path: root/fs/nilfs2/gcinode.c
2012-06-20nilfs2: ensure proper cache clearing for gc-inodesRyusuke Konishi
A gc-inode is a pseudo inode used to buffer the blocks to be moved by garbage collection. Block caches of gc-inodes must be cleared every time a garbage collection function (nilfs_clean_segments) completes. Otherwise, stale blocks buffered in the caches may be wrongly reused in successive calls of the GC function. For user files, this is not a problem because their gc-inodes are distinguished by a checkpoint number as well as an inode number. They never buffer different blocks if either an inode number, a checkpoint number, or a block offset differs. However, gc-inodes of sufile, cpfile and DAT file can store different data for the same block offset. Thus, the nilfs_clean_segments function can move incorrect block for these meta-data files if an old block is cached. I found this is really causing meta-data corruption in nilfs. This fixes the issue by ensuring cache clear of gc-inodes and resolves reported GC problems including checkpoint file corruption, b-tree corruption, and the following warning during GC. nilfs_palloc_freev: entry number 307234 already freed. ... Signed-off-by: Ryusuke Konishi <konishi.ryusuke@lab.ntt.co.jp> Tested-by: Ryusuke Konishi <konishi.ryusuke@lab.ntt.co.jp> Cc: <stable@vger.kernel.org> [2.6.37+] Signed-off-by: Andrew Morton <akpm@linux-foundation.org> Signed-off-by: Linus Torvalds <torvalds@linux-foundation.org>
2011-05-10nilfs2: use mark_buffer_dirty to mark btnode or meta data dirtyRyusuke Konishi
This replaces nilfs_mdt_mark_buffer_dirty and nilfs_btnode_mark_dirty macros with mark_buffer_dirty and gets rid of nilfs_mark_buffer_dirty, an own mark buffer dirty function. Signed-off-by: Ryusuke Konishi <konishi.ryusuke@lab.ntt.co.jp>
2011-05-10nilfs2: get rid of NILFS_I_NILFSRyusuke Konishi
This replaces all references of NILFS_I_NILFS(inode)->ns_bdev with inode->i_sb->s_bdev and unfolds remaining uses of NILFS_I_NILFS inline function. Before 2.6.37, referring to a nilfs object from inodes needed a conditional judgement, and NILFS_I_NILFS was helpful to simplify it. But now we can simply do it by going through a super block instance like inode->i_sb->s_fs_info. Signed-off-by: Ryusuke Konishi <konishi.ryusuke@lab.ntt.co.jp>
2011-05-10nilfs2: use empty_aops for gc-inodesRyusuke Konishi
Applies empty_aops for address space operations of gc-inodes. Signed-off-by: Ryusuke Konishi <konishi.ryusuke@lab.ntt.co.jp>
2011-03-10block: remove per-queue pluggingJens Axboe
Code has been converted over to the new explicit on-stack plugging, and delay users have been converted to use the new API for that. So lets kill off the old plugging along with aops->sync_page(). Signed-off-by: Jens Axboe <jaxboe@fusionio.com>
2010-12-16nilfs2: fix regression of garbage collection ioctlRyusuke Konishi
On 2.6.37-rc1, garbage collection ioctl of nilfs was broken due to the commit 263d90cefc7d82a0 ("nilfs2: remove own inode hash used for GC"), and leading to filesystem corruption. The patch doesn't queue gc-inodes for log writer if they are reused through the vfs inode cache. Here, gc-inode is the inode which buffers blocks to be relocated on GC. That patch queues gc-inodes in nilfs_init_gcinode() function, but this function is not called when they don't have I_NEW flag. Thus, some of live blocks are wrongly overrode without being moved to new logs. This resolves the problem by moving the gc-inode queueing to an outer function to ensure it's done right. Signed-off-by: Ryusuke Konishi <konishi.ryusuke@lab.ntt.co.jp>
2010-10-23nilfs2: do not allocate nilfs_mdt_info structure to gc-inodesRyusuke Konishi
GC-inode now doesn't need the nilfs_mdt_info structure and there is no reason that it is a sort of metadata files. This stops the allocation and makes them not dependent on metadata file routines. Signed-off-by: Ryusuke Konishi <konishi.ryusuke@lab.ntt.co.jp>
2010-10-23nilfs2: remove own inode hash used for GCRyusuke Konishi
This uses inode hash function that vfs provides instead of the own hash table for caching gc inodes. This finally removes the own inode hash from nilfs. Signed-off-by: Ryusuke Konishi <konishi.ryusuke@lab.ntt.co.jp>
2010-10-23nilfs2: separate initializer of metadata file inodeRyusuke Konishi
This separates a part of initialization code of metadata file inode, and makes it available from the nilfs iget function that a later patch will add to. Signed-off-by: Ryusuke Konishi <konishi.ryusuke@lab.ntt.co.jp>
2010-07-23nilfs2: add read ahead mode to nilfs_btnode_submit_blockRyusuke Konishi
This adds mode argument to nilfs_btnode_submit_block() function and allows it to issue a read-ahead request. An optional submit_ptr argument is also added to store the actual block address for which bio is sent. submit_ptr is used for a series of read-ahead requests, and helps to decide if each requested block is continous to the previous one on disk. Signed-off-by: Ryusuke Konishi <konishi.ryusuke@lab.ntt.co.jp>
2010-07-23nilfs2: get rid of nilfs_bmap_unionRyusuke Konishi
This removes nilfs_bmap_union and finally unifies three structures and the union in bmap/btree code into one. Signed-off-by: Ryusuke Konishi <konishi.ryusuke@lab.ntt.co.jp>
2010-07-23nilfs2: verify btree node after readingRyusuke Konishi
This inserts sanity checks soon after read btree node from disk. This allows early detection of broken btree nodes, and helps to narrow down problems due to file system corruption. Signed-off-by: Ryusuke Konishi <konishi.ryusuke@lab.ntt.co.jp>
implicit slab.h inclusion from percpu.h percpu.h is included by sched.h and module.h and thus ends up being included when building most .c files. percpu.h includes slab.h which in turn includes gfp.h making everything defined by the two files universally available and complicating inclusion dependencies. percpu.h -> slab.h dependency is about to be removed. Prepare for this change by updating users of gfp and slab facilities include those headers directly instead of assuming availability. As this conversion needs to touch large number of source files, the following script is used as the basis of conversion. http://userweb.kernel.org/~tj/misc/slabh-sweep.py The script does the followings. * Scan files for gfp and slab usages and update includes such that only the necessary includes are there. ie. if only gfp is used, gfp.h, if slab is used, slab.h. * When the script inserts a new include, it looks at the include blocks and try to put the new include such that its order conforms to its surrounding. It's put in the include block which contains core kernel includes, in the same order that the rest are ordered - alphabetical, Christmas tree, rev-Xmas-tree or at the end if there doesn't seem to be any matching order. * If the script can't find a place to put a new include (mostly because the file doesn't have fitting include block), it prints out an error message indicating which .h file needs to be added to the file. The conversion was done in the following steps. 1. The initial automatic conversion of all .c files updated slightly over 4000 files, deleting around 700 includes and adding ~480 gfp.h and ~3000 slab.h inclusions. The script emitted errors for ~400 files. 2. Each error was manually checked. Some didn't need the inclusion, some needed manual addition while adding it to implementation .h or embedding .c file was more appropriate for others. This step added inclusions to around 150 files. 3. The script was run again and the output was compared to the edits from #2 to make sure no file was left behind. 4. Several build tests were done and a couple of problems were fixed. e.g. lib/decompress_*.c used malloc/free() wrappers around slab APIs requiring slab.h to be added manually. 5. The script was run on all .h files but without automatically editing them as sprinkling gfp.h and slab.h inclusions around .h files could easily lead to inclusion dependency hell. Most gfp.h inclusion directives were ignored as stuff from gfp.h was usually wildly available and often used in preprocessor macros. Each slab.h inclusion directive was examined and added manually as necessary. 6. percpu.h was updated not to include slab.h. 7. Build test were done on the following configurations and failures were fixed. CONFIG_GCOV_KERNEL was turned off for all tests (as my distributed build env didn't work with gcov compiles) and a few more options had to be turned off depending on archs to make things build (like ipr on powerpc/64 which failed due to missing writeq). * x86 and x86_64 UP and SMP allmodconfig and a custom test config. * powerpc and powerpc64 SMP allmodconfig * sparc and sparc64 SMP allmodconfig * ia64 SMP allmodconfig * s390 SMP allmodconfig * alpha SMP allmodconfig * um on x86_64 SMP allmodconfig 8. percpu.h modifications were reverted so that it could be applied as a separate patch and serve as bisection point. Given the fact that I had only a couple of failures from tests on step 6, I'm fairly confident about the coverage of this conversion patch. If there is a breakage, it's likely to be something in one of the arch headers which should be easily discoverable easily on most builds of the specific arch. Signed-off-by: Tejun Heo <tj@kernel.org> Guess-its-ok-by: Christoph Lameter <cl@linux-foundation.org> Cc: Ingo Molnar <mingo@redhat.com> Cc: Lee Schermerhorn <Lee.Schermerhorn@hp.com>
2010-03-14nilfs2: fix various typos in commentsRyusuke Konishi
This fixes various typos I found in comments of nilfs2. Signed-off-by: Ryusuke Konishi <konishi.ryusuke@lab.ntt.co.jp>
2009-11-20nilfs2: remove newblk argument from nilfs_btnode_submit_blockRyusuke Konishi
This removes the obsolete argument from nilfs_btnode_submit_block(). This will complete separating a create function of btree node. Signed-off-by: Ryusuke Konishi <konishi.ryusuke@lab.ntt.co.jp>
2009-11-20nilfs2: hide nilfs_mdt_clear calls in nilfs_mdt_destroyRyusuke Konishi
This will hide a function call of nilfs_mdt_clear() in nilfs_mdt_destroy(). This ensures nilfs_mdt_destroy() to do cleanup jobs included in nilfs_mdt_clear(). Signed-off-by: Ryusuke Konishi <konishi.ryusuke@lab.ntt.co.jp>
2009-11-20nilfs2: add size option of private object to metadata file allocatorRyusuke Konishi
This adds an optional "object size" argument to nilfs_mdt_new_common() function; the argument specifies the size of private object attached to a newly allocated metadata file inode. This will afford space to keep local variables for meta data files. Signed-off-by: Ryusuke Konishi <konishi.ryusuke@lab.ntt.co.jp>
2009-09-22const: mark remaining address_space_operations constAlexey Dobriyan
Signed-off-by: Alexey Dobriyan <adobriyan@gmail.com> Signed-off-by: Andrew Morton <akpm@linux-foundation.org> Signed-off-by: Linus Torvalds <torvalds@linux-foundation.org>
2009-06-10nilfs2: add sync_page method to page caches of meta dataRyusuke Konishi
This applies block_sync_page() function to the sync_page method of page caches for meta data files, gc page caches, and btree node buffers. This is a companion patch of ("nilfs2: enable sync_page mothod") which applied the function for data pages. This allows lock_page() for those meta data to unplug pending bio requests. Signed-off-by: Ryusuke Konishi <konishi.ryusuke@lab.ntt.co.jp>
2009-04-07nilfs2: support nanosecond timestampRyusuke Konishi
After a review of user's feedback for finding out other compatibility issues, I found nilfs improperly initializes timestamps in inode; CURRENT_TIME was used there instead of CURRENT_TIME_SEC even though nilfs didn't have nanosecond timestamps on disk. A few users gave us the report that the tar program sometimes failed to expand symbolic links on nilfs, and it turned out to be the cause. Instead of applying the above displacement, I've decided to support nanosecond timestamps on this occation. Fortunetaly, a needless 64-bit field was in the nilfs_inode struct, and I found it's available for this purpose without impact for the users. So, this will do the enhancement and resolve the tar problem. Signed-off-by: Ryusuke Konishi <konishi.ryusuke@lab.ntt.co.jp> Signed-off-by: Andrew Morton <akpm@linux-foundation.org> Signed-off-by: Linus Torvalds <torvalds@linux-foundation.org>
2009-04-07nilfs2: insert explanations in gcinode fileRyusuke Konishi
The file gcinode.c gives buffer cache functions for on-disk blocks moved in garbage collection. Joern Engel has suggested inserting its explanations in the source file (Message-ID: <20080917144146.GD8750@logfs.org> and <20080917224953.GB14644@logfs.org>). This follows the comment. Cc: Joern Engel <joern@logfs.org> Signed-off-by: Ryusuke Konishi <konishi.ryusuke@lab.ntt.co.jp> Signed-off-by: Andrew Morton <akpm@linux-foundation.org> Signed-off-by: Linus Torvalds <torvalds@linux-foundation.org>
2009-04-07nilfs2: block cache for garbage collectionRyusuke Konishi
This adds the cache of on-disk blocks to be moved in garbage collection. The disk blocks are held with dummy inodes (called gcinodes), and this file provides lookup function of the dummy inodes, and their buffer read function. Signed-off-by: Seiji Kihara <kihara.seiji@lab.ntt.co.jp> Signed-off-by: Ryusuke Konishi <konishi.ryusuke@lab.ntt.co.jp> Signed-off-by: Yoshiji Amagai <amagai.yoshiji@lab.ntt.co.jp> Signed-off-by: Andrew Morton <akpm@linux-foundation.org> Signed-off-by: Linus Torvalds <torvalds@linux-foundation.org>
