Pull fourth vfs update from Al Viro:
"d_inode() annotations from David Howells (sat in for-next since before
the beginning of merge window) + four assorted fixes"
* 'for-linus' of git://git.kernel.org/pub/scm/linux/kernel/git/viro/vfs:
RCU pathwalk breakage when running into a symlink overmounting something
fix I_DIO_WAKEUP definition
direct-io: only inc/dec inode->i_dio_count for file systems
fs/9p: fix readdir()
VFS: assorted d_backing_inode() annotations
VFS: fs/inode.c helpers: d_inode() annotations
VFS: fs/cachefiles: d_backing_inode() annotations
VFS: fs library helpers: d_inode() annotations
VFS: assorted weird filesystems: d_inode() annotations
VFS: normal filesystems (and lustre): d_inode() annotations
VFS: security/: d_inode() annotations
VFS: security/: d_backing_inode() annotations
VFS: net/: d_inode() annotations
VFS: net/unix: d_backing_inode() annotations
VFS: kernel/: d_inode() annotations
VFS: audit: d_backing_inode() annotations
VFS: Fix up some ->d_inode accesses in the chelsio driver
VFS: Cachefiles should perform fs modifications on the top layer only
VFS: AF_UNIX sockets should call mknod on the top layer only
In the case we already have a struct file (derived from a stateid), we
still need to do permission-checking; otherwise an unauthorized user
could gain access to a file by sniffing or guessing somebody else's
stateid.
Cc: stable@vger.kernel.org
Fixes: dc97618ddda9 "nfsd4: separate splice and readv cases"
Signed-off-by: J. Bruce Fields <bfields@redhat.com>
that's the bulk of filesystem drivers dealing with inodes of their own
NFS4_MAXLABELLEN has defined for sec label max length, use it directly.
Signed-off-by: Kinglong Mee <kinglongmee@gmail.com>
Return status after nfsd4_decode_stateid failed.
Add support for the GETDEVICEINFO, LAYOUTGET, LAYOUTCOMMIT and
LAYOUTRETURN NFSv4.1 operations, as well as backing code to manage
outstanding layouts and devices.
Layout management is very straight forward, with a nfs4_layout_stateid
structure that extends nfs4_stid to manage layout stateids as the
top-level structure. It is linked into the nfs4_file and nfs4_client
structures like the other stateids, and contains a linked list of
layouts that hang of the stateid. The actual layout operations are
implemented in layout drivers that are not part of this commit, but
will be added later.
The worst part of this commit is the management of the pNFS device IDs,
which suffers from a specification that is not sanely implementable due
to the fact that the device-IDs are global and not bound to an export,
and have a small enough size so that we can't store the fsid portion of
a file handle, and must never be reused. As we still do need perform all
export authentication and validation checks on a device ID passed to
GETDEVICEINFO we are caught between a rock and a hard place. To work
around this issue we add a new hash that maps from a 64-bit integer to a
fsid so that we can look up the export to authenticate against it,
a 32-bit integer as a generation that we can bump when changing the device,
and a currently unused 32-bit integer that could be used in the future
to handle more than a single device per export. Entries in this hash
table are never deleted as we can't reuse the ids anyway, and would have
a severe lifetime problem anyway as Linux export structures are temporary
structures that can go away under load.
Parts of the XDR data, structures and marshaling/unmarshaling code, as
well as many concepts are derived from the old pNFS server implementation
from Andy Adamson, Benny Halevy, Dean Hildebrand, Marc Eshel, Fred Isaman,
Mike Sager, Ricardo Labiaga and many others.
RFC 3530 14.2.24 says
This value represents the length of the names of the directory
entries and the cookie value for these entries. This length
represents the XDR encoding of the data (names and cookies)...
The "xdr encoding" of the name should probably include the 4 bytes for
the length.
But this is all just a hint so not worth e.g. backporting to stable.
Also reshuffle some lines to more clearly group together the
dircount-related code.
Pull nfsd updates from Bruce Fields:
"A comparatively quieter cycle for nfsd this time, but still with two
larger changes:
- RPC server scalability improvements from Jeff Layton (using RCU
instead of a spinlock to find idle threads).
- server-side NFSv4.2 ALLOCATE/DEALLOCATE support from Anna
Schumaker, enabling fallocate on new clients"
* 'for-3.19' of git://linux-nfs.org/~bfields/linux: (32 commits)
nfsd4: fix xdr4 count of server in fs_location4
nfsd4: fix xdr4 inclusion of escaped char
sunrpc/cache: convert to use string_escape_str()
sunrpc: only call test_bit once in svc_xprt_received
fs: nfsd: Fix signedness bug in compare_blob
sunrpc: add some tracepoints around enqueue and dequeue of svc_xprt
sunrpc: convert to lockless lookup of queued server threads
sunrpc: fix potential races in pool_stats collection
sunrpc: add a rcu_head to svc_rqst and use kfree_rcu to free it
sunrpc: require svc_create callers to pass in meaningful shutdown routine
sunrpc: have svc_wake_up only deal with pool 0
sunrpc: convert sp_task_pending flag to use atomic bitops
sunrpc: move rq_cachetype field to better optimize space
sunrpc: move rq_splice_ok flag into rq_flags
sunrpc: move rq_dropme flag into rq_flags
sunrpc: move rq_usedeferral flag to rq_flags
sunrpc: move rq_local field to rq_flags
sunrpc: add a generic rq_flags field to svc_rqst and move rq_secure to it
nfsd: minor off by one checks in __write_versions()
sunrpc: release svc_pool_map reference when serv allocation fails
Fix a bug where nfsd4_encode_components_esc() incorrectly calculates the
length of server array in fs_location4--note that it is a count of the
number of array elements, not a length in bytes.
Signed-off-by: Benjamin Coddington <bcodding@redhat.com>
Fixes: 082d4bd72a45 (nfsd4: "backfill" using write_bytes_to_xdr_buf)
Fix a bug where nfsd4_encode_components_esc() includes the esc_end char as
an additional string encoding.
Fixes: e7a0444aef4a "nfsd: add IPv6 addr escaping to fs_location hosts"
Signed-off-by: Jeff Layton <jlayton@primarydata.com>
DEALLOCATE only returns a status value, meaning we can use the noop()
xdr encoder to reply to the client.
Signed-off-by: Anna Schumaker <Anna.Schumaker@Netapp.com>
The ALLOCATE operation is used to preallocate space in a file. I can do
this by using vfs_fallocate() to do the actual preallocation.
ALLOCATE only returns a status indicator, so we don't need to write a
special encode() function.
"Highlights:
- support the NFSv4.2 SEEK operation (allowing clients to support
SEEK_HOLE/SEEK_DATA), thanks to Anna.
- end the grace period early in a number of cases, mitigating a
long-standing annoyance, thanks to Jeff
- improve SMP scalability, thanks to Trond"
* 'for-3.18' of git://linux-nfs.org/~bfields/linux: (55 commits)
nfsd: eliminate "to_delegation" define
NFSD: Implement SEEK
NFSD: Add generic v4.2 infrastructure
svcrdma: advertise the correct max payload
nfsd: introduce nfsd4_callback_ops
nfsd: split nfsd4_callback initialization and use
nfsd: introduce a generic nfsd4_cb
nfsd: remove nfsd4_callback.cb_op
nfsd: do not clear rpc_resp in nfsd4_cb_done_sequence
nfsd: fix nfsd4_cb_recall_done error handling
nfsd4: clarify how grace period ends
nfsd4: stop grace_time update at end of grace period
nfsd: skip subsequent UMH "create" operations after the first one for v4.0 clients
nfsd: set and test NFSD4_CLIENT_STABLE bit to reduce nfsdcltrack upcalls
nfsd: serialize nfsdcltrack upcalls for a particular client
nfsd: pass extra info in env vars to upcalls to allow for early grace period end
nfsd: add a v4_end_grace file to /proc/fs/nfsd
lockd: add a /proc/fs/lockd/nlm_end_grace file
nfsd: reject reclaim request when client has already sent RECLAIM_COMPLETE
nfsd: remove redundant boot_time parm from grace_done client tracking op
The calculation of page_ptr here is wrong in the case the read doesn't
start at an offset that is a multiple of a page.
The result is that nfs4svc_encode_compoundres sets rq_next_page to a
value one too small, and then the loop in svc_free_res_pages may
incorrectly fail to clear a page pointer in rq_respages[].
Pages left in rq_respages[] are available for the next rpc request to
use, so xdr data may be written to that page, which may hold data still
waiting to be transmitted to the client or data in the page cache.
The observed result was silent data corruption seen on an NFSv4 client.
We tag this as "fixing" 05638dc73af2 because that commit exposed this
bug, though the incorrect calculation predates it.
Particular thanks to Andrea Arcangeli and David Gilbert for analysis and
testing.
Fixes: 05638dc73af2 "nfsd4: simplify server xdr->next_page use"
Reported-by: Andrea Arcangeli <aarcange@redhat.com>
Tested-by: "Dr. David Alan Gilbert" <dgilbert@redhat.com>
This patch adds server support for the NFS v4.2 operation SEEK, which
returns the position of the next hole or data segment in a file.
It's cleaner to introduce everything at once and have the server reply
with "not supported" than it would be to introduce extra operations when
implementing a specific one in the middle of the list.
Commit 3b299709091b "nfsd4: enforce rd_dircount" totally misunderstood
rd_dircount; it refers to total non-attribute bytes returned, not number
of directory entries returned.
Bring the code into agreement with RFC 3530 section 14.2.24.
Fixes: 3b299709091b "nfsd4: enforce rd_dircount"
As of 8c7424cff6 "nfsd4: don't try to encode conflicting owner if low
on space", we permit the server to process a LOCK operation even if
there might not be space to return the conflicting lockowner, because
we've made returning the conflicting lockowner optional.
However, the rpc server still wants to know the most we might possibly
return, so we need to take into account the possible conflicting
lockowner in the svc_reserve_space() call here.
Symptoms were log messages like "RPC request reserved 88 but used 108".
Fixes: 8c7424cff6 "nfsd4: don't try to encode conflicting owner if low on space"
Reported-by: Kinglong Mee <kinglongmee@gmail.com>
We do what Neil suggests now.
"This includes a major rewrite of the NFSv4 state code, which has
always depended on a single mutex. As an example, open creates are no
longer serialized, fixing a performance regression on NFSv3->NFSv4
upgrades. Thanks to Jeff, Trond, and Benny, and to Christoph for
review.
Also some RDMA fixes from Chuck Lever and Steve Wise, and
miscellaneous fixes from Kinglong Mee and others"
* 'for-3.17' of git://linux-nfs.org/~bfields/linux: (167 commits)
svcrdma: remove rdma_create_qp() failure recovery logic
nfsd: add some comments to the nfsd4 object definitions
nfsd: remove the client_mutex and the nfs4_lock/unlock_state wrappers
nfsd: remove nfs4_lock_state: nfs4_state_shutdown_net
nfsd: remove nfs4_lock_state: nfs4_laundromat
nfsd: Remove nfs4_lock_state(): reclaim_complete()
nfsd: Remove nfs4_lock_state(): setclientid, setclientid_confirm, renew
nfsd: Remove nfs4_lock_state(): exchange_id, create/destroy_session()
nfsd: Remove nfs4_lock_state(): nfsd4_open and nfsd4_open_confirm
nfsd: Remove nfs4_lock_state(): nfsd4_delegreturn()
nfsd: Remove nfs4_lock_state(): nfsd4_open_downgrade + nfsd4_close
nfsd: Remove nfs4_lock_state(): nfsd4_lock/locku/lockt()
nfsd: Remove nfs4_lock_state(): nfsd4_release_lockowner
nfsd: Remove nfs4_lock_state(): nfsd4_test_stateid/nfsd4_free_stateid
nfsd: Remove nfs4_lock_state(): nfs4_preprocess_stateid_op()
nfsd: remove old fault injection infrastructure
nfsd: add more granular locking to *_delegations fault injectors
nfsd: add more granular locking to forget_openowners fault injector
nfsd: add more granular locking to forget_locks fault injector
nfsd: add a list_head arg to nfsd_foreach_client_lock
We don't want to rely on the client_mutex for protection in the case of
NFSv4 open owners. Instead, we add a mutex that will only be taken for
NFSv4.0 state mutating operations, and that will be released once the
entire compound is done.
Also, ensure that nfsd4_cstate_assign_replay/nfsd4_cstate_clear_replay
take a reference to the stateowner when they are using it for NFSv4.0
open and lock replay caching.
Signed-off-by: Trond Myklebust <trond.myklebust@primarydata.com>
Commit 8c7424cff6 "nfsd4: don't try to encode conflicting owner if low
on space" forgot to free conf->data in nfsd4_encode_lockt and before
sign conf->data to NULL in nfsd4_encode_lock_denied, causing a leak.
Worse, kfree() can be called on an uninitialized pointer in the case of
a succesful lock (or one that fails for a reason other than a conflict).
(Note that lock->lk_denied.ld_owner.data appears it should be zero here,
until you notice that it's one arm of a union the other arm of which is
written to in the succesful case by the
memcpy(&lock->lk_resp_stateid, &lock_stp->st_stid.sc_stateid,
sizeof(stateid_t));
in nfsd4_lock(). In the 32-bit case this overwrites ld_owner.data.)
Fixes: 8c7424cff6 ""nfsd4: don't try to encode conflicting owner if low on space"
The first 8 ops of the compound are zeroed since they're a part of the
argument that's zeroed by the
memset(rqstp->rq_argp, 0, procp->pc_argsize);
in svc_process_common(). But we handle larger compounds by allocating
the memory on the fly in nfsd4_decode_compound(). Other than code
recently fixed by 01529e3f8179 "NFSD: Fix memory leak in encoding denied
lock", I don't know of any examples of code depending on this
initialization. But it definitely seems possible, and I'd rather be
safe.
Compounds this long are unusual so I'm much more worried about failure
in this poorly tested cases than about an insignificant performance hit.
Note that the caller has already reserved space for count and eof, so
xdr->p has already moved past them, only the padding remains.
Fixes dc97618ddd (nfsd4: separate splice and readv cases)
Commit 8c7424cff6 (nfsd4: don't try to encode conflicting owner if low on space)
forgot free conf->data in nfsd4_encode_lockt and before sign conf->data to NULL
in nfsd4_encode_lock_denied.
Move the slot return, put session etc into a helper in fs/nfsd/nfs4state.c
instead of open coding in nfs4svc_encode_compoundres.
fs/nfsd/nfs4xdr.c: In function 'nfsd4_encode_readv':
>> fs/nfsd/nfs4xdr.c:3137:148: warning: comparison of distinct pointer types lacks a cast [enabled by default]
thislen = min(len, ((void *)xdr->end - (void *)xdr->p));
Reported-by: Fengguang Wu <fengguang.wu@intel.com>
Avoid an extra allocation for the tmpbuf struct itself, and stop
ignoring some allocation failures.
This is a not-that-useful kmalloc wrapper. And I'd like one of the
callers to actually use something other than kmalloc.
28e05dd8457c "knfsd: nfsd4: represent nfsv4 acl with array instead of
linked list" removed the last user that wanted a custom free function.
The name of a link is currently stored in cr_name and cr_namelen, and
the content in cr_linkname and cr_linklen. That's confusing.
An NFS operation that creates a new symlink includes the symlink data,
which is xdr-encoded as a length followed by the data plus 0 to 3 bytes
of zero-padding as required to reach a 4-byte boundary.
The vfs, on the other hand, wants null-terminated data.
The simple way to handle this would be by copying the data into a newly
allocated buffer with space for the final null.
The current nfsd_symlink code tries to be more clever by skipping that
step in the (likely) case where the byte following the string is already
0.
But that assumes that the byte following the string is ours to look at.
In fact, it might be the first byte of a page that we can't read, or of
some object that another task might modify.
Worse, the NFSv4 code tries to fix the problem by actually writing to
that byte.
In the NFSv2/v3 cases this actually appears to be safe:
- nfs3svc_decode_symlinkargs explicitly null-terminates the data
(after first checking its length and copying it to a new
page).
- NFSv2 limits symlinks to 1k. The buffer holding the rpc
request is always at least a page, and the link data (and
previous fields) have maximum lengths that prevent the request
from reaching the end of a page.
In the NFSv4 case the CREATE op is potentially just one part of a long
compound so can end up on the end of a page if you're unlucky.
The minimal fix here is to copy and null-terminate in the NFSv4 case.
The nfsd_symlink() interface here seems too fragile, though. It should
really either do the copy itself every time or just require a
null-terminated string.
Reported-by: Jeff Layton <jlayton@primarydata.com>
Introduced by commit 561f0ed498 (nfsd4: allow large readdirs).
XDR requires 4-byte alignment; nfs4d READLINK reply writes out the padding,
but truncates the packet to the padding-less size.
Fix by taking the padding into consideration when truncating the packet.
Symptoms:
# ll /mnt/
ls: cannot read symbolic link /mnt/test: Input/output error
total 4
-rw-r--r--. 1 root root 0 Jun 14 01:21 123456
lrwxrwxrwx. 1 root root 6 Jul 2 03:33 test
drwxr-xr-x. 1 root root 0 Jul 2 23:50 tmp
drwxr-xr-x. 1 root root 60 Jul 2 23:44 tree
Signed-off-by: Avi Kivity <avi@cloudius-systems.com>
Fixes: 476a7b1f4b2c (nfsd4: don't treat readlink like a zero-copy operation)
Reviewed-by: Kinglong Mee <kinglongmee@gmail.com>
0.
that byte.
page).
Commit 561f0ed498ca (nfsd4: allow large readdirs) introduces a bug
about readdir the root of pseudofs.
Call xdr_truncate_encode() revert encoded name when skipping.
While we're here, let's kill off a couple of the read-side macros.
Leaving the more complicated ones alone for now.
sparse says:
CHECK fs/nfsd/nfs4xdr.c
fs/nfsd/nfs4xdr.c:2043:1: warning: symbol 'nfsd4_encode_fattr' was not declared. Should it be static?
Note nobody's ever noticed because the typical client probably never
requests FILES_AVAIL without also requesting something else on the list.
RPC_MAX_AUTH_SIZE is scattered around several places. Better to set it
once in the auth code, where this kind of estimate should be made. And
while we're at it we can leave it zero when we're not using krb5i or
krb5p.
And switch a couple other functions from the encode(&p,...) convention
to the p = encode(p,...) convention mostly used elsewhere.
