path: root/fs/notify
2009-07-02fs/notify/inotify: decrement user inotify count on closeKeith Packard
The per-user inotify_devs value is incremented each time a new file is allocated, but never decremented. This led to inotify_init failing after a limited number of calls. Signed-off-by: Keith Packard <keithp@keithp.com> Signed-off-by: Eric Paris <eparis@redhat.com>
2009-06-19inotify: inotify_destroy_mark_entry could get called twiceEric Paris
inotify_destroy_mark_entry could get called twice for the same mark since it is called directly in inotify_rm_watch and when the mark is being destroyed for another reason. As an example assume that the file being watched was just deleted so inotify_destroy_mark_entry would get called from the path fsnotify_inoderemove() -> fsnotify_destroy_marks_by_inode() -> fsnotify_destroy_mark_entry() -> inotify_destroy_mark_entry(). If this happened at the same time as userspace tried to remove a watch via inotify_rm_watch we could attempt to remove the mark from the idr twice and could thus double dec the ref cnt and potentially could be in a use after free/double free situation. The fix is to have inotify_rm_watch use the generic recursive safe fsnotify_destroy_mark_by_entry() so we are sure the inotify_destroy_mark_entry() function can only be called one. This patch also renames the function to inotify_ingored_remove_idr() so it is clear what is actually going on in the function. Hopefully this fixes: [ 20.342058] idr_remove called for id=20 which is not allocated. [ 20.348000] Pid: 1860, comm: udevd Not tainted 2.6.30-tip #1077 [ 20.353933] Call Trace: [ 20.356410] [<ffffffff811a82b7>] idr_remove+0x115/0x18f [ 20.361737] [<ffffffff8134259d>] ? _spin_lock+0x6d/0x75 [ 20.367061] [<ffffffff8111640a>] ? inotify_destroy_mark_entry+0xa3/0xcf [ 20.373771] [<ffffffff8111641e>] inotify_destroy_mark_entry+0xb7/0xcf [ 20.380306] [<ffffffff81115913>] inotify_freeing_mark+0xe/0x10 [ 20.386238] [<ffffffff8111410d>] fsnotify_destroy_mark_by_entry+0x143/0x170 [ 20.393293] [<ffffffff811163a3>] inotify_destroy_mark_entry+0x3c/0xcf [ 20.399829] [<ffffffff811164d1>] sys_inotify_rm_watch+0x9b/0xc6 [ 20.405850] [<ffffffff8100bcdb>] system_call_fastpath+0x16/0x1b Reported-by: Peter Zijlstra <peterz@infradead.org> Signed-off-by: Eric Paris <eparis@redhat.com> Tested-by: Peter Ziljlstra <peterz@infradead.org>
2009-06-11fsnotify: allow groups to set freeing_mark to nullEric Paris
Most fsnotify listeners (all but inotify) do not care about marks being freed. Allow groups to set freeing_mark to null and do not call any function if it is set that way. Signed-off-by: Eric Paris <eparis@redhat.com>
2009-06-11inotify/dnotify: should_send_event shouldn't match on FS_EVENT_ON_CHILDEric Paris
inotify and dnotify will both indicate that they want any event which came from a child inode. The fix is to mask off FS_EVENT_ON_CHILD when deciding if inotify or dnotify is interested in a given event. Signed-off-by: Eric Paris <eparis@redhat.com>
2009-06-11dnotify: do not bother to lock entry->lock when reading maskEric Paris
entry->lock is needed to make sure entry->mask does not change while manipulating it. In dnotify_should_send_event() we don't care if we get an old or a new mask value out of this entry so there is no point it taking the lock. Signed-off-by: Eric Paris <eparis@redhat.com>
2009-06-11dnotify: do not use ?true:false when assigning to a boolEric Paris
dnotify_should send event assigned a bool using ?true:false when computing a bit operation. This is poitless and the bool type does this for us. Signed-off-by: Eric Paris <eparis@redhat.com>
2009-06-11inotify: reimplement inotify using fsnotifyEric Paris
Reimplement inotify_user using fsnotify. This should be feature for feature exactly the same as the original inotify_user. This does not make any changes to the in kernel inotify feature used by audit. Those patches (and the eventual removal of in kernel inotify) will come after the new inotify_user proves to be working correctly. Signed-off-by: Eric Paris <eparis@redhat.com> Acked-by: Al Viro <viro@zeniv.linux.org.uk> Cc: Christoph Hellwig <hch@lst.de>
2009-06-11fsnotify: handle filesystem unmounts with fsnotify marksEric Paris
When an fs is unmounted with an fsnotify mark entry attached to one of its inodes we need to destroy that mark entry and we also (like inotify) send an unmount event. Signed-off-by: Eric Paris <eparis@redhat.com> Acked-by: Al Viro <viro@zeniv.linux.org.uk> Cc: Christoph Hellwig <hch@lst.de>
2009-06-11fsnotify: fsnotify marks on inodes pin them in coreEric Paris
This patch pins any inodes with an fsnotify mark in core. The idea is that as soon as the mark is removed from the inode->fsnotify_mark_entries list the inode will be iput. In reality is doesn't quite work exactly this way. The igrab will happen when the mark is added to an inode, but the iput will happen when the inode pointer is NULL'd inside the mark. It's possible that 2 racing things will try to remove the mark from different directions. One may try to remove the mark because of an explicit request and one might try to remove it because the inode was deleted. It's possible that the removal because of inode deletion will remove the mark from the inode's list, but the removal by explicit request will actually set entry->inode == NULL; and call the iput. This is safe. Signed-off-by: Eric Paris <eparis@redhat.com> Acked-by: Al Viro <viro@zeniv.linux.org.uk> Cc: Christoph Hellwig <hch@lst.de>
2009-06-11fsnotify: allow groups to add private data to eventsEric Paris
inotify needs per group information attached to events. This patch allows groups to attach private information and implements a callback so that information can be freed when an event is being destroyed. Signed-off-by: Eric Paris <eparis@redhat.com> Acked-by: Al Viro <viro@zeniv.linux.org.uk> Cc: Christoph Hellwig <hch@lst.de>
2009-06-11fsnotify: add correlations between eventsEric Paris
As part of the standard inotify events it includes a correlation cookie between two dentry move operations. This patch includes the same behaviour in fsnotify events. It is needed so that inotify userspace can be implemented on top of fsnotify. Signed-off-by: Eric Paris <eparis@redhat.com> Acked-by: Al Viro <viro@zeniv.linux.org.uk> Cc: Christoph Hellwig <hch@lst.de>
2009-06-11fsnotify: include pathnames with entries when possibleEric Paris
When inotify wants to send events to a directory about a child it includes the name of the original file. This patch collects that filename and makes it available for notification. Signed-off-by: Eric Paris <eparis@redhat.com> Acked-by: Al Viro <viro@zeniv.linux.org.uk> Cc: Christoph Hellwig <hch@lst.de>
2009-06-11fsnotify: generic notification queue and waitqEric Paris
inotify needs to do asyc notification in which event information is stored on a queue until the listener is ready to receive it. This patch implements a generic notification queue for inotify (and later fanotify) to store events to be sent at a later time. Signed-off-by: Eric Paris <eparis@redhat.com> Acked-by: Al Viro <viro@zeniv.linux.org.uk> Cc: Christoph Hellwig <hch@lst.de>
2009-06-11dnotify: reimplement dnotify using fsnotifyEric Paris
Reimplement dnotify using fsnotify. Signed-off-by: Eric Paris <eparis@redhat.com> Acked-by: Al Viro <viro@zeniv.linux.org.uk> Cc: Christoph Hellwig <hch@lst.de>
2009-06-11fsnotify: parent event notificationEric Paris
inotify and dnotify both use a similar parent notification mechanism. We add a generic parent notification mechanism to fsnotify for both of these to use. This new machanism also adds the dentry flag optimization which exists for inotify to dnotify. Signed-off-by: Eric Paris <eparis@redhat.com> Acked-by: Al Viro <viro@zeniv.linux.org.uk> Cc: Christoph Hellwig <hch@lst.de>
2009-06-11fsnotify: add marks to inodes so groups can interpret how to handle those inodesEric Paris
This patch creates a way for fsnotify groups to attach marks to inodes. These marks have little meaning to the generic fsnotify infrastructure and thus their meaning should be interpreted by the group that attached them to the inode's list. dnotify and inotify will make use of these markings to indicate which inodes are of interest to their respective groups. But this implementation has the useful property that in the future other listeners could actually use the marks for the exact opposite reason, aka to indicate which inodes it had NO interest in. Signed-off-by: Eric Paris <eparis@redhat.com> Acked-by: Al Viro <viro@zeniv.linux.org.uk> Cc: Christoph Hellwig <hch@lst.de>
2009-06-11fsnotify: unified filesystem notification backendEric Paris
fsnotify is a backend for filesystem notification. fsnotify does not provide any userspace interface but does provide the basis needed for other notification schemes such as dnotify. fsnotify can be extended to be the backend for inotify or the upcoming fanotify. fsnotify provides a mechanism for "groups" to register for some set of filesystem events and to then deliver those events to those groups for processing. fsnotify has a number of benefits, the first being actually shrinking the size of an inode. Before fsnotify to support both dnotify and inotify an inode had unsigned long i_dnotify_mask; /* Directory notify events */ struct dnotify_struct *i_dnotify; /* for directory notifications */ struct list_head inotify_watches; /* watches on this inode */ struct mutex inotify_mutex; /* protects the watches list But with fsnotify this same functionallity (and more) is done with just __u32 i_fsnotify_mask; /* all events for this inode */ struct hlist_head i_fsnotify_mark_entries; /* marks on this inode */ That's right, inotify, dnotify, and fanotify all in 64 bits. We used that much space just in inotify_watches alone, before this patch set. fsnotify object lifetime and locking is MUCH better than what we have today. inotify locking is incredibly complex. See 8f7b0ba1c8539 as an example of what's been busted since inception. inotify needs to know internal semantics of superblock destruction and unmounting to function. The inode pinning and vfs contortions are horrible. no fsnotify implementers do allocation under locks. This means things like f04b30de3 which (due to an overabundance of caution) changes GFP_KERNEL to GFP_NOFS can be reverted. There are no longer any allocation rules when using or implementing your own fsnotify listener. fsnotify paves the way for fanotify. In brief fanotify is a notification mechanism that delivers the lisener both an 'event' and an open file descriptor to the object in question. This means that fanotify is pathname agnostic. Some on lkml may not care for the original companies or users that pushed for TALPA, but fanotify was designed with flexibility and input for other users in mind. The readahead group expressed interest in fanotify as it could be used to profile disk access on boot without breaking the audit system. The desktop search groups have also expressed interest in fanotify as it solves a number of the race conditions and problems present with managing inotify when more than a limited number of specific files are of interest. fanotify can provide for a userspace access control system which makes it a clean interface for AV vendors to hook without trying to do binary patching on the syscall table, LSM, and everywhere else they do their things today. With this patch series fanotify can be implemented in less than 1200 lines of easy to review code. Almost all of which is the socket based user interface. This patch series builds fsnotify to the point that it can implement dnotify and inotify_user. Patches exist and will be sent soon after acceptance to finish the in kernel inotify conversion (audit) and implement fanotify. Signed-off-by: Eric Paris <eparis@redhat.com> Acked-by: Al Viro <viro@zeniv.linux.org.uk> Cc: Christoph Hellwig <hch@lst.de>
2009-05-06inotify: use GFP_NOFS in kernel_event() to work around a lockdep false-positiveWu Fengguang
There is what we believe to be a false positive reported by lockdep. inotify_inode_queue_event() => take inotify_mutex => kernel_event() => kmalloc() => SLOB => alloc_pages_node() => page reclaim => slab reclaim => dcache reclaim => inotify_inode_is_dead => take inotify_mutex => deadlock The plan is to fix this via lockdep annotation, but that is proving to be quite involved. The patch flips the allocation over to GFP_NFS to shut the warning up, for the 2.6.30 release. Hopefully we will fix this for real in 2.6.31. I'll queue a patch in -mm to switch it back to GFP_KERNEL so we don't forget. ================================= [ INFO: inconsistent lock state ] 2.6.30-rc2-next-20090417 #203 --------------------------------- inconsistent {RECLAIM_FS-ON-W} -> {IN-RECLAIM_FS-W} usage. kswapd0/380 [HC0[0]:SC0[0]:HE1:SE1] takes: (&inode->inotify_mutex){+.+.?.}, at: [<ffffffff8112f1b5>] inotify_inode_is_dead+0x35/0xb0 {RECLAIM_FS-ON-W} state was registered at: [<ffffffff81079188>] mark_held_locks+0x68/0x90 [<ffffffff810792a5>] lockdep_trace_alloc+0xf5/0x100 [<ffffffff810f5261>] __kmalloc_node+0x31/0x1e0 [<ffffffff81130652>] kernel_event+0xe2/0x190 [<ffffffff81130826>] inotify_dev_queue_event+0x126/0x230 [<ffffffff8112f096>] inotify_inode_queue_event+0xc6/0x110 [<ffffffff8110444d>] vfs_create+0xcd/0x140 [<ffffffff8110825d>] do_filp_open+0x88d/0xa20 [<ffffffff810f6b68>] do_sys_open+0x98/0x140 [<ffffffff810f6c50>] sys_open+0x20/0x30 [<ffffffff8100c272>] system_call_fastpath+0x16/0x1b [<ffffffffffffffff>] 0xffffffffffffffff irq event stamp: 690455 hardirqs last enabled at (690455): [<ffffffff81564fe4>] _spin_unlock_irqrestore+0x44/0x80 hardirqs last disabled at (690454): [<ffffffff81565372>] _spin_lock_irqsave+0x32/0xa0 softirqs last enabled at (690178): [<ffffffff81052282>] __do_softirq+0x202/0x220 softirqs last disabled at (690157): [<ffffffff8100d50c>] call_softirq+0x1c/0x50 other info that might help us debug this: 2 locks held by kswapd0/380: #0: (shrinker_rwsem){++++..}, at: [<ffffffff810d0bd7>] shrink_slab+0x37/0x180 #1: (&type->s_umount_key#17){++++..}, at: [<ffffffff8110cfbf>] shrink_dcache_memory+0x11f/0x1e0 stack backtrace: Pid: 380, comm: kswapd0 Not tainted 2.6.30-rc2-next-20090417 #203 Call Trace: [<ffffffff810789ef>] print_usage_bug+0x19f/0x200 [<ffffffff81018bff>] ? save_stack_trace+0x2f/0x50 [<ffffffff81078f0b>] mark_lock+0x4bb/0x6d0 [<ffffffff810799e0>] ? check_usage_forwards+0x0/0xc0 [<ffffffff8107b142>] __lock_acquire+0xc62/0x1ae0 [<ffffffff810f478c>] ? slob_free+0x10c/0x370 [<ffffffff8107c0a1>] lock_acquire+0xe1/0x120 [<ffffffff8112f1b5>] ? inotify_inode_is_dead+0x35/0xb0 [<ffffffff81562d43>] mutex_lock_nested+0x63/0x420 [<ffffffff8112f1b5>] ? inotify_inode_is_dead+0x35/0xb0 [<ffffffff8112f1b5>] ? inotify_inode_is_dead+0x35/0xb0 [<ffffffff81012fe9>] ? sched_clock+0x9/0x10 [<ffffffff81077165>] ? lock_release_holdtime+0x35/0x1c0 [<ffffffff8112f1b5>] inotify_inode_is_dead+0x35/0xb0 [<ffffffff8110c9dc>] dentry_iput+0xbc/0xe0 [<ffffffff8110cb23>] d_kill+0x33/0x60 [<ffffffff8110ce23>] __shrink_dcache_sb+0x2d3/0x350 [<ffffffff8110cffa>] shrink_dcache_memory+0x15a/0x1e0 [<ffffffff810d0cc5>] shrink_slab+0x125/0x180 [<ffffffff810d1540>] kswapd+0x560/0x7a0 [<ffffffff810ce160>] ? isolate_pages_global+0x0/0x2c0 [<ffffffff81065a30>] ? autoremove_wake_function+0x0/0x40 [<ffffffff8107953d>] ? trace_hardirqs_on+0xd/0x10 [<ffffffff810d0fe0>] ? kswapd+0x0/0x7a0 [<ffffffff8106555b>] kthread+0x5b/0xa0 [<ffffffff8100d40a>] child_rip+0xa/0x20 [<ffffffff8100cdd0>] ? restore_args+0x0/0x30 [<ffffffff81065500>] ? kthread+0x0/0xa0 [<ffffffff8100d400>] ? child_rip+0x0/0x20 [eparis@redhat.com: fix audit too] Cc: Al Viro <viro@zeniv.linux.org.uk> Cc: Matt Mackall <mpm@selenic.com> Cc: Christoph Lameter <clameter@sgi.com> Signed-off-by: Wu Fengguang <fengguang.wu@intel.com> Signed-off-by: Eric Paris <eparis@redhat.com> Cc: Peter Zijlstra <a.p.zijlstra@chello.nl> Signed-off-by: Andrew Morton <akpm@linux-foundation.org> Signed-off-by: Linus Torvalds <torvalds@linux-foundation.org>
2009-03-27fs: avoid I_NEW inodesNick Piggin
To be on the safe side, it should be less fragile to exclude I_NEW inodes from inode list scans by default (unless there is an important reason to have them). Normally they will get excluded (eg. by zero refcount or writecount etc), however it is a bit fragile for list walkers to know exactly what parts of the inode state is set up and valid to test when in I_NEW. So along these lines, move I_NEW checks upward as well (sometimes taking I_FREEING etc checks with them too -- this shouldn't be a problem should it?) Signed-off-by: Nick Piggin <npiggin@suse.de> Acked-by: Jan Kara <jack@suse.cz> Cc: Al Viro <viro@zeniv.linux.org.uk> Signed-off-by: Andrew Morton <akpm@linux-foundation.org> Signed-off-by: Al Viro <viro@zeniv.linux.org.uk>
2009-02-18inotify: fix GFP_KERNEL related deadlockIngo Molnar
Enhanced lockdep coverage of __GFP_NOFS turned up this new lockdep assert: [ 1093.677775] [ 1093.677781] ================================= [ 1093.680031] [ INFO: inconsistent lock state ] [ 1093.680031] 2.6.29-rc5-tip-01504-gb49eca1-dirty #1 [ 1093.680031] --------------------------------- [ 1093.680031] inconsistent {RECLAIM_FS-ON-W} -> {IN-RECLAIM_FS-W} usage. [ 1093.680031] kswapd0/308 [HC0[0]:SC0[0]:HE1:SE1] takes: [ 1093.680031] (&inode->inotify_mutex){+.+.?.}, at: [<c0205942>] inotify_inode_is_dead+0x20/0x80 [ 1093.680031] {RECLAIM_FS-ON-W} state was registered at: [ 1093.680031] [<c01696b9>] mark_held_locks+0x43/0x5b [ 1093.680031] [<c016baa4>] lockdep_trace_alloc+0x6c/0x6e [ 1093.680031] [<c01cf8b0>] kmem_cache_alloc+0x20/0x150 [ 1093.680031] [<c040d0ec>] idr_pre_get+0x27/0x6c [ 1093.680031] [<c02056e3>] inotify_handle_get_wd+0x25/0xad [ 1093.680031] [<c0205f43>] inotify_add_watch+0x7a/0x129 [ 1093.680031] [<c020679e>] sys_inotify_add_watch+0x20f/0x250 [ 1093.680031] [<c010389e>] sysenter_do_call+0x12/0x35 [ 1093.680031] [<ffffffff>] 0xffffffff [ 1093.680031] irq event stamp: 60417 [ 1093.680031] hardirqs last enabled at (60417): [<c018d5f5>] call_rcu+0x53/0x59 [ 1093.680031] hardirqs last disabled at (60416): [<c018d5b9>] call_rcu+0x17/0x59 [ 1093.680031] softirqs last enabled at (59656): [<c0146229>] __do_softirq+0x157/0x16b [ 1093.680031] softirqs last disabled at (59651): [<c0106293>] do_softirq+0x74/0x15d [ 1093.680031] [ 1093.680031] other info that might help us debug this: [ 1093.680031] 2 locks held by kswapd0/308: [ 1093.680031] #0: (shrinker_rwsem){++++..}, at: [<c01b0502>] shrink_slab+0x36/0x189 [ 1093.680031] #1: (&type->s_umount_key#4){+++++.}, at: [<c01e6d77>] shrink_dcache_memory+0x110/0x1fb [ 1093.680031] [ 1093.680031] stack backtrace: [ 1093.680031] Pid: 308, comm: kswapd0 Not tainted 2.6.29-rc5-tip-01504-gb49eca1-dirty #1 [ 1093.680031] Call Trace: [ 1093.680031] [<c016947a>] valid_state+0x12a/0x13d [ 1093.680031] [<c016954e>] mark_lock+0xc1/0x1e9 [ 1093.680031] [<c016a5b4>] ? check_usage_forwards+0x0/0x3f [ 1093.680031] [<c016ab74>] __lock_acquire+0x2c6/0xac8 [ 1093.680031] [<c01688d9>] ? register_lock_class+0x17/0x228 [ 1093.680031] [<c016b3d3>] lock_acquire+0x5d/0x7a [ 1093.680031] [<c0205942>] ? inotify_inode_is_dead+0x20/0x80 [ 1093.680031] [<c08824c4>] __mutex_lock_common+0x3a/0x4cb [ 1093.680031] [<c0205942>] ? inotify_inode_is_dead+0x20/0x80 [ 1093.680031] [<c08829ed>] mutex_lock_nested+0x2e/0x36 [ 1093.680031] [<c0205942>] ? inotify_inode_is_dead+0x20/0x80 [ 1093.680031] [<c0205942>] inotify_inode_is_dead+0x20/0x80 [ 1093.680031] [<c01e6672>] dentry_iput+0x90/0xc2 [ 1093.680031] [<c01e67a3>] d_kill+0x21/0x45 [ 1093.680031] [<c01e6a46>] __shrink_dcache_sb+0x27f/0x355 [ 1093.680031] [<c01e6dc5>] shrink_dcache_memory+0x15e/0x1fb [ 1093.680031] [<c01b05ed>] shrink_slab+0x121/0x189 [ 1093.680031] [<c01b0d12>] kswapd+0x39f/0x561 [ 1093.680031] [<c01ae499>] ? isolate_pages_global+0x0/0x233 [ 1093.680031] [<c0157eae>] ? autoremove_wake_function+0x0/0x43 [ 1093.680031] [<c01b0973>] ? kswapd+0x0/0x561 [ 1093.680031] [<c0157daf>] kthread+0x41/0x82 [ 1093.680031] [<c0157d6e>] ? kthread+0x0/0x82 [ 1093.680031] [<c01043ab>] kernel_thread_helper+0x7/0x10 inotify_handle_get_wd() does idr_pre_get() which does a kmem_cache_alloc() without __GFP_FS - and is hence deadlockable under extreme MM pressure. Signed-off-by: Ingo Molnar <mingo@elte.hu> Acked-by: Peter Zijlstra <a.p.zijlstra@chello.nl> Cc: MinChan Kim <minchan.kim@gmail.com> Cc: Nick Piggin <nickpiggin@yahoo.com.au> Signed-off-by: Andrew Morton <akpm@linux-foundation.org> Signed-off-by: Linus Torvalds <torvalds@linux-foundation.org>
2009-01-26inotify: clean up inotify_read and fix locking problemsVegard Nossum
If userspace supplies an invalid pointer to a read() of an inotify instance, the inotify device's event list mutex is unlocked twice. This causes an unbalance which effectively leaves the data structure unprotected, and we can trigger oopses by accessing the inotify instance from different tasks concurrently. The best fix (contributed largely by Linus) is a total rewrite of the function in question: On Thu, Jan 22, 2009 at 7:05 AM, Linus Torvalds wrote: > The thing to notice is that: > > - locking is done in just one place, and there is no question about it > not having an unlock. > > - that whole double-while(1)-loop thing is gone. > > - use multiple functions to make nesting and error handling sane > > - do error testing after doing the things you always need to do, ie do > this: > > mutex_lock(..) > ret = function_call(); > mutex_unlock(..) > > .. test ret here .. > > instead of doing conditional exits with unlocking or freeing. > > So if the code is written in this way, it may still be buggy, but at least > it's not buggy because of subtle "forgot to unlock" or "forgot to free" > issues. > > This _always_ unlocks if it locked, and it always frees if it got a > non-error kevent. Cc: John McCutchan <ttb@tentacle.dhs.org> Cc: Robert Love <rlove@google.com> Cc: <stable@kernel.org> Signed-off-by: Vegard Nossum <vegard.nossum@gmail.com> Signed-off-by: Linus Torvalds <torvalds@linux-foundation.org>
2009-01-14[CVE-2009-0029] System call wrappers part 29Heiko Carstens
2009-01-14[CVE-2009-0029] System call wrappers part 28Heiko Carstens
2009-01-05inotify: fix type errors in interfacesMichael Kerrisk
The problems lie in the types used for some inotify interfaces, both at the kernel level and at the glibc level. This mail addresses the kernel problem. I will follow up with some suggestions for glibc changes. For the sys_inotify_rm_watch() interface, the type of the 'wd' argument is currently 'u32', it should be '__s32' . That is Robert's suggestion, and is consistent with the other declarations of watch descriptors in the kernel source, in particular, the inotify_event structure in include/linux/inotify.h: struct inotify_event { __s32 wd; /* watch descriptor */ __u32 mask; /* watch mask */ __u32 cookie; /* cookie to synchronize two events */ __u32 len; /* length (including nulls) of name */ char name[0]; /* stub for possible name */ }; The patch makes the changes needed for inotify_rm_watch(). Signed-off-by: Michael Kerrisk <mtk.manpages@googlemail.com> Cc: Robert Love <rlove@google.com> Cc: Vegard Nossum <vegard.nossum@gmail.com> Cc: Ulrich Drepper <drepper@redhat.com> Signed-off-by: Andrew Morton <akpm@linux-foundation.org> Signed-off-by: Al Viro <viro@zeniv.linux.org.uk>
2008-12-31filesystem notification: create fs/notify to contain all fs notificationEric Paris
Creating a generic filesystem notification interface, fsnotify, which will be used by inotify, dnotify, and eventually fanotify is really starting to clutter the fs directory. This patch simply moves inotify and dnotify into fs/notify/inotify and fs/notify/dnotify respectively to make both current fs/ and future notification tidier. Signed-off-by: Eric Paris <eparis@redhat.com> Signed-off-by: Al Viro <viro@zeniv.linux.org.uk>
