While it's not likely a pathname will be longer than
SIMPLE_TRANSACTION_SIZE, we should be more careful about just
plopping it into the output buffer without bounds checking.
Signed-off-by: Chuck Lever <chuck.lever@oracle.com>
Signed-off-by: J. Bruce Fields <bfields@citi.umich.edu>
Adjust the synopsis of svc_sock_names() to pass in the size of the
output buffer. Add a documenting comment.
This is a cosmetic change for now. A subsequent patch will make sure
the buffer length is passed to one_sock_name(), where the length will
actually be useful.
Adjust the synopsis of svc_addsock() to pass in the size of the output
actually be useful.
The svc_xprt_names() function can overflow its buffer if it's so near
the end of the passed in buffer that the "name too long" string still
doesn't fit. Of course, it could never tell if it was near the end
of the passed in buffer, since its only caller passes in zero as the
buffer length.
Let's make this API a little safer.
Change svc_xprt_names() so it *always* checks for a buffer overflow,
and change its only caller to pass in the correct buffer length.
If svc_xprt_names() does overflow its buffer, it now fails with an
ENAMETOOLONG errno, instead of trying to write a message at the end
of the buffer. I don't like this much, but I can't figure out a clean
way that's always safe to return some of the names, *and* an
indication that the buffer was not long enough.
The displayed error when doing a 'cat /proc/fs/nfsd/portlist' is
"File name too long".
Clean up.
A couple of years ago, a series of commits, finishing with commit
5680c446, swapped the order of the lockd_up() and svc_addsock() calls
in __write_ports(). At that time lockd_up() needed to know the
transport protocol of the passed-in socket to start a listener on the
same transport protocol.
These days, lockd_up() doesn't take a protocol argument; it always
starts both a UDP and TCP listener. It's now more straightforward to
try the lockd_up() first, then do a lockd_down() if the svc_addsock()
fails.
Careful review of this code shows that the svc_sock_names() call is
used only to close the just-opened socket in case lockd_up() fails.
So it is no longer needed if lockd_up() is done first.
Clean up: Refactor transport name listing out of __write_ports() to
make it easier to understand and maintain.
User space must call listen(3) on SOCK_STREAM sockets passed into
/proc/fs/nfsd/portlist, otherwise that listener is ignored. Document
this.
Clean up: Refactor the socket creation logic out of __write_ports() to
Clean up: Refactor the socket closing logic out of __write_ports() to
Clean up: Refactor transport addition out of __write_ports() to make
Clean up: Refactor transport removal out of __write_ports() to make it
* 'for-2.6.30' of git://linux-nfs.org/~bfields/linux: (81 commits)
nfsd41: define nfsd4_set_statp as noop for !CONFIG_NFSD_V4
nfsd41: define NFSD_DRC_SIZE_SHIFT in set_max_drc
nfsd41: Documentation/filesystems/nfs41-server.txt
nfsd41: CREATE_EXCLUSIVE4_1
nfsd41: SUPPATTR_EXCLCREAT attribute
nfsd41: support for 3-word long attribute bitmask
nfsd: dynamically skip encoded fattr bitmap in _nfsd4_verify
nfsd41: pass writable attrs mask to nfsd4_decode_fattr
nfsd41: provide support for minor version 1 at rpc level
nfsd41: control nfsv4.1 svc via /proc/fs/nfsd/versions
nfsd41: add OPEN4_SHARE_ACCESS_WANT nfs4_stateid bmap
nfsd41: access_valid
nfsd41: clientid handling
nfsd41: check encode size for sessions maxresponse cached
nfsd41: stateid handling
nfsd: pass nfsd4_compound_state* to nfs4_preprocess_{state,seq}id_op
nfsd41: destroy_session operation
nfsd41: non-page DRC for solo sequence responses
nfsd41: Add a create session replay cache
nfsd41: create_session operation
Support enabling and disabling nfsv4.1 via /proc/fs/nfsd/versions
by writing the strings "+4.1" or "-4.1" correspondingly.
Use user mode nfs-utils (rpc.nfsd option) to enable.
This will allow us to get rid of CONFIG_NFSD_V4_1
[nfsd41: disable support for minorversion by default]
Signed-off-by: Benny Halevy <bhalevy@panasas.com>
The sv_family field is going away. Pass a protocol family argument to
svc_create_xprt() instead of extracting the family from the passed-in
svc_serv struct.
Again, as this is a listener socket and not an address, we make this
new argument an "int" protocol family, instead of an "sa_family_t."
Signed-off-by: Trond Myklebust <Trond.Myklebust@netapp.com>
Make sure port value read from user space by write_ports is valid before
passing it to svc_find_xprt(). If it wasn't, the writer would get ENOENT
instead of EINVAL.
Noticed-by: J. Bruce Fields <bfields@fieldses.org>
Add /proc/fs/nfsd/pool_stats to export to userspace various
statistics about the operation of rpc server thread pools.
This patch is based on a forward-ported version of
knfsd-add-pool-thread-stats which has been shipping in the SGI
"Enhanced NFS" product since 2006 and which was previously
posted:
http://article.gmane.org/gmane.linux.nfs/10375
It has also been updated thus:
* moved EXPORT_SYMBOL() to near the function it exports
* made the new struct struct seq_operations const
* used SEQ_START_TOKEN instead of ((void *)1)
* merged fix from SGI PV 990526 "sunrpc: use dprintk instead of
printk in svc_pool_stats_*()" by Harshula Jayasuriya.
* merged fix from SGI PV 964001 "Crash reading pool_stats before
nfsds are started".
Signed-off-by: Greg Banks <gnb@sgi.com>
Signed-off-by: Harshula Jayasuriya <harshula@sgi.com>
Document the NFSD sysctl interface laid out in fs/nfsd/nfsctl.c.
Clean up: Instead of open-coding 2049, use the NFS_PORT macro.
Clean up: follow kernel coding style.
Clean up: Rename recently-added failover functions to match the naming
convention in fs/nfsd/nfsctl.c.
Using NIPQUAD() with NIPQUAD_FMT, %d.%d.%d.%d or %u.%u.%u.%u
can be replaced with %pI4
Signed-off-by: Harvey Harrison <harvey.harrison@gmail.com>
Clean up: The svc_addsock() function no longer uses its "proto"
argument, so remove it.
Cc: Neil Brown <neilb@suse.de>
Clean up: Now that lockd_up() starts listeners for both transports, the
"proto" argument is no longer needed.
fs.h needs path.h, not namei.h; nfs_fs.h doesn't need it at all.
Several places in the tree needed direct include.
Pass a more generic socket address type to nlmsvc_unlock_all_by_ip() to
allow for future support of IPv6. Also provide additional sanity
checking in failover_unlock_ip() when constructing the server's IP
address.
As an added bonus, provide clean kerneldoc comments on related NLM
interfaces which were recently added.
Several of the nfsd filesystem interfaces allow changes to parameters
that don't have any effect on a running nfsd service. They are only ever
checked when nfsd is started. This patch fixes it so that changes to
those procfiles return -EBUSY if nfsd is already running to make it
clear that changes on the fly don't work.
The patch should also close some relatively harmless races between
changing the info in those interfaces and starting nfsd, since these
variables are being moved under the protection of the nfsd_mutex.
Finally, the nfsv4recoverydir file always returns -EINVAL if read. This
patch fixes it to return the recoverydir path as expected.
Signed-off-by: Jeff Layton <jlayton@redhat.com>
locking.
This removes the BKL from the RPC service creation codepath. The BKL
really isn't adequate for this job since some of this info needs
protection across sleeps.
Also, add some comments to try and clarify how the locking should work
and to make it clear that the BKL isn't necessary as long as there is
adequate locking between tasks when touching the svc_serv fields.
Signed-off-by: Neil Brown <neilb@suse.de>
Use proc_create() to make sure that ->proc_fops be setup before gluing PDE to
main tree.
Signed-off-by: Denis V. Lunev <den@openvz.org>
Cc: "J. Bruce Fields" <bfields@fieldses.org>
Cc: Alexey Dobriyan <adobriyan@gmail.com>
Cc: "Eric W. Biederman" <ebiederm@xmission.com>
Add /proc/fs/nfsd/unlock_filesystem, which allows e.g.:
shell> echo /mnt/sfs1 > /proc/fs/nfsd/unlock_filesystem
so that a filesystem can be unmounted before allowing a peer nfsd to
take over nfs service for the filesystem.
Signed-off-by: S. Wendy Cheng <wcheng@redhat.com>
Cc: Lon Hohberger <lhh@redhat.com>
fs/lockd/svcsubs.c | 66 +++++++++++++++++++++++++++++++++++++++-----
fs/nfsd/nfsctl.c | 65 +++++++++++++++++++++++++++++++++++++++++++
include/linux/lockd/lockd.h | 7 ++++
3 files changed, 131 insertions(+), 7 deletions(-)
For high-availability NFS service, we generally need to be able to drop
file locks held on the exported filesystem before moving clients to a
new server. Currently the only way to do that is by shutting down lockd
entirely, which is often undesireable (for example, if you want to
continue exporting other filesystems).
This patch allows the administrator to release all locks held by clients
accessing the client through a given server ip address, by echoing that
address to a new file, /proc/fs/nfsd/unlock_ip, as in:
shell> echo 10.1.1.2 > /proc/fs/nfsd/unlock_ip
The expected sequence of events can be:
1. Tear down the IP address
2. Unexport the path
3. Write IP to /proc/fs/nfsd/unlock_ip to unlock files
4. Signal peer to begin take-over.
For now we only support IPv4 addresses and NFSv2/v3 (NFSv4 locks are not
affected).
Also, if unmounting the filesystem is required, we assume at step 3 that
clients using the given server ip are the only clients holding locks on
the given filesystem; otherwise, an additional patch is required to
allow revoking all locks held by lockd on a given filesystem.
Add extern to nfsd/nfsd.h
fs/nfsd/nfssvc.c:146:5: warning: symbol 'nfsd_nrthreads' was not declared. Should it be static?
fs/nfsd/nfssvc.c:261:5: warning: symbol 'nfsd_nrpools' was not declared. Should it be static?
fs/nfsd/nfssvc.c:269:5: warning: symbol 'nfsd_get_nrthreads' was not declared. Should it be static?
fs/nfsd/nfssvc.c:281:5: warning: symbol 'nfsd_set_nrthreads' was not declared. Should it be static?
fs/nfsd/export.c:1534:23: warning: symbol 'nfs_exports_op' was not declared. Should it be static?
Add include of auth.h
fs/nfsd/auth.c:27:5: warning: symbol 'nfsd_setuser' was not declared. Should it be static?
Make static, move forward declaration closer to where it's needed.
fs/nfsd/nfs4state.c:1877:1: warning: symbol 'laundromat_main' was not declared. Should it be static?
Make static, forward declaration was already marked static.
fs/nfsd/nfs4idmap.c:206:1: warning: symbol 'idtoname_parse' was not declared. Should it be static?
fs/nfsd/vfs.c:1156:1: warning: symbol 'nfsd_create_setattr' was not declared. Should it be static?
This adds IPv6 support to the interfaces that are used to express nfsd
exports. All addressed are stored internally as IPv6; backwards
compatibility is maintained using mapped addresses.
Thanks to Bruce Fields, Brian Haley, Neil Brown and Hideaki Joshifuji
for comments
Signed-off-by: Aurelien Charbon <aurelien.charbon@bull.net>
Cc: Brian Haley <brian.haley@hp.com>
Cc: YOSHIFUJI Hideaki / 吉藤英明 <yoshfuji@linux-ipv6.org>
Neil Brown points out that we're checking buf[size-1] in a couple places
without first checking whether size is zero.
Actually, given the implementation of simple_transaction_get(), buf[-1]
is zero, so in both of these cases the subsequent check of the value of
buf[size-1] will catch this case.
But it seems fragile to depend on that, so add explicit checks for this
case.
Acked-by: NeilBrown <neilb@suse.de>
Create a transport independent version of the svc_sock_names function.
The toclose capability of the svc_sock_names service can be implemented
using the svc_xprt_find and svc_xprt_close services.
Signed-off-by: Tom Tucker <tom@opengridcomputing.com>
Acked-by: Neil Brown <neilb@suse.de>
Reviewed-by: Chuck Lever <chuck.lever@oracle.com>
Reviewed-by: Greg Banks <gnb@sgi.com>
Update the write handler for the portlist file to allow creating new
listening endpoints on a transport. The general form of the string is:
<transport_name><space><port number>
For example:
echo "tcp 2049" > /proc/fs/nfsd/portlist
This is intended to support the creation of a listening endpoint for
RDMA transports without adding #ifdef code to the nfssvc.c file.
Transports can also be removed as follows:
'-'<transport_name><space><port number>
For example:
echo "-tcp 2049" > /proc/fs/nfsd/portlist
Attempting to add a listener with an invalid transport string results
in EPROTONOSUPPORT and a perror string of "Protocol not supported".
Attempting to remove an non-existent listener (.e.g. bad proto or port)
results in ENOTCONN and a perror string of
"Transport endpoint is not connected"
Newer server features such as nfsv4 and gss depend on proc to work, so a
failure to initialize the proc files they need should be treated as
fatal.
Thanks to Andrew Morton for style fix and compile fix in case where
CONFIG_NFSD_V4 is undefined.
I assume the reason failure of creation was ignored here was just to
continue support embedded systems that want nfsd but not proc.
However, in cases where proc is supported it would be clearer to fail
entirely than to come up with some features disabled.
If the reply cache initialization fails due to a kmalloc failure,
currently we try to soldier on with a reduced (or nonexistant) reply
cache.
Better to just fail immediately: the failure is then much easier to
understand and debug, and it could save us complexity in some later
code. (But actually, it doesn't help currently because the cache is
also turned off in some odd failure cases; we should probably find a
better way to handle those failure cases some day.)
Fix some minor style problems while we're at it, and rename
nfsd_cache_init() to remove the need for a comment describing it.
Handle the failure case here with something closer to the standard
kernel style.
Doesn't really matter for now, but I'd like to add a few more failure
cases, and then this'll help.
We forgot to shut down the nfs4 state and idmapping code in this case.
fs/nfsd/nfsctl.c: In function 'write_filehandle':
fs/nfsd/nfsctl.c:301: warning: 'maxsize' may be used uninitialized in this function
Signed-off-by: "J. Bruce Fields" <bfields@citi.umich.edu>
We have some slabs that the nfs4 server uses to store state objects.
We're currently creating and destroying those slabs whenever the server
is brought up or down. That seems excessive; may as well just do that
in module initialization and exit.
Also add some minor header cleanup. (Thanks to Andrew Morton for that
and a compile fix.)
It looks like Al Viro gutted this header file five years ago and it hasn't
been touched since.
gcc-4.3:
fs/nfsd/nfsctl.c: In function 'write_getfs':
fs/nfsd/nfsctl.c:248: warning: cast from pointer to integer of different size
Most files in the 'nfsd' filesystem are transactional. When you write, a
reply is generated that can be read back only on the same 'file'.
If the reply has zero length, the 'write' will incorrectly return a value of
'0' instead of the length that was written. This causes 'rpc.nfsd' to give an
annoying warning.
This patch fixes the test.
Change all the uses of f_{dentry,vfsmnt} to f_path.{dentry,mnt} in the nfs
server code.
Signed-off-by: Josef "Jeff" Sipek <jsipek@cs.sunysb.edu>
The max possible is the maximum RPC payload. The default depends on amount of
total memory.
The value can be set within reason as long as no nfsd threads are currently
running. The value can also be ready, allowing the default to be determined
after nfsd has started.
Arrgg.. We cannot 'lockd_up' before 'svc_addsock' as we don't know the
protocol yet.... So switch it around again and save the name of the created
sockets so that it can be closed if lock_up fails.
