path: root/fs/ocfs2/Makefile
2008-04-18ocfs2: Allow selection of cluster plug-ins.Joel Becker
ocfs2 now supports plug-ins for the classic O2CB stack as well as userspace cluster stacks in conjunction with fs/dlm. This allows zero, one, or both of the plug-ins to be selected in Kconfig. For local mounts (non-clustered), neither plug-in is needed. Both plugins can be loaded at one time, the runtime will select the one needed for the cluster systme in use. Signed-off-by: Joel Becker <joel.becker@oracle.com> Signed-off-by: Mark Fasheh <mfasheh@suse.com>
2008-04-18ocfs2: Add kbuild for ocfs2_stack_user.koJoel Becker
Add ocfs2_stack_user.ko to the Makefile so that it builds. Signed-off-by: Joel Becker <joel.becker@oracle.com> Signed-off-by: Mark Fasheh <mfasheh@suse.com>
2008-04-18ocfs2: Break out stackglue into modules.Joel Becker
We define the ocfs2_stack_plugin structure to represent a stack driver. The o2cb stack code is split into stack_o2cb.c. This becomes the ocfs2_stack_o2cb.ko module. The stackglue generic functions are similarly split into the ocfs2_stackglue.ko module. This module now provides an interface to register drivers. The ocfs2_stack_o2cb driver registers itself. As part of this interface, ocfs2_stackglue can load drivers on demand. This is accomplished in ocfs2_cluster_connect(). ocfs2_cluster_disconnect() is now notified when a _hangup() is pending. If a hangup is pending, it will not release the driver module and will let _hangup() do that. Signed-off-by: Joel Becker <joel.becker@oracle.com>
2008-04-18ocfs2: Create ocfs2_stack_operations and split out the o2cb stack.Joel Becker
Define the ocfs2_stack_operations structure. Build o2cb_stack_ops from all of the o2cb-specific stack functions. Change the generic stack glue functions to call the stack_ops instead of the o2cb functions directly. The o2cb functions are moved to stack_o2cb.c. The headers are cleaned up to where only needed headers are included. In this code, stackglue.c and stack_o2cb.c refer to some shared extern variables. When they become modules, that will change. Signed-off-by: Joel Becker <joel.becker@oracle.com> Signed-off-by: Mark Fasheh <mfasheh@suse.com>
2008-04-18ocfs2: Separate out dlm lock functions.Joel Becker
This is the first in a series of patches to isolate ocfs2 from the underlying cluster stack. Here we wrap the dlm locking functions with ocfs2-specific calls. Because ocfs2 always uses the same dlm lock status callbacks, we can eliminate the callbacks from the filesystem visible functions. Signed-off-by: Joel Becker <joel.becker@oracle.com> Signed-off-by: Mark Fasheh <mfasheh@suse.com>
2008-01-25[PATCH 2/2] ocfs2: cluster aware flock()Mark Fasheh
Hook up ocfs2_flock(), using the new flock lock type in dlmglue.c. A new mount option, "localflocks" is added so that users can revert to old functionality as need be. Signed-off-by: Mark Fasheh <mark.fasheh@oracle.com>
2008-01-25[PATCH 1/2] ocfs2: Add group extend for online resizeTao Ma
This patch adds the ability for a userspace program to request an extend of last cluster group on an Ocfs2 file system. The request is made via ioctl, OCFS2_IOC_GROUP_EXTEND. This is derived from EXT3_IOC_GROUP_EXTEND, but is obviously Ocfs2 specific. tunefs.ocfs2 would call this for an online-resize operation if the last cluster group isn't full. Signed-off-by: Tao Ma <tao.ma@oracle.com> Signed-off-by: Mark Fasheh <mark.fasheh@oracle.com>
2008-01-25ocfs2: Remove mount/unmount votesMark Fasheh
The node maps that are set/unset by these votes are no longer relevant, thus we can remove the mount and umount votes. Since those are the last two remaining votes, we can also remove the entire vote infrastructure. The vote thread has been renamed to the downconvert thread, and the small amount of functionality related to managing it has been moved into fs/ocfs2/dlmglue.c. All references to votes have been removed or updated. Signed-off-by: Mark Fasheh <mark.fasheh@oracle.com>
2006-09-20ocfs2: add ext2 attributesHerbert Poetzl
Support immutable, and other attributes. Some renaming and other minor fixes done by myself. Signed-off-by: Herbert Poetzl <herbert@13thfloor.at> Signed-off-by: Mark Fasheh <mark.fasheh@oracle.com>
2006-01-03[PATCH] OCFS2: The Second Oracle Cluster FilesystemMark Fasheh
The OCFS2 file system module. Signed-off-by: Mark Fasheh <mark.fasheh@oracle.com> Signed-off-by: Kurt Hackel <kurt.hackel@oracle.com>
