There's a lot of common code in inode and mount marks handling. Factor it
out to a common helper function.
Cc: Eric Paris <eparis@redhat.com>
Cc: Heinrich Schuchardt <xypron.glpk@gmx.de>
inotify_read is a wait loop with sleeps in. Wait loops rely on
task_struct::state and sleeps do too, since that's the only means of
actually sleeping. Therefore the nested sleeps destroy the wait loop
state and the wait loop breaks the sleep functions that assume
TASK_RUNNING (mutex_lock).
Fix this by using the new woken_wake_function and wait_woken() stuff,
which registers wakeups in wait and thereby allows shrinking the
task_state::state changes to the actual sleep part.
Cc: tglx@linutronix.de
Cc: ilya.dryomov@inktank.com
Cc: umgwanakikbuti@gmail.com
Cc: Robert Love <rlove@rlove.org>
Cc: Eric Paris <eparis@parisplace.org>
Cc: John McCutchan <john@johnmccutchan.com>
Link: http://lkml.kernel.org/r/20140924082242.254858080@infradead.org
On some failure paths we may attempt to free user context even if it
wasn't assigned yet. This will cause a NULL ptr deref and a kernel BUG.
The path I was looking at is in inotify_new_group():
oevent = kmalloc(sizeof(struct inotify_event_info), GFP_KERNEL);
if (unlikely(!oevent)) {
fsnotify_destroy_group(group);
return ERR_PTR(-ENOMEM);
fsnotify_destroy_group() would get called here, but
group->inotify_data.user is only getting assigned later:
group->inotify_data.user = get_current_user();
Reviewed-by: Heinrich Schuchardt <xypron.glpk@gmx.de>
Rename fsnotify_add_notify_event() to fsnotify_add_event() since the
"notify" part is duplicit. Rename fsnotify_remove_notify_event() and
fsnotify_peek_notify_event() to fsnotify_remove_first_event() and
fsnotify_peek_first_event() respectively since "notify" part is duplicit
and they really look at the first event in the queue.
This typedef is unnecessary and should just be removed.
Commit 7053aee26a35 "fsnotify: do not share events between notification
groups" used overflow event statically allocated in a group with the
size of the generic notification event. This causes problems because
some code looks at type specific parts of event structure and gets
confused by a random data it sees there and causes crashes.
Fix the problem by allocating overflow event with type corresponding to
the group type so code cannot get confused.
My rework of handling of notification events (namely commit 7053aee26a35
"fsnotify: do not share events between notification groups") broke
sending of cookies with inotify events. We didn't propagate the value
passed to fsnotify() properly and passed 4 uninitialized bytes to
userspace instead (so it is also an information leak). Sadly I didn't
notice this during my testing because inotify cookies aren't used very
much and LTP inotify tests ignore them.
Fix the problem by passing the cookie value properly.
Fixes: 7053aee26a3548ebaba046ae2e52396ccf56ac6c
Reported-by: Vegard Nossum <vegard.nossum@oracle.com>
The event returned from fsnotify_add_notify_event() cannot ever be used
safely as the event may be freed by the time the function returns (after
dropping notification_mutex). So change the prototype to just return
whether the event was added or merged into some existing event.
Reported-and-tested-by: Jiri Kosina <jkosina@suse.cz>
Reported-and-tested-by: Dave Jones <davej@fedoraproject.org>
After removing event structure creation from the generic layer there is
no reason for separate .should_send_event and .handle_event callbacks.
So just remove the first one.
Currently fsnotify framework creates one event structure for each
notification event and links this event into all interested notification
groups. This is done so that we save memory when several notification
groups are interested in the event. However the need for event
structure shared between inotify & fanotify bloats the event structure
so the result is often higher memory consumption.
Another problem is that fsnotify framework keeps path references with
outstanding events so that fanotify can return open file descriptors
with its events. This has the undesirable effect that filesystem cannot
be unmounted while there are outstanding events - a regression for
inotify compared to a situation before it was converted to fsnotify
framework. For fanotify this problem is hard to avoid and users of
fanotify should kind of expect this behavior when they ask for file
descriptors from notified files.
This patch changes fsnotify and its users to create separate event
structure for each group. This allows for much simpler code (~400 lines
removed by this patch) and also smaller event structures. For example
on 64-bit system original struct fsnotify_event consumes 120 bytes, plus
additional space for file name, additional 24 bytes for second and each
subsequent group linking the event, and additional 32 bytes for each
inotify group for private data. After the conversion inotify event
consumes 48 bytes plus space for file name which is considerably less
memory unless file names are long and there are several groups
interested in the events (both of which are uncommon). Fanotify event
fits in 56 bytes after the conversion (fanotify doesn't care about file
names so its events don't have to have it allocated). A win unless
there are four or more fanotify groups interested in the event.
The conversion also solves the problem with unmount when only inotify is
used as we don't have to grab path references for inotify events.
[hughd@google.com: fanotify: fix corruption preventing startup]
Rounding of name length when passing it to userspace was done in several
places. Provide a function to do it and use it in all places.
In inotify_new_watch() the number of watches for a group is compared
against the max number of allowed watches and increased afterwards. The
check and incrementation is not done atomically, so it is possible for
multiple concurrent threads to pass the check and increment the number
of marks above the allowed max.
This patch uses an inotify groups mark_lock to ensure that both check
and incrementation are done atomic. Furthermore we dont have to worry
about the race that allows a concurrent thread to add a watch just after
inotify_update_existing_watch() returned with -ENOENT anymore, since
this is also synchronized by the groups mark mutex now.
Signed-off-by: Lino Sanfilippo <LinoSanfilippo@gmx.de>
Pull VFS updates from Al Viro,
Misc cleanups all over the place, mainly wrt /proc interfaces (switch
create_proc_entry to proc_create(), get rid of the deprecated
create_proc_read_entry() in favor of using proc_create_data() and
seq_file etc).
7kloc removed.
* 'for-linus' of git://git.kernel.org/pub/scm/linux/kernel/git/viro/vfs: (204 commits)
don't bother with deferred freeing of fdtables
proc: Move non-public stuff from linux/proc_fs.h to fs/proc/internal.h
proc: Make the PROC_I() and PDE() macros internal to procfs
proc: Supply a function to remove a proc entry by PDE
take cgroup_open() and cpuset_open() to fs/proc/base.c
ppc: Clean up scanlog
ppc: Clean up rtas_flash driver somewhat
hostap: proc: Use remove_proc_subtree()
drm: proc: Use remove_proc_subtree()
drm: proc: Use minor->index to label things, not PDE->name
drm: Constify drm_proc_list[]
zoran: Don't print proc_dir_entry data in debug
reiserfs: Don't access the proc_dir_entry in r_open(), r_start() r_show()
proc: Supply an accessor for getting the data from a PDE's parent
airo: Use remove_proc_subtree()
rtl8192u: Don't need to save device proc dir PDE
rtl8187se: Use a dir under /proc/net/r8180/
proc: Add proc_mkdir_data()
proc: Move some bits from linux/proc_fs.h to linux/{of.h,signal.h,tty.h}
proc: Move PDE_NET() to fs/proc/proc_net.c
When we run the crackerjack testsuite, the inotify_add_watch test is
stalled.
This is caused by the invalid mask 0 - the task is waiting for the event
but it never comes. inotify_add_watch() should return -EINVAL as it did
before commit 676a0675cf92 ("inotify: remove broken mask checks causing
unmount to be EINVAL"). That commit removes the invalid mask check, but
that check is needed.
Check the mask's ALL_INOTIFY_BITS before the inotify_arg_to_mask() call.
If none are set, just return -EINVAL.
Because IN_UNMOUNT is in ALL_INOTIFY_BITS, this change will not trigger
the problem that above commit fixed.
[akpm@linux-foundation.org: fix build]
Signed-off-by: Zhao Hongjiang <zhaohongjiang@huawei.com>
Acked-by: Jim Somerville <Jim.Somerville@windriver.com>
Cc: Paul Gortmaker <paul.gortmaker@windriver.com>
Cc: Jerome Marchand <jmarchan@redhat.com>
Cc: <stable@vger.kernel.org>
Signed-off-by: Jeff Layton <jlayton@redhat.com>
Cc: Tejun Heo <tj@kernel.org>
... it's done already by __fput()
Convert to the much saner new idr interface.
Note that the adhoc cyclic id allocation is buggy. If wraparound
happens, the previous code with idr_get_new_above() may segfault and
the converted code will trigger WARN and return -EINVAL. Even if it's
fixed to wrap to zero, the code will be prone to unnecessary -ENOSPC
failures after the first wraparound. We probably need to implement
proper cyclic support in idr.
idr_destroy() can destroy idr by itself and idr_remove_all() is being
deprecated. Drop its usage.
Running the command:
inotifywait -e unmount /mnt/disk
immediately aborts with a -EINVAL return code. This is however a valid
parameter. This abort occurs only if unmount is the sole event
parameter. If other event parameters are supplied, then the unmount
event wait will work.
The problem was introduced by commit 44b350fc23e ("inotify: Fix mask
checks"). In that commit, it states:
The mask checks in inotify_update_existing_watch() and
inotify_new_watch() are useless because inotify_arg_to_mask()
sets FS_IN_IGNORED and FS_EVENT_ON_CHILD bits anyway.
But instead of removing the useless checks, it did this:
mask = inotify_arg_to_mask(arg);
- if (unlikely(!mask))
+ if (unlikely(!(mask & IN_ALL_EVENTS)))
return -EINVAL;
The problem is that IN_ALL_EVENTS doesn't include IN_UNMOUNT, and other
parts of the code keep IN_UNMOUNT separate from IN_ALL_EVENTS. So the
check should be:
if (unlikely(!(mask & (IN_ALL_EVENTS | IN_UNMOUNT))))
But inotify_arg_to_mask(arg) always sets the IN_UNMOUNT bit in the mask
anyway, so the check is always going to pass and thus should simply be
removed. Also note that inotify_arg_to_mask completely controls what
mask bits get set from arg, there's no way for invalid bits to get
enabled there.
Lets fix it by simply removing the useless broken checks.
Signed-off-by: Jim Somerville <Jim.Somerville@windriver.com>
Cc: <stable@vger.kernel.org> [2.6.37+]
Pull filesystem notification updates from Eric Paris:
"This pull mostly is about locking changes in the fsnotify system. By
switching the group lock from a spin_lock() to a mutex() we can now
hold the lock across things like iput(). This fixes a problem
involving unmounting a fs and having inodes be busy, first pointed out
by FAT, but reproducible with tmpfs.
This also restores signal driven I/O for inotify, which has been
broken since about 2.6.32."
Ugh. I *hate* the timing of this. It was rebased after the merge
window opened, and then left to sit with the pull request coming the day
before the merge window closes. That's just crap. But apparently the
patches themselves have been around for over a year, just gathering
dust, so now it's suddenly critical.
Fixed up semantic conflict in fs/notify/fdinfo.c as per Stephen
Rothwell's fixes from -next.
* 'for-next' of git://git.infradead.org/users/eparis/notify:
inotify: automatically restart syscalls
inotify: dont skip removal of watch descriptor if creation of ignored event failed
fanotify: dont merge permission events
fsnotify: make fasync generic for both inotify and fanotify
fsnotify: change locking order
fsnotify: dont put marks on temporary list when clearing marks by group
fsnotify: introduce locked versions of fsnotify_add_mark() and fsnotify_remove_mark()
fsnotify: pass group to fsnotify_destroy_mark()
fsnotify: use a mutex instead of a spinlock to protect a groups mark list
fanotify: add an extra flag to mark_remove_from_mask that indicates wheather a mark should be destroyed
fsnotify: take groups mark_lock before mark lock
fsnotify: use reference counting for groups
fsnotify: introduce fsnotify_get_group()
inotify, fanotify: replace fsnotify_put_group() with fsnotify_destroy_group()
This allow us to print out fsnotify details such as watchee inode, device,
mask and optionally a file handle.
For inotify objects if kernel compiled with exportfs support the output
will be
| pos: 0
| flags: 02000000
| inotify wd:3 ino:9e7e sdev:800013 mask:800afce ignored_mask:0 fhandle-bytes:8 fhandle-type:1 f_handle:7e9e0000640d1b6d
| inotify wd:2 ino:a111 sdev:800013 mask:800afce ignored_mask:0 fhandle-bytes:8 fhandle-type:1 f_handle:11a1000020542153
| inotify wd:1 ino:6b149 sdev:800013 mask:800afce ignored_mask:0 fhandle-bytes:8 fhandle-type:1 f_handle:49b1060023552153
If kernel compiled without exportfs support, the file handle
won't be provided but inode and device only.
| pos: 0
| flags: 02000000
For fanotify the output is like
| pos: 0
| flags: 04002
| fanotify flags:10 event-flags:0
| fanotify mnt_id:12 mask:3b ignored_mask:0
| fanotify ino:50205 sdev:800013 mask:3b ignored_mask:40000000 fhandle-bytes:8 fhandle-type:1 f_handle:05020500fb1d47e7
To minimize impact on general fsnotify code the new functionality
is gathered in fs/notify/fdinfo.c file.
Signed-off-by: Cyrill Gorcunov <gorcunov@openvz.org>
Acked-by: Pavel Emelyanov <xemul@parallels.com>
Cc: Andrey Vagin <avagin@openvz.org>
Cc: Al Viro <viro@ZenIV.linux.org.uk>
Cc: Alexey Dobriyan <adobriyan@gmail.com>
Cc: James Bottomley <jbottomley@parallels.com>
Cc: "Aneesh Kumar K.V" <aneesh.kumar@linux.vnet.ibm.com>
Cc: Matthew Helsley <matt.helsley@gmail.com>
Cc: "J. Bruce Fields" <bfields@fieldses.org>
Cc: Tvrtko Ursulin <tvrtko.ursulin@onelan.co.uk>
We were mistakenly returning EINTR when we found an outstanding signal.
Instead we should returen ERESTARTSYS and allow the kernel to handle
things the right way.
Patch-from: Oleg Nesterov <oleg@redhat.com>
Signed-off-by: Eric Paris <eparis@redhat.com>
failed
In inotify_ignored_and_remove_idr() the removal of a watch descriptor is skipped
if the allocation of an ignored event failed and we are leaking memory (the
watch descriptor and the mark linked to it).
This patch ensures that the watch descriptor is removed regardless of whether
event creation failed or not.
inotify is supposed to support async signal notification when information
is available on the inotify fd. This patch moves that support to generic
fsnotify functions so it can be used by all notification mechanisms.
In fsnotify_destroy_mark() dont get the group from the passed mark anymore,
but pass the group itself as an additional parameter to the function.
Get a group ref for each mark that is added to the groups list and release that
ref when the mark is freed in fsnotify_put_mark().
We also use get a group reference for duplicated marks and for private event
data.
Now we dont free a group any more when the number of marks becomes 0 but when
the groups ref count does. Since this will only happen when all marks are removed
from a groups mark list, we dont have to set the groups number of marks to 1 at
group creation.
Beside clearing all marks in fsnotify_destroy_group() we do also flush the
groups event queue. This is since events may hold references to groups (due to
private event data) and we have to put those references first before we get a
chance to put the final ref, which will result in a call to
fsnotify_final_destroy_group().
Currently in fsnotify_put_group() the ref count of a group is decremented and if
it becomes 0 fsnotify_destroy_group() is called. Since a groups ref count is only
at group creation set to 1 and never increased after that a call to fsnotify_put_group()
always results in a call to fsnotify_destroy_group().
With this patch fsnotify_destroy_group() is called directly.
* 'for-linus2' of git://git.profusion.mobi/users/lucas/linux-2.6:
Fix common misspellings
On an error path in inotify_init1 a normal user can trigger a double
free of struct user. This is a regression introduced by a2ae4cc9a16e
("inotify: stop kernel memory leak on file creation failure").
We fix this by making sure that if a group exists the user reference is
dropped when the group is cleaned up. We should not explictly drop the
reference on error and also drop the reference when the group is cleaned
up.
The new lifetime rules are that an inotify group lives from
inotify_new_group to the last fsnotify_put_group. Since the struct user
and inotify_devs are directly tied to this lifetime they are only
changed/updated in those two locations. We get rid of all special
casing of struct user or user->inotify_devs.
Cc: stable@kernel.org (2.6.37 and up)
If inotify_init is unable to allocate a new file for the new inotify
group we leak the new group. This patch drops the reference on the
group on file allocation failure.
Reported-by: Vegard Nossum <vegard.nossum@gmail.com>
cc: stable@kernel.org
The _IN_ in the naming is reserved for flags only used by inotify. Since I
am about to use this flag for fanotify rename it to be generic like the
rest.
All file_operations should get a .llseek operation so we can make
nonseekable_open the default for future file operations without a
.llseek pointer.
The three cases that we can automatically detect are no_llseek, seq_lseek
and default_llseek. For cases where we can we can automatically prove that
the file offset is always ignored, we use noop_llseek, which maintains
the current behavior of not returning an error from a seek.
New drivers should normally not use noop_llseek but instead use no_llseek
and call nonseekable_open at open time. Existing drivers can be converted
to do the same when the maintainer knows for certain that no user code
relies on calling seek on the device file.
The generated code is often incorrectly indented and right now contains
comments that clarify for each added line why a specific variant was
chosen. In the version that gets submitted upstream, the comments will
be gone and I will manually fix the indentation, because there does not
seem to be a way to do that using coccinelle.
Some amount of new code is currently sitting in linux-next that should get
the same modifications, which I will do at the end of the merge window.
Many thanks to Julia Lawall for helping me learn to write a semantic
patch that does all this.
===== begin semantic patch =====
// This adds an llseek= method to all file operations,
// as a preparation for making no_llseek the default.
// The rules are
// - use no_llseek explicitly if we do nonseekable_open
// - use seq_lseek for sequential files
// - use default_llseek if we know we access f_pos
// - use noop_llseek if we know we don't access f_pos,
// but we still want to allow users to call lseek
@ open1 exists @
identifier nested_open;
nested_open(...)
nonseekable_open(...)
@ open exists@
identifier open_f;
identifier i, f;
identifier open1.nested_open;
int open_f(struct inode *i, struct file *f)
nested_open(...)
@ read disable optional_qualifier exists @
identifier read_f;
identifier f, p, s, off;
type ssize_t, size_t, loff_t;
expression E;
identifier func;
ssize_t read_f(struct file *f, char *p, size_t s, loff_t *off)
*off = E
*off += E
func(..., off, ...)
E = *off
@ read_no_fpos disable optional_qualifier exists @
identifier read_f;
... when != off
@ write @
identifier write_f;
expression E;
identifier func;
ssize_t write_f(struct file *f, const char *p, size_t s, loff_t *off)
*off = E
*off += E
func(..., off, ...)
E = *off
@ write_no_fpos @
identifier write_f;
... when != off
@ fops0 @
identifier fops;
struct file_operations fops = {
@ has_llseek depends on fops0 @
identifier fops0.fops;
identifier llseek_f;
.llseek = llseek_f,
@ has_read depends on fops0 @
identifier read_f;
.read = read_f,
@ has_write depends on fops0 @
identifier write_f;
.write = write_f,
@ has_open depends on fops0 @
identifier open_f;
.open = open_f,
// use no_llseek if we call nonseekable_open
@ nonseekable1 depends on !has_llseek && has_open @
identifier nso ~= "nonseekable_open";
... .open = nso, ...
+.llseek = no_llseek, /* nonseekable */
@ nonseekable2 depends on !has_llseek @
identifier open.open_f;
... .open = open_f, ...
+.llseek = no_llseek, /* open uses nonseekable */
// use seq_lseek for sequential files
@ seq depends on !has_llseek @
identifier sr ~= "seq_read";
... .read = sr, ...
+.llseek = seq_lseek, /* we have seq_read */
// use default_llseek if there is a readdir
@ fops1 depends on !has_llseek && !nonseekable1 && !nonseekable2 && !seq @
identifier readdir_e;
// any other fop is used that changes pos
... .readdir = readdir_e, ...
+.llseek = default_llseek, /* readdir is present */
// use default_llseek if at least one of read/write touches f_pos
@ fops2 depends on !fops1 && !has_llseek && !nonseekable1 && !nonseekable2 && !seq @
identifier read.read_f;
// read fops use offset
... .read = read_f, ...
+.llseek = default_llseek, /* read accesses f_pos */
@ fops3 depends on !fops1 && !fops2 && !has_llseek && !nonseekable1 && !nonseekable2 && !seq @
identifier write.write_f;
// write fops use offset
... .write = write_f, ...
+ .llseek = default_llseek, /* write accesses f_pos */
// Use noop_llseek if neither read nor write accesses f_pos
@ fops4 depends on !fops1 && !fops2 && !fops3 && !has_llseek && !nonseekable1 && !nonseekable2 && !seq @
identifier read_no_fpos.read_f;
identifier write_no_fpos.write_f;
.write = write_f,
.read = read_f,
+.llseek = noop_llseek, /* read and write both use no f_pos */
@ depends on has_write && !has_read && !fops1 && !fops2 && !has_llseek && !nonseekable1 && !nonseekable2 && !seq @
+.llseek = noop_llseek, /* write uses no f_pos */
@ depends on has_read && !has_write && !fops1 && !fops2 && !has_llseek && !nonseekable1 && !nonseekable2 && !seq @
+.llseek = noop_llseek, /* read uses no f_pos */
@ depends on !has_read && !has_write && !fops1 && !fops2 && !has_llseek && !nonseekable1 && !nonseekable2 && !seq @
+.llseek = noop_llseek, /* no read or write fn */
===== End semantic patch =====
Cc: Julia Lawall <julia@diku.dk>
This reverts commit 3bcf3860a4ff9bbc522820b4b765e65e4deceb3e (and the
accompanying commit c1e5c954020e "vfs/fsnotify: fsnotify_close can delay
the final work in fput" that was a horribly ugly hack to make it work at
all).
The 'struct file' approach not only causes that disgusting hack, it
somehow breaks pulseaudio, probably due to some other subtlety with
f_count handling.
Fix up various conflicts due to later fsnotify work.
fanotify currently, when given a vfsmount_mark will look up (if it exists)
the corresponding inode mark. This patch drops that lookup and uses the
mark provided.
should_send_event() and handle_event() will both need to look up the inode
event if they get a vfsmount event. Lets just pass both at the same time
since we have them both after walking the lists in lockstep.
group->mask is now useless. It was originally a shortcut for fsnotify to
save on performance. These checks are now redundant, so we remove them.
The change to use srcu and walk the object list rather than the global
fsnotify_group list means that should_send_event is no longer needed for a
number of groups and can be simplified for others. Do that.
inotify now gets a mark in the should_send_event and handle_event
functions. Rather than look up the mark themselves inotify should just use
the mark it was handed.
With the change of fsnotify to use srcu walking the marks list instead of
walking the global groups list we now know the mark in question. The code can
send the mark to the group's handling functions and the groups won't have to
find those marks themselves.
Al explains that calling dentry_open() with a mnt/dentry pair is only
garunteed to be safe if they are already used in an open struct file. To
make sure this is the case don't store and use a struct path in fsnotify,
always use a struct file.
Rather than the horrific void ** argument and such just to pass the
fanotify_merge event back to the caller of fsnotify_add_notify_event() have
those things return an event if it was different than the event suggusted to
be added.
It can be hard to debug fsnotify since there are so few printks. Use
pr_debug to allow for dynamic debugging.
inotify_new_watch() are useless because inotify_arg_to_mask() sets
inotify uses bits called IN_* and fsnotify uses bits called FS_*. These
need to line up. This patch adds build time checks to make sure noone can
change these bits so they are not the same.
An inotify watch on a directory will send events for children even if those
children have been unlinked. This patch add a new inotify flag IN_EXCL_UNLINK
which allows a watch to specificy they don't care about unlinked children.
This should fix performance problems seen by tasks which add a watch to
/tmp and then are overrun with events when other processes are reading and
writing to unlinked files they created in /tmp.
https://bugzilla.kernel.org/show_bug.cgi?id=16296
Requested-by: Matthias Clasen <mclasen@redhat.com>
Since the .31 or so notify rewrite inotify has not sent events about
inodes which are unmounted. This patch restores those events.
During the large inotify rewrite to fsnotify I completely dropped support
for IN_ONESHOT. Reimplement that support.
