path: root/fs/ntfs/inode.h
2007-01-18NTFS: 2.1.28 - Fix deadlock reported by Sergey Vlasov due to ntfs_put_inode().Anton Altaparmakov
- Fix deadlock in fs/ntfs/inode.c::ntfs_put_inode(). Thanks to Sergey Vlasov for the report and detailed analysis of the deadlock. The fix involved getting rid of ntfs_put_inode() altogether and hence NTFS no longer has a ->put_inode super operation. Signed-off-by: Anton Altaparmakov <aia21@cantab.net>
2006-03-23NTFS: Semaphore to mutex conversion.Ingo Molnar
The conversion was generated via scripts, and the result was validated automatically via a script as well. Signed-off-by: Ingo Molnar <mingo@elte.hu> Signed-off-by: Andrew Morton <akpm@osdl.org> Signed-off-by: Anton Altaparmakov <aia21@cantab.net>
2005-06-25NTFS: Fix several occurences of a bug where we would perform 'var & ~const'Anton Altaparmakov
with a 64-bit variable and a int, i.e. 32-bit, constant. This causes the higher order 32-bits of the 64-bit variable to be zeroed. To fix this cast the 'const' to the same 64-bit type as 'var'. Signed-off-by: Anton Altaparmakov <aia21@cantab.net>
2005-05-05NTFS: - Add disable_sparse mount option together with a per volume sparseAnton Altaparmakov
enable bit which is set appropriately and a per inode sparse disable bit which is preset on some system file inodes as appropriate. - Enforce that sparse support is disabled on NTFS volumes pre 3.0. Signed-off-by: Anton Altaparmakov <aia21@cantab.net>
2005-05-05NTFS: - In fs/ntfs/compress.c, use i_size_read() at the start and then use theAnton Altaparmakov
cached value everywhere. Cache the initialized_size in the same way and protect the critical region where the two sizes are read using the new size_lock of the ntfs inode. - Add the new size_lock to the ntfs_inode structure (fs/ntfs/inode.h) and initialize it (fs/ntfs/inode.c). Signed-off-by: Anton Altaparmakov <aia21@cantab.net>
