path: root/fs/nfsd/vfs.c
2011-11-11nfsd4: permit read opens of executable-only filesJ. Bruce Fields
commit a043226bc140a2c1dde162246d68a67e5043e6b2 upstream. A client that wants to execute a file must be able to read it. Read opens over nfs are therefore implicitly allowed for executable files even when those files are not readable. NFSv2/v3 get this right by using a passed-in NFSD_MAY_OWNER_OVERRIDE on read requests, but NFSv4 has gotten this wrong ever since dc730e173785e29b297aa605786c94adaffe2544 "nfsd4: fix owner-override on open", when we realized that the file owner shouldn't override permissions on non-reclaim NFSv4 opens. So we can't use NFSD_MAY_OWNER_OVERRIDE to tell nfsd_permission to allow reads of executable files. So, do the same thing we do whenever we encounter another weird NFS permission nit: define yet another NFSD_MAY_* flag. The industry's future standardization on 128-bit processors will be motivated primarily by the need for integers with enough bits for all the NFSD_MAY_* flags. Reported-by: Leonardo Borda <leonardoborda@gmail.com> Signed-off-by: J. Bruce Fields <bfields@redhat.com> Signed-off-by: Greg Kroah-Hartman <gregkh@suse.de>
2011-06-20nfsd4: fix break_lease flags on nfsd openJ. Bruce Fields
Thanks to Casey Bodley for pointing out that on a read open we pass 0, instead of O_RDONLY, to break_lease, with the result that a read open is treated like a write open for the purposes of lease breaking! Reported-by: Casey Bodley <cbodley@citi.umich.edu> Cc: stable@kernel.org Signed-off-by: J. Bruce Fields <bfields@redhat.com>
2011-06-06nfsd: link returns nfserr_delay when breaking leaseCasey Bodley
fix for commit 4795bb37effb7b8fe77e2d2034545d062d3788a8, nfsd: break lease on unlink, link, and rename if the LINK operation breaks a delegation, it returns NFS4ERR_NOENT (which is not a valid error in rfc 5661) instead of NFS4ERR_DELAY. the return value of nfsd_break_lease() in nfsd_link() must be converted from host_err to err Signed-off-by: Casey Bodley <cbodley@citi.umich.edu> Cc: stable@kernel.org Signed-off-by: J. Bruce Fields <bfields@redhat.com>
2011-05-29Merge branch 'for-2.6.40' of git://linux-nfs.org/~bfields/linuxLinus Torvalds
* 'for-2.6.40' of git://linux-nfs.org/~bfields/linux: (22 commits) nfsd: make local functions static NFSD: Remove unused variable from nfsd4_decode_bind_conn_to_session() NFSD: Check status from nfsd4_map_bcts_dir() NFSD: Remove setting unused variable in nfsd_vfs_read() nfsd41: error out on repeated RECLAIM_COMPLETE nfsd41: compare request's opcnt with session's maxops at nfsd4_sequence nfsd v4.1 lOCKT clientid field must be ignored nfsd41: add flag checking for create_session nfsd41: make sure nfs server process OPEN with EXCLUSIVE4_1 correctly nfsd4: fix wrongsec handling for PUTFH + op cases nfsd4: make fh_verify responsibility of nfsd_lookup_dentry caller nfsd4: introduce OPDESC helper nfsd4: allow fh_verify caller to skip pseudoflavor checks nfsd: distinguish functions of NFSD_MAY_* flags svcrpc: complete svsk processing on cb receive failure svcrpc: take advantage of tcp autotuning SUNRPC: Don't wait for full record to receive tcp data svcrpc: copy cb reply instead of pages svcrpc: close connection if client sends short packet svcrpc: note network-order types in svc_process_calldir ...
2011-04-29NFSD: Remove setting unused variable in nfsd_vfs_read()Bryan Schumaker
Compiling gave me this warning: fs/nfsd/vfs.c: In function ‘nfsd_vfs_read’: fs/nfsd/vfs.c:880:16: warning: variable ‘inode’ set but not used [-Wunused-but-set-variable] I discovered that a local variable "inode" was being set towards the beginning of nfsd_vfs_read() and then ignored for the rest of the function. Signed-off-by: Bryan Schumaker <bjschuma@netapp.com> Signed-off-by: J. Bruce Fields <bfields@redhat.com>
2011-04-29nfsd41: make sure nfs server process OPEN with EXCLUSIVE4_1 correctlyMi Jinlong
The NFS server uses nfsd_create_v3 to handle EXCLUSIVE4_1 opens, but that function is not prepared to handle them. Rename nfsd_create_v3() to do_nfsd_create(), and add handling of EXCLUSIVE4_1. Signed-off-by: Mi Jinlong <mijinlong@cn.fujitsu.com> Signed-off-by: J. Bruce Fields <bfields@redhat.com>
2011-04-20Open with O_CREAT flag set fails to open existing files on non writable ↵Sachin Prabhu
directories An open on a NFS4 share using the O_CREAT flag on an existing file for which we have permissions to open but contained in a directory with no write permissions will fail with EACCES. A tcpdump shows that the client had set the open mode to UNCHECKED which indicates that the file should be created if it doesn't exist and encountering an existing flag is not an error. Since in this case the file exists and can be opened by the user, the NFS server is wrong in attempting to check create permissions on the parent directory. The patch adds a conditional statement to check for create permissions only if the file doesn't exist. Signed-off-by: Sachin S. Prabhu <sprabhu@redhat.com> Signed-off-by: J. Bruce Fields <bfields@redhat.com>
2011-04-11nfsd4: make fh_verify responsibility of nfsd_lookup_dentry callerJ. Bruce Fields
The secinfo caller actually won't want this. Signed-off-by: J. Bruce Fields <bfields@redhat.com>
2011-04-11nfsd: distinguish functions of NFSD_MAY_* flagsJ. Bruce Fields
Most of the NFSD_MAY_* flags actually request permissions, but over the years we've accreted a few that modify the behavior of the permission or open code in other ways. Distinguish the two cases a little more. In particular, allow the shortcut at the start of nfsd_permission to ignore the non-permission-requesting bits. Signed-off-by: J. Bruce Fields <bfields@redhat.com>
2011-03-24Merge branch 'for-2.6.39' of git://linux-nfs.org/~bfields/linuxLinus Torvalds
* 'for-2.6.39' of git://linux-nfs.org/~bfields/linux: SUNRPC: Remove resource leak in svc_rdma_send_error() nfsd: wrong index used in inner loop nfsd4: fix comment and remove unused nfsd4_file fields nfs41: make sure nfs server return right ca_maxresponsesize_cached nfsd: fix compile error svcrpc: fix bad argument in unix_domain_find nfsd4: fix struct file leak nfsd4: minor nfs4state.c reshuffling svcrpc: fix rare race on unix_domain creation nfsd41: modify the members value of nfsd4_op_flags nfsd: add proc file listing kernel's gss_krb5 enctypes gss:krb5 only include enctype numbers in gm_upcall_enctypes NFSD, VFS: Remove dead code in nfsd_rename() nfsd: kill unused macro definition locks: use assign_type()
2011-03-18don't pass 'mounting_here' flag to follow_down()Al Viro
it's always false now Signed-off-by: Al Viro <viro@zeniv.linux.org.uk>
2011-03-07NFSD, VFS: Remove dead code in nfsd_rename()Jesper Juhl
Currently we have the following code in fs/nfsd/vfs.c::nfsd_rename() : ... host_err = nfsd_break_lease(odentry->d_inode); if (host_err) goto out_drop_write; if (ndentry->d_inode) { host_err = nfsd_break_lease(ndentry->d_inode); if (host_err) goto out_drop_write; } if (host_err) goto out_drop_write; ... 'host_err' is guaranteed to be 0 by the time we test 'ndentry->d_inode'. If 'host_err' becomes != 0 inside the 'if' statement, then we goto 'out_drop_write'. So, after the 'if' statement there is no way that 'host_err' can be anything but 0, so the test afterwards is just dead code. This patch removes the dead code. Signed-off-by: Jesper Juhl <jj@chaosbits.net> Signed-off-by: J. Bruce Fields <bfields@redhat.com>
2011-02-14nfsd: break lease on unlink due to renameJ. Bruce Fields
4795bb37effb7b8fe77e2d2034545d062d3788a8 "nfsd: break lease on unlink, link, and rename", only broke the lease on the file that was being renamed, and didn't handle the case where the target path refers to an already-existing file that will be unlinked by a rename--in that case the target file should have any leases broken as well. Signed-off-by: J. Bruce Fields <bfields@redhat.com>
2011-02-14NFSD: memory corruption due to writing beyond the stat arrayKonstantin Khorenko
If nfsd fails to find an exported via NFS file in the readahead cache, it should increment corresponding nfsdstats counter (ra_depth[10]), but due to a bug it may instead write to ra_depth[11], corrupting the following field. In a kernel with NFSDv4 compiled in the corruption takes the form of an increment of a counter of the number of NFSv4 operation 0's received; since there is no operation 0, this is harmless. In a kernel with NFSDv4 disabled it corrupts whatever happens to be in the memory beyond nfsdstats. Signed-off-by: Konstantin Khorenko <khorenko@openvz.org> Cc: stable@kernel.org Signed-off-by: J. Bruce Fields <bfields@redhat.com>
2011-02-14nfsd: don't leak dentry count on mnt_want_write failureJ. Bruce Fields
The exit cleanup isn't quite right here. Signed-off-by: J. Bruce Fields <bfields@redhat.com>
2011-01-16Merge branch 'for-linus' of ↵Linus Torvalds
git://git.kernel.org/pub/scm/linux/kernel/git/viro/vfs-2.6 * 'for-linus' of git://git.kernel.org/pub/scm/linux/kernel/git/viro/vfs-2.6: (23 commits) sanitize vfsmount refcounting changes fix old umount_tree() breakage autofs4: Merge the remaining dentry ops tables Unexport do_add_mount() and add in follow_automount(), not ->d_automount() Allow d_manage() to be used in RCU-walk mode Remove a further kludge from __do_follow_link() autofs4: Bump version autofs4: Add v4 pseudo direct mount support autofs4: Fix wait validation autofs4: Clean up autofs4_free_ino() autofs4: Clean up dentry operations autofs4: Clean up inode operations autofs4: Remove unused code autofs4: Add d_manage() dentry operation autofs4: Add d_automount() dentry operation Remove the automount through follow_link() kludge code from pathwalk CIFS: Use d_automount() rather than abusing follow_link() NFS: Use d_automount() rather than abusing follow_link() AFS: Use d_automount() rather than abusing follow_link() Add an AT_NO_AUTOMOUNT flag to suppress terminal automount ...
2011-01-15Add a dentry op to allow processes to be held during pathwalk transitDavid Howells
Add a dentry op (d_manage) to permit a filesystem to hold a process and make it sleep when it tries to transit away from one of that filesystem's directories during a pathwalk. The operation is keyed off a new dentry flag (DCACHE_MANAGE_TRANSIT). The filesystem is allowed to be selective about which processes it holds and which it permits to continue on or prohibits from transiting from each flagged directory. This will allow autofs to hold up client processes whilst letting its userspace daemon through to maintain the directory or the stuff behind it or mounted upon it. The ->d_manage() dentry operation: int (*d_manage)(struct path *path, bool mounting_here); takes a pointer to the directory about to be transited away from and a flag indicating whether the transit is undertaken by do_add_mount() or do_move_mount() skipping through a pile of filesystems mounted on a mountpoint. It should return 0 if successful and to let the process continue on its way; -EISDIR to prohibit the caller from skipping to overmounted filesystems or automounting, and to use this directory; or some other error code to return to the user. ->d_manage() is called with namespace_sem writelocked if mounting_here is true and no other locks held, so it may sleep. However, if mounting_here is true, it may not initiate or wait for a mount or unmount upon the parameter directory, even if the act is actually performed by userspace. Within fs/namei.c, follow_managed() is extended to check with d_manage() first on each managed directory, before transiting away from it or attempting to automount upon it. follow_down() is renamed follow_down_one() and should only be used where the filesystem deliberately intends to avoid management steps (e.g. autofs). A new follow_down() is added that incorporates the loop done by all other callers of follow_down() (do_add/move_mount(), autofs and NFSD; whilst AFS, NFS and CIFS do use it, their use is removed by converting them to use d_automount()). The new follow_down() calls d_manage() as appropriate. It also takes an extra parameter to indicate if it is being called from mount code (with namespace_sem writelocked) which it passes to d_manage(). follow_down() ignores automount points so that it can be used to mount on them. __follow_mount_rcu() is made to abort rcu-walk mode if it hits a directory with DCACHE_MANAGE_TRANSIT set on the basis that we're probably going to have to sleep. It would be possible to enter d_manage() in rcu-walk mode too, and have that determine whether to abort or not itself. That would allow the autofs daemon to continue on in rcu-walk mode. Note that DCACHE_MANAGE_TRANSIT on a directory should be cleared when it isn't required as every tranist from that directory will cause d_manage() to be invoked. It can always be set again when necessary. ========================== WHAT THIS MEANS FOR AUTOFS ========================== Autofs currently uses the lookup() inode op and the d_revalidate() dentry op to trigger the automounting of indirect mounts, and both of these can be called with i_mutex held. autofs knows that the i_mutex will be held by the caller in lookup(), and so can drop it before invoking the daemon - but this isn't so for d_revalidate(), since the lock is only held on _some_ of the code paths that call it. This means that autofs can't risk dropping i_mutex from its d_revalidate() function before it calls the daemon. The bug could manifest itself as, for example, a process that's trying to validate an automount dentry that gets made to wait because that dentry is expired and needs cleaning up: mkdir S ffffffff8014e05a 0 32580 24956 Call Trace: [<ffffffff885371fd>] :autofs4:autofs4_wait+0x674/0x897 [<ffffffff80127f7d>] avc_has_perm+0x46/0x58 [<ffffffff8009fdcf>] autoremove_wake_function+0x0/0x2e [<ffffffff88537be6>] :autofs4:autofs4_expire_wait+0x41/0x6b [<ffffffff88535cfc>] :autofs4:autofs4_revalidate+0x91/0x149 [<ffffffff80036d96>] __lookup_hash+0xa0/0x12f [<ffffffff80057a2f>] lookup_create+0x46/0x80 [<ffffffff800e6e31>] sys_mkdirat+0x56/0xe4 versus the automount daemon which wants to remove that dentry, but can't because the normal process is holding the i_mutex lock: automount D ffffffff8014e05a 0 32581 1 32561 Call Trace: [<ffffffff80063c3f>] __mutex_lock_slowpath+0x60/0x9b [<ffffffff8000ccf1>] do_path_lookup+0x2ca/0x2f1 [<ffffffff80063c89>] .text.lock.mutex+0xf/0x14 [<ffffffff800e6d55>] do_rmdir+0x77/0xde [<ffffffff8005d229>] tracesys+0x71/0xe0 [<ffffffff8005d28d>] tracesys+0xd5/0xe0 which means that the system is deadlocked. This patch allows autofs to hold up normal processes whilst the daemon goes ahead and does things to the dentry tree behind the automouter point without risking a deadlock as almost no locks are held in d_manage() and none in d_automount(). Signed-off-by: David Howells <dhowells@redhat.com> Was-Acked-by: Ian Kent <raven@themaw.net> Signed-off-by: Al Viro <viro@zeniv.linux.org.uk>
2011-01-14Merge branch 'for-2.6.38' of git://linux-nfs.org/~bfields/linuxLinus Torvalds
* 'for-2.6.38' of git://linux-nfs.org/~bfields/linux: (62 commits) nfsd4: fix callback restarting nfsd: break lease on unlink, link, and rename nfsd4: break lease on nfsd setattr nfsd: don't support msnfs export option nfsd4: initialize cb_per_client nfsd4: allow restarting callbacks nfsd4: simplify nfsd4_cb_prepare nfsd4: give out delegations more quickly in 4.1 case nfsd4: add helper function to run callbacks nfsd4: make sure sequence flags are set after destroy_session nfsd4: re-probe callback on connection loss nfsd4: set sequence flag when backchannel is down nfsd4: keep finer-grained callback status rpc: allow xprt_class->setup to return a preexisting xprt rpc: keep backchannel xprt as long as server connection rpc: move sk_bc_xprt to svc_xprt nfsd4: allow backchannel recovery nfsd4: support BIND_CONN_TO_SESSION nfsd4: modify session list under cl_lock Documentation: fl_mylease no longer exists ... Fix up conflicts in fs/nfsd/vfs.c with the vfs-scale work. The vfs-scale work touched some msnfs cases, and this merge removes support for that entirely, so the conflict was trivial to resolve.
2011-01-13nfsd: break lease on unlink, link, and renameJ. Bruce Fields
Any change to any of the links pointing to an entry should also break delegations. Signed-off-by: J. Bruce Fields <bfields@redhat.com>
2011-01-13nfsd4: break lease on nfsd setattrJ. Bruce Fields
Leases (delegations) should really be broken on any metadata change, not just on size change. Signed-off-by: J. Bruce Fields <bfields@redhat.com>
2011-01-13nfsd: don't support msnfs export optionJ. Bruce Fields
We've long had these pointless #ifdef MSNFS's sprinkled throughout the code--pointless because MSNFS is always defined (and we give no config option to make that easy to change). So we could just remove the ifdef's and compile the resulting code unconditionally. But as long as we're there: why not just rip out this code entirely? The only purpose is to implement the "msnfs" export option which turns on Windows-like behavior in some cases, and: - the export option isn't documented anywhere; - the userland utilities (which would need to be able to parse "msnfs" in an export file) don't support it; - I don't know how to maintain this, as I don't know what the proper behavior is; and - google shows no evidence that anyone has ever used this. Signed-off-by: J. Bruce Fields <bfields@redhat.com>
2011-01-13Merge branch 'for-2.6.38/core' of git://git.kernel.dk/linux-2.6-blockLinus Torvalds
* 'for-2.6.38/core' of git://git.kernel.dk/linux-2.6-block: (43 commits) block: ensure that completion error gets properly traced blktrace: add missing probe argument to block_bio_complete block cfq: don't use atomic_t for cfq_group block cfq: don't use atomic_t for cfq_queue block: trace event block fix unassigned field block: add internal hd part table references block: fix accounting bug on cross partition merges kref: add kref_test_and_get bio-integrity: mark kintegrityd_wq highpri and CPU intensive block: make kblockd_workqueue smarter Revert "sd: implement sd_check_events()" block: Clean up exit_io_context() source code. Fix compile warnings due to missing removal of a 'ret' variable fs/block: type signature of major_to_index(int) to major_to_index(unsigned) block: convert !IS_ERR(p) && p to !IS_ERR_NOR_NULL(p) cfq-iosched: don't check cfqg in choose_service_tree() fs/splice: Pull buf->ops->confirm() from splice_from_pipe actors cdrom: export cdrom_check_events() sd: implement sd_check_events() sr: implement sr_check_events() ...
2011-01-07fs: dcache scale dentry refcountNick Piggin
Make d_count non-atomic and protect it with d_lock. This allows us to ensure a 0 refcount dentry remains 0 without dcache_lock. It is also fairly natural when we start protecting many other dentry members with d_lock. Signed-off-by: Nick Piggin <npiggin@kernel.dk>
2011-01-04nfsd4: move idmap and acl header files into fs/nfsdJ. Bruce Fields
These are internal nfsd interfaces. Signed-off-by: J. Bruce Fields <bfields@redhat.com>
2011-01-04nfsd: remove some unnecessary dropit handlingJ. Bruce Fields
We no longer need a few of these special cases. Signed-off-by: J. Bruce Fields <bfields@redhat.com>
2010-12-20Fix compile warnings due to missing removal of a 'ret' variableJens Axboe
Commit a8adbe3 forgot to remove the return variable, kill it. drivers/block/loop.c: In function 'lo_splice_actor': drivers/block/loop.c:398: warning: unused variable 'ret' [...] fs/nfsd/vfs.c: In function 'nfsd_splice_actor': fs/nfsd/vfs.c:848: warning: unused variable 'ret' Reported-by: Stephen Rothwell <sfr@canb.auug.org.au> Signed-off-by: Jens Axboe <jaxboe@fusionio.com>
2010-12-17fs/splice: Pull buf->ops->confirm() from splice_from_pipe actorsMichał Mirosław
This patch pulls calls to buf->ops->confirm() from all actors passed (also indirectly) to splice_from_pipe_feed(). Is avoiding the call to buf->ops->confirm() while splice()ing to /dev/null is an intentional optimization? No other user does that and this will remove this special case. Against current linux.git 6313e3c21743cc88bb5bd8aa72948ee1e83937b6. Signed-off-by: Michał Mirosław <mirq-linux@rere.qmqm.pl> Signed-off-by: Jens Axboe <jaxboe@fusionio.com>
2010-10-25fs: add sync_inode_metadataChristoph Hellwig
Add a new helper to write out the inode using the writeback code, that is including the correct dirty bit and list manipulation. A few of filesystems already opencode this, and a lot of others should be using it instead of using write_inode_now which also writes out the data. Signed-off-by: Christoph Hellwig <hch@lst.de> Signed-off-by: Al Viro <viro@zeniv.linux.org.uk>
2010-08-26nfsd: fix NULL dereference in nfsd_statfs()Takashi Iwai
The commit ebabe9a9001af0af56c0c2780ca1576246e7a74b pass a struct path to vfs_statfs introduced the struct path initialization, and this seems to trigger an Oops on my machine. fh_dentry field may be NULL and set later in fh_verify(), thus the initialization of path must be after fh_verify(). Signed-off-by: Takashi Iwai <tiwai@suse.de> Reviewed-by: Christoph Hellwig <hch@lst.de> Reviewed-by: Minchan Kim <minchan.kim@gmail.com> Signed-off-by: J. Bruce Fields <bfields@redhat.com>
2010-08-10Merge branch 'for-linus' of git://git.infradead.org/users/eparis/notifyLinus Torvalds
* 'for-linus' of git://git.infradead.org/users/eparis/notify: (132 commits) fanotify: use both marks when possible fsnotify: pass both the vfsmount mark and inode mark fsnotify: walk the inode and vfsmount lists simultaneously fsnotify: rework ignored mark flushing fsnotify: remove global fsnotify groups lists fsnotify: remove group->mask fsnotify: remove the global masks fsnotify: cleanup should_send_event fanotify: use the mark in handler functions audit: use the mark in handler functions dnotify: use the mark in handler functions inotify: use the mark in handler functions fsnotify: send fsnotify_mark to groups in event handling functions fsnotify: Exchange list heads instead of moving elements fsnotify: srcu to protect read side of inode and vfsmount locks fsnotify: use an explicit flag to indicate fsnotify_destroy_mark has been called fsnotify: use _rcu functions for mark list traversal fsnotify: place marks on object in order of group memory address vfs/fsnotify: fsnotify_close can delay the final work in fput fsnotify: store struct file not struct path ... Fix up trivial delete/modify conflict in fs/notify/inotify/inotify.c.
2010-08-10Merge branch 'for-linus' of ↵Linus Torvalds
git://git.kernel.org/pub/scm/linux/kernel/git/viro/vfs-2.6 * 'for-linus' of git://git.kernel.org/pub/scm/linux/kernel/git/viro/vfs-2.6: (96 commits) no need for list_for_each_entry_safe()/resetting with superblock list Fix sget() race with failing mount vfs: don't hold s_umount over close_bdev_exclusive() call sysv: do not mark superblock dirty on remount sysv: do not mark superblock dirty on mount btrfs: remove junk sb_dirt change BFS: clean up the superblock usage AFFS: wait for sb synchronization when needed AFFS: clean up dirty flag usage cifs: truncate fallout mbcache: fix shrinker function return value mbcache: Remove unused features add f_flags to struct statfs(64) pass a struct path to vfs_statfs update VFS documentation for method changes. All filesystems that need invalidate_inode_buffers() are doing that explicitly convert remaining ->clear_inode() to ->evict_inode() Make ->drop_inode() just return whether inode needs to be dropped fs/inode.c:clear_inode() is gone fs/inode.c:evict() doesn't care about delete vs. non-delete paths now ... Fix up trivial conflicts in fs/nilfs2/super.c
2010-08-09pass a struct path to vfs_statfsChristoph Hellwig
We'll need the path to implement the flags field for statvfs support. We do have it available in all callers except: - ecryptfs_statfs. This one doesn't actually need vfs_statfs but just needs to do a caller to the lower filesystem statfs method. - sys_ustat. Add a non-exported statfs_by_dentry helper for it which doesn't won't be able to fill out the flags field later on. In addition rename the helpers for statfs vs fstatfs to do_*statfs instead of the misleading vfs prefix. Signed-off-by: Christoph Hellwig <hch@lst.de> Signed-off-by: Al Viro <viro@zeniv.linux.org.uk>
2010-08-07Merge branch 'for-2.6.36' of git://linux-nfs.org/~bfields/linuxLinus Torvalds
* 'for-2.6.36' of git://linux-nfs.org/~bfields/linux: (34 commits) nfsd4: fix file open accounting for RDWR opens nfsd: don't allow setting maxblksize after svc created nfsd: initialize nfsd versions before creating svc net: sunrpc: removed duplicated #include nfsd41: Fix a crash when a callback is retried nfsd: fix startup/shutdown order bug nfsd: minor nfsd read api cleanup gcc-4.6: nfsd: fix initialized but not read warnings nfsd4: share file descriptors between stateid's nfsd4: fix openmode checking on IO using lock stateid nfsd4: miscellaneous process_open2 cleanup nfsd4: don't pretend to support write delegations nfsd: bypass readahead cache when have struct file nfsd: minor nfsd_svc() cleanup nfsd: move more into nfsd_startup() nfsd: just keep single lockd reference for nfsd nfsd: clean up nfsd_create_serv error handling nfsd: fix error handling in __write_ports_addxprt nfsd: fix error handling when starting nfsd with rpcbind down nfsd4: fix v4 state shutdown error paths ...
2010-07-30nfsd: minor nfsd read api cleanupJ. Bruce Fields
Christoph points that the NFSv2/v3 callers know which case they want here, so we may as well just call the file=NULL case directly instead of making this conditional. Cc: Christoph Hellwig <hch@infradead.org> Signed-off-by: J. Bruce Fields <bfields@redhat.com>
2010-07-29gcc-4.6: nfsd: fix initialized but not read warningsAndi Kleen
Fixes at least one real minor bug: the nfs4 recovery dir sysctl would not return its status properly. Also I finished Al's 1e41568d7378d ("Take ima_path_check() in nfsd past dentry_open() in nfsd_open()") commit, it moved the IMA code, but left the old path initializer in there. The rest is just dead code removed I think, although I was not fully sure about the "is_borc" stuff. Some more review would be still good. Found by gcc 4.6's new warnings. Signed-off-by: Andi Kleen <ak@linux.intel.com> Cc: Al Viro <viro@zeniv.linux.org.uk> Cc: Neil Brown <neilb@suse.de> Signed-off-by: Andrew Morton <akpm@linux-foundation.org> Signed-off-by: J. Bruce Fields <bfields@redhat.com>
2010-07-28fsnotify: pass a file instead of an inode to open, read, and writeEric Paris
fanotify, the upcoming notification system actually needs a struct path so it can do opens in the context of listeners, and it needs a file so it can get f_flags from the original process. Close was the only operation that already was passing a struct file to the notification hook. This patch passes a file for access, modify, and open as well as they are easily available to these hooks. Signed-off-by: Eric Paris <eparis@redhat.com>
2010-07-27nfsd: bypass readahead cache when have struct fileJ. Bruce Fields
The readahead cache compensates for the fact that the NFS server currently does an open and close on every IO operation in the NFSv2 and NFSv3 case. In the NFSv4 case we have long-lived struct files associated with client opens, so there's no need for this. In fact, concurrent IO's using trying to modify the same file->f_ra may cause problems. So, don't bother with the readahead cache in that case. Note eventually we'll likely do this in the v2/v3 case as well by keeping a cache of struct files instead of struct file_ra_state's. Signed-off-by: J. Bruce Fields <bfields@redhat.com>
2010-07-23nfsd: remove unused assignment from nfsd_linkJ. Bruce Fields
Trivial cleanup, since "dest" is never used. Reported-by: Anshul Madan <Anshul.Madan@netapp.com> Signed-off-by: J. Bruce Fields <bfields@redhat.com>
2010-07-06nfsd4: comment nitpickJ. Bruce Fields
Reported-by: "Madan, Anshul" <Anshul.Madan@netapp.com> Signed-off-by: J. Bruce Fields <bfields@citi.umich.edu>
2010-06-09Merge branch 'for-2.6.35' of git://linux-nfs.org/~bfields/linuxLinus Torvalds
* 'for-2.6.35' of git://linux-nfs.org/~bfields/linux: nfsd4: shut down callback queue outside state lock nfsd: nfsd_setattr needs to call commit_metadata
2010-06-08Merge branch 'for-2.6.34-incoming' into for-2.6.35-incomingJ. Bruce Fields
2010-06-01nfsd: nfsd_setattr needs to call commit_metadataChristoph Hellwig
The conversion of write_inode_now calls to commit_metadata in commit f501912a35c02eadc55ca9396ece55fe36f785d0 missed out the call in nfsd_setattr. But without this conversion we can't guarantee that a SETATTR request has actually been commited to disk with XFS, which causes a regression from 2.6.32 (only for NFSv2, but anyway). Signed-off-by: Christoph Hellwig <hch@lst.de> Cc: stable@kernel.org Signed-off-by: J. Bruce Fields <bfields@citi.umich.edu>
2010-05-21sanitize vfs_fsync calling conventionsChristoph Hellwig
Now that the last user passing a NULL file pointer is gone we can remove the redundant dentry argument and associated hacks inside vfs_fsynmc_range. The next step will be removig the dentry argument from ->fsync, but given the luck with the last round of method prototype changes I'd rather defer this until after the main merge window. Signed-off-by: Christoph Hellwig <hch@lst.de> Signed-off-by: Al Viro <viro@zeniv.linux.org.uk>
2010-05-04Merge commit 'v2.6.34-rc6'J. Bruce Fields
Conflicts: fs/nfsd/nfs4callback.c
implicit slab.h inclusion from percpu.h percpu.h is included by sched.h and module.h and thus ends up being included when building most .c files. percpu.h includes slab.h which in turn includes gfp.h making everything defined by the two files universally available and complicating inclusion dependencies. percpu.h -> slab.h dependency is about to be removed. Prepare for this change by updating users of gfp and slab facilities include those headers directly instead of assuming availability. As this conversion needs to touch large number of source files, the following script is used as the basis of conversion. http://userweb.kernel.org/~tj/misc/slabh-sweep.py The script does the followings. * Scan files for gfp and slab usages and update includes such that only the necessary includes are there. ie. if only gfp is used, gfp.h, if slab is used, slab.h. * When the script inserts a new include, it looks at the include blocks and try to put the new include such that its order conforms to its surrounding. It's put in the include block which contains core kernel includes, in the same order that the rest are ordered - alphabetical, Christmas tree, rev-Xmas-tree or at the end if there doesn't seem to be any matching order. * If the script can't find a place to put a new include (mostly because the file doesn't have fitting include block), it prints out an error message indicating which .h file needs to be added to the file. The conversion was done in the following steps. 1. The initial automatic conversion of all .c files updated slightly over 4000 files, deleting around 700 includes and adding ~480 gfp.h and ~3000 slab.h inclusions. The script emitted errors for ~400 files. 2. Each error was manually checked. Some didn't need the inclusion, some needed manual addition while adding it to implementation .h or embedding .c file was more appropriate for others. This step added inclusions to around 150 files. 3. The script was run again and the output was compared to the edits from #2 to make sure no file was left behind. 4. Several build tests were done and a couple of problems were fixed. e.g. lib/decompress_*.c used malloc/free() wrappers around slab APIs requiring slab.h to be added manually. 5. The script was run on all .h files but without automatically editing them as sprinkling gfp.h and slab.h inclusions around .h files could easily lead to inclusion dependency hell. Most gfp.h inclusion directives were ignored as stuff from gfp.h was usually wildly available and often used in preprocessor macros. Each slab.h inclusion directive was examined and added manually as necessary. 6. percpu.h was updated not to include slab.h. 7. Build test were done on the following configurations and failures were fixed. CONFIG_GCOV_KERNEL was turned off for all tests (as my distributed build env didn't work with gcov compiles) and a few more options had to be turned off depending on archs to make things build (like ipr on powerpc/64 which failed due to missing writeq). * x86 and x86_64 UP and SMP allmodconfig and a custom test config. * powerpc and powerpc64 SMP allmodconfig * sparc and sparc64 SMP allmodconfig * ia64 SMP allmodconfig * s390 SMP allmodconfig * alpha SMP allmodconfig * um on x86_64 SMP allmodconfig 8. percpu.h modifications were reverted so that it could be applied as a separate patch and serve as bisection point. Given the fact that I had only a couple of failures from tests on step 6, I'm fairly confident about the coverage of this conversion patch. If there is a breakage, it's likely to be something in one of the arch headers which should be easily discoverable easily on most builds of the specific arch. Signed-off-by: Tejun Heo <tj@kernel.org> Guess-its-ok-by: Christoph Lameter <cl@linux-foundation.org> Cc: Ingo Molnar <mingo@redhat.com> Cc: Lee Schermerhorn <Lee.Schermerhorn@hp.com>
2010-03-22nfsd: don't break lease while servicing a COMMITJeff Layton
This is the second attempt to fix the problem whereby a COMMIT call causes a lease break and triggers a possible deadlock. The problem is that nfsd attempts to break a lease on a COMMIT call. This triggers a delegation recall if the lease is held for a delegation. If the client is the one holding the delegation and it's the same one on which it's issuing the COMMIT, then it can't return that delegation until the COMMIT is complete. But, nfsd won't complete the COMMIT until the delegation is returned. The client and server are essentially deadlocked until the state is marked bad (due to the client not responding on the callback channel). The first patch attempted to deal with this by eliminating the open of the file altogether and simply had nfsd_commit pass a NULL file pointer to the vfs_fsync_range. That would conflict with some work in progress by Christoph Hellwig to clean up the fsync interface, so this patch takes a different approach. This declares a new NFSD_MAY_NOT_BREAK_LEASE access flag that indicates to nfsd_open that it should not break any leases when opening the file, and has nfsd_commit set that flag on the nfsd_open call. For now, this patch leaves nfsd_commit opening the file with write access since I'm not clear on what sort of access would be more appropriate. Signed-off-by: Jeff Layton <jlayton@redhat.com> Cc: stable@kernel.org Signed-off-by: J. Bruce Fields <bfields@citi.umich.edu>
2010-03-06Merge branch 'for-2.6.34' of git://linux-nfs.org/~bfields/linuxLinus Torvalds
* 'for-2.6.34' of git://linux-nfs.org/~bfields/linux: (22 commits) nfsd4: fix minor memory leak svcrpc: treat uid's as unsigned nfsd: ensure sockets are closed on error Revert "sunrpc: move the close processing after do recvfrom method" Revert "sunrpc: fix peername failed on closed listener" sunrpc: remove unnecessary svc_xprt_put NFSD: NFSv4 callback client should use RPC_TASK_SOFTCONN xfs_export_operations.commit_metadata commit_metadata export operation replacing nfsd_sync_dir lockd: don't clear sm_monitored on nsm_reboot_lookup lockd: release reference to nsm_handle in nlm_host_rebooted nfsd: Use vfs_fsync_range() in nfsd_commit NFSD: Create PF_INET6 listener in write_ports SUNRPC: NFS kernel APIs shouldn't return ENOENT for "transport not found" SUNRPC: Bury "#ifdef IPV6" in svc_create_xprt() NFSD: Support AF_INET6 in svc_addsock() function SUNRPC: Use rpc_pton() in ip_map_parse() nfsd: 4.1 has an rfc number nfsd41: Create the recovery entry for the NFSv4.1 client nfsd: use vfs_fsync for non-directories ...
2010-03-05Merge branch 'for_linus' of ↵Linus Torvalds
git://git.kernel.org/pub/scm/linux/kernel/git/jack/linux-fs-2.6 * 'for_linus' of git://git.kernel.org/pub/scm/linux/kernel/git/jack/linux-fs-2.6: (33 commits) quota: stop using QUOTA_OK / NO_QUOTA dquot: cleanup dquot initialize routine dquot: move dquot initialization responsibility into the filesystem dquot: cleanup dquot drop routine dquot: move dquot drop responsibility into the filesystem dquot: cleanup dquot transfer routine dquot: move dquot transfer responsibility into the filesystem dquot: cleanup inode allocation / freeing routines dquot: cleanup space allocation / freeing routines ext3: add writepage sanity checks ext3: Truncate allocated blocks if direct IO write fails to update i_size quota: Properly invalidate caches even for filesystems with blocksize < pagesize quota: generalize quota transfer interface quota: sb_quota state flags cleanup jbd: Delay discarding buffers in journal_unmap_buffer ext3: quota_write cross block boundary behaviour quota: drop permission checks from xfs_fs_set_xstate/xfs_fs_set_xquota quota: split out compat_sys_quotactl support from quota.c quota: split out netlink notification support from quota.c quota: remove invalid optimization from quota_sync_all ... Fixed trivial conflicts in fs/namei.c and fs/ufs/inode.c
2010-03-05dquot: move dquot initialization responsibility into the filesystemChristoph Hellwig
Currently various places in the VFS call vfs_dq_init directly. This means we tie the quota code into the VFS. Get rid of that and make the filesystem responsible for the initialization. For most metadata operations this is a straight forward move into the methods, but for truncate and open it's a bit more complicated. For truncate we currently only call vfs_dq_init for the sys_truncate case because open already takes care of it for ftruncate and open(O_TRUNC) - the new code causes an additional vfs_dq_init for those which is harmless. For open the initialization is moved from do_filp_open into the open method, which means it happens slightly earlier now, and only for regular files. The latter is fine because we don't need to initialize it for operations on special files, and we already do it as part of the namespace operations for directories. Add a dquot_file_open helper that filesystems that support generic quotas can use to fill in ->open. Signed-off-by: Christoph Hellwig <hch@lst.de> Signed-off-by: Jan Kara <jack@suse.cz>
2010-03-04Merge branch 'for-linus' of git://oss.sgi.com/xfs/xfs into for-2.6.34-incomingJ. Bruce Fields
Resolve merge conflict in fs/xfs/linux-2.6/xfs_export.c.
