patch 5d47a35600270e7115061cb1320ee60ae9bcb6b8 in mainline.
If the inode is flagged as having an invalid mapping, then we can't rely on
the PageUptodate() flag. Ensure that we don't use the "anti-fragmentation"
write optimisation in nfs_updatepage(), since that will cause NFS to write
out areas of the page that are no longer guaranteed to be up to date.
A potential corruption could occur in the following scenario:
client 1 client 2
fd=open("f",O_CREAT|O_WRONLY,0644);
write(fd,"fubar\n",6); // cache last page
close(fd);
fd=open("f",O_WRONLY|O_APPEND);
write(fd,"foo\n",4);
close(fd);
write(fd,"bar\n",4);
close(fd);
The bug may lead to the file "f" reading 'fubar\n\0\0\0\nbar\n' because
client 2 does not update the cached page after re-opening the file for
write. Instead it keeps it marked as PageUptodate() until someone calls
invalidate_inode_pages2() (typically by calling read()).
The bug was introduced by commit 44b11874ff583b6e766a05856b04f3c492c32b84
"NFS: Separate metadata and page cache revalidation mechanisms"
Signed-off-by: Trond Myklebust <Trond.Myklebust@netapp.com>
Sharing the open sequence queue causes a deadlock when we try to take
both a lock sequence id and and open sequence id.
This fixes the regression reported by Dimitri Puzin and Jeff Garzik: See
http://bugzilla.kernel.org/show_bug.cgi?id=9712
for details.
Reported-and-tested-by: Dimitri Puzin <bugs@psycast.de>
Tested-by: Jeff Garzik <jgarzik@redhat.com>
NFSv4 file locking is currently completely broken since it doesn't respect
the OPEN sequencing when it is given an unconfirmed lock_owner and needs to
do an open_to_lock_owner. Worse: it breaks the sunrpc rules by doing a
GFP_KERNEL allocation inside an rpciod callback.
Fix is to preallocate the open seqid structure in nfs4_alloc_lockdata if we
see that the lock_owner is unconfirmed.
Then, in nfs4_lock_prepare() we wait for either the open_seqid, if
the lock_owner is still unconfirmed, or else fall back to waiting on the
standard lock_seqid.
RFC3530 states that the open_owner is confirmed if and only if the client
sends an OPEN_CONFIRM request with the appropriate sequence id and stateid
within the lease period.
Erez Zadok reports:
[ INFO: possible circular locking dependency detected ]
2.6.24-rc6-unionfs2 #80
umount.nfs4/4017 is trying to acquire lock:
(&(&clp->cl_renewd)->work){--..}, at: [<c0223e53>]
__cancel_work_timer+0x83/0x17f
but task is already holding lock:
(&clp->cl_sem){----}, at: [<f8879897>] nfs4_kill_renewd+0x17/0x29 [nfs]
which lock already depends on the new lock.
the existing dependency chain (in reverse order) is:
-> #1 (&clp->cl_sem){----}:
[<c0230699>] __lock_acquire+0x9cc/0xb95
[<c0230c39>] lock_acquire+0x5f/0x78
[<c0397cb8>] down_read+0x3a/0x4c
[<f88798e6>] nfs4_renew_state+0x1c/0x1b8 [nfs]
[<c0223821>] run_workqueue+0xd9/0x1ac
[<c0224220>] worker_thread+0x7a/0x86
[<c0226b49>] kthread+0x3b/0x62
[<c02033a3>] kernel_thread_helper+0x7/0x10
[<ffffffff>] 0xffffffff
-> #0 (&(&clp->cl_renewd)->work){--..}:
[<c0230589>] __lock_acquire+0x8bc/0xb95
[<c0223e87>] __cancel_work_timer+0xb7/0x17f
[<c0223f5a>] cancel_delayed_work_sync+0xb/0xd
[<f887989e>] nfs4_kill_renewd+0x1e/0x29 [nfs]
[<f885a8f6>] nfs_free_client+0x37/0x9e [nfs]
[<f885ab20>] nfs_put_client+0x5d/0x62 [nfs]
[<f885ab9a>] nfs_free_server+0x75/0xae [nfs]
[<f8862672>] nfs4_kill_super+0x27/0x2b [nfs]
[<c0258aab>] deactivate_super+0x3f/0x51
[<c0269668>] mntput_no_expire+0x42/0x67
[<c025d0e4>] path_release_on_umount+0x15/0x18
[<c0269d30>] sys_umount+0x1a3/0x1cb
[<c0269d71>] sys_oldumount+0x19/0x1b
[<c02026ca>] sysenter_past_esp+0x5f/0xa5
Looking at the code, it would seem that taking the clp->cl_sem in
nfs4_kill_renewd is completely redundant, since we're already guaranteed to
have exclusive access to the nfs_client (we're shutting down).
Sigh... commit 4584f520e1f773082ef44ff4f8969a5d992b16ec (NFS: Fix NFS
mountpoint crossing...) had a slight flaw: server can be NULL if sget()
returned an existing superblock.
Fix the fix by dereferencing s->s_fs_info.
Thanks to Coverity/Adrian Bunk and Frank Filz for spotting the bug.
(See http://bugzilla.kernel.org/show_bug.cgi?id=9647)
Also add in the same namespace Oops fix for NFSv4 in both the mountpoint
crossing case, and the referral case.
Ensure that the dummy 'root dentry' is invisible to d_find_alias(). If not,
then it may be spliced into the tree if a parent directory from the same
filesystem gets mounted at a later time.
This reverts commit b9148c6b80d802dbc2a7530b29915a80432e50c7.
On Wed, 12 Dec 2007 10:57:30 -0500, Chuck Lever wrote
> commit b9148c6b should be reverted. It was recently forward-ported
> from some years-old patches, and is clearly not needed now.
> On Dec 11, 2007, at 5:21 PM, Adrian Bunk wrote:
>> This code became dead after commit
>> (which BTW doesn't seem to have changed any behaviour) and can
>> therefore
>> be removed.
>> Spotted by the Coverity checker.
>> Signed-off-by: Adrian Bunk <bunk@kernel.org>
>> --- linux-2.6/fs/nfs/direct.c.old 2007-12-02 21:54:53.000000000 +0100
>> +++ linux-2.6/fs/nfs/direct.c 2007-12-02 21:55:10.000000000 +0100
>> @@ -897,15 +897,12 @@ ssize_t nfs_file_direct_write(struct kio
>> if (!count)
>> goto out; /* return 0 */
>> retval = -EINVAL;
>> if ((ssize_t) count < 0)
>> goto out;
>> - retval = 0;
>> - if (!count)
>> - goto out;
>> retval = nfs_sync_mapping(mapping);
>> if (retval)
>> goto out;
>> retval = nfs_direct_write(iocb, iov, nr_segs, pos, count);
Neil Brown said:
> Hi Trond,
> We found that a machine which made moderately heavy use of
> 'automount' was leaking some nfs data structures - particularly the
> 4K allocated by rpc_alloc_iostats.
> It turns out that this only happens with filesystems with -onolock
> set.
> The problem is that if NFS_MOUNT_NONLM is set, nfs_start_lockd doesn't
> set server->destroy, so when the filesystem is unmounted, the
> ->client_acl is not shutdown, and so several resources are still
> held. Multiple mount/umount cycles will slowly eat away memory
> several pages at a time.
Acked-by: NeilBrown <neilb@suse.de>
The check that was added to nfs_xdev_get_sb() to work around broken
servers, works fine for NFSv2, but causes mountpoint crossing on NFSv3 to
always return ESTALE.
Simplify calling sequence of nfs_direct_{read,write}_schedule(), and
rename them to reflect their new role.
Signed-off-by: Chuck Lever <chuck.lever@oracle.com>
A zero byte count direct write request should be a successful no-op, not an
error.
Signed-off-by: Chuck Lever <cel@netapp.com>
Allow applications to perform asynchronous scatter-gather direct I/O
to NFS files.
Add helpers that iterate over multi-segment iovecs. These will
be used to support multi-segment scatter/gather direct I/O in a
later patch.
Every file should include the headers containing the prototypes for its global
functions (in this case nfs_access_cache_shrinker()).
Cc: Trond Myklebust <trond.myklebust@fys.uio.no>
Cc: "J. Bruce Fields" <bfields@fieldses.org>
nfs_wb_page_priority() can now become static.
While testing a kernel based upon ecd744eec3aa8bbc949ec04ed3fbf7ecb2958a0e
(with wrong boot arguments), I got the following bad page state entry while
NFS was trying to mount it's rootfs:
IP-Config: Complete:
device=eth0, addr=192.168.1.101, mask=255.255.255.0, gw=255.255.255.255,
host=192.168.1.101, domain=, nis-domain=(none),
bootserver=192.168.1.100, rootserver=192.168.1.100, rootpath=
Looking up port of RPC 100003/2 on 192.168.1.100
rpcbind: server 192.168.1.100 not responding, timed out
Root-NFS: Unable to get nfsd port number from server, using default
Looking up port of RPC 100005/1 on 192.168.1.100
Root-NFS: Unable to get mountd port number from server, using default
mount: server 192.168.1.100 not responding, timed out
Root-NFS: Server returned error -5 while mounting /nfs/rootfs/
VFS: Unable to mount root fs via NFS, trying floppy.
Bad page state in process 'swapper'
page:c02b1260 flags:0x00000400 mapping:00000000 mapcount:0 count:0
Trying to fix it up, but a reboot is needed
Backtrace:
[<c0023e34>] (dump_stack+0x0/0x14) from [<c0062570>] (bad_page+0x70/0xac)
[<c0062500>] (bad_page+0x0/0xac) from [<c0064914>] (free_hot_cold_page+0x80/0x178)
[<c0064894>] (free_hot_cold_page+0x0/0x178) from [<c0064a74>] (free_hot_page+0x14/0x18)
[<c0064a60>] (free_hot_page+0x0/0x18) from [<c0067078>] (put_page+0xf8/0x154)
[<c0066f80>] (put_page+0x0/0x154) from [<c007dbc8>] (kfree+0xc8/0xd0)
[<c007db00>] (kfree+0x0/0xd0) from [<c00cbb54>] (nfs_get_sb+0x230/0x710)
[<c00cb924>] (nfs_get_sb+0x0/0x710) from [<c0084334>] (vfs_kern_mount+0x58/0xac)[<c00842dc>] (vfs_kern_mount+0x0/0xac) from [<c00843c0>] (do_kern_mount+0x38/0xf4)
[<c0084388>] (do_kern_mount+0x0/0xf4) from [<c0099c7c>] (do_mount+0x1e8/0x614)
This seems to be caused by use of an uninitialised structure due to NULL
options being passed to nfs_validate_mount_data(). Ensure that the
parsed mount data is always initialised.
(Trond: added fix for the same bug in nfs4_validate_mount_data()).
Hi Trond,
I have discovered that the BUG_ON in nfs_follow_mountpoint:
BUG_ON(IS_ROOT(dentry));
can be triggered by a misbehaving server.
What happens is the client does a lookup and discoveres that the named
directory has a different fsid, so it initiates a mount.
It then performs a GETATTR on the mounted directory and gets a
different fsid again (due to a bug in the NFS server).
This causes nfs_follow_mountpoint to be called on the newly mounted
root, which triggers the BUG_ON.
To duplicate this, have a directory which contains some mountpoints,
and export that directory with the "crossmnt" flag using nfs-utils
1.1.1 (or 1.1.0 I think)
The GETATTR on the root of the mounted filesystem will return the
information for the top exportpoint, while a lookup will return the
correct information. This difference causes the NFS client to BUG.
I think the best way to fix this is to trap this possibility early, so
just before completing the mount in the NFS client, check that it isn't
going to use nfs_mountpoint_inode_operations.
As long as i_op will never change once set (is that true?), this
should be adequately safe.
The following patch shows a possible approach, and it works for me.
i.e. when the NFS server is misbehaving, I get ESTALE on those
mountpoints, while when the NFS server is working correctly, I get
correct behaviour on the client.
NeilBrown
Signed-off-by: Neil Brown <neilb@suse.de>
Since 2.6.18, the superblock sb->s_root has been a dummy dentry with a
dummy inode. This breaks ustat(), which actually uses sb->s_root in a
vfstat() call.
Fix this by making the s_root a dummy alias to the directory inode that was
used when creating the superblock.
Commit eda3cef8dd2b83875affe82595db9d0c278879b2 ("NFS: Fix error
handling in nfs_direct_write_result()") ensured that if a WRITE returns
an error, then data->res.verf->committed is not tested (as it is not
initialised).
Then commit 60fa3f769f7651a60125a0f44e3ffe3246d7cf39 ("NFS: Fix two bugs
in the O_DIRECT write code") inadvertently reverted this while fixing
other problems.
So move the test so that we never examine ->committed in an error case,
and fix a speeling error while we are there.
Cc: Chuck Lever <chuck.lever@oracle.com>
Acked-by: Chuck Lever <chuck.lever@oracle.com>
* git://git.kernel.org/pub/scm/linux/kernel/git/bunk/trivial: (74 commits)
fix do_sys_open() prototype
sysfs: trivial: fix sysfs_create_file kerneldoc spelling mistake
Documentation: Fix typo in SubmitChecklist.
Typo: depricated -> deprecated
Add missing profile=kvm option to Documentation/kernel-parameters.txt
fix typo about TBI in e1000 comment
proc.txt: Add /proc/stat field
small documentation fixes
Fix compiler warning in smount example program from sharedsubtree.txt
docs/sysfs: add missing word to sysfs attribute explanation
documentation/ext3: grammar fixes
Documentation/java.txt: typo and grammar fixes
Documentation/filesystems/vfs.txt: typo fix
include/asm-*/system.h: remove unused set_rmb(), set_wmb() macros
trivial copy_data_pages() tidy up
Fix typo in arch/x86/kernel/tsc_32.c
file link fix for Pegasus USB net driver help
remove unused return within void return function
Typo fixes retrun -> return
x86 hpet.h: remove broken links
Erez Zadok reports that certain configurations fail to build due to
schedule() TASK_[UN]INTERRUPTIBLE not being declared. Add proper
include files to fix.
Cc: Erez Zadok <ezk@cs.sunysb.edu>
Cc: Trond Myklebust <Trond.Myklebust@netapp.com>
* Convert files to UTF-8.
* Also correct some people's names
(one example is Eißfeldt, which was found in a source file.
Given that the author used an ß at all in a source file
indicates that the real name has in fact a 'ß' and not an 'ss',
which is commonly used as a substitute for 'ß' when limited to
7bit.)
* Correct town names (Goettingen -> Göttingen)
* Update Eberhard Mönkeberg's address (http://lkml.org/lkml/2007/1/8/313)
Signed-off-by: Jan Engelhardt <jengelh@gmx.de>
Otherwise, we do end up breaking close-to-open semantics. We also end up
breaking some of the silly-rename tests in Connectathon on some setups.
Please refer to the bug-report at
http://bugzilla.linux-nfs.org/show_bug.cgi?id=150
lookup() and sillyrename() can race one another because the sillyrename()
completion cannot take the parent directory's inode->i_mutex since the
latter may be held by whoever is calling dput().
We therefore have little option but to add extra locking to ensure that
nfs_lookup() and nfs_atomic_open() do not race with the sillyrename
completion.
If somebody has looked up the sillyrenamed file in the meantime, we just
transfer the sillydelete information to the new dentry.
This patch fixes a regression that was introduced by commit
44dd151d5c21234cc534c47d7382f5c28c3143cd
We cannot zero the user page in nfs_mark_uptodate() any more, since
a) We'd be modifying the page without holding the page lock
b) We can race with other updates of the page, most notably
because of the call to nfs_wb_page() in nfs_writepage_setup().
Instead, we do the zeroing in nfs_update_request() if we see that we're
creating a request that might potentially be marked as up to date.
Thanks to Olivier Paquet for reporting the bug and providing a test-case.
If the ATTR_KILL_S*ID bits are set then any mode change is only for clearing
the setuid/setgid bits. For NFS, skip the mode change and let the server
handle it.
Signed-off-by: Jeff Layton <jlayton@redhat.com>
Slab constructors currently have a flags parameter that is never used. And
the order of the arguments is opposite to other slab functions. The object
pointer is placed before the kmem_cache pointer.
Convert
ctor(void *object, struct kmem_cache *s, unsigned long flags)
to
ctor(struct kmem_cache *s, void *object)
throughout the kernel
[akpm@linux-foundation.org: coupla fixes]
Signed-off-by: Christoph Lameter <clameter@sgi.com>
Count per BDI reclaimable pages; nr_reclaimable = nr_dirty + nr_unstable.
provide BDI constructor/destructor hooks
[akpm@linux-foundation.org: compile fix]
These patches aim to improve balance_dirty_pages() and directly address three
issues:
1) inter device starvation
2) stacked device deadlocks
3) inter process starvation
1 and 2 are a direct result from removing the global dirty limit and using
per device dirty limits. By giving each device its own dirty limit is will
no longer starve another device, and the cyclic dependancy on the dirty limit
is broken.
In order to efficiently distribute the dirty limit across the independant
devices a floating proportion is used, this will allocate a share of the total
limit proportional to the device's recent activity.
3 is done by also scaling the dirty limit proportional to the current task's
recent dirty rate.
This patch:
nfs: remove congestion_end(). It's redundant, clear_bdi_congested() already
wakes the waiters.
[akpm@linux-foundation.org: fix against git-nfs]
[peterz@infradead.org: fix against git-nfs]
Signed-off-by: Nick Piggin <npiggin@suse.de>
Acked-by: Trond Myklebust <Trond.Myklebust@netapp.com>
* 'locks' of git://linux-nfs.org/~bfields/linux:
nfsd: remove IS_ISMNDLCK macro
Rework /proc/locks via seq_files and seq_list helpers
fs/locks.c: use list_for_each_entry() instead of list_for_each()
NFS: clean up explicit check for mandatory locks
AFS: clean up explicit check for mandatory locks
9PFS: clean up explicit check for mandatory locks
GFS2: clean up explicit check for mandatory locks
Cleanup macros for distinguishing mandatory locks
Documentation: move locks.txt in filesystems/
locks: add warning about mandatory locking races
Documentation: move mandatory locking documentation to filesystems/
locks: Fix potential OOPS in generic_setlease()
Use list_first_entry in locks_wake_up_blocks
locks: fix flock_lock_file() comment
Memory shortage can result in inconsistent flocks state
locks: kill redundant local variable
locks: reverse order of posix_locks_conflict() arguments
We were intending to put the previous instance of delegation->cred
before setting a new one.
Thanks to David Howells for spotting this.
The __mandatory_lock(inode) macro makes the same check, but makes the code
more readable.
Signed-off-by: Pavel Emelyanov <xemul@openvz.org>
This boot parameter will allow legacy 32-bit applications which call stat()
to continue to function even if the NFSv3/v4 server uses 64-bit inode
numbers.
If the cached attributes match the ones supplied in the fattr, then assume
we've revalidated the inode.
We're failing basic test6 against Linux servers because they lack a correct
change attribute. The fix is to assume that we always want to invalidate
the readdir caches when we call update_changeattr and/or
nfs_post_op_update_inode on a directory.
nfs_post_op_update_inode() is really only meant to be used if we expect the
inode and its attributes to have changed in some way.
- NFS_READTIME, NFS_CHANGE_ATTR are completely unused.
- Inline the few remaining uses of NFS_ATTRTIMEO, and remove.
If necessary, the caches will get zapped under normal revalidation.
LOOKUP returns the directory post-op attributes whether or not the
operation was successful.
