path: root/fs/ntfs/logfile.h
2006-10-01[PATCH] fs/ntfs: Conversion to generic booleanRichard Knutsson
Conversion of booleans to: generic-boolean.patch (2006-08-23) Signed-off-by: Richard Knutsson <ricknu-0@student.ltu.se> Signed-off-by: Anton Altaparmakov <aia21@cantab.net> Signed-off-by: Andrew Morton <akpm@osdl.org> Signed-off-by: Linus Torvalds <torvalds@osdl.org>
2005-09-22NTFS: Fix sparse warnings that have crept in over time.Anton Altaparmakov
2005-09-08NTFS: Support more clean journal ($LogFile) states.Anton Altaparmakov
- Support journals ($LogFile) which have been modified by chkdsk. This means users can boot into Windows after we marked the volume dirty. The Windows boot will run chkdsk and then reboot. The user can then immediately boot into Linux rather than having to do a full Windows boot first before rebooting into Linux and we will recognize such a journal and empty it as it is clean by definition. - Support journals ($LogFile) with only one restart page as well as journals with two different restart pages. We sanity check both and either use the only sane one or the more recent one of the two in the case that both are valid. Signed-off-by: Anton Altaparmakov <aia21@cantab.net>
