path: root/fs/nilfs2/segbuf.c
2017-08-23block: replace bi_bdev with a gendisk pointer and partitions indexChristoph Hellwig
This way we don't need a block_device structure to submit I/O. The block_device has different life time rules from the gendisk and request_queue and is usually only available when the block device node is open. Other callers need to explicitly create one (e.g. the lightnvm passthrough code, or the new nvme multipathing code). For the actual I/O path all that we need is the gendisk, which exists once per block device. But given that the block layer also does partition remapping we additionally need a partition index, which is used for said remapping in generic_make_request. Note that all the block drivers generally want request_queue or sometimes the gendisk, so this removes a layer of indirection all over the stack. Signed-off-by: Christoph Hellwig <hch@lst.de> Signed-off-by: Jens Axboe <axboe@kernel.dk>
2017-06-09block: switch bios to blk_status_tChristoph Hellwig
Replace bi_error with a new bi_status to allow for a clear conversion. Note that device mapper overloaded bi_error with a private value, which we'll have to keep arround at least for now and thus propagate to a proper blk_status_t value. Signed-off-by: Christoph Hellwig <hch@lst.de> Signed-off-by: Jens Axboe <axboe@fb.com>
2016-08-02nilfs2: reduce bare use of printk() with nilfs_msg()Ryusuke Konishi
Replace most use of printk() in nilfs2 implementation with nilfs_msg(), and reduce the following checkpatch.pl warning: "WARNING: Prefer [subsystem eg: netdev]_crit([subsystem]dev, ... then dev_crit(dev, ... then pr_crit(... to printk(KERN_CRIT ..." This patch also fixes a minor checkpatch warning "WARNING: quoted string split across lines" that often accompanies the prior warning, and amends message format as needed. Link: http://lkml.kernel.org/r/1464875891-5443-5-git-send-email-konishi.ryusuke@lab.ntt.co.jp Signed-off-by: Ryusuke Konishi <konishi.ryusuke@lab.ntt.co.jp> Signed-off-by: Andrew Morton <akpm@linux-foundation.org> Signed-off-by: Linus Torvalds <torvalds@linux-foundation.org>
2016-06-07nilfs: use bio op accessorsMike Christie
Separate the op from the rq_flag_bits and have nilfs set/get the bio using bio_set_op_attrs/bio_op. Signed-off-by: Mike Christie <mchristi@redhat.com> Reviewed-by: Christoph Hellwig <hch@lst.de> Reviewed-by: Hannes Reinecke <hare@suse.com> Acked-by: Ryusuke Konishi <konishi.ryusuke@lab.ntt.co.jp> Signed-off-by: Jens Axboe <axboe@fb.com>
2016-06-07block/fs/drivers: remove rw argument from submit_bioMike Christie
This has callers of submit_bio/submit_bio_wait set the bio->bi_rw instead of passing it in. This makes that use the same as generic_make_request and how we set the other bio fields. Signed-off-by: Mike Christie <mchristi@redhat.com> Fixed up fs/ext4/crypto.c Signed-off-by: Jens Axboe <axboe@fb.com>
2016-05-23nilfs2: avoid bare use of 'unsigned'Ryusuke Konishi
This fixes checkpatch.pl warning "WARNING: Prefer 'unsigned int' to bare use of 'unsigned'". Link: http://lkml.kernel.org/r/1462886671-3521-5-git-send-email-konishi.ryusuke@lab.ntt.co.jp Signed-off-by: Ryusuke Konishi <konishi.ryusuke@lab.ntt.co.jp> Signed-off-by: Andrew Morton <akpm@linux-foundation.org> Signed-off-by: Linus Torvalds <torvalds@linux-foundation.org>
2016-05-23nilfs2: clean up old e-mail addressesRyusuke Konishi
E-mail addresses of osrg.net domain are no longer available. This removes them from authorship notices and prevents reporters from being confused. Link: http://lkml.kernel.org/r/1461935747-10380-5-git-send-email-konishi.ryusuke@lab.ntt.co.jp Signed-off-by: Ryusuke Konishi <konishi.ryusuke@lab.ntt.co.jp> Signed-off-by: Andrew Morton <akpm@linux-foundation.org> Signed-off-by: Linus Torvalds <torvalds@linux-foundation.org>
2016-05-23nilfs2: remove FSF mailing address from GPL noticesRyusuke Konishi
This removes the extra paragraph which mentions FSF address in GPL notices from source code of nilfs2 and avoids the checkpatch.pl error related to it. Link: http://lkml.kernel.org/r/1461935747-10380-4-git-send-email-konishi.ryusuke@lab.ntt.co.jp Signed-off-by: Ryusuke Konishi <konishi.ryusuke@lab.ntt.co.jp> Signed-off-by: Andrew Morton <akpm@linux-foundation.org> Signed-off-by: Linus Torvalds <torvalds@linux-foundation.org>
2015-08-13block: remove bio_get_nr_vecs()Kent Overstreet
We can always fill up the bio now, no need to estimate the possible size based on queue parameters. Acked-by: Steven Whitehouse <swhiteho@redhat.com> Signed-off-by: Kent Overstreet <kent.overstreet@gmail.com> [hch: rebased and wrote a changelog] Signed-off-by: Christoph Hellwig <hch@lst.de> Signed-off-by: Ming Lin <ming.l@ssi.samsung.com> Signed-off-by: Jens Axboe <axboe@fb.com>
2015-07-29block: add a bi_error field to struct bioChristoph Hellwig
Currently we have two different ways to signal an I/O error on a BIO: (1) by clearing the BIO_UPTODATE flag (2) by returning a Linux errno value to the bi_end_io callback The first one has the drawback of only communicating a single possible error (-EIO), and the second one has the drawback of not beeing persistent when bios are queued up, and are not passed along from child to parent bio in the ever more popular chaining scenario. Having both mechanisms available has the additional drawback of utterly confusing driver authors and introducing bugs where various I/O submitters only deal with one of them, and the others have to add boilerplate code to deal with both kinds of error returns. So add a new bi_error field to store an errno value directly in struct bio and remove the existing mechanisms to clean all this up. Signed-off-by: Christoph Hellwig <hch@lst.de> Reviewed-by: Hannes Reinecke <hare@suse.de> Reviewed-by: NeilBrown <neilb@suse.com> Signed-off-by: Jens Axboe <axboe@fb.com>
2015-05-19block: remove BIO_EOPNOTSUPPChristoph Hellwig
Since the big barrier rewrite/removal in 2007 we never fail FLUSH or FUA requests, which means we can remove the magic BIO_EOPNOTSUPP flag to help propagating those to the buffer_head layer. Signed-off-by: Christoph Hellwig <hch@lst.de> Reviewed-by: Jeff Moyer <jmoyer@redhat.com> Acked-by: Tejun Heo <tj@kernel.org> Signed-off-by: Jens Axboe <axboe@fb.com>
2013-11-23block: Abstract out bvec iteratorKent Overstreet
Immutable biovecs are going to require an explicit iterator. To implement immutable bvecs, a later patch is going to add a bi_bvec_done member to this struct; for now, this patch effectively just renames things. Signed-off-by: Kent Overstreet <kmo@daterainc.com> Cc: Jens Axboe <axboe@kernel.dk> Cc: Geert Uytterhoeven <geert@linux-m68k.org> Cc: Benjamin Herrenschmidt <benh@kernel.crashing.org> Cc: Paul Mackerras <paulus@samba.org> Cc: "Ed L. Cashin" <ecashin@coraid.com> Cc: Nick Piggin <npiggin@kernel.dk> Cc: Lars Ellenberg <drbd-dev@lists.linbit.com> Cc: Jiri Kosina <jkosina@suse.cz> Cc: Matthew Wilcox <willy@linux.intel.com> Cc: Geoff Levand <geoff@infradead.org> Cc: Yehuda Sadeh <yehuda@inktank.com> Cc: Sage Weil <sage@inktank.com> Cc: Alex Elder <elder@inktank.com> Cc: ceph-devel@vger.kernel.org Cc: Joshua Morris <josh.h.morris@us.ibm.com> Cc: Philip Kelleher <pjk1939@linux.vnet.ibm.com> Cc: Rusty Russell <rusty@rustcorp.com.au> Cc: "Michael S. Tsirkin" <mst@redhat.com> Cc: Konrad Rzeszutek Wilk <konrad.wilk@oracle.com> Cc: Jeremy Fitzhardinge <jeremy@goop.org> Cc: Neil Brown <neilb@suse.de> Cc: Alasdair Kergon <agk@redhat.com> Cc: Mike Snitzer <snitzer@redhat.com> Cc: dm-devel@redhat.com Cc: Martin Schwidefsky <schwidefsky@de.ibm.com> Cc: Heiko Carstens <heiko.carstens@de.ibm.com> Cc: linux390@de.ibm.com Cc: Boaz Harrosh <bharrosh@panasas.com> Cc: Benny Halevy <bhalevy@tonian.com> Cc: "James E.J. Bottomley" <JBottomley@parallels.com> Cc: Greg Kroah-Hartman <gregkh@linuxfoundation.org> Cc: "Nicholas A. Bellinger" <nab@linux-iscsi.org> Cc: Alexander Viro <viro@zeniv.linux.org.uk> Cc: Chris Mason <chris.mason@fusionio.com> Cc: "Theodore Ts'o" <tytso@mit.edu> Cc: Andreas Dilger <adilger.kernel@dilger.ca> Cc: Jaegeuk Kim <jaegeuk.kim@samsung.com> Cc: Steven Whitehouse <swhiteho@redhat.com> Cc: Dave Kleikamp <shaggy@kernel.org> Cc: Joern Engel <joern@logfs.org> Cc: Prasad Joshi <prasadjoshi.linux@gmail.com> Cc: Trond Myklebust <Trond.Myklebust@netapp.com> Cc: KONISHI Ryusuke <konishi.ryusuke@lab.ntt.co.jp> Cc: Mark Fasheh <mfasheh@suse.com> Cc: Joel Becker <jlbec@evilplan.org> Cc: Ben Myers <bpm@sgi.com> Cc: xfs@oss.sgi.com Cc: Steven Rostedt <rostedt@goodmis.org> Cc: Frederic Weisbecker <fweisbec@gmail.com> Cc: Ingo Molnar <mingo@redhat.com> Cc: Len Brown <len.brown@intel.com> Cc: Pavel Machek <pavel@ucw.cz> Cc: "Rafael J. Wysocki" <rjw@sisk.pl> Cc: Herton Ronaldo Krzesinski <herton.krzesinski@canonical.com> Cc: Ben Hutchings <ben@decadent.org.uk> Cc: Andrew Morton <akpm@linux-foundation.org> Cc: Guo Chao <yan@linux.vnet.ibm.com> Cc: Tejun Heo <tj@kernel.org> Cc: Asai Thambi S P <asamymuthupa@micron.com> Cc: Selvan Mani <smani@micron.com> Cc: Sam Bradshaw <sbradshaw@micron.com> Cc: Wei Yongjun <yongjun_wei@trendmicro.com.cn> Cc: "Roger Pau Monné" <roger.pau@citrix.com> Cc: Jan Beulich <jbeulich@suse.com> Cc: Stefano Stabellini <stefano.stabellini@eu.citrix.com> Cc: Ian Campbell <Ian.Campbell@citrix.com> Cc: Sebastian Ott <sebott@linux.vnet.ibm.com> Cc: Christian Borntraeger <borntraeger@de.ibm.com> Cc: Minchan Kim <minchan@kernel.org> Cc: Jiang Liu <jiang.liu@huawei.com> Cc: Nitin Gupta <ngupta@vflare.org> Cc: Jerome Marchand <jmarchand@redhat.com> Cc: Joe Perches <joe@perches.com> Cc: Peng Tao <tao.peng@emc.com> Cc: Andy Adamson <andros@netapp.com> Cc: fanchaoting <fanchaoting@cn.fujitsu.com> Cc: Jie Liu <jeff.liu@oracle.com> Cc: Sunil Mushran <sunil.mushran@gmail.com> Cc: "Martin K. Petersen" <martin.petersen@oracle.com> Cc: Namjae Jeon <namjae.jeon@samsung.com> Cc: Pankaj Kumar <pankaj.km@samsung.com> Cc: Dan Magenheimer <dan.magenheimer@oracle.com> Cc: Mel Gorman <mgorman@suse.de>6
2013-08-23nilfs2: fix issue with counting number of bio requests for BIO_EOPNOTSUPP ↵Vyacheslav Dubeyko
error detection Fix the issue with improper counting number of flying bio requests for BIO_EOPNOTSUPP error detection case. The sb_nbio must be incremented exactly the same number of times as complete() function was called (or will be called) because nilfs_segbuf_wait() will call wail_for_completion() for the number of times set to sb_nbio: do { wait_for_completion(&segbuf->sb_bio_event); } while (--segbuf->sb_nbio > 0); Two functions complete() and wait_for_completion() must be called the same number of times for the same sb_bio_event. Otherwise, wait_for_completion() will hang or leak. Signed-off-by: Vyacheslav Dubeyko <slava@dubeyko.com> Cc: Dan Carpenter <dan.carpenter@oracle.com> Acked-by: Ryusuke Konishi <konishi.ryusuke@lab.ntt.co.jp> Tested-by: Ryusuke Konishi <konishi.ryusuke@lab.ntt.co.jp> Cc: <stable@vger.kernel.org> Signed-off-by: Andrew Morton <akpm@linux-foundation.org> Signed-off-by: Linus Torvalds <torvalds@linux-foundation.org>
2013-08-23nilfs2: remove double bio_put() in nilfs_end_bio_write() for BIO_EOPNOTSUPP ↵Vyacheslav Dubeyko
error Remove double call of bio_put() in nilfs_end_bio_write() for the case of BIO_EOPNOTSUPP error detection. The issue was found by Dan Carpenter and he suggests first version of the fix too. Signed-off-by: Vyacheslav Dubeyko <slava@dubeyko.com> Reported-by: Dan Carpenter <dan.carpenter@oracle.com> Acked-by: Ryusuke Konishi <konishi.ryusuke@lab.ntt.co.jp> Tested-by: Ryusuke Konishi <konishi.ryusuke@lab.ntt.co.jp> Cc: <stable@vger.kernel.org> Signed-off-by: Andrew Morton <akpm@linux-foundation.org> Signed-off-by: Linus Torvalds <torvalds@linux-foundation.org>
2012-03-20nilfs2: remove the second argument of k[un]map_atomic()Cong Wang
Acked-by: Ryusuke Konishi <konishi.ryusuke@lab.ntt.co.jp> Signed-off-by: Cong Wang <amwang@redhat.com>
2011-05-10nilfs2: super root size should change depending on inode sizeRyusuke Konishi
The size of super root structure depends on inode size, so NILFS_SR_BYTES macro should be a function of the inode size. This fixes the issue. Even though a different size value will be written for a possible future filesystem with extended inode, but fortunately this does not break disk format compatibility. Signed-off-by: Ryusuke Konishi <konishi.ryusuke@lab.ntt.co.jp>
2011-05-10nilfs2: get rid of private page allocatorRyusuke Konishi
Previously, nilfs was cloning pages for mmapped region to freeze their data and ensure consistency of checksum during writeback cycles. A private page allocator was used for this page cloning. But, we no longer need to do that since clear_page_dirty_for_io function sets up pte so that vm_ops->page_mkwrite function is called right before the mmapped pages are modified and nilfs_page_mkwrite function can safely wait for the pages to be written back to disk. So, this stops making a copy of mmapped pages during writeback, and eliminates the private page allocation and deallocation functions from nilfs. Signed-off-by: Ryusuke Konishi <konishi.ryusuke@lab.ntt.co.jp>
2011-03-10block: kill off REQ_UNPLUGJens Axboe
With the plugging now being explicitly controlled by the submitter, callers need not pass down unplugging hints to the block layer. If they want to unplug, it's because they manually plugged on their own - in which case, they should just unplug at will. Signed-off-by: Jens Axboe <jaxboe@fusionio.com>
2010-10-23nilfs2: get rid of bdi from nilfs objectRyusuke Konishi
Nilfs now can use sb->s_bdi to get backing_dev_info, so we use it instead of ns_bdi on the nilfs object and remove ns_bdi. Signed-off-by: Ryusuke Konishi <konishi.ryusuke@lab.ntt.co.jp>
2010-08-07block: unify flags for struct bio and struct requestChristoph Hellwig
Remove the current bio flags and reuse the request flags for the bio, too. This allows to more easily trace the type of I/O from the filesystem down to the block driver. There were two flags in the bio that were missing in the requests: BIO_RW_UNPLUG and BIO_RW_AHEAD. Also I've renamed two request flags that had a superflous RW in them. Note that the flags are in bio.h despite having the REQ_ name - as blkdev.h includes bio.h that is the only way to go for now. Signed-off-by: Christoph Hellwig <hch@lst.de> Signed-off-by: Jens Axboe <jaxboe@fusionio.com>
2010-05-10nilfs2: insert checkpoint number in segment summary headerRyusuke Konishi
This adds a field to record the latest checkpoint number in the nilfs_segment_summary structure. This will help to recover the latest checkpoint number from logs on disk. This field is intended for crucial cases in which super blocks have lost pointer to the latest log. Even though this will change the disk format, both backward and forward compatibility is preserved by a size field prepared in the segment summary header. Signed-off-by: Ryusuke Konishi <konishi.ryusuke@lab.ntt.co.jp>
2010-05-10nilfs2: cleanup multi kmem_cache_{create,destroy} codeLi Hong
This cleanup patch gives several improvements: - Moving all kmem_cache_{create_destroy} calls into one place, which removes some small function calls, cleans up error check code and clarify the logic. - Mark all initial code in __init section. - Remove some very obvious comments. - Adjust some declarations. - Fix some space-tab issues. Signed-off-by: Li Hong <lihong.hi@gmail.com> Signed-off-by: Ryusuke Konishi <konishi.ryusuke@lab.ntt.co.jp>
2010-05-10nilfs2: move out checksum routines to segment buffer codeRyusuke Konishi
This moves out checksum routines in log writer to segbuf.c for cleanup. Signed-off-by: Ryusuke Konishi <konishi.ryusuke@lab.ntt.co.jp>
2010-05-10nilfs2: move pointer to super root block into logsRyusuke Konishi
This moves a pointer to buffer storing super root block to each log buffer from nilfs_sc_info struct for simplicity. Signed-off-by: Ryusuke Konishi <konishi.ryusuke@lab.ntt.co.jp>
implicit slab.h inclusion from percpu.h percpu.h is included by sched.h and module.h and thus ends up being included when building most .c files. percpu.h includes slab.h which in turn includes gfp.h making everything defined by the two files universally available and complicating inclusion dependencies. percpu.h -> slab.h dependency is about to be removed. Prepare for this change by updating users of gfp and slab facilities include those headers directly instead of assuming availability. As this conversion needs to touch large number of source files, the following script is used as the basis of conversion. http://userweb.kernel.org/~tj/misc/slabh-sweep.py The script does the followings. * Scan files for gfp and slab usages and update includes such that only the necessary includes are there. ie. if only gfp is used, gfp.h, if slab is used, slab.h. * When the script inserts a new include, it looks at the include blocks and try to put the new include such that its order conforms to its surrounding. It's put in the include block which contains core kernel includes, in the same order that the rest are ordered - alphabetical, Christmas tree, rev-Xmas-tree or at the end if there doesn't seem to be any matching order. * If the script can't find a place to put a new include (mostly because the file doesn't have fitting include block), it prints out an error message indicating which .h file needs to be added to the file. The conversion was done in the following steps. 1. The initial automatic conversion of all .c files updated slightly over 4000 files, deleting around 700 includes and adding ~480 gfp.h and ~3000 slab.h inclusions. The script emitted errors for ~400 files. 2. Each error was manually checked. Some didn't need the inclusion, some needed manual addition while adding it to implementation .h or embedding .c file was more appropriate for others. This step added inclusions to around 150 files. 3. The script was run again and the output was compared to the edits from #2 to make sure no file was left behind. 4. Several build tests were done and a couple of problems were fixed. e.g. lib/decompress_*.c used malloc/free() wrappers around slab APIs requiring slab.h to be added manually. 5. The script was run on all .h files but without automatically editing them as sprinkling gfp.h and slab.h inclusions around .h files could easily lead to inclusion dependency hell. Most gfp.h inclusion directives were ignored as stuff from gfp.h was usually wildly available and often used in preprocessor macros. Each slab.h inclusion directive was examined and added manually as necessary. 6. percpu.h was updated not to include slab.h. 7. Build test were done on the following configurations and failures were fixed. CONFIG_GCOV_KERNEL was turned off for all tests (as my distributed build env didn't work with gcov compiles) and a few more options had to be turned off depending on archs to make things build (like ipr on powerpc/64 which failed due to missing writeq). * x86 and x86_64 UP and SMP allmodconfig and a custom test config. * powerpc and powerpc64 SMP allmodconfig * sparc and sparc64 SMP allmodconfig * ia64 SMP allmodconfig * s390 SMP allmodconfig * alpha SMP allmodconfig * um on x86_64 SMP allmodconfig 8. percpu.h modifications were reverted so that it could be applied as a separate patch and serve as bisection point. Given the fact that I had only a couple of failures from tests on step 6, I'm fairly confident about the coverage of this conversion patch. If there is a breakage, it's likely to be something in one of the arch headers which should be easily discoverable easily on most builds of the specific arch. Signed-off-by: Tejun Heo <tj@kernel.org> Guess-its-ok-by: Christoph Lameter <cl@linux-foundation.org> Cc: Ingo Molnar <mingo@redhat.com> Cc: Lee Schermerhorn <Lee.Schermerhorn@hp.com>
2010-03-24nilfs2: fix imperfect completion wait in nilfs_wait_on_logsRyusuke Konishi
nilfs_wait_on_logs has a potential to slip out before completion of all bio requests when it met an error. This synchronization fault may cause unexpected results, for instance, violative access to freed segment buffers from an end-bio callback routine. This fixes the issue by ensuring that nilfs_wait_on_logs waits all given logs. Signed-off-by: Ryusuke Konishi <konishi.ryusuke@lab.ntt.co.jp>
2010-03-14nilfs2: remove spaces before tabsRyusuke Konishi
This kills the following checkpatch warnings: WARNING: please, no space before tabs #74: FILE: segment.h:74: +^Iunsigned ^I^Iflags;$ WARNING: please, no space before tabs #35: FILE: segbuf.c:35: +^Iint ^I^I^Istart, end; /* The region to be submitted */$ Signed-off-by: Ryusuke Konishi <konishi.ryusuke@lab.ntt.co.jp>
2010-03-14nilfs2: fix various typos in commentsRyusuke Konishi
This fixes various typos I found in comments of nilfs2. Signed-off-by: Ryusuke Konishi <konishi.ryusuke@lab.ntt.co.jp>
2010-03-14nilfs2: fix discrepancy in use of static specifierRyusuke Konishi
Two segbuf functions, nilfs_segbuf_write and nilfs_segbuf_wait, are declared with the static storage class specifier, but their implementations are not. This fixes the discrepancy. Signed-off-by: Ryusuke Konishi <konishi.ryusuke@lab.ntt.co.jp>
2010-02-13nilfs2: move iterator to write log into segment bufferRyusuke Konishi
This moves iterator to submit write requests for a series of logs into segbuf.c, and hides nilfs_segbuf_write() and nilfs_segbuf_wait() in the file. Signed-off-by: Ryusuke Konishi <konishi.ryusuke@lab.ntt.co.jp>
2009-11-30nilfs2: separate wait function from nilfs_segctor_writeRyusuke Konishi
This separates wait function for submitted logs from the write function nilfs_segctor_write(). A new list of segment buffers "sc_write_logs" is added to hold logs under writing, and double buffering is partially applied to hide io latency. At this point, the double buffering is disabled for blocksize < pagesize because page dirty flag is turned off during write and dirty buffers are not properly collected for pages crossing over segments. To receive full benefit of the double buffering, further refinement is needed to move the io wait outside the lock section of log writer. Signed-off-by: Ryusuke Konishi <konishi.ryusuke@lab.ntt.co.jp>
2009-11-30nilfs2: add iterator for segment buffersRyusuke Konishi
This adds a few iterator functions for segment buffers to make it easy to handle multiple series of logs. Signed-off-by: Ryusuke Konishi <konishi.ryusuke@lab.ntt.co.jp>
2009-11-30nilfs2: hide nilfs_write_info struct in segment buffer codeRyusuke Konishi
Hides nilfs_write_info struct and nilfs_segbuf_prepare_write function in segbuf.c to simplify the interface of nilfs_segbuf_write function. Signed-off-by: Ryusuke Konishi <konishi.ryusuke@lab.ntt.co.jp>
2009-11-30nilfs2: relocate io status variables to segment bufferRyusuke Konishi
This moves io status variables in nilfs_write_info struct to nilfs_segment_buffer struct. This is a preparation to hide nilfs_write_info in segment buffer code. Signed-off-by: Ryusuke Konishi <konishi.ryusuke@lab.ntt.co.jp>
2009-11-29nilfs2: do not return io error for bio allocation failureRyusuke Konishi
Previously, log writer had possibility to set an io error flag on segments even in case of memory allocation failure. This fixes the issue. Signed-off-by: Ryusuke Konishi <konishi.ryusuke@lab.ntt.co.jp>
2009-09-14nilfs2: use GFP_NOIO for bio_alloc instead of GFP_NOWAITRyusuke Konishi
Alberto Bertogli advised me about bio_alloc() use in nilfs: On Sat, 13 Jun 2009 22:52:40 -0300, Alberto Bertogli wrote: > By the way, those bio_alloc()s are using GFP_NOWAIT but it looks > like they could use at least GFP_NOIO or GFP_NOFS, since the caller > can (and sometimes do) sleep. The only caller is nilfs_submit_bh(), > which calls nilfs_submit_seg_bio() which can sleep calling > wait_for_completion(). This takes in the comment and replaces the use of GFP_NOWAIT flag with GFP_NOIO. Signed-off-by: Ryusuke Konishi <konishi.ryusuke@lab.ntt.co.jp>
2009-06-10nilfs2: set bio unplug flag for the last bio in segmentRyusuke Konishi
This sets BIO_RW_UNPLUG flag on the last bio of each segment during write. The last bio should be unplugged immediately because the caller waits for the completion after the submission. Signed-off-by: Ryusuke Konishi <konishi.ryusuke@lab.ntt.co.jp>
2009-06-10nilfs2: eliminate removal list of segmentsRyusuke Konishi
This will clean up the removal list of segments and the related functions from segment.c and ioctl.c, which have hurt code readability. This elimination is applied by using nilfs_sufile_updatev() previously introduced in the patch ("nilfs2: add sufile function that can modify multiple segment usages"). Signed-off-by: Ryusuke Konishi <konishi.ryusuke@lab.ntt.co.jp>
2009-04-07nilfs2: simplify handling of active state of segmentsRyusuke Konishi
will reduce some lines of segment constructor. Previously, the state was complexly controlled through a list of segments in order to keep consistency in meta data of usage state of segments. Instead, this presents ``calculated'' active flags to userland cleaner program and stop maintaining its real flag on disk. Only by this fake flag, the cleaner cannot exactly know if each segment is reclaimable or not. However, the recent extension of nilfs_sustat ioctl struct (nilfs2-extend-nilfs_sustat-ioctl-struct.patch) can prevent the cleaner from reclaiming in-use segment wrongly. So, now I can apply this for simplification. Signed-off-by: Ryusuke Konishi <konishi.ryusuke@lab.ntt.co.jp> Signed-off-by: Andrew Morton <akpm@linux-foundation.org> Signed-off-by: Linus Torvalds <torvalds@linux-foundation.org>
2009-04-07nilfs2: segment bufferRyusuke Konishi
This adds the segment buffer which is used to constuct logs. [akpm@linux-foundation.org: BIO_RW_SYNC got removed] Signed-off-by: Ryusuke Konishi <konishi.ryusuke@lab.ntt.co.jp> Signed-off-by: Andrew Morton <akpm@linux-foundation.org> Signed-off-by: Linus Torvalds <torvalds@linux-foundation.org>
