path: root/fs/ntfs/attrib.h
2006-10-01[PATCH] fs/ntfs: Conversion to generic booleanRichard Knutsson
Conversion of booleans to: generic-boolean.patch (2006-08-23) Signed-off-by: Richard Knutsson <ricknu-0@student.ltu.se> Signed-off-by: Anton Altaparmakov <aia21@cantab.net> Signed-off-by: Andrew Morton <akpm@osdl.org> Signed-off-by: Linus Torvalds <torvalds@osdl.org>
2005-10-04NTFS: Add fs/ntfs/attrib.[hc]::ntfs_attr_extend_allocation(), a function toAnton Altaparmakov
extend the allocation of an attributes. Optionally, the data size, but not the initialized size can be extended, too. Signed-off-by: Anton Altaparmakov <aia21@cantab.net>
2005-10-04NTFS: Change ntfs_attr_make_non_resident to take the attribute value sizeAnton Altaparmakov
as an extra parameter. This is needed since we need to know the size before we can map the mft record and our callers always know it. The reason we cannot simply read the size from the vfs inode i_size is that this is not necessarily uptodate. This happens when ntfs_attr_make_non_resident() is called in the ->truncate call path. Signed-off-by: Anton Altaparmakov <aia21@cantab.net>
2005-10-04NTFS: Change ntfs_attr_find_vcn_nolock() to also take an optional attributeAnton Altaparmakov
search context as argument. This allows calling it with the mft record mapped. Update all callers. Signed-off-by: Anton Altaparmakov <aia21@cantab.net>
2005-10-04NTFS: Change ntfs_map_runlist_nolock() to also take an optional attributeAnton Altaparmakov
search context. This allows calling it with the mft record mapped. Signed-off-by: Anton Altaparmakov <aia21@cantab.net>
2005-09-08NTFS: Add fs/ntfs/attrib.[hc]::ntfs_resident_attr_value_resize().Anton Altaparmakov
2005-05-05NTFS: Fix compilation when configured read-only.Anton Altaparmakov
- Add ifdef NTFS_RW around write specific code if fs/ntfs/runlist.[hc] and fs/ntfs/attrib.[hc]. - Minor bugfix to fs/ntfs/attrib.c::ntfs_attr_make_non_resident() where the runlist was not freed in all error cases. - Add fs/ntfs/runlist.[hc]::ntfs_rl_find_vcn_nolock(). Signed-off-by: Anton Altaparmakov <aia21@cantab.net>
2005-05-05NTFS: Add fs/ntfs/attrib.[hc]::ntfs_attr_make_non_resident().Anton Altaparmakov
2005-05-05NTFS: - Fix bug in fs/ntfs/attrib.c::ntfs_find_vcn_nolock() where afterAnton Altaparmakov
dropping the read lock and taking the write lock we were not checking whether someone else did not already do the work we wanted to do. - Rename ntfs_find_vcn_nolock() to ntfs_attr_find_vcn_nolock(). - Tidy up some comments in fs/ntfs/runlist.c. - Add LCN_ENOMEM and LCN_EIO definitions to fs/ntfs/runlist.h. Signed-off-by: Anton Altaparmakov <aia21@cantab.net>
2005-05-05NTFS: Add fs/ntfs/attrib.[hc]::ntfs_attr_vcn_to_lcn_nolock() used by the newAnton Altaparmakov
write code. Signed-off-by: Anton Altaparmakov <aia21@cantab.net>
2005-05-05NTFS: - Split ntfs_map_runlist() into ntfs_map_runlist() and a non-lockingAnton Altaparmakov
helper ntfs_map_runlist_nolock() which is used by ntfs_map_runlist(). This allows us to map runlist fragments with the runlist lock already held without having to drop and reacquire it around the call. Adapt all callers. - Change ntfs_find_vcn() to ntfs_find_vcn_nolock() which takes a locked runlist. This allows us to find runlist elements with the runlist lock already held without having to drop and reacquire it around the call. Adapt all callers. Signed-off-by: Anton Altaparmakov <aia21@cantab.net>
