Philippe Ombredanne.
How this work was done:
the use cases:
lines of source
lines).
identifiers to apply.
COPYING file license applied.
GPL-2.0 11139
the concluded license(s).
in time.
they are related.
in about 15000 files.
correct identifier.
version early this week with:
license ids and scores
generate the patches.
Pointer to ->free_mark callback unnecessarily occupies one long in each
fsnotify_mark although they are the same for all marks from one
notification group. Move the callback pointer to fsnotify_ops.
Reviewed-by: Miklos Szeredi <mszeredi@redhat.com>
Reviewed-by: Amir Goldstein <amir73il@gmail.com>
Currently we initialize mark->group only in fsnotify_add_mark_lock().
However we will need to access fsnotify_ops of corresponding group from
fsnotify_put_mark() so we need mark->group initialized earlier. Do that
in fsnotify_init_mark() which has a consequence that once
fsnotify_init_mark() is called on a mark, the mark has to be destroyed
by fsnotify_put_mark().
These are very thin wrappers, just remove them. Drop
fs/notify/vfsmount_mark.c as it is empty now.
These helpers are just very thin wrappers now. Remove them.
These helpers are now only a simple assignment and just obfuscate
what is going on. Remove them.
Pass fsnotify_iter_info into ->handle_event() handler so that it can
release and reacquire SRCU lock via fsnotify_prepare_user_wait() and
fsnotify_finish_user_wait() functions. These functions also make sure
current marks are appropriately pinned so that iteration protected by
srcu in fsnotify() stays safe.
Currently we queue mark into a list of marks for destruction in
__fsnotify_free_mark() and keep the last mark reference dangling. After the
worker waits for SRCU period, it drops the last reference to the mark
which frees it. This scheme has the disadvantage that if we hold
reference to a mark and drop and reacquire SRCU lock, the mark can get
freed immediately which is slightly inconvenient and we will need to
avoid this in the future.
Move to a scheme where queueing of mark into a list of marks for
destruction happens when the last reference to the mark is dropped. Also
drop reference to the mark held by group list already when mark is
removed from that list instead of dropping it only from the destruction
worker.
Dropping mark reference can result in mark being freed. Although it
should not happen in inotify_remove_from_idr() since caller should hold
another reference, just don't risk lock up just after WARN_ON
unnecessarily. Also fold do_inotify_remove_from_idr() into the single
callsite as that function really is just two lines of real code.
Printing inode pointers in warnings has dubious value and with future
changes we won't be able to easily get them without either locking or
chances we oops along the way. So just remove inode pointers from the
warning messages.
<linux/sched.h> into <linux/sched/signal.h>
Fix up affected files that include this signal functionality via sched.h.
Acked-by: Linus Torvalds <torvalds@linux-foundation.org>
Add #include <linux/cred.h> dependencies to all .c files rely on sched.h
doing that for them.
Note that even if the count where we need to add extra headers seems high,
it's still a net win, because <linux/sched.h> is included in over
2,200 files ...
This patchset converts inotify to using the newly introduced
per-userns sysctl infrastructure.
Currently the inotify instances/watches are being accounted in the
user_struct structure. This means that in setups where multiple
users in unprivileged containers map to the same underlying
real user (i.e. pointing to the same user_struct) the inotify limits
are going to be shared as well, allowing one user(or application) to exhaust
all others limits.
Fix this by switching the inotify sysctls to using the
per-namespace/per-user limits. This will allow the server admin to
set sensible global limits, which can further be tuned inside every
individual user namespace. Additionally, in order to preserve the
sysctl ABI make the existing inotify instances/watches sysctls
modify the values of the initial user namespace.
Signed-off-by: Nikolay Borisov <n.borisov.lkml@gmail.com>
Acked-by: Jan Kara <jack@suse.cz>
Acked-by: Serge Hallyn <serge@hallyn.com>
notification_mutex is used to protect the list of pending events. As such
there's no reason to use a sleeping lock for it. Convert it to a
spinlock.
[jack@suse.cz: fixed version]
Link: http://lkml.kernel.org/r/1474031567-1831-1-git-send-email-jack@suse.cz
Link: http://lkml.kernel.org/r/1473797711-14111-5-git-send-email-jack@suse.cz
Reviewed-by: Lino Sanfilippo <LinoSanfilippo@gmx.de>
Tested-by: Guenter Roeck <linux@roeck-us.net>
Cc: Miklos Szeredi <mszeredi@redhat.com>
Cc: Eric Paris <eparis@redhat.com>
Cc: Al Viro <viro@ZenIV.linux.org.uk>
The comment here says that it is checking for invalid bits. But, the mask
is *actually* checking to ensure that _any_ valid bit is set, which is
quite different.
Without this check, an unexpected bit could get set on an inotify object.
Since these bits are also interpreted by the fsnotify/dnotify code, there
is the potential for an object to be mishandled inside the kernel. For
instance, can we be sure that setting the dnotify flag FS_DN_RENAME on an
inotify watch is harmless?
Add the actual check which was intended. Retain the existing inotify bits
are being added to the watch. Plus, this is existing behavior which would
be nice to preserve.
I did a quick sniff test that inotify functions and that my
'inotify-tools' package passes 'make check'.
Signed-off-by: Dave Hansen <dave.hansen@linux.intel.com>
Cc: John McCutchan <john@johnmccutchan.com>
Cc: Robert Love <rlove@rlove.org>
Cc: Eric Paris <eparis@parisplace.org>
Cc: Josh Boyer <jwboyer@fedoraproject.org>
The INOTIFY_USER option is bool, and hence this code is either
present or absent. It will never be modular, so using
module_init as an alias for __initcall is rather misleading.
Fix this up now, so that we can relocate module_init from
init.h into module.h in the future. If we don't do this, we'd
have to add module.h to obviously non-modular code, and that
would be a worse thing.
Note that direct use of __initcall is discouraged, vs. one
of the priority categorized subgroups. As __initcall gets
mapped onto device_initcall, our use of fs_initcall (which
makes sense for fs code) will thus change this registration
from level 6-device to level 5-fs (i.e. slightly earlier).
However no observable impact of that small difference has
been observed during testing, or is expected.
There's a lot of common code in inode and mount marks handling. Factor it
out to a common helper function.
Cc: Heinrich Schuchardt <xypron.glpk@gmx.de>
inotify_read is a wait loop with sleeps in. Wait loops rely on
task_struct::state and sleeps do too, since that's the only means of
actually sleeping. Therefore the nested sleeps destroy the wait loop
state and the wait loop breaks the sleep functions that assume
TASK_RUNNING (mutex_lock).
Fix this by using the new woken_wake_function and wait_woken() stuff,
which registers wakeups in wait and thereby allows shrinking the
task_state::state changes to the actual sleep part.
Cc: tglx@linutronix.de
Cc: ilya.dryomov@inktank.com
Cc: umgwanakikbuti@gmail.com
Link: http://lkml.kernel.org/r/20140924082242.254858080@infradead.org
On some failure paths we may attempt to free user context even if it
wasn't assigned yet. This will cause a NULL ptr deref and a kernel BUG.
The path I was looking at is in inotify_new_group():
oevent = kmalloc(sizeof(struct inotify_event_info), GFP_KERNEL);
if (unlikely(!oevent)) {
fsnotify_destroy_group(group);
return ERR_PTR(-ENOMEM);
fsnotify_destroy_group() would get called here, but
group->inotify_data.user is only getting assigned later:
group->inotify_data.user = get_current_user();
Reviewed-by: Heinrich Schuchardt <xypron.glpk@gmx.de>
Rename fsnotify_add_notify_event() to fsnotify_add_event() since the
"notify" part is duplicit. Rename fsnotify_remove_notify_event() and
fsnotify_peek_notify_event() to fsnotify_remove_first_event() and
fsnotify_peek_first_event() respectively since "notify" part is duplicit
and they really look at the first event in the queue.
This typedef is unnecessary and should just be removed.
Commit 7053aee26a35 "fsnotify: do not share events between notification
groups" used overflow event statically allocated in a group with the
size of the generic notification event. This causes problems because
some code looks at type specific parts of event structure and gets
confused by a random data it sees there and causes crashes.
Fix the problem by allocating overflow event with type corresponding to
the group type so code cannot get confused.
My rework of handling of notification events (namely commit 7053aee26a35
"fsnotify: do not share events between notification groups") broke
sending of cookies with inotify events. We didn't propagate the value
passed to fsnotify() properly and passed 4 uninitialized bytes to
userspace instead (so it is also an information leak). Sadly I didn't
notice this during my testing because inotify cookies aren't used very
much and LTP inotify tests ignore them.
Fix the problem by passing the cookie value properly.
Fixes: 7053aee26a3548ebaba046ae2e52396ccf56ac6c
Reported-by: Vegard Nossum <vegard.nossum@oracle.com>
The event returned from fsnotify_add_notify_event() cannot ever be used
safely as the event may be freed by the time the function returns (after
dropping notification_mutex). So change the prototype to just return
whether the event was added or merged into some existing event.
Reported-and-tested-by: Jiri Kosina <jkosina@suse.cz>
Reported-and-tested-by: Dave Jones <davej@fedoraproject.org>
After removing event structure creation from the generic layer there is
no reason for separate .should_send_event and .handle_event callbacks.
So just remove the first one.
Currently fsnotify framework creates one event structure for each
notification event and links this event into all interested notification
groups. This is done so that we save memory when several notification
groups are interested in the event. However the need for event
structure shared between inotify & fanotify bloats the event structure
so the result is often higher memory consumption.
Another problem is that fsnotify framework keeps path references with
outstanding events so that fanotify can return open file descriptors
with its events. This has the undesirable effect that filesystem cannot
be unmounted while there are outstanding events - a regression for
inotify compared to a situation before it was converted to fsnotify
framework. For fanotify this problem is hard to avoid and users of
fanotify should kind of expect this behavior when they ask for file
descriptors from notified files.
This patch changes fsnotify and its users to create separate event
structure for each group. This allows for much simpler code (~400 lines
removed by this patch) and also smaller event structures. For example
on 64-bit system original struct fsnotify_event consumes 120 bytes, plus
additional space for file name, additional 24 bytes for second and each
subsequent group linking the event, and additional 32 bytes for each
inotify group for private data. After the conversion inotify event
consumes 48 bytes plus space for file name which is considerably less
memory unless file names are long and there are several groups
interested in the events (both of which are uncommon). Fanotify event
fits in 56 bytes after the conversion (fanotify doesn't care about file
names so its events don't have to have it allocated). A win unless
there are four or more fanotify groups interested in the event.
The conversion also solves the problem with unmount when only inotify is
used as we don't have to grab path references for inotify events.
[hughd@google.com: fanotify: fix corruption preventing startup]
Rounding of name length when passing it to userspace was done in several
places. Provide a function to do it and use it in all places.
In inotify_new_watch() the number of watches for a group is compared
against the max number of allowed watches and increased afterwards. The
check and incrementation is not done atomically, so it is possible for
multiple concurrent threads to pass the check and increment the number
of marks above the allowed max.
This patch uses an inotify groups mark_lock to ensure that both check
and incrementation are done atomic. Furthermore we dont have to worry
about the race that allows a concurrent thread to add a watch just after
inotify_update_existing_watch() returned with -ENOENT anymore, since
this is also synchronized by the groups mark mutex now.
Signed-off-by: Lino Sanfilippo <LinoSanfilippo@gmx.de>
Pull VFS updates from Al Viro,
Misc cleanups all over the place, mainly wrt /proc interfaces (switch
create_proc_entry to proc_create(), get rid of the deprecated
create_proc_read_entry() in favor of using proc_create_data() and
seq_file etc).
7kloc removed.
* 'for-linus' of git://git.kernel.org/pub/scm/linux/kernel/git/viro/vfs: (204 commits)
don't bother with deferred freeing of fdtables
proc: Move non-public stuff from linux/proc_fs.h to fs/proc/internal.h
proc: Make the PROC_I() and PDE() macros internal to procfs
proc: Supply a function to remove a proc entry by PDE
take cgroup_open() and cpuset_open() to fs/proc/base.c
ppc: Clean up scanlog
ppc: Clean up rtas_flash driver somewhat
hostap: proc: Use remove_proc_subtree()
drm: proc: Use remove_proc_subtree()
drm: proc: Use minor->index to label things, not PDE->name
drm: Constify drm_proc_list[]
zoran: Don't print proc_dir_entry data in debug
reiserfs: Don't access the proc_dir_entry in r_open(), r_start() r_show()
proc: Supply an accessor for getting the data from a PDE's parent
airo: Use remove_proc_subtree()
rtl8192u: Don't need to save device proc dir PDE
rtl8187se: Use a dir under /proc/net/r8180/
proc: Add proc_mkdir_data()
proc: Move some bits from linux/proc_fs.h to linux/{of.h,signal.h,tty.h}
proc: Move PDE_NET() to fs/proc/proc_net.c
When we run the crackerjack testsuite, the inotify_add_watch test is
stalled.
This is caused by the invalid mask 0 - the task is waiting for the event
but it never comes. inotify_add_watch() should return -EINVAL as it did
before commit 676a0675cf92 ("inotify: remove broken mask checks causing
unmount to be EINVAL"). That commit removes the invalid mask check, but
that check is needed.
Check the mask's ALL_INOTIFY_BITS before the inotify_arg_to_mask() call.
If none are set, just return -EINVAL.
Because IN_UNMOUNT is in ALL_INOTIFY_BITS, this change will not trigger
the problem that above commit fixed.
[akpm@linux-foundation.org: fix build]
Signed-off-by: Zhao Hongjiang <zhaohongjiang@huawei.com>
Acked-by: Jim Somerville <Jim.Somerville@windriver.com>
Cc: Paul Gortmaker <paul.gortmaker@windriver.com>
Cc: Jerome Marchand <jmarchan@redhat.com>
Cc: <stable@vger.kernel.org>
Signed-off-by: Jeff Layton <jlayton@redhat.com>
Cc: Tejun Heo <tj@kernel.org>
... it's done already by __fput()
Convert to the much saner new idr interface.
Note that the adhoc cyclic id allocation is buggy. If wraparound
happens, the previous code with idr_get_new_above() may segfault and
the converted code will trigger WARN and return -EINVAL. Even if it's
fixed to wrap to zero, the code will be prone to unnecessary -ENOSPC
failures after the first wraparound. We probably need to implement
proper cyclic support in idr.
idr_destroy() can destroy idr by itself and idr_remove_all() is being
deprecated. Drop its usage.
Running the command:
inotifywait -e unmount /mnt/disk
immediately aborts with a -EINVAL return code. This is however a valid
parameter. This abort occurs only if unmount is the sole event
parameter. If other event parameters are supplied, then the unmount
event wait will work.
The problem was introduced by commit 44b350fc23e ("inotify: Fix mask
checks"). In that commit, it states:
The mask checks in inotify_update_existing_watch() and
inotify_new_watch() are useless because inotify_arg_to_mask()
sets FS_IN_IGNORED and FS_EVENT_ON_CHILD bits anyway.
But instead of removing the useless checks, it did this:
mask = inotify_arg_to_mask(arg);
- if (unlikely(!mask))
+ if (unlikely(!(mask & IN_ALL_EVENTS)))
return -EINVAL;
The problem is that IN_ALL_EVENTS doesn't include IN_UNMOUNT, and other
parts of the code keep IN_UNMOUNT separate from IN_ALL_EVENTS. So the
check should be:
if (unlikely(!(mask & (IN_ALL_EVENTS | IN_UNMOUNT))))
But inotify_arg_to_mask(arg) always sets the IN_UNMOUNT bit in the mask
anyway, so the check is always going to pass and thus should simply be
removed. Also note that inotify_arg_to_mask completely controls what
mask bits get set from arg, there's no way for invalid bits to get
enabled there.
Lets fix it by simply removing the useless broken checks.
Signed-off-by: Jim Somerville <Jim.Somerville@windriver.com>
Cc: <stable@vger.kernel.org> [2.6.37+]
Pull filesystem notification updates from Eric Paris:
"This pull mostly is about locking changes in the fsnotify system. By
switching the group lock from a spin_lock() to a mutex() we can now
hold the lock across things like iput(). This fixes a problem
involving unmounting a fs and having inodes be busy, first pointed out
by FAT, but reproducible with tmpfs.
This also restores signal driven I/O for inotify, which has been
broken since about 2.6.32."
Ugh. I *hate* the timing of this. It was rebased after the merge
window opened, and then left to sit with the pull request coming the day
before the merge window closes. That's just crap. But apparently the
patches themselves have been around for over a year, just gathering
dust, so now it's suddenly critical.
Fixed up semantic conflict in fs/notify/fdinfo.c as per Stephen
Rothwell's fixes from -next.
* 'for-next' of git://git.infradead.org/users/eparis/notify:
inotify: automatically restart syscalls
inotify: dont skip removal of watch descriptor if creation of ignored event failed
fanotify: dont merge permission events
fsnotify: make fasync generic for both inotify and fanotify
fsnotify: change locking order
fsnotify: dont put marks on temporary list when clearing marks by group
fsnotify: introduce locked versions of fsnotify_add_mark() and fsnotify_remove_mark()
fsnotify: pass group to fsnotify_destroy_mark()
fsnotify: use a mutex instead of a spinlock to protect a groups mark list
fanotify: add an extra flag to mark_remove_from_mask that indicates wheather a mark should be destroyed
fsnotify: take groups mark_lock before mark lock
fsnotify: use reference counting for groups
fsnotify: introduce fsnotify_get_group()
inotify, fanotify: replace fsnotify_put_group() with fsnotify_destroy_group()
This allow us to print out fsnotify details such as watchee inode, device,
mask and optionally a file handle.
For inotify objects if kernel compiled with exportfs support the output
will be
| pos: 0
| flags: 02000000
| inotify wd:3 ino:9e7e sdev:800013 mask:800afce ignored_mask:0 fhandle-bytes:8 fhandle-type:1 f_handle:7e9e0000640d1b6d
| inotify wd:2 ino:a111 sdev:800013 mask:800afce ignored_mask:0 fhandle-bytes:8 fhandle-type:1 f_handle:11a1000020542153
| inotify wd:1 ino:6b149 sdev:800013 mask:800afce ignored_mask:0 fhandle-bytes:8 fhandle-type:1 f_handle:49b1060023552153
If kernel compiled without exportfs support, the file handle
won't be provided but inode and device only.
| pos: 0
| flags: 02000000
For fanotify the output is like
| pos: 0
| flags: 04002
| fanotify flags:10 event-flags:0
| fanotify mnt_id:12 mask:3b ignored_mask:0
| fanotify ino:50205 sdev:800013 mask:3b ignored_mask:40000000 fhandle-bytes:8 fhandle-type:1 f_handle:05020500fb1d47e7
To minimize impact on general fsnotify code the new functionality
is gathered in fs/notify/fdinfo.c file.
Signed-off-by: Cyrill Gorcunov <gorcunov@openvz.org>
Acked-by: Pavel Emelyanov <xemul@parallels.com>
Cc: Andrey Vagin <avagin@openvz.org>
Cc: Alexey Dobriyan <adobriyan@gmail.com>
Cc: James Bottomley <jbottomley@parallels.com>
Cc: "Aneesh Kumar K.V" <aneesh.kumar@linux.vnet.ibm.com>
Cc: Matthew Helsley <matt.helsley@gmail.com>
Cc: "J. Bruce Fields" <bfields@fieldses.org>
Cc: Tvrtko Ursulin <tvrtko.ursulin@onelan.co.uk>
We were mistakenly returning EINTR when we found an outstanding signal.
Instead we should returen ERESTARTSYS and allow the kernel to handle
things the right way.
Patch-from: Oleg Nesterov <oleg@redhat.com>
Signed-off-by: Eric Paris <eparis@redhat.com>
failed
In inotify_ignored_and_remove_idr() the removal of a watch descriptor is skipped
if the allocation of an ignored event failed and we are leaking memory (the
watch descriptor and the mark linked to it).
This patch ensures that the watch descriptor is removed regardless of whether
event creation failed or not.
inotify is supposed to support async signal notification when information
is available on the inotify fd. This patch moves that support to generic
fsnotify functions so it can be used by all notification mechanisms.
In fsnotify_destroy_mark() dont get the group from the passed mark anymore,
but pass the group itself as an additional parameter to the function.
Get a group ref for each mark that is added to the groups list and release that
ref when the mark is freed in fsnotify_put_mark().
We also use get a group reference for duplicated marks and for private event
data.
Now we dont free a group any more when the number of marks becomes 0 but when
the groups ref count does. Since this will only happen when all marks are removed
from a groups mark list, we dont have to set the groups number of marks to 1 at
group creation.
Beside clearing all marks in fsnotify_destroy_group() we do also flush the
groups event queue. This is since events may hold references to groups (due to
private event data) and we have to put those references first before we get a
chance to put the final ref, which will result in a call to
fsnotify_final_destroy_group().
Currently in fsnotify_put_group() the ref count of a group is decremented and if
it becomes 0 fsnotify_destroy_group() is called. Since a groups ref count is only
at group creation set to 1 and never increased after that a call to fsnotify_put_group()
always results in a call to fsnotify_destroy_group().
With this patch fsnotify_destroy_group() is called directly.
* 'for-linus2' of git://git.profusion.mobi/users/lucas/linux-2.6:
Fix common misspellings
On an error path in inotify_init1 a normal user can trigger a double
free of struct user. This is a regression introduced by a2ae4cc9a16e
("inotify: stop kernel memory leak on file creation failure").
We fix this by making sure that if a group exists the user reference is
dropped when the group is cleaned up. We should not explictly drop the
reference on error and also drop the reference when the group is cleaned
up.
The new lifetime rules are that an inotify group lives from
inotify_new_group to the last fsnotify_put_group. Since the struct user
and inotify_devs are directly tied to this lifetime they are only
changed/updated in those two locations. We get rid of all special
casing of struct user or user->inotify_devs.
Cc: stable@kernel.org (2.6.37 and up)
If inotify_init is unable to allocate a new file for the new inotify
group we leak the new group. This patch drops the reference on the
group on file allocation failure.
Reported-by: Vegard Nossum <vegard.nossum@gmail.com>
cc: stable@kernel.org
