: Trond Myklebust <Trond.Myklebust@netapp.com>
2005-10-27NFS: Don't let nfs_end_data_update() clobber attribute update informationTrond Myklebust
Since we almost always call nfs_end_data_update() after we called nfs_refresh_inode(), we now end up marking the inode metadata as needing revalidation immediately after having updated it. This patch rearranges things so that we mark the inode as needing revalidation _before_ we call nfs_refresh_inode() on those operations that need it. Signed-off-by: Trond Myklebust <Trond.Myklebust@netapp.com>
2005-10-27NFS: Cleanup initialisation of struct nfs_fattrTrond Myklebust
2005-10-18NFSv4: Eliminate nfsv4 open race...Trond Myklebust
Make NFSv4 return the fully initialized file pointer with the stateid that it created in the lookup w/intent. Signed-off-by: Trond Myklebust <Trond.Myklebust@netapp.com>
2005-08-16[PATCH] NFS: Ensure we always update inode->i_mode when doing O_EXCL createsTrond Myklebust
When the client performs an exclusive create and opens the file for writing, a Netapp filer will first create the file using the mode 01777. It does this since an NFSv3/v4 exclusive create cannot immediately set the mode bits. The 01777 mode then gets put into the inode->i_mode. After the file creation is successful, we then do a setattr to change the mode to the correct value (as per the NFS spec). The problem is that nfs_refresh_inode() no longer updates inode->i_mode, so the latter retains the 01777 mode. A bit later, the VFS notices this, and calls remove_suid(). This of course now resets the file mode to inode->i_mode & 0777. Hey presto, the file mode on the server is now magically changed to 0777. Duh... Fixes http://bugzilla.linux-nfs.org/show_bug.cgi?id=32 Signed-off-by: Trond Myklebust <Trond.Myklebust@netapp.com> Signed-off-by: Linus Torvalds <torvalds@osdl.org>
2005-06-22[PATCH] NFS: Allow NFS versions to support different sets of inode operations.J. Bruce Fields
ACL support will require supporting additional inode operations in v4 (getxattr, setxattr, listxattr). This patch allows different protocol versions to support different inode operations by adding a file_inode_ops to the nfs_rpc_ops (to match the existing dir_inode_ops). Signed-off-by: J. Bruce Fields <bfields@citi.umich.edu> Signed-off-by: Trond Myklebust <Trond.Myklebust@netapp.com>
