commit 63513232f8cd219dcaa5eafae028740ed3067d83 upstream.
Since rpc_task is async, the release function should be called which
will free the impl_id, scope, and owner.
Trond pointed at 2 more problems:
-- use of client pointer after free in the nfs4_exchangeid_release() function
-- cl_count mismatch if rpc_run_task() isn't run
Fixes: 8d89bd70bc9 ("NFS setup async exchange_id")
Signed-off-by: Olga Kornievskaia <kolga@netapp.com>
Signed-off-by: Anna Schumaker <Anna.Schumaker@Netapp.com>
commit 93faccbbfa958a9668d3ab4e30f38dd205cee8d8 upstream.
To support unprivileged users mounting filesystems two permission
checks have to be performed: a test to see if the user allowed to
create a mount in the mount namespace, and a test to see if
the user is allowed to access the specified filesystem.
The automount case is special in that mounting the original filesystem
grants permission to mount the sub-filesystems, to any user who
happens to stumble across the their mountpoint and satisfies the
ordinary filesystem permission checks.
Attempting to handle the automount case by using override_creds
almost works. It preserves the idea that permission to mount
the original filesystem is permission to mount the sub-filesystem.
Unfortunately using override_creds messes up the filesystems
ordinary permission checks.
Solve this by being explicit that a mount is a submount by introducing
vfs_submount, and using it where appropriate.
vfs_submount uses a new mount internal mount flags MS_SUBMOUNT, to let
sget and friends know that a mount is a submount so they can take appropriate
action.
sget and sget_userns are modified to not perform any permission checks
on submounts.
follow_automount is modified to stop using override_creds as that
has proven problemantic.
do_mount is modified to always remove the new MS_SUBMOUNT flag so
that we know userspace will never by able to specify it.
autofs4 is modified to stop using current_real_cred that was put in
there to handle the previous version of submount permission checking.
cifs is modified to pass the mountpoint all of the way down to vfs_submount.
debugfs is modified to pass the mountpoint all of the way down to
trace_automount by adding a new parameter. To make this change easier
a new typedef debugfs_automount_t is introduced to capture the type of
the debugfs automount function.
Fixes: 069d5ac9ae0d ("autofs: Fix automounts by using current_real_cred()->uid")
Fixes: aeaa4a79ff6a ("fs: Call d_automount with the filesystems creds")
Reviewed-by: Trond Myklebust <trond.myklebust@primarydata.com>
Reviewed-by: Seth Forshee <seth.forshee@canonical.com>
commit ed92d8c137b7794c2c2aa14479298b9885967607 upstream.
We're not taking into account that the space needed for the (variable
length) attr bitmap, with the result that we'd sometimes get a spurious
ERANGE when the ACL data got close to the end of a page.
Just add in an extra page to make sure.
Signed-off-by: Weston Andros Adamson <dros@primarydata.com>
Signed-off-by: J. Bruce Fields <bfields@redhat.com>
commit 6682c14bbe505a8b912c57faf544f866777ee48d upstream.
Bitmap and attrlen follow immediately after the op reply header. This
was an oversight from commit bf118a342f.
Consequences of this are just minor efficiency (extra calls to
xdr_shrink_bufhead).
Fixes: bf118a342f10 "NFSv4: include bitmap in nfsv4 get acl data"
Reviewed-by: Kinglong Mee <kinglongmee@gmail.com>
commit df3ab232e462bce20710596d697ade6b72497694 upstream.
If we see that our pNFS READ/WRITE/COMMIT operation failed, but we
also see that our layout segment is no longer valid, then we need to
get a new layout segment before retrying.
Fixes: 90816d1ddacf ("NFSv4.1/flexfiles: Don't mark the entire deviceid...")
Signed-off-by: Trond Myklebust <trond.myklebust@primarydata.com>
commit 9d8cacbf5636657d2cd0dda17438a56d806d3224 upstream.
Copy offload code needs to be hooked into the code for handling
NFS4ERR_BAD_STATEID by ensuring that we set the "stateid" field
in struct nfs4_exception.
Reported-by: Olga Kornievskaia <aglo@umich.edu>
Fixes: 2e72448b07dc3 ("NFS: Add COPY nfs operation")
commit a974deee477af89411e0f80456bfb344ac433c98 upstream.
If we exit because the file access check failed, we currently
leak the struct nfs4_state. We need to attach it to the
open context before returning.
Fixes: 3efb9722475e ("NFSv4: Refactor _nfs4_open_and_get_state..")
commit a430607b2ef7c3be090f88c71cfcb1b3988aa7c0 upstream.
Some nfsv4.0 servers may return a mode for the verifier following an open
with EXCLUSIVE4 createmode, but this does not mean the client should skip
setting the mode in the following SETATTR. It should only do that for
EXCLUSIVE4_1 or UNGAURDED createmode.
Fixes: 5334c5bdac92 ("NFS: Send attributes in OPEN request for NFS4_CREATE_EXCLUSIVE4_1")
Signed-off-by: Benjamin Coddington <bcodding@redhat.com>
commit 8ac092519ad91931c96d306c4bfae2c6587c325f upstream.
We cannot call nfs4_handle_exception() without first ensuring that the
slot has been freed. If not, we end up deadlocking with the process
waiting for recovery to complete, and recovery waiting for the slot
table to drain.
Fixes: 2e80dbe7ac51 ("NFSv4.1: Close callback races for OPEN, LAYOUTGET...")
commit cfd278c280f997cf2fe4662e0acab0fe465f637b upstream.
Various places assume that if nfs4_fl_prepare_ds() turns a non-NULL 'ds',
then ds->ds_clp will also be non-NULL.
This is not necessasrily true in the case when the process received a fatal signal
while nfs4_pnfs_ds_connect is waiting in nfs4_wait_ds_connect().
In that case ->ds_clp may not be set, and the devid may not recently have been marked
unavailable.
So add a test for ds_clp == NULL and return NULL in that case.
Fixes: c23266d532b4 ("NFS4.1 Fix data server connection race")
Signed-off-by: NeilBrown <neilb@suse.com>
Acked-by: Olga Kornievskaia <aglo@umich.edu>
Acked-by: Adamson, Andy <William.Adamson@netapp.com>
commit 79f687a3de9e3ba2518b4ea33f38ca6cbe9133eb upstream.
Ben Coddington reports that commit 311324ad1713, by adding the function
nfs_dir_mapping_need_revalidate() that checks page cache validity on
each call to nfs_readdir() causes a performance regression when
the directory is being modified.
If the directory is changing while we're iterating through the directory,
POSIX does not require us to invalidate the page cache unless the user
calls rewinddir(). However, we still do want to ensure that we use
readdirplus in order to avoid a load of stat() calls when the user
is doing an 'ls -l' workload.
The fix should be to invalidate the page cache immediately when we're
setting the NFS_INO_ADVISE_RDPLUS bit.
Reported-by: Benjamin Coddington <bcodding@redhat.com>
Fixes: 311324ad1713 ("NFS: Be more aggressive in using readdirplus...")
Reviewed-by: Benjamin Coddington <bcodding@redhat.com>
Tested-by: Benjamin Coddington <bcodding@redhat.com>
commit ee284e35d8c71bf5d4d807eaff6f67a17134b359 upstream.
We must put the task to sleep while holding the inode->i_lock in order
to ensure atomicity with the test for NFS_LAYOUT_RETURN.
Fixes: 500d701f336b ("NFS41: make close wait for layoutreturn")
commit f36ab161bebe464d33b998294eff29b17a9c8918 upstream.
Fix typo in parameter description.
Fixes: 5405fc44c337 ("NFSv4.x: Add kernel parameter to control the
callback server")
Signed-off-by: Wei Yongjun <weiyongjun1@huawei.com>
commit 54e4a0dfa25d9365c4e80a639e80d9213eb6edbe upstream.
We must not call nfs_pageio_init_read() on a new nfs_pageio_descriptor
while holding a reference to a layout segment, as that can deadlock
pnfs_update_layout().
Fixes: d67ae825a59d6 ("pnfs/flexfiles: Add the FlexFile Layout Driver")
commit ae5a459d5f65c3e83f3e14068dde5fb9c9d81807 upstream.
We must ensure that we don't schedule a layoutreturn if the layout stateid
has been marked as invalid.
Fixes: 2a59a0411671e ("pNFS: Fix pnfs_set_layout_stateid() to clear...")
commit 7b650994ab07434ae58a247dc9ac87d2488ca75c upstream.
If we no longer hold any layout segments, we're normally expected to
consider the layout stateid to be invalid. However we cannot assume this
if we're about to, or in the process of sending a layoutreturn.
Fixes: 334a8f37115b ("pNFS: Don't forget the layout stateid if...")
commit 6604b203fb6394ed1f24c21bfa3c207e5ae8e461 upstream.
If there is an I/O error, we should not call LAYOUTGET until the
LAYOUTRETURN that reports the error is complete.
commit c0cf3ef5e0f47e385920450b245d22bead93e7ad upstream.
What matters when deciding if we should make a page uptodate is
not how much we _wanted_ to copy, but how much we actually have
copied. As it is, on architectures that do not zero tail on
short copy we can leave uninitialized data in page marked uptodate.
Pull NFS client bugfixes from Anna Schumaker:
"Most of these fix regressions or races, but there is one patch for
stable that Arnd sent me
Stable bugfix:
- Hide array-bounds warning
Bugfixes:
- Keep a reference on lock states while checking
- Handle NFS4ERR_OLD_STATEID in nfs4_reclaim_open_state
- Don't call close if the open stateid has already been cleared
- Fix CLOSE rases with OPEN
- Fix a regression in DELEGRETURN"
* tag 'nfs-for-4.9-4' of git://git.linux-nfs.org/projects/anna/linux-nfs:
NFSv4.x: hide array-bounds warning
NFSv4.1: Keep a reference on lock states while checking
NFSv4.1: Handle NFS4ERR_OLD_STATEID in nfs4_reclaim_open_state
NFSv4: Don't call close if the open stateid has already been cleared
NFSv4: Fix CLOSE races with OPEN
NFSv4.1: Fix a regression in DELEGRETURN
A correct bugfix introduced a harmless warning that shows up with gcc-7:
fs/nfs/callback.c: In function 'nfs_callback_up':
fs/nfs/callback.c:214:14: error: array subscript is outside array bounds [-Werror=array-bounds]
What happens here is that the 'minorversion == 0' check tells the
compiler that we assume minorversion can be something other than 0,
but when CONFIG_NFS_V4_1 is disabled that would be invalid and
result in an out-of-bounds access.
The added check for IS_ENABLED(CONFIG_NFS_V4_1) tells gcc that this
really can't happen, which makes the code slightly smaller and also
avoids the warning.
The bugfix that introduced the warning is marked for stable backports,
we want this one backported to the same releases.
Fixes: 98b0f80c2396 ("NFSv4.x: Fix a refcount leak in nfs_callback_up_net")
Cc: stable@vger.kernel.org # v3.7+
While walking the list of lock_states, keep a reference on each
nfs4_lock_state to be checked, otherwise the lock state could be removed
while the check performs TEST_STATEID and possible FREE_STATEID.
Now that we're doing TEST_STATEID in nfs4_reclaim_open_state(), we can have
a NFS4ERR_OLD_STATEID returned from nfs41_open_expired() . Instead of
marking state recovery as failed, mark the state for recovery again.
Ensure we test to see if the open stateid is actually set, before we
send a CLOSE.
If the reply to a successful CLOSE call races with an OPEN to the same
file, we can end up scribbling over the stateid that represents the
new open state.
The race looks like:
Client Server
CLOSE stateid A on file "foo"
CLOSE stateid A, return stateid C
OPEN file "foo"
OPEN "foo", return stateid B
Receive reply to OPEN
Reset open state for "foo"
Associate stateid B to "foo"
Receive CLOSE for A
Replace stateid B with C
The fix is to examine the argument of the CLOSE, and check for a match
with the current stateid "other" field. If the two do not match, then
the above race occurred, and we should just ignore the CLOSE.
We don't want to call nfs4_free_revoked_stateid() in the case where
the delegreturn was successful.
"Most of these fix regressions in 4.9, and none are going to stable
this time around.
Bugfixes:
- Trim extra slashes in v4 nfs_paths to fix tools that use this
- Fix a -Wmaybe-uninitialized warnings
- Fix suspicious RCU usages
- Fix Oops when mounting multiple servers at once
- Suppress a false-positive pNFS error
- Fix a DMAR failure in NFS over RDMA"
* tag 'nfs-for-4.9-3' of git://git.linux-nfs.org/projects/anna/linux-nfs:
xprtrdma: Fix DMAR failure in frwr_op_map() after reconnect
fs/nfs: Fix used uninitialized warn in nfs4_slot_seqid_in_use()
NFS: Don't print a pNFS error if we aren't using pNFS
NFS: Ignore connections that have cl_rpcclient uninitialized
SUNRPC: Fix suspicious RCU usage
NFSv4.1: work around -Wmaybe-uninitialized warning
NFS: Trim extra slash in v4 nfs_path
Fix the following warn:
fs/nfs/nfs4session.c: In function ‘nfs4_slot_seqid_in_use’:
fs/nfs/nfs4session.c:203:54: warning: ‘cur_seq’ may be used uninitialized in this function [-Wmaybe-uninitialized]
if (nfs4_slot_get_seqid(tbl, slotid, &cur_seq) == 0 &&
cur_seq == seq_nr && test_bit(slotid, tbl->used_slots))
Signed-off-by: Shuah Khan <shuahkh@osg.samsung.com>
We used to check for a valid layout type id before verifying pNFS flags
as an indicator for if we are using pNFS. This changed in 3132e49ece
with the introduction of multiple layout types, since now we are passing
an array of ids instead of just one. Since then, users have been seeing
a KERN_ERR printk show up whenever mounting NFS v4 without pNFS. This
patch restores the original behavior of exiting set_pnfs_layoutdriver()
early if we aren't using pNFS.
Fixes 3132e49ece ("pnfs: track multiple layout types in fsinfo
structure")
Reviewed-by: Jeff Layton <jlayton@redhat.com>
cl_rpcclient starts as ERR_PTR(-EINVAL), and connections like that
are floating freely through the system. Most places check whether
pointer is valid before dereferencing it, but newly added code
in nfs_match_client does not.
Which causes crashes when more than one NFS mount point is present.
Signed-off-by: Petr Vandrovec <petr@vandrovec.name>
A bugfix introduced a harmless gcc warning in nfs4_slot_seqid_in_use
if we enable -Wmaybe-uninitialized again:
fs/nfs/nfs4session.c:203:54: error: 'cur_seq' may be used uninitialized in this function [-Werror=maybe-uninitialized]
gcc is not smart enough to conclude that the IS_ERR/PTR_ERR pair
results in a nonzero return value here. Using PTR_ERR_OR_ZERO()
instead makes this clear to the compiler.
The warning originally did not appear in v4.8 as it was globally
disabled, but the bugfix that introduced the warning got backported
to stable kernels which again enable it, and this is now the only
warning in the v4.7 builds.
Fixes: e09c978aae5b ("NFSv4.1: Fix Oopsable condition in server callback races")
Cc: Trond Myklebust <trond.myklebust@primarydata.com>
A NFSv4 mount of a subdirectory will show an extra slash (as in
'server://path') in proc's mountinfo which will not match the device name
and path. This can cause problems for programs searching for the mount.
Fix this by checking for a leading slash in the dentry path, if so trim
away any trailing slashes in the device name.
"Just two bugfixes this time:
Stable bugfix:
- Fix last_write_offset incorrectly set to page boundary
Other bugfix:
- Fix missing-braces warning"
* tag 'nfs-for-4.9-2' of git://git.linux-nfs.org/projects/anna/linux-nfs:
nfs4: fix missing-braces warning
pnfs/blocklayout: fix last_write_offset incorrectly set to page boundary
A bugfix introduced a harmless warning for update_open_stateid:
fs/nfs/nfs4proc.c:1548:2: error: missing braces around initializer [-Werror=missing-braces]
Removing the zero in the initializer will do the right thing here
and initialize the entire structure to zero.
Fixes: 1393d9612ba0 ("NFSv4: Fix a race when updating an open_stateid")
Pull NFS client updates from Anna Schumaker:
"Highlights include:
Stable bugfixes:
- sunrpc: fix writ espace race causing stalls
- NFS: Fix inode corruption in nfs_prime_dcache()
- NFSv4: Don't report revoked delegations as valid in nfs_have_delegation()
- NFSv4: nfs4_copy_delegation_stateid() must fail if the delegation is invalid
- NFSv4: Open state recovery must account for file permission changes
- NFSv4.2: Fix a reference leak in nfs42_proc_layoutstats_generic
Features:
- Add support for tracking multiple layout types with an ordered list
- Add support for using multiple backchannel threads on the client
- Add support for pNFS file layout session trunking
- Delay xprtrdma use of DMA API (for device driver removal)
- Add support for xprtrdma remote invalidation
- Add support for larger xprtrdma inline thresholds
- Use a scatter/gather list for sending xprtrdma RPC calls
- Add support for the CB_NOTIFY_LOCK callback
- Improve hashing sunrpc auth_creds by using both uid and gid
Bugfixes:
- Fix xprtrdma use of DMA API
- Validate filenames before adding to the dcache
- Fix corruption of xdr->nwords in xdr_copy_to_scratch
- Fix setting buffer length in xdr_set_next_buffer()
- Don't deadlock the state manager on the SEQUENCE status flags
- Various delegation and stateid related fixes
- Retry operations if an interrupted slot receives EREMOTEIO
- Make nfs boot time y2038 safe"
* tag 'nfs-for-4.9-1' of git://git.linux-nfs.org/projects/anna/linux-nfs: (100 commits)
fs: nfs: Make nfs boot time y2038 safe
sunrpc: replace generic auth_cred hash with auth-specific function
sunrpc: add RPCSEC_GSS hash_cred() function
sunrpc: add auth_unix hash_cred() function
sunrpc: add generic_auth hash_cred() function
sunrpc: add hash_cred() function to rpc_authops struct
Retry operation on EREMOTEIO on an interrupted slot
pNFS: Fix atime updates on pNFS clients
sunrpc: queue work on system_power_efficient_wq
NFSv4.1: Even if the stateid is OK, we may need to recover the open modes
NFSv4: If recovery failed for a specific open stateid, then don't retry
NFSv4: Fix retry issues with nfs41_test/free_stateid
NFSv4: Mark the lock and open stateids as invalid after freeing them
NFSv4: Don't test open_stateid unless it is set
NFSv4: nfs4_do_handle_exception() handle revoke/expiry of a single stateid
NFS: Always call nfs_inode_find_state_and_recover() when revoking a delegation
NFSv4: Fix a race in nfs_inode_reclaim_delegation()
Commit 41963c10c47a35185e68cb9049f7a3493c94d2d7 sets the block layout's
last written byte to the offset of the end of the extent rather than the
end of the write which incorrectly updates the inode's size for
partial-page writes.
Fixes: 41963c10c47a ("pnfs/blocklayout: update last_write_offset atomically with extents")
Tested-by: Christoph Hellwig <hch@lst.de>
Cc: stable@vger.kernel.org # 4.8+
Pull more vfs updates from Al Viro:
">rename2() work from Miklos + current_time() from Deepa"
* 'for-linus' of git://git.kernel.org/pub/scm/linux/kernel/git/viro/vfs:
fs: Replace current_fs_time() with current_time()
fs: Replace CURRENT_TIME_SEC with current_time() for inode timestamps
fs: Replace CURRENT_TIME with current_time() for inode timestamps
fs: proc: Delete inode time initializations in proc_alloc_inode()
vfs: Add current_time() api
vfs: add note about i_op->rename changes to porting
fs: rename "rename2" i_op to "rename"
vfs: remove unused i_op->rename
fs: make remaining filesystems use .rename2
libfs: support RENAME_NOREPLACE in simple_rename()
fs: support RENAME_NOREPLACE for local filesystems
ncpfs: fix unused variable warning
Pull vfs xattr updates from Al Viro:
"xattr stuff from Andreas
This completes the switch to xattr_handler ->get()/->set() from
->getxattr/->setxattr/->removexattr"
* 'work.xattr' of git://git.kernel.org/pub/scm/linux/kernel/git/viro/vfs:
vfs: Remove {get,set,remove}xattr inode operations
xattr: Stop calling {get,set,remove}xattr inode operations
vfs: Check for the IOP_XATTR flag in listxattr
xattr: Add __vfs_{get,set,remove}xattr helpers
libfs: Use IOP_XATTR flag for empty directory handling
vfs: Use IOP_XATTR flag for bad-inode handling
vfs: Add IOP_XATTR inode operations flag
vfs: Move xattr_resolve_name to the front of fs/xattr.c
ecryptfs: Switch to generic xattr handlers
sockfs: Get rid of getxattr iop
sockfs: getxattr: Fail with -EOPNOTSUPP for invalid attribute names
kernfs: Switch to generic xattr handlers
hfs: Switch to generic xattr handlers
jffs2: Remove jffs2_{get,set,remove}xattr macros
xattr: Remove unnecessary NULL attribute name check
Merge updates from Andrew Morton:
- fsnotify updates
- ocfs2 updates
- all of MM
* emailed patches from Andrew Morton <akpm@linux-foundation.org>: (127 commits)
console: don't prefer first registered if DT specifies stdout-path
cred: simpler, 1D supplementary groups
CREDITS: update Pavel's information, add GPG key, remove snail mail address
mailmap: add Johan Hovold
.gitattributes: set git diff driver for C source code files
uprobes: remove function declarations from arch/{mips,s390}
spelling.txt: "modeled" is spelt correctly
nmi_backtrace: generate one-line reports for idle cpus
arch/tile: adopt the new nmi_backtrace framework
nmi_backtrace: do a local dump_stack() instead of a self-NMI
nmi_backtrace: add more trigger_*_cpu_backtrace() methods
min/max: remove sparse warnings when they're nested
Documentation/filesystems/proc.txt: add more description for maps/smaps
mm, proc: fix region lost in /proc/self/smaps
proc: fix timerslack_ns CAP_SYS_NICE check when adjusting self
proc: add LSM hook checks to /proc/<tid>/timerslack_ns
proc: relax /proc/<tid>/timerslack_ns capability requirements
meminfo: break apart a very long seq_printf with #ifdefs
seq/proc: modify seq_put_decimal_[u]ll to take a const char *, not char
proc: faster /proc/*/status
These inode operations are no longer used; remove them.
Signed-off-by: Andreas Gruenbacher <agruenba@redhat.com>
After using the offset of the swap entry as the key of the swap cache,
the page_index() becomes exactly same as page_file_index(). So the
page_file_index() is removed and the callers are changed to use
page_index() instead.
Link: http://lkml.kernel.org/r/1473270649-27229-2-git-send-email-ying.huang@intel.com
Signed-off-by: "Huang, Ying" <ying.huang@intel.com>
Cc: Anna Schumaker <anna.schumaker@netapp.com>
Cc: "Kirill A. Shutemov" <kirill.shutemov@linux.intel.com>
Cc: Michal Hocko <mhocko@suse.com>
Cc: Dave Hansen <dave.hansen@linux.intel.com>
Cc: Dan Williams <dan.j.williams@intel.com>
Cc: Joonsoo Kim <iamjoonsoo.kim@lge.com>
Cc: Ross Zwisler <ross.zwisler@linux.intel.com>
Cc: Eric Dumazet <edumazet@google.com>
... and kill the ->splice_read() instances that can be switched to it
The caller of rpc_run_task also gets a reference that must be put.
Signed-off-by: Jeff Layton <jeff.layton@primarydata.com>
Cc: stable@vger.kernel.org # 4.2+
boot_time is represented as a struct timespec.
struct timespec and CURRENT_TIME are not y2038 safe.
Overall, the plan is to use timespec64 and ktime_t for
all internal kernel representation of timestamps.
CURRENT_TIME will also be removed.
boot_time is used to construct the nfs client boot verifier.
Use ktime_t to represent boot_time and ktime_get_real() for
the boot_time value.
Following Trond's request https://lkml.org/lkml/2016/6/9/22 ,
use ktime_t instead of converting to struct timespec64.
Use higher and lower 32 bit parts of ktime_t for the boot
verifier.
Use the lower 32 bit part of ktime_t for the authsys_parms
stamp field.
Signed-off-by: Deepa Dinamani <deepa.kernel@gmail.com>
Reviewed-by: Arnd Bergmann <arnd@arndb.de>
Cc: linux-nfs@vger.kernel.org
If an operation got interrupted, then since we don't know if the
server processed it on not, we keep the seq#. Upon reuse of slot
and seq# if we get reply from the cache (ie EREMOTEIO) then we
need to retry the operation after bumping the seq#
Fix the code so that we always mark the atime as invalid in nfs4_read_done().
Currently, the expectation appears to be that the pNFS drivers should always
do this, with the result that most of them don't.
TEST_STATEID only tells you that you have a valid open stateid. It doesn't
tell the client anything about whether or not it holds the required share
locks.
Tested-by: Oleg Drokin <green@linuxhacker.ru>
[Anna: Wrap nfs_open_stateid_recover_openmode in CONFIG_NFS_V4_1 checks]
_nfs41_free_stateid() needs to be cached by the session, but
nfs41_test_stateid() may return NFS4ERR_RETRY_UNCACHED_REP (in which
case we should just retry).
If the file permissions change on the server, then we may not be able to
recover open state. If so, we need to ensure that we mark the file
descriptor appropriately.
