path: root/fs/nilfs2
2015-03-12nilfs2: fix deadlock of segment constructor during recoveryRyusuke Konishi
According to a report from Yuxuan Shui, nilfs2 in kernel 3.19 got stuck during recovery at mount time. The code path that caused the deadlock was as follows: nilfs_fill_super() load_nilfs() nilfs_salvage_orphan_logs() * Do roll-forwarding, attach segment constructor for recovery, and kick it. nilfs_segctor_thread() nilfs_segctor_thread_construct() * A lock is held with nilfs_transaction_lock() nilfs_segctor_do_construct() nilfs_segctor_drop_written_files() iput() iput_final() write_inode_now() writeback_single_inode() __writeback_single_inode() do_writepages() nilfs_writepage() nilfs_construct_dsync_segment() nilfs_transaction_lock() --> deadlock This can happen if commit 7ef3ff2fea8b ("nilfs2: fix deadlock of segment constructor over I_SYNC flag") is applied and roll-forward recovery was performed at mount time. The roll-forward recovery can happen if datasync write is done and the file system crashes immediately after that. For instance, we can reproduce the issue with the following steps: < nilfs2 is mounted on /nilfs (device: /dev/sdb1) > # dd if=/dev/zero of=/nilfs/test bs=4k count=1 && sync # dd if=/dev/zero of=/nilfs/test conv=notrunc oflag=dsync bs=4k count=1 && reboot -nfh < the system will immediately reboot > # mount -t nilfs2 /dev/sdb1 /nilfs The deadlock occurs because iput() can run segment constructor through writeback_single_inode() if MS_ACTIVE flag is not set on sb->s_flags. The above commit changed segment constructor so that it calls iput() asynchronously for inodes with i_nlink == 0, but that change was imperfect. This fixes the another deadlock by deferring iput() in segment constructor even for the case that mount is not finished, that is, for the case that MS_ACTIVE flag is not set. Signed-off-by: Ryusuke Konishi <konishi.ryusuke@lab.ntt.co.jp> Reported-by: Yuxuan Shui <yshuiv7@gmail.com> Tested-by: Ryusuke Konishi <konishi.ryusuke@lab.ntt.co.jp> Cc: Al Viro <viro@zeniv.linux.org.uk> Cc: <stable@vger.kernel.org> Signed-off-by: Andrew Morton <akpm@linux-foundation.org> Signed-off-by: Linus Torvalds <torvalds@linux-foundation.org>
2015-02-28nilfs2: fix potential memory overrun on inodeRyusuke Konishi
Each inode of nilfs2 stores a root node of a b-tree, and it turned out to have a memory overrun issue: Each b-tree node of nilfs2 stores a set of key-value pairs and the number of them (in "bn_nchildren" member of nilfs_btree_node struct), as well as a few other "bn_*" members. Since the value of "bn_nchildren" is used for operations on the key-values within the b-tree node, it can cause memory access overrun if a large number is incorrectly set to "bn_nchildren". For instance, nilfs_btree_node_lookup() function determines the range of binary search with it, and too large "bn_nchildren" leads nilfs_btree_node_get_key() in that function to overrun. As for intermediate b-tree nodes, this is prevented by a sanity check performed when each node is read from a drive, however, no sanity check has been done for root nodes stored in inodes. This patch fixes the issue by adding missing sanity check against b-tree root nodes so that it's called when on-memory inodes are read from ifile, inode metadata file. Signed-off-by: Ryusuke Konishi <konishi.ryusuke@lab.ntt.co.jp> Cc: <stable@vger.kernel.org> Signed-off-by: Andrew Morton <akpm@linux-foundation.org> Signed-off-by: Linus Torvalds <torvalds@linux-foundation.org>
2015-02-12Merge branch 'for-3.20/bdi' of git://git.kernel.dk/linux-blockLinus Torvalds
Pull backing device changes from Jens Axboe: "This contains a cleanup of how the backing device is handled, in preparation for a rework of the life time rules. In this part, the most important change is to split the unrelated nommu mmap flags from it, but also removing a backing_dev_info pointer from the address_space (and inode), and a cleanup of other various minor bits. Christoph did all the work here, I just fixed an oops with pages that have a swap backing. Arnd fixed a missing export, and Oleg killed the lustre backing_dev_info from staging. Last patch was from Al, unexporting parts that are now no longer needed outside" * 'for-3.20/bdi' of git://git.kernel.dk/linux-block: Make super_blocks and sb_lock static mtd: export new mtd_mmap_capabilities fs: make inode_to_bdi() handle NULL inode staging/lustre/llite: get rid of backing_dev_info fs: remove default_backing_dev_info fs: don't reassign dirty inodes to default_backing_dev_info nfs: don't call bdi_unregister ceph: remove call to bdi_unregister fs: remove mapping->backing_dev_info fs: export inode_to_bdi and use it in favor of mapping->backing_dev_info nilfs2: set up s_bdi like the generic mount_bdev code block_dev: get bdev inode bdi directly from the block device block_dev: only write bdev inode on close fs: introduce f_op->mmap_capabilities for nommu mmap support fs: kill BDI_CAP_SWAP_BACKED fs: deduplicate noop_backing_dev_info
2015-02-10mm: drop vm_ops->remap_pages and generic_file_remap_pages() stubKirill A. Shutemov
Nobody uses it anymore. [akpm@linux-foundation.org: fix filemap_xip.c] Signed-off-by: Kirill A. Shutemov <kirill.shutemov@linux.intel.com> Cc: Wu Fengguang <fengguang.wu@intel.com> Signed-off-by: Andrew Morton <akpm@linux-foundation.org> Signed-off-by: Linus Torvalds <torvalds@linux-foundation.org>
2015-02-05nilfs2: fix deadlock of segment constructor over I_SYNC flagRyusuke Konishi
Nilfs2 eventually hangs in a stress test with fsstress program. This issue was caused by the following deadlock over I_SYNC flag between nilfs_segctor_thread() and writeback_sb_inodes(): nilfs_segctor_thread() nilfs_segctor_thread_construct() nilfs_segctor_unlock() nilfs_dispose_list() iput() iput_final() evict() inode_wait_for_writeback() * wait for I_SYNC flag writeback_sb_inodes() * set I_SYNC flag on inode->i_state __writeback_single_inode() do_writepages() nilfs_writepages() nilfs_construct_dsync_segment() nilfs_segctor_sync() * wait for completion of segment constructor inode_sync_complete() * clear I_SYNC flag after __writeback_single_inode() completed writeback_sb_inodes() calls do_writepages() for dirty inodes after setting I_SYNC flag on inode->i_state. do_writepages() in turn calls nilfs_writepages(), which can run segment constructor and wait for its completion. On the other hand, segment constructor calls iput(), which can call evict() and wait for the I_SYNC flag on inode_wait_for_writeback(). Since segment constructor doesn't know when I_SYNC will be set, it cannot know whether iput() will block or not unless inode->i_nlink has a non-zero count. We can prevent evict() from being called in iput() by implementing sop->drop_inode(), but it's not preferable to leave inodes with i_nlink == 0 for long periods because it even defers file truncation and inode deallocation. So, this instead resolves the deadlock by calling iput() asynchronously with a workqueue for inodes with i_nlink == 0. Signed-off-by: Ryusuke Konishi <konishi.ryusuke@lab.ntt.co.jp> Cc: Al Viro <viro@zeniv.linux.org.uk> Tested-by: Ryusuke Konishi <konishi.ryusuke@lab.ntt.co.jp> Cc: <stable@vger.kernel.org> Signed-off-by: Andrew Morton <akpm@linux-foundation.org> Signed-off-by: Linus Torvalds <torvalds@linux-foundation.org>
2015-01-20fs: remove mapping->backing_dev_infoChristoph Hellwig
Now that we never use the backing_dev_info pointer in struct address_space we can simply remove it and save 4 to 8 bytes in every inode. Signed-off-by: Christoph Hellwig <hch@lst.de> Acked-by: Ryusuke Konishi <konishi.ryusuke@lab.ntt.co.jp> Reviewed-by: Tejun Heo <tj@kernel.org> Reviewed-by: Jan Kara <jack@suse.cz> Signed-off-by: Jens Axboe <axboe@fb.com>
2015-01-20nilfs2: set up s_bdi like the generic mount_bdev codeChristoph Hellwig
mapping->backing_dev_info will go away, so don't rely on it. Signed-off-by: Christoph Hellwig <hch@lst.de> Acked-by: Ryusuke Konishi <konishi.ryusuke@lab.ntt.co.jp> Reviewed-by: Tejun Heo <tj@kernel.org> Reviewed-by: Jan Kara <jack@suse.cz> Signed-off-by: Jens Axboe <axboe@fb.com>
2014-12-10nilfs2: fix the nilfs_iget() vs. nilfs_new_inode() racesRyusuke Konishi
Same story as in commit 41080b5a2401 ("nfsd race fixes: ext2") (similar ext2 fix) except that nilfs2 needs to use insert_inode_locked4() instead of insert_inode_locked() and a bug of a check for dead inodes needs to be fixed. If nilfs_iget() is called from nfsd after nilfs_new_inode() calls insert_inode_locked4(), nilfs_iget() will wait for unlock_new_inode() at the end of nilfs_mkdir()/nilfs_create()/etc to unlock the inode. If nilfs_iget() is called before nilfs_new_inode() calls insert_inode_locked4(), it will create an in-core inode and read its data from the on-disk inode. But, nilfs_iget() will find i_nlink equals zero and fail at nilfs_read_inode_common(), which will lead it to call iget_failed() and cleanly fail. However, this sanity check doesn't work as expected for reused on-disk inodes because they leave a non-zero value in i_mode field and it hinders the test of i_nlink. This patch also fixes the issue by removing the test on i_mode that nilfs2 doesn't need. Signed-off-by: Ryusuke Konishi <konishi.ryusuke@lab.ntt.co.jp> Cc: Al Viro <viro@zeniv.linux.org.uk> Signed-off-by: Andrew Morton <akpm@linux-foundation.org> Signed-off-by: Linus Torvalds <torvalds@linux-foundation.org>
2014-12-10nilfs2: deletion of an unnecessary check before the function call "iput"Markus Elfring
The iput() function tests whether its argument is NULL and then returns immediately. Thus the test around the call is not needed. This issue was detected by using the Coccinelle software. Signed-off-by: Markus Elfring <elfring@users.sourceforge.net> Signed-off-by: Ryusuke Konishi <konishi.ryusuke@lab.ntt.co.jp> Signed-off-by: Andrew Morton <akpm@linux-foundation.org> Signed-off-by: Linus Torvalds <torvalds@linux-foundation.org>
2014-12-10nilfs2: avoid duplicate segment construction for fsync()Andreas Rohner
This patch removes filemap_write_and_wait_range() from nilfs_sync_file(), because it triggers a data segment construction by calling nilfs_writepages() with WB_SYNC_ALL. A data segment construction does not remove the inode from the i_dirty list and it does not clear the NILFS_I_DIRTY flag. Therefore nilfs_inode_dirty() still returns true, which leads to an unnecessary duplicate segment construction in nilfs_sync_file(). A call to filemap_write_and_wait_range() is not needed, because NILFS2 does not rely on the generic writeback mechanisms. Instead it implements its own mechanism to collect all dirty pages and write them into segments. It is more efficient to initiate the segment construction directly in nilfs_sync_file() without the detour over filemap_write_and_wait_range(). Additionally the lock of i_mutex is not needed, because all code blocks that are protected by i_mutex are also protected by a NILFS transaction: Function i_mutex nilfs_transaction ------------------------------------------------------ nilfs_ioctl_setflags: yes yes nilfs_fiemap: yes no nilfs_write_begin: yes yes nilfs_write_end: yes yes nilfs_lookup: yes no nilfs_create: yes yes nilfs_link: yes yes nilfs_mknod: yes yes nilfs_symlink: yes yes nilfs_mkdir: yes yes nilfs_unlink: yes yes nilfs_rmdir: yes yes nilfs_rename: yes yes nilfs_setattr: yes yes For nilfs_lookup() i_mutex is held for the parent directory, to protect it from modification. The segment construction does not modify directory inodes, so no lock is needed. nilfs_fiemap() reads the block layout on the disk, by using nilfs_bmap_lookup_contig(). This is already protected by bmap->b_sem. Signed-off-by: Andreas Rohner <andreas.rohner@gmx.net> Signed-off-by: Ryusuke Konishi <konishi.ryusuke@lab.ntt.co.jp> Signed-off-by: Andrew Morton <akpm@linux-foundation.org> Signed-off-by: Linus Torvalds <torvalds@linux-foundation.org>
2014-10-14nilfs2: improve the performance of fdatasync()Andreas Rohner
Support for fdatasync() has been implemented in NILFS2 for a long time, but whenever the corresponding inode is dirty the implementation falls back to a full-flegded sync(). Since every write operation has to update the modification time of the file, the inode will almost always be dirty and fdatasync() will fall back to sync() most of the time. But this fallback is only necessary for a change of the file size and not for a change of the various timestamps. This patch adds a new flag NILFS_I_INODE_SYNC to differentiate between those two situations. * If it is set the file size was changed and a full sync is necessary. * If it is not set then only the timestamps were updated and fdatasync() can go ahead. There is already a similar flag I_DIRTY_DATASYNC on the VFS layer with the exact same semantics. Unfortunately it cannot be used directly, because NILFS2 doesn't implement write_inode() and doesn't clear the VFS flags when inodes are written out. So the VFS writeback thread can clear I_DIRTY_DATASYNC at any time without notifying NILFS2. So I_DIRTY_DATASYNC has to be mapped onto NILFS_I_INODE_SYNC in nilfs_update_inode(). Signed-off-by: Andreas Rohner <andreas.rohner@gmx.net> Signed-off-by: Ryusuke Konishi <konishi.ryusuke@lab.ntt.co.jp> Signed-off-by: Andrew Morton <akpm@linux-foundation.org> Signed-off-by: Linus Torvalds <torvalds@linux-foundation.org>
2014-10-14nilfs2: add missing blkdev_issue_flush() to nilfs_sync_fs()Andreas Rohner
Under normal circumstances nilfs_sync_fs() writes out the super block, which causes a flush of the underlying block device. But this depends on the THE_NILFS_SB_DIRTY flag, which is only set if the pointer to the last segment crosses a segment boundary. So if only a small amount of data is written before the call to nilfs_sync_fs(), no flush of the block device occurs. In the above case an additional call to blkdev_issue_flush() is needed. To prevent unnecessary overhead, the new flag nilfs->ns_flushed_device is introduced, which is cleared whenever new logs are written and set whenever the block device is flushed. For convenience the function nilfs_flush_device() is added, which contains the above logic. Signed-off-by: Andreas Rohner <andreas.rohner@gmx.net> Signed-off-by: Ryusuke Konishi <konishi.ryusuke@lab.ntt.co.jp> Signed-off-by: Andrew Morton <akpm@linux-foundation.org> Signed-off-by: Linus Torvalds <torvalds@linux-foundation.org>
2014-09-26nilfs2: fix data loss with mmap()Andreas Rohner
This bug leads to reproducible silent data loss, despite the use of msync(), sync() and a clean unmount of the file system. It is easily reproducible with the following script: ----------------[BEGIN SCRIPT]-------------------- mkfs.nilfs2 -f /dev/sdb mount /dev/sdb /mnt dd if=/dev/zero bs=1M count=30 of=/mnt/testfile umount /mnt mount /dev/sdb /mnt CHECKSUM_BEFORE="$(md5sum /mnt/testfile)" /root/mmaptest/mmaptest /mnt/testfile 30 10 5 sync CHECKSUM_AFTER="$(md5sum /mnt/testfile)" umount /mnt mount /dev/sdb /mnt CHECKSUM_AFTER_REMOUNT="$(md5sum /mnt/testfile)" umount /mnt echo "BEFORE MMAP:\t$CHECKSUM_BEFORE" echo "AFTER MMAP:\t$CHECKSUM_AFTER" echo "AFTER REMOUNT:\t$CHECKSUM_AFTER_REMOUNT" ----------------[END SCRIPT]-------------------- The mmaptest tool looks something like this (very simplified, with error checking removed): ----------------[BEGIN mmaptest]-------------------- data = mmap(NULL, file_size - file_offset, PROT_READ | PROT_WRITE, MAP_SHARED, fd, file_offset); for (i = 0; i < write_count; ++i) { memcpy(data + i * 4096, buf, sizeof(buf)); msync(data, file_size - file_offset, MS_SYNC)) } ----------------[END mmaptest]-------------------- The output of the script looks something like this: BEFORE MMAP: 281ed1d5ae50e8419f9b978aab16de83 /mnt/testfile AFTER MMAP: 6604a1c31f10780331a6850371b3a313 /mnt/testfile AFTER REMOUNT: 281ed1d5ae50e8419f9b978aab16de83 /mnt/testfile So it is clear, that the changes done using mmap() do not survive a remount. This can be reproduced a 100% of the time. The problem was introduced in commit 136e8770cd5d ("nilfs2: fix issue of nilfs_set_page_dirty() for page at EOF boundary"). If the page was read with mpage_readpage() or mpage_readpages() for example, then it has no buffers attached to it. In that case page_has_buffers(page) in nilfs_set_page_dirty() will be false. Therefore nilfs_set_file_dirty() is never called and the pages are never collected and never written to disk. This patch fixes the problem by also calling nilfs_set_file_dirty() if the page has no buffers attached to it. [akpm@linux-foundation.org: s/PAGE_SHIFT/PAGE_CACHE_SHIFT/] Signed-off-by: Andreas Rohner <andreas.rohner@gmx.net> Tested-by: Andreas Rohner <andreas.rohner@gmx.net> Signed-off-by: Ryusuke Konishi <konishi.ryusuke@lab.ntt.co.jp> Cc: <stable@vger.kernel.org> Signed-off-by: Andrew Morton <akpm@linux-foundation.org> Signed-off-by: Linus Torvalds <torvalds@linux-foundation.org>
2014-08-11Merge branch 'for-linus' of ↵Linus Torvalds
git://git.kernel.org/pub/scm/linux/kernel/git/viro/vfs Pull vfs updates from Al Viro: "Stuff in here: - acct.c fixes and general rework of mnt_pin mechanism. That allows to go for delayed-mntput stuff, which will permit mntput() on deep stack without worrying about stack overflows - fs shutdown will happen on shallow stack. IOW, we can do Eric's umount-on-rmdir series without introducing tons of stack overflows on new mntput() call chains it introduces. - Bruce's d_splice_alias() patches - more Miklos' rename() stuff. - a couple of regression fixes (stable fodder, in the end of branch) and a fix for API idiocy in iov_iter.c. There definitely will be another pile, maybe even two. I'd like to get Eric's series in this time, but even if we miss it, it'll go right in the beginning of for-next in the next cycle - the tricky part of prereqs is in this pile" * 'for-linus' of git://git.kernel.org/pub/scm/linux/kernel/git/viro/vfs: (40 commits) fix copy_tree() regression __generic_file_write_iter(): fix handling of sync error after DIO switch iov_iter_get_pages() to passing maximal number of pages fs: mark __d_obtain_alias static dcache: d_splice_alias should detect loops exportfs: update Exporting documentation dcache: d_find_alias needn't recheck IS_ROOT && DCACHE_DISCONNECTED dcache: remove unused d_find_alias parameter dcache: d_obtain_alias callers don't all want DISCONNECTED dcache: d_splice_alias should ignore DCACHE_DISCONNECTED dcache: d_splice_alias mustn't create directory aliases dcache: close d_move race in d_splice_alias dcache: move d_splice_alias namei: trivial fix to vfs_rename_dir comment VFS: allow ->d_manage() to declare -EISDIR in rcu_walk mode. cifs: support RENAME_NOREPLACE hostfs: support rename flags shmem: support RENAME_EXCHANGE shmem: support RENAME_NOREPLACE btrfs: add RENAME_NOREPLACE ...
2014-08-08nilfs2: integrate sysfs support into driverVyacheslav Dubeyko
This patch integrates creation of sysfs groups and attributes into NILFS file system driver. It was found the issue with nilfs_sysfs_{create/delete}_snapshot_group functions by Michael L Semon <mlsemon35@gmail.com> in the first version of the patch: BUG: sleeping function called from invalid context at kernel/locking/mutex.c:579 in_atomic(): 1, irqs_disabled(): 0, pid: 32676, name: umount.nilfs2 2 locks held by umount.nilfs2/32676: #0: (&type->s_umount_key#21){++++..}, at: [<790c18e2>] deactivate_super+0x37/0x58 #1: (&(&nilfs->ns_cptree_lock)->rlock){+.+...}, at: [<791bf659>] nilfs_put_root+0x23/0x5a Preemption disabled at:[<791bf659>] nilfs_put_root+0x23/0x5a CPU: 0 PID: 32676 Comm: umount.nilfs2 Not tainted 3.14.0+ #2 Hardware name: Dell Computer Corporation Dimension 2350/07W080, BIOS A01 12/17/2002 Call Trace: dump_stack+0x4b/0x75 __might_sleep+0x111/0x16f mutex_lock_nested+0x1e/0x3ad kernfs_remove+0x12/0x26 sysfs_remove_dir+0x3d/0x62 kobject_del+0x13/0x38 nilfs_sysfs_delete_snapshot_group+0xb/0xd nilfs_put_root+0x2a/0x5a nilfs_detach_log_writer+0x1ab/0x2c1 nilfs_put_super+0x13/0x68 generic_shutdown_super+0x60/0xd1 kill_block_super+0x1d/0x60 deactivate_locked_super+0x22/0x3f deactivate_super+0x3e/0x58 mntput_no_expire+0xe2/0x141 SyS_oldumount+0x70/0xa5 syscall_call+0x7/0xb The reason of the issue was placement of nilfs_sysfs_{create/delete}_snapshot_group() call under nilfs->ns_cptree_lock protection. But this protection is unnecessary and wrong solution. The second version of the patch fixes this issue. [fengguang.wu@intel.com: nilfs_sysfs_create_mounted_snapshots_group can be static] Reported-by: Michael L. Semon <mlsemon35@gmail.com> Signed-off-by: Vyacheslav Dubeyko <Vyacheslav.Dubeyko@hgst.com> Cc: Vyacheslav Dubeyko <slava@dubeyko.com> Cc: Ryusuke Konishi <konishi.ryusuke@lab.ntt.co.jp> Tested-by: Michael L. Semon <mlsemon35@gmail.com> Signed-off-by: Fengguang Wu <fengguang.wu@intel.com> Signed-off-by: Andrew Morton <akpm@linux-foundation.org> Signed-off-by: Linus Torvalds <torvalds@linux-foundation.org>
2014-08-08nilfs2: add /sys/fs/nilfs2/<device>/mounted_snapshots/<snapshot> groupVyacheslav Dubeyko
This patch adds creation of <snapshot> group for every mounted snapshot in /sys/fs/nilfs2/<device>/mounted_snapshots group. The group contains details about mounted snapshot: (1) inodes_count - show number of inodes for snapshot. (2) blocks_count - show number of blocks for snapshot. Signed-off-by: Vyacheslav Dubeyko <Vyacheslav.Dubeyko@hgst.com> Cc: Vyacheslav Dubeyko <slava@dubeyko.com> Cc: Ryusuke Konishi <konishi.ryusuke@lab.ntt.co.jp> Cc: Michael L. Semon <mlsemon35@gmail.com> Signed-off-by: Andrew Morton <akpm@linux-foundation.org> Signed-off-by: Linus Torvalds <torvalds@linux-foundation.org>
2014-08-08nilfs2: add /sys/fs/nilfs2/<device>/mounted_snapshots groupVyacheslav Dubeyko
This patch adds creation of /sys/fs/nilfs2/<device>/mounted_snapshots group. The mounted_snapshots group contains group for every mounted snapshot. Signed-off-by: Vyacheslav Dubeyko <Vyacheslav.Dubeyko@hgst.com> Cc: Vyacheslav Dubeyko <slava@dubeyko.com> Cc: Ryusuke Konishi <konishi.ryusuke@lab.ntt.co.jp> Cc: Michael L. Semon <mlsemon35@gmail.com> Signed-off-by: Andrew Morton <akpm@linux-foundation.org> Signed-off-by: Linus Torvalds <torvalds@linux-foundation.org>
2014-08-08nilfs2: add /sys/fs/nilfs2/<device>/checkpoints groupVyacheslav Dubeyko
This patch adds creation of /sys/fs/nilfs2/<device>/checkpoints group. The checkpoints group contains attributes that describe details about volume's checkpoints: (1) checkpoints_number - show number of checkpoints on volume. (2) snapshots_number - show number of snapshots on volume. (3) last_seg_checkpoint - show checkpoint number of the latest segment. (4) next_checkpoint - show next checkpoint number. Signed-off-by: Vyacheslav Dubeyko <Vyacheslav.Dubeyko@hgst.com> Cc: Vyacheslav Dubeyko <slava@dubeyko.com> Cc: Ryusuke Konishi <konishi.ryusuke@lab.ntt.co.jp> Cc: Michael L. Semon <mlsemon35@gmail.com> Signed-off-by: Andrew Morton <akpm@linux-foundation.org> Signed-off-by: Linus Torvalds <torvalds@linux-foundation.org>
2014-08-08nilfs2: add /sys/fs/nilfs2/<device>/segments groupVyacheslav Dubeyko
This patch adds creation of /sys/fs/nilfs2/<device>/segments group. The segments group contains attributes that describe details about volume's segments: (1) segments_number - show number of segments on volume. (2) blocks_per_segment - show number of blocks in segment. (3) clean_segments - show count of clean segments. (4) dirty_segments - show count of dirty segments. Signed-off-by: Vyacheslav Dubeyko <Vyacheslav.Dubeyko@hgst.com> Cc: Vyacheslav Dubeyko <slava@dubeyko.com> Cc: Ryusuke Konishi <konishi.ryusuke@lab.ntt.co.jp> Cc: Michael L. Semon <mlsemon35@gmail.com> Signed-off-by: Andrew Morton <akpm@linux-foundation.org> Signed-off-by: Linus Torvalds <torvalds@linux-foundation.org>
2014-08-08nilfs2: add /sys/fs/nilfs2/<device>/segctor groupVyacheslav Dubeyko
This patch adds creation of /sys/fs/nilfs2/<device>/segctor group. The segctor group contains attributes that describe segctor thread activity details: (1) last_pseg_block - show start block number of the latest segment. (2) last_seg_sequence - show sequence value of the latest segment. (3) last_seg_checkpoint - show checkpoint number of the latest segment. (4) current_seg_sequence - show segment sequence counter. (5) current_last_full_seg - show index number of the latest full segment. (6) next_full_seg - show index number of the full segment index to be used next. (7) next_pseg_offset - show offset of next partial segment in the current full segment. (8) next_checkpoint - show next checkpoint number. (9) last_seg_write_time - show write time of the last segment in human-readable format. (10) last_seg_write_time_secs - show write time of the last segment in seconds. (11) last_nongc_write_time - show write time of the last segment not for cleaner operation in human-readable format. (12) last_nongc_write_time_secs - show write time of the last segment not for cleaner operation in seconds. (13) dirty_data_blocks_count - show number of dirty data blocks. Signed-off-by: Vyacheslav Dubeyko <Vyacheslav.Dubeyko@hgst.com> Cc: Vyacheslav Dubeyko <slava@dubeyko.com> Cc: Ryusuke Konishi <konishi.ryusuke@lab.ntt.co.jp> Cc: Michael L. Semon <mlsemon35@gmail.com> Signed-off-by: Andrew Morton <akpm@linux-foundation.org> Signed-off-by: Linus Torvalds <torvalds@linux-foundation.org>
2014-08-08nilfs2: add /sys/fs/nilfs2/<device>/superblock groupVyacheslav Dubeyko
This patch adds creation of /sys/fs/nilfs2/<device>/superblock group. The superblock group contains attributes that describe superblock's details: (1) sb_write_time - show previous write time of super block in human-readable format. (2) sb_write_time_secs - show previous write time of super block in seconds. (3) sb_write_count - show write count of super block. (4) sb_update_frequency - show/set interval of periodical update of superblock (in seconds). You can set preferable frequency of superblock update by command: echo <value> > /sys/fs/nilfs2/<device>/superblock/sb_update_frequency Signed-off-by: Vyacheslav Dubeyko <Vyacheslav.Dubeyko@hgst.com> Cc: Vyacheslav Dubeyko <slava@dubeyko.com> Cc: Ryusuke Konishi <konishi.ryusuke@lab.ntt.co.jp> Cc: Michael L. Semon <mlsemon35@gmail.com> Signed-off-by: Andrew Morton <akpm@linux-foundation.org> Signed-off-by: Linus Torvalds <torvalds@linux-foundation.org>
2014-08-08nilfs2: add /sys/fs/nilfs2/<device> groupVyacheslav Dubeyko
This patch adds creation of /sys/fs/nilfs2/<device> group. The <device> group contains attributes that describe file system partition's details: (1) revision - show NILFS file system revision. (2) blocksize - show volume block size in bytes. (3) device_size - show volume size in bytes. (4) free_blocks - show count of free blocks on volume. (5) uuid - show volume's UUID. (6) volume_name - show volume's name. Signed-off-by: Vyacheslav Dubeyko <Vyacheslav.Dubeyko@hgst.com> Cc: Vyacheslav Dubeyko <slava@dubeyko.com> Cc: Ryusuke Konishi <konishi.ryusuke@lab.ntt.co.jp> Cc: Michael L. Semon <mlsemon35@gmail.com> Signed-off-by: Andrew Morton <akpm@linux-foundation.org> Signed-off-by: Linus Torvalds <torvalds@linux-foundation.org>
2014-08-08nilfs2: add /sys/fs/nilfs2/features groupVyacheslav Dubeyko
This patchset implements creation of sysfs groups and attributes with the purpose to show NILFS2 volume details, internal state of the driver and to manage internal state of NILFS2 driver. Sysfs is a virtual file system that exports information about devices and drivers from the kernel device model to user space, and is also used for configuration. NILFS2 is a complex file system that has segctor thread, GC thread, checkpoint/snapshot model and so on. Sysfs namespace provides native and easy way for: (1) getting info and statistics about volume state; (2) getting info and configuration of internal subsystems (segctor thread); (3) snapshots management. Suggested patchset provides basis for managing segctor thread behaviour and manipulation by snapshots. Currently, it informs only about segctor thread's internal parameters and about mounted snapshots. But sysfs interface can provide easy and simple way for deep management of segctor thread and snapshots. This patchset provides opportunity to manage interval of periodical update of superblock (in seconds). Default value is 10 seconds. Now a user can increase this value by means of nilfs2/<device>/superblock/sb_update_frequency attribute in the case of necessity. Also the patchset provides opportunity to get information easily about key volumes's parameters (free blocks, superblock write count, superblock update frequency, latest segment info, dirty data blocks count, count of clean segments, count of dirty segments and so on) in real time manner. Such information can be used in scripts for subtle management of filesystem. Implemented functionality creates such groups: (1) /sys/fs/nilfs2 - root group (2) /sys/fs/nilfs2/features - group contains attributes that describe NILFS file system driver features (3) /sys/fs/nilfs2/<device> - group contains attributes that describe file system partition's details (4) /sys/fs/nilfs2/<device>/superblock - group contains attributes that describe superblock's details (5) /sys/fs/nilfs2/<device>/segctor - group contains attributes that describe segctor thread activity details (6) /sys/fs/nilfs2/<device>/segments - group contains attributes that describe details about volume's segments (7) /sys/fs/nilfs2/<device>/checkpoints - group contains attributes that describe details about volume's checkpoints (8) /sys/fs/nilfs2/<device>/mounted_snapshots - group contains group for every mounted snapshot (9) /sys/fs/nilfs2/<device>/mounted_snapshots/<snapshot> - group contains details about mounted snapshot This patch (of 9): This patch adds code of creation /sys/fs/nilfs2 group and /sys/fs/nilfs2/features group. The features group contains attributes that describe NILFS file system driver features: (1) revision - show current revision of NILFS file system driver. There are two formats of timestamp output - seconds and human-readable format. Every showed timestamp has two sysfs files (time-<xxx> and time-<xxx>-secs). One sysfs file (time-<xxx>) shows time in human-readable format. Another sysfs file (time-<xxx>-secs) shows time in seconds. It was reported by Michael Semon that timestamp output in human-readable format should be changed from "2014-4-12 14:5:38" to "2014-04-12 14:05:38". Second version of the patch fixes this issue. Reported-by: Michael L. Semon <mlsemon35@gmail.com> Signed-off-by: Vyacheslav Dubeyko <Vyacheslav.Dubeyko@hgst.com> Cc: Vyacheslav Dubeyko <slava@dubeyko.com> Cc: Ryusuke Konishi <konishi.ryusuke@lab.ntt.co.jp> Signed-off-by: Andrew Morton <akpm@linux-foundation.org> Signed-off-by: Linus Torvalds <torvalds@linux-foundation.org>
2014-08-07dcache: d_obtain_alias callers don't all want DISCONNECTEDJ. Bruce Fields
There are a few d_obtain_alias callers that are using it to get the root of a filesystem which may already have an alias somewhere else. This is not the same as the filehandle-lookup case, and none of them actually need DCACHE_DISCONNECTED set. It isn't really a serious problem, but it would really be clearer if we reserved DCACHE_DISCONNECTED for those cases where it's actually needed. In the btrfs case this was causing a spurious printk from nfsd/nfsfh.c:fh_verify when it found an unexpected DCACHE_DISCONNECTED dentry. Josef worked around this by unsetting DCACHE_DISCONNECTED manually in 3a0dfa6a12e "Btrfs: unset DCACHE_DISCONNECTED when mounting default subvol", and this replaces that workaround. Cc: Josef Bacik <jbacik@fb.com> Signed-off-by: J. Bruce Fields <bfields@redhat.com> Signed-off-by: Al Viro <viro@zeniv.linux.org.uk>
2014-05-06write_iter variants of {__,}generic_file_aio_write()Al Viro
2014-05-06switch simple generic_file_aio_read() users to ->read_iter()Al Viro
2014-05-06switch {__,}blockdev_direct_IO() to iov_iterAl Viro
2014-05-06get rid of pointless iov_length() in ->direct_IO()Al Viro
all callers have iov_length(iter->iov, iter->nr_segs) == iov_iter_count(iter) Signed-off-by: Al Viro <viro@zeniv.linux.org.uk>
2014-05-06pass iov_iter to ->direct_IO()Al Viro
unmodified, for now Signed-off-by: Al Viro <viro@zeniv.linux.org.uk>
2014-04-07mm: implement ->map_pages for page cacheKirill A. Shutemov
filemap_map_pages() is generic implementation of ->map_pages() for filesystems who uses page cache. It should be safe to use filemap_map_pages() for ->map_pages() if filesystem use filemap_fault() for ->fault(). Signed-off-by: Kirill A. Shutemov <kirill.shutemov@linux.intel.com> Acked-by: Linus Torvalds <torvalds@linux-foundation.org> Cc: Mel Gorman <mgorman@suse.de> Cc: Rik van Riel <riel@redhat.com> Cc: Andi Kleen <ak@linux.intel.com> Cc: Matthew Wilcox <matthew.r.wilcox@intel.com> Cc: Dave Hansen <dave.hansen@linux.intel.com> Cc: Alexander Viro <viro@zeniv.linux.org.uk> Cc: Dave Chinner <david@fromorbit.com> Cc: Ning Qu <quning@gmail.com> Cc: Hugh Dickins <hughd@google.com> Signed-off-by: Andrew Morton <akpm@linux-foundation.org> Signed-off-by: Linus Torvalds <torvalds@linux-foundation.org>
2014-04-04Merge tag 'ext4_for_linus' of ↵Linus Torvalds
git://git.kernel.org/pub/scm/linux/kernel/git/tytso/ext4 Pull ext4 updates from Ted Ts'o: "Major changes for 3.14 include support for the newly added ZERO_RANGE and COLLAPSE_RANGE fallocate operations, and scalability improvements in the jbd2 layer and in xattr handling when the extended attributes spill over into an external block. Other than that, the usual clean ups and minor bug fixes" * tag 'ext4_for_linus' of git://git.kernel.org/pub/scm/linux/kernel/git/tytso/ext4: (42 commits) ext4: fix premature freeing of partial clusters split across leaf blocks ext4: remove unneeded test of ret variable ext4: fix comment typo ext4: make ext4_block_zero_page_range static ext4: atomically set inode->i_flags in ext4_set_inode_flags() ext4: optimize Hurd tests when reading/writing inodes ext4: kill i_version support for Hurd-castrated file systems ext4: each filesystem creates and uses its own mb_cache fs/mbcache.c: doucple the locking of local from global data fs/mbcache.c: change block and index hash chain to hlist_bl_node ext4: Introduce FALLOC_FL_ZERO_RANGE flag for fallocate ext4: refactor ext4_fallocate code ext4: Update inode i_size after the preallocation ext4: fix partial cluster handling for bigalloc file systems ext4: delete path dealloc code in ext4_ext_handle_uninitialized_extents ext4: only call sync_filesystm() when remounting read-only fs: push sync_filesystem() down to the file system's remount_fs() jbd2: improve error messages for inconsistent journal heads jbd2: minimize region locked by j_list_lock in jbd2_journal_forget() jbd2: minimize region locked by j_list_lock in journal_get_create_access() ...
2014-04-03nilfs2: verify metadata sizes read from diskRyusuke Konishi
Add code to check sizes of on-disk data of metadata files such as inode size, segment usage size, DAT entry size, and checkpoint size. Although these sizes are read from disk, the current implementation doesn't check them. If these sizes are not sane on disk, it can cause out-of-range access to metadata or memory access overrun on metadata block buffers due to overflow in sundry calculations. Both lower limit and upper limit of metadata sizes are verified to prevent these issues. Signed-off-by: Ryusuke Konishi <konishi.ryusuke@lab.ntt.co.jp> Cc: Andreas Rohner <andreas.rohner@gmx.net> Signed-off-by: Andrew Morton <akpm@linux-foundation.org> Signed-off-by: Linus Torvalds <torvalds@linux-foundation.org>
2014-04-03nilfs2: add FITRIM ioctl support for nilfs2Andreas Rohner
Add support for the FITRIM ioctl, which enables user space tools to issue TRIM/DISCARD requests to the underlying device. Every clean segment within the specified range will be discarded. Signed-off-by: Andreas Rohner <andreas.rohner@gmx.net> Signed-off-by: Ryusuke Konishi <konishi.ryusuke@lab.ntt.co.jp> Signed-off-by: Andrew Morton <akpm@linux-foundation.org> Signed-off-by: Linus Torvalds <torvalds@linux-foundation.org>
2014-04-03nilfs2: add nilfs_sufile_trim_fs to trim clean segsAndreas Rohner
Add nilfs_sufile_trim_fs(), which takes an fstrim_range structure and calls blkdev_issue_discard for every clean segment in the specified range. The range is truncated to file system block boundaries. Signed-off-by: Andreas Rohner <andreas.rohner@gmx.net> Signed-off-by: Ryusuke Konishi <konishi.ryusuke@lab.ntt.co.jp> Signed-off-by: Andrew Morton <akpm@linux-foundation.org> Signed-off-by: Linus Torvalds <torvalds@linux-foundation.org>
2014-04-03nilfs2: implementation of NILFS_IOCTL_SET_SUINFO ioctlAndreas Rohner
With this ioctl the segment usage entries in the SUFILE can be updated from userspace. This is useful, because it allows the userspace GC to modify and update segment usage entries for specific segments, which enables it to avoid unnecessary write operations. If a segment needs to be cleaned, but there is no or very little reclaimable space in it, the cleaning operation basically degrades to a useless moving operation. In the end the only thing that changes is the location of the data and a timestamp in the segment usage information. With this ioctl the GC can skip the cleaning and update the segment usage entries directly instead. This is basically a shortcut to cleaning the segment. It is still necessary to read the segment summary information, but the writing of the live blocks can be skipped if it's not worth it. [konishi.ryusuke@lab.ntt.co.jp: add description of NILFS_IOCTL_SET_SUINFO ioctl] Signed-off-by: Andreas Rohner <andreas.rohner@gmx.net> Signed-off-by: Ryusuke Konishi <konishi.ryusuke@lab.ntt.co.jp> Signed-off-by: Andrew Morton <akpm@linux-foundation.org> Signed-off-by: Linus Torvalds <torvalds@linux-foundation.org>
2014-04-03nilfs2: add nilfs_sufile_set_suinfo to update segment usageAndreas Rohner
Introduce nilfs_sufile_set_suinfo(), which expects an array of nilfs_suinfo_update structures and updates the segment usage information accordingly. This is basically a helper function for the newly introduced NILFS_IOCTL_SET_SUINFO ioctl. [konishi.ryusuke@lab.ntt.co.jp: use put_bh() instead of brelse() because we know bh != NULL] Signed-off-by: Andreas Rohner <andreas.rohner@gmx.net> Signed-off-by: Ryusuke Konishi <konishi.ryusuke@lab.ntt.co.jp> Signed-off-by: Andrew Morton <akpm@linux-foundation.org> Signed-off-by: Linus Torvalds <torvalds@linux-foundation.org>
2014-04-03mm + fs: store shadow entries in page cacheJohannes Weiner
Reclaim will be leaving shadow entries in the page cache radix tree upon evicting the real page. As those pages are found from the LRU, an iput() can lead to the inode being freed concurrently. At this point, reclaim must no longer install shadow pages because the inode freeing code needs to ensure the page tree is really empty. Add an address_space flag, AS_EXITING, that the inode freeing code sets under the tree lock before doing the final truncate. Reclaim will check for this flag before installing shadow pages. Signed-off-by: Johannes Weiner <hannes@cmpxchg.org> Reviewed-by: Rik van Riel <riel@redhat.com> Reviewed-by: Minchan Kim <minchan@kernel.org> Cc: Andrea Arcangeli <aarcange@redhat.com> Cc: Bob Liu <bob.liu@oracle.com> Cc: Christoph Hellwig <hch@infradead.org> Cc: Dave Chinner <david@fromorbit.com> Cc: Greg Thelen <gthelen@google.com> Cc: Hugh Dickins <hughd@google.com> Cc: Jan Kara <jack@suse.cz> Cc: KOSAKI Motohiro <kosaki.motohiro@jp.fujitsu.com> Cc: Luigi Semenzato <semenzato@google.com> Cc: Mel Gorman <mgorman@suse.de> Cc: Metin Doslu <metin@citusdata.com> Cc: Michel Lespinasse <walken@google.com> Cc: Ozgun Erdogan <ozgun@citusdata.com> Cc: Peter Zijlstra <peterz@infradead.org> Cc: Roman Gushchin <klamm@yandex-team.ru> Cc: Ryan Mallon <rmallon@gmail.com> Cc: Tejun Heo <tj@kernel.org> Cc: Vlastimil Babka <vbabka@suse.cz> Signed-off-by: Andrew Morton <akpm@linux-foundation.org> Signed-off-by: Linus Torvalds <torvalds@linux-foundation.org>
2014-03-13fs: push sync_filesystem() down to the file system's remount_fs()Theodore Ts'o
Previously, the no-op "mount -o mount /dev/xxx" operation when the file system is already mounted read-write causes an implied, unconditional syncfs(). This seems pretty stupid, and it's certainly documented or guaraunteed to do this, nor is it particularly useful, except in the case where the file system was mounted rw and is getting remounted read-only. However, it's possible that there might be some file systems that are actually depending on this behavior. In most file systems, it's probably fine to only call sync_filesystem() when transitioning from read-write to read-only, and there are some file systems where this is not needed at all (for example, for a pseudo-filesystem or something like romfs). Signed-off-by: "Theodore Ts'o" <tytso@mit.edu> Cc: linux-fsdevel@vger.kernel.org Cc: Christoph Hellwig <hch@infradead.org> Cc: Artem Bityutskiy <dedekind1@gmail.com> Cc: Adrian Hunter <adrian.hunter@intel.com> Cc: Evgeniy Dushistov <dushistov@mail.ru> Cc: Jan Kara <jack@suse.cz> Cc: OGAWA Hirofumi <hirofumi@mail.parknet.co.jp> Cc: Anders Larsen <al@alarsen.net> Cc: Phillip Lougher <phillip@squashfs.org.uk> Cc: Kees Cook <keescook@chromium.org> Cc: Mikulas Patocka <mikulas@artax.karlin.mff.cuni.cz> Cc: Petr Vandrovec <petr@vandrovec.name> Cc: xfs@oss.sgi.com Cc: linux-btrfs@vger.kernel.org Cc: linux-cifs@vger.kernel.org Cc: samba-technical@lists.samba.org Cc: codalist@coda.cs.cmu.edu Cc: linux-ext4@vger.kernel.org Cc: linux-f2fs-devel@lists.sourceforge.net Cc: fuse-devel@lists.sourceforge.net Cc: cluster-devel@redhat.com Cc: linux-mtd@lists.infradead.org Cc: jfs-discussion@lists.sourceforge.net Cc: linux-nfs@vger.kernel.org Cc: linux-nilfs@vger.kernel.org Cc: linux-ntfs-dev@lists.sourceforge.net Cc: ocfs2-devel@oss.oracle.com Cc: reiserfs-devel@vger.kernel.org
2014-01-30Merge branch 'for-3.14/core' of git://git.kernel.dk/linux-blockLinus Torvalds
Pull core block IO changes from Jens Axboe: "The major piece in here is the immutable bio_ve series from Kent, the rest is fairly minor. It was supposed to go in last round, but various issues pushed it to this release instead. The pull request contains: - Various smaller blk-mq fixes from different folks. Nothing major here, just minor fixes and cleanups. - Fix for a memory leak in the error path in the block ioctl code from Christian Engelmayer. - Header export fix from CaiZhiyong. - Finally the immutable biovec changes from Kent Overstreet. This enables some nice future work on making arbitrarily sized bios possible, and splitting more efficient. Related fixes to immutable bio_vecs: - dm-cache immutable fixup from Mike Snitzer. - btrfs immutable fixup from Muthu Kumar. - bio-integrity fix from Nic Bellinger, which is also going to stable" * 'for-3.14/core' of git://git.kernel.dk/linux-block: (44 commits) xtensa: fixup simdisk driver to work with immutable bio_vecs block/blk-mq-cpu.c: use hotcpu_notifier() blk-mq: for_each_* macro correctness block: Fix memory leak in rw_copy_check_uvector() handling bio-integrity: Fix bio_integrity_verify segment start bug block: remove unrelated header files and export symbol blk-mq: uses page->list incorrectly blk-mq: use __smp_call_function_single directly btrfs: fix missing increment of bi_remaining Revert "block: Warn and free bio if bi_end_io is not set" block: Warn and free bio if bi_end_io is not set blk-mq: fix initializing request's start time block: blk-mq: don't export blk_mq_free_queue() block: blk-mq: make blk_sync_queue support mq block: blk-mq: support draining mq queue dm cache: increment bi_remaining when bi_end_io is restored block: fixup for generic bio chaining block: Really silence spurious compiler warnings block: Silence spurious compiler warnings block: Kill bio_pair_split() ...
2014-01-23nilfs2: add comments for ioctlsVyacheslav Dubeyko
Add comments for ioctls in fs/nilfs2/ioctl.c file and describe NILFS2 specific ioctls in Documentation/filesystems/nilfs2.txt. Signed-off-by: Vyacheslav Dubeyko <slava@dubeyko.com> Reviewed-by: Ryusuke Konishi <konishi.ryusuke@lab.ntt.co.jp> Cc: Wenliang Fan <fanwlexca@gmail.com> Signed-off-by: Andrew Morton <akpm@linux-foundation.org> Signed-off-by: Linus Torvalds <torvalds@linux-foundation.org>
2014-01-23fs/nilfs2: fix integer overflow in nilfs_ioctl_wrap_copy()Wenliang Fan
The local variable 'pos' in nilfs_ioctl_wrap_copy function can overflow if a large number was passed to argv->v_index from userspace and the sum of argv->v_index and argv->v_nmembs exceeds the maximum value of __u64 type integer (= ~(__u64)0 = 18446744073709551615). Here, argv->v_index is a 64-bit width argument to specify the start position of target data items (such as segment number, checkpoint number, or virtual block address of nilfs), and argv->v_nmembs gives the total number of the items that userland programs (such as lssu, lscp, or cleanerd) want to get information about, which also gives the maximum element count of argv->v_base[] array. nilfs_ioctl_wrap_copy() calls dofunc() repeatedly and increments the position variable 'pos' at the end of each iteration if dofunc() itself didn't update 'pos': if (pos == ppos) pos += n; This patch prevents the overflow here by rejecting pairs of a start position (argv->v_index) and a total count (argv->v_nmembs) which leads to the overflow. [konishi.ryusuke@lab.ntt.co.jp: fix signedness issue] Signed-off-by: Wenliang Fan <fanwlexca@gmail.com> Cc: Vyacheslav Dubeyko <slava@dubeyko.com> Signed-off-by: Ryusuke Konishi <konishi.ryusuke@lab.ntt.co.jp> Signed-off-by: Andrew Morton <akpm@linux-foundation.org> Signed-off-by: Linus Torvalds <torvalds@linux-foundation.org>
2014-01-15nilfs2: fix segctor bug that causes file system corruptionAndreas Rohner
There is a bug in the function nilfs_segctor_collect, which results in active data being written to a segment, that is marked as clean. It is possible, that this segment is selected for a later segment construction, whereby the old data is overwritten. The problem shows itself with the following kernel log message: nilfs_sufile_do_cancel_free: segment 6533 must be clean Usually a few hours later the file system gets corrupted: NILFS: bad btree node (blocknr=8748107): level = 0, flags = 0x0, nchildren = 0 NILFS error (device sdc1): nilfs_bmap_last_key: broken bmap (inode number=114660) The issue can be reproduced with a file system that is nearly full and with the cleaner running, while some IO intensive task is running. Although it is quite hard to reproduce. This is what happens: 1. The cleaner starts the segment construction 2. nilfs_segctor_collect is called 3. sc_stage is on NILFS_ST_SUFILE and segments are freed 4. sc_stage is on NILFS_ST_DAT current segment is full 5. nilfs_segctor_extend_segments is called, which allocates a new segment 6. The new segment is one of the segments freed in step 3 7. nilfs_sufile_cancel_freev is called and produces an error message 8. Loop around and the collection starts again 9. sc_stage is on NILFS_ST_SUFILE and segments are freed including the newly allocated segment, which will contain active data and can be allocated at a later time 10. A few hours later another segment construction allocates the segment and causes file system corruption This can be prevented by simply reordering the statements. If nilfs_sufile_cancel_freev is called before nilfs_segctor_extend_segments the freed segments are marked as dirty and cannot be allocated any more. Signed-off-by: Andreas Rohner <andreas.rohner@gmx.net> Reviewed-by: Ryusuke Konishi <konishi.ryusuke@lab.ntt.co.jp> Tested-by: Andreas Rohner <andreas.rohner@gmx.net> Signed-off-by: Ryusuke Konishi <konishi.ryusuke@lab.ntt.co.jp> Cc: <stable@vger.kernel.org> Signed-off-by: Andrew Morton <akpm@linux-foundation.org> Signed-off-by: Linus Torvalds <torvalds@linux-foundation.org>
2013-11-23block: Abstract out bvec iteratorKent Overstreet
Immutable biovecs are going to require an explicit iterator. To implement immutable bvecs, a later patch is going to add a bi_bvec_done member to this struct; for now, this patch effectively just renames things. Signed-off-by: Kent Overstreet <kmo@daterainc.com> Cc: Jens Axboe <axboe@kernel.dk> Cc: Geert Uytterhoeven <geert@linux-m68k.org> Cc: Benjamin Herrenschmidt <benh@kernel.crashing.org> Cc: Paul Mackerras <paulus@samba.org> Cc: "Ed L. Cashin" <ecashin@coraid.com> Cc: Nick Piggin <npiggin@kernel.dk> Cc: Lars Ellenberg <drbd-dev@lists.linbit.com> Cc: Jiri Kosina <jkosina@suse.cz> Cc: Matthew Wilcox <willy@linux.intel.com> Cc: Geoff Levand <geoff@infradead.org> Cc: Yehuda Sadeh <yehuda@inktank.com> Cc: Sage Weil <sage@inktank.com> Cc: Alex Elder <elder@inktank.com> Cc: ceph-devel@vger.kernel.org Cc: Joshua Morris <josh.h.morris@us.ibm.com> Cc: Philip Kelleher <pjk1939@linux.vnet.ibm.com> Cc: Rusty Russell <rusty@rustcorp.com.au> Cc: "Michael S. Tsirkin" <mst@redhat.com> Cc: Konrad Rzeszutek Wilk <konrad.wilk@oracle.com> Cc: Jeremy Fitzhardinge <jeremy@goop.org> Cc: Neil Brown <neilb@suse.de> Cc: Alasdair Kergon <agk@redhat.com> Cc: Mike Snitzer <snitzer@redhat.com> Cc: dm-devel@redhat.com Cc: Martin Schwidefsky <schwidefsky@de.ibm.com> Cc: Heiko Carstens <heiko.carstens@de.ibm.com> Cc: linux390@de.ibm.com Cc: Boaz Harrosh <bharrosh@panasas.com> Cc: Benny Halevy <bhalevy@tonian.com> Cc: "James E.J. Bottomley" <JBottomley@parallels.com> Cc: Greg Kroah-Hartman <gregkh@linuxfoundation.org> Cc: "Nicholas A. Bellinger" <nab@linux-iscsi.org> Cc: Alexander Viro <viro@zeniv.linux.org.uk> Cc: Chris Mason <chris.mason@fusionio.com> Cc: "Theodore Ts'o" <tytso@mit.edu> Cc: Andreas Dilger <adilger.kernel@dilger.ca> Cc: Jaegeuk Kim <jaegeuk.kim@samsung.com> Cc: Steven Whitehouse <swhiteho@redhat.com> Cc: Dave Kleikamp <shaggy@kernel.org> Cc: Joern Engel <joern@logfs.org> Cc: Prasad Joshi <prasadjoshi.linux@gmail.com> Cc: Trond Myklebust <Trond.Myklebust@netapp.com> Cc: KONISHI Ryusuke <konishi.ryusuke@lab.ntt.co.jp> Cc: Mark Fasheh <mfasheh@suse.com> Cc: Joel Becker <jlbec@evilplan.org> Cc: Ben Myers <bpm@sgi.com> Cc: xfs@oss.sgi.com Cc: Steven Rostedt <rostedt@goodmis.org> Cc: Frederic Weisbecker <fweisbec@gmail.com> Cc: Ingo Molnar <mingo@redhat.com> Cc: Len Brown <len.brown@intel.com> Cc: Pavel Machek <pavel@ucw.cz> Cc: "Rafael J. Wysocki" <rjw@sisk.pl> Cc: Herton Ronaldo Krzesinski <herton.krzesinski@canonical.com> Cc: Ben Hutchings <ben@decadent.org.uk> Cc: Andrew Morton <akpm@linux-foundation.org> Cc: Guo Chao <yan@linux.vnet.ibm.com> Cc: Tejun Heo <tj@kernel.org> Cc: Asai Thambi S P <asamymuthupa@micron.com> Cc: Selvan Mani <smani@micron.com> Cc: Sam Bradshaw <sbradshaw@micron.com> Cc: Wei Yongjun <yongjun_wei@trendmicro.com.cn> Cc: "Roger Pau Monné" <roger.pau@citrix.com> Cc: Jan Beulich <jbeulich@suse.com> Cc: Stefano Stabellini <stefano.stabellini@eu.citrix.com> Cc: Ian Campbell <Ian.Campbell@citrix.com> Cc: Sebastian Ott <sebott@linux.vnet.ibm.com> Cc: Christian Borntraeger <borntraeger@de.ibm.com> Cc: Minchan Kim <minchan@kernel.org> Cc: Jiang Liu <jiang.liu@huawei.com> Cc: Nitin Gupta <ngupta@vflare.org> Cc: Jerome Marchand <jmarchand@redhat.com> Cc: Joe Perches <joe@perches.com> Cc: Peng Tao <tao.peng@emc.com> Cc: Andy Adamson <andros@netapp.com> Cc: fanchaoting <fanchaoting@cn.fujitsu.com> Cc: Jie Liu <jeff.liu@oracle.com> Cc: Sunil Mushran <sunil.mushran@gmail.com> Cc: "Martin K. Petersen" <martin.petersen@oracle.com> Cc: Namjae Jeon <namjae.jeon@samsung.com> Cc: Pankaj Kumar <pankaj.km@samsung.com> Cc: Dan Magenheimer <dan.magenheimer@oracle.com> Cc: Mel Gorman <mgorman@suse.de>6
2013-09-30nilfs2: fix issue with race condition of competition between segments for ↵Vyacheslav Dubeyko
dirty blocks Many NILFS2 users were reported about strange file system corruption (for example): NILFS: bad btree node (blocknr=185027): level = 0, flags = 0x0, nchildren = 768 NILFS error (device sda4): nilfs_bmap_last_key: broken bmap (inode number=11540) But such error messages are consequence of file system's issue that takes place more earlier. Fortunately, Jerome Poulin <jeromepoulin@gmail.com> and Anton Eliasson <devel@antoneliasson.se> were reported about another issue not so recently. These reports describe the issue with segctor thread's crash: BUG: unable to handle kernel paging request at 0000000000004c83 IP: nilfs_end_page_io+0x12/0xd0 [nilfs2] Call Trace: nilfs_segctor_do_construct+0xf25/0x1b20 [nilfs2] nilfs_segctor_construct+0x17b/0x290 [nilfs2] nilfs_segctor_thread+0x122/0x3b0 [nilfs2] kthread+0xc0/0xd0 ret_from_fork+0x7c/0xb0 These two issues have one reason. This reason can raise third issue too. Third issue results in hanging of segctor thread with eating of 100% CPU. REPRODUCING PATH: One of the possible way or the issue reproducing was described by Jermoe me Poulin <jeromepoulin@gmail.com>: 1. init S to get to single user mode. 2. sysrq+E to make sure only my shell is running 3. start network-manager to get my wifi connection up 4. login as root and launch "screen" 5. cd /boot/log/nilfs which is a ext3 mount point and can log when NILFS dies. 6. lscp | xz -9e > lscp.txt.xz 7. mount my snapshot using mount -o cp=3360839,ro /dev/vgUbuntu/root /mnt/nilfs 8. start a screen to dump /proc/kmsg to text file since rsyslog is killed 9. start a screen and launch strace -f -o find-cat.log -t find /mnt/nilfs -type f -exec cat {} > /dev/null \; 10. start a screen and launch strace -f -o apt-get.log -t apt-get update 11. launch the last command again as it did not crash the first time 12. apt-get crashes 13. ps aux > ps-aux-crashed.log 13. sysrq+W 14. sysrq+E wait for everything to terminate 15. sysrq+SUSB Simplified way of the issue reproducing is starting kernel compilation task and "apt-get update" in parallel. REPRODUCIBILITY: The issue is reproduced not stable [60% - 80%]. It is very important to have proper environment for the issue reproducing. The critical conditions for successful reproducing: (1) It should have big modified file by mmap() way. (2) This file should have the count of dirty blocks are greater that several segments in size (for example, two or three) from time to time during processing. (3) It should be intensive background activity of files modification in another thread. INVESTIGATION: First of all, it is possible to see that the reason of crash is not valid page address: NILFS [nilfs_segctor_complete_write]:2100 bh->b_count 0, bh->b_blocknr 13895680, bh->b_size 13897727, bh->b_page 0000000000001a82 NILFS [nilfs_segctor_complete_write]:2101 segbuf->sb_segnum 6783 Moreover, value of b_page (0x1a82) is 6786. This value looks like segment number. And b_blocknr with b_size values look like block numbers. So, buffer_head's pointer points on not proper address value. Detailed investigation of the issue is discovered such picture: [-----------------------------SEGMENT 6783-------------------------------] NILFS [nilfs_segctor_do_construct]:2310 nilfs_segctor_begin_construction NILFS [nilfs_segctor_do_construct]:2321 nilfs_segctor_collect NILFS [nilfs_segctor_do_construct]:2336 nilfs_segctor_assign NILFS [nilfs_segctor_do_construct]:2367 nilfs_segctor_update_segusage NILFS [nilfs_segctor_do_construct]:2371 nilfs_segctor_prepare_write NILFS [nilfs_segctor_do_construct]:2376 nilfs_add_checksums_on_logs NILFS [nilfs_segctor_do_construct]:2381 nilfs_segctor_write NILFS [nilfs_segbuf_submit_bio]:464 bio->bi_sector 111149024, segbuf->sb_segnum 6783 [-----------------------------SEGMENT 6784-------------------------------] NILFS [nilfs_segctor_do_construct]:2310 nilfs_segctor_begin_construction NILFS [nilfs_segctor_do_construct]:2321 nilfs_segctor_collect NILFS [nilfs_lookup_dirty_data_buffers]:782 bh->b_count 1, bh->b_page ffffea000709b000, page->index 0, i_ino 1033103, i_size 25165824 NILFS [nilfs_lookup_dirty_data_buffers]:783 bh->b_assoc_buffers.next ffff8802174a6798, bh->b_assoc_buffers.prev ffff880221cffee8 NILFS [nilfs_segctor_do_construct]:2336 nilfs_segctor_assign NILFS [nilfs_segctor_do_construct]:2367 nilfs_segctor_update_segusage NILFS [nilfs_segctor_do_construct]:2371 nilfs_segctor_prepare_write NILFS [nilfs_segctor_do_construct]:2376 nilfs_add_checksums_on_logs NILFS [nilfs_segctor_do_construct]:2381 nilfs_segctor_write NILFS [nilfs_segbuf_submit_bh]:575 bh->b_count 1, bh->b_page ffffea000709b000, page->index 0, i_ino 1033103, i_size 25165824 NILFS [nilfs_segbuf_submit_bh]:576 segbuf->sb_segnum 6784 NILFS [nilfs_segbuf_submit_bh]:577 bh->b_assoc_buffers.next ffff880218a0d5f8, bh->b_assoc_buffers.prev ffff880218bcdf50 NILFS [nilfs_segbuf_submit_bio]:464 bio->bi_sector 111150080, segbuf->sb_segnum 6784, segbuf->sb_nbio 0 [----------] ditto NILFS [nilfs_segbuf_submit_bio]:464 bio->bi_sector 111164416, segbuf->sb_segnum 6784, segbuf->sb_nbio 15 [-----------------------------SEGMENT 6785-------------------------------] NILFS [nilfs_segctor_do_construct]:2310 nilfs_segctor_begin_construction NILFS [nilfs_segctor_do_construct]:2321 nilfs_segctor_collect NILFS [nilfs_lookup_dirty_data_buffers]:782 bh->b_count 2, bh->b_page ffffea000709b000, page->index 0, i_ino 1033103, i_size 25165824 NILFS [nilfs_lookup_dirty_data_buffers]:783 bh->b_assoc_buffers.next ffff880219277e80, bh->b_assoc_buffers.prev ffff880221cffc88 NILFS [nilfs_segctor_do_construct]:2367 nilfs_segctor_update_segusage NILFS [nilfs_segctor_do_construct]:2371 nilfs_segctor_prepare_write NILFS [nilfs_segctor_do_construct]:2376 nilfs_add_checksums_on_logs NILFS [nilfs_segctor_do_construct]:2381 nilfs_segctor_write NILFS [nilfs_segbuf_submit_bh]:575 bh->b_count 2, bh->b_page ffffea000709b000, page->index 0, i_ino 1033103, i_size 25165824 NILFS [nilfs_segbuf_submit_bh]:576 segbuf->sb_segnum 6785 NILFS [nilfs_segbuf_submit_bh]:577 bh->b_assoc_buffers.next ffff880218a0d5f8, bh->b_assoc_buffers.prev ffff880222cc7ee8 NILFS [nilfs_segbuf_submit_bio]:464 bio->bi_sector 111165440, segbuf->sb_segnum 6785, segbuf->sb_nbio 0 [----------] ditto NILFS [nilfs_segbuf_submit_bio]:464 bio->bi_sector 111177728, segbuf->sb_segnum 6785, segbuf->sb_nbio 12 NILFS [nilfs_segctor_do_construct]:2399 nilfs_segctor_wait NILFS [nilfs_segbuf_wait]:676 segbuf->sb_segnum 6783 NILFS [nilfs_segbuf_wait]:676 segbuf->sb_segnum 6784 NILFS [nilfs_segbuf_wait]:676 segbuf->sb_segnum 6785 NILFS [nilfs_segctor_complete_write]:2100 bh->b_count 0, bh->b_blocknr 13895680, bh->b_size 13897727, bh->b_page 0000000000001a82 BUG: unable to handle kernel paging request at 0000000000001a82 IP: [<ffffffffa024d0f2>] nilfs_end_page_io+0x12/0xd0 [nilfs2] Usually, for every segment we collect dirty files in list. Then, dirty blocks are gathered for every dirty file, prepared for write and submitted by means of nilfs_segbuf_submit_bh() call. Finally, it takes place complete write phase after calling nilfs_end_bio_write() on the block layer. Buffers/pages are marked as not dirty on final phase and processed files removed from the list of dirty files. It is possible to see that we had three prepare_write and submit_bio phases before segbuf_wait and complete_write phase. Moreover, segments compete between each other for dirty blocks because on every iteration of segments processing dirty buffer_heads are added in several lists of payload_buffers: [SEGMENT 6784]: bh->b_assoc_buffers.next ffff880218a0d5f8, bh->b_assoc_buffers.prev ffff880218bcdf50 [SEGMENT 6785]: bh->b_assoc_buffers.next ffff880218a0d5f8, bh->b_assoc_buffers.prev ffff880222cc7ee8 The next pointer is the same but prev pointer has changed. It means that buffer_head has next pointer from one list but prev pointer from another. Such modification can be made several times. And, finally, it can be resulted in various issues: (1) segctor hanging, (2) segctor crashing, (3) file system metadata corruption. FIX: This patch adds: (1) setting of BH_Async_Write flag in nilfs_segctor_prepare_write() for every proccessed dirty block; (2) checking of BH_Async_Write flag in nilfs_lookup_dirty_data_buffers() and nilfs_lookup_dirty_node_buffers(); (3) clearing of BH_Async_Write flag in nilfs_segctor_complete_write(), nilfs_abort_logs(), nilfs_forget_buffer(), nilfs_clear_dirty_page(). Reported-by: Jerome Poulin <jeromepoulin@gmail.com> Reported-by: Anton Eliasson <devel@antoneliasson.se> Cc: Paul Fertser <fercerpav@gmail.com> Cc: ARAI Shun-ichi <hermes@ceres.dti.ne.jp> Cc: Piotr Szymaniak <szarpaj@grubelek.pl> Cc: Juan Barry Manuel Canham <Linux@riotingpacifist.net> Cc: Zahid Chowdhury <zahid.chowdhury@starsolutions.com> Cc: Elmer Zhang <freeboy6716@gmail.com> Cc: Kenneth Langga <klangga@gmail.com> Signed-off-by: Vyacheslav Dubeyko <slava@dubeyko.com> Acked-by: Ryusuke Konishi <konishi.ryusuke@lab.ntt.co.jp> Cc: <stable@vger.kernel.org> Signed-off-by: Andrew Morton <akpm@linux-foundation.org> Signed-off-by: Linus Torvalds <torvalds@linux-foundation.org>
2013-09-12truncate: drop 'oldsize' truncate_pagecache() parameterKirill A. Shutemov
truncate_pagecache() doesn't care about old size since commit cedabed49b39 ("vfs: Fix vmtruncate() regression"). Let's drop it. Signed-off-by: Kirill A. Shutemov <kirill.shutemov@linux.intel.com> Cc: OGAWA Hirofumi <hirofumi@mail.parknet.co.jp> Signed-off-by: Andrew Morton <akpm@linux-foundation.org> Signed-off-by: Linus Torvalds <torvalds@linux-foundation.org>
2013-09-05Merge branch 'for-linus' of ↵Linus Torvalds
git://git.kernel.org/pub/scm/linux/kernel/git/viro/vfs Pull vfs pile 1 from Al Viro: "Unfortunately, this merge window it'll have a be a lot of small piles - my fault, actually, for not keeping #for-next in anything that would resemble a sane shape ;-/ This pile: assorted fixes (the first 3 are -stable fodder, IMO) and cleanups + %pd/%pD formats (dentry/file pathname, up to 4 last components) + several long-standing patches from various folks. There definitely will be a lot more (starting with Miklos' check_submount_and_drop() series)" * 'for-linus' of git://git.kernel.org/pub/scm/linux/kernel/git/viro/vfs: (26 commits) direct-io: Handle O_(D)SYNC AIO direct-io: Implement generic deferred AIO completions add formats for dentry/file pathnames kvm eventfd: switch to fdget powerpc kvm: use fdget switch fchmod() to fdget switch epoll_ctl() to fdget switch copy_module_from_fd() to fdget git simplify nilfs check for busy subtree ibmasmfs: don't bother passing superblock when not needed don't pass superblock to hypfs_{mkdir,create*} don't pass superblock to hypfs_diag_create_files don't pass superblock to hypfs_vm_create_files() oprofile: get rid of pointless forward declarations of struct super_block oprofilefs_create_...() do not need superblock argument oprofilefs_mkdir() doesn't need superblock argument don't bother with passing superblock to oprofile_create_stats_files() oprofile: don't bother with passing superblock to ->create_files() don't bother passing sb to oprofile_create_files() coh901318: don't open-code simple_read_from_buffer() ...
2013-09-03git simplify nilfs check for busy subtreeAl Viro
Reviewed-by: Ryusuke Konishi <konishi.ryusuke@lab.ntt.co.jp> Signed-off-by: Al Viro <viro@zeniv.linux.org.uk>
2013-08-23nilfs2: fix issue with counting number of bio requests for BIO_EOPNOTSUPP ↵Vyacheslav Dubeyko
error detection Fix the issue with improper counting number of flying bio requests for BIO_EOPNOTSUPP error detection case. The sb_nbio must be incremented exactly the same number of times as complete() function was called (or will be called) because nilfs_segbuf_wait() will call wail_for_completion() for the number of times set to sb_nbio: do { wait_for_completion(&segbuf->sb_bio_event); } while (--segbuf->sb_nbio > 0); Two functions complete() and wait_for_completion() must be called the same number of times for the same sb_bio_event. Otherwise, wait_for_completion() will hang or leak. Signed-off-by: Vyacheslav Dubeyko <slava@dubeyko.com> Cc: Dan Carpenter <dan.carpenter@oracle.com> Acked-by: Ryusuke Konishi <konishi.ryusuke@lab.ntt.co.jp> Tested-by: Ryusuke Konishi <konishi.ryusuke@lab.ntt.co.jp> Cc: <stable@vger.kernel.org> Signed-off-by: Andrew Morton <akpm@linux-foundation.org> Signed-off-by: Linus Torvalds <torvalds@linux-foundation.org>
2013-08-23nilfs2: remove double bio_put() in nilfs_end_bio_write() for BIO_EOPNOTSUPP ↵Vyacheslav Dubeyko
error Remove double call of bio_put() in nilfs_end_bio_write() for the case of BIO_EOPNOTSUPP error detection. The issue was found by Dan Carpenter and he suggests first version of the fix too. Signed-off-by: Vyacheslav Dubeyko <slava@dubeyko.com> Reported-by: Dan Carpenter <dan.carpenter@oracle.com> Acked-by: Ryusuke Konishi <konishi.ryusuke@lab.ntt.co.jp> Tested-by: Ryusuke Konishi <konishi.ryusuke@lab.ntt.co.jp> Cc: <stable@vger.kernel.org> Signed-off-by: Andrew Morton <akpm@linux-foundation.org> Signed-off-by: Linus Torvalds <torvalds@linux-foundation.org>
2013-07-05helper for reading ->d_countAl Viro
