path: root/fs/notify
2012-01-25fsnotify: don't BUG in fsnotify_destroy_mark()Miklos Szeredi
commit fed474857efbed79cd390d0aee224231ca718f63 upstream. Removing the parent of a watched file results in "kernel BUG at fs/notify/mark.c:139". To reproduce add "-w /tmp/audit/dir/watched_file" to audit.rules rm -rf /tmp/audit/dir This is caused by fsnotify_destroy_mark() being called without an extra reference taken by the caller. Reported by Francesco Cosoleto here: https://bugzilla.novell.com/show_bug.cgi?id=689860 Fix by removing the BUG_ON and adding a comment about not accessing mark after the iput. Signed-off-by: Miklos Szeredi <mszeredi@suse.cz> Signed-off-by: Linus Torvalds <torvalds@linux-foundation.org> Signed-off-by: Greg Kroah-Hartman <gregkh@suse.de>
2011-04-07Merge branch 'for-linus2' of git://git.profusion.mobi/users/lucas/linux-2.6Linus Torvalds
* 'for-linus2' of git://git.profusion.mobi/users/lucas/linux-2.6: Fix common misspellings
2011-04-05inotify: fix double free/corruption of stuct userEric Paris
On an error path in inotify_init1 a normal user can trigger a double free of struct user. This is a regression introduced by a2ae4cc9a16e ("inotify: stop kernel memory leak on file creation failure"). We fix this by making sure that if a group exists the user reference is dropped when the group is cleaned up. We should not explictly drop the reference on error and also drop the reference when the group is cleaned up. The new lifetime rules are that an inotify group lives from inotify_new_group to the last fsnotify_put_group. Since the struct user and inotify_devs are directly tied to this lifetime they are only changed/updated in those two locations. We get rid of all special casing of struct user or user->inotify_devs. Signed-off-by: Eric Paris <eparis@redhat.com> Cc: stable@kernel.org (2.6.37 and up) Signed-off-by: Linus Torvalds <torvalds@linux-foundation.org>
2011-03-24fs: rename inode_lock to inode_hash_lockDave Chinner
All that remains of the inode_lock is protecting the inode hash list manipulation and traversals. Rename the inode_lock to inode_hash_lock to reflect it's actual function. Signed-off-by: Dave Chinner <dchinner@redhat.com> Signed-off-by: Al Viro <viro@zeniv.linux.org.uk>
2011-03-24fs: move i_sb_list out from under inode_lockDave Chinner
Protect the per-sb inode list with a new global lock inode_sb_list_lock and use it to protect the list manipulations and traversals. This lock replaces the inode_lock as the inodes on the list can be validity checked while holding the inode->i_lock and hence the inode_lock is no longer needed to protect the list. Signed-off-by: Dave Chinner <dchinner@redhat.com> Signed-off-by: Al Viro <viro@zeniv.linux.org.uk>
2011-03-24fs: protect inode->i_state with inode->i_lockDave Chinner
Protect inode state transitions and validity checks with the inode->i_lock. This enables us to make inode state transitions independently of the inode_lock and is the first step to peeling away the inode_lock from the code. This requires that __iget() is done atomically with i_state checks during list traversals so that we don't race with another thread marking the inode I_FREEING between the state check and grabbing the reference. Also remove the unlock_new_inode() memory barrier optimisation required to avoid taking the inode_lock when clearing I_NEW. Simplify the code by simply taking the inode->i_lock around the state change and wakeup. Because the wakeup is no longer tricky, remove the wake_up_inode() function and open code the wakeup where necessary. Signed-off-by: Dave Chinner <dchinner@redhat.com> Signed-off-by: Al Viro <viro@zeniv.linux.org.uk>
2011-03-01Remove one to many n's in a wordJustin P. Mattock
Signed-off-by: Justin P. Mattock <justinmattock@gmail.com> Signed-off-by: Jiri Kosina <jkosina@suse.cz>
2011-01-13Merge branch 'for-next' of ↵Linus Torvalds
git://git.kernel.org/pub/scm/linux/kernel/git/jikos/trivial * 'for-next' of git://git.kernel.org/pub/scm/linux/kernel/git/jikos/trivial: (43 commits) Documentation/trace/events.txt: Remove obsolete sched_signal_send. writeback: fix global_dirty_limits comment runtime -> real-time ppc: fix comment typo singal -> signal drivers: fix comment typo diable -> disable. m68k: fix comment typo diable -> disable. wireless: comment typo fix diable -> disable. media: comment typo fix diable -> disable. remove doc for obsolete dynamic-printk kernel-parameter remove extraneous 'is' from Documentation/iostats.txt Fix spelling milisec -> ms in snd_ps3 module parameter description Fix spelling mistakes in comments Revert conflicting V4L changes i7core_edac: fix typos in comments mm/rmap.c: fix comment sound, ca0106: Fix assignment to 'channel'. hrtimer: fix a typo in comment init/Kconfig: fix typo anon_inodes: fix wrong function name in comment fix comment typos concerning "consistent" poll: fix a typo in comment ... Fix up trivial conflicts in: - drivers/net/wireless/iwlwifi/iwl-core.c (moved to iwl-legacy.c) - fs/ext4/ext4.h Also fix missed 'diabled' typo in drivers/net/bnx2x/bnx2x.h while at it.
2011-01-07fs: dcache per-inode inode alias lockingNick Piggin
dcache_inode_lock can be replaced with per-inode locking. Use existing inode->i_lock for this. This is slightly non-trivial because we sometimes need to find the inode from the dentry, which requires d_inode to be stabilised (either with refcount or d_lock). Signed-off-by: Nick Piggin <npiggin@kernel.dk>
2011-01-07fs: dcache remove dcache_lockNick Piggin
dcache_lock no longer protects anything. remove it. Signed-off-by: Nick Piggin <npiggin@kernel.dk>
2011-01-07fs: scale inode alias listNick Piggin
Add a new lock, dcache_inode_lock, to protect the inode's i_dentry list from concurrent modification. d_alias is also protected by d_lock. Signed-off-by: Nick Piggin <npiggin@kernel.dk>
2011-01-07fs: dcache scale subdirsNick Piggin
Protect d_subdirs and d_child with d_lock, except in filesystems that aren't using dcache_lock for these anyway (eg. using i_mutex). Note: if we change the locking rule in future so that ->d_child protection is provided only with ->d_parent->d_lock, it may allow us to reduce some locking. But it would be an exception to an otherwise regular locking scheme, so we'd have to see some good results. Probably not worthwhile. Signed-off-by: Nick Piggin <npiggin@kernel.dk>
2010-12-22Merge branch 'master' into for-nextJiri Kosina
Conflicts: MAINTAINERS arch/arm/mach-omap2/pm24xx.c drivers/scsi/bfa/bfa_fcpim.c Needed to update to apply fixes for which the old branch was too outdated.
2010-12-15fanotify: fill in the metadata_len field on struct fanotify_event_metadataEric Paris
The fanotify_event_metadata now has a field which is supposed to indicate the length of the metadata portion of the event. Fill in that field as well. Based-in-part-on-patch-by: Alexey Zaytsev <alexey.zaytsev@gmail.com> Signed-off-by: Eric Paris <eparis@redhat.com>
2010-12-07fanotify: Dont try to open a file descriptor for the overflow eventLino Sanfilippo
We should not try to open a file descriptor for the overflow event since this will always fail. Signed-off-by: Lino Sanfilippo <LinoSanfilippo@gmx.de> Signed-off-by: Eric Paris <eparis@redhat.com>
2010-12-07fanotify: do not leak user reference on allocation failureEric Paris
If fanotify_init is unable to allocate a new fsnotify group it will return but will not drop its reference on the associated user struct. Drop that reference on error. Reported-by: Vegard Nossum <vegard.nossum@gmail.com> Signed-off-by: Eric Paris <eparis@redhat.com>
2010-12-07inotify: stop kernel memory leak on file creation failureEric Paris
If inotify_init is unable to allocate a new file for the new inotify group we leak the new group. This patch drops the reference on the group on file allocation failure. Reported-by: Vegard Nossum <vegard.nossum@gmail.com> cc: stable@kernel.org Signed-off-by: Eric Paris <eparis@redhat.com>
2010-12-07fanotify: on group destroy allow all waiters to bypass permission checkLino Sanfilippo
When fanotify_release() is called, there may still be processes waiting for access permission. Currently only processes for which an event has already been queued into the groups access list will be woken up. Processes for which no event has been queued will continue to sleep and thus cause a deadlock when fsnotify_put_group() is called. Furthermore there is a race allowing further processes to be waiting on the access wait queue after wake_up (if they arrive before clear_marks_by_group() is called). This patch corrects this by setting a flag to inform processes that the group is about to be destroyed and thus not to wait for access permission. [additional changelog from eparis] Lets think about the 4 relevant code paths from the PoV of the 'operator' 'listener' 'responder' and 'closer'. Where operator is the process doing an action (like open/read) which could require permission. Listener is the task (or in this case thread) slated with reading from the fanotify file descriptor. The 'responder' is the thread responsible for responding to access requests. 'Closer' is the thread attempting to close the fanotify file descriptor. The 'operator' is going to end up in: fanotify_handle_event() get_response_from_access() (THIS BLOCKS WAITING ON USERSPACE) The 'listener' interesting code path fanotify_read() copy_event_to_user() prepare_for_access_response() (THIS CREATES AN fanotify_response_event) The 'responder' code path: fanotify_write() process_access_response() (REMOVE A fanotify_response_event, SET RESPONSE, WAKE UP 'operator') The 'closer': fanotify_release() (SUPPOSED TO CLEAN UP THE REST OF THIS MESS) What we have today is that in the closer we remove all of the fanotify_response_events and set a bit so no more response events are ever created in prepare_for_access_response(). The bug is that we never wake all of the operators up and tell them to move along. You fix that in fanotify_get_response_from_access(). You also fix other operators which haven't gotten there yet. So I agree that's a good fix. [/additional changelog from eparis] [remove additional changes to minimize patch size] [move initialization so it was inside CONFIG_FANOTIFY_PERMISSION] Signed-off-by: Lino Sanfilippo <LinoSanfilippo@gmx.de> Signed-off-by: Eric Paris <eparis@redhat.com>
2010-12-07fanotify: Dont allow a mask of 0 if setting or removing a markLino Sanfilippo
In mark_remove_from_mask() we destroy marks that have their event mask cleared. Thus we should not allow the creation of those marks in the first place. With this patch we check if the mask given from user is 0 in case of FAN_MARK_ADD. If so we return an error. Same for FAN_MARK_REMOVE since this does not have any effect. Signed-off-by: Lino Sanfilippo <LinoSanfilippo@gmx.de> Signed-off-by: Eric Paris <eparis@redhat.com>
2010-12-07fanotify: correct broken ref counting in case adding a mark failedLino Sanfilippo
If adding a mount or inode mark failed fanotify_free_mark() is called explicitly. But at this time the mark has already been put into the destroy list of the fsnotify_mark kernel thread. If the thread is too slow it will try to decrease the reference of a mark, that has already been freed by fanotify_free_mark(). (If its fast enough it will only decrease the marks ref counter from 2 to 1 - note that the counter has been increased to 2 in add_mark() - which has practically no effect.) This patch fixes the ref counting by not calling free_mark() explicitly, but decreasing the ref counter and rely on the fsnotify_mark thread to cleanup in case adding the mark has failed. Signed-off-by: Lino Sanfilippo <LinoSanfilippo@gmx.de> Signed-off-by: Eric Paris <eparis@redhat.com>
2010-12-07fanotify: deny permissions when no event was sentEric Paris
If no event was sent to userspace we cannot expect userspace to respond to permissions requests. Today such requests just hang forever. This patch will deny any permissions event which was unable to be sent to userspace. Reported-by: Tvrtko Ursulin <tvrtko.ursulin@sophos.com> Signed-off-by: Eric Paris <eparis@redhat.com>
2010-11-01Kconfig: typo: and -> anMichael Witten
Signed-off-by: Michael Witten <mfwitten@gmail.com> Signed-off-by: Jiri Kosina <jkosina@suse.cz>
2010-10-30make fanotify_read() restartable across signalsLino Sanfilippo
In fanotify_read() return -ERESTARTSYS instead of -EINTR to make read() restartable across signals (BSD semantic). Signed-off-by: Eric Paris <eparis@redhat.com>
2010-10-28fs/notify/fanotify/fanotify_user.c: fix warningsAndrew Morton
fs/notify/fanotify/fanotify_user.c: In function 'fanotify_release': fs/notify/fanotify/fanotify_user.c:375: warning: unused variable 'lre' fs/notify/fanotify/fanotify_user.c:375: warning: unused variable 're' this is really ugly. Cc: Eric Paris <eparis@redhat.com> Signed-off-by: Andrew Morton <akpm@linux-foundation.org> Signed-off-by: Eric Paris <eparis@redhat.com>
2010-10-28fanotify: do not recalculate the mask if the ignored mask changedEric Paris
If fanotify sets a new bit in the ignored mask it will cause the generic fsnotify layer to recalculate the real mask. This is stupid since we didn't change that part. Signed-off-by: Eric Paris <eparis@redhat.com>
2010-10-28fanotify: ignore events on directories unless specifically requestedEric Paris
fanotify has a very limited number of events it sends on directories. The usefulness of these events is yet to be seen and still we send them. This is particularly painful for mount marks where one might receive many of these useless events. As such this patch will drop events on IS_DIR() inodes unless they were explictly requested with FAN_ON_DIR. This means that a mark on a directory without FAN_EVENT_ON_CHILD or FAN_ON_DIR is meaningless and will result in no events ever (although it will still be allowed since detecting it is hard) Signed-off-by: Eric Paris <eparis@redhat.com>
2010-10-28fsnotify: rename FS_IN_ISDIR to FS_ISDIREric Paris
The _IN_ in the naming is reserved for flags only used by inotify. Since I am about to use this flag for fanotify rename it to be generic like the rest. Signed-off-by: Eric Paris <eparis@redhat.com>
2010-10-28fanotify: do not send events for irregular filesEric Paris
fanotify_should_send_event has a test to see if an object is a file or directory and does not send an event otherwise. The problem is that the test is actually checking if the object with a mark is a file or directory, not if the object the event happened on is a file or directory. We should check the latter. Signed-off-by: Eric Paris <eparis@redhat.com>
2010-10-28fanotify: limit number of listeners per userEric Paris
fanotify currently has no limit on the number of listeners a given user can have open. This patch limits the total number of listeners per user to 128. This is the same as the inotify default limit. Signed-off-by: Eric Paris <eparis@redhat.com>
2010-10-28fanotify: allow userspace to override max marksEric Paris
Some fanotify groups, especially those like AV scanners, will need to place lots of marks, particularly ignore marks. Since ignore marks do not pin inodes in cache and are cleared if the inode is removed from core (usually under memory pressure) we expose an interface for listeners, with CAP_SYS_ADMIN, to override the maximum number of marks and be allowed to set and 'unlimited' number of marks. Programs which make use of this feature will be able to OOM a machine. Signed-off-by: Eric Paris <eparis@redhat.com>
2010-10-28fanotify: limit the number of marks in a single fanotify groupEric Paris
There is currently no limit on the number of marks a given fanotify group can have. Since fanotify is gated on CAP_SYS_ADMIN this was not seen as a serious DoS threat. This patch implements a default of 8192, the same as inotify to work towards removing the CAP_SYS_ADMIN gating and eliminating the default DoS'able status. Signed-off-by: Eric Paris <eparis@redhat.com>
2010-10-28fanotify: allow userspace to override max queue depthEric Paris
fanotify has a defualt max queue depth. This patch allows processes which explicitly request it to have an 'unlimited' queue depth. These processes need to be very careful to make sure they cannot fall far enough behind that they OOM the box. Thus this flag is gated on CAP_SYS_ADMIN. Signed-off-by: Eric Paris <eparis@redhat.com>
2010-10-28fsnotify: implement a default maximum queue depthEric Paris
Currently fanotify has no maximum queue depth. Since fanotify is CAP_SYS_ADMIN only this does not pose a normal user DoS issue, but it certianly is possible that an fanotify listener which can't keep up could OOM the box. This patch implements a default 16k depth. This is the same default depth used by inotify, but given fanotify's better queue merging in many situations this queue will contain many additional useful events by comparison. Signed-off-by: Eric Paris <eparis@redhat.com>
2010-10-28fanotify: ignore fanotify ignore marks if open writersEric Paris
fanotify will clear ignore marks if a task changes the contents of an inode. The problem is with the races around when userspace finishes checking a file and when that result is actually attached to the inode. This race was described as such: Consider the following scenario with hostile processes A and B, and victim process C: 1. Process A opens new file for writing. File check request is generated. 2. File check is performed in userspace. Check result is "file has no malware". 3. The "permit" response is delivered to kernel space. 4. File ignored mark set. 5. Process A writes dummy bytes to the file. File ignored flags are cleared. 6. Process B opens the same file for reading. File check request is generated. 7. File check is performed in userspace. Check result is "file has no malware". 8. Process A writes malware bytes to the file. There is no cached response yet. 9. The "permit" response is delivered to kernel space and is cached in fanotify. 10. File ignored mark set. 11. Now any process C will be permitted to open the malware file. There is a race between steps 8 and 10 While fanotify makes no strong guarantees about systems with hostile processes there is no reason we cannot harden against this race. We do that by simply ignoring any ignore marks if the inode has open writers (aka i_writecount > 0). (We actually do not ignore ignore marks if the FAN_MARK_SURV_MODIFY flag is set) Reported-by: Vasily Novikov <vasily.novikov@kaspersky.com> Signed-off-by: Eric Paris <eparis@redhat.com>
2010-10-28fsnotify: call fsnotify_parent in perm eventsEric Paris
fsnotify perm events do not call fsnotify parent. That means you cannot register a perm event on a directory and enforce permissions on all inodes in that directory. This patch fixes that situation. Signed-off-by: Eric Paris <eparis@redhat.com>
2010-10-28fsnotify: correctly handle return codes from listenersEric Paris
When fsnotify groups return errors they are ignored. For permissions events these should be passed back up the stack, but for most events these should continue to be ignored. Signed-off-by: Eric Paris <eparis@redhat.com>
2010-10-28fanotify: implement fanotify listener orderingEric Paris
The fanotify listeners needs to be able to specify what types of operations they are going to perform so they can be ordered appropriately between other listeners doing other types of operations. They need this to be able to make sure that things like hierarchichal storage managers will get access to inodes before processes which need the data. This patch defines 3 possible uses which groups must indicate in the fanotify_init() flags. FAN_CLASS_PRE_CONTENT FAN_CLASS_CONTENT FAN_CLASS_NOTIF Groups will receive notification in that order. The order between 2 groups in the same class is undeterministic. FAN_CLASS_PRE_CONTENT is intended to be used by listeners which need access to the inode before they are certain that the inode contains it's final data. A hierarchical storage manager should choose to use this class. FAN_CLASS_CONTENT is intended to be used by listeners which need access to the inode after it contains its intended contents. This would be the appropriate level for an AV solution or document control system. FAN_CLASS_NOTIF is intended for normal async notification about access, much the same as inotify and dnotify. Syncronous permissions events are not permitted at this class. Signed-off-by: Eric Paris <eparis@redhat.com>
2010-10-28fsnotify: implement ordering between notifiersEric Paris
fanotify needs to be able to specify that some groups get events before others. They use this idea to make sure that a hierarchical storage manager gets access to files before programs which actually use them. This is purely infrastructure. Everything will have a priority of 0, but the infrastructure will exist for it to be non-zero. Signed-off-by: Eric Paris <eparis@redhat.com>
2010-10-28fanotify: allow fanotify to be builtEric Paris
We disabled the ability to build fanotify in commit 7c5347733dcc4ba0ba. This reverts that commit and allows people to build fanotify. Signed-off-by: Eric Paris <eparis@redhat.com>
2010-10-25split invalidate_inodes()Al Viro
Pull removal of fsnotify marks into generic_shutdown_super(). Split umount-time work into a new function - evict_inodes(). Make sure that invalidate_inodes() will be able to cope with I_FREEING once we change locking in iput(). Signed-off-by: Al Viro <viro@zeniv.linux.org.uk>
2010-10-25fsnotify: use dget_parentChristoph Hellwig
Use dget_parent instead of opencoding it. This simplifies the code, but more importanly prepares for the more complicated locking for a parent dget in the dcache scale patch series. It means we do grab a reference to the parent now if need to be watched, but not with the specified mask. If this turns out to be a problem we'll have to revisit it, but for now let's keep as much as possible dcache internals inside dcache.[ch]. Signed-off-by: Christoph Hellwig <hch@lst.de> Signed-off-by: Al Viro <viro@zeniv.linux.org.uk>
2010-10-22Merge branch 'llseek' of git://git.kernel.org/pub/scm/linux/kernel/git/arnd/bklLinus Torvalds
* 'llseek' of git://git.kernel.org/pub/scm/linux/kernel/git/arnd/bkl: vfs: make no_llseek the default vfs: don't use BKL in default_llseek llseek: automatically add .llseek fop libfs: use generic_file_llseek for simple_attr mac80211: disallow seeks in minstrel debug code lirc: make chardev nonseekable viotape: use noop_llseek raw: use explicit llseek file operations ibmasmfs: use generic_file_llseek spufs: use llseek in all file operations arm/omap: use generic_file_llseek in iommu_debug lkdtm: use generic_file_llseek in debugfs net/wireless: use generic_file_llseek in debugfs drm: use noop_llseek
All file_operations should get a .llseek operation so we can make nonseekable_open the default for future file operations without a .llseek pointer. The three cases that we can automatically detect are no_llseek, seq_lseek and default_llseek. For cases where we can we can automatically prove that the file offset is always ignored, we use noop_llseek, which maintains the current behavior of not returning an error from a seek. New drivers should normally not use noop_llseek but instead use no_llseek and call nonseekable_open at open time. Existing drivers can be converted to do the same when the maintainer knows for certain that no user code relies on calling seek on the device file. The generated code is often incorrectly indented and right now contains comments that clarify for each added line why a specific variant was chosen. In the version that gets submitted upstream, the comments will be gone and I will manually fix the indentation, because there does not seem to be a way to do that using coccinelle. Some amount of new code is currently sitting in linux-next that should get the same modifications, which I will do at the end of the merge window. Many thanks to Julia Lawall for helping me learn to write a semantic patch that does all this. ===== begin semantic patch ===== // This adds an llseek= method to all file operations, // as a preparation for making no_llseek the default. // // The rules are // - use no_llseek explicitly if we do nonseekable_open // - use seq_lseek for sequential files // - use default_llseek if we know we access f_pos // - use noop_llseek if we know we don't access f_pos, // but we still want to allow users to call lseek // @ open1 exists @ identifier nested_open; @@ nested_open(...) { <+... nonseekable_open(...) ...+> } @ open exists@ identifier open_f; identifier i, f; identifier open1.nested_open; @@ int open_f(struct inode *i, struct file *f) { <+... ( nonseekable_open(...) | nested_open(...) ) ...+> } @ read disable optional_qualifier exists @ identifier read_f; identifier f, p, s, off; type ssize_t, size_t, loff_t; expression E; identifier func; @@ ssize_t read_f(struct file *f, char *p, size_t s, loff_t *off) { <+... ( *off = E | *off += E | func(..., off, ...) | E = *off ) ...+> } @ read_no_fpos disable optional_qualifier exists @ identifier read_f; identifier f, p, s, off; type ssize_t, size_t, loff_t; @@ ssize_t read_f(struct file *f, char *p, size_t s, loff_t *off) { ... when != off } @ write @ identifier write_f; identifier f, p, s, off; type ssize_t, size_t, loff_t; expression E; identifier func; @@ ssize_t write_f(struct file *f, const char *p, size_t s, loff_t *off) { <+... ( *off = E | *off += E | func(..., off, ...) | E = *off ) ...+> } @ write_no_fpos @ identifier write_f; identifier f, p, s, off; type ssize_t, size_t, loff_t; @@ ssize_t write_f(struct file *f, const char *p, size_t s, loff_t *off) { ... when != off } @ fops0 @ identifier fops; @@ struct file_operations fops = { ... }; @ has_llseek depends on fops0 @ identifier fops0.fops; identifier llseek_f; @@ struct file_operations fops = { ... .llseek = llseek_f, ... }; @ has_read depends on fops0 @ identifier fops0.fops; identifier read_f; @@ struct file_operations fops = { ... .read = read_f, ... }; @ has_write depends on fops0 @ identifier fops0.fops; identifier write_f; @@ struct file_operations fops = { ... .write = write_f, ... }; @ has_open depends on fops0 @ identifier fops0.fops; identifier open_f; @@ struct file_operations fops = { ... .open = open_f, ... }; // use no_llseek if we call nonseekable_open //////////////////////////////////////////// @ nonseekable1 depends on !has_llseek && has_open @ identifier fops0.fops; identifier nso ~= "nonseekable_open"; @@ struct file_operations fops = { ... .open = nso, ... +.llseek = no_llseek, /* nonseekable */ }; @ nonseekable2 depends on !has_llseek @ identifier fops0.fops; identifier open.open_f; @@ struct file_operations fops = { ... .open = open_f, ... +.llseek = no_llseek, /* open uses nonseekable */ }; // use seq_lseek for sequential files ///////////////////////////////////// @ seq depends on !has_llseek @ identifier fops0.fops; identifier sr ~= "seq_read"; @@ struct file_operations fops = { ... .read = sr, ... +.llseek = seq_lseek, /* we have seq_read */ }; // use default_llseek if there is a readdir /////////////////////////////////////////// @ fops1 depends on !has_llseek && !nonseekable1 && !nonseekable2 && !seq @ identifier fops0.fops; identifier readdir_e; @@ // any other fop is used that changes pos struct file_operations fops = { ... .readdir = readdir_e, ... +.llseek = default_llseek, /* readdir is present */ }; // use default_llseek if at least one of read/write touches f_pos ///////////////////////////////////////////////////////////////// @ fops2 depends on !fops1 && !has_llseek && !nonseekable1 && !nonseekable2 && !seq @ identifier fops0.fops; identifier read.read_f; @@ // read fops use offset struct file_operations fops = { ... .read = read_f, ... +.llseek = default_llseek, /* read accesses f_pos */ }; @ fops3 depends on !fops1 && !fops2 && !has_llseek && !nonseekable1 && !nonseekable2 && !seq @ identifier fops0.fops; identifier write.write_f; @@ // write fops use offset struct file_operations fops = { ... .write = write_f, ... + .llseek = default_llseek, /* write accesses f_pos */ }; // Use noop_llseek if neither read nor write accesses f_pos /////////////////////////////////////////////////////////// @ fops4 depends on !fops1 && !fops2 && !fops3 && !has_llseek && !nonseekable1 && !nonseekable2 && !seq @ identifier fops0.fops; identifier read_no_fpos.read_f; identifier write_no_fpos.write_f; @@ // write fops use offset struct file_operations fops = { ... .write = write_f, .read = read_f, ... +.llseek = noop_llseek, /* read and write both use no f_pos */ }; @ depends on has_write && !has_read && !fops1 && !fops2 && !has_llseek && !nonseekable1 && !nonseekable2 && !seq @ identifier fops0.fops; identifier write_no_fpos.write_f; @@ struct file_operations fops = { ... .write = write_f, ... +.llseek = noop_llseek, /* write uses no f_pos */ }; @ depends on has_read && !has_write && !fops1 && !fops2 && !has_llseek && !nonseekable1 && !nonseekable2 && !seq @ identifier fops0.fops; identifier read_no_fpos.read_f; @@ struct file_operations fops = { ... .read = read_f, ... +.llseek = noop_llseek, /* read uses no f_pos */ }; @ depends on !has_read && !has_write && !fops1 && !fops2 && !has_llseek && !nonseekable1 && !nonseekable2 && !seq @ identifier fops0.fops; @@ struct file_operations fops = { ... +.llseek = noop_llseek, /* no read or write fn */ }; ===== End semantic patch ===== Signed-off-by: Arnd Bergmann <arnd@arndb.de> Cc: Julia Lawall <julia@diku.dk> Cc: Christoph Hellwig <hch@infradead.org>
2010-10-11fanotify: disable fanotify syscallsEric Paris
This patch disables the fanotify syscalls by just not building them and letting the cond_syscall() statements in kernel/sys_ni.c redirect them to sys_ni_syscall(). It was pointed out by Tvrtko Ursulin that the fanotify interface did not include an explicit prioritization between groups. This is necessary for fanotify to be usable for hierarchical storage management software, as they must get first access to the file, before inotify-like notifiers see the file. This feature can be added in an ABI compatible way in the next release (by using a number of bits in the flags field to carry the info) but it was suggested by Alan that maybe we should just hold off and do it in the next cycle, likely with an (new) explicit argument to the syscall. I don't like this approach best as I know people are already starting to use the current interface, but Alan is all wise and noone on list backed me up with just using what we have. I feel this is needlessly ripping the rug out from under people at the last minute, but if others think it needs to be a new argument it might be the best way forward. Three choices: Go with what we got (and implement the new feature next cycle). Add a new field right now (and implement the new feature next cycle). Wait till next cycle to release the ABI (and implement the new feature next cycle). This is number 3. Signed-off-by: Eric Paris <eparis@redhat.com> Signed-off-by: Linus Torvalds <torvalds@linux-foundation.org>
2010-08-27fsnotify: drop two useless bools in the fnsotify main loopEric Paris
The fsnotify main loop has 2 bools which indicated if we processed the inode or vfsmount mark in that particular pass through the loop. These bool can we replaced with the inode_group and vfsmount_group variables and actually make the code a little easier to understand. Signed-off-by: Eric Paris <eparis@redhat.com>
2010-08-27fsnotify: fix list walk orderEric Paris
Marks were stored on the inode and vfsmonut mark list in order from highest memory address to lowest memory address. The code to walk those lists thought they were in order from lowest to highest with unpredictable results when trying to match up marks from each. It was possible that extra events would be sent to userspace when inode marks ignoring events wouldn't get matched with the vfsmount marks. This problem only affected fanotify when using both vfsmount and inode marks simultaneously. Signed-off-by: Eric Paris <eparis@redhat.com>
2010-08-27fanotify: Return EPERM when a process is not privilegedAndreas Gruenbacher
The appropriate error code when privileged operations are denied is EPERM, not EACCES. Signed-off-by: Andreas Gruenbacher <agruen@suse.de> Signed-off-by: Eric Paris <paris@paris.rdu.redhat.com>
2010-08-22fanotify: drop duplicate pr_debug statementTvrtko Ursulin
This reminded me... you have two pr_debugs in fanotify_should_send_event which output redundant information. Maybe you intended it like that so it is selectable how much log spam you want, or if not you may want to apply this patch. Signed-off-by: Tvrtko Ursulin <tvrtko.ursulin@sophos.com> Signed-off-by: Eric Paris <eparis@redhat.com>
2010-08-22fanotify: flush outstanding perm requests on group destroyEric Paris
When an fanotify listener is closing it may cause a deadlock between the listener and the original task doing an fs operation. If the original task is waiting for a permissions response it will be holding the srcu lock. The listener cannot clean up and exit until after that srcu lock is syncronized. Thus deadlock. The fix introduced here is to stop accepting new permissions events when a listener is shutting down and to grant permission for all outstanding events. Thus the original task will eventually release the srcu lock and the listener can complete shutdown. Reported-by: Andreas Gruenbacher <agruen@suse.de> Cc: Andreas Gruenbacher <agruen@suse.de> Signed-off-by: Eric Paris <eparis@redhat.com>
