path: root/fs/nfsd/vfs.c
2008-04-23knfsd: clear both setuid and setgid whenever a chown is doneJeff Layton
Currently, knfsd only clears the setuid bit if the owner of a file is changed on a SETATTR call, and only clears the setgid bit if the group is changed. POSIX says this in the spec for chown(): "If the specified file is a regular file, one or more of the S_IXUSR, S_IXGRP, or S_IXOTH bits of the file mode are set, and the process does not have appropriate privileges, the set-user-ID (S_ISUID) and set-group-ID (S_ISGID) bits of the file mode shall be cleared upon successful return from chown()." If I'm reading this correctly, then knfsd is doing this wrong. It should be clearing both the setuid and setgid bit on any SETATTR that changes the uid or gid. This wasn't really as noticable before, but now that the ATTR_KILL_S*ID bits are a no-op for the NFS client, it's more evident. This patch corrects the nfsd_setattr logic so that this occurs. It also does a bit of cleanup to the function. There is also one small behavioral change. If a SETATTR call comes in that changes the uid/gid and the mode, then we now only clear the setgid bit if the group execute bit isn't set. The setgid bit without a group execute bit signifies mandatory locking and we likely don't want to clear the bit in that case. Since there is no call in POSIX that should generate a SETATTR call like this, then this should rarely happen, but it's worth noting. Signed-off-by: Jeff Layton <jlayton@redhat.com> Signed-off-by: J. Bruce Fields <bfields@citi.umich.edu>
2008-04-23knfsd: get rid of imode variable in nfsd_setattrJeff Layton
...it's not really needed. Signed-off-by: Jeff Layton <jlayton@redhat.com> Signed-off-by: J. Bruce Fields <bfields@citi.umich.edu>
2008-04-23nfsd: fix sparse warning in vfs.cHarvey Harrison
fs/nfsd/vfs.c:991:27: warning: Using plain integer as NULL pointer Signed-off-by: Harvey Harrison <harvey.harrison@gmail.com> Signed-off-by: J. Bruce Fields <bfields@citi.umich.edu>
2008-04-23make nfsd_create_setattr() staticAdrian Bunk
This patch makes the needlessly global nfsd_create_setattr() static. Signed-off-by: Adrian Bunk <bunk@kernel.org> Signed-off-by: J. Bruce Fields <bfields@citi.umich.edu>
2008-04-19[PATCH] r/o bind mounts: check mnt instead of superblock directlyDave Hansen
If we depend on the inodes for writeability, we will not catch the r/o mounts when implemented. This patches uses __mnt_want_write(). It does not guarantee that the mount will stay writeable after the check. But, this is OK for one of the checks because it is just for a printk(). The other two are probably unnecessary and duplicate existing checks in the VFS. This won't make them better checks than before, but it will make them detect r/o mounts. Acked-by: Al Viro <viro@ZenIV.linux.org.uk> Signed-off-by: Christoph Hellwig <hch@infradead.org> Signed-off-by: Dave Hansen <haveblue@us.ibm.com> Signed-off-by: Andrew Morton <akpm@linux-foundation.org> Signed-off-by: Al Viro <viro@zeniv.linux.org.uk>
2008-04-19[PATCH] r/o bind mounts: elevate write count for xattr_permission() callersDave Hansen
This basically audits the callers of xattr_permission(), which calls permission() and can perform writes to the filesystem. [AV: add missing parts - removexattr() and nfsd posix acls, plug for a leak spotted by Miklos] Acked-by: Al Viro <viro@ZenIV.linux.org.uk> Signed-off-by: Christoph Hellwig <hch@lst.de> Signed-off-by: Dave Hansen <haveblue@us.ibm.com> Signed-off-by: Andrew Morton <akpm@linux-foundation.org> Signed-off-by: Al Viro <viro@zeniv.linux.org.uk>
2008-04-19[PATCH] r/o bind mounts: get write access for vfs_rename() callersDave Hansen
This also uses the little helper in the NFS code to make an if() a little bit less ugly. We introduced the helper at the beginning of the series. Acked-by: Al Viro <viro@ZenIV.linux.org.uk> Signed-off-by: Christoph Hellwig <hch@lst.de> Signed-off-by: Dave Hansen <haveblue@us.ibm.com> Signed-off-by: Andrew Morton <akpm@linux-foundation.org> Signed-off-by: Al Viro <viro@zeniv.linux.org.uk>
2008-04-19[PATCH] r/o bind mounts: write counts for link/symlinkDave Hansen
[AV: add missing nfsd pieces] Acked-by: Al Viro <viro@ZenIV.linux.org.uk> Signed-off-by: Christoph Hellwig <hch@lst.de> Signed-off-by: Dave Hansen <haveblue@us.ibm.com> Signed-off-by: Al Viro <viro@zeniv.linux.org.uk>
2008-04-19[PATCH] r/o bind mounts: get callers of vfs_mknod/create/mkdir()Dave Hansen
This takes care of all of the direct callers of vfs_mknod(). Since a few of these cases also handle normal file creation as well, this also covers some calls to vfs_create(). So that we don't have to make three mnt_want/drop_write() calls inside of the switch statement, we move some of its logic outside of the switch and into a helper function suggested by Christoph. This also encapsulates a fix for mknod(S_IFREG) that Miklos found. [AV: merged mkdir handling, added missing nfsd pieces] Acked-by: Al Viro <viro@ZenIV.linux.org.uk> Signed-off-by: Christoph Hellwig <hch@infradead.org> Signed-off-by: Dave Hansen <haveblue@us.ibm.com> Signed-off-by: Andrew Morton <akpm@linux-foundation.org> Signed-off-by: Al Viro <viro@zeniv.linux.org.uk>
2008-04-19[PATCH] r/o bind mounts: elevate write count for rmdir and unlink.Dave Hansen
Elevate the write count during the vfs_rmdir() and vfs_unlink(). [AV: merged rmdir and unlink parts, added missing pieces in nfsd] Acked-by: Serge Hallyn <serue@us.ibm.com> Acked-by: Al Viro <viro@ZenIV.linux.org.uk> Signed-off-by: Christoph Hellwig <hch@lst.de> Signed-off-by: Dave Hansen <haveblue@us.ibm.com> Signed-off-by: Andrew Morton <akpm@linux-foundation.org> Signed-off-by: Al Viro <viro@zeniv.linux.org.uk>
2008-02-14Use struct path in struct svc_exportJan Blunck
I'm embedding struct path into struct svc_export. [akpm@linux-foundation.org: coding-style fixes] [ezk@cs.sunysb.edu: NFSD: fix wrong mnt_writer count in rename] Signed-off-by: Jan Blunck <jblunck@suse.de> Acked-by: J. Bruce Fields <bfields@citi.umich.edu> Acked-by: Christoph Hellwig <hch@infradead.org> Cc: Al Viro <viro@zeniv.linux.org.uk> Cc: "J. Bruce Fields" <bfields@fieldses.org> Cc: Neil Brown <neilb@suse.de> Cc: Trond Myklebust <trond.myklebust@fys.uio.no> Signed-off-by: Erez Zadok <ezk@cs.sunysb.edu> Signed-off-by: Andrew Morton <akpm@linux-foundation.org> Signed-off-by: Linus Torvalds <torvalds@linux-foundation.org>
2008-02-01nfsd: allow root to set uid and gid on createJ. Bruce Fields
The server silently ignores attempts to set the uid and gid on create. Based on the comment, this appears to have been done to prevent some overly-clever IRIX client from causing itself problems. Perhaps we should remove that hack completely. For now, at least, it makes sense to allow root (when no_root_squash is set) to set uid and gid. While we're there, since nfsd_create and nfsd_create_v3 share the same logic, pull that out into a separate function. And spell out the individual modifications of ia_valid instead of doing them both at once inside a conditional. Thanks to Roger Willcocks <roger@filmlight.ltd.uk> for the bug report and original patch on which this is based. Signed-off-by: J. Bruce Fields <bfields@citi.umich.edu>
2008-02-01NFSD: Adjust filename length argument of nfsd_lookupChuck Lever
Clean up: adjust the sign of the length argument of nfsd_lookup and nfsd_lookup_dentry, for consistency with recent changes. NFSD version 4 callers already pass an unsigned file name length. Signed-off-by: Chuck Lever <chuck.lever@oracle.com> Acked-By: NeilBrown <neilb@suse.de> Signed-off-by: J. Bruce Fields <bfields@citi.umich.edu>
2007-10-19Use helpers to obtain task pid in printksPavel Emelyanov
The task_struct->pid member is going to be deprecated, so start using the helpers (task_pid_nr/task_pid_vnr/task_pid_nr_ns) in the kernel. The first thing to start with is the pid, printed to dmesg - in this case we may safely use task_pid_nr(). Besides, printks produce more (much more) than a half of all the explicit pid usage. [akpm@linux-foundation.org: git-drm went and changed lots of stuff] Signed-off-by: Pavel Emelyanov <xemul@openvz.org> Cc: Dave Airlie <airlied@linux.ie> Signed-off-by: Andrew Morton <akpm@linux-foundation.org> Signed-off-by: Linus Torvalds <torvalds@linux-foundation.org>
2007-10-18knfsd: only set ATTR_KILL_S*ID if ATTR_MODE isn't being explicitly setJeff Layton
It's theoretically possible for a single SETATTR call to come in that sets the mode and the uid/gid. In that case, don't set the ATTR_KILL_S*ID bits since that would trip the BUG() in notify_change. Just fix up the mode to have the same effect. Signed-off-by: Jeff Layton <jlayton@redhat.com> Cc: Neil Brown <neilb@suse.de> Cc: "J. Bruce Fields" <bfields@fieldses.org> Cc: Christoph Hellwig <hch@lst.de> Signed-off-by: Andrew Morton <akpm@linux-foundation.org> Signed-off-by: Linus Torvalds <torvalds@linux-foundation.org>
2007-10-17Implement file posix capabilitiesSerge E. Hallyn
Implement file posix capabilities. This allows programs to be given a subset of root's powers regardless of who runs them, without having to use setuid and giving the binary all of root's powers. This version works with Kaigai Kohei's userspace tools, found at http://www.kaigai.gr.jp/index.php. For more information on how to use this patch, Chris Friedhoff has posted a nice page at http://www.friedhoff.org/fscaps.html. Changelog: Nov 27: Incorporate fixes from Andrew Morton (security-introduce-file-caps-tweaks and security-introduce-file-caps-warning-fix) Fix Kconfig dependency. Fix change signaling behavior when file caps are not compiled in. Nov 13: Integrate comments from Alexey: Remove CONFIG_ ifdef from capability.h, and use %zd for printing a size_t. Nov 13: Fix endianness warnings by sparse as suggested by Alexey Dobriyan. Nov 09: Address warnings of unused variables at cap_bprm_set_security when file capabilities are disabled, and simultaneously clean up the code a little, by pulling the new code into a helper function. Nov 08: For pointers to required userspace tools and how to use them, see http://www.friedhoff.org/fscaps.html. Nov 07: Fix the calculation of the highest bit checked in check_cap_sanity(). Nov 07: Allow file caps to be enabled without CONFIG_SECURITY, since capabilities are the default. Hook cap_task_setscheduler when !CONFIG_SECURITY. Move capable(TASK_KILL) to end of cap_task_kill to reduce audit messages. Nov 05: Add secondary calls in selinux/hooks.c to task_setioprio and task_setscheduler so that selinux and capabilities with file cap support can be stacked. Sep 05: As Seth Arnold points out, uid checks are out of place for capability code. Sep 01: Define task_setscheduler, task_setioprio, cap_task_kill, and task_setnice to make sure a user cannot affect a process in which they called a program with some fscaps. One remaining question is the note under task_setscheduler: are we ok with CAP_SYS_NICE being sufficient to confine a process to a cpuset? It is a semantic change, as without fsccaps, attach_task doesn't allow CAP_SYS_NICE to override the uid equivalence check. But since it uses security_task_setscheduler, which elsewhere is used where CAP_SYS_NICE can be used to override the uid equivalence check, fixing it might be tough. task_setscheduler note: this also controls cpuset:attach_task. Are we ok with CAP_SYS_NICE being used to confine to a cpuset? task_setioprio task_setnice sys_setpriority uses this (through set_one_prio) for another process. Need same checks as setrlimit Aug 21: Updated secureexec implementation to reflect the fact that euid and uid might be the same and nonzero, but the process might still have elevated caps. Aug 15: Handle endianness of xattrs. Enforce capability version match between kernel and disk. Enforce that no bits beyond the known max capability are set, else return -EPERM. With this extra processing, it may be worth reconsidering doing all the work at bprm_set_security rather than d_instantiate. Aug 10: Always call getxattr at bprm_set_security, rather than caching it at d_instantiate. [morgan@kernel.org: file-caps clean up for linux/capability.h] [bunk@kernel.org: unexport cap_inode_killpriv] Signed-off-by: Serge E. Hallyn <serue@us.ibm.com> Cc: Stephen Smalley <sds@tycho.nsa.gov> Cc: James Morris <jmorris@namei.org> Cc: Chris Wright <chrisw@sous-sol.org> Cc: Andrew Morgan <morgan@kernel.org> Signed-off-by: Andrew Morgan <morgan@kernel.org> Signed-off-by: Adrian Bunk <bunk@kernel.org> Signed-off-by: Andrew Morton <akpm@linux-foundation.org> Signed-off-by: Linus Torvalds <torvalds@linux-foundation.org>
2007-10-17r/o bind mounts: create cleanup helper svc_msnfs()Dave Hansen
I'm going to be modifying nfsd_rename() shortly to support read-only bind mounts. This #ifdef is around the area I'm patching, and it starts to get really ugly if I just try to add my new code by itself. Using this little helper makes things a lot cleaner to use. Signed-off-by: Dave Hansen <haveblue@us.ibm.com> Acked-by: Christoph Hellwig <hch@infradead.org> Signed-off-by: Andrew Morton <akpm@linux-foundation.org> Signed-off-by: Linus Torvalds <torvalds@linux-foundation.org>
2007-10-15Merge branch 'locks' of git://linux-nfs.org/~bfields/linuxLinus Torvalds
* 'locks' of git://linux-nfs.org/~bfields/linux: nfsd: remove IS_ISMNDLCK macro Rework /proc/locks via seq_files and seq_list helpers fs/locks.c: use list_for_each_entry() instead of list_for_each() NFS: clean up explicit check for mandatory locks AFS: clean up explicit check for mandatory locks 9PFS: clean up explicit check for mandatory locks GFS2: clean up explicit check for mandatory locks Cleanup macros for distinguishing mandatory locks Documentation: move locks.txt in filesystems/ locks: add warning about mandatory locking races Documentation: move mandatory locking documentation to filesystems/ locks: Fix potential OOPS in generic_setlease() Use list_first_entry in locks_wake_up_blocks locks: fix flock_lock_file() comment Memory shortage can result in inconsistent flocks state locks: kill redundant local variable locks: reverse order of posix_locks_conflict() arguments
2007-10-09nfsd: remove IS_ISMNDLCK macroJ. Bruce Fields
This macro is only used in one place; in this place it seems simpler to put open-code it and move the comment to where it's used. Signed-off-by: J. Bruce Fields <bfields@citi.umich.edu>
2007-10-09Cleanup macros for distinguishing mandatory locksPavel Emelyanov
The combination of S_ISGID bit set and S_IXGRP bit unset is used to mark the inode as "mandatory lockable" and there's a macro for this check called MANDATORY_LOCK(inode). However, fs/locks.c and some filesystems still perform the explicit i_mode checking. Besides, Andrew pointed out, that this macro is buggy itself, as it dereferences the inode arg twice. Convert this macro into static inline function and switch its users to it, making the code shorter and more readable. The __mandatory_lock() helper is to be used in places where the IS_MANDLOCK() for superblock is already known to be true. Signed-off-by: Pavel Emelyanov <xemul@openvz.org> Cc: Trond Myklebust <trond.myklebust@fys.uio.no> Cc: "J. Bruce Fields" <bfields@fieldses.org> Cc: David Howells <dhowells@redhat.com> Cc: Eric Van Hensbergen <ericvh@gmail.com> Cc: Ron Minnich <rminnich@sandia.gov> Cc: Latchesar Ionkov <lucho@ionkov.net> Cc: Steven Whitehouse <swhiteho@redhat.com> Signed-off-by: Andrew Morton <akpm@linux-foundation.org>
2007-10-09nfsd: fix horrible indentation in nfsd_setattrChristoph Hellwig
Signed-off-by: Christoph Hellwig <hch@lst.de> Signed-off-by: J. Bruce Fields <bfields@citi.umich.edu> Acked-by: Neil Brown <neilb@suse.de>
2007-09-10knfsd: Fixed problem with NFS exporting directories which are mounted on.Neil Brown
Recent changes in NFSd cause a directory which is mounted-on to not appear properly when the filesystem containing it is exported. *exp_get* now returns -ENOENT rather than NULL and when commit 5d3dbbeaf56d0365ac6b5c0a0da0bd31cc4781e1 removed the NULL checks, it didn't add a check for -ENOENT. Signed-off-by: Neil Brown <neilb@suse.de> Signed-off-by: J. Bruce Fields <bfields@citi.umich.edu> Signed-off-by: Linus Torvalds <torvalds@linux-foundation.org>
2007-07-31knfsd: set the response bitmask for NFS4_CREATE_EXCLUSIVEJeff Layton
RFC 3530 says: If the server uses an attribute to store the exclusive create verifier, it will signify which attribute by setting the appropriate bit in the attribute mask that is returned in the results. Linux uses the atime and mtime to store the verifier, but sends a zeroed out bitmask back to the client. This patch makes sure that we set the correct bits in the bitmask in this situation. Signed-off-by: Jeff Layton <jlayton@redhat.com> Signed-off-by: J. Bruce Fields <bfields@citi.umich.edu> Cc: Neil Brown <neilb@suse.de> Signed-off-by: Andrew Morton <akpm@linux-foundation.org> Signed-off-by: Linus Torvalds <torvalds@linux-foundation.org>
2007-07-19knfsd: clean up EX_RDONLYJ. Bruce Fields
Share a little common code, reverse the arguments for consistency, drop the unnecessary "inline", and lowercase the name. Signed-off-by: "J. Bruce Fields" <bfields@citi.umich.edu> Acked-by: Neil Brown <neilb@suse.de> Signed-off-by: Andrew Morton <akpm@linux-foundation.org> Signed-off-by: Linus Torvalds <torvalds@linux-foundation.org>
2007-07-19knfsd: move EX_RDONLY out of headerJ. Bruce Fields
EX_RDONLY is only called in one place; just put it there. Signed-off-by: "J. Bruce Fields" <bfields@citi.umich.edu> Acked-by: Neil Brown <neilb@suse.de> Signed-off-by: Andrew Morton <akpm@linux-foundation.org> Signed-off-by: Linus Torvalds <torvalds@linux-foundation.org>
2007-07-19nfsd: remove unnecessary NULL checks from nfsd_cross_mntJ. Bruce Fields
We can now assume that rqst_exp_get_by_name() does not return NULL; so clean up some unnecessary checks. Signed-off-by: "J. Bruce Fields" <bfields@citi.umich.edu> Acked-by: Neil Brown <neilb@suse.de> Signed-off-by: Andrew Morton <akpm@linux-foundation.org> Signed-off-by: Linus Torvalds <torvalds@linux-foundation.org>
2007-07-19nfsd: fix possible read-ahead cache and export table corruptionJ. Bruce Fields
The value of nperbucket calculated here is too small--we should be rounding up instead of down--with the result that the index j in the following loop can overflow the raparm_hash array. At least in my case, the next thing in memory turns out to be export_table, so the symptoms I see are crashes caused by the appearance of four zeroed-out export entries in the first bucket of the hash table of exports (which were actually entries in the readahead cache, a pointer to which had been written to the export table in this initialization code). It looks like the bug was probably introduced with commit fce1456a19f5c08b688c29f00ef90fdfa074c79b ("knfsd: make the readahead params cache SMP-friendly"). Cc: <stable@kernel.org> Cc: Greg Banks <gnb@melbourne.sgi.com> Signed-off-by: "J. Bruce Fields" <bfields@citi.umich.edu> Acked-by: NeilBrown <neilb@suse.de> Signed-off-by: Andrew Morton <akpm@linux-foundation.org> Signed-off-by: Linus Torvalds <torvalds@linux-foundation.org>
2007-07-17knfsd: nfsd4: make readonly access depend on pseudoflavorJ. Bruce Fields
Allow readonly access to vary depending on the pseudoflavor, using the flag passed with each pseudoflavor in the export downcall. The rest of the flags are ignored for now, though some day we might also allow id squashing to vary based on the flavor. Signed-off-by: "J. Bruce Fields" <bfields@citi.umich.edu> Signed-off-by: Neil Brown <neilb@suse.de> Signed-off-by: Andrew Morton <akpm@linux-foundation.org> Signed-off-by: Linus Torvalds <torvalds@linux-foundation.org>
2007-07-17knfsd: nfsd4: return nfserr_wrongsecAndy Adamson
Make the first actual use of the secinfo information by using it to return nfserr_wrongsec when an export is found that doesn't allow the flavor used on this request. Signed-off-by: J. Bruce Fields <bfields@citi.umich.edu> Signed-off-by: Andy Adamson <andros@citi.umich.edu> Signed-off-by: Neil Brown <neilb@suse.de> Signed-off-by: Andrew Morton <akpm@linux-foundation.org> Signed-off-by: Linus Torvalds <torvalds@linux-foundation.org>
2007-07-17knfsd: nfsd: factor nfsd_lookup into 2 piecesJ. Bruce Fields
Factor nfsd_lookup into nfsd_lookup_dentry, which finds the right dentry and export, and a second part which composes the filehandle (and which will later check the security flavor on the new export). No change in behavior. Signed-off-by: "J. Bruce Fields" <bfields@citi.umich.edu> Signed-off-by: Neil Brown <neilb@suse.de> Signed-off-by: Andrew Morton <akpm@linux-foundation.org> Signed-off-by: Linus Torvalds <torvalds@linux-foundation.org>
2007-07-17knfsd: nfsd: provide export lookup wrappers which take a svc_rqstJ. Bruce Fields
Split the callers of exp_get_by_name(), exp_find(), and exp_parent() into those that are processing requests and those that are doing other stuff (like looking up filehandles for mountd). No change in behavior, just a (fairly pointless, on its own) cleanup. (Note this has the effect of making nfsd_cross_mnt() pass rqstp->rq_client instead of exp->ex_client into exp_find_by_name(). However, the two should have the same value at this point.) Signed-off-by: "J. Bruce Fields" <bfields@citi.umich.edu> Signed-off-by: Neil Brown <neilb@suse.de> Signed-off-by: Andrew Morton <akpm@linux-foundation.org> Signed-off-by: Linus Torvalds <torvalds@linux-foundation.org>
2007-07-17knfsd: nfsd: remove superfluous assignment from nfsd_lookupJ. Bruce Fields
The "err" variable will only be used in the final return, which always happens after either the preceding err = fh_compose(...); or after the following err = nfserrno(host_err); So the earlier assignment to err is ignored. Signed-off-by: "J. Bruce Fields" <bfields@citi.umich.edu> Signed-off-by: Neil Brown <neilb@suse.de> Signed-off-by: Andrew Morton <akpm@linux-foundation.org> Signed-off-by: Linus Torvalds <torvalds@linux-foundation.org>
2007-07-17knfsd: nfsd: make all exp_finding functions return -errno's on errJ. Bruce Fields
Currently exp_find(), exp_get_by_name(), and friends, return an export on success, and on failure return: errors -EAGAIN (drop this request pending an upcall) or -ETIMEDOUT (an upcall has timed out), or return NULL, which can mean either that there was a memory allocation failure, or that an export was not found, or that a passed-in export lacks an auth_domain. Many callers seem to assume that NULL means that an export was not found, which may lead to bugs in the case of a memory allocation failure. Modify these functions to distinguish between the two NULL cases by returning either -ENOENT or -ENOMEM. They now never return NULL. We get to simplify some code in the process. We return -ENOENT in the case of a missing auth_domain. This case should probably be removed (or converted to a bug) after confirming that it can never happen. Signed-off-by: "J. Bruce Fields" <bfields@citi.umich.edu> Signed-off-by: Neil Brown <neilb@suse.de> Signed-off-by: Andrew Morton <akpm@linux-foundation.org> Signed-off-by: Linus Torvalds <torvalds@linux-foundation.org>
2007-07-17knfsd: nfsd4: fix handling of acl errrorsJ. Bruce Fields
nfs4_acl_nfsv4_to_posix() returns an error and returns any posix acls calculated in two caller-provided pointers. It was setting these pointers to -errno in some error cases, resulting in nfsd4_set_nfs4_acl() calling posix_acl_release() with a -errno as an argument. Fix both the caller and the callee, by modifying nfsd4_set_nfs4_acl() to stop relying on the passed-in-pointers being left as NULL in the error case, and by modifying nfs4_acl_nfsv4_to_posix() to stop returning garbage in those pointers. Thanks to Alex Soule for reporting the bug. Signed-off-by: "J. Bruce Fields" <bfields@citi.umich.edu> Cc: Alexander Soule <soule@umich.edu> Signed-off-by: Neil Brown <neilb@suse.de> Signed-off-by: Andrew Morton <akpm@linux-foundation.org> Signed-off-by: Linus Torvalds <torvalds@linux-foundation.org>
2007-07-13nfsd: fix nfsd_vfs_read() splice actor setupJens Axboe
When nfsd was transitioned to use splice instead of sendfile() for data transfers, a line setting the page index was lost. Restore it, so that nfsd is functional when that path is used. Signed-off-by: Jens Axboe <jens.axboe@oracle.com> Signed-off-by: Linus Torvalds <torvalds@linux-foundation.org>
2007-07-10pipe: change the ->pin() operation to ->confirm()Jens Axboe
The name 'pin' was badly chosen, it doesn't pin a pipe buffer in the most commonly used sense in the kernel. So change the name to 'confirm', after debating this issue with Hugh Dickins a bit. A good return from ->confirm() means that the buffer is really there, and that the contents are good. Signed-off-by: Jens Axboe <jens.axboe@oracle.com>
2007-07-10splice: divorce the splice structure/function definitions from the pipe headerJens Axboe
We need to move even more stuff into the header so that folks can use the splice_to_pipe() implementation instead of open-coding a lot of pipe knowledge (see relay implementation), so move to our own header file finally. Signed-off-by: Jens Axboe <jens.axboe@oracle.com>
2007-07-10sendfile: convert nfsd to splice_direct_to_actor()Jens Axboe
2007-02-16[PATCH] knfsd: nfsd4: fix error return on unsupported aclJ. Bruce Fields
We should be returning ATTRNOTSUPP, not NOTSUPP, when acls are unsupported. Also fix a comment. Signed-off-by: "J. Bruce Fields" <bfields@citi.umich.edu> Signed-off-by: Neil Brown <neilb@suse.de> Signed-off-by: Andrew Morton <akpm@linux-foundation.org> Signed-off-by: Linus Torvalds <torvalds@linux-foundation.org>
2007-01-30[PATCH] knfsd: ratelimit some nfsd messages that are triggered by external ↵NeilBrown
events Also remove {NFSD,RPC}_PARANOIA as having the defines doesn't really add anything. The printks covered by RPC_PARANOIA were triggered by badly formatted packets and so should be ratelimited. Signed-off-by: Neil Brown <neilb@suse.de> Signed-off-by: Andrew Morton <akpm@osdl.org> Signed-off-by: Linus Torvalds <torvalds@linux-foundation.org>
2007-01-26[PATCH] knfsd: Fix type mismatch with filldir_t used by nfsdNeilBrown
nfsd defines a type 'encode_dent_fn' which is much like 'filldir_t' except that the first pointer is 'struct readdir_cd *' rather than 'void *'. It then casts encode_dent_fn points to 'filldir_t' as needed. This hides any other type mismatches between the two such as the fact that the 'ino' arg recently changed from ino_t to u64. So: get rid of 'encode_dent_fn', get rid of the cast of the function type, change the first arg of various functions from 'struct readdir_cd *' to 'void *', and live with the fact that we have a little less type checking on the calling of these functions now. Less internal (to nfsd) checking offset by more external checking, which is more important. Thanks to Gabriel Paubert <paubert@iram.es> for discovering this and providing an initial patch. Signed-off-by: Gabriel Paubert <paubert@iram.es> Signed-off-by: Neil Brown <neilb@suse.de> Signed-off-by: Andrew Morton <akpm@osdl.org> Signed-off-by: Linus Torvalds <torvalds@linux-foundation.org>
2007-01-26[PATCH] knfsd: Don't mess with the 'mode' when storing a exclusive-create cookiePeter Staubach
NFS V3 (and V4) support exclusive create by passing a 'cookie' which can get stored with the file. If the file exists but has exactly the right cookie stored, then we assume this is a retransmit and the exclusive create was successful. The cookie is 64bits and is traditionally stored in the mtime and atime fields. This causes a problem with Solaris7 as negative mtime or atime confuse it. So we moved two bits into the mode word instead. But inherited ACLs sometimes overwrite the mode word on create, so this is a problem. So we give up and just store 62 of the 64 bits and assume that is close enough. Signed-off-by: Neil Brown <neilb@suse.de> Signed-off-by: Andrew Morton <akpm@osdl.org> Signed-off-by: Linus Torvalds <torvalds@linux-foundation.org>
2007-01-26[PATCH] knfsd: fix an NFSD bug with full sized, non-page-aligned readsNeilBrown
NFSd assumes that largest number of pages that will be needed for a request+response is 2+N where N pages is the size of the largest permitted read/write request. The '2' are 1 for the non-data part of the request, and 1 for the non-data part of the reply. However, when a read request is not page-aligned, and we choose to use ->sendfile to send it directly from the page cache, we may need N+1 pages to hold the whole reply. This can overflow and array and cause an Oops. This patch increases size of the array for holding pages by one and makes sure that entry is NULL when it is not in use. Signed-off-by: Neil Brown <neilb@suse.de> Signed-off-by: Andrew Morton <akpm@osdl.org> Signed-off-by: Linus Torvalds <torvalds@linux-foundation.org>
2006-12-13[PATCH] knfsd: nfsd: don't drop silently on upcall deferralJ.Bruce Fields
To avoid tying up server threads when nfsd makes an upcall (to mountd, to get export options, to idmapd, for nfsv4 name<->id mapping, etc.), we temporarily "drop" the request and save enough information so that we can revisit it later. Certain failures during the deferral process can cause us to really drop the request and never revisit it. This is often less than ideal, and is unacceptable in the NFSv4 case--rfc 3530 forbids the server from dropping a request without also closing the connection. As a first step, we modify the deferral code to return -ETIMEDOUT (which is translated to nfserr_jukebox in the v3 and v4 cases, and remains a drop in the v2 case). Signed-off-by: J. Bruce Fields <bfields@citi.umich.edu> Signed-off-by: Neil Brown <neilb@suse.de> Signed-off-by: Andrew Morton <akpm@osdl.org> Signed-off-by: Linus Torvalds <torvalds@osdl.org>
2006-12-08[PATCH] nfsd: replace kmalloc+memset with kcalloc + simplify NULL checkYan Burman
Replace kmalloc+memset with kcalloc and simplify Signed-off-by: Yan Burman <burman.yan@gmail.com> Cc: Neil Brown <neilb@cse.unsw.edu.au> Signed-off-by: Andrew Morton <akpm@osdl.org> Signed-off-by: Linus Torvalds <torvalds@osdl.org>
2006-12-08[PATCH] nfsd: change uses of f_{dentry, vfsmnt} to use f_pathJosef "Jeff" Sipek
Change all the uses of f_{dentry,vfsmnt} to f_path.{dentry,mnt} in the nfs server code. Signed-off-by: Josef "Jeff" Sipek <jsipek@cs.sunysb.edu> Signed-off-by: Andrew Morton <akpm@osdl.org> Signed-off-by: Linus Torvalds <torvalds@osdl.org>
2006-11-08[PATCH] nfsd: fix spurious error return from nfsd_create in async caseJ. Bruce Fields
Commit 6264d69d7df654ca64f625e9409189a0e50734e9 modified the nfsd_create() error handling in such a way that nfsd_create will usually return nfserr_perm even when succesful, if the export has the async export option. This introduced a regression that could cause mkdir() to always return a permissions error, even though the directory in question was actually succesfully created. Signed-off-by: J. Bruce Fields <bfields@citi.umich.edu> Acked-by: NeilBrown <neilb@suse.de> Signed-off-by: Andrew Morton <akpm@osdl.org> Signed-off-by: Linus Torvalds <torvalds@osdl.org>
2006-11-08[PATCH] nfsd4: fix open-create permissionsJ. Bruce Fields
In the case where an open creates the file, we shouldn't be rechecking permissions to open the file; the open succeeds regardless of what the new file's mode bits say. This patch fixes the problem, but only by introducing yet another parameter to nfsd_create_v3. This is ugly. This will be fixed by later patches. Signed-off-by: J. Bruce Fields <bfields@citi.umich.edu> Acked-by: Neil Brown <neilb@suse.de> Cc: Jeff Garzik <jeff@garzik.org> Signed-off-by: Andrew Morton <akpm@osdl.org> Signed-off-by: Linus Torvalds <torvalds@osdl.org>
2006-10-20[PATCH] nfsd: vfs.c endianness annotationsAl Viro
don't use the same variable to store NFS and host error values Signed-off-by: Al Viro <viro@zeniv.linux.org.uk> Acked-by: Trond Myklebust <trond.myklebust@fys.uio.no> Acked-by: Neil Brown <neilb@suse.de> Signed-off-by: Andrew Morton <akpm@osdl.org> Signed-off-by: Linus Torvalds <torvalds@osdl.org>
2006-10-04[PATCH] knfsd: nfsd4: acls: fix handling of zero-length aclsJ.Bruce Fields
It is legal to have zero-length NFSv4 acls; they just deny everything. Also, nfs4_acl_nfsv4_to_posix will always return with pacl and dpacl set on success, so the caller doesn't need to check this. Signed-off-by: J. Bruce Fields <bfields@citi.umich.edu> Signed-off-by: Neil Brown <neilb@suse.de> Signed-off-by: Andrew Morton <akpm@osdl.org> Signed-off-by: Linus Torvalds <torvalds@osdl.org>
