path: root/fs/nls
2013-03-20NLS: improve UTF8 -> UTF16 string conversion routineAlan Stern
commit 0720a06a7518c9d0c0125bd5d1f3b6264c55c3dd upstream. The utf8s_to_utf16s conversion routine needs to be improved. Unlike its utf16s_to_utf8s sibling, it doesn't accept arguments specifying the maximum length of the output buffer or the endianness of its 16-bit output. This patch (as1501) adds the two missing arguments, and adjusts the only two places in the kernel where the function is called. A follow-on patch will add a third caller that does utilize the new capabilities. The two conversion routines are still annoyingly inconsistent in the way they handle invalid byte combinations. But that's a subject for a different patch. Signed-off-by: Alan Stern <stern@rowland.harvard.edu> CC: Clemens Ladisch <clemens@ladisch.de> Signed-off-by: Greg Kroah-Hartman <gregkh@suse.de> Signed-off-by: Ben Hutchings <ben@decadent.org.uk>
2009-09-30Merge git://git.kernel.org/pub/scm/linux/kernel/git/hirofumi/fatfs-2.6Linus Torvalds
* git://git.kernel.org/pub/scm/linux/kernel/git/hirofumi/fatfs-2.6: fat: Check s_dirt in fat_sync_fs() vfat: change the default from shortname=lower to shortname=mixed fat/nls: Fix handling of utf8 invalid char
2009-09-24fs: Make unload_nls() NULL pointer safeThomas Gleixner
Most call sites of unload_nls() do: if (nls) unload_nls(nls); Check the pointer inside unload_nls() like we do in kfree() and simplify the call sites. Signed-off-by: Thomas Gleixner <tglx@linutronix.de> Cc: Steve French <sfrench@us.ibm.com> Cc: OGAWA Hirofumi <hirofumi@mail.parknet.co.jp> Cc: Roman Zippel <zippel@linux-m68k.org> Cc: Dave Kleikamp <shaggy@linux.vnet.ibm.com> Cc: Petr Vandrovec <vandrove@vc.cvut.cz> Cc: Anton Altaparmakov <aia21@cantab.net> Signed-off-by: Al Viro <viro@zeniv.linux.org.uk>
2009-08-01fat/nls: Fix handling of utf8 invalid charOGAWA Hirofumi
With utf8 option, vfat allowed the duplicated filenames. Normal nls returns -EINVAL for invalid char. But utf8s_to_utf16s() skipped the invalid char historically. So, this changes the utf8s_to_utf16s() directly to return -EINVAL for invalid char, because vfat is only user of it. mkdir /mnt/fatfs FILENAME=`echo -ne "invalidutf8char_\\0341_endofchar"` echo "Using filename: $FILENAME" dd if=/dev/zero of=fatfs bs=512 count=128 mkdosfs -F 32 fatfs mount -o loop,utf8 fatfs /mnt/fatfs touch "/mnt/fatfs/$FILENAME" umount /mnt/fatfs mount -o loop,utf8 fatfs /mnt/fatfs touch "/mnt/fatfs/$FILENAME" ls -l /mnt/fatfs umount /mnt/fatfs ---- And the output is: Using filename: invalidutf8char_\0341_endofchar 128+0 records in 128+0 records out 65536 bytes (66 kB) copied, 0.000388118 s, 169 MB/s mkdosfs 2.11 (12 Mar 2005) total 0 -rwxr-xr-x 1 root root 0 Jun 28 19:46 invalidutf8char__endofchar -rwxr-xr-x 1 root root 0 Jun 28 19:46 invalidutf8char__endofchar Tested-by: Marton Balint <cus@fazekas.hu> Signed-off-by: OGAWA Hirofumi <hirofumi@mail.parknet.co.jp>
2009-06-15NLS: update handling of UnicodeAlan Stern
This patch (as1239) updates the kernel's treatment of Unicode. The character-set conversion routines are well behind the current state of the Unicode specification: They don't recognize the existence of code points beyond plane 0 or of surrogate pairs in the UTF-16 encoding. The old wchar_t 16-bit type is retained because it's still used in lots of places. This shouldn't cause any new problems; if a conversion now results in an invalid 16-bit code then before it must have yielded an undefined code. Difficult-to-read names like "utf_mbstowcs" are replaced with more transparent names like "utf8s_to_utf16s" and the ordering of the parameters is rationalized (buffer lengths come immediate after the pointers they refer to, and the inputs precede the outputs). Fortunately the low-level conversion routines are used in only a few places; the interfaces to the higher-level uni2char and char2uni methods have been left unchanged. Signed-off-by: Alan Stern <stern@rowland.harvard.edu> Acked-by: Clemens Ladisch <clemens@ladisch.de> Signed-off-by: Greg Kroah-Hartman <gregkh@suse.de>
2009-06-15nls: utf8_wcstombs: fix buffer overflowClemens Ladisch
utf8_wcstombs forgot to include one-byte UTF-8 characters when calculating the output buffer size, i.e., theoretically, it was possible to overflow the output buffer with an input string that contains enough ASCII characters. In practice, this was no problem because the only user so far (VFAT) always uses a big enough output buffer. Signed-off-by: Clemens Ladisch <clemens@ladisch.de> Signed-off-by: Greg Kroah-Hartman <gregkh@suse.de>
2009-06-15nls: utf8_wcstombs: use correct buffer size in error caseClemens Ladisch
When utf8_wcstombs encounters a character that cannot be encoded, we must not decrease the remaining output buffer size because nothing has been written to the output buffer. Signed-off-by: Clemens Ladisch <clemens@ladisch.de> Signed-off-by: Greg Kroah-Hartman <gregkh@suse.de>
2008-10-17remove CONFIG_KMOD from fsJohannes Berg
Just always compile the code when the kernel is modular. Convert load_nls to use try_then_request_module to tidy up the code. Signed-off-by: Johannes Berg <johannes@sipsolutions.net> Signed-off-by: Rusty Russell <rusty@rustcorp.com.au>
2007-10-18sparse pointer use of zero as nullStephen Hemminger
Get rid of sparse related warnings from places that use integer as NULL pointer. [akpm@linux-foundation.org: coding-style fixes] Signed-off-by: Stephen Hemminger <shemminger@linux-foundation.org> Cc: Andi Kleen <ak@suse.de> Cc: Jeff Garzik <jeff@garzik.org> Cc: Matt Mackall <mpm@selenic.com> Cc: Ian Kent <raven@themaw.net> Cc: Arnd Bergmann <arnd@arndb.de> Cc: Davide Libenzi <davidel@xmailserver.org> Cc: Stephen Smalley <sds@tycho.nsa.gov> Signed-off-by: Andrew Morton <akpm@linux-foundation.org> Signed-off-by: Linus Torvalds <torvalds@linux-foundation.org>
2007-10-17menuconfig: transform NLS and DLM menusJan Engelhardt
Changes NLS and DLM menus into a 'menuconfig' object so that it can be disabled at once without having to enter the menu first to disable the config option. Signed-off-by: Jan Engelhardt <jengelh@gmx.de> Cc: Steven Whitehouse <swhiteho@redhat.com> Signed-off-by: Andrew Morton <akpm@linux-foundation.org> Signed-off-by: Linus Torvalds <torvalds@linux-foundation.org>
2007-10-17add consts where appropriate in fs/nls/*Denys Vlasenko
Add const modifiers to a few struct nls_table's member pointers in include/linux/nls.h and adds a lot of const's in fs/nls/*.c files. Resulting changes as visible by size: text data bss dec hex filename 113612 481216 2368 597196 91ccc nls.org/built-in.o 593548 3296 288 597132 91c8c nls/built-in.o Apparently compiler managed to optimize code a bit better because of const-ness. No other changes are made. Signed-off-by: Denys Vlasenko <vda.linux@googlemail.com> Cc: Al Viro <viro@zeniv.linux.org.uk> Signed-off-by: Andrew Morton <akpm@linux-foundation.org> Signed-off-by: Linus Torvalds <torvalds@linux-foundation.org>
2007-07-16NLS: Remove obsolete Makefile entriesRobert P. J. Day
Since the corresponding source files no longer exist, remove the irrelevant Makefile entries for them. Signed-off-by: Robert P. J. Day <rpjday@mindspring.com> Signed-off-by: Andrew Morton <akpm@linux-foundation.org> Signed-off-by: Linus Torvalds <torvalds@linux-foundation.org>
2006-12-07[PATCH] fs: make nls_cp936.c handle some U00XY characters and U20AC correctlyJun Chen
Twenty characters in cp936 are not correctly handled. They're all in the U00 plane. nls_cp936 converts all U00XY to XY but this is not correct for some characters.(e.g. U00B7 -> A1A4, U00A8 -> A1A7). This problem is fixed by generating u2c_00 based on all c2u_xx and changing uni2char() to give U00 plane a special handling. The "€"(U20AC,80 in cp936) is also be handled properly. Acked-by: Gang Chen <cgdlut@gmail.com> Cc: OGAWA Hirofumi <hirofumi@mail.parknet.co.jp> Signed-off-by: Andrew Morton <akpm@osdl.org> Signed-off-by: Linus Torvalds <torvalds@osdl.org>
2006-10-03fix file specification in commentsUwe Zeisberger
Many files include the filename at the beginning, serveral used a wrong one. Signed-off-by: Uwe Zeisberger <Uwe_Zeisberger@digi.com> Signed-off-by: Adrian Bunk <bunk@stusta.de>
2006-10-02[PATCH] Remove NULL check in register_nls()Alexey Dobriyan
Everybody passes valid pointer there. Signed-off-by: Alexey Dobriyan <adobriyan@gmail.com> Acked-by: OGAWA Hirofumi <hirofumi@mail.parknet.co.jp> Signed-off-by: Andrew Morton <akpm@osdl.org> Signed-off-by: Linus Torvalds <torvalds@osdl.org>
2006-03-24[PATCH] fs: Use ARRAY_SIZE macroTobias Klauser
Use ARRAY_SIZE macro instead of sizeof(x)/sizeof(x[0]) and remove a duplicate of ARRAY_SIZE. Some trailing whitespaces are also deleted. Signed-off-by: Tobias Klauser <tklauser@nuerscht.ch> Cc: David Howells <dhowells@redhat.com> Cc: Dave Kleikamp <shaggy@austin.ibm.com> Acked-by: Trond Myklebust <trond.myklebust@fys.uio.no> Cc: Neil Brown <neilb@cse.unsw.edu.au> Cc: Chris Mason <mason@suse.com> Cc: Jeff Mahoney <jeffm@suse.com> Cc: Christoph Hellwig <hch@lst.de> Cc: Nathan Scott <nathans@sgi.com> Signed-off-by: Andrew Morton <akpm@osdl.org> Signed-off-by: Linus Torvalds <torvalds@osdl.org>
2006-03-22It's UTF-8Alexey Dobriyan
Fix some comments to "UTF-8". Signed-off-by: Alexey Dobriyan <adobriyan@gmail.com> Signed-off-by: Adrian Bunk <bunk@stusta.de>
2005-05-05[PATCH] make some things staticAdrian Bunk
This patch makes some needlessly global identifiers static. Signed-off-by: Adrian Bunk <bunk@stusta.de> Acked-by: Arjan van de Ven <arjanv@infradead.org> Acked-by: Trond Myklebust <trond.myklebust@fys.uio.no> Signed-off-by: Andrew Morton <akpm@osdl.org> Signed-off-by: Linus Torvalds <torvalds@osdl.org>
