path: root/fs/nfs
2015-07-04Merge branch 'for-linus' of ↵Linus Torvalds
git://git.kernel.org/pub/scm/linux/kernel/git/viro/vfs Pull more vfs updates from Al Viro: "Assorted VFS fixes and related cleanups (IMO the most interesting in that part are f_path-related things and Eric's descriptor-related stuff). UFS regression fixes (it got broken last cycle). 9P fixes. fs-cache series, DAX patches, Jan's file_remove_suid() work" [ I'd say this is much more than "fixes and related cleanups". The file_table locking rule change by Eric Dumazet is a rather big and fundamental update even if the patch isn't huge. - Linus ] * 'for-linus' of git://git.kernel.org/pub/scm/linux/kernel/git/viro/vfs: (49 commits) 9p: cope with bogus responses from server in p9_client_{read,write} p9_client_write(): avoid double p9_free_req() 9p: forgetting to cancel request on interrupted zero-copy RPC dax: bdev_direct_access() may sleep block: Add support for DAX reads/writes to block devices dax: Use copy_from_iter_nocache dax: Add block size note to documentation fs/file.c: __fget() and dup2() atomicity rules fs/file.c: don't acquire files->file_lock in fd_install() fs:super:get_anon_bdev: fix race condition could cause dev exceed its upper limitation vfs: avoid creation of inode number 0 in get_next_ino namei: make set_root_rcu() return void make simple_positive() public ufs: use dir_pages instead of ufs_dir_pages() pagemap.h: move dir_pages() over there remove the pointless include of lglock.h fs: cleanup slight list_entry abuse xfs: Correctly lock inode when removing suid and file capabilities fs: Call security_ops->inode_killpriv on truncate fs: Provide function telling whether file_remove_privs() will do anything ...
2015-07-02Merge tag 'nfs-for-4.2-1' of git://git.linux-nfs.org/projects/trondmy/linux-nfsLinus Torvalds
Pull NFS client updates from Trond Myklebust: "Highlights include: Stable patches: - Fix a crash in the NFSv4 file locking code. - Fix an fsync() regression, where we were failing to retry I/O in some circumstances. - Fix an infinite loop in NFSv4.0 OPEN stateid recovery - Fix a memory leak when an attempted pnfs fails. - Fix a memory leak in the backchannel code - Large hostnames were not supported correctly in NFSv4.1 - Fix a pNFS/flexfiles bug that was impeding error reporting on I/O. - Fix a couple of credential issues in pNFS/flexfiles Bugfixes + cleanups: - Open flag sanity checks in the NFSv4 atomic open codepath - More NFSv4 delegation related bugfixes - Various NFSv4.1 backchannel bugfixes and cleanups - Fix the NFS swap socket code - Various cleanups of the NFSv4 SETCLIENTID and EXCHANGE_ID code - Fix a UDP transport deadlock issue Features: - More RDMA client transport improvements - NFSv4.2 LAYOUTSTATS functionality for pnfs flexfiles" * tag 'nfs-for-4.2-1' of git://git.linux-nfs.org/projects/trondmy/linux-nfs: (87 commits) nfs: Remove invalid tk_pid from debug message nfs: Remove invalid NFS_ATTR_FATTR_V4_REFERRAL checking in nfs4_get_rootfh nfs: Drop bad comment in nfs41_walk_client_list() nfs: Remove unneeded micro checking of CONFIG_PROC_FS nfs: Don't setting FILE_CREATED flags always nfs: Use remove_proc_subtree() instead remove_proc_entry() nfs: Remove unused argument in nfs_server_set_fsinfo() nfs: Fix a memory leak when meeting an unsupported state protect nfs: take extra reference to fl->fl_file when running a LOCKU operation NFSv4: When returning a delegation, don't reclaim an incompatible open mode. NFSv4.2: LAYOUTSTATS is optional to implement NFSv4.2: Fix up a decoding error in layoutstats pNFS/flexfiles: Fix the reset of struct pgio_header when resending pNFS/flexfiles: Turn off layoutcommit for servers that don't need it pnfs/flexfiles: protect ktime manipulation with mirror lock nfs: provide pnfs_report_layoutstat when NFS42 is disabled nfs: verify open flags before allowing open nfs: always update creds in mirror, even when we have an already connected ds nfs: fix potential credential leak in ff_layout_update_mirror_cred pnfs/flexfiles: report layoutstat regularly ...
2015-07-01Merge tag 'modules-next-for-linus' of ↵Linus Torvalds
git://git.kernel.org/pub/scm/linux/kernel/git/rusty/linux Pull module updates from Rusty Russell: "Main excitement here is Peter Zijlstra's lockless rbtree optimization to speed module address lookup. He found some abusers of the module lock doing that too. A little bit of parameter work here too; including Dan Streetman's breaking up the big param mutex so writing a parameter can load another module (yeah, really). Unfortunately that broke the usual suspects, !CONFIG_MODULES and !CONFIG_SYSFS, so those fixes were appended too" * tag 'modules-next-for-linus' of git://git.kernel.org/pub/scm/linux/kernel/git/rusty/linux: (26 commits) modules: only use mod->param_lock if CONFIG_MODULES param: fix module param locks when !CONFIG_SYSFS. rcu: merge fix for Convert ACCESS_ONCE() to READ_ONCE() and WRITE_ONCE() module: add per-module param_lock module: make perm const params: suppress unused variable error, warn once just in case code changes. modules: clarify CONFIG_MODULE_COMPRESS help, suggest 'N'. kernel/module.c: avoid ifdefs for sig_enforce declaration kernel/workqueue.c: remove ifdefs over wq_power_efficient kernel/params.c: export param_ops_bool_enable_only kernel/params.c: generalize bool_enable_only kernel/module.c: use generic module param operaters for sig_enforce kernel/params: constify struct kernel_param_ops uses sysfs: tightened sysfs permission checks module: Rework module_addr_{min,max} module: Use __module_address() for module_address_lookup() module: Make the mod_tree stuff conditional on PERF_EVENTS || TRACING module: Optimize __module_address() using a latched RB-tree rbtree: Implement generic latch_tree seqlock: Introduce raw_read_seqcount_latch() ...
2015-07-01nfs: Remove invalid tk_pid from debug messageKinglong Mee
Before rpc_run_task(), tk_pid is uninitiated as 0 always. Signed-off-by: Kinglong Mee <kinglongmee@gmail.com> Signed-off-by: Trond Myklebust <trond.myklebust@primarydata.com>
2015-07-01nfs: Remove invalid NFS_ATTR_FATTR_V4_REFERRAL checking in nfs4_get_rootfhKinglong Mee
NFS_ATTR_FATTR_V4_REFERRAL is only set in nfs4_proc_lookup_common. Signed-off-by: Kinglong Mee <kinglongmee@gmail.com> Signed-off-by: Trond Myklebust <trond.myklebust@primarydata.com>
2015-07-01nfs: Drop bad comment in nfs41_walk_client_list()Kinglong Mee
Commit 7b1f1fd184 "NFSv4/4.1: Fix bugs in nfs4[01]_walk_client_list" have change the logical of the list_for_each_entry(). Signed-off-by: Kinglong Mee <kinglongmee@gmail.com> Signed-off-by: Trond Myklebust <trond.myklebust@primarydata.com>
2015-07-01nfs: Remove unneeded micro checking of CONFIG_PROC_FSKinglong Mee
Have checking CONFIG_PROC_FS in include/linux/sunrpc/stats.h. Signed-off-by: Kinglong Mee <kinglongmee@gmail.com> Signed-off-by: Trond Myklebust <trond.myklebust@primarydata.com>
2015-07-01nfs: Don't setting FILE_CREATED flags alwaysKinglong Mee
Commit 5bc2afc2b5 "NFSv4: Honour the 'opened' parameter in the atomic_open() filesystem method" have support the opened arguments now. Also, Commit 03da633aa7 "atomic_open: take care of EEXIST in no-open case with O_CREAT|O_EXCL in fs/namei.c" have change vfs's logical. Signed-off-by: Kinglong Mee <kinglongmee@gmail.com> Signed-off-by: Trond Myklebust <trond.myklebust@primarydata.com>
2015-07-01nfs: Use remove_proc_subtree() instead remove_proc_entry()Kinglong Mee
Thanks for Al Viro's comments of killing proc_fs_nfs completely. Signed-off-by: Kinglong Mee <kinglongmee@gmail.com> Signed-off-by: Trond Myklebust <trond.myklebust@primarydata.com>
2015-07-01nfs: Remove unused argument in nfs_server_set_fsinfo()Kinglong Mee
Commit e38eb6506f "NFS: set_pnfs_layoutdriver() from nfs4_proc_fsinfo()" have remove the using of mntfh from nfs_server_set_fsinfo(). Signed-off-by: Kinglong Mee <kinglongmee@gmail.com> Signed-off-by: Trond Myklebust <trond.myklebust@primarydata.com>
2015-07-01nfs: Fix a memory leak when meeting an unsupported state protectKinglong Mee
2015-07-01nfs: take extra reference to fl->fl_file when running a LOCKU operationJeff Layton
Jean reported another crash, similar to the one fixed by feaff8e5b2cf: BUG: unable to handle kernel NULL pointer dereference at 0000000000000148 IP: [<ffffffff8124ef7f>] locks_get_lock_context+0xf/0xa0 PGD 0 Oops: 0000 [#1] SMP Modules linked in: nfsv3 nfs_layout_flexfiles rpcsec_gss_krb5 nfsv4 dns_resolver nfs fscache vmw_vsock_vmci_transport vsock cfg80211 rfkill coretemp crct10dif_pclmul ppdev vmw_balloon crc32_pclmul crc32c_intel ghash_clmulni_intel pcspkr vmxnet3 parport_pc i2c_piix4 microcode serio_raw parport nfsd floppy vmw_vmci acpi_cpufreq auth_rpcgss shpchp nfs_acl lockd grace sunrpc vmwgfx drm_kms_helper ttm drm mptspi scsi_transport_spi mptscsih ata_generic mptbase i2c_core pata_acpi CPU: 0 PID: 329 Comm: kworker/0:1H Not tainted 4.1.0-rc7+ #2 Hardware name: VMware, Inc. VMware Virtual Platform/440BX Desktop Reference Platform, BIOS 6.00 07/30/2013 Workqueue: rpciod rpc_async_schedule [sunrpc] 30ec000 RIP: 0010:[<ffffffff8124ef7f>] [<ffffffff8124ef7f>] locks_get_lock_context+0xf/0xa0 RSP: 0018:ffff8802330efc08 EFLAGS: 00010296 RAX: ffff8802330efc58 RBX: ffff880097187c80 RCX: 0000000000000000 RDX: 0000000000000000 RSI: 0000000000000002 RDI: 0000000000000000 RBP: ffff8802330efc18 R08: ffff88023fc173d8 R09: 3038b7bf00000000 R10: 00002f1a02000000 R11: 3038b7bf00000000 R12: 0000000000000000 R13: 0000000000000000 R14: ffff8802337a2300 R15: 0000000000000020 FS: 0000000000000000(0000) GS:ffff88023fc00000(0000) knlGS:0000000000000000 CS: 0010 DS: 0000 ES: 0000 CR0: 0000000080050033 CR2: 0000000000000148 CR3: 000000003680f000 CR4: 00000000001407f0 Stack: ffff880097187c80 ffff880097187cd8 ffff8802330efc98 ffffffff81250281 ffff8802330efc68 ffffffffa013e7df ffff8802330efc98 0000000000000246 ffff8801f6901c00 ffff880233d2b8d8 ffff8802330efc58 ffff8802330efc58 Call Trace: [<ffffffff81250281>] __posix_lock_file+0x31/0x5e0 [<ffffffffa013e7df>] ? rpc_wake_up_task_queue_locked.part.35+0xcf/0x240 [sunrpc] [<ffffffff8125088b>] posix_lock_file_wait+0x3b/0xd0 [<ffffffffa03890b2>] ? nfs41_wake_and_assign_slot+0x32/0x40 [nfsv4] [<ffffffffa0365808>] ? nfs41_sequence_done+0xd8/0x300 [nfsv4] [<ffffffffa0367525>] do_vfs_lock+0x35/0x40 [nfsv4] [<ffffffffa03690c1>] nfs4_locku_done+0x81/0x120 [nfsv4] [<ffffffffa013e310>] ? rpc_destroy_wait_queue+0x20/0x20 [sunrpc] [<ffffffffa013e310>] ? rpc_destroy_wait_queue+0x20/0x20 [sunrpc] [<ffffffffa013e33c>] rpc_exit_task+0x2c/0x90 [sunrpc] [<ffffffffa0134400>] ? call_refreshresult+0x170/0x170 [sunrpc] [<ffffffffa013ece4>] __rpc_execute+0x84/0x410 [sunrpc] [<ffffffffa013f085>] rpc_async_schedule+0x15/0x20 [sunrpc] [<ffffffff810add67>] process_one_work+0x147/0x400 [<ffffffff810ae42b>] worker_thread+0x11b/0x460 [<ffffffff810ae310>] ? rescuer_thread+0x2f0/0x2f0 [<ffffffff810b35d9>] kthread+0xc9/0xe0 [<ffffffff81010000>] ? perf_trace_xen_mmu_set_pmd+0xa0/0x160 [<ffffffff810b3510>] ? kthread_create_on_node+0x170/0x170 [<ffffffff8173c222>] ret_from_fork+0x42/0x70 [<ffffffff810b3510>] ? kthread_create_on_node+0x170/0x170 Code: a5 81 e8 85 75 e4 ff c6 05 31 ee aa 00 01 eb 98 66 66 66 2e 0f 1f 84 00 00 00 00 00 0f 1f 44 00 00 55 48 89 e5 41 54 49 89 fc 53 <48> 8b 9f 48 01 00 00 48 85 db 74 08 48 89 d8 5b 41 5c 5d c3 83 RIP [<ffffffff8124ef7f>] locks_get_lock_context+0xf/0xa0 RSP <ffff8802330efc08> CR2: 0000000000000148 ---[ end trace 64484f16250de7ef ]--- The problem is almost exactly the same as the one fixed by feaff8e5b2cf. We must take a reference to the struct file when running the LOCKU compound to prevent the final fput from running until the operation is complete. Reported-by: Jean Spector <jean@primarydata.com> Signed-off-by: Jeff Layton <jeff.layton@primarydata.com> Cc: stable@vger.kernel.org Signed-off-by: Trond Myklebust <trond.myklebust@primarydata.com>
2015-06-29NFSv4: When returning a delegation, don't reclaim an incompatible open mode.NeilBrown
It is possible to have an active open with one mode, and a delegation for the same file with a different mode. In particular, a WR_ONLY open and an RD_ONLY delegation. This happens if a WR_ONLY open is followed by a RD_ONLY open which provides a delegation, but is then close. When returning the delegation, we currently try to claim opens for every open type (n_rdwr, n_rdonly, n_wronly). As there is no harm in claiming an open for a mode that we already have, this is often simplest. However if the delegation only provides a subset of the modes that we currently have open, this will produce an error from the server. So when claiming open modes prior to returning a delegation, skip the open request if the mode is not covered by the delegation - the open_stateid must already cover that mode, so there is nothing to do. Signed-off-by: NeilBrown <neilb@suse.de> Signed-off-by: Trond Myklebust <trond.myklebust@primarydata.com>
2015-06-27NFSv4.2: LAYOUTSTATS is optional to implementTrond Myklebust
Make it so, by checking the return value for NFS4ERR_MOTSUPP and caching the information as a server capability. Signed-off-by: Trond Myklebust <trond.myklebust@primarydata.com>
2015-06-27NFSv4.2: Fix up a decoding error in layoutstatsTrond Myklebust
According to the spec, the server is only returning the status, which we decode in the op header. Signed-off-by: Trond Myklebust <trond.myklebust@primarydata.com>
2015-06-26pNFS/flexfiles: Fix the reset of struct pgio_header when resendingTrond Myklebust
hdr->good_bytes needs to be set to the length of the request, not zero. Cc: stable@vger.kernel.org # 4.0+ Signed-off-by: Trond Myklebust <trond.myklebust@primarydata.com>
2015-06-26pNFS/flexfiles: Turn off layoutcommit for servers that don't need itTrond Myklebust
This patch ensures that we record the value of 'ffl_flags' from the layout, and then checks for the presence of the FF_FLAGS_NO_LAYOUTCOMMIT flag before deciding whether or not to call pnfs_set_layoutcommit(). The effect is that servers now can decide whether or not they want the client to call layoutcommit before returning a writeable layout. Signed-off-by: Trond Myklebust <trond.myklebust@primarydata.com>
2015-06-26Merge branch 'layoutstats'Trond Myklebust
* layoutstats: pnfs/flexfiles: protect ktime manipulation with mirror lock nfs: provide pnfs_report_layoutstat when NFS42 is disabled pnfs/flexfiles: report layoutstat regularly nfs42: serialize LAYOUTSTATS calls of the same file pnfs/flexfiles: encode LAYOUTSTATS flexfiles specific data pnfs/flexfiles: add ff_layout_prepare_layoutstats pNFS/flexfiles: track when layout is first used pNFS/flexfiles: add layoutstats tracking pNFS/flexfiles: Remove unused struct members user_name, group_name pnfs: add pnfs_report_layoutstat helper function pNFS: fill in nfs42_layoutstat_ops NFSv.2/pnfs Add a LAYOUTSTATS rpc function
2015-06-26pnfs/flexfiles: protect ktime manipulation with mirror lockPeng Tao
It looks as if xchg() and cmpxchg() are not available for 64-bit integers on sparc32: > New breakage seen in linux-next today: > > ERROR: "__xchg_called_with_bad_pointer" [fs/nfs/flexfilelayout/nfs_layout_flexfiles.ko] undefined! > ERROR: "__cmpxchg_called_with_bad_pointer" [fs/nfs/flexfilelayout/nfs_layout_flexfiles.ko] undefined! > make[2]: *** [__modpost] Error 1 > make[1]: *** [modules] Error 2 Given that mirror ktime manipulation is already under mirror->lock, let's make use of the fact. Reported-by: Paul Gortmaker <paul.gortmaker@windriver.com> Signed-off-by: Peng Tao <tao.peng@primarydata.com> Signed-off-by: Trond Myklebust <trond.myklebust@primarydata.com>
2015-06-26nfs: provide pnfs_report_layoutstat when NFS42 is disabledPeng Tao
kbuild test robot reported: fs/built-in.o: In function `pnfs_report_layoutstat': >> (.text+0x151a1c): undefined reference to `nfs42_proc_layoutstats_generic' Reported-by: kbuild test robot <fengguang.wu@intel.com> Signed-off-by: Peng Tao <tao.peng@primarydata.com> Signed-off-by: Trond Myklebust <trond.myklebust@primarydata.com>
2015-06-25nfs: verify open flags before allowing openBenjamin Coddington
Commit 9597c13b forbade opens with O_APPEND|O_DIRECT for NFSv4: nfs: verify open flags before allowing an atomic open Currently, you can open a NFSv4 file with O_APPEND|O_DIRECT, but cannot fcntl(F_SETFL,...) with those flags. This flag combination is explicitly forbidden on NFSv3 opens, and it seems like it should also be on NFSv4. However, you can still open a file with O_DIRECT|O_APPEND if there exists a cached dentry for the file because nfs4_file_open() is used instead of nfs_atomic_open() and the check is bypassed. Add the check in nfs4_file_open() as well. Signed-off-by: Benjamin Coddington <bcodding@redhat.com> Signed-off-by: Trond Myklebust <trond.myklebust@primarydata.com>
2015-06-25nfs: always update creds in mirror, even when we have an already connected dsJeff Layton
A ds can be associated with more than one mirror, but we currently skip setting a mirror's credentials if we find that it's already set up with a connected client. The upshot is that we can end up sending DS writes with MDS credentials instead of properly setting them up. Fix nfs4_ff_layout_prepare_ds to always verify that the mirror's credentials are set up, even when we have a DS that's already connected. Reported-by: Tom Haynes <thomas.haynes@primarydata.com> Signed-off-by: Jeff Layton <jeff.layton@primarydata.com> Cc: stable@vger.kernel.org # 4.0+ Signed-off-by: Trond Myklebust <trond.myklebust@primarydata.com>
2015-06-25nfs: fix potential credential leak in ff_layout_update_mirror_credJeff Layton
If we have two tasks racing to update a mirror's credentials, then they can end up leaking one (or more) sets of credentials. The first task will set mirror->cred and then the second task will just overwrite it. Use a cmpxchg to ensure that the creds are only set once. If we get to the point where we would set mirror->cred and find that they're already set, then we just release the creds that were just found. Signed-off-by: Jeff Layton <jeff.layton@primarydata.com> Cc: stable@vger.kernel.org # 4.0+ Signed-off-by: Trond Myklebust <trond.myklebust@primarydata.com>
2015-06-25Merge branch 'for-4.2/writeback' of git://git.kernel.dk/linux-blockLinus Torvalds
Pull cgroup writeback support from Jens Axboe: "This is the big pull request for adding cgroup writeback support. This code has been in development for a long time, and it has been simmering in for-next for a good chunk of this cycle too. This is one of those problems that has been talked about for at least half a decade, finally there's a solution and code to go with it. Also see last weeks writeup on LWN: http://lwn.net/Articles/648292/" * 'for-4.2/writeback' of git://git.kernel.dk/linux-block: (85 commits) writeback, blkio: add documentation for cgroup writeback support vfs, writeback: replace FS_CGROUP_WRITEBACK with SB_I_CGROUPWB writeback: do foreign inode detection iff cgroup writeback is enabled v9fs: fix error handling in v9fs_session_init() bdi: fix wrong error return value in cgwb_create() buffer: remove unusued 'ret' variable writeback: disassociate inodes from dying bdi_writebacks writeback: implement foreign cgroup inode bdi_writeback switching writeback: add lockdep annotation to inode_to_wb() writeback: use unlocked_inode_to_wb transaction in inode_congested() writeback: implement unlocked_inode_to_wb transaction and use it for stat updates writeback: implement [locked_]inode_to_wb_and_lock_list() writeback: implement foreign cgroup inode detection writeback: make writeback_control track the inode being written back writeback: relocate wb[_try]_get(), wb_put(), inode_{attach|detach}_wb() mm: vmscan: disable memcg direct reclaim stalling if cgroup writeback support is in use writeback: implement memcg writeback domain based throttling writeback: reset wb_domain->dirty_limit[_tstmp] when memcg domain size changes writeback: implement memcg wb_domain writeback: update wb_over_bg_thresh() to use wb_domain aware operations ...
2015-06-24pnfs/flexfiles: report layoutstat regularlyPeng Tao
As a simple scheme, report every minute if IO is still going on. Reviewed-by: Jeff Layton <jeff.layton@primarydata.com> Signed-off-by: Peng Tao <tao.peng@primarydata.com> Signed-off-by: Trond Myklebust <trond.myklebust@primarydata.com>
2015-06-24nfs42: serialize LAYOUTSTATS calls of the same filePeng Tao
There is no need to report concurrently. Reviewed-by: Jeff Layton <jeff.layton@primarydata.com> Signed-off-by: Peng Tao <tao.peng@primarydata.com> Signed-off-by: Trond Myklebust <trond.myklebust@primarydata.com>
2015-06-24pnfs/flexfiles: encode LAYOUTSTATS flexfiles specific dataPeng Tao
2015-06-24pnfs/flexfiles: add ff_layout_prepare_layoutstatsPeng Tao
It fills in the generic part of LAYOUTSTATS call. One thing to note is that we don't really track if IO is continuous or not. So just fake to use the completed bytes for it. Still missing flexfiles specific part, which will be included in the next patch. Reviewed-by: Jeff Layton <jeff.layton@primarydata.com> Signed-off-by: Peng Tao <tao.peng@primarydata.com> Signed-off-by: Trond Myklebust <trond.myklebust@primarydata.com>
2015-06-24pNFS/flexfiles: track when layout is first usedPeng Tao
So that we can report cumulative time since the beginning of statistics collection of the layout. Reviewed-by: Jeff Layton <jeff.layton@primarydata.com> Signed-off-by: Peng Tao <tao.peng@primarydata.com> Signed-off-by: Trond Myklebust <trond.myklebust@primarydata.com>
2015-06-24pNFS/flexfiles: add layoutstats trackingTrond Myklebust
Reviewed-by: Jeff Layton <jeff.layton@primarydata.com> Signed-off-by: Trond Myklebust <trond.myklebust@primarydata.com>
2015-06-24pNFS/flexfiles: Remove unused struct members user_name, group_nameTrond Myklebust
2015-06-24pnfs: add pnfs_report_layoutstat helper functionPeng Tao
2015-06-24pNFS: fill in nfs42_layoutstat_opsPeng Tao
2015-06-24NFSv.2/pnfs Add a LAYOUTSTATS rpc functionTrond Myklebust
Reviewed-by: Jeff Layton <jeff.layton@primarydata.com> Signed-off-by: Trond Myklebust <trond.myklebust@primarydata.com> Signed-off-by: Peng Tao <tao.peng@primarydata.com> Signed-off-by: Trond Myklebust <trond.myklebust@primarydata.com>
2015-06-23make simple_positive() publicAl Viro
2015-06-22Merge branch 'for-linus-1' of ↵Linus Torvalds
git://git.kernel.org/pub/scm/linux/kernel/git/viro/vfs Pull vfs updates from Al Viro: "In this pile: pathname resolution rewrite. - recursion in link_path_walk() is gone. - nesting limits on symlinks are gone (the only limit remaining is that the total amount of symlinks is no more than 40, no matter how nested). - "fast" (inline) symlinks are handled without leaving rcuwalk mode. - stack footprint (independent of the nesting) is below kilobyte now, about on par with what it used to be with one level of nested symlinks and ~2.8 times lower than it used to be in the worst case. - struct nameidata is entirely private to fs/namei.c now (not even opaque pointers are being passed around). - ->follow_link() and ->put_link() calling conventions had been changed; all in-tree filesystems converted, out-of-tree should be able to follow reasonably easily. For out-of-tree conversions, see Documentation/filesystems/porting for details (and in-tree filesystems for examples of conversion). That has sat in -next since mid-May, seems to survive all testing without regressions and merges clean with v4.1" * 'for-linus-1' of git://git.kernel.org/pub/scm/linux/kernel/git/viro/vfs: (131 commits) turn user_{path_at,path,lpath,path_dir}() into static inlines namei: move saved_nd pointer into struct nameidata inline user_path_create() inline user_path_parent() namei: trim do_last() arguments namei: stash dfd and name into nameidata namei: fold path_cleanup() into terminate_walk() namei: saner calling conventions for filename_parentat() namei: saner calling conventions for filename_create() namei: shift nameidata down into filename_parentat() namei: make filename_lookup() reject ERR_PTR() passed as name namei: shift nameidata inside filename_lookup() namei: move putname() call into filename_lookup() namei: pass the struct path to store the result down into path_lookupat() namei: uninline set_root{,_rcu}() namei: be careful with mountpoint crossings in follow_dotdot_rcu() Documentation: remove outdated information from automount-support.txt get rid of assorted nameidata-related debris lustre: kill unused helper lustre: kill unused macro (LOOKUP_CONTINUE) ...
2015-06-22Merge branch 'bugfixes'Trond Myklebust
* bugfixes: NFS: Ensure we set NFS_CONTEXT_RESEND_WRITES when requeuing writes pNFS: Fix a memory leak when attempted pnfs fails NFS: Ensure that we update the sequence id under the slot table lock nfs: Initialize cb_sequenceres information before validate_seqid() nfs: Only update callback sequnce id when CB_SEQUENCE success NFSv4: nfs4_handle_delegation_recall_error should ignore EAGAIN
2015-06-18nfs: Fix comment for nfs_pageio_init() and nfs_pageio_complete_mirror()Yijing Wang
Signed-off-by: Yijing Wang <wangyijing@huawei.com> Signed-off-by: Trond Myklebust <trond.myklebust@primarydata.com>
2015-06-17NFS: Ensure we set NFS_CONTEXT_RESEND_WRITES when requeuing writesTrond Myklebust
If a write attempt fails, and the write is queued up for resending to the server, as opposed to being dropped, then we need to set the appropriate flag so that nfs_file_fsync() does the right thing. Cc: stable@vger.kernel.org Signed-off-by: Trond Myklebust <trond.myklebust@primarydata.com>
2015-06-17pNFS: Fix a memory leak when attempted pnfs failsTrond Myklebust
pnfs_do_write() expects the call to pnfs_write_through_mds() to free the pgio header and to release the layout segment before exiting. The problem is that nfs_pgio_data_destroy() doesn't actually do this; it only frees the memory allocated by nfs_generic_pgio(). Ditto for pnfs_do_read()... Fix in both cases is to add a call to hdr->release(hdr). Cc: stable@vger.kernel.org Signed-off-by: Trond Myklebust <trond.myklebust@primarydata.com>
2015-06-16NFSv4: Fix stateid recovery on revoked delegationsTrond Myklebust
Ensure that we fix the non-NULL stateid case as well. Signed-off-by: Trond Myklebust <trond.myklebust@primarydata.com>
2015-06-16Recover from stateid-type error on SETATTROlga Kornievskaia
Client can receives stateid-type error (eg., BAD_STATEID) on SETATTR when delegation stateid was used. When no open state exists, in case of application calling truncate() on the file, client has no state to recover and fails with EIO. Instead, upon such error, return the bad delegation and then resend the SETATTR with a zero stateid. Signed-off: Olga Kornievskaia <kolga@netapp.com> Signed-off-by: Trond Myklebust <trond.myklebust@primarydata.com>
2015-06-16nfs: Fix showing truncated fsid/dev in, /proc/net/nfsfs/volumesKinglong Mee
A truncated fsid showing from /proc/fs/nfsfs/volumes as, NV SERVER PORT DEV FSID FSC v4 c0a80881 801 0:43 34931f044c2a439b no It should be as, NV SERVER PORT DEV FSID FSC v4 c0a80881 801 0:43 34931f044c2a439b:954c5d830fa4be8c no The max buffer length for storing "%llx:%llx" format should be 16 + 1 + 16 + 1 = 34 (16 for %llx, 1 for ':', 1 for '\0'). Also, for storing "%u:%u" of MAJOR() and MINOR() should be 8 + 1 + 3 + 1 = 13 (8 for 2^24, 1 for ':', 3 for 2^8, 1 for '\0'). v2, add comments for dev/fsid buffer and use sizeof in snprintf. Signed-off-by: Kinglong Mee <kinglongmee@gmail.com> Signed-off-by: Trond Myklebust <trond.myklebust@primarydata.com>
2015-06-16nfs: make nfs4_init_uniform_client_string use a dynamically allocated bufferJeff Layton
Change the uniform client string generator to dynamically allocate the NFSv4 client name string buffer. With this patch, we can eliminate the buffers that are embedded within the "args" structs and simply use the name string that is hanging off the client. This uniform string case is a little simpler than the nonuniform since we don't need to deal with RCU, but we do have two different cases, depending on whether there is a uniquifier or not. Signed-off-by: Jeff Layton <jeff.layton@primarydata.com> Signed-off-by: Trond Myklebust <trond.myklebust@primarydata.com>
2015-06-16nfs: make nfs4_init_nonuniform_client_string use a dynamically allocated bufferJeff Layton
The way the *_client_string functions work is a little goofy. They build the string in an on-stack buffer and then use kstrdup to copy it. This is not only stack-heavy but artificially limits the size of the client name string. Change it so that we determine the length of the string, allocate it and then scnprintf into it. Since the contents of the nonuniform string depend on rcu-managed data structures, it's possible that they'll change between when we allocate the string and when we go to fill it. If that happens, free the string, recalculate the length and try again. If it the mismatch isn't resolved on the second try then just give up and return -EINVAL. Signed-off-by: Jeff Layton <jeff.layton@primarydata.com> Signed-off-by: Trond Myklebust <trond.myklebust@primarydata.com>
2015-06-16nfs: update maxsz values for SETCLIENTID and EXCHANGE_IDJeff Layton
The spec allows for up to NFS4_OPAQUE_LIMIT (1k). While we'll almost certainly never use that much, these ops are generally the only ones in the compound so we might as well allow for them to be that large. Also, the existing code didn't add in a word for the opaque length field for either name string. Fix that while we're in there. Signed-off-by: Jeff Layton <jeff.layton@primarydata.com> Signed-off-by: Trond Myklebust <trond.myklebust@primarydata.com>
2015-06-16nfs: convert setclientid and exchange_id encoders to use clp->cl_owner_idJeff Layton
...instead of buffers that are part of their arg structs. We already hold a reference to the client, so we might as well use the allocated buffer. In the event that we can't allocate the clp->cl_owner_id, then just return -ENOMEM. Note too that we switch from a GFP_KERNEL allocation here to GFP_NOFS. It's possible we could end up trying to do a SETCLIENTID or EXCHANGE_ID in order to reclaim some memory, and the GFP_KERNEL allocations in the existing code could cause recursion back into NFS reclaim. Signed-off-by: Jeff Layton <jeff.layton@primarydata.com> Signed-off-by: Trond Myklebust <trond.myklebust@primarydata.com>
2015-06-16pnfs/flexfiles: use swap() in ff_layout_sort_mirrors()Fabian Frederick
Use kernel.h macro definition. Thanks to Julia Lawall for Coccinelle scripting support. Signed-off-by: Fabian Frederick <fabf@skynet.be> Signed-off-by: Trond Myklebust <trond.myklebust@primarydata.com>
2015-06-11NFS: Ensure that we update the sequence id under the slot table lockTrond Myklebust
Fix a callback slot table regression. Fixes: e937ee714b2d ("nfs: Only update callback sequnce id when CB_SEQUENCE success") Cc: Kinglong Mee <kinglongmee@gmail.com> Signed-off-by: Trond Myklebust <trond.myklebust@primarydata.com>
2015-06-11nfs: Initialize cb_sequenceres information before validate_seqid()Kinglong Mee
For a cb_layoutrecall replay, nfsd got CB_SEQUENCE status of zero, but all informations of cb_sequenceres are zero too !!! validate_seqid() return NFS4ERR_RETRY_UNCACHED_REP for a replay, and skip the initlize cb_sequenceres. Signed-off-by: Kinglong Mee <kinglongmee@gmail.com> Signed-off-by: Trond Myklebust <trond.myklebust@primarydata.com>
