path: root/fs/nilfs2
2013-09-12truncate: drop 'oldsize' truncate_pagecache() parameterKirill A. Shutemov
truncate_pagecache() doesn't care about old size since commit cedabed49b39 ("vfs: Fix vmtruncate() regression"). Let's drop it. Signed-off-by: Kirill A. Shutemov <kirill.shutemov@linux.intel.com> Cc: OGAWA Hirofumi <hirofumi@mail.parknet.co.jp> Signed-off-by: Andrew Morton <akpm@linux-foundation.org> Signed-off-by: Linus Torvalds <torvalds@linux-foundation.org>
2013-09-05Merge branch 'for-linus' of ↵Linus Torvalds
git://git.kernel.org/pub/scm/linux/kernel/git/viro/vfs Pull vfs pile 1 from Al Viro: "Unfortunately, this merge window it'll have a be a lot of small piles - my fault, actually, for not keeping #for-next in anything that would resemble a sane shape ;-/ This pile: assorted fixes (the first 3 are -stable fodder, IMO) and cleanups + %pd/%pD formats (dentry/file pathname, up to 4 last components) + several long-standing patches from various folks. There definitely will be a lot more (starting with Miklos' check_submount_and_drop() series)" * 'for-linus' of git://git.kernel.org/pub/scm/linux/kernel/git/viro/vfs: (26 commits) direct-io: Handle O_(D)SYNC AIO direct-io: Implement generic deferred AIO completions add formats for dentry/file pathnames kvm eventfd: switch to fdget powerpc kvm: use fdget switch fchmod() to fdget switch epoll_ctl() to fdget switch copy_module_from_fd() to fdget git simplify nilfs check for busy subtree ibmasmfs: don't bother passing superblock when not needed don't pass superblock to hypfs_{mkdir,create*} don't pass superblock to hypfs_diag_create_files don't pass superblock to hypfs_vm_create_files() oprofile: get rid of pointless forward declarations of struct super_block oprofilefs_create_...() do not need superblock argument oprofilefs_mkdir() doesn't need superblock argument don't bother with passing superblock to oprofile_create_stats_files() oprofile: don't bother with passing superblock to ->create_files() don't bother passing sb to oprofile_create_files() coh901318: don't open-code simple_read_from_buffer() ...
2013-09-03git simplify nilfs check for busy subtreeAl Viro
Reviewed-by: Ryusuke Konishi <konishi.ryusuke@lab.ntt.co.jp> Signed-off-by: Al Viro <viro@zeniv.linux.org.uk>
2013-08-23nilfs2: fix issue with counting number of bio requests for BIO_EOPNOTSUPP ↵Vyacheslav Dubeyko
error detection Fix the issue with improper counting number of flying bio requests for BIO_EOPNOTSUPP error detection case. The sb_nbio must be incremented exactly the same number of times as complete() function was called (or will be called) because nilfs_segbuf_wait() will call wail_for_completion() for the number of times set to sb_nbio: do { wait_for_completion(&segbuf->sb_bio_event); } while (--segbuf->sb_nbio > 0); Two functions complete() and wait_for_completion() must be called the same number of times for the same sb_bio_event. Otherwise, wait_for_completion() will hang or leak. Signed-off-by: Vyacheslav Dubeyko <slava@dubeyko.com> Cc: Dan Carpenter <dan.carpenter@oracle.com> Acked-by: Ryusuke Konishi <konishi.ryusuke@lab.ntt.co.jp> Tested-by: Ryusuke Konishi <konishi.ryusuke@lab.ntt.co.jp> Cc: <stable@vger.kernel.org> Signed-off-by: Andrew Morton <akpm@linux-foundation.org> Signed-off-by: Linus Torvalds <torvalds@linux-foundation.org>
2013-08-23nilfs2: remove double bio_put() in nilfs_end_bio_write() for BIO_EOPNOTSUPP ↵Vyacheslav Dubeyko
error Remove double call of bio_put() in nilfs_end_bio_write() for the case of BIO_EOPNOTSUPP error detection. The issue was found by Dan Carpenter and he suggests first version of the fix too. Signed-off-by: Vyacheslav Dubeyko <slava@dubeyko.com> Reported-by: Dan Carpenter <dan.carpenter@oracle.com> Acked-by: Ryusuke Konishi <konishi.ryusuke@lab.ntt.co.jp> Tested-by: Ryusuke Konishi <konishi.ryusuke@lab.ntt.co.jp> Cc: <stable@vger.kernel.org> Signed-off-by: Andrew Morton <akpm@linux-foundation.org> Signed-off-by: Linus Torvalds <torvalds@linux-foundation.org>
2013-07-05helper for reading ->d_countAl Viro
2013-07-03] nilfs2: use atomic64_t type for inodes_count and blocks_count fields in ↵Vyacheslav Dubeyko
nilfs_root struct The cp_inodes_count and cp_blocks_count are represented as __le64 type in on-disk structure (struct nilfs_checkpoint). But analogous fields in in-core structure (struct nilfs_root) are represented by atomic_t type. This patch replaces atomic_t on atomic64_t type in representation of inodes_count and blocks_count fields in struct nilfs_root. Signed-off-by: Vyacheslav Dubeyko <slava@dubeyko.com> Acked-by: Ryusuke Konishi <konishi.ryusuke@lab.ntt.co.jp> Acked-by: Joern Engel <joern@logfs.org> Cc: Clemens Eisserer <linuxhippy@gmail.com> Signed-off-by: Andrew Morton <akpm@linux-foundation.org> Signed-off-by: Linus Torvalds <torvalds@linux-foundation.org>
2013-07-03nilfs2: implement calculation of free inodes countVyacheslav Dubeyko
Currently, NILFS2 returns 0 as free inodes count (f_ffree) and current used inodes count as total file nodes in file system (f_files): df -i Filesystem Inodes IUsed IFree IUse% Mounted on /dev/loop0 2 2 0 100% /mnt/nilfs2 This patch implements real calculation of free inodes count. First of all, it is calculated total file nodes in file system as (desc_blocks_count * groups_per_desc_block * entries_per_group). Then, it is calculated free inodes count as difference the total file nodes and used inodes count. As a result, we have such output for NILFS2: df -i Filesystem Inodes IUsed IFree IUse% Mounted on /dev/loop0 4194304 2114701 2079603 51% /mnt/nilfs2 Reported-by: Clemens Eisserer <linuxhippy@gmail.com> Signed-off-by: Vyacheslav Dubeyko <slava@dubeyko.com> Signed-off-by: Ryusuke Konishi <konishi.ryusuke@lab.ntt.co.jp> Tested-by: Vyacheslav Dubeyko <slava@dubeyko.com> Cc: Joern Engel <joern@logfs.org> Signed-off-by: Andrew Morton <akpm@linux-foundation.org> Signed-off-by: Linus Torvalds <torvalds@linux-foundation.org>
2013-06-29[readdir] convert nilfs2Al Viro
2013-05-24nilfs2: fix issue of nilfs_set_page_dirty() for page at EOF boundaryRyusuke Konishi
nilfs2: fix issue of nilfs_set_page_dirty for page at EOF boundary DESCRIPTION: There are use-cases when NILFS2 file system (formatted with block size lesser than 4 KB) can be remounted in RO mode because of encountering of "broken bmap" issue. The issue was reported by Anthony Doggett <Anthony2486@interfaces.org.uk>: "The machine I've been trialling nilfs on is running Debian Testing, Linux version 3.2.0-4-686-pae (debian-kernel@lists.debian.org) (gcc version 4.6.3 (Debian 4.6.3-14) ) #1 SMP Debian 3.2.35-2), but I've also reproduced it (identically) with Debian Unstable amd64 and Debian Experimental (using the 3.8-trunk kernel). The problematic partitions were formatted with "mkfs.nilfs2 -b 1024 -B 8192"." SYMPTOMS: (1) System log contains error messages likewise: [63102.496756] nilfs_direct_assign: invalid pointer: 0 [63102.496786] NILFS error (device dm-17): nilfs_bmap_assign: broken bmap (inode number=28) [63102.496798] [63102.524403] Remounting filesystem read-only (2) The NILFS2 file system is remounted in RO mode. REPRODUSING PATH: (1) Create volume group with name "unencrypted" by means of vgcreate utility. (2) Run script (prepared by Anthony Doggett <Anthony2486@interfaces.org.uk>): ----------------[BEGIN SCRIPT]-------------------- VG=unencrypted lvcreate --size 2G --name ntest $VG mkfs.nilfs2 -b 1024 -B 8192 /dev/mapper/$VG-ntest mkdir /var/tmp/n mkdir /var/tmp/n/ntest mount /dev/mapper/$VG-ntest /var/tmp/n/ntest mkdir /var/tmp/n/ntest/thedir cd /var/tmp/n/ntest/thedir sleep 2 date darcs init sleep 2 dmesg|tail -n 5 date darcs whatsnew || true date sleep 2 dmesg|tail -n 5 ----------------[END SCRIPT]-------------------- REPRODUCIBILITY: 100% INVESTIGATION: As it was discovered, the issue takes place during segment construction after executing such sequence of user-space operations: open("_darcs/index", O_RDWR|O_CREAT|O_NOCTTY, 0666) = 7 fstat(7, {st_mode=S_IFREG|0644, st_size=0, ...}) = 0 ftruncate(7, 60) The error message "NILFS error (device dm-17): nilfs_bmap_assign: broken bmap (inode number=28)" takes place because of trying to get block number for third block of the file with logical offset #3072 bytes. As it is possible to see from above output, the file has 60 bytes of the whole size. So, it is enough one block (1 KB in size) allocation for the whole file. Trying to operate with several blocks instead of one takes place because of discovering several dirty buffers for this file in nilfs_segctor_scan_file() method. The root cause of this issue is in nilfs_set_page_dirty function which is called just before writing to an mmapped page. When nilfs_page_mkwrite function handles a page at EOF boundary, it fills hole blocks only inside EOF through __block_page_mkwrite(). The __block_page_mkwrite() function calls set_page_dirty() after filling hole blocks, thus nilfs_set_page_dirty function (= a_ops->set_page_dirty) is called. However, the current implementation of nilfs_set_page_dirty() wrongly marks all buffers dirty even for page at EOF boundary. As a result, buffers outside EOF are inconsistently marked dirty and queued for write even though they are not mapped with nilfs_get_block function. FIX: This modifies nilfs_set_page_dirty() not to mark hole blocks dirty. Thanks to Vyacheslav Dubeyko for his effort on analysis and proposals for this issue. Signed-off-by: Ryusuke Konishi <konishi.ryusuke@lab.ntt.co.jp> Reported-by: Anthony Doggett <Anthony2486@interfaces.org.uk> Reported-by: Vyacheslav Dubeyko <slava@dubeyko.com> Cc: Vyacheslav Dubeyko <slava@dubeyko.com> Tested-by: Ryusuke Konishi <konishi.ryusuke@lab.ntt.co.jp> Cc: <stable@vger.kernel.org> Signed-off-by: Andrew Morton <akpm@linux-foundation.org> Signed-off-by: Linus Torvalds <torvalds@linux-foundation.org>
2013-05-07aio: don't include aio.h in sched.hKent Overstreet
Faster kernel compiles by way of fewer unnecessary includes. [akpm@linux-foundation.org: fix fallout] [akpm@linux-foundation.org: fix build] Signed-off-by: Kent Overstreet <koverstreet@google.com> Cc: Zach Brown <zab@redhat.com> Cc: Felipe Balbi <balbi@ti.com> Cc: Greg Kroah-Hartman <gregkh@linuxfoundation.org> Cc: Mark Fasheh <mfasheh@suse.com> Cc: Joel Becker <jlbec@evilplan.org> Cc: Rusty Russell <rusty@rustcorp.com.au> Cc: Jens Axboe <axboe@kernel.dk> Cc: Asai Thambi S P <asamymuthupa@micron.com> Cc: Selvan Mani <smani@micron.com> Cc: Sam Bradshaw <sbradshaw@micron.com> Cc: Jeff Moyer <jmoyer@redhat.com> Cc: Al Viro <viro@zeniv.linux.org.uk> Cc: Benjamin LaHaise <bcrl@kvack.org> Reviewed-by: "Theodore Ts'o" <tytso@mit.edu> Signed-off-by: Andrew Morton <akpm@linux-foundation.org> Signed-off-by: Linus Torvalds <torvalds@linux-foundation.org>
2013-04-30nilfs2: remove unneeded test in nilfs_writepage()Vyacheslav Dubeyko
page->mapping->host cannot be NULL in nilfs_writepage(), so remove the unneeded test. The fixes the smatch warning: "fs/nilfs2/inode.c:211 nilfs_writepage() error: we previously assumed 'inode' could be null (see line 195)". Reported-by: Dan Carpenter <dan.carpenter@oracle.com> Signed-off-by: Vyacheslav Dubeyko <slava@dubeyko.com> Cc: Ryusuke Konishi <konishi.ryusuke@lab.ntt.co.jp> Signed-off-by: Andrew Morton <akpm@linux-foundation.org> Signed-off-by: Linus Torvalds <torvalds@linux-foundation.org>
2013-04-30nilfs2: fix using of PageLocked() in nilfs_clear_dirty_page()Vyacheslav Dubeyko
Change test_bit(PG_locked, &page->flags) to PageLocked(). Signed-off-by: Vyacheslav Dubeyko <slava@dubeyko.com> Cc: Ryusuke Konishi <konishi.ryusuke@lab.ntt.co.jp> Signed-off-by: Andrew Morton <akpm@linux-foundation.org> Signed-off-by: Linus Torvalds <torvalds@linux-foundation.org>
2013-04-30nilfs2: fix issue with flush kernel thread after remount in RO mode because ↵Vyacheslav Dubeyko
of driver's internal error or metadata corruption The NILFS2 driver remounts itself in RO mode in the case of discovering metadata corruption (for example, discovering a broken bmap). But usually, this takes place when there have been file system operations before remounting in RO mode. Thereby, NILFS2 driver can be in RO mode with presence of dirty pages in modified inodes' address spaces. It results in flush kernel thread's infinite trying to flush dirty pages in RO mode. As a result, it is possible to see such side effects as: (1) flush kernel thread occupies 50% - 99% of CPU time; (2) system can't be shutdowned without manual power switch off. SYMPTOMS: (1) System log contains error message: "Remounting filesystem read-only". (2) The flush kernel thread occupies 50% - 99% of CPU time. (3) The system can't be shutdowned without manual power switch off. REPRODUCTION PATH: (1) Create volume group with name "unencrypted" by means of vgcreate utility. (2) Run script (prepared by Anthony Doggett <Anthony2486@interfaces.org.uk>): ----------------[BEGIN SCRIPT]-------------------- #!/bin/bash VG=unencrypted #apt-get install nilfs-tools darcs lvcreate --size 2G --name ntest $VG mkfs.nilfs2 -b 1024 -B 8192 /dev/mapper/$VG-ntest mkdir /var/tmp/n mkdir /var/tmp/n/ntest mount /dev/mapper/$VG-ntest /var/tmp/n/ntest mkdir /var/tmp/n/ntest/thedir cd /var/tmp/n/ntest/thedir sleep 2 date darcs init sleep 2 dmesg|tail -n 5 date darcs whatsnew || true date sleep 2 dmesg|tail -n 5 ----------------[END SCRIPT]-------------------- (3) Try to shutdown the system. REPRODUCIBILITY: 100% FIX: This patch implements checking mount state of NILFS2 driver in nilfs_writepage(), nilfs_writepages() and nilfs_mdt_write_page() methods. If it is detected the RO mount state then all dirty pages are simply discarded with warning messages is written in system log. [akpm@linux-foundation.org: fix printk warning] Signed-off-by: Vyacheslav Dubeyko <slava@dubeyko.com> Acked-by: Ryusuke Konishi <konishi.ryusuke@lab.ntt.co.jp> Cc: Anthony Doggett <Anthony2486@interfaces.org.uk> Cc: ARAI Shun-ichi <hermes@ceres.dti.ne.jp> Cc: Piotr Szymaniak <szarpaj@grubelek.pl> Cc: Zahid Chowdhury <zahid.chowdhury@starsolutions.com> Cc: Elmer Zhang <freeboy6716@gmail.com> Cc: Wu Fengguang <fengguang.wu@intel.com> Signed-off-by: Andrew Morton <akpm@linux-foundation.org> Signed-off-by: Linus Torvalds <torvalds@linux-foundation.org>
2013-03-03fs: Limit sys_mount to only request filesystem modules.Eric W. Biederman
Modify the request_module to prefix the file system type with "fs-" and add aliases to all of the filesystems that can be built as modules to match. A common practice is to build all of the kernel code and leave code that is not commonly needed as modules, with the result that many users are exposed to any bug anywhere in the kernel. Looking for filesystems with a fs- prefix limits the pool of possible modules that can be loaded by mount to just filesystems trivially making things safer with no real cost. Using aliases means user space can control the policy of which filesystem modules are auto-loaded by editing /etc/modprobe.d/*.conf with blacklist and alias directives. Allowing simple, safe, well understood work-arounds to known problematic software. This also addresses a rare but unfortunate problem where the filesystem name is not the same as it's module name and module auto-loading would not work. While writing this patch I saw a handful of such cases. The most significant being autofs that lives in the module autofs4. This is relevant to user namespaces because we can reach the request module in get_fs_type() without having any special permissions, and people get uncomfortable when a user specified string (in this case the filesystem type) goes all of the way to request_module. After having looked at this issue I don't think there is any particular reason to perform any filtering or permission checks beyond making it clear in the module request that we want a filesystem module. The common pattern in the kernel is to call request_module() without regards to the users permissions. In general all a filesystem module does once loaded is call register_filesystem() and go to sleep. Which means there is not much attack surface exposed by loading a filesytem module unless the filesystem is mounted. In a user namespace filesystems are not mounted unless .fs_flags = FS_USERNS_MOUNT, which most filesystems do not set today. Acked-by: Serge Hallyn <serge.hallyn@canonical.com> Acked-by: Kees Cook <keescook@chromium.org> Reported-by: Kees Cook <keescook@google.com> Signed-off-by: "Eric W. Biederman" <ebiederm@xmission.com>
2013-02-26Merge branch 'for-linus' of ↵Linus Torvalds
git://git.kernel.org/pub/scm/linux/kernel/git/viro/vfs Pull vfs pile (part one) from Al Viro: "Assorted stuff - cleaning namei.c up a bit, fixing ->d_name/->d_parent locking violations, etc. The most visible changes here are death of FS_REVAL_DOT (replaced with "has ->d_weak_revalidate()") and a new helper getting from struct file to inode. Some bits of preparation to xattr method interface changes. Misc patches by various people sent this cycle *and* ocfs2 fixes from several cycles ago that should've been upstream right then. PS: the next vfs pile will be xattr stuff." * 'for-linus' of git://git.kernel.org/pub/scm/linux/kernel/git/viro/vfs: (46 commits) saner proc_get_inode() calling conventions proc: avoid extra pde_put() in proc_fill_super() fs: change return values from -EACCES to -EPERM fs/exec.c: make bprm_mm_init() static ocfs2/dlm: use GFP_ATOMIC inside a spin_lock ocfs2: fix possible use-after-free with AIO ocfs2: Fix oops in ocfs2_fast_symlink_readpage() code path get_empty_filp()/alloc_file() leave both ->f_pos and ->f_version zero target: writev() on single-element vector is pointless export kernel_write(), convert open-coded instances fs: encode_fh: return FILEID_INVALID if invalid fid_type kill f_vfsmnt vfs: kill FS_REVAL_DOT by adding a d_weak_revalidate dentry op nfsd: handle vfs_getattr errors in acl protocol switch vfs_getattr() to struct path default SET_PERSONALITY() in linux/elf.h ceph: prepopulate inodes only when request is aborted d_hash_and_lookup(): export, switch open-coded instances 9p: switch v9fs_set_create_acl() to inode+fid, do it before d_instantiate() 9p: split dropping the acls from v9fs_set_create_acl() ...
2013-02-26fs: encode_fh: return FILEID_INVALID if invalid fid_typeNamjae Jeon
This patch is a follow up on below patch: [PATCH] exportfs: add FILEID_INVALID to indicate invalid fid_type commit: 216b6cbdcbd86b1db0754d58886b466ae31f5a63 Signed-off-by: Namjae Jeon <namjae.jeon@samsung.com> Signed-off-by: Vivek Trivedi <t.vivek@samsung.com> Acked-by: Steven Whitehouse <swhiteho@redhat.com> Acked-by: Sage Weil <sage@inktank.com> Signed-off-by: Al Viro <viro@zeniv.linux.org.uk>
2013-02-22new helper: file_inode(file)Al Viro
2013-02-21Merge branch 'akpm' (incoming from Andrew)Linus Torvalds
Merge misc patches from Andrew Morton: - Florian has vanished so I appear to have become fbdev maintainer again :( - Joel and Mark are distracted to welcome to the new OCFS2 maintainer - The backlight queue - Small core kernel changes - lib/ updates - The rtc queue - Various random bits * akpm: (164 commits) rtc: rtc-davinci: use devm_*() functions rtc: rtc-max8997: use devm_request_threaded_irq() rtc: rtc-max8907: use devm_request_threaded_irq() rtc: rtc-da9052: use devm_request_threaded_irq() rtc: rtc-wm831x: use devm_request_threaded_irq() rtc: rtc-tps80031: use devm_request_threaded_irq() rtc: rtc-lp8788: use devm_request_threaded_irq() rtc: rtc-coh901331: use devm_clk_get() rtc: rtc-vt8500: use devm_*() functions rtc: rtc-tps6586x: use devm_request_threaded_irq() rtc: rtc-imxdi: use devm_clk_get() rtc: rtc-cmos: use dev_warn()/dev_dbg() instead of printk()/pr_debug() rtc: rtc-pcf8583: use dev_warn() instead of printk() rtc: rtc-sun4v: use pr_warn() instead of printk() rtc: rtc-vr41xx: use dev_info() instead of printk() rtc: rtc-rs5c313: use pr_err() instead of printk() rtc: rtc-at91rm9200: use dev_dbg()/dev_err() instead of printk()/pr_debug() rtc: rtc-rs5c372: use dev_dbg()/dev_warn() instead of printk()/pr_debug() rtc: rtc-ds2404: use dev_err() instead of printk() rtc: rtc-efi: use dev_err()/dev_warn()/pr_err() instead of printk() ...
2013-02-21mm: only enforce stable page writes if the backing device requires itDarrick J. Wong
Create a helper function to check if a backing device requires stable page writes and, if so, performs the necessary wait. Then, make it so that all points in the memory manager that handle making pages writable use the helper function. This should provide stable page write support to most filesystems, while eliminating unnecessary waiting for devices that don't require the feature. Before this patchset, all filesystems would block, regardless of whether or not it was necessary. ext3 would wait, but still generate occasional checksum errors. The network filesystems were left to do their own thing, so they'd wait too. After this patchset, all the disk filesystems except ext3 and btrfs will wait only if the hardware requires it. ext3 (if necessary) snapshots pages instead of blocking, and btrfs provides its own bdi so the mm will never wait. Network filesystems haven't been touched, so either they provide their own stable page guarantees or they don't block at all. The blocking behavior is back to what it was before 3.0 if you don't have a disk requiring stable page writes. Here's the result of using dbench to test latency on ext2: 3.8.0-rc3: Operation Count AvgLat MaxLat ---------------------------------------- WriteX 109347 0.028 59.817 ReadX 347180 0.004 3.391 Flush 15514 29.828 287.283 Throughput 57.429 MB/sec 4 clients 4 procs max_latency=287.290 ms 3.8.0-rc3 + patches: WriteX 105556 0.029 4.273 ReadX 335004 0.005 4.112 Flush 14982 30.540 298.634 Throughput 55.4496 MB/sec 4 clients 4 procs max_latency=298.650 ms As you can see, the maximum write latency drops considerably with this patch enabled. The other filesystems (ext3/ext4/xfs/btrfs) behave similarly, but see the cover letter for those results. Signed-off-by: Darrick J. Wong <darrick.wong@oracle.com> Acked-by: Steven Whitehouse <swhiteho@redhat.com> Reviewed-by: Jan Kara <jack@suse.cz> Cc: Adrian Hunter <adrian.hunter@intel.com> Cc: Andy Lutomirski <luto@amacapital.net> Cc: Artem Bityutskiy <dedekind1@gmail.com> Cc: Joel Becker <jlbec@evilplan.org> Cc: Mark Fasheh <mfasheh@suse.com> Cc: Jens Axboe <axboe@kernel.dk> Cc: Eric Van Hensbergen <ericvh@gmail.com> Cc: Ron Minnich <rminnich@sandia.gov> Cc: Latchesar Ionkov <lucho@ionkov.net> Signed-off-by: Andrew Morton <akpm@linux-foundation.org> Signed-off-by: Linus Torvalds <torvalds@linux-foundation.org>
2013-02-21Merge tag 'driver-core-3.9-rc1' of ↵Linus Torvalds
git://git.kernel.org/pub/scm/linux/kernel/git/gregkh/driver-core Pull driver core patches from Greg Kroah-Hartman: "Here is the big driver core merge for 3.9-rc1 There are two major series here, both of which touch lots of drivers all over the kernel, and will cause you some merge conflicts: - add a new function called devm_ioremap_resource() to properly be able to check return values. - remove CONFIG_EXPERIMENTAL Other than those patches, there's not much here, some minor fixes and updates" Fix up trivial conflicts * tag 'driver-core-3.9-rc1' of git://git.kernel.org/pub/scm/linux/kernel/git/gregkh/driver-core: (221 commits) base: memory: fix soft/hard_offline_page permissions drivercore: Fix ordering between deferred_probe and exiting initcalls backlight: fix class_find_device() arguments TTY: mark tty_get_device call with the proper const values driver-core: constify data for class_find_device() firmware: Ignore abort check when no user-helper is used firmware: Reduce ifdef CONFIG_FW_LOADER_USER_HELPER firmware: Make user-mode helper optional firmware: Refactoring for splitting user-mode helper code Driver core: treat unregistered bus_types as having no devices watchdog: Convert to devm_ioremap_resource() thermal: Convert to devm_ioremap_resource() spi: Convert to devm_ioremap_resource() power: Convert to devm_ioremap_resource() mtd: Convert to devm_ioremap_resource() mmc: Convert to devm_ioremap_resource() mfd: Convert to devm_ioremap_resource() media: Convert to devm_ioremap_resource() iommu: Convert to devm_ioremap_resource() drm: Convert to devm_ioremap_resource() ...
2013-02-05nilfs2: fix fix very long mount time issueVyacheslav Dubeyko
There exists a situation when GC can work in background alone without any other filesystem activity during significant time. The nilfs_clean_segments() method calls nilfs_segctor_construct() that updates superblocks in the case of NILFS_SC_SUPER_ROOT and THE_NILFS_DISCONTINUED flags are set. But when GC is working alone the nilfs_clean_segments() is called with unset THE_NILFS_DISCONTINUED flag. As a result, the update of superblocks doesn't occurred all this time and in the case of SPOR superblocks keep very old values of last super root placement. SYMPTOMS: Trying to mount a NILFS2 volume after SPOR in such environment ends with very long mounting time (it can achieve about several hours in some cases). REPRODUCING PATH: 1. It needs to use external USB HDD, disable automount and doesn't make any additional filesystem activity on the NILFS2 volume. 2. Generate temporary file with size about 100 - 500 GB (for example, dd if=/dev/zero of=<file_name> bs=1073741824 count=200). The size of file defines duration of GC working. 3. Then it needs to delete file. 4. Start GC manually by means of command "nilfs-clean -p 0". When you start GC by means of such way then, at the end, superblocks is updated by once. So, for simulation of SPOR, it needs to wait sometime (15 - 40 minutes) and simply switch off USB HDD manually. 5. Switch on USB HDD again and try to mount NILFS2 volume. As a result, NILFS2 volume will mount during very long time. REPRODUCIBILITY: 100% FIX: This patch adds checking that superblocks need to update and set THE_NILFS_DISCONTINUED flag before nilfs_clean_segments() call. Reported-by: Sergey Alexandrov <splavgm@gmail.com> Signed-off-by: Vyacheslav Dubeyko <slava@dubeyko.com> Tested-by: Vyacheslav Dubeyko <slava@dubeyko.com> Acked-by: Ryusuke Konishi <konishi.ryusuke@lab.ntt.co.jp> Tested-by: Ryusuke Konishi <konishi.ryusuke@lab.ntt.co.jp> Cc: <stable@vger.kernel.org> Signed-off-by: Andrew Morton <akpm@linux-foundation.org> Signed-off-by: Linus Torvalds <torvalds@linux-foundation.org>
2013-01-11fs/nilfs2: remove depends on CONFIG_EXPERIMENTALKees Cook
The CONFIG_EXPERIMENTAL config item has not carried much meaning for a while now and is almost always enabled by default. As agreed during the Linux kernel summit, remove it from any "depends on" lines in Kconfigs. CC: KONISHI Ryusuke <konishi.ryusuke@lab.ntt.co.jp> Signed-off-by: Kees Cook <keescook@chromium.org> Acked-by: Ryusuke Konishi <konishi.ryusuke@lab.ntt.co.jp>
2012-12-20nilfs2: drop vmtruncateMarco Stornelli
Removed vmtruncate Signed-off-by: Marco Stornelli <marco.stornelli@gmail.com> Signed-off-by: Al Viro <viro@zeniv.linux.org.uk>
2012-12-11mm: redefine address_space.assoc_mappingRafael Aquini
Overhaul struct address_space.assoc_mapping renaming it to address_space.private_data and its type is redefined to void*. By this approach we consistently name the .private_* elements from struct address_space as well as allow extended usage for address_space association with other data structures through ->private_data. Also, all users of old ->assoc_mapping element are converted to reflect its new name and type change (->private_data). Signed-off-by: Rafael Aquini <aquini@redhat.com> Cc: Rusty Russell <rusty@rustcorp.com.au> Cc: "Michael S. Tsirkin" <mst@redhat.com> Cc: Rik van Riel <riel@redhat.com> Cc: Mel Gorman <mel@csn.ul.ie> Cc: Andi Kleen <andi@firstfloor.org> Cc: Konrad Rzeszutek Wilk <konrad.wilk@oracle.com> Cc: Minchan Kim <minchan@kernel.org> Signed-off-by: Andrew Morton <akpm@linux-foundation.org> Signed-off-by: Linus Torvalds <torvalds@linux-foundation.org>
2012-10-09mm: kill vma flag VM_CAN_NONLINEARKonstantin Khlebnikov
Move actual pte filling for non-linear file mappings into the new special vma operation: ->remap_pages(). Filesystems must implement this method to get non-linear mapping support, if it uses filemap_fault() then generic_file_remap_pages() can be used. Now device drivers can implement this method and obtain nonlinear vma support. Signed-off-by: Konstantin Khlebnikov <khlebnikov@openvz.org> Cc: Alexander Viro <viro@zeniv.linux.org.uk> Cc: Carsten Otte <cotte@de.ibm.com> Cc: Chris Metcalf <cmetcalf@tilera.com> #arch/tile Cc: Cyrill Gorcunov <gorcunov@openvz.org> Cc: Eric Paris <eparis@redhat.com> Cc: H. Peter Anvin <hpa@zytor.com> Cc: Hugh Dickins <hughd@google.com> Cc: Ingo Molnar <mingo@redhat.com> Cc: James Morris <james.l.morris@oracle.com> Cc: Jason Baron <jbaron@redhat.com> Cc: Kentaro Takeda <takedakn@nttdata.co.jp> Cc: Matt Helsley <matthltc@us.ibm.com> Cc: Nick Piggin <npiggin@kernel.dk> Cc: Oleg Nesterov <oleg@redhat.com> Cc: Peter Zijlstra <a.p.zijlstra@chello.nl> Cc: Robert Richter <robert.richter@amd.com> Cc: Suresh Siddha <suresh.b.siddha@intel.com> Cc: Tetsuo Handa <penguin-kernel@I-love.SAKURA.ne.jp> Cc: Venkatesh Pallipadi <venki@google.com> Acked-by: Linus Torvalds <torvalds@linux-foundation.org> Signed-off-by: Andrew Morton <akpm@linux-foundation.org> Signed-off-by: Linus Torvalds <torvalds@linux-foundation.org>
2012-10-08Merge tag 'ext4_for_linus' of ↵Linus Torvalds
git://git.kernel.org/pub/scm/linux/kernel/git/tytso/ext4 Pull ext4 updates from Ted Ts'o: "The big new feature added this time is supporting online resizing using the meta_bg feature. This allows us to resize file systems which are greater than 16TB. In addition, the speed of online resizing has been improved in general. We also fix a number of races, some of which could lead to deadlocks, in ext4's Asynchronous I/O and online defrag support, thanks to good work by Dmitry Monakhov. There are also a large number of more minor bug fixes and cleanups from a number of other ext4 contributors, quite of few of which have submitted fixes for the first time." * tag 'ext4_for_linus' of git://git.kernel.org/pub/scm/linux/kernel/git/tytso/ext4: (69 commits) ext4: fix ext4_flush_completed_IO wait semantics ext4: fix mtime update in nodelalloc mode ext4: fix ext_remove_space for punch_hole case ext4: punch_hole should wait for DIO writers ext4: serialize truncate with owerwrite DIO workers ext4: endless truncate due to nonlocked dio readers ext4: serialize unlocked dio reads with truncate ext4: serialize dio nonlocked reads with defrag workers ext4: completed_io locking cleanup ext4: fix unwritten counter leakage ext4: give i_aiodio_unwritten a more appropriate name ext4: ext4_inode_info diet ext4: convert to use leXX_add_cpu() ext4: ext4_bread usage audit fs: reserve fallocate flag codepoint ext4: remove redundant offset check in mext_check_arguments() ext4: don't clear orphan list on ro mount with errors jbd2: fix assertion failure in commit code due to lacking transaction credits ext4: release donor reference when EXT4_IOC_MOVE_EXT ioctl fails ext4: enable FITRIM ioctl on bigalloc file system ...
2012-10-02Merge branch 'for-linus' of ↵Linus Torvalds
git://git.kernel.org/pub/scm/linux/kernel/git/viro/vfs Pull vfs update from Al Viro: - big one - consolidation of descriptor-related logics; almost all of that is moved to fs/file.c (BTW, I'm seriously tempted to rename the result to fd.c. As it is, we have a situation when file_table.c is about handling of struct file and file.c is about handling of descriptor tables; the reasons are historical - file_table.c used to be about a static array of struct file we used to have way back). A lot of stray ends got cleaned up and converted to saner primitives, disgusting mess in android/binder.c is still disgusting, but at least doesn't poke so much in descriptor table guts anymore. A bunch of relatively minor races got fixed in process, plus an ext4 struct file leak. - related thing - fget_light() partially unuglified; see fdget() in there (and yes, it generates the code as good as we used to have). - also related - bits of Cyrill's procfs stuff that got entangled into that work; _not_ all of it, just the initial move to fs/proc/fd.c and switch of fdinfo to seq_file. - Alex's fs/coredump.c spiltoff - the same story, had been easier to take that commit than mess with conflicts. The rest is a separate pile, this was just a mechanical code movement. - a few misc patches all over the place. Not all for this cycle, there'll be more (and quite a few currently sit in akpm's tree)." Fix up trivial conflicts in the android binder driver, and some fairly simple conflicts due to two different changes to the sock_alloc_file() interface ("take descriptor handling from sock_alloc_file() to callers" vs "net: Providing protocol type via system.sockprotoname xattr of /proc/PID/fd entries" adding a dentry name to the socket) * 'for-linus' of git://git.kernel.org/pub/scm/linux/kernel/git/viro/vfs: (72 commits) MAX_LFS_FILESIZE should be a loff_t compat: fs: Generic compat_sys_sendfile implementation fs: push rcu_barrier() from deactivate_locked_super() to filesystems btrfs: reada_extent doesn't need kref for refcount coredump: move core dump functionality into its own file coredump: prevent double-free on an error path in core dumper usb/gadget: fix misannotations fcntl: fix misannotations ceph: don't abuse d_delete() on failure exits hypfs: ->d_parent is never NULL or negative vfs: delete surplus inode NULL check switch simple cases of fget_light to fdget new helpers: fdget()/fdput() switch o2hb_region_dev_write() to fget_light() proc_map_files_readdir(): don't bother with grabbing files make get_file() return its argument vhost_set_vring(): turn pollstart/pollstop into bool switch prctl_set_mm_exe_file() to fget_light() switch xfs_find_handle() to fget_light() switch xfs_swapext() to fget_light() ...
2012-10-02fs: push rcu_barrier() from deactivate_locked_super() to filesystemsKirill A. Shutemov
There's no reason to call rcu_barrier() on every deactivate_locked_super(). We only need to make sure that all delayed rcu free inodes are flushed before we destroy related cache. Removing rcu_barrier() from deactivate_locked_super() affects some fast paths. E.g. on my machine exit_group() of a last process in IPC namespace takes 0.07538s. rcu_barrier() takes 0.05188s of that time. Signed-off-by: Kirill A. Shutemov <kirill.shutemov@linux.intel.com> Cc: Al Viro <viro@zeniv.linux.org.uk> Signed-off-by: Andrew Morton <akpm@linux-foundation.org> Signed-off-by: Al Viro <viro@zeniv.linux.org.uk>
git://git.kernel.org/pub/scm/linux/kernel/git/ebiederm/user-namespace Pull user namespace changes from Eric Biederman: "This is a mostly modest set of changes to enable basic user namespace support. This allows the code to code to compile with user namespaces enabled and removes the assumption there is only the initial user namespace. Everything is converted except for the most complex of the filesystems: autofs4, 9p, afs, ceph, cifs, coda, fuse, gfs2, ncpfs, nfs, ocfs2 and xfs as those patches need a bit more review. The strategy is to push kuid_t and kgid_t values are far down into subsystems and filesystems as reasonable. Leaving the make_kuid and from_kuid operations to happen at the edge of userspace, as the values come off the disk, and as the values come in from the network. Letting compile type incompatible compile errors (present when user namespaces are enabled) guide me to find the issues. The most tricky areas have been the places where we had an implicit union of uid and gid values and were storing them in an unsigned int. Those places were converted into explicit unions. I made certain to handle those places with simple trivial patches. Out of that work I discovered we have generic interfaces for storing quota by projid. I had never heard of the project identifiers before. Adding full user namespace support for project identifiers accounts for most of the code size growth in my git tree. Ultimately there will be work to relax privlige checks from "capable(FOO)" to "ns_capable(user_ns, FOO)" where it is safe allowing root in a user names to do those things that today we only forbid to non-root users because it will confuse suid root applications. While I was pushing kuid_t and kgid_t changes deep into the audit code I made a few other cleanups. I capitalized on the fact we process netlink messages in the context of the message sender. I removed usage of NETLINK_CRED, and started directly using current->tty. Some of these patches have also made it into maintainer trees, with no problems from identical code from different trees showing up in linux-next. After reading through all of this code I feel like I might be able to win a game of kernel trivial pursuit." Fix up some fairly trivial conflicts in netfilter uid/git logging code. * 'for-linus' of git://git.kernel.org/pub/scm/linux/kernel/git/ebiederm/user-namespace: (107 commits) userns: Convert the ufs filesystem to use kuid/kgid where appropriate userns: Convert the udf filesystem to use kuid/kgid where appropriate userns: Convert ubifs to use kuid/kgid userns: Convert squashfs to use kuid/kgid where appropriate userns: Convert reiserfs to use kuid and kgid where appropriate userns: Convert jfs to use kuid/kgid where appropriate userns: Convert jffs2 to use kuid and kgid where appropriate userns: Convert hpfs to use kuid and kgid where appropriate userns: Convert btrfs to use kuid/kgid where appropriate userns: Convert bfs to use kuid/kgid where appropriate userns: Convert affs to use kuid/kgid wherwe appropriate userns: On alpha modify linux_to_osf_stat to use convert from kuids and kgids userns: On ia64 deal with current_uid and current_gid being kuid and kgid userns: On ppc convert current_uid from a kuid before printing. userns: Convert s390 getting uid and gid system calls to use kuid and kgid userns: Convert s390 hypfs to use kuid and kgid where appropriate userns: Convert binder ipc to use kuids userns: Teach security_path_chown to take kuids and kgids userns: Add user namespace support to IMA userns: Convert EVM to deal with kuids and kgids in it's hmac computation ...
2012-09-30ext4: fix mtime update in nodelalloc modeTheodore Ts'o
Commits 5e8830dc85d0 and 41c4d25f78c0 introduced a regression into v3.6-rc1 for ext4 in nodealloc mode, such that mtime updates would not take place for files modified via mmap if the page was already in the page cache. This would also affect ext3 file systems mounted using the ext4 file system driver. The problem was that ext4_page_mkwrite() had a shortcut which would avoid calling __block_page_mkwrite() under some circumstances, and the above two commit transferred the responsibility of calling file_update_time() to __block_page_mkwrite --- which woudln't get called in some circumstances. Since __block_page_mkwrite() only has three callers, block_page_mkwrite(), ext4_page_mkwrite, and nilfs_page_mkwrite(), the best way to solve this is to move the responsibility for calling file_update_time() to its caller. This problem was found via xfstests #215 with a file system mounted with -o nodelalloc. Signed-off-by: "Theodore Ts'o" <tytso@mit.edu> Reviewed-by: Jan Kara <jack@suse.cz> Cc: KONISHI Ryusuke <konishi.ryusuke@lab.ntt.co.jp> Cc: stable@vger.kernel.org
2012-09-21userns: Convert nillfs2 to use kuid/kgid where appropriateEric W. Biederman
Acked-by: Ryusuke Konishi <konishi.ryusuke@lab.ntt.co.jp> Acked-by: Serge Hallyn <serge.hallyn@canonical.com> Signed-off-by: Eric W. Biederman <ebiederm@xmission.com>
2012-08-04nilfs2: nuke write_super from commentsArtem Bityutskiy
The '->write_super' superblock method is gone, and this patch removes all the references to 'write_super' from ntfs. Cc: KONISHI Ryusuke <konishi.ryusuke@lab.ntt.co.jp> Signed-off-by: Artem Bityutskiy <artem.bityutskiy@linux.intel.com> Signed-off-by: Al Viro <viro@zeniv.linux.org.uk>
2012-08-01Merge branch 'for-linus' of ↵Linus Torvalds
git://git.kernel.org/pub/scm/linux/kernel/git/viro/vfs Pull second vfs pile from Al Viro: "The stuff in there: fsfreeze deadlock fixes by Jan (essentially, the deadlock reproduced by xfstests 068), symlink and hardlink restriction patches, plus assorted cleanups and fixes. Note that another fsfreeze deadlock (emergency thaw one) is *not* dealt with - the series by Fernando conflicts a lot with Jan's, breaks userland ABI (FIFREEZE semantics gets changed) and trades the deadlock for massive vfsmount leak; this is going to be handled next cycle. There probably will be another pull request, but that stuff won't be in it." Fix up trivial conflicts due to unrelated changes next to each other in drivers/{staging/gdm72xx/usb_boot.c, usb/gadget/storage_common.c} * 'for-linus' of git://git.kernel.org/pub/scm/linux/kernel/git/viro/vfs: (54 commits) delousing target_core_file a bit Documentation: Correct s_umount state for freeze_fs/unfreeze_fs fs: Remove old freezing mechanism ext2: Implement freezing btrfs: Convert to new freezing mechanism nilfs2: Convert to new freezing mechanism ntfs: Convert to new freezing mechanism fuse: Convert to new freezing mechanism gfs2: Convert to new freezing mechanism ocfs2: Convert to new freezing mechanism xfs: Convert to new freezing code ext4: Convert to new freezing mechanism fs: Protect write paths by sb_start_write - sb_end_write fs: Skip atime update on frozen filesystem fs: Add freezing handling to mnt_want_write() / mnt_drop_write() fs: Improve filesystem freezing handling switch the protection of percpu_counter list to spinlock nfsd: Push mnt_want_write() outside of i_mutex btrfs: Push mnt_want_write() outside of i_mutex fat: Push mnt_want_write() outside of i_mutex ...
2012-07-31nilfs2: Convert to new freezing mechanismJan Kara
We change nilfs_page_mkwrite() to provide proper freeze protection for writeable page faults (we must wait for frozen filesystem even if the page is fully mapped). We remove all vfs_check_frozen() checks since they are now handled by the generic code. CC: linux-nilfs@vger.kernel.org CC: KONISHI Ryusuke <konishi.ryusuke@lab.ntt.co.jp> Signed-off-by: Jan Kara <jack@suse.cz> Signed-off-by: Al Viro <viro@zeniv.linux.org.uk>
2012-07-30nilfs2: add omitted comments for different structures in driver implementationVyacheslav Dubeyko
Add omitted comments for different structures in driver implementation. Signed-off-by: Vyacheslav Dubeyko <slava@dubeyko.com> Signed-off-by: Ryusuke Konishi <konishi.ryusuke@lab.ntt.co.jp> Signed-off-by: Andrew Morton <akpm@linux-foundation.org> Signed-off-by: Linus Torvalds <torvalds@linux-foundation.org>
2012-07-30nilfs2: fix deadlock issue between chcp and thaw ioctlsRyusuke Konishi
An fs-thaw ioctl causes deadlock with a chcp or mkcp -s command: chcp D ffff88013870f3d0 0 1325 1324 0x00000004 ... Call Trace: nilfs_transaction_begin+0x11c/0x1a0 [nilfs2] wake_up_bit+0x20/0x20 copy_from_user+0x18/0x30 [nilfs2] nilfs_ioctl_change_cpmode+0x7d/0xcf [nilfs2] nilfs_ioctl+0x252/0x61a [nilfs2] do_page_fault+0x311/0x34c get_unmapped_area+0x132/0x14e do_vfs_ioctl+0x44b/0x490 __set_task_blocked+0x5a/0x61 vm_mmap_pgoff+0x76/0x87 __set_current_blocked+0x30/0x4a sys_ioctl+0x4b/0x6f system_call_fastpath+0x16/0x1b thaw D ffff88013870d890 0 1352 1351 0x00000004 ... Call Trace: rwsem_down_failed_common+0xdb/0x10f call_rwsem_down_write_failed+0x13/0x20 down_write+0x25/0x27 thaw_super+0x13/0x9e do_vfs_ioctl+0x1f5/0x490 vm_mmap_pgoff+0x76/0x87 sys_ioctl+0x4b/0x6f filp_close+0x64/0x6c system_call_fastpath+0x16/0x1b where the thaw ioctl deadlocked at thaw_super() when called while chcp was waiting at nilfs_transaction_begin() called from nilfs_ioctl_change_cpmode(). This deadlock is 100% reproducible. This is because nilfs_ioctl_change_cpmode() first locks sb->s_umount in read mode and then waits for unfreezing in nilfs_transaction_begin(), whereas thaw_super() locks sb->s_umount in write mode. The locking of sb->s_umount here was intended to make snapshot mounts and the downgrade of snapshots to checkpoints exclusive. This fixes the deadlock issue by replacing the sb->s_umount usage in nilfs_ioctl_change_cpmode() with a dedicated mutex which protects snapshot mounts. Signed-off-by: Ryusuke Konishi <konishi.ryusuke@lab.ntt.co.jp> Cc: Fernando Luis Vazquez Cao <fernando@oss.ntt.co.jp> Tested-by: Ryusuke Konishi <konishi.ryusuke@lab.ntt.co.jp> Cc: <stable@vger.kernel.org> Signed-off-by: Andrew Morton <akpm@linux-foundation.org> Signed-off-by: Linus Torvalds <torvalds@linux-foundation.org>
2012-07-30nilfs2: fix timing issue between rmcp and chcp ioctlsRyusuke Konishi
The checkpoint deletion ioctl (rmcp ioctl) has potential for breaking snapshot because it is not fully exclusive with checkpoint mode change ioctl (chcp ioctl). The rmcp ioctl first tests if the specified checkpoint is a snapshot or not within nilfs_cpfile_delete_checkpoint function, and then calls nilfs_cpfile_delete_checkpoints function to actually invalidate the checkpoint only if it's not a snapshot. However, the checkpoint can be changed into a snapshot by the chcp ioctl between these two operations. In that case, calling nilfs_cpfile_delete_checkpoints() wrongly invalidates the snapshot, which leads to snapshot list corruption and snapshot count mismatch. This fixes the issue by changing nilfs_cpfile_delete_checkpoints() so that it reconfirms the target checkpoints are snapshot or not. This second check is exclusive with the chcp operation since it is protected by an existing semaphore. Signed-off-by: Ryusuke Konishi <konishi.ryusuke@lab.ntt.co.jp> Cc: Fernando Luis Vazquez Cao <fernando@oss.ntt.co.jp> Signed-off-by: Andrew Morton <akpm@linux-foundation.org> Signed-off-by: Linus Torvalds <torvalds@linux-foundation.org>
2012-07-30nilfs2: remove references to long gone super operationsFernando Luis Vazquez Cao
->delete_inode(), ->write_super_lockfs(), ->unlockfs() are gone so remove references to them in the NTFS code. Noticed while cleaning up the fsfreeze mess. Signed-off-by: Fernando Luis Vazquez Cao <fernando@oss.ntt.co.jp> Signed-off-by: Ryusuke Konishi <konishi.ryusuke@lab.ntt.co.jp> Signed-off-by: Andrew Morton <akpm@linux-foundation.org> Signed-off-by: Linus Torvalds <torvalds@linux-foundation.org>
2012-07-30nilfs2: add omitted comment for ns_mount_state field of the_nilfs structureVyacheslav Dubeyko
Add omitted comment for ns_mount_state field of the_nilfs structure. Signed-off-by: Vyacheslav Dubeyko <slava@dubeyko.com> Signed-off-by: Ryusuke Konishi <konishi.ryusuke@lab.ntt.co.jp> Signed-off-by: Andrew Morton <akpm@linux-foundation.org> Signed-off-by: Linus Torvalds <torvalds@linux-foundation.org>
2012-07-14VFS: Pass mount flags to sget()David Howells
Pass mount flags to sget() so that it can use them in initialising a new superblock before the set function is called. They could also be passed to the compare function. Signed-off-by: David Howells <dhowells@redhat.com> Signed-off-by: Al Viro <viro@zeniv.linux.org.uk>
2012-07-14don't pass nameidata to ->create()Al Viro
boolean "does it have to be exclusive?" flag is passed instead; Local filesystem should just ignore it - the object is guaranteed not to be there yet. Signed-off-by: Al Viro <viro@zeniv.linux.org.uk>
2012-07-14stop passing nameidata to ->lookup()Al Viro
Just the flags; only NFS cares even about that, but there are legitimate uses for such argument. And getting rid of that completely would require splitting ->lookup() into a couple of methods (at least), so let's leave that alone for now... Signed-off-by: Al Viro <viro@zeniv.linux.org.uk>
2012-06-20nilfs2: ensure proper cache clearing for gc-inodesRyusuke Konishi
A gc-inode is a pseudo inode used to buffer the blocks to be moved by garbage collection. Block caches of gc-inodes must be cleared every time a garbage collection function (nilfs_clean_segments) completes. Otherwise, stale blocks buffered in the caches may be wrongly reused in successive calls of the GC function. For user files, this is not a problem because their gc-inodes are distinguished by a checkpoint number as well as an inode number. They never buffer different blocks if either an inode number, a checkpoint number, or a block offset differs. However, gc-inodes of sufile, cpfile and DAT file can store different data for the same block offset. Thus, the nilfs_clean_segments function can move incorrect block for these meta-data files if an old block is cached. I found this is really causing meta-data corruption in nilfs. This fixes the issue by ensuring cache clear of gc-inodes and resolves reported GC problems including checkpoint file corruption, b-tree corruption, and the following warning during GC. nilfs_palloc_freev: entry number 307234 already freed. ... Signed-off-by: Ryusuke Konishi <konishi.ryusuke@lab.ntt.co.jp> Tested-by: Ryusuke Konishi <konishi.ryusuke@lab.ntt.co.jp> Cc: <stable@vger.kernel.org> [2.6.37+] Signed-off-by: Andrew Morton <akpm@linux-foundation.org> Signed-off-by: Linus Torvalds <torvalds@linux-foundation.org>
2012-06-01Merge branch 'for-linus' of ↵Linus Torvalds
git://git.kernel.org/pub/scm/linux/kernel/git/viro/vfs Pull vfs changes from Al Viro. "A lot of misc stuff. The obvious groups: * Miklos' atomic_open series; kills the damn abuse of ->d_revalidate() by NFS, which was the major stumbling block for all work in that area. * ripping security_file_mmap() and dealing with deadlocks in the area; sanitizing the neighborhood of vm_mmap()/vm_munmap() in general. * ->encode_fh() switched to saner API; insane fake dentry in mm/cleancache.c gone. * assorted annotations in fs (endianness, __user) * parts of Artem's ->s_dirty work (jff2 and reiserfs parts) * ->update_time() work from Josef. * other bits and pieces all over the place. Normally it would've been in two or three pull requests, but signal.git stuff had eaten a lot of time during this cycle ;-/" Fix up trivial conflicts in Documentation/filesystems/vfs.txt (the 'truncate_range' inode method was removed by the VM changes, the VFS update adds an 'update_time()' method), and in fs/btrfs/ulist.[ch] (due to sparse fix added twice, with other changes nearby). * 'for-linus' of git://git.kernel.org/pub/scm/linux/kernel/git/viro/vfs: (95 commits) nfs: don't open in ->d_revalidate vfs: retry last component if opening stale dentry vfs: nameidata_to_filp(): don't throw away file on error vfs: nameidata_to_filp(): inline __dentry_open() vfs: do_dentry_open(): don't put filp vfs: split __dentry_open() vfs: do_last() common post lookup vfs: do_last(): add audit_inode before open vfs: do_last(): only return EISDIR for O_CREAT vfs: do_last(): check LOOKUP_DIRECTORY vfs: do_last(): make ENOENT exit RCU safe vfs: make follow_link check RCU safe vfs: do_last(): use inode variable vfs: do_last(): inline walk_component() vfs: do_last(): make exit RCU safe vfs: split do_lookup() Btrfs: move over to use ->update_time fs: introduce inode operation ->update_time reiserfs: get rid of resierfs_sync_super reiserfs: mark the superblock as dirty a bit later ...
2012-05-31nilfs2: flush disk caches in syncingRyusuke Konishi
There are two cases that the cache flush is needed to avoid data loss against unexpected hang or power failure. One is sync file function (i.e. nilfs_sync_file) and another is checkpointing ioctl. This issues a cache flush request to device for such cases if barrier mount option is enabled, and makes sure data really is on persistent storage on their completion. Signed-off-by: Ryusuke Konishi <konishi.ryusuke@lab.ntt.co.jp> Signed-off-by: Andrew Morton <akpm@linux-foundation.org> Signed-off-by: Linus Torvalds <torvalds@linux-foundation.org>
2012-05-29->encode_fh() API changeAl Viro
pass inode + parent's inode or NULL instead of dentry + bool saying whether we want the parent or not. NOTE: that needs ceph fix folded in. Signed-off-by: Al Viro <viro@zeniv.linux.org.uk>
2012-05-28Merge tag 'writeback' of git://git.kernel.org/pub/scm/linux/kernel/git/wfg/linuxLinus Torvalds
Pull writeback tree from Wu Fengguang: "Mainly from Jan Kara to avoid iput() in the flusher threads." * tag 'writeback' of git://git.kernel.org/pub/scm/linux/kernel/git/wfg/linux: writeback: Avoid iput() from flusher thread vfs: Rename end_writeback() to clear_inode() vfs: Move waiting for inode writeback from end_writeback() to evict_inode() writeback: Refactor writeback_single_inode() writeback: Remove wb->list_lock from writeback_single_inode() writeback: Separate inode requeueing after writeback writeback: Move I_DIRTY_PAGES handling writeback: Move requeueing when I_SYNC set to writeback_sb_inodes() writeback: Move clearing of I_SYNC into inode_sync_complete() writeback: initialize global_dirty_limit fs: remove 8 bytes of padding from struct writeback_control on 64 bit builds mm: page-writeback.c: local functions should not be exposed globally
2012-05-10vfs: make it possible to access the dentry hash/len as one 64-bit entryLinus Torvalds
This allows comparing hash and len in one operation on 64-bit architectures. Right now only __d_lookup_rcu() takes advantage of this, since that is the case we care most about. The use of anonymous struct/unions hides the alternate 64-bit approach from most users, the exception being a few cases where we initialize a 'struct qstr' with a static initializer. This makes the problematic cases use a new QSTR_INIT() helper function for that (but initializing just the name pointer with a "{ .name = xyzzy }" initializer remains valid, as does just copying another qstr structure). Signed-off-by: Linus Torvalds <torvalds@linux-foundation.org>
2012-05-06vfs: Rename end_writeback() to clear_inode()Jan Kara
After we moved inode_sync_wait() from end_writeback() it doesn't make sense to call the function end_writeback() anymore. Rename it to clear_inode() which well says what the function really does - set I_CLEAR flag. Signed-off-by: Jan Kara <jack@suse.cz> Signed-off-by: Fengguang Wu <fengguang.wu@intel.com>
