path: root/fs/ocfs2/localalloc.c
2008-04-30ocfs2: Use GFP_NOFS in kmalloc during localalloc window moveSunil Mushran
kmalloc() during a localalloc window move can trigger the mm to prune the dcache which inturn can trigger the fs to delete an inode causing it start a recursive transaction. The fix also makes the change in kmalloc during localalloc shutdown just to be safe. Fixes oss bugzilla#901 http://oss.oracle.com/bugzilla/show_bug.cgi?id=901 Signed-off-by: Sunil Mushran <sunil.mushran@oracle.com> Signed-off-by: Mark Fasheh <mfasheh@suse.com>
2008-04-18ocfs2: Add inode stealing for ocfs2_reserve_new_inodeTao Ma
Inode allocation is modified to look in other nodes allocators during extreme out of space situations. We retry our own slot when space is freed back to the global bitmap, or whenever we've allocated more than 1024 inodes from another slot. Signed-off-by: Tao Ma <tao.ma@oracle.com> Signed-off-by: Mark Fasheh <mfasheh@suse.com>
2008-04-18ocfs2: Add ac_alloc_slot in ocfs2_alloc_contextTao Ma
In inode stealing, we no longer restrict the allocation to happen in the local node. So it is neccessary for us to add a new member in ocfs2_alloc_context to indicate which slot we are using for allocation. We also modify the process of local alloc so that this member can be used there also. Signed-off-by: Tao Ma <tao.ma@oracle.com> Signed-off-by: Sunil Mushran <sunil.mushran@oracle.com> Signed-off-by: Mark Fasheh <mfasheh@suse.com>
2008-03-03[PATCH] ocfs2: le*_add_cpu conversionMarcin Slusarz
replace all: little_endian_variable = cpu_to_leX(leX_to_cpu(little_endian_variable) + expression_in_cpu_byteorder); with: leX_add_cpu(&little_endian_variable, expression_in_cpu_byteorder); generated with semantic patch Signed-off-by: Marcin Slusarz <marcin.slusarz@gmail.com> Signed-off-by: Mark Fasheh <mark.fasheh@oracle.com>
2008-03-03ocfs2: Enable localalloc for local mountsSunil Mushran
Commit 2fbe8d1ebe004425b4f7b8bba345623d2280be82 disabled localalloc for local mounts. This caused issues as ocfs2 uses localalloc to provide write locality. This patch enables localalloc for local mounts. Signed-off-by: Sunil Mushran <sunil.mushran@oracle.com> Signed-off-by: Mark Fasheh <mark.fasheh@oracle.com>
2008-01-25ocfs2: Local alloc window size changeable via mount optionSunil Mushran
Local alloc is a performance optimization in ocfs2 in which a node takes a window of bits from the global bitmap and then uses that for all small local allocations. This window size is fixed to 8MB currently. This patch allows users to specify the window size in MB including disabling it by passing in 0. If the number specified is too large, the fs will use the default value of 8MB. mount -o localalloc=X /dev/sdX /mntpoint Signed-off-by: Sunil Mushran <sunil.mushran@oracle.com> Signed-off-by: Mark Fasheh <mark.fasheh@oracle.com>
2008-01-25ocfs2: Rename ocfs2_meta_[un]lockMark Fasheh
Call this the "inode_lock" now, since it covers both data and meta data. This patch makes no functional changes. Signed-off-by: Mark Fasheh <mark.fasheh@oracle.com>
2007-11-27[PATCH] ocfs2: Remove expensive bitmap scanningJan Kara
Enable expensive bitmap scanning only if DEBUG option is enabled. The bitmap scanning quite loads the CPU and on my machine the write throughput of dd if=/dev/zero of=/ocfs2/file bs=1M count=500 conv=sync improves from 37 MB/s to 45.4 MB/s in local mode... Signed-off-by: Jan Kara <jack@suse.cz> Signed-off-by: Mark Fasheh <mark.fasheh@oracle.com>
2007-10-03ocfs2: Unlock mutex in local alloc failure caseSunil Mushran
The fs was not unlocking the local alloc inode mutex in the code path in which it failed to find a window of free bits in the global bitmap. Signed-off-by: Sunil Mushran <sunil.mushran@oracle.com> Signed-off-by: Mark Fasheh <mark.fasheh@oracle.com>
2007-09-20ocfs2: Allow smaller allocations during large writesMark Fasheh
The ocfs2 write code loops through a page much like the block code, except that ocfs2 allocation units can be any size, including larger than page size. Typically it's equal to or larger than page size - most kernels run 4k pages, the minimum ocfs2 allocation (cluster) size. Some changes introduced during 2.6.23 changed the way writes to pages are handled, and inadvertantly broke support for > 4k page size. Instead of just writing one cluster at a time, we now handle the whole page in one pass. This means that multiple (small) seperate allocations might happen in the same pass. The allocation code howver typically optimizes by getting the maximum which was reserved. This triggered a BUG_ON in the extend code where it'd ask for a single bit (for one part of a > 4k page) and get back more than it asked for. Fix this by providing a variant of the high level allocation function which allows the caller to specify a maximum. The traditional function remains and just calls the new one with a maximum determined from the initial reservation. Signed-off-by: Mark Fasheh <mark.fasheh@oracle.com>
2007-05-25ocfs2: fix inode leakMark Fasheh
We weren't cleaning up our inode reference on error in ocfs2_reserve_local_alloc_bits(). Add a check for error return and iput() if need be. Move the code to set the alloc context inode info to the end of the function so we don't have any possibility of passing back a bad pointer. Signed-off-by: Mark Fasheh <mark.fasheh@oracle.com>
2006-12-13[PATCH] Fix numerous kcalloc() calls, convert to kzalloc()Robert P. J. Day
All kcalloc() calls of the form "kcalloc(1,...)" are converted to the equivalent kzalloc() calls, and a few kcalloc() calls with the incorrect ordering of the first two arguments are fixed. Signed-off-by: Robert P. J. Day <rpjday@mindspring.com> Cc: Jeff Garzik <jeff@garzik.org> Cc: Alan Cox <alan@lxorguk.ukuu.org.uk> Cc: Dominik Brodowski <linux@dominikbrodowski.net> Cc: Adam Belay <ambx1@neo.rr.com> Cc: James Bottomley <James.Bottomley@steeleye.com> Cc: Greg KH <greg@kroah.com> Cc: Mark Fasheh <mark.fasheh@oracle.com> Cc: Trond Myklebust <trond.myklebust@fys.uio.no> Cc: Neil Brown <neilb@suse.de> Signed-off-by: Andrew Morton <akpm@osdl.org> Signed-off-by: Linus Torvalds <torvalds@osdl.org>
2006-12-01ocfs2: Remove struct ocfs2_journal_handle in favor of handle_tMark Fasheh
This is mostly a search and replace as ocfs2_journal_handle is now no more than a container for a handle_t pointer. ocfs2_commit_trans() becomes very straight forward, and we remove some out of date comments / code. Signed-off-by: Mark Fasheh <mark.fasheh@oracle.com>
2006-12-01ocfs2: remove handle argument to ocfs2_start_trans()Mark Fasheh
All callers either pass in NULL directly, or a local variable that is already set to NULL. The internals of ocfs2_start_trans() get a nice cleanup as a result. Signed-off-by: Mark Fasheh <mark.fasheh@oracle.com>
2006-12-01ocfs2: pass ocfs2_super * into ocfs2_commit_trans()Mark Fasheh
This sets us up to remove handle->journal. Signed-off-by: Mark Fasheh <mark.fasheh@oracle.com>
2006-12-01ocfs2: remove unused handle argument from ocfs2_meta_lock_full()Mark Fasheh
Now that this is unused and all callers pass NULL, we can safely remove it. Signed-off-by: Mark Fasheh <mark.fasheh@oracle.com>
2006-12-01ocfs2: don't use handle for locking in allocation functionsMark Fasheh
Instead we record our state on the allocation context structure which all callers already know about and lifetime correctly. This means the reservation functions don't need a handle passed in any more, and we can also take it off the alloc context. Signed-off-by: Mark Fasheh <mark.fasheh@oracle.com>
2006-12-01ocfs2: don't pass handle to ocfs2_meta_lock() in localalloc.cMark Fasheh
Take and drop the locks directly. Signed-off-by: Mark Fasheh <mark.fasheh@oracle.com>
2006-12-01ocfs2: remove ocfs2_journal_handle flags fieldMark Fasheh
Callers can set h_sync directly on the handle_t, whether a transaction has been started or not can be determined via the existence of the handle_t on the struct ocfs2_journal_handle. Signed-off-by: Mark Fasheh <mark.fasheh@oracle.com>
2006-08-07ocfs2: allocation hintsMark Fasheh
Record the most recently used allocation group on the allocation context, so that subsequent allocations can attempt to optimize for contiguousness. Local alloc especially should benefit from this as the current chain search tends to let it spew across the disk. Signed-off-by: Mark Fasheh <mark.fasheh@oracle.com>
2006-03-24ocfs2: don't use MLF* in the file systemMark Fasheh
2006-01-09[PATCH] mutex subsystem, semaphore to mutex: VFS, ->i_semJes Sorensen
This patch converts the inode semaphore to a mutex. I have tested it on XFS and compiled as much as one can consider on an ia64. Anyway your luck with it might be different. Modified-by: Ingo Molnar <mingo@elte.hu> (finished the conversion) Signed-off-by: Jes Sorensen <jes@sgi.com> Signed-off-by: Ingo Molnar <mingo@elte.hu>
2006-01-03[PATCH] OCFS2: The Second Oracle Cluster FilesystemMark Fasheh
The OCFS2 file system module. Signed-off-by: Mark Fasheh <mark.fasheh@oracle.com> Signed-off-by: Kurt Hackel <kurt.hackel@oracle.com>
