path: root/fs/nfsd/nfs4callback.c
2009-09-15nfsd41: modify nfsd4.1 backchannel to use new xprt classAlexandros Batsakis
This patch enables the use of the nfsv4.1 backchannel. Signed-off-by: Alexandros Batsakis <batsakis@netapp.com> [initialize rpc_create_args.bc_xprt too] Signed-off-by: Benny Halevy <bhalevy@panasas.com> Signed-off-by: J. Bruce Fields <bfields@citi.umich.edu>
2009-09-15nfsd41: Backchannel: Implement cb_recall over NFSv4.1Ricardo Labiaga
Signed-off-by: Ricardo Labiaga <Ricardo.Labiaga@netapp.com> [nfsd41: cb_recall callback] [Share v4.0 and v4.1 back channel xdr] Signed-off-by: Andy Adamson <andros@netapp.com> Signed-off-by: Ricardo Labiaga <ricardo.labiaga@netapp.com> Signed-off-by: Benny Halevy <bhalevy@panasas.com> [Share v4.0 and v4.1 back channel xdr] Signed-off-by: Andy Adamson <andros@netapp.com> Signed-off-by: Benny Halevy <bhalevy@panasas.com> [nfsd41: use nfsd4_cb_sequence for callback minorversion] [nfsd41: conditionally decode_sequence in nfs4_xdr_dec_cb_recall] Signed-off-by: Benny Halevy <bhalevy@panasas.com> [nfsd41: Backchannel: Add sequence arguments to callback RPC arguments] Signed-off-by: Ricardo Labiaga <Ricardo.Labiaga@netapp.com> [pulled-in definition of nfsd4_cb_done] Signed-off-by: Benny Halevy <bhalevy@panasas.com> Signed-off-by: J. Bruce Fields <bfields@citi.umich.edu>
2009-09-15nfsd41: Backchannel: cb_sequence callbackBenny Halevy
Implement the cb_sequence callback conforming to draft-ietf-nfsv4-minorversion1 Note: highest slot id and target highest slot id do not have to be 0 as was previously implemented. They can be greater than what the nfs server sent if the client supports a larger slot table on the backchannel. At this point we just ignore that. Signed-off-by: Benny Halevy <bhalevy@panasas.com> Signed-off-by: Ricardo Labiaga <Ricardo.Labiaga@netapp.com> [Rework the back channel xdr using the shared v4.0 and v4.1 framework.] Signed-off-by: Andy Adamson <andros@netapp.com> [fixed indentation] Signed-off-by: Benny Halevy <bhalevy@panasas.com> [nfsd41: use nfsd4_cb_sequence for callback minorversion] Signed-off-by: Benny Halevy <bhalevy@panasas.com> [nfsd41: fix verification of CB_SEQUENCE highest slot id[ Signed-off-by: Benny Halevy <bhalevy@panasas.com> [nfsd41: Backchannel: Remove old backchannel serialization] [nfsd41: Backchannel: First callback sequence ID should be 1] Signed-off-by: Ricardo Labiaga <Ricardo.Labiaga@netapp.com> Signed-off-by: Benny Halevy <bhalevy@panasas.com> [nfsd41: decode_cb_sequence does not need to actually decode ignored fields] Signed-off-by: Benny Halevy <bhalevy@panasas.com> Signed-off-by: Ricardo Labiaga <Ricardo.Labiaga@netapp.com> Signed-off-by: Benny Halevy <bhalevy@panasas.com> Signed-off-by: J. Bruce Fields <bfields@citi.umich.edu>
2009-09-15nfsd41: Backchannel: Setup sequence informationRicardo Labiaga
Follows the model used by the NFS client. Setup the RPC prepare and done function pointers so that we can populate the sequence information if minorversion == 1. rpc_run_task() is then invoked directly just like existing NFS client operations do. nfsd4_cb_prepare() determines if the sequence information needs to be setup. If the slot is in use, it adds itself to the wait queue. nfsd4_cb_done() wakes anyone sleeping on the callback channel wait queue after our RPC reply has been received. It also sets the task message result pointer to NULL to clearly indicate we're done using it. Signed-off-by: Ricardo Labiaga <Ricardo.Labiaga@netapp.com> [define and initialize cl_cb_seq_nr here] [pulled out unused defintion of nfsd4_cb_done] Signed-off-by: Benny Halevy <bhalevy@panasas.com> Signed-off-by: J. Bruce Fields <bfields@citi.umich.edu>
2009-09-15nfsd41: Backchannel: Add sequence arguments to callback RPC argumentsRicardo Labiaga
Follow the model we use in the client. Make the sequence arguments part of the regular RPC arguments. None of the callbacks that are soon to be implemented expect results that need to be passed back to the caller, so we don't define a separate RPC results structure. For session validation, the cb_sequence decoding will use a pointer to the sequence arguments that are part of the RPC argument. Signed-off-by: Ricardo Labiaga <Ricardo.Labiaga@netapp.com> [define struct nfsd4_cb_sequence here] Signed-off-by: Benny Halevy <bhalevy@panasas.com> Signed-off-by: J. Bruce Fields <bfields@citi.umich.edu>
2009-09-15nfsd41: Backchannel: callback infrastructureAndy Adamson
Keep the xprt used for create_session in cl_cb_xprt. Mark cl_callback.cb_minorversion = 1 and remember the client provided cl_callback.cb_prog rpc program number. Use it to probe the callback path. Use the client's network address to initialize as the callback's address as expected by the xprt creation routines. Define xdr sizes and code nfs4_cb_compound header to be able to send a null callback rpc. Signed-off-by: Andy Adamson<andros@netapp.com> Signed-off-by: Benny Halevy <bhalevy@panasas.com> Signed-off-by: Ricardo Labiaga <Ricardo.Labiaga@netapp.com> [get callback minorversion from fore channel's] Signed-off-by: Benny Halevy <bhalevy@panasas.com> [nfsd41: change bc_sock to bc_xprt] Signed-off-by: Benny Halevy <bhalevy@panasas.com> [pulled definition for cl_cb_xprt] Signed-off-by: Benny Halevy <bhalevy@panasas.com> [nfsd41: set up backchannel's cb_addr] [moved rpc_create_args init to "nfsd: modify nfsd4.1 backchannel to use new xprt class"] Signed-off-by: Benny Halevy <bhalevy@panasas.com> Signed-off-by: J. Bruce Fields <bfields@citi.umich.edu>
2009-09-15nfsd4: use common rpc_cred for all callbacksJ. Bruce Fields
Callbacks are always made using the machine's identity, so we can use a single auth_generic credential shared among callbacks to all clients and let the rpc code take care of the rest. Signed-off-by: J. Bruce Fields <bfields@citi.umich.edu>
2009-09-15nfsd4: fix null dereference creating nfsv4 callback clientJ. Bruce Fields
On setting up the callback to the client, we attempt to use the same authentication flavor the client did. We find an rpc cred to use by calling rpcauth_lookup_credcache(), which assumes that the given authentication flavor has a credentials cache. However, this is not required to be true--in particular, auth_null does not use one. Instead, we should call the auth's lookup_cred() method. Without this, a client attempting to mount using nfsv4 and auth_null triggers a null dereference. Cc: stable@kernel.org Signed-off-by: J. Bruce Fields <bfields@citi.umich.edu>
2009-09-13nfsd4: fix whitespace in NFSPROC4_CLNT_CB_NULL definitionBenny Halevy
2009-08-21nfsd: convert nfs4_cb_conn struct to hold address in sockaddr_storageJeff Layton
...rather than as a separate address and port fields. This will be necessary for implementing callbacks over IPv6. Also, convert gen_callback to use the standard rpcuaddr2sockaddr routine rather than its own private one. Signed-off-by: Jeff Layton <jlayton@redhat.com> Acked-by: Chuck Lever <chuck.lever@oracle.com> Signed-off-by: J. Bruce Fields <bfields@citi.umich.edu>
2009-06-18nfsd41: Backchannel: minorversion support for the back channelAndy Adamson
Prepare to share backchannel code with NFSv4.1. Signed-off-by: Andy Adamson <andros@netapp.com> Signed-off-by: Benny Halevy <bhalevy@panasas.com> Signed-off-by: Ricardo Labiaga <Ricardo.Labiaga@netapp.com> [nfsd41: use nfsd4_cb_sequence for callback minorversion] Signed-off-by: Benny Halevy <bhalevy@panasas.com> Signed-off-by: J. Bruce Fields <bfields@citi.umich.edu>
2009-06-18nfsd41: Backchannel: cleanup nfs4.0 callback encode routinesAndy Adamson
Mimic the client and prepare to share the back channel xdr with NFSv4.1. Bump the number of operations in each encode routine, then backfill the number of operations. Signed-off-by: Andy Adamson <andros@netapp.com> Signed-off-by: Benny Halevy <bhalevy@panasas.com> Signed-off-by: Ricardo Labiaga <Ricardo.Labiaga@netapp.com> Signed-off-by: Benny Halevy <bhalevy@panasas.com> Signed-off-by: J. Bruce Fields <bfields@citi.umich.edu>
2009-05-03nfsd4: make recall callback an asynchronous rpcJ. Bruce Fields
As with the probe, this removes the need for another kthread. Signed-off-by: J. Bruce Fields <bfields@citi.umich.edu>
2009-05-01nfsd4: track recall retries in nfs4_delegationJ. Bruce Fields
Move this out of a local variable into the nfs4_delegation object in preparation for making this an async rpc call (at which point we'll need any state like this in a common object that's preserved across function calls). Signed-off-by: J. Bruce Fields <bfields@citi.umich.edu>
2009-05-01nfsd4: remove unused dl_truncJ. Bruce Fields
There's no point in keeping this field around--it's always zero. (Background: the protocol allows you to tell the client that the file is about to be truncated, as an optimization to save the client from writing back dirty pages that will just be discarded. We don't implement this hint. If we do some day, adding this field back in will be the least of the work involved.) Signed-off-by: J. Bruce Fields <bfields@citi.umich.edu>
2009-05-01nfsd4: eliminate struct nfs4_cb_recallJ. Bruce Fields
The nfs4_cb_recall struct is used only in nfs4_delegation, so its pointer to the containing delegation is unnecessary--we could just use container_of(). But there's no real reason to have this a separate struct at all--just move these fields to nfs4_delegation. Signed-off-by: J. Bruce Fields <bfields@citi.umich.edu>
2009-05-01nfsd4: rename callback struct to cb_connJ. Bruce Fields
I want to use the name for a struct that actually does represent a single callback. (Actually, I've never been sure it helps to a separate struct for the callback information. Some day maybe those fields could just be dumped into struct nfs4_client. I don't know.) Signed-off-by: J. Bruce Fields <bfields@citi.umich.edu>
2009-04-29nfsd4: replace callback thread by asynchronous rpcJ. Bruce Fields
We don't really need a synchronous rpc, and moving to an asynchronous rpc allows us to do without this extra kthread. Signed-off-by: J. Bruce Fields <bfields@citi.umich.edu>
2009-04-29nfsd4: lookup up callback cred only onceJ. Bruce Fields
Lookup the callback cred once and then use it for all subsequent callbacks. Signed-off-by: J. Bruce Fields <bfields@citi.umich.edu>
2009-04-29nfsd4: create rpc callback client from server threadJ. Bruce Fields
The code is a little simpler, and it should be easier to avoid races, if we just do all rpc client creation/destruction from nfsd or laundromat threads and do only the rpc calls themselves asynchronously. The rpc creation doesn't involve any significant waiting (it doesn't call the client, for example), so there's no reason not to do this. Also don't bother destroying the client on failure of the rpc null probe. We may want to retry the probe later anyway. Signed-off-by: J. Bruce Fields <bfields@citi.umich.edu>
2009-04-29nfsd4: set cb_client inside setup_callback_clientJ. Bruce Fields
This is just a minor code simplification. Signed-off-by: J. Bruce Fields <bfields@citi.umich.edu>
2009-04-29nfsd4: set shorter timeoutJ. Bruce Fields
We tried to do something overly complicated with the callback rpc timeouts here. And they're wrong--the result is that by the time a single callback times out, it's already too late to tell the client (using the cb_path_down return to RENEW) that the callback is down. Use a much shorter, simpler timeout. Signed-off-by: J. Bruce Fields <bfields@citi.umich.edu>
2009-03-18nfsd4: move rpc_client setup to a separate functionJ. Bruce Fields
2009-03-18nfsd4: fix do_probe_callback errorsJ. Bruce Fields
The errors returned aren't used. Just return 0 and make them available to a dprintk(). Also, consistently use -ERRNO errors instead of nfs errors. Signed-off-by: J. Bruce Fields <bfields@citi.umich.edu> Reviewed-by: Benny Halevy <bhalevy@panasas.com>
2009-03-18nfsd4: remove use of mutex for file_hashtableJ. Bruce Fields
As part of reducing the scope of the client_mutex, and in order to remove the need for mutexes from the callback code (so that callbacks can be done as asynchronous rpc calls), move manipulations of the file_hashtable under the recall_lock. Update the relevant comments while we're here. Signed-off-by: J. Bruce Fields <bfields@citi.umich.edu> Cc: Alexandros Batsakis <batsakis@netapp.com> Reviewed-by: Benny Halevy <bhalevy@panasas.com>
2009-03-18nfsd4: put_nfs4_client does not require state lockJ. Bruce Fields
Since free_client() is guaranteed to only be called once, and to only touch the client structure itself (not any common data structures), it has no need for the state lock. Signed-off-by: J. Bruce Fields <bfields@citi.umich.edu> Cc: Alexandros Batsakis <batsakis@netapp.com>
2009-03-18nfsd: lock state around put client and delegation in nfsd4_cb_recallAlexandros Batsakis
not having the state locked before putting the client/delegation causes a bug. Also removed the comment from the function header about the state being already locked Signed-off-by: Alexandros Batsakis <batsakis@netapp.com> Signed-off-by: Benny Halevy <bhalevy@panasas.com> Signed-off-by: J. Bruce Fields <bfields@citi.umich.edu>
2009-03-18nfsd4: use helper for copying delegation filehandleJ. Bruce Fields
2009-01-07nfsd: git rid of nfs4_cb_null_ops declarationBenny Halevy
There's no use for nfs4_cb_null_ops's declaration in fs/nfsd/nfs4callback.c Signed-off-by: Benny Halevy <bhalevy@panasas.com> Signed-off-by: J. Bruce Fields <bfields@citi.umich.edu>
2008-12-23nfsd: support callbacks with gss flavorsOlga Kornievskaia
This patch adds server-side support for callbacks other than AUTH_SYS. Signed-off-by: Olga Kornievskaia <aglo@citi.umich.edu> Signed-off-by: J. Bruce Fields <bfields@citi.umich.edu> Signed-off-by: Trond Myklebust <Trond.Myklebust@netapp.com>
2008-12-23rpc: pass target name down to rpc level on callbacksOlga Kornievskaia
The rpc client needs to know the principal that the setclientid was done as, so it can tell gssd who to authenticate to. Signed-off-by: Olga Kornievskaia <aglo@citi.umich.edu> Signed-off-by: J. Bruce Fields <bfields@citi.umich.edu> Signed-off-by: Trond Myklebust <Trond.Myklebust@netapp.com>
2008-09-29nfsd: use nfs client rpc callback programBenny Halevy
since commit ff7d9756b501744540be65e172d27ee321d86103 "nfsd: use static memory for callback program and stats" do_probe_callback uses a static callback program (NFS4_CALLBACK) rather than the one set in clp->cl_callback.cb_prog as passed in by the client in setclientid (4.0) or create_session (4.1). This patches introduces rpc_create_args.prognumber that allows overriding program->number when creating rpc_clnt. Signed-off-by: Benny Halevy <bhalevy@panasas.com> Signed-off-by: J. Bruce Fields <bfields@citi.umich.edu>
2008-09-29nfsd: do_probe_callback should not clear rpc statsBenny Halevy
Now that cb_stats are static (since commit ff7d9756b501744540be65e172d27ee321d86103) there's no need to clear them. Initially I thought it might make sense to do that every callback probing but since the stats are per-program and they are shared between possibly several client callback instances, zeroing them out seems like the wrong thing to do. Note that that commit also introduced a bug since stats.program is also being cleared in the process and it is not restored after the memset as it used to be. Signed-off-by: Benny Halevy <bhalevy@panasas.com> Signed-off-by: J. Bruce Fields <bfields@citi.umich.edu>
2008-09-29nfsd: properly xdr-encode stateid4.seqid as uint32_t for cb_recallBenny Halevy
2008-07-09rpc: bring back cl_chattyOlga Kornievskaia
The cl_chatty flag alows us to control whether a given rpc client leaves "server X not responding, timed out" messages in the syslog. Such messages make sense for ordinary nfs clients (where an unresponsive server means applications on the mountpoint are probably hanging), but not for the callback client (which can fail more commonly, with the only result just of disabling some optimizations). Previously cl_chatty was removed, do to lack of users; reinstate it, and use it for the nfsd's callback client. Signed-off-by: J. Bruce Fields <bfields@citi.umich.edu> Signed-off-by: Trond Myklebust <Trond.Myklebust@netapp.com>
2008-05-18nfsd: reorder printk in do_probe_callback to avoid use-after-freeJ. Bruce Fields
We're currently dereferencing the client after we drop our reference count to it. Signed-off-by: J. Bruce Fields <bfields@citi.umich.edu>
2008-04-30fs: replace remaining __FUNCTION__ occurrencesHarvey Harrison
2008-04-23nfsd: use static memory for callback program and statsOlga Kornievskaia
There's no need to dynamically allocate this memory, and doing so may create the possibility of races on shutdown of the rpc client. (We've witnessed it only after adding rpcsec_gss support to the server, after which the rpc code can send destroys calls that expect to still be able to access the rpc_stats structure after it has been destroyed.) Such races are in theory possible if the module containing this "static" memory is removed very quickly after an rpc client is destroyed, but we haven't seen that happen. Signed-off-by: J. Bruce Fields <bfields@citi.umich.edu>
2008-02-01nfsd4: recognize callback channel failure earlierJ. Bruce Fields
When the callback channel fails, we inform the client of that by returning a cb_path_down error the next time it tries to renew its lease. If we wait most of a lease period before deciding that a callback has failed and that the callback channel is down, then we decrease the chances that the client will find out in time to do anything about it. So, mark the channel down as soon as we recognize that an rpc has failed. However, continue trying to recall delegations anyway, in hopes it will come back up. This will prevent more delegations from being given out, and ensure cb_path_down is returned to renew calls earlier, while still making the best effort to deliver recalls of existing delegations. Also fix a couple comments and remove a dprink that doesn't seem likely to be useful. Signed-off-by: J. Bruce Fields <bfields@citi.umich.edu>
2008-02-01nfsd: move callback rpc_client creation into separate threadJ. Bruce Fields
The whole reason to move this callback-channel probe into a separate thread was because (for now) we don't have an easy way to create the rpc_client asynchronously. But I forgot to move the rpc_create() to the spawned thread. Doh! Fix that. Signed-off-by: J. Bruce Fields <bfields@citi.umich.edu>
2008-02-01nfsd4: probe callback channel only onceJ. Bruce Fields
Our callback code doesn't actually handle concurrent attempts to probe the callback channel. Some rethinking of the locking may be required. However, we can also just move the callback probing to this case. Since this is the only time a client is "confirmed" (and since that can only happen once in the lifetime of a client), this ensures we only probe once. Signed-off-by: J. Bruce Fields <bfields@citi.umich.edu>
2007-10-09knfsd: nfsv4 delegation recall should take reference on clientJ. Bruce Fields
It's not enough to take a reference on the delegation object itself; we need to ensure that the rpc_client won't go away just as we're about to make an rpc call. Signed-off-by: J. Bruce Fields <bfields@citi.umich.edu>
2007-10-09knfsd: fix callback rpc credJ. Bruce Fields
It doesn't make sense to make the callback with credentials that the client made the setclientid with. Instead the spec requires that the callback occur with the credentials the client authenticated *to*. It probably doesn't matter what we use for auth_unix, and some more infrastructure will be needed for auth_gss, so let's just remove the cred lookup for now. Signed-off-by: J. Bruce Fields <bfields@citi.umich.edu> Acked-by: Neil Brown <neilb@suse.de>
2007-10-09knfsd: spawn kernel thread to probe callback channelJ. Bruce Fields
We want to allow gss on the callback channel, so people using krb5 can still get the benefits of delegations. But looking up the rpc credential can take some time in that case. And we shouldn't delay the response to setclientid_confirm while we wait. It may be inefficient, but for now the simplest solution is just to spawn a new thread as necessary for the purpose. (Thanks to Adrian Bunk for catching a missing static here.) Signed-off-by: "J. Bruce Fields" <bfields@citi.umich.edu> Cc: Adrian Bunk <bunk@kernel.org>
2007-07-17knfsd: nfsd4: fix enc_stateid_sz for nfsd callbacksBenny Halevy
enc_stateid_sz should be given in u32 words units, not bytes, so we were overestimating the buffer space needed here. Signed-off-by: Benny Halevy <bhalevy@panasas.com> Signed-off-by: "J. Bruce Fields" <bfields@citi.umich.edu> Signed-off-by: Neil Brown <neilb@suse.de> Signed-off-by: Andrew Morton <akpm@linux-foundation.org> Signed-off-by: Linus Torvalds <torvalds@linux-foundation.org>
2007-07-10SUNRPC: Add a convenient default for the hostname when calling rpc_create()Chuck Lever
A couple of callers just use a stringified IP address for the rpc client's hostname. Move the logic for constructing this into rpc_create(), so it can be shared. Signed-off-by: Chuck Lever <chuck.lever@oracle.com> Signed-off-by: Trond Myklebust <Trond.Myklebust@netapp.com>
2007-07-10SUNRPC: Remove redundant calls to rpciod_up()/rpciod_down()Trond Myklebust
2007-05-21Detach sched.h from mm.hAlexey Dobriyan
First thing mm.h does is including sched.h solely for can_do_mlock() inline function which has "current" dereference inside. By dealing with can_do_mlock() mm.h can be detached from sched.h which is good. See below, why. This patch a) removes unconditional inclusion of sched.h from mm.h b) makes can_do_mlock() normal function in mm/mlock.c c) exports can_do_mlock() to not break compilation d) adds sched.h inclusions back to files that were getting it indirectly. e) adds less bloated headers to some files (asm/signal.h, jiffies.h) that were getting them indirectly Net result is: a) mm.h users would get less code to open, read, preprocess, parse, ... if they don't need sched.h b) sched.h stops being dependency for significant number of files: on x86_64 allmodconfig touching sched.h results in recompile of 4083 files, after patch it's only 3744 (-8.3%). Cross-compile tested on all arm defconfigs, all mips defconfigs, all powerpc defconfigs, alpha alpha-up arm i386 i386-up i386-defconfig i386-allnoconfig ia64 ia64-up m68k mips parisc parisc-up powerpc powerpc-up s390 s390-up sparc sparc-up sparc64 sparc64-up um-x86_64 x86_64 x86_64-up x86_64-defconfig x86_64-allnoconfig as well as my two usual configs. Signed-off-by: Alexey Dobriyan <adobriyan@gmail.com> Signed-off-by: Linus Torvalds <torvalds@linux-foundation.org>
2007-04-30SUNRPC: RPC buffer size estimates are too largeChuck Lever
The RPC buffer size estimation logic in net/sunrpc/clnt.c always significantly overestimates the requirements for the buffer size. A little instrumentation demonstrated that in fact rpc_malloc was never allocating the buffer from the mempool, but almost always called kmalloc. To compute the size of the RPC buffer more precisely, split p_bufsiz into two fields; one for the argument size, and one for the result size. Then, compute the sum of the exact call and reply header sizes, and split the RPC buffer precisely between the two. That should keep almost all RPC buffers within the 2KiB buffer mempool limit. And, we can finally be rid of RPC_SLACK_SPACE! Signed-off-by: Chuck Lever <chuck.lever@oracle.com> Signed-off-by: Trond Myklebust <Trond.Myklebust@netapp.com>
2007-02-16[PATCH] knfsd: nfsd4: fix non-terminated stringJ. Bruce Fields
The server name is expected to be a null-terminated string, so we can't pass in the raw client identifier. What's more, the client identifier is just a binary, not necessarily printable, blob. Let's just use the ip address instead. The server name appears to exist just to help debugging by making some printk's more informative. Note that the string is copies into the rpc client structure, so the pointer to the local variable does not outlive the function call. Signed-off-by: "J. Bruce Fields" <bfields@citi.umich.edu> Signed-off-by: Neil Brown <neilb@suse.de> Signed-off-by: Andrew Morton <akpm@linux-foundation.org> Signed-off-by: Linus Torvalds <torvalds@linux-foundation.org>
