path: root/fs/ocfs2/symlink.c
2011-02-21ocfs2: remove NAMEI from symlink.cTao Ma
No mlog(0,...) in symlink.c, so just remove NAMEI. Signed-off-by: Tao Ma <boyu.mt@taobao.com>
2011-03-07ocfs2: Remove EXIT from masklog.Tao Ma
mlog_exit is used to record the exit status of a function. But because it is added in so many functions, if we enable it, the system logs get filled up quickly and cause too much I/O. So actually no one can open it for a production system or even for a test. This patch just try to remove it or change it. So: 1. if all the error paths already use mlog_errno, it is just removed. Otherwise, it will be replaced by mlog_errno. 2. if it is used to print some return value, it is replaced with mlog(0,...). mlog_exit_ptr is changed to mlog(0. All those mlog(0,...) will be replaced with trace events later. Signed-off-by: Tao Ma <boyu.mt@taobao.com>
2011-02-21ocfs2: Remove ENTRY from masklog.Tao Ma
ENTRY is used to record the entry of a function. But because it is added in so many functions, if we enable it, the system logs get filled up quickly and cause too much I/O. So actually no one can open it for a production system or even for a test. So for mlog_entry_void, we just remove it. for mlog_entry(...), we replace it with mlog(0,...), and they will be replace by trace event later. Signed-off-by: Tao Ma <boyu.mt@taobao.com>
2010-09-29ocfs2: Don't walk off the end of fast symlinks.Joel Becker
ocfs2 fast symlinks are NUL terminated strings stored inline in the inode data area. However, disk corruption or a local attacker could, in theory, remove that NUL. Because we're using strlen() (my fault, introduced in a731d1 when removing vfs_follow_link()), we could walk off the end of that string. Signed-off-by: Joel Becker <joel.becker@oracle.com> Cc: stable@kernel.org
2010-01-11ocfs2: Fix refcnt leak on ocfs2_fast_follow_link() error pathOGAWA Hirofumi
If ->follow_link handler returns an error, it should decrement nd->path refcnt. But ocfs2_fast_follow_link() doesn't decrement. This patch fixes the problem by using nd_set_link() style error handling instead of playing with nd->path. Signed-off-by: OGAWA Hirofumi <hirofumi@mail.parknet.co.jp> Signed-off-by: Joel Becker <joel.becker@oracle.com>
2009-12-23Ocfs2: Let ocfs2 support fiemap for symlink and fast symlink.Tristan Ye
For fast symlink, it can be treated the same as inlined files since the data extent we want to return of both case all were stored in metadata block. For symlink, it can be simply treated the same as we did for regular files. Signed-off-by: Tristan Ye <tristan.ye@oracle.com> Acked-by: Sunil Mushran <sunil.mushran@oracle.com> Signed-off-by: Joel Becker <joel.becker@oracle.com>
2009-09-23headers: utsname.h reduxAlexey Dobriyan
* remove asm/atomic.h inclusion from linux/utsname.h -- not needed after kref conversion * remove linux/utsname.h inclusion from files which do not need it NOTE: it looks like fs/binfmt_elf.c do not need utsname.h, however due to some personality stuff it _is_ needed -- cowardly leave ELF-related headers and files alone. Signed-off-by: Alexey Dobriyan <adobriyan@gmail.com> Signed-off-by: Linus Torvalds <torvalds@linux-foundation.org>
2009-05-09ocfs2: Use nd_set_link().Joel Becker
ocfs2 was hand-calling vfs_follow_link(), but there's no point to that. Let's use page_follow_link_light() and nd_set_link(). Signed-off-by: Joel Becker <joel.becker@oracle.com> Signed-off-by: Al Viro <viro@zeniv.linux.org.uk>
2009-01-05ocfs2: Wrap inode block reads in a dedicated function.Joel Becker
The ocfs2 code currently reads inodes off disk with a simple ocfs2_read_block() call. Each place that does this has a different set of sanity checks it performs. Some check only the signature. A couple validate the block number (the block read vs di->i_blkno). A couple others check for VALID_FL. Only one place validates i_fs_generation. A couple check nothing. Even when an error is found, they don't all do the same thing. We wrap inode reading into ocfs2_read_inode_block(). This will validate all the above fields, going readonly if they are invalid (they never should be). ocfs2_read_inode_block_full() is provided for the places that want to pass read_block flags. Every caller is passing a struct inode with a valid ip_blkno, so we don't need a separate blkno argument either. We will remove the validation checks from the rest of the code in a later commit, as they are no longer necessary. Signed-off-by: Joel Becker <joel.becker@oracle.com> Signed-off-by: Mark Fasheh <mfasheh@suse.com>
2008-10-14ocfs2: Simplify ocfs2_read_block()Joel Becker
More than 30 callers of ocfs2_read_block() pass exactly OCFS2_BH_CACHED. Only six pass a different flag set. Rather than have every caller care, let's make ocfs2_read_block() take no flags and always do a cached read. The remaining six places can call ocfs2_read_blocks() directly. Signed-off-by: Joel Becker <joel.becker@oracle.com> Signed-off-by: Mark Fasheh <mfasheh@suse.com>
2008-10-14ocfs2: Require an inode for ocfs2_read_block(s)().Joel Becker
Now that synchronous readers are using ocfs2_read_blocks_sync(), all callers of ocfs2_read_blocks() are passing an inode. Use it unconditionally. Since it's there, we don't need to pass the ocfs2_super either. Signed-off-by: Joel Becker <joel.becker@oracle.com> Signed-off-by: Mark Fasheh <mfasheh@suse.com>
2008-10-13ocfs2: Don't check for NULL before brelse()Mark Fasheh
This is pointless as brelse() already does the check. Signed-off-by: Mark Fasheh
2008-10-13ocfs2: Add extended attribute supportTiger Yang
This patch implements storing extended attributes both in inode or a single external block. We only store EA's in-inode when blocksize > 512 or that inode block has free space for it. When an EA's value is larger than 80 bytes, we will store the value via b-tree outside inode or block. Signed-off-by: Tiger Yang <tiger.yang@oracle.com> Signed-off-by: Mark Fasheh <mfasheh@suse.com>
2008-04-30ocfs2: Allow uid/gid/perm changes of symlinksSunil Mushran
This patch adds the ability to change attributes of a symlink. Fixes oss bugzilla#963 http://oss.oracle.com/bugzilla/show_bug.cgi?id=963 Signed-off-by: Sunil Mushran <sunil.mushran@oracle.com> Signed-off-by: Mark Fasheh <mfasheh@suse.com>
2007-05-07mm: make read_cache_page synchronousNick Piggin
Ensure pages are uptodate after returning from read_cache_page, which allows us to cut out most of the filesystem-internal PageUptodate calls. I didn't have a great look down the call chains, but this appears to fixes 7 possible use-before uptodate in hfs, 2 in hfsplus, 1 in jfs, a few in ecryptfs, 1 in jffs2, and a possible cleared data overwritten with readpage in block2mtd. All depending on whether the filler is async and/or can return with a !uptodate page. Signed-off-by: Nick Piggin <npiggin@suse.de> Cc: Hugh Dickins <hugh@veritas.com> Signed-off-by: Andrew Morton <akpm@linux-foundation.org> Signed-off-by: Linus Torvalds <torvalds@linux-foundation.org>
2007-02-12[PATCH] mark struct inode_operations const 2Arjan van de Ven
2007-01-21ocfs2: Don't print errors when following symlinksMark Fasheh
We shouldn't print errors returned from vfs_follow_link(). This was causing spurious errors to show up in the logs. Signed-off-by: Mark Fasheh <mark.fasheh@oracle.com>
2006-12-01ocfs2: update file system paths to set atimeTiger Yang
Conditionally update atime in ocfs2_file_aio_read(), ocfs2_readdir() and ocfs2_mmap(). Signed-off-by: Tiger Yang <tiger.yang@oracle.com> Signed-off-by: Mark Fasheh <mark.fasheh@oracle.com>
2006-06-29ocfs2: silence ENOENT during lookup of broken linksSunil Mushran
Signed-off-by: Sunil Mushran <sunil.mushran@oracle.com> Signed-off-by: Mark Fasheh <mark.fasheh@oracle.com>
2006-06-23[PATCH] read_mapping_page for address spacePekka Enberg
Add read_mapping_page() which is used for callers that pass mapping->a_ops->readpage as the filler for read_cache_page. This removes some duplication from filesystem code. Signed-off-by: Pekka Enberg <penberg@cs.helsinki.fi> Signed-off-by: Andrew Morton <akpm@osdl.org> Signed-off-by: Linus Torvalds <torvalds@osdl.org>
2006-01-03[PATCH] OCFS2: The Second Oracle Cluster FilesystemMark Fasheh
The OCFS2 file system module. Signed-off-by: Mark Fasheh <mark.fasheh@oracle.com> Signed-off-by: Kurt Hackel <kurt.hackel@oracle.com>
