path: root/fs/ocfs2/export.c
2009-04-21ocfs2: Fix some printk() warnings.Joel Becker
The old %llu vs u64 battle. Cast them correctly. Signed-off-by: Joel Becker <joel.becker@oracle.com>
2009-04-03ocfs2: fix rare stale inode errors when exporting via nfswengang wang
For nfs exporting, ocfs2_get_dentry() returns the dentry for fh. ocfs2_get_dentry() may read from disk when the inode is not in memory, without any cross cluster lock. this leads to the file system loading a stale inode. This patch fixes above problem. Solution is that in case of inode is not in memory, we get the cluster lock(PR) of alloc inode where the inode in question is allocated from (this causes node on which deletion is done sync the alloc inode) before reading out the inode itsself. then we check the bitmap in the group (the inode in question allcated from) to see if the bit is clear. if it's clear then it's stale. if the bit is set, we then check generation as the existing code does. We have to read out the inode in question from disk first to know its alloc slot and allot bit. And if its not stale we read it out using ocfs2_iget(). The second read should then be from cache. And also we have to add a per superblock nfs_sync_lock to cover the lock for alloc inode and that for inode in question. this is because ocfs2_get_dentry() and ocfs2_delete_inode() lock on them in reverse order. nfs_sync_lock is locked in EX mode in ocfs2_get_dentry() and in PR mode in ocfs2_delete_inode(). so that mutliple ocfs2_delete_inode() can run concurrently in normal case. [mfasheh@suse.com: build warning fixes and comment cleanups] Signed-off-by: Wengang Wang <wen.gang.wang@oracle.com> Acked-by: Joel Becker <joel.becker@oracle.com> Signed-off-by: Mark Fasheh <mfasheh@suse.com>
2008-10-23[PATCH] switch all filesystems over to d_obtain_aliasChristoph Hellwig
Switch all users of d_alloc_anon to d_obtain_alias. Signed-off-by: Christoph Hellwig <hch@lst.de> Signed-off-by: Al Viro <viro@zeniv.linux.org.uk>
2008-01-25ocfs2: Silence false lockdep warningsJan Kara
Create separate lockdep lock classes for system file's i_mutexes. They are used to guard allocations and similar things and thus rank differently than i_mutex of a regular file or directory. Signed-off-by: Jan Kara <jack@suse.cz> Signed-off-by: Mark Fasheh <mark.fasheh@oracle.com>
2008-01-25ocfs2: Rename ocfs2_meta_[un]lockMark Fasheh
Call this the "inode_lock" now, since it covers both data and meta data. This patch makes no functional changes. Signed-off-by: Mark Fasheh <mark.fasheh@oracle.com>
2007-10-22exportfs: make struct export_operations constChristoph Hellwig
Now that nfsd has stopped writing to the find_exported_dentry member we an mark the export_operations const Signed-off-by: Christoph Hellwig <hch@lst.de> Cc: Neil Brown <neilb@suse.de> Cc: "J. Bruce Fields" <bfields@fieldses.org> Cc: <linux-ext4@vger.kernel.org> Cc: Dave Kleikamp <shaggy@austin.ibm.com> Cc: Anton Altaparmakov <aia21@cantab.net> Cc: David Chinner <dgc@sgi.com> Cc: Timothy Shimmin <tes@sgi.com> Cc: OGAWA Hirofumi <hirofumi@mail.parknet.co.jp> Cc: Hugh Dickins <hugh@veritas.com> Cc: Chris Mason <mason@suse.com> Cc: Jeff Mahoney <jeffm@suse.com> Cc: "Vladimir V. Saveliev" <vs@namesys.com> Cc: Steven Whitehouse <swhiteho@redhat.com> Cc: Mark Fasheh <mark.fasheh@oracle.com> Signed-off-by: Andrew Morton <akpm@linux-foundation.org> Signed-off-by: Linus Torvalds <torvalds@linux-foundation.org>
2007-10-22ocfs2: new export opsChristoph Hellwig
OCFS2 has it's own 64bit-firendly filehandle format so we can't use the generic helpers here. I'll add a struct for the types later. Signed-off-by: Christoph Hellwig <hch@lst.de> Cc: Neil Brown <neilb@suse.de> Cc: "J. Bruce Fields" <bfields@fieldses.org> Cc: Mark Fasheh <mark.fasheh@oracle.com> Signed-off-by: Andrew Morton <akpm@linux-foundation.org> Signed-off-by: Linus Torvalds <torvalds@linux-foundation.org>
2007-10-12ocfs2: Provide convenience function for ino lookupMark Fasheh
A couple paths which needed to just match a parent dir + name pair to an inode number were a bit messy because they had to deal with ocfs2_find_files_on_disk() which returns a larger number of values. Provide a convenience function, ocfs2_lookup_ino_from_name() which internalizes all the extra accounting. Signed-off-by: Mark Fasheh <mark.fasheh@oracle.com> Reviewed-by: Joel Becker <joel.becker@oracle.com>
2007-05-02ocfs2: fix sparse warnings in fs/ocfs2Mark Fasheh
None of these are actually harmful, but the noise makes looking for real problems difficult. Signed-off-by: Mark Fasheh <mark.fasheh@oracle.com>
2007-01-21ocfs2: cleanup ocfs2_iget() errorsMark Fasheh
Get rid of some error prints in the ocfs2_iget() path from ocfs2_get_dentry(). NFSD can easily cause us to read stale inodes. Signed-off-by: Mark Fasheh <mark.fasheh@oracle.com>
2006-12-01ocfs2: remove unused handle argument from ocfs2_meta_lock_full()Mark Fasheh
Now that this is unused and all callers pass NULL, we can safely remove it. Signed-off-by: Mark Fasheh <mark.fasheh@oracle.com>
2006-09-24ocfs2: Remove i_generation from inode lock namesMark Fasheh
OCFS2 puts inode meta data in the "lock value block" provided by the DLM. Typically, i_generation is encoded in the lock name so that a deleted inode on and a new one in the same block don't share the same lvb. Unfortunately, that scheme means that the read in ocfs2_read_locked_inode() is potentially thrown away as soon as the meta data lock is taken - we cannot encode the lock name without first knowing i_generation, which requires a disk read. This patch encodes i_generation in the inode meta data lvb, and removes the value from the inode meta data lock name. This way, the read can be covered by a lock, and at the same time we can distinguish between an up to date and a stale LVB. This will help cold-cache stat(2) performance in particular. Since this patch changes the protocol version, we take the opportunity to do a minor re-organization of two of the LVB fields. Signed-off-by: Mark Fasheh <mark.fasheh@oracle.com>
2006-09-24ocfs2: Hook rest of the file system into dentry locking APIMark Fasheh
Actually replace the vote calls with the new dentry operations. Make any necessary adjustments to get the scheme to work. Signed-off-by: Mark Fasheh <mark.fasheh@oracle.com>
2006-03-24ocfs2: don't use MLF* in the file systemMark Fasheh
2006-01-03[PATCH] OCFS2: The Second Oracle Cluster FilesystemMark Fasheh
The OCFS2 file system module. Signed-off-by: Mark Fasheh <mark.fasheh@oracle.com> Signed-off-by: Kurt Hackel <kurt.hackel@oracle.com>
