path: root/fs/nfs/proc.c
2009-09-23headers: utsname.h reduxAlexey Dobriyan
* remove asm/atomic.h inclusion from linux/utsname.h -- not needed after kref conversion * remove linux/utsname.h inclusion from files which do not need it NOTE: it looks like fs/binfmt_elf.c do not need utsname.h, however due to some personality stuff it _is_ needed -- cowardly leave ELF-related headers and files alone. Signed-off-by: Alexey Dobriyan <adobriyan@gmail.com> Signed-off-by: Linus Torvalds <torvalds@linux-foundation.org>
2009-03-19NFS: Optimise NFS close()Trond Myklebust
Close-to-open cache consistency rules really only require us to flush out writes on calls to close(), and require us to revalidate attributes on the very last close of the file. Currently we appear to be doing a lot of extra attribute revalidation and cache flushes. Signed-off-by: Trond Myklebust <Trond.Myklebust@netapp.com>
2008-10-07nfs: authenticated deep mountingEG Keizer
Allow mount to do authenticated mounts below the root of the exported tree. The wording in RFC 2623, sec 2.3.2. allows fsinfo with UNIX authentication on the root of the export. Mounts are not always done on the root of the exported tree. Especially autoumounts often mount below the root of the exported tree. Some server implementations (justly) require full authentication for the so-called deep mounts. The old code used AUTH_SYS only. This caused deep mounts to fail on systems requiring stronger authentication.. The client should try both authentication types and use the first one that succeeds. This method was already partially implemented. This patch completes the implementation for NFS2 and NFS3. This patch was developed to allow Debian systems to automount home directories on Solaris servers with krb5 authentication. Tested on kernel 2.6.24-etchnhalf.1 Signed-off-by: E.G. Keizer <keie@few.vu.nl> Signed-off-by: J. Bruce Fields <bfields@citi.umich.edu> Signed-off-by: Trond Myklebust <Trond.Myklebust@netapp.com>
2008-07-09NFS: Remove the redundant file_open entry from struct nfs_rpc_opsTrond Myklebust
All instances are set to nfs_open(), so we should just remove the redundant indirection. Ditto for the file_release op Signed-off-by: Trond Myklebust <Trond.Myklebust@netapp.com>
2008-07-09NFS: Fix the ftruncate() credential problemTrond Myklebust
ftruncate() access checking is supposed to be performed at open() time, just like reads and writes. Signed-off-by: Trond Myklebust <Trond.Myklebust@netapp.com>
2008-07-09NFS: Add correct bounds checking to NFSv2 locksTrond Myklebust
NFSv2 file locking currently fails the Connectathon tests, because the calls to the VFS locking code do not return an EINVAL error if the struct file_lock overflows the 32-bit boundaries. The problem is due to the fact that we occasionally call helpers from fs/locks.c in order to avoid RPC calls to the server when we know that a local process holds the lock. These helpers are, of course, always 64-bit enabled, so EINVAL is not returned in cases when it would if the call had gone to the NLM code. For consistency, we therefore add support for a bounds-checking helper. Signed-off-by: Trond Myklebust <Trond.Myklebust@netapp.com>
2008-05-16nfs: replace remaining __FUNCTION__ occurrencesHarvey Harrison
__FUNCTION__ is gcc-specific, use __func__ Signed-off-by: Harvey Harrison <harvey.harrison@gmail.com> Cc: Trond Myklebust <trond.myklebust@fys.uio.no> Cc: "J. Bruce Fields" <bfields@fieldses.org> Signed-off-by: Andrew Morton <akpm@linux-foundation.org> Signed-off-by: Trond Myklebust <Trond.Myklebust@netapp.com>
2008-01-30NLM/NFS: Use cached nlm_host when calling nlmclnt_proc()Chuck Lever
Now that each NFS mount point caches its own nlm_host structure, it can be passed to nlmclnt_proc() for each lock request. By pinning an nlm_host for each mount point, we trade the overhead of looking up or creating a fresh nlm_host struct during every NLM procedure call for a little extra memory. We also restrict the nlmclnt_proc symbol to limit the use of this call to in-tree modules. Note that nlm_lookup_host() (just removed from the client's per-request NLM processing) could also trigger an nlm_host garbage collection. Now client-side nlm_host garbage collection occurs only during NFS mount processing. Since the NFS client now holds a reference on these nlm_host structures, they wouldn't have been affected by garbage collection anyway. Given that nlm_lookup_host() reorders the global nlm_host chain after every successful lookup, and that a garbage collection could be triggered during the call, we've removed a significant amount of per-NLM-request CPU processing overhead. Sidebar: there are only a few remaining references to the internals of NFS inodes in the client-side NLM code. The only references I found are related to extracting or comparing the inode's file handle via NFS_FH(). One is in nlmclnt_grant(); the other is in nlmclnt_setlockargs(). Signed-off-by: Chuck Lever <chuck.lever@oracle.com> Signed-off-by: Trond Myklebust <Trond.Myklebust@netapp.com>
2008-01-30NFS: Clean up the (commit|read|write)_setup() callback routinesTrond Myklebust
Move the common code for setting up the nfs_write_data and nfs_read_data structures into fs/nfs/read.c, fs/nfs/write.c and fs/nfs/direct.c. Signed-off-by: Trond Myklebust <Trond.Myklebust@netapp.com>
2007-10-21NFSv2: Ensure that the directory metadata gets revalidated on file createTrond Myklebust
2007-10-09NFS: Fake up 'wcc' attributes to prevent cache invalidation after writeTrond Myklebust
NFSv2 and v4 don't offer weak cache consistency attributes on WRITE calls. In NFSv3, returning wcc data is optional. In all cases, we want to prevent the client from invalidating our cached data whenever ->write_done() attempts to update the inode attributes. Signed-off-by: Trond Myklebust <Trond.Myklebust@netapp.com>
2007-10-09NFS: Fix atime revalidation in read()Trond Myklebust
NFSv3 will correctly update atime on a read() call, so there is no need to set the NFS_INO_INVALID_ATIME flag unless the call to nfs_refresh_inode() fails. Signed-off-by: Trond Myklebust <Trond.Myklebust@netapp.com>
2007-10-09NFS: Fix atime revalidation in readdir()Trond Myklebust
NFSv3 will correctly update atime on a readdir call, so there is no need to set the NFS_INO_INVALID_ATIME flag unless the call to nfs_refresh_inode() fails. Signed-off-by: Trond Myklebust <Trond.Myklebust@netapp.com>
2007-07-19SUNRPC: Clean up the sillyrename codeTrond Myklebust
Fix a couple of bugs: - Don't rely on the parent dentry still being valid when the call completes. Fixes a race with shrink_dcache_for_umount_subtree() - Don't remove the file if the filehandle has been labelled as stale. Fix a couple of inefficiencies - Remove the global list of sillyrenamed files. Instead we can cache the sillyrename information in the dentry->d_fsdata - Move common code from unlink_setup/unlink_done into fs/nfs/unlink.c Signed-off-by: Trond Myklebust <Trond.Myklebust@netapp.com>
2007-07-19NFS: Introduce struct nfs_removeargs+nfs_removeresTrond Myklebust
We need a common structure for setting up an unlink() rpc call in order to fix the asynchronous unlink code. Signed-off-by: Trond Myklebust <Trond.Myklebust@netapp.com>
2007-02-03NFS: Remove nfs_readpage_sync()Trond Myklebust
It makes no sense to maintain 2 parallel systems for reading in pages. Signed-off-by: Trond Myklebust <Trond.Myklebust@netapp.com>
2006-12-08[PATCH] nfs: change uses of f_{dentry,vfsmnt} to use f_pathJosef "Jeff" Sipek
Change all the uses of f_{dentry,vfsmnt} to f_path.{dentry,mnt} in the nfs client code. Signed-off-by: Josef "Jeff" Sipek <jsipek@cs.sunysb.edu> Signed-off-by: Andrew Morton <akpm@osdl.org> Signed-off-by: Linus Torvalds <torvalds@osdl.org>
2006-12-06NFS: Remove nfs_writepage_sync()Trond Myklebust
Maintaining two parallel ways of doing synchronous writes is rather pointless. This patch gets rid of the legacy nfs_writepage_sync(), and replaces it with the faster asynchronous writes. Signed-off-by: Trond Myklebust <Trond.Myklebust@netapp.com>
2006-12-06NFS: Remove use of the Big Kernel Lock around calls to rpc_call_syncFrank Filz
Remove use of the Big Kernel Lock around calls to rpc_call_sync. Signed-off-by: Frank Filz <ffilz@us.ibm.com> Signed-off-by: Trond Myklebust <Trond.Myklebust@netapp.com>
2006-09-27[PATCH] fs: Removing useless castsPanagiotis Issaris
* Removing useless casts * Removing useless wrapper * Conversion from kmalloc+memset to kzalloc Signed-off-by: Panagiotis Issaris <takis@issaris.org> Acked-by: Dave Kleikamp <shaggy@austin.ibm.com> Signed-off-by: Andrew Morton <akpm@osdl.org> Signed-off-by: Linus Torvalds <torvalds@osdl.org>
2006-09-22NFS: Use cached page as buffer for NFS symlink requestsChuck Lever
Now that we have a copy of the symlink path in the page cache, we can pass a struct page down to the XDR routines instead of a string buffer. Test plan: Connectathon, all NFS versions. Signed-off-by: Chuck Lever <chuck.lever@oracle.com> Signed-off-by: Trond Myklebust <Trond.Myklebust@netapp.com>
2006-09-22NFS: Fix double d_drop in nfs_instantiate() error pathChuck Lever
If the LOOKUP or GETATTR in nfs_instantiate fail, nfs_instantiate will do a d_drop before returning. But some callers already do a d_drop in the case of an error return. Make certain we do only one d_drop in all error paths. This issue was introduced because over time, the symlink proc API diverged slightly from the create/mkdir/mknod proc API. To prevent other coding mistakes of this type, change the symlink proc API to be more like create/mkdir/mknod and move the nfs_instantiate call into the symlink proc routines so it is used in exactly the same way for create, mkdir, mknod, and symlink. Test plan: Connectathon, all versions of NFS. Signed-off-by: Chuck Lever <chuck.lever@oracle.com> Signed-off-by: Trond Myklebust <Trond.Myklebust@netapp.com>
2006-09-22NFS: Eliminate client_sys in favour of cl_rpcclientDavid Howells
Eliminate nfs_server::client_sys in favour of nfs_client::cl_rpcclient as we only really need one per server that we're talking to since it doesn't have any security on it. The retransmission management variables are also moved to the common struct as they're required to set up the cl_rpcclient connection. The NFS2/3 client and client_acl connections are thenceforth derived by cloning the cl_rpcclient connection and post-applying the authorisation flavour. The code for setting up the initial common connection has been moved to client.c as nfs_create_rpc_client(). All the NFS program definition tables are also moved there as that's where they're now required rather than super.c. Signed-Off-By: David Howells <dhowells@redhat.com> Signed-off-by: Trond Myklebust <Trond.Myklebust@netapp.com>
2006-09-22NFS: Add extra const qualifiersDavid Howells
Add some extra const qualifiers into NFS. Signed-Off-By: David Howells <dhowells@redhat.com> Signed-off-by: Trond Myklebust <Trond.Myklebust@netapp.com>
2006-06-09NFS: Split fs/nfs/inode.cDavid Howells
As fs/nfs/inode.c is rather large, heterogenous and unwieldy, the attached patch splits it up into a number of files: (*) fs/nfs/inode.c Strictly inode specific functions. (*) fs/nfs/super.c Superblock management functions for NFS and NFS4, normal access, clones and referrals. The NFS4 superblock functions _could_ move out into a separate conditionally compiled file, but it's probably not worth it as there're so many common bits. (*) fs/nfs/namespace.c Some namespace-specific functions have been moved here. (*) fs/nfs/nfs4namespace.c NFS4-specific namespace functions (this could be merged into the previous file). This file is conditionally compiled. (*) fs/nfs/internal.h Inter-file declarations, plus a few simple utility functions moved from fs/nfs/inode.c. Additionally, all the in-.c-file externs have been moved here, and those files they were moved from now includes this file. For the most part, the functions have not been changed, only some multiplexor functions have changed significantly. I've also: (*) Added some extra banner comments above some functions. (*) Rearranged the function order within the files to be more logical and better grouped (IMO), though someone may prefer a different order. (*) Reduced the number of #ifdefs in .c files. (*) Added missing __init and __exit directives. Signed-Off-By: David Howells <dhowells@redhat.com>
2006-03-20NFS: Cleanup of NFS read codeTrond Myklebust
Same callback hierarchy inversion as for the NFS write calls. This patch is not strictly speaking needed by the O_DIRECT code, but avoids confusing differences between the asynchronous read and write code. Signed-off-by: Trond Myklebust <Trond.Myklebust@netapp.com>
2006-03-20NFS: Cleanup of NFS write code in preparation for asynchronous o_directTrond Myklebust
This patch inverts the callback hierarchy for NFS write calls. Instead of having the NFSv2/v3/v4-specific code set up the RPC callback ops, we allow the original caller to do so. This allows for more flexibility w.r.t. how to set up and tear down the nfs_write_data structure while still allowing the NFSv3/v4 code to perform error handling. The greater flexibility is needed by the asynchronous O_DIRECT code, which wants to be able to hold on to the original nfs_write_data structures after the WRITE RPC call has completed in order to be able to replay them if the COMMIT call determines that the server has rebooted. Signed-off-by: Trond Myklebust <Trond.Myklebust@netapp.com>
2006-03-20SUNRPC: eliminate rpc_call()Chuck Lever
Clean-up: replace rpc_call() helper with direct call to rpc_call_sync. This makes NFSv2 and NFSv3 synchronous calls more computationally efficient, and reduces stack consumption in functions that used to invoke rpc_call more than once. Test plan: Compile kernel with CONFIG_NFS enabled. Connectathon on NFS version 2, version 3, and version 4 mount points. Signed-off-by: Chuck Lever <cel@netapp.com> Signed-off-by: Trond Myklebust <Trond.Myklebust@netapp.com>
2006-01-06NFS: Send valid mode bits to the serverTrond Myklebust
inode->i_mode contains a lot more than just the mode bits. Make sure that we mask away this extra stuff in SETATTR calls to the server. Signed-off-by: Trond Myklebust <Trond.Myklebust@netapp.com>
2006-01-06RPC: Clean up RPC task structureTrond Myklebust
Shrink the RPC task structure. Instead of storing separate pointers for task->tk_exit and task->tk_release, put them in a structure. Also pass the user data pointer as a parameter instead of passing it via task->tk_calldata. This enables us to nest callbacks. Signed-off-by: Trond Myklebust <Trond.Myklebust@netapp.com>
2005-12-03NFS: Fix post-op attribute revalidation...Trond Myklebust
- Missing nfs_mark_for_revalidate in nfs_proc_link() - Missing nfs_mark_for_revalidate in nfs_rename() Signed-off-by: Trond Myklebust <Trond.Myklebust@netapp.com>
2005-10-27NFS: Don't let nfs_end_data_update() clobber attribute update informationTrond Myklebust
Since we almost always call nfs_end_data_update() after we called nfs_refresh_inode(), we now end up marking the inode metadata as needing revalidation immediately after having updated it. This patch rearranges things so that we mark the inode as needing revalidation _before_ we call nfs_refresh_inode() on those operations that need it. Signed-off-by: Trond Myklebust <Trond.Myklebust@netapp.com>
2005-10-27NFS: Cleanup initialisation of struct nfs_fattrTrond Myklebust
2005-10-18NFSv4: Eliminate nfsv4 open race...Trond Myklebust
Make NFSv4 return the fully initialized file pointer with the stateid that it created in the lookup w/intent. Signed-off-by: Trond Myklebust <Trond.Myklebust@netapp.com>
2005-08-16[PATCH] NFS: Ensure we always update inode->i_mode when doing O_EXCL createsTrond Myklebust
When the client performs an exclusive create and opens the file for writing, a Netapp filer will first create the file using the mode 01777. It does this since an NFSv3/v4 exclusive create cannot immediately set the mode bits. The 01777 mode then gets put into the inode->i_mode. After the file creation is successful, we then do a setattr to change the mode to the correct value (as per the NFS spec). The problem is that nfs_refresh_inode() no longer updates inode->i_mode, so the latter retains the 01777 mode. A bit later, the VFS notices this, and calls remove_suid(). This of course now resets the file mode to inode->i_mode & 0777. Hey presto, the file mode on the server is now magically changed to 0777. Duh... Fixes http://bugzilla.linux-nfs.org/show_bug.cgi?id=32 Signed-off-by: Trond Myklebust <Trond.Myklebust@netapp.com> Signed-off-by: Linus Torvalds <torvalds@osdl.org>
2005-06-22[PATCH] NFS: Allow NFS versions to support different sets of inode operations.J. Bruce Fields
ACL support will require supporting additional inode operations in v4 (getxattr, setxattr, listxattr). This patch allows different protocol versions to support different inode operations by adding a file_inode_ops to the nfs_rpc_ops (to match the existing dir_inode_ops). Signed-off-by: J. Bruce Fields <bfields@citi.umich.edu> Signed-off-by: Trond Myklebust <Trond.Myklebust@netapp.com>
