path: root/fs/nfs
2005-06-28[PATCH] really remove xattr_acl.hChristoph Hellwig
Looks like it sneaked back with the NFS ACL merge.. Signed-off-by: Christoph Hellwig <hch@lst.de> Cc: Trond Myklebust <trond.myklebust@fys.uio.no> Cc: Neil Brown <neilb@cse.unsw.edu.au> Signed-off-by: Andrew Morton <akpm@osdl.org> Signed-off-by: Linus Torvalds <torvalds@osdl.org>
2005-06-23[PATCH] Remove f_error field from struct fileChristoph Lameter
The following patch removes the f_error field and all checks of f_error. Trond said: f_error was introduced for NFS, and made sense when we were guaranteed always to have a file pointer around when write errors occurred. Since then, we have (for various reasons) had to introduce the nfs_open_context in order to track the file read/write state, and it made sense to move our f_error tracking there too. Signed-off-by: Christoph Lameter <christoph@lameter.com> Acked-by: Trond Myklebust <trond.myklebust@fys.uio.no> Signed-off-by: Andrew Morton <akpm@osdl.org> Signed-off-by: Linus Torvalds <torvalds@osdl.org>
2005-06-22[PATCH] NFS: Add debugging code to NFSv4 readdirTrond Myklebust
Signed-off-by: Trond Myklebust <Trond.Myklebust@netapp.com>
2005-06-22[PATCH] NFSv4: Map a couple of NFSv4 errors to EINVAL.Manoj Naik
This shows up on running tar over NFSv4. Signed-off-by: Manoj Naik <manoj@almaden.ibm.com> Signed-off-by: Trond Myklebust <Trond.Myklebust@netapp.com>
2005-06-22[PATCH] NFSv4: add support for rdattr_error in NFSv4 readdir requests.Manoj Naik
Request RDATTR_ERROR as an attribute in readdir to distinguish between a directory being within an absent filesystem or one (or more) of its entries. Signed-off-by: Manoj Naik <manoj@almaden.ibm.com> Signed-off-by: Trond Myklebust <Trond.Myklebust@netapp.com>
2005-06-22[PATCH] NFSv4: Clean up nfs4 lock state accountingTrond Myklebust
Ensure that lock owner structures are not released prematurely. Signed-off-by: Trond Myklebust <Trond.Myklebust@netapp.com>
2005-06-22[PATCH] NFS: Replace nfs_page insertion sort with a radix sortTrond Myklebust
2005-06-22[PATCH] NFS: Make searching and waiting on busy writeback requests more ↵Trond Myklebust
efficient. Basically copies the VFS's method for tracking writebacks and applies it to the struct nfs_page. Signed-off-by: Trond Myklebust <Trond.Myklebust@netapp.com>
2005-06-22[PATCH] NFS: Write optimization for short files and small O_SYNC writes.Trond Myklebust
Use stable writes if we can see that we are only going to put a single write on the wire. Signed-off-by: Trond Myklebust <Trond.Myklebust@netapp.com>
2005-06-22[PATCH] NFS: Ensure that fstat() always returns the correct mtimeTrond Myklebust
Even if the file is open for writes. Signed-off-by: Trond Myklebust <Trond.Myklebust@netapp.com>
2005-06-22[PATCH] NFS: Cleanup of caching code, and slight optimization of writes.Trond Myklebust
Unless we're doing O_APPEND writes, we really don't care about revalidating the file length. Just make sure that we catch any page cache invalidations. Signed-off-by: Trond Myklebust <Trond.Myklebust@netapp.com>
2005-06-22[PATCH] NFS: Fix the file size revalidationTrond Myklebust
Instead of looking at whether or not the file is open for writes before we accept to update the length using the server value, we should rather be looking at whether or not we are currently caching any writes. Failure to do so means in particular that we're not updating the file length correctly after obtaining a POSIX or BSD lock. Signed-off-by: Trond Myklebust <Trond.Myklebust@netapp.com>
2005-06-22[PATCH] NFSv4: Fix up races in nfs4_proc_setattr()Trond Myklebust
If we do not hold a valid stateid that is open for writes, there is little point in doing an extra open of the file, as the RFC does not appear to mandate this... Make setattr use the correct stateid if we're holding mandatory byte range locks. Signed-off-by: Trond Myklebust <Trond.Myklebust@netapp.com>
2005-06-22[PATCH] NFSv4: Ensure that propagate NFSv4 state errors to the reclaim codeTrond Myklebust
2005-06-22[PATCH] NFS: Clean up readdir changes.Trond Myklebust
2005-06-22[PATCH] NFS: Hide NFS server-generated readdir cookies from userlandOlivier Galibert
NFSv3 currently returns the unsigned 64-bit cookie directly to userspace. The following patch causes the kernel to generate loff_t offsets for the benefit of userland. The current server-generated READDIR cookie is cached in the nfs_open_context instead of in filp->f_pos, so we still end up work correctly under directory insertions/deletion. Signed-off-by: Olivier Galibert <galibert@pobox.com> Signed-off-by: Trond Myklebust <Trond.Myklebust@netapp.com>
2005-06-22[PATCH] NFSv4: Fix an Oops in the callback code.Trond Myklebust
The changeset "trond.myklebust@fys.uio.no|ChangeSet|20050322152404|16979" (RPC: Ensure XDR iovec length is initialized correctly in call_header) causes the NFSv4 callback code to BUG() due to an incorrectly initialized scratch buffer. Signed-off-by: Trond Myklebust <Trond.Myklebust@netapp.com>
2005-06-22[PATCH] NFSv4: Fix build warningReuben Farrelly
From: Reuben Farrelly <reuben-lkml@reub.net> With gcc-4.0: fs/nfs/nfs4proc.c:2976: error: static declaration of 'nfs4_file_inode_operations' follows non-static declaration fs/nfs/nfs4_fs.h:179: error: previous declaration of 'nfs4_file_inode_operations' was here Signed-off-by: Andrew Morton <akpm@osdl.org> Signed-off-by: Trond Myklebust <Trond.Myklebust@netapp.com>
2005-06-22[PATCH] NFSv4: empty array fixAndrew Morton
Older gcc's don't like this. fs/nfs/nfs4proc.c:2194: field `data' has incomplete type Signed-off-by: Andrew Morton <akpm@osdl.org> Signed-off-by: Trond Myklebust <Trond.Myklebust@netapp.com>
2005-06-22[PATCH] NFSv4: fs/nfs/nfs4proc.c: small simplificationAdrian Bunk
The Coverity checker noticed that such a simplification was possible. Signed-off-by: Adrian Bunk <bunk@stusta.de> Signed-off-by: Trond Myklebust <Trond.Myklebust@netapp.com>
2005-06-22[PATCH] fix nfsacl pointer arithmetic and pg_class initialization bugsAndreas Gruenbacher
* Pointer arithmetic bug: p is in word units. This fixes a memory corruption with big acls. * Initialize pg_class to prevent a NULL pointer access. Signed-off-by: Andreas Gruenbacher <agruen@suse.de> Signed-off-by: Trond Myklebust <Trond.Myklebust@netapp.com>
2005-06-22[PATCH] NFS: Fix up v3 ACL caching codeTrond Myklebust
Initialize the inode cache values correctly. Clean up __nfs3_forget_cached_acls() Signed-off-by: Trond Myklebust <Trond.Myklebust@netapp.com>
2005-06-22[PATCH] NFS: Cache the NFSv3 acls.Andreas Gruenbacher
Attach acls to inodes in the icache to avoid unnecessary GETACL RPC round-trips. As long as the client doesn't retrieve any acls itself, only the default acls of exiting directories and the default and access acls of new directories will end up in the cache, which preserves some memory compared to always caching the access and default acl of all files. Signed-off-by: Andreas Gruenbacher <agruen@suse.de> Acked-by: Olaf Kirch <okir@suse.de> Signed-off-by: Andrew Morton <akpm@osdl.org> Signed-off-by: Trond Myklebust <Trond.Myklebust@netapp.com>
2005-06-22[PATCH] NFS: Fix handling of the umask when an NFSv3 default acl is present.Andreas Gruenbacher
NFSv3 has no concept of a umask on the server side: The client applies the umask locally, and sends the effective permissions to the server. This behavior is wrong when files are created in a directory that has a default ACL. In this case, the umask is supposed to be ignored, and only the default ACL determines the file's effective permissions. Usually its the server's task to conditionally apply the umask. But since the server knows nothing about the umask, we have to do it on the client side. This patch tries to fetch the parent directory's default ACL before creating a new file, computes the appropriate create mode to send to the server, and finally sets the new file's access and default acl appropriately. Many thanks to Buck Huppmann <buchk@pobox.com> for sending the initial version of this patch, as well as for arguing why we need this change. Signed-off-by: Andreas Gruenbacher <agruen@suse.de> Acked-by: Olaf Kirch <okir@suse.de> Signed-off-by: Andrew Morton <akpm@osdl.org> Signed-off-by: Trond Myklebust <Trond.Myklebust@netapp.com>
2005-06-22[PATCH] NFS: Add support for NFSv3 ACLsAndreas Gruenbacher
This adds acl support fo nfs clients via the NFSACL protocol extension, by implementing the getxattr, listxattr, setxattr, and removexattr iops for the system.posix_acl_access and system.posix_acl_default attributes. This patch implements a dumb version that uses no caching (and thus adds some overhead). (Another patch in this patchset adds caching as well.) Signed-off-by: Andreas Gruenbacher <agruen@suse.de> Acked-by: Olaf Kirch <okir@suse.de> Signed-off-by: Andrew Morton <akpm@osdl.org> Signed-off-by: Trond Myklebust <Trond.Myklebust@netapp.com>
2005-06-22[PATCH] RPC: [PATCH] improve rpcauthauth_create error returnsJ. Bruce Fields
Currently we return -ENOMEM for every single failure to create a new auth. This is actually accurate for auth_null and auth_unix, but for auth_gss it's a bit confusing. Allow rpcauth_create (and the ->create methods) to return errors. With this patch, the user may sometimes see an EINVAL instead. Whee. Signed-off-by: J. Bruce Fields <bfields@citi.umich.edu> Signed-off-by: Trond Myklebust <Trond.Myklebust@netapp.com>
2005-06-22[PATCH] NFSv4: client-side caching NFSv4 ACLsJ. Bruce Fields
Add nfs4_acl field to the nfs_inode, and use it to cache acls. Only cache acls of size up to a page. Also prepare for up to a page of acl data even when the user doesn't pass in a buffer, as when they want to get the acl length to decide what size buffer to allocate. Signed-off-by: J. Bruce Fields <bfields@citi.umich.edu> Signed-off-by: Trond Myklebust <Trond.Myklebust@netapp.com>
2005-06-22[PATCH] NFSv4: ACL support for the NFSv4 client: writeJ. Bruce Fields
Client-side write support for NFSv4 ACLs. Signed-off-by: J. Bruce Fields <bfields@citi.umich.edu> Signed-off-by: Trond Myklebust <Trond.Myklebust@netapp.com>
2005-06-22[PATCH] NFSv4: Client-side xdr for writing NFSv4 aclsJ. Bruce Fields
Client-side support for NFSv4 acls: xdr encoding and decoding routines for writing acls Signed-off-by: J. Bruce Fields <bfields@citi.umich.edu> Signed-off-by: Trond Myklebust <Trond.Myklebust@netapp.com>
2005-06-22[PATCH] NFSv4: ACL support for the NFSv4 client: readJ. Bruce Fields
Client-side support for NFSv4 ACLs. Exports the raw xdr code via the system.nfs4_acl extended attribute. It is up to userspace to decode the acl (and to provide correctly xdr'd acls on setxattr), and to convert to/from POSIX ACLs if desired. This patch provides only the read support. Signed-off-by: J. Bruce Fields <bfields@citi.umich.edu> Signed-off-by: Trond Myklebust <Trond.Myklebust@netapp.com>
2005-06-22[PATCH] NFSv4: Client-side xdr for reading NFSv4 aclsJ. Bruce Fields
Client-side support for NFSv4 acls: xdr encoding and decoding routines for reading acls Signed-off-by: J. Bruce Fields <bfields@citi.umich.edu> Signed-off-by: Trond Myklebust <Trond.Myklebust@netapp.com>
2005-06-22[PATCH] NFSv4: fix fattr size calculationsJ. Bruce Fields
Make nfs4 fattr size calculations more explicit, revising them downward a bit in the process. Signed-off-by: J. Bruce Fields <bfields@citi.umich.edu> Signed-off-by: Trond Myklebust <Trond.Myklebust@netapp.com>
2005-06-22[PATCH] NFSv4: Add {get,set,list}xattr methods for nfs4J. Bruce Fields
Add {get,set,list}xattr methods for nfs4. The new methods are no-ops, to be used by subsequent ACL patch. Signed-off-by: J. Bruce Fields <bfields@citi.umich.edu> Signed-off-by: Trond Myklebust <Trond.Myklebust@netapp.com>
2005-06-22[PATCH] NFS: Add hooks to allow common NFS attribute code to clear cached aclsTrond Myklebust
2005-06-22[PATCH] NFS: Allow NFS versions to support different sets of inode operations.J. Bruce Fields
ACL support will require supporting additional inode operations in v4 (getxattr, setxattr, listxattr). This patch allows different protocol versions to support different inode operations by adding a file_inode_ops to the nfs_rpc_ops (to match the existing dir_inode_ops). Signed-off-by: J. Bruce Fields <bfields@citi.umich.edu> Signed-off-by: Trond Myklebust <Trond.Myklebust@netapp.com>
2005-06-22[PATCH] NFS: cleanup: shrink struct nfs_open_contextTrond Myklebust
Remove the wait queue, and replace the functions that depended on it with wait_on_bit(). Signed-off-by: Trond Myklebust <Trond.Myklebust@netapp.com>
2005-06-22[PATCH] NFS: Remove unused NFS inode field readdir_timestamp.Trond Myklebust
2005-06-22[PATCH] NFS: Header file cleanup...Trond Myklebust
- Move NFSv4 state definitions into a private header file. - Clean up gunk in nfs_fs.h Signed-off-by: Trond Myklebust <Trond.Myklebust@netapp.com>
2005-06-22[PATCH] NFS: Kill annoying mount version mismatch printksTrond Myklebust
Ensure that we fix up the missing fields in the nfs_mount_data with sane defaults for older versions of mount, and return errors in the cases where we cannot. Convert a bunch of annoying warnings into dprintks() Return -EPROTONOSUPPORT rather than EIO if mount() tries to set NFSv3 without it actually being compiled in. Signed-off-by: Trond Myklebust <Trond.Myklebust@netapp.com>
2005-06-22[PATCH] RPC: Make rpc_create_client() destroy the transport on failure.Trond Myklebust
This saves us a couple of lines of cleanup code for each call. Signed-off-by: Trond Myklebust <Trond.Myklebust@netapp.com>
2005-06-13[PATCH] NFS: Ensure that we revalidate the cached file length for ↵Trond Myklebust
llseek(SEEK_END) This fixes a data corruption error for mail delivery applications that expect to be able to do posix locking and then append writes on NFS. Signed-off-by: Trond Myklebust <Trond.Myklebust@netapp.com> Signed-off-by: Linus Torvalds <torvalds@osdl.org>
2005-06-07[PATCH] NFS: Fix lookup intent handlingTrond Myklebust
We should never apply a lookup intent to anything other than the last path component in an open(), create() or access() call. Introduce the helper nfs_lookup_check_intent() which always returns zero if LOOKUP_CONTINUE or LOOKUP_PARENT are set, and returns the intent flags if we're on the last component of the lookup. By doing so, we fix a bug in open(O_EXCL), where we may end up optimizing away a real lookup of the parent directory. Problem noticed by Linda Dunaphant <linda.dunaphant@ccur.com> Signed-off-by: Trond Myklebust <Trond.Myklebust@netapp.com> Signed-off-by: Linus Torvalds <torvalds@osdl.org>
2005-05-05[PATCH] make some things staticAdrian Bunk
This patch makes some needlessly global identifiers static. Signed-off-by: Adrian Bunk <bunk@stusta.de> Acked-by: Arjan van de Ven <arjanv@infradead.org> Acked-by: Trond Myklebust <trond.myklebust@fys.uio.no> Signed-off-by: Andrew Morton <akpm@osdl.org> Signed-off-by: Linus Torvalds <torvalds@osdl.org>
