[ Upstream commit 9e6aea22802b5684c7e1d69822aeb0844dd01953 ]
Included file path was hard-wired in the ocfs2 makefile, which might
causes some confusion when compiling ocfs2 as an external module.
Say if we compile ocfs2 module as following.
cp -r /kernel/tree/fs/ocfs2 /other/dir/ocfs2
cd /other/dir/ocfs2
make -C /path/to/kernel_source M=`pwd` modules
Acutally, the compiler wil try to find included file in
/kernel/tree/fs/ocfs2, rather than the directory /other/dir/ocfs2.
To fix this little bug, we introduce the var $(src) provided by kbuild.
$(src) means the absolute path of the running kbuild file.
Link: http://lkml.kernel.org/r/20181108085546.15149-1-lchen@suse.com
Signed-off-by: Larry Chen <lchen@suse.com>
Reviewed-by: Andrew Morton <akpm@linux-foundation.org>
Cc: Mark Fasheh <mark@fasheh.com>
Cc: Junxiao Bi <junxiao.bi@oracle.com>
Cc: Joseph Qi <jiangqi903@gmail.com>
Cc: Changwei Ge <ge.changwei@h3c.com>
Philippe Ombredanne.
How this work was done:
the use cases:
lines of source
lines).
identifiers to apply.
COPYING file license applied.
GPL-2.0 11139
the concluded license(s).
in time.
they are related.
in about 15000 files.
correct identifier.
version early this week with:
license ids and scores
generate the patches.
According to some high-load testing, these two BUG assertions were
encountered, this led system panic. Actually, there were some
discussions about removing these two BUG() assertions, it would not
bring any side effect.
Then, I did the the following changes,
1) use the existing macro CATCH_BH_JBD_RACES to wrap BUG() in the
ocfs2_read_blocks_sync function like before.
2) disable the macro CATCH_BH_JBD_RACES in Makefile by default.
Link: http://lkml.kernel.org/r/1466574294-26863-1-git-send-email-ghe@suse.com
Signed-off-by: Gang He <ghe@suse.com>
Cc: Mark Fasheh <mfasheh@suse.de>
Cc: Joseph Qi <joseph.qi@huawei.com>
Implement online file check sysfile interfaces, e.g. how to create the
related sysfile according to device name, how to display/handle file
check request from the sysfile.
Reviewed-by: Mark Fasheh <mfasheh@suse.de>
The versioning information is confusing for end-users. The numbers are
stuck at 1.5.0 when the tools version have moved to 1.8.2. Remove the
versioning system in the OCFS2 modules and let the kernel version be the
guide to debug issues.
Signed-off-by: Goldwyn Rodrigues <rgoldwyn@suse.com>
Acked-by: Sunil Mushran <sunil.mushran@gmail.com>
Cc: Mark Fasheh <mfasheh@suse.com>
Acked-by: Joel Becker <jlbec@evilplan.org>
Adding new files move_extents.[c|h] and fill it with nothing but
only a context structure.
Signed-off-by: Tristan Ye <tristan.ye@oracle.com>
Replace EXTRA_CFLAGS with ccflags-y. And change ntfs-objs to ntfs-y
for cleaner conditional inclusion.
Signed-off-by: matt mooney <mfm@muteddisk.com>
Acked-by: WANG Cong <xiyou.wangcong@gmail.com>
This patch improves Ocfs2 allocation policy by allowing an inode to
reserve a portion of the local alloc bitmap for itself. The reserved
portion (allocation window) is advisory in that other allocation
windows might steal it if the local alloc bitmap becomes
full. Otherwise, the reservations are honored and guaranteed to be
free. When the local alloc window is moved to a different portion of
the bitmap, existing reservations are discarded.
Reservation windows are represented internally by a red-black
tree. Within that tree, each node represents the reservation window of
one inode. An LRU of active reservations is also maintained. When new
data is written, we allocate it from the inodes window. When all bits
in a window are exhausted, we allocate a new one as close to the
previous one as possible. Should we not find free space, an existing
reservation is pulled off the LRU and cannibalized.
Signed-off-by: Mark Fasheh <mfasheh@suse.com>
We're going to remove the tie between ocfs2_dlmfs and o2dlm.
ocfs2_dlmfs doesn't belong in the fs/ocfs2/dlm directory anymore. Here
we move it to fs/ocfs2/dlmfs.
Signed-off-by: Joel Becker <joel.becker@oracle.com>
To become consistent with filesystems such as XFS or BTRFS, make posix
ACLs always available. This also reduces possibility of
misconfiguration on admin's side.
Signed-off-by: Tao Ma <tao.ma@oracle.com>
This is the code that computes crc32 and ecc for ocfs2 metadata blocks.
There are high-level functions that check whether the filesystem has the
ecc feature, mid-level functions that work on a single block or array of
buffer_heads, and the low-level ecc hamming code that can handle
multiple buffers like crc32_le().
It's not hooked up to the filesystem yet.
For each quota type each node has local quota file. In this file it stores
changes users have made to disk usage via this node. Once in a while this
information is synced to global file (and thus with other nodes) so that
limits enforcement at least aproximately works.
Global quota files contain all the information about usage and limits. It's
mostly handled by the generic VFS code (which implements a trie of structures
inside a quota file). We only have to provide functions to convert structures
from on-disk format to in-memory one. We also have to provide wrappers for
various quota functions starting transactions and acquiring necessary cluster
locks before the actual IO is really started.
This patch adds POSIX ACL(access control lists) APIs in ocfs2. We convert
struct posix_acl to many ocfs2_acl_entry and regard them as an extended
attribute entry.
Signed-off-by: Tiger Yang <tiger.yang@oracle.com>
Per Christoph Hellwig's suggestion - don't split these up. It's not like we
gained much by having the two tiny files around.
This patch implements storing extended attributes both in inode or a single
external block. We only store EA's in-inode when blocksize > 512 or that
inode block has free space for it. When an EA's value is larger than 80
bytes, we will store the value via b-tree outside inode or block.
Add some thin wrappers around ocfs2_insert_extent() for each of the 3
different btree types, ocfs2_inode_insert_extent(),
ocfs2_xattr_value_insert_extent() and ocfs2_xattr_tree_insert_extent(). The
last is for the xattr index btree, which will be used in a followup patch.
All the old callers in file.c etc will call ocfs2_dinode_insert_extent(),
while the other two handle the xattr issue. And the init of extent tree are
handled by these functions.
When storing xattr value which is too large, we will allocate some clusters
for it and here ocfs2_extent_list and ocfs2_extent_rec will also be used. In
order to re-use the b-tree operation code, a new parameter named "private"
is added into ocfs2_extent_tree and it is used to indicate the root of
ocfs2_exent_list. The reason is that we can't deduce the root from the
buffer_head now. It may be in an inode, an ocfs2_xattr_block or even worse,
in any place in an ocfs2_xattr_bucket.
ocfs2 now supports plug-ins for the classic O2CB stack as well as
userspace cluster stacks in conjunction with fs/dlm. This allows zero,
one, or both of the plug-ins to be selected in Kconfig. For local mounts
(non-clustered), neither plug-in is needed. Both plugins can be loaded
at one time, the runtime will select the one needed for the cluster
systme in use.
Add ocfs2_stack_user.ko to the Makefile so that it builds.
We define the ocfs2_stack_plugin structure to represent a stack driver.
The o2cb stack code is split into stack_o2cb.c. This becomes the
ocfs2_stack_o2cb.ko module.
The stackglue generic functions are similarly split into the
ocfs2_stackglue.ko module. This module now provides an interface to
register drivers. The ocfs2_stack_o2cb driver registers itself. As
part of this interface, ocfs2_stackglue can load drivers on demand.
This is accomplished in ocfs2_cluster_connect().
ocfs2_cluster_disconnect() is now notified when a _hangup() is pending.
If a hangup is pending, it will not release the driver module and will
let _hangup() do that.
Define the ocfs2_stack_operations structure. Build o2cb_stack_ops from
all of the o2cb-specific stack functions. Change the generic stack glue
functions to call the stack_ops instead of the o2cb functions directly.
The o2cb functions are moved to stack_o2cb.c. The headers are cleaned up
to where only needed headers are included.
In this code, stackglue.c and stack_o2cb.c refer to some shared
extern variables. When they become modules, that will change.
This is the first in a series of patches to isolate ocfs2 from the
underlying cluster stack. Here we wrap the dlm locking functions with
ocfs2-specific calls. Because ocfs2 always uses the same dlm lock status
callbacks, we can eliminate the callbacks from the filesystem visible
functions.
Hook up ocfs2_flock(), using the new flock lock type in dlmglue.c. A new
mount option, "localflocks" is added so that users can revert to old
functionality as need be.
Signed-off-by: Mark Fasheh <mark.fasheh@oracle.com>
This patch adds the ability for a userspace program to request an extend of
last cluster group on an Ocfs2 file system. The request is made via ioctl,
OCFS2_IOC_GROUP_EXTEND. This is derived from EXT3_IOC_GROUP_EXTEND, but is
obviously Ocfs2 specific.
tunefs.ocfs2 would call this for an online-resize operation if the last
cluster group isn't full.
The node maps that are set/unset by these votes are no longer relevant, thus
we can remove the mount and umount votes. Since those are the last two
remaining votes, we can also remove the entire vote infrastructure.
The vote thread has been renamed to the downconvert thread, and the small
amount of functionality related to managing it has been moved into
fs/ocfs2/dlmglue.c. All references to votes have been removed or updated.
Support immutable, and other attributes.
Some renaming and other minor fixes done by myself.
Signed-off-by: Herbert Poetzl <herbert@13thfloor.at>
The OCFS2 file system module.
Signed-off-by: Kurt Hackel <kurt.hackel@oracle.com>
