commit c1ac3ffcd0bc7e9617f62be8c7043d53ab84deac upstream.
If vfs_getattr in fill_post_wcc returns an error, we don't
set fh_post_change.
For NFSv4, this can result in set_change_info triggering a BUG_ON.
i.e. fh_post_saved being zero isn't really a bug.
So:
- instead of BUGging when fh_post_saved is zero, just clear ->atomic.
- if vfs_getattr fails in fill_post_wcc, take a copy of i_ctime anyway.
This will be used i seg_change_info, but not overly trusted.
- While we are there, remove the pointless 'if' statements in set_change_info.
There is no harm setting all the values.
Signed-off-by: NeilBrown <neilb@suse.de>
Signed-off-by: J. Bruce Fields <bfields@redhat.com>
As of commit 43a9aa64a2f4330a9cb59aaf5c5636566bce067c "NFSD:
Fill in WCC data for REMOVE, RMDIR, MKNOD, and MKDIR", we sometimes call
fh_unlock on a filehandle that isn't fully initialized.
We should fix up the callers, but as a quick fix it is also sufficient
just to remove this assertion.
Reported-by: Marius Tolzmann <tolzmann@molgen.mpg.de>
Cc: Chuck Lever <chuck.lever@oracle.com>
The NFSv4 client's callback server calls svc_gss_principal(), which
is defined in the auth_rpcgss.ko
The NFSv4 server has the same dependency, and in addition calls
svcauth_gss_flavor(), gss_mech_get_by_pseudoflavor(),
gss_pseudoflavor_to_service() and gss_mech_put() from the same module.
The module auth_rpcgss itself has no dependencies aside from sunrpc,
so we only need to select RPCSEC_GSS.
Reported-by: Uwe Kleine-König <u.kleine-koenig@pengutronix.de>
Signed-off-by: Trond Myklebust <Trond.Myklebust@netapp.com>
* 'for-2.6.36' of git://linux-nfs.org/~bfields/linux:
nfsd4: mask out non-access bits in nfs4_access_to_omode
This fixes an unnecessary BUG().
nfsd: fix NULL dereference in nfsd_statfs()
nfsd4: fix downgrade/lock logic
nfsd4: typo fix in find_any_file
nfsd4: bad BUG() in preprocess_stateid_op
The commit ebabe9a9001af0af56c0c2780ca1576246e7a74b
pass a struct path to vfs_statfs
introduced the struct path initialization, and this seems to trigger
an Oops on my machine.
fh_dentry field may be NULL and set later in fh_verify(), thus the
initialization of path must be after fh_verify().
Reviewed-by: Minchan Kim <minchan.kim@gmail.com>
If we already had a RW open for a file, and get a readonly open, we were
piggybacking on the existing RW open. That's inconsistent with the
downgrade logic which blows away the RW open assuming you'll still have
a readonly open.
Also, make sure there is a readonly or writeonly open available for
locking, again to prevent bad behavior in downgrade cases when any RW
open may be lost.
It's OK for this function to return without setting filp--we do it in
the special-stateid case.
And there's a legitimate case where we can hit this, since we do permit
reads on write-only stateid's.
* 'bugfixes' of git://git.linux-nfs.org/projects/trondmy/nfs-2.6:
NFS: Fix an Oops in the NFSv4 atomic open code
NFS: Fix the selection of security flavours in Kconfig
NFS: fix the return value of nfs_file_fsync()
rpcrdma: Fix SQ size calculation when memreg is FRMR
xprtrdma: Do not truncate iova_start values in frmr registrations.
nfs: Remove redundant NULL check upon kfree()
nfs: Add "lookupcache" to displayed mount options
NFS: allow close-to-open cache semantics to apply to root of NFS filesystem
SUNRPC: fix NFS client over TCP hangs due to packet loss (Bug 16494)
Randy Dunlap reports:
ERROR: "svc_gss_principal" [fs/nfs/nfs.ko] undefined!
because in fs/nfs/Kconfig, NFS_V4 selects RPCSEC_GSS_KRB5
and/or in fs/nfsd/Kconfig, NFSD_V4 selects RPCSEC_GSS_KRB5.
RPCSEC_GSS_KRB5 does 5 selects, but none of these is enforced/followed
by the fs/nfs[d]/Kconfig configs:
select SUNRPC_GSS
select CRYPTO
select CRYPTO_MD5
select CRYPTO_DES
select CRYPTO_CBC
Reported-by: Randy Dunlap <randy.dunlap@oracle.com>
Cc: J. Bruce Fields <bfields@fieldses.org>
* 'for-linus' of git://git.infradead.org/users/eparis/notify: (132 commits)
fanotify: use both marks when possible
fsnotify: pass both the vfsmount mark and inode mark
fsnotify: walk the inode and vfsmount lists simultaneously
fsnotify: rework ignored mark flushing
fsnotify: remove global fsnotify groups lists
fsnotify: remove group->mask
fsnotify: remove the global masks
fsnotify: cleanup should_send_event
fanotify: use the mark in handler functions
audit: use the mark in handler functions
dnotify: use the mark in handler functions
inotify: use the mark in handler functions
fsnotify: send fsnotify_mark to groups in event handling functions
fsnotify: Exchange list heads instead of moving elements
fsnotify: srcu to protect read side of inode and vfsmount locks
fsnotify: use an explicit flag to indicate fsnotify_destroy_mark has been called
fsnotify: use _rcu functions for mark list traversal
fsnotify: place marks on object in order of group memory address
vfs/fsnotify: fsnotify_close can delay the final work in fput
fsnotify: store struct file not struct path
Fix up trivial delete/modify conflict in fs/notify/inotify/inotify.c.
git://git.kernel.org/pub/scm/linux/kernel/git/viro/vfs-2.6
* 'for-linus' of git://git.kernel.org/pub/scm/linux/kernel/git/viro/vfs-2.6: (96 commits)
no need for list_for_each_entry_safe()/resetting with superblock list
Fix sget() race with failing mount
vfs: don't hold s_umount over close_bdev_exclusive() call
sysv: do not mark superblock dirty on remount
sysv: do not mark superblock dirty on mount
btrfs: remove junk sb_dirt change
BFS: clean up the superblock usage
AFFS: wait for sb synchronization when needed
AFFS: clean up dirty flag usage
cifs: truncate fallout
mbcache: fix shrinker function return value
mbcache: Remove unused features
add f_flags to struct statfs(64)
update VFS documentation for method changes.
All filesystems that need invalidate_inode_buffers() are doing that explicitly
convert remaining ->clear_inode() to ->evict_inode()
Make ->drop_inode() just return whether inode needs to be dropped
fs/inode.c:clear_inode() is gone
fs/inode.c:evict() doesn't care about delete vs. non-delete paths now
Fix up trivial conflicts in fs/nilfs2/super.c
We'll need the path to implement the flags field for statvfs support.
We do have it available in all callers except:
- ecryptfs_statfs. This one doesn't actually need vfs_statfs but just
needs to do a caller to the lower filesystem statfs method.
- sys_ustat. Add a non-exported statfs_by_dentry helper for it which
doesn't won't be able to fill out the flags field later on.
In addition rename the helpers for statfs vs fstatfs to do_*statfs instead
of the misleading vfs prefix.
* 'for-2.6.36' of git://linux-nfs.org/~bfields/linux: (34 commits)
nfsd4: fix file open accounting for RDWR opens
nfsd: don't allow setting maxblksize after svc created
nfsd: initialize nfsd versions before creating svc
net: sunrpc: removed duplicated #include
nfsd41: Fix a crash when a callback is retried
nfsd: fix startup/shutdown order bug
nfsd: minor nfsd read api cleanup
gcc-4.6: nfsd: fix initialized but not read warnings
nfsd4: share file descriptors between stateid's
nfsd4: fix openmode checking on IO using lock stateid
nfsd4: miscellaneous process_open2 cleanup
nfsd4: don't pretend to support write delegations
nfsd: bypass readahead cache when have struct file
nfsd: minor nfsd_svc() cleanup
nfsd: move more into nfsd_startup()
nfsd: just keep single lockd reference for nfsd
nfsd: clean up nfsd_create_serv error handling
nfsd: fix error handling in __write_ports_addxprt
nfsd: fix error handling when starting nfsd with rpcbind down
nfsd4: fix v4 state shutdown error paths
Commit f9d7562fdb9dc0ada3a7aba5dbbe9d965e2a105d "nfsd4: share file
descriptors between stateid's" didn't correctly account for O_RDWR opens.
Symptoms include leaked files, resulting in failures to unmount and/or
warnings about orphaned inodes on reboot.
It's harmless to set this after the server is created, but also
ineffective, since the value is only used at the time of
svc_create_pooled(). So fail the attempt, in keeping with the pattern
set by write_versions, write_{lease,grace}time and write_recoverydir.
(This could break userspace that tried to write to nfsd/max_block_size
between setting up sockets and starting the server. However, such code
wouldn't have worked anyway, and I don't know of any examples--rpc.nfsd
in nfs-utils, probably the only user of the interface, doesn't do that.)
Commit 59db4a0c102e0de226a3395dbf25ea51bf845937 "nfsd: move more into
nfsd_startup()" inadvertently moved nfsd_versions after
nfsd_create_svc(). On older distributions using an rpc.nfsd that does
not explicitly set the list of nfsd versions, this results in
svc-create_pooled() being called with an empty versions array. The
resulting incomplete initialization leads to a NULL dereference in
svc_process_common() the first time a client accesses the server.
Move nfsd_reset_versions() back before the svc_create_pooled(); this
time, put it closer to the svc_create_pooled() call, to make this
mistake more difficult in the future.
If a callback is retried at nfsd4_cb_recall_done() due to
some error, the returned rpc reply crashes here:
@@ -514,6 +514,7 @@ decode_cb_sequence(struct xdr_stream *xdr, struct nfsd4_cb_sequence *res,
u32 dummy;
__be32 *p;
+ BUG_ON(!res);
if (res->cbs_minorversion == 0)
return 0;
[BUG_ON added for demonstration]
This is because the nfsd4_cb_done_sequence() has NULLed out
the task->tk_msg.rpc_resp pointer.
Also eventually the rpc would use the new slot without making
sure it is free by calling nfsd41_cb_setup_sequence().
This problem was introduced by a 4.1 protocol addition patch:
[0421b5c5] nfsd41: Backchannel: Implement cb_recall over NFSv4.1
Which was overlooking the possibility of an RPC callback retries.
For not-4.1 case redoing the _prepare is harmless.
Signed-off-by: Boaz Harrosh <bharrosh@panasas.com>
We must create the server before we can call init_socks or check the
number of threads.
Symptoms were a NULL pointer dereference in nfsd_svc(). Problem
identified by Jeff Layton.
Also fix a minor cleanup-on-error case in nfsd_startup().
Reported-by: Tetsuo Handa <penguin-kernel@I-love.SAKURA.ne.jp>
Christoph points that the NFSv2/v3 callers know which case they want
here, so we may as well just call the file=NULL case directly instead of
making this conditional.
Fixes at least one real minor bug: the nfs4 recovery dir sysctl
would not return its status properly.
Also I finished Al's 1e41568d7378d ("Take ima_path_check() in nfsd
past dentry_open() in nfsd_open()") commit, it moved the IMA
code, but left the old path initializer in there.
The rest is just dead code removed I think, although I was not
fully sure about the "is_borc" stuff. Some more review
would be still good.
Found by gcc 4.6's new warnings.
Cc: Neil Brown <neilb@suse.de>
The vfs doesn't really allow us to "upgrade" a file descriptor from
read-only to read-write, and our attempt to do so in nfs4_upgrade_open
is ugly and incomplete.
Move to a different scheme where we keep multiple opens, shared between
open stateid's, in the nfs4_file struct. Each file will be opened at
most 3 times (for read, write, and read-write), and those opens will be
shared between all clients and openers. On upgrade we will do another
open if necessary instead of attempting to upgrade an existing open.
We keep count of the number of readers and writers so we know when to
close the shared files.
Signed-off-by: J. Bruce Fields <bfields@citi.umich.edu>
It is legal to perform a write using the lock stateid that was
originally associated with a read lock, or with a file that was
originally opened for read, but has since been upgraded.
So, when checking the openmode, check the mode associated with the
open stateid from which the lock was derived.
Move more work into helper functions.
The delegation code mostly pretends to support either read or write
delegations. However, correct support for write delegations would
require, for example, breaking of delegations (and/or implementation of
cb_getattr) on stat. Currently all that stops us from handing out
delegations is a subtle reference-counting issue.
Avoid confusion by adding an earlier check that explicitly refuses write
delegations.
For now, though, I'm not going so far as to rip out existing
half-support for write delegations, in case we get around to using that
soon.
fanotify, the upcoming notification system actually needs a struct path so it can
do opens in the context of listeners, and it needs a file so it can get f_flags
from the original process. Close was the only operation that already was passing
a struct file to the notification hook. This patch passes a file for access,
modify, and open as well as they are easily available to these hooks.
Signed-off-by: Eric Paris <eparis@redhat.com>
The readahead cache compensates for the fact that the NFS server
currently does an open and close on every IO operation in the NFSv2 and
NFSv3 case.
In the NFSv4 case we have long-lived struct files associated with client
opens, so there's no need for this. In fact, concurrent IO's using
trying to modify the same file->f_ra may cause problems.
So, don't bother with the readahead cache in that case.
Note eventually we'll likely do this in the v2/v3 case as well by
keeping a cache of struct files instead of struct file_ra_state's.
More idiomatic to put the error case in the if clause.
This is just cleanup--it's harmless to call nfsd_rachache_init,
nfsd_init_socks, and nfsd_reset_versions more than once. But there's no
point to it.
Right now, nfsd keeps a lockd reference for each socket that it has
open. This is unnecessary and complicates the error handling on
startup and shutdown. Change it to just do a lockd_up when starting
the first nfsd thread just do a single lockd_down when taking down the
last nfsd thread. Because of the strange way the sv_count is handled
this requires an extra flag to tell whether the nfsd_serv holds a
reference for lockd or not.
Signed-off-by: Jeff Layton <jlayton@redhat.com>
There doesn't seem to be any need to reset the nfssvc_boot time if the
nfsd startup failed.
__write_ports_addxprt calls nfsd_create_serv. That increases the
refcount of nfsd_serv (which is tracked in sv_nrthreads). The service
only decrements the thread count on error, not on success like
__write_ports_addfd does, so using this interface leaves the nfsd
thread count high.
Fix this by having this function call svc_destroy() on error to release
the reference (and possibly to tear down the service) and simply
decrement the refcount without tearing down the service on success.
This makes the sv_threads handling work basically the same in both
__write_ports_addxprt and __write_ports_addfd.
The refcounting for nfsd is a little goofy. What happens is that we
create the nfsd RPC service, attach sockets to it but don't actually
start the threads until someone writes to the "threads" procfile. To do
this, __write_ports_addfd will create the nfsd service and then will
decrement the refcount when exiting but won't actually destroy the
service.
This is fine when there aren't errors, but when there are this can
cause later attempts to start nfsd to fail. nfsd_serv will be set,
and that causes __write_versions to return EBUSY.
Fix this by calling svc_destroy on nfsd_serv when this function is
going to return error.
If someone tries to shut down the laundry_wq while it isn't up it'll
cause an oops.
This can happen because write_ports can create a nfsd_svc before we
really start the nfs server, and we may fail before the server is ever
started.
Also make sure state is shutdown on error paths in nfsd_svc().
Use a common global nfsd_up flag instead of nfs4_init, and create common
helper functions for nfsd start/shutdown, as there will be other work
that we want done only when we the number of nfsd threads transitions
between zero and nonzero.
Trivial cleanup, since "dest" is never used.
Reported-by: Anshul Madan <Anshul.Madan@netapp.com>
Some well-known NFSv3 clients drop their directory entry caches when
they receive replies with no WCC data. Without this data, they
employ extra READ, LOOKUP, and GETATTR requests to ensure their
directory entry caches are up to date, causing performance to suffer
needlessly.
In order to return WCC data, our server has to have both the pre-op
and the post-op attribute data on hand when a reply is XDR encoded.
The pre-op data is filled in when the incoming fh is locked, and the
post-op data is filled in when the fh is unlocked.
Unfortunately, for REMOVE, RMDIR, MKNOD, and MKDIR, the directory fh
is not unlocked until well after the reply has been XDR encoded. This
means that encode_wcc_data() does not have wcc_data for the parent
directory, so none is returned to the client after these operations
complete.
By unlocking the parent directory fh immediately after the internal
operations for each NFS procedure is complete, the post-op data is
filled in before XDR encoding starts, so it can be returned to the
client properly.
Signed-off-by: Chuck Lever <chuck.lever@oracle.com>
Reported-by: "Madan, Anshul" <Anshul.Madan@netapp.com>
When the rarely-used callback-connection-changing setclientid occurs
simultaneously with a delegation recall, we rerun the recall by
requeueing it on a workqueue. But we also need to take a reference on
the delegation in that case, since the delegation held by the rpc itself
will be released by the rpc_release callback.
This is overkill.
To be used also for the pnfs cb_layoutrecall callback
Signed-off-by: Benny Halevy <bhalevy@panasas.com>
[nfsd4: fix cb_recall encoding]
"nfsd: nfs4callback encode_stateid helper function" forgot to reserve
more space after return from the new helper.
Reported-by: Michael Groshans <groshans@citi.umich.edu>
If the server is out of memory is better for clients to back off and
retry than to just error out.
Note the session has to be put() here regardless of what happens to the
client.
* 'for-2.6.35' of git://linux-nfs.org/~bfields/linux:
nfsd4: shut down callback queue outside state lock
nfsd: nfsd_setattr needs to call commit_metadata
This reportedly causes a lockdep warning on nfsd shutdown. That looks
like a false positive to me, but there's no reason why this needs the
state lock anyway.
Reported-by: Jeff Layton <jlayton@redhat.com>
The conversion of write_inode_now calls to commit_metadata in commit
f501912a35c02eadc55ca9396ece55fe36f785d0 missed out the call in nfsd_setattr.
But without this conversion we can't guarantee that a SETATTR request
has actually been commited to disk with XFS, which causes a regression
from 2.6.32 (only for NFSv2, but anyway).
Cc: stable@kernel.org
