path: root/fs/ocfs2
2013-09-26ocfs2: fix the end cluster offset of FIEMAPJie Liu
commit 28e8be31803b19d0d8f76216cb11b480b8a98bec upstream. Call fiemap ioctl(2) with given start offset as well as an desired mapping range should show extents if possible. However, we somehow figure out the end offset of mapping via 'mapping_end -= cpos' before iterating the extent records which would cause problems if the given fiemap length is too small to a cluster size, e.g, Cluster size 4096: debugfs.ocfs2 1.6.3 Block Size Bits: 12 Cluster Size Bits: 12 The extended fiemap test utility From David: https://gist.github.com/anonymous/6172331 # dd if=/dev/urandom of=/ocfs2/test_file bs=1M count=1000 # ./fiemap /ocfs2/test_file 4096 10 start: 4096, length: 10 File /ocfs2/test_file has 0 extents: # Logical Physical Length Flags ^^^^^ <-- No extent is shown In this case, at ocfs2_fiemap(): cpos == mapping_end == 1. Hence the loop of searching extent records was not executed at all. This patch remove the in question 'mapping_end -= cpos', and loops until the cpos is larger than the mapping_end as usual. # ./fiemap /ocfs2/test_file 4096 10 start: 4096, length: 10 File /ocfs2/test_file has 1 extents: # Logical Physical Length Flags 0: 0000000000000000 0000000056a01000 0000000006a00000 0000 Signed-off-by: Jie Liu <jeff.liu@oracle.com> Reported-by: David Weber <wb@munzinger.de> Tested-by: David Weber <wb@munzinger.de> Cc: Sunil Mushran <sunil.mushran@gmail.com> Cc: Mark Fashen <mfasheh@suse.de> Cc: Joel Becker <jlbec@evilplan.org> Signed-off-by: Andrew Morton <akpm@linux-foundation.org> Signed-off-by: Linus Torvalds <torvalds@linux-foundation.org> Signed-off-by: Greg Kroah-Hartman <gregkh@linuxfoundation.org>
2013-07-21ocfs2: xattr: fix inlined xattr reflinkJunxiao Bi
commit ef962df057aaafd714f5c22ba3de1be459571fdf upstream. Inlined xattr shared free space of inode block with inlined data or data extent record, so the size of the later two should be adjusted when inlined xattr is enabled. See ocfs2_xattr_ibody_init(). But this isn't done well when reflink. For inode with inlined data, its max inlined data size is adjusted in ocfs2_duplicate_inline_data(), no problem. But for inode with data extent record, its record count isn't adjusted. Fix it, or data extent record and inlined xattr may overwrite each other, then cause data corruption or xattr failure. One panic caused by this bug in our test environment is the following: kernel BUG at fs/ocfs2/xattr.c:1435! invalid opcode: 0000 [#1] SMP Pid: 10871, comm: multi_reflink_t Not tainted 2.6.39-300.17.1.el5uek #1 RIP: ocfs2_xa_offset_pointer+0x17/0x20 [ocfs2] RSP: e02b:ffff88007a587948 EFLAGS: 00010283 RAX: 0000000000000000 RBX: 0000000000000010 RCX: 00000000000051e4 RDX: ffff880057092060 RSI: 0000000000000f80 RDI: ffff88007a587a68 RBP: ffff88007a587948 R08: 00000000000062f4 R09: 0000000000000000 R10: 0000000000000000 R11: 0000000000000000 R12: 0000000000000010 R13: ffff88007a587a68 R14: 0000000000000001 R15: ffff88007a587c68 FS: 00007fccff7f06e0(0000) GS:ffff88007fc00000(0000) knlGS:0000000000000000 CS: e033 DS: 0000 ES: 0000 CR0: 000000008005003b CR2: 00000000015cf000 CR3: 000000007aa76000 CR4: 0000000000000660 DR0: 0000000000000000 DR1: 0000000000000000 DR2: 0000000000000000 DR3: 0000000000000000 DR6: 00000000ffff0ff0 DR7: 0000000000000400 Process multi_reflink_t Call Trace: ocfs2_xa_reuse_entry+0x60/0x280 [ocfs2] ocfs2_xa_prepare_entry+0x17e/0x2a0 [ocfs2] ocfs2_xa_set+0xcc/0x250 [ocfs2] ocfs2_xattr_ibody_set+0x98/0x230 [ocfs2] __ocfs2_xattr_set_handle+0x4f/0x700 [ocfs2] ocfs2_xattr_set+0x6c6/0x890 [ocfs2] ocfs2_xattr_user_set+0x46/0x50 [ocfs2] generic_setxattr+0x70/0x90 __vfs_setxattr_noperm+0x80/0x1a0 vfs_setxattr+0xa9/0xb0 setxattr+0xc3/0x120 sys_fsetxattr+0xa8/0xd0 system_call_fastpath+0x16/0x1b Signed-off-by: Junxiao Bi <junxiao.bi@oracle.com> Reviewed-by: Jie Liu <jeff.liu@oracle.com> Acked-by: Joel Becker <jlbec@evilplan.org> Cc: Mark Fasheh <mfasheh@suse.com> Cc: Sunil Mushran <sunil.mushran@gmail.com> Signed-off-by: Andrew Morton <akpm@linux-foundation.org> Signed-off-by: Linus Torvalds <torvalds@linux-foundation.org> Signed-off-by: Greg Kroah-Hartman <gregkh@linuxfoundation.org>
2013-06-12ocfs2: add missing lockres put in dlm_mig_lockres_handlerXue jiufei
dlm_mig_lockres_handler() is missing a dlm_lockres_put() on an error path. Signed-off-by: joyce <xuejiufei@huawei.com> Reviewed-by: shencanquan <shencanquan@huawei.com> Cc: Mark Fasheh <mfasheh@suse.com> Cc: Joel Becker <jlbec@evilplan.org> Signed-off-by: Andrew Morton <akpm@linux-foundation.org> Signed-off-by: Linus Torvalds <torvalds@linux-foundation.org>
2013-06-12fs/ocfs2/namei.c: remove unecessary ERROR when removing non-empty directoryGoldwyn Rodrigues
While removing a non-empty directory, the kernel dumps a message: (rmdir,21743,1):ocfs2_unlink:953 ERROR: status = -39 Suppress the error message from being printed in the dmesg so users don't panic. Signed-off-by: Goldwyn Rodrigues <rgoldwyn@suse.com> Cc: Mark Fasheh <mfasheh@suse.com> Cc: Joel Becker <jlbec@evilplan.org> Acked-by: Sunil Mushran <sunil.mushran@gmail.com> Reviewed-by: Jie Liu <jeff.liu@oracle.com> Signed-off-by: Andrew Morton <akpm@linux-foundation.org> Signed-off-by: Linus Torvalds <torvalds@linux-foundation.org>
2013-06-12ocfs2: ocfs2_prep_new_orphaned_file() should return retXiaowei.Hu
If an error occurs, for example an EIO in __ocfs2_prepare_orphan_dir, ocfs2_prep_new_orphaned_file will release the inode_ac, then when the caller of ocfs2_prep_new_orphaned_file gets a 0 return, it will refer to a NULL ocfs2_alloc_context struct in the following functions. A kernel panic happens. Signed-off-by: "Xiaowei.Hu" <xiaowei.hu@oracle.com> Reviewed-by: shencanquan <shencanquan@huawei.com> Acked-by: Sunil Mushran <sunil.mushran@gmail.com> Cc: Joe Jin <joe.jin@oracle.com> Cc: Mark Fasheh <mfasheh@suse.com> Cc: Joel Becker <jlbec@evilplan.org> Signed-off-by: Andrew Morton <akpm@linux-foundation.org> Signed-off-by: Linus Torvalds <torvalds@linux-foundation.org>
2013-05-24ocfs2: goto out_unlock if ocfs2_get_clusters_nocache() failed in ocfs2_fiemap()Joseph Qi
Last time we found there is lock/unlock bug in ocfs2_file_aio_write, and then we did a thorough search for all lock resources in ocfs2_inode_info, including rw, inode and open lockres and found this bug. My kernel version is 3.0.13, and it is also in the lastest version 3.9. In ocfs2_fiemap, once ocfs2_get_clusters_nocache failed, it should goto out_unlock instead of out, because we need release buffer head, up read alloc sem and unlock inode. Signed-off-by: Joseph Qi <joseph.qi@huawei.com> Reviewed-by: Jie Liu <jeff.liu@oracle.com> Cc: Mark Fasheh <mfasheh@suse.com> Cc: Joel Becker <jlbec@evilplan.org> Acked-by: Sunil Mushran <sunil.mushran@gmail.com> Cc: <stable@vger.kernel.org> Signed-off-by: Andrew Morton <akpm@linux-foundation.org> Signed-off-by: Linus Torvalds <torvalds@linux-foundation.org>
2013-05-24ocfs2: unlock rw lock if inode lock failedJoseph Qi
In ocfs2_file_aio_write(), it does ocfs2_rw_lock() first and then ocfs2_inode_lock(). But if ocfs2_inode_lock() failed, it goes to out_sems without unlocking rw lock. This will cause a bug in ocfs2_lock_res_free() when testing res->l_ex_holders, which is increased in __ocfs2_cluster_lock() and decreased in __ocfs2_cluster_unlock(). Signed-off-by: Joseph Qi <joseph.qi@huawei.com> Cc: Joel Becker <jlbec@evilplan.org> Cc: Mark Fasheh <mfasheh@suse.com> Cc: Li Zefan <lizefan@huawei.com> Cc: "Duyongfeng (B)" <du.duyongfeng@huawei.com> Acked-by: Sunil Mushran <sunil.mushran@gmail.com> Signed-off-by: Andrew Morton <akpm@linux-foundation.org> Signed-off-by: Linus Torvalds <torvalds@linux-foundation.org>
2013-05-07aio: don't include aio.h in sched.hKent Overstreet
Faster kernel compiles by way of fewer unnecessary includes. [akpm@linux-foundation.org: fix fallout] [akpm@linux-foundation.org: fix build] Signed-off-by: Kent Overstreet <koverstreet@google.com> Cc: Zach Brown <zab@redhat.com> Cc: Felipe Balbi <balbi@ti.com> Cc: Greg Kroah-Hartman <gregkh@linuxfoundation.org> Cc: Mark Fasheh <mfasheh@suse.com> Cc: Joel Becker <jlbec@evilplan.org> Cc: Rusty Russell <rusty@rustcorp.com.au> Cc: Jens Axboe <axboe@kernel.dk> Cc: Asai Thambi S P <asamymuthupa@micron.com> Cc: Selvan Mani <smani@micron.com> Cc: Sam Bradshaw <sbradshaw@micron.com> Cc: Jeff Moyer <jmoyer@redhat.com> Cc: Al Viro <viro@zeniv.linux.org.uk> Cc: Benjamin LaHaise <bcrl@kvack.org> Reviewed-by: "Theodore Ts'o" <tytso@mit.edu> Signed-off-by: Andrew Morton <akpm@linux-foundation.org> Signed-off-by: Linus Torvalds <torvalds@linux-foundation.org>
2013-05-07aio: remove retry-based AIOZach Brown
This removes the retry-based AIO infrastructure now that nothing in tree is using it. We want to remove retry-based AIO because it is fundemantally unsafe. It retries IO submission from a kernel thread that has only assumed the mm of the submitting task. All other task_struct references in the IO submission path will see the kernel thread, not the submitting task. This design flaw means that nothing of any meaningful complexity can use retry-based AIO. This removes all the code and data associated with the retry machinery. The most significant benefit of this is the removal of the locking around the unused run list in the submission path. [akpm@linux-foundation.org: coding-style fixes] Signed-off-by: Kent Overstreet <koverstreet@google.com> Signed-off-by: Zach Brown <zab@redhat.com> Cc: Zach Brown <zab@redhat.com> Cc: Felipe Balbi <balbi@ti.com> Cc: Greg Kroah-Hartman <gregkh@linuxfoundation.org> Cc: Mark Fasheh <mfasheh@suse.com> Cc: Joel Becker <jlbec@evilplan.org> Cc: Rusty Russell <rusty@rustcorp.com.au> Cc: Jens Axboe <axboe@kernel.dk> Cc: Asai Thambi S P <asamymuthupa@micron.com> Cc: Selvan Mani <smani@micron.com> Cc: Sam Bradshaw <sbradshaw@micron.com> Acked-by: Jeff Moyer <jmoyer@redhat.com> Cc: Al Viro <viro@zeniv.linux.org.uk> Cc: Benjamin LaHaise <bcrl@kvack.org> Reviewed-by: "Theodore Ts'o" <tytso@mit.edu> Signed-off-by: Andrew Morton <akpm@linux-foundation.org> Signed-off-by: Linus Torvalds <torvalds@linux-foundation.org>
2013-05-01Merge branch 'for-linus' of ↵Linus Torvalds
git://git.kernel.org/pub/scm/linux/kernel/git/viro/vfs Pull VFS updates from Al Viro, Misc cleanups all over the place, mainly wrt /proc interfaces (switch create_proc_entry to proc_create(), get rid of the deprecated create_proc_read_entry() in favor of using proc_create_data() and seq_file etc). 7kloc removed. * 'for-linus' of git://git.kernel.org/pub/scm/linux/kernel/git/viro/vfs: (204 commits) don't bother with deferred freeing of fdtables proc: Move non-public stuff from linux/proc_fs.h to fs/proc/internal.h proc: Make the PROC_I() and PDE() macros internal to procfs proc: Supply a function to remove a proc entry by PDE take cgroup_open() and cpuset_open() to fs/proc/base.c ppc: Clean up scanlog ppc: Clean up rtas_flash driver somewhat hostap: proc: Use remove_proc_subtree() drm: proc: Use remove_proc_subtree() drm: proc: Use minor->index to label things, not PDE->name drm: Constify drm_proc_list[] zoran: Don't print proc_dir_entry data in debug reiserfs: Don't access the proc_dir_entry in r_open(), r_start() r_show() proc: Supply an accessor for getting the data from a PDE's parent airo: Use remove_proc_subtree() rtl8192u: Don't need to save device proc dir PDE rtl8187se: Use a dir under /proc/net/r8180/ proc: Add proc_mkdir_data() proc: Move some bits from linux/proc_fs.h to linux/{of.h,signal.h,tty.h} proc: Move PDE_NET() to fs/proc/proc_net.c ...
2013-04-29ocfs2/dlm: remove redundant null pointer checkSachin Kamat
kfree on a NULL pointer is a no-op. Remove the redundant null pointer check. Signed-off-by: Sachin Kamat <sachin.kamat@linaro.org> Acked-by: Mark Fasheh <mfasheh@suse.de> Cc: Joel Becker <jlbec@evilplan.org> Signed-off-by: Andrew Morton <akpm@linux-foundation.org> Signed-off-by: Linus Torvalds <torvalds@linux-foundation.org>
2013-04-29ocfs2: fix NULL dereference for moving extentsDan Carpenter
We can't dereference "bg" before it has been assigned. GCC should have warned about this but "bg" was initialized to NULL. I've fixed that as well. Signed-off-by: Dan Carpenter <dan.carpenter@oracle.com> Signed-off-by: Jie Liu <jeff.liu@oracle.com> Reviewed-by: Jie Liu <jeff.liu@oracle.com> Cc: Mark Fasheh <mfasheh@suse.com> Cc: Joel Becker <jlbec@evilplan.org> Signed-off-by: Andrew Morton <akpm@linux-foundation.org> Signed-off-by: Linus Torvalds <torvalds@linux-foundation.org>
2013-04-29ocfs2: fix error handling in ocfs2_ioctl_move_extents()Dan Carpenter
Smatch complains that if we hit an error (for example if the file is immutable) then "range" has uninitialized stack data and we copy it to the user. I've re-written the error handling to avoid this problem and make it a little cleaner as well. Signed-off-by: Dan Carpenter <dan.carpenter@oracle.com> Signed-off-by: Jie Liu <jeff.liu@oracle.com> Reviewed-by: Jie Liu <jeff.liu@oracle.com> Cc: Mark Fasheh <mfasheh@suse.com> Cc: Joel Becker <jlbec@evilplan.org> Signed-off-by: Andrew Morton <akpm@linux-foundation.org> Signed-off-by: Linus Torvalds <torvalds@linux-foundation.org>
2013-04-29ocfs2: fix error return code in ocfs2_info_handle_freefrag()Wei Yongjun
Fix to return a negative error code from the error handling case instead of 0, as returned elsewhere in this function. Signed-off-by: Wei Yongjun <yongjun_wei@trendmicro.com.cn> Cc: Joel Becker <jlbec@evilplan.org> Cc: Mark Fasheh <mfasheh@suse.com> Signed-off-by: Andrew Morton <akpm@linux-foundation.org> Signed-off-by: Linus Torvalds <torvalds@linux-foundation.org>
2013-04-29ocfs2: delay inode update transactions after verifying the input flagsJeff Liu
There is no need to start the inode update transactions before/while verifying the input flags. As a refinement, this patch delay the transactions utill the pre-check up is ok. Signed-off-by: Jie Liu <jeff.liu@oracle.com> Acked-by: Joel Becker <jlbec@evilplan.org> Cc: Mark Fasheh <mfasheh@suse.com> Cc: Al Viro <viro@zeniv.linux.org.uk> Signed-off-by: Andrew Morton <akpm@linux-foundation.org> Signed-off-by: Linus Torvalds <torvalds@linux-foundation.org>
2013-04-09pipe: don't use ->i_mutexAl Viro
now it can be done - put mutex into pipe_inode_info, use it instead of ->i_mutex Signed-off-by: Al Viro <viro@zeniv.linux.org.uk>
2013-04-09lift sb_start_write/sb_end_write out of ->aio_write()Al Viro
2013-03-07fs: Limit sys_mount to only request filesystem modules (Part 2).Eric W. Biederman
Add missing MODULE_ALIAS_FS("ocfs2") how did I miss that? Remove unnecessary MODULE_ALIAS_FS("devpts") devpts can not be modular. Signed-off-by: "Eric W. Biederman" <ebiederm@xmission.com>
2013-03-03fs: Limit sys_mount to only request filesystem modules.Eric W. Biederman
Modify the request_module to prefix the file system type with "fs-" and add aliases to all of the filesystems that can be built as modules to match. A common practice is to build all of the kernel code and leave code that is not commonly needed as modules, with the result that many users are exposed to any bug anywhere in the kernel. Looking for filesystems with a fs- prefix limits the pool of possible modules that can be loaded by mount to just filesystems trivially making things safer with no real cost. Using aliases means user space can control the policy of which filesystem modules are auto-loaded by editing /etc/modprobe.d/*.conf with blacklist and alias directives. Allowing simple, safe, well understood work-arounds to known problematic software. This also addresses a rare but unfortunate problem where the filesystem name is not the same as it's module name and module auto-loading would not work. While writing this patch I saw a handful of such cases. The most significant being autofs that lives in the module autofs4. This is relevant to user namespaces because we can reach the request module in get_fs_type() without having any special permissions, and people get uncomfortable when a user specified string (in this case the filesystem type) goes all of the way to request_module. After having looked at this issue I don't think there is any particular reason to perform any filtering or permission checks beyond making it clear in the module request that we want a filesystem module. The common pattern in the kernel is to call request_module() without regards to the users permissions. In general all a filesystem module does once loaded is call register_filesystem() and go to sleep. Which means there is not much attack surface exposed by loading a filesytem module unless the filesystem is mounted. In a user namespace filesystems are not mounted unless .fs_flags = FS_USERNS_MOUNT, which most filesystems do not set today. Acked-by: Serge Hallyn <serge.hallyn@canonical.com> Acked-by: Kees Cook <keescook@chromium.org> Reported-by: Kees Cook <keescook@google.com> Signed-off-by: "Eric W. Biederman" <ebiederm@xmission.com>
2013-02-27hlist: drop the node parameter from iteratorsSasha Levin
I'm not sure why, but the hlist for each entry iterators were conceived list_for_each_entry(pos, head, member) The hlist ones were greedy and wanted an extra parameter: hlist_for_each_entry(tpos, pos, head, member) Why did they need an extra pos parameter? I'm not quite sure. Not only they don't really need it, it also prevents the iterator from looking exactly like the list iterator, which is unfortunate. Besides the semantic patch, there was some manual work required: - Fix up the actual hlist iterators in linux/list.h - Fix up the declaration of other iterators based on the hlist ones. - A very small amount of places were using the 'node' parameter, this was modified to use 'obj->member' instead. - Coccinelle didn't handle the hlist_for_each_entry_safe iterator properly, so those had to be fixed up manually. The semantic patch which is mostly the work of Peter Senna Tschudin is here: @@ iterator name hlist_for_each_entry, hlist_for_each_entry_continue, hlist_for_each_entry_from, hlist_for_each_entry_rcu, hlist_for_each_entry_rcu_bh, hlist_for_each_entry_continue_rcu_bh, for_each_busy_worker, ax25_uid_for_each, ax25_for_each, inet_bind_bucket_for_each, sctp_for_each_hentry, sk_for_each, sk_for_each_rcu, sk_for_each_from, sk_for_each_safe, sk_for_each_bound, hlist_for_each_entry_safe, hlist_for_each_entry_continue_rcu, nr_neigh_for_each, nr_neigh_for_each_safe, nr_node_for_each, nr_node_for_each_safe, for_each_gfn_indirect_valid_sp, for_each_gfn_sp, for_each_host; type T; expression a,c,d,e; identifier b; statement S; @@ -T b; <+... when != b ( hlist_for_each_entry(a, - b, c, d) S | hlist_for_each_entry_continue(a, - b, c) S | hlist_for_each_entry_from(a, - b, c) S | hlist_for_each_entry_rcu(a, - b, c, d) S | hlist_for_each_entry_rcu_bh(a, - b, c, d) S | hlist_for_each_entry_continue_rcu_bh(a, - b, c) S | for_each_busy_worker(a, c, - b, d) S | ax25_uid_for_each(a, - b, c) S | ax25_for_each(a, - b, c) S | inet_bind_bucket_for_each(a, - b, c) S | sctp_for_each_hentry(a, - b, c) S | sk_for_each(a, - b, c) S | sk_for_each_rcu(a, - b, c) S | sk_for_each_from -(a, b) +(a) S + sk_for_each_from(a) S | sk_for_each_safe(a, - b, c, d) S | sk_for_each_bound(a, - b, c) S | hlist_for_each_entry_safe(a, - b, c, d, e) S | hlist_for_each_entry_continue_rcu(a, - b, c) S | nr_neigh_for_each(a, - b, c) S | nr_neigh_for_each_safe(a, - b, c, d) S | nr_node_for_each(a, - b, c) S | nr_node_for_each_safe(a, - b, c, d) S | - for_each_gfn_sp(a, c, d, b) S + for_each_gfn_sp(a, c, d) S | - for_each_gfn_indirect_valid_sp(a, c, d, b) S + for_each_gfn_indirect_valid_sp(a, c, d) S | for_each_host(a, - b, c) S | for_each_host_safe(a, - b, c, d) S | for_each_mesh_entry(a, - b, c, d) S ) ...+> [akpm@linux-foundation.org: drop bogus change from net/ipv4/raw.c] [akpm@linux-foundation.org: drop bogus hunk from net/ipv6/raw.c] [akpm@linux-foundation.org: checkpatch fixes] [akpm@linux-foundation.org: fix warnings] [akpm@linux-foudnation.org: redo intrusive kvm changes] Tested-by: Peter Senna Tschudin <peter.senna@gmail.com> Acked-by: Paul E. McKenney <paulmck@linux.vnet.ibm.com> Signed-off-by: Sasha Levin <sasha.levin@oracle.com> Cc: Wu Fengguang <fengguang.wu@intel.com> Cc: Marcelo Tosatti <mtosatti@redhat.com> Cc: Gleb Natapov <gleb@redhat.com> Signed-off-by: Andrew Morton <akpm@linux-foundation.org> Signed-off-by: Linus Torvalds <torvalds@linux-foundation.org>
2013-02-27ocfs2: convert to idr_alloc()Tejun Heo
Convert to the much saner new idr interface. Signed-off-by: Tejun Heo <tj@kernel.org> Cc: Mark Fasheh <mfasheh@suse.com> Acked-by: Joel Becker <jlbec@evilplan.org> Signed-off-by: Andrew Morton <akpm@linux-foundation.org> Signed-off-by: Linus Torvalds <torvalds@linux-foundation.org>
2013-02-27ocfs2: ac->ac_allow_chain_relink=0 won't disable group relinkXiaowei.Hu
ocfs2_block_group_alloc_discontig() disables chain relink by setting ac->ac_allow_chain_relink = 0 because it grabs clusters from multiple cluster groups. It doesn't keep the credits for all chain relink,but ocfs2_claim_suballoc_bits overrides this in this call trace: ocfs2_block_group_claim_bits()->ocfs2_claim_clusters()-> __ocfs2_claim_clusters()->ocfs2_claim_suballoc_bits() ocfs2_claim_suballoc_bits set ac->ac_allow_chain_relink = 1; then call ocfs2_search_chain() one time and disable it again, and then we run out of credits. Fix is to allow relink by default and disable it in ocfs2_block_group_alloc_discontig. Without this patch, End-users will run into a crash due to run out of credits, backtrace like this: RIP: 0010:[<ffffffffa0808b14>] [<ffffffffa0808b14>] jbd2_journal_dirty_metadata+0x164/0x170 [jbd2] RSP: 0018:ffff8801b919b5b8 EFLAGS: 00010246 RAX: 0000000000000000 RBX: ffff88022139ddc0 RCX: ffff880159f652d0 RDX: ffff880178aa3000 RSI: ffff880159f652d0 RDI: ffff880087f09bf8 RBP: ffff8801b919b5e8 R08: 0000000000000000 R09: 0000000000000000 R10: 0000000000001e00 R11: 00000000000150b0 R12: ffff880159f652d0 R13: ffff8801a0cae908 R14: ffff880087f09bf8 R15: ffff88018d177800 FS: 00007fc9b0b6b6e0(0000) GS:ffff88022fd40000(0000) knlGS:0000000000000000 CS: 0010 DS: 0000 ES: 0000 CR0: 000000008005003b CR2: 000000000040819c CR3: 0000000184017000 CR4: 00000000000006e0 DR0: 0000000000000000 DR1: 0000000000000000 DR2: 0000000000000000 DR3: 0000000000000000 DR6: 00000000ffff0ff0 DR7: 0000000000000400 Process dd (pid: 9945, threadinfo ffff8801b919a000, task ffff880149a264c0) Call Trace: ocfs2_journal_dirty+0x2f/0x70 [ocfs2] ocfs2_relink_block_group+0x111/0x480 [ocfs2] ocfs2_search_chain+0x455/0x9a0 [ocfs2] ... Signed-off-by: Xiaowei.Hu <xiaowei.hu@oracle.com> Reviewed-by: Srinivas Eeda <srinivas.eeda@oracle.com> Cc: Mark Fasheh <mfasheh@suse.com> Cc: Joel Becker <jlbec@evilplan.org> Cc: <stable@vger.kernel.org> Signed-off-by: Andrew Morton <akpm@linux-foundation.org> Signed-off-by: Linus Torvalds <torvalds@linux-foundation.org>
2013-02-27ocfs2: fix ocfs2_init_security_and_acl() to initialize acl correctlyJeff Liu
We need to re-initialize the security for a new reflinked inode with its parent dirs if it isn't specified to be preserved for ocfs2_reflink(). However, the code logic is broken at ocfs2_init_security_and_acl() although ocfs2_init_security_get() succeed. As a result, ocfs2_acl_init() does not involked and therefore the default ACL of parent dir was missing on the new inode. Note this was introduced by 9d8f13ba3 ("security: new security_inode_init_security API adds function callback") To reproduce: set default ACL for the parent dir(ocfs2 in this case): $ setfacl -m default:user:jeff:rwx ../ocfs2/ $ getfacl ../ocfs2/ # file: ../ocfs2/ # owner: jeff # group: jeff user::rwx group::r-x other::r-x default:user::rwx default:user:jeff:rwx default:group::r-x default:mask::rwx default:other::r-x $ touch a $ getfacl a # file: a # owner: jeff # group: jeff user::rw- group::rw- other::r-- Before patching, create reflink file b from a, the user default ACL entry(user:jeff:rwx)was missing: $ ./ocfs2_reflink a b $ getfacl b # file: b # owner: jeff # group: jeff user::rw- group::rw- other::r-- In this case, the end user can also observed an error message at syslog: (ocfs2_reflink,3229,2):ocfs2_init_security_and_acl:7193 ERROR: status = 0 After applying this patch, create reflink file c from a: $ ./ocfs2_reflink a c $ getfacl c # file: c # owner: jeff # group: jeff user::rw- user:jeff:rwx #effective:rw- group::r-x #effective:r-- mask::rw- other::r-- Test program: /* Usage: reflink <source> <dest> */ #include <stdio.h> #include <stdint.h> #include <stdbool.h> #include <string.h> #include <errno.h> #include <sys/types.h> #include <sys/stat.h> #include <fcntl.h> #include <sys/ioctl.h> static int reflink_file(char const *src_name, char const *dst_name, bool preserve_attrs) { int fd; #ifndef REFLINK_ATTR_NONE # define REFLINK_ATTR_NONE 0 #endif #ifndef REFLINK_ATTR_PRESERVE # define REFLINK_ATTR_PRESERVE 1 #endif #ifndef OCFS2_IOC_REFLINK struct reflink_arguments { uint64_t old_path; uint64_t new_path; uint64_t preserve; }; # define OCFS2_IOC_REFLINK _IOW ('o', 4, struct reflink_arguments) #endif struct reflink_arguments args = { .old_path = (unsigned long) src_name, .new_path = (unsigned long) dst_name, .preserve = preserve_attrs ? REFLINK_ATTR_PRESERVE : REFLINK_ATTR_NONE, }; fd = open(src_name, O_RDONLY); if (fd < 0) { fprintf(stderr, "Failed to open %s: %s\n", src_name, strerror(errno)); return -1; } if (ioctl(fd, OCFS2_IOC_REFLINK, &args) < 0) { fprintf(stderr, "Failed to reflink %s to %s: %s\n", src_name, dst_name, strerror(errno)); return -1; } } int main(int argc, char *argv[]) { if (argc != 3) { fprintf(stdout, "Usage: %s source dest\n", argv[0]); return 1; } return reflink_file(argv[1], argv[2], 0); } Signed-off-by: Jie Liu <jeff.liu@oracle.com> Reviewed-by: Tao Ma <boyu.mt@taobao.com> Cc: Mimi Zohar <zohar@linux.vnet.ibm.com> Cc: Joel Becker <jlbec@evilplan.org> Cc: Mark Fasheh <mfasheh@suse.com> Cc: <stable@vger.kernel.org> Signed-off-by: Andrew Morton <akpm@linux-foundation.org> Signed-off-by: Linus Torvalds <torvalds@linux-foundation.org>
2013-02-26Merge branch 'for-linus' of ↵Linus Torvalds
git://git.kernel.org/pub/scm/linux/kernel/git/viro/vfs Pull vfs pile (part one) from Al Viro: "Assorted stuff - cleaning namei.c up a bit, fixing ->d_name/->d_parent locking violations, etc. The most visible changes here are death of FS_REVAL_DOT (replaced with "has ->d_weak_revalidate()") and a new helper getting from struct file to inode. Some bits of preparation to xattr method interface changes. Misc patches by various people sent this cycle *and* ocfs2 fixes from several cycles ago that should've been upstream right then. PS: the next vfs pile will be xattr stuff." * 'for-linus' of git://git.kernel.org/pub/scm/linux/kernel/git/viro/vfs: (46 commits) saner proc_get_inode() calling conventions proc: avoid extra pde_put() in proc_fill_super() fs: change return values from -EACCES to -EPERM fs/exec.c: make bprm_mm_init() static ocfs2/dlm: use GFP_ATOMIC inside a spin_lock ocfs2: fix possible use-after-free with AIO ocfs2: Fix oops in ocfs2_fast_symlink_readpage() code path get_empty_filp()/alloc_file() leave both ->f_pos and ->f_version zero target: writev() on single-element vector is pointless export kernel_write(), convert open-coded instances fs: encode_fh: return FILEID_INVALID if invalid fid_type kill f_vfsmnt vfs: kill FS_REVAL_DOT by adding a d_weak_revalidate dentry op nfsd: handle vfs_getattr errors in acl protocol switch vfs_getattr() to struct path default SET_PERSONALITY() in linux/elf.h ceph: prepopulate inodes only when request is aborted d_hash_and_lookup(): export, switch open-coded instances 9p: switch v9fs_set_create_acl() to inode+fid, do it before d_instantiate() 9p: split dropping the acls from v9fs_set_create_acl() ...
2013-02-26Merge branch 'for_linus' of ↵Linus Torvalds
git://git.kernel.org/pub/scm/linux/kernel/git/jack/linux-fs Pull ext2, ext3, udf updates from Jan Kara: "Several UDF fixes, a support for UDF extent cache, and couple of ext2 and ext3 cleanups and minor fixes" * 'for_linus' of git://git.kernel.org/pub/scm/linux/kernel/git/jack/linux-fs: Ext2: remove the static function release_blocks to optimize the kernel Ext2: mark inode dirty after the function dquot_free_block_nodirty is called Ext2: remove the overhead check about sb in the function ext2_new_blocks udf: Remove unused s_extLength from udf_bitmap udf: Make s_block_bitmap standard array udf: Fix bitmap overflow on large filesystems with small block size udf: add extent cache support in case of file reading udf: Write LVID to disk after opening / closing Ext3: return ENOMEM rather than EIO if sb_getblk fails Ext2: return ENOMEM rather than EIO if sb_getblk fails Ext3: use unlikely to improve the efficiency of the kernel Ext2: use unlikely to improve the efficiency of the kernel Ext3: add necessary check in case IO error happens Ext2: free memory allocated and forget buffer head when io error happens ext3: Fix memory leak when quota options are specified multiple times ext3, ext4, ocfs2: remove unused macro NAMEI_RA_INDEX
2013-02-26ocfs2/dlm: use GFP_ATOMIC inside a spin_lockDan Carpenter
My static checker complains that this is called with a spin_lock held in dlm_master_requery_handler() from dlmrecovery.c. Probably the reason we have not received any bug reports about this is that recovery is not a common operation. Signed-off-by: Dan Carpenter <dan.carpenter@oracle.com> Signed-off-by: Joel Becker <jlbec@evilplan.org> Signed-off-by: Al Viro <viro@zeniv.linux.org.uk>
2013-02-26ocfs2: fix possible use-after-free with AIOJan Kara
Running AIO is pinning inode in memory using file reference. Once AIO is completed using aio_complete(), file reference is put and inode can be freed from memory. So we have to be sure that calling aio_complete() is the last thing we do with the inode. Signed-off-by: Jan Kara <jack@suse.cz> Acked-by: Jeff Moyer <jmoyer@redhat.com> Acked-by: Joel Becker <jlbec@evilplan.org> Cc: Mark Fasheh <mfasheh@suse.com> Cc: Al Viro <viro@zeniv.linux.org.uk> Cc: <stable@vger.kernel.org> Signed-off-by: Andrew Morton <akpm@linux-foundation.org> Signed-off-by: Al Viro <viro@zeniv.linux.org.uk>
2013-02-26ocfs2: Fix oops in ocfs2_fast_symlink_readpage() code pathSunil Mushran
Commit ea022dfb3c2a4680483b00eb2fecc9fc4f6091d1 was missing a var init. Reported-and-Tested-by: Vincent Etienne <vetienne@aprogsys.com> Signed-off-by: Sunil Mushran <sunil.mushran@gmail.com> Signed-off-by: Joel Becker <jlbec@evilplan.org> Signed-off-by: Al Viro <viro@zeniv.linux.org.uk>
2013-02-26fs: encode_fh: return FILEID_INVALID if invalid fid_typeNamjae Jeon
This patch is a follow up on below patch: [PATCH] exportfs: add FILEID_INVALID to indicate invalid fid_type commit: 216b6cbdcbd86b1db0754d58886b466ae31f5a63 Signed-off-by: Namjae Jeon <namjae.jeon@samsung.com> Signed-off-by: Vivek Trivedi <t.vivek@samsung.com> Acked-by: Steven Whitehouse <swhiteho@redhat.com> Acked-by: Sage Weil <sage@inktank.com> Signed-off-by: Al Viro <viro@zeniv.linux.org.uk>
2013-02-26kill f_vfsmntAl Viro
very few users left... Signed-off-by: Al Viro <viro@zeniv.linux.org.uk>
2013-02-25Merge branch 'for-linus' of ↵Linus Torvalds
git://git.kernel.org/pub/scm/linux/kernel/git/ebiederm/user-namespace Pull user namespace and namespace infrastructure changes from Eric W Biederman: "This set of changes starts with a few small enhnacements to the user namespace. reboot support, allowing more arbitrary mappings, and support for mounting devpts, ramfs, tmpfs, and mqueuefs as just the user namespace root. I do my best to document that if you care about limiting your unprivileged users that when you have the user namespace support enabled you will need to enable memory control groups. There is a minor bug fix to prevent overflowing the stack if someone creates way too many user namespaces. The bulk of the changes are a continuation of the kuid/kgid push down work through the filesystems. These changes make using uids and gids typesafe which ensures that these filesystems are safe to use when multiple user namespaces are in use. The filesystems converted for 3.9 are ceph, 9p, afs, ocfs2, gfs2, ncpfs, nfs, nfsd, and cifs. The changes for these filesystems were a little more involved so I split the changes into smaller hopefully obviously correct changes. XFS is the only filesystem that remains. I was hoping I could get that in this release so that user namespace support would be enabled with an allyesconfig or an allmodconfig but it looks like the xfs changes need another couple of days before it they are ready." * 'for-linus' of git://git.kernel.org/pub/scm/linux/kernel/git/ebiederm/user-namespace: (93 commits) cifs: Enable building with user namespaces enabled. cifs: Convert struct cifs_ses to use a kuid_t and a kgid_t cifs: Convert struct cifs_sb_info to use kuids and kgids cifs: Modify struct smb_vol to use kuids and kgids cifs: Convert struct cifsFileInfo to use a kuid cifs: Convert struct cifs_fattr to use kuid and kgids cifs: Convert struct tcon_link to use a kuid. cifs: Modify struct cifs_unix_set_info_args to hold a kuid_t and a kgid_t cifs: Convert from a kuid before printing current_fsuid cifs: Use kuids and kgids SID to uid/gid mapping cifs: Pass GLOBAL_ROOT_UID and GLOBAL_ROOT_GID to keyring_alloc cifs: Use BUILD_BUG_ON to validate uids and gids are the same size cifs: Override unmappable incoming uids and gids nfsd: Enable building with user namespaces enabled. nfsd: Properly compare and initialize kuids and kgids nfsd: Store ex_anon_uid and ex_anon_gid as kuids and kgids nfsd: Modify nfsd4_cb_sec to use kuids and kgids nfsd: Handle kuids and kgids in the nfs4acl to posix_acl conversion nfsd: Convert nfsxdr to use kuids and kgids nfsd: Convert nfs3xdr to use kuids and kgids ...
2013-02-22new helper: file_inode(file)Al Viro
2013-02-21Merge branch 'for-linus' of ↵Linus Torvalds
git://git.kernel.org/pub/scm/linux/kernel/git/jikos/trivial Pull trivial tree from Jiri Kosina: "Assorted tiny fixes queued in trivial tree" * 'for-linus' of git://git.kernel.org/pub/scm/linux/kernel/git/jikos/trivial: (22 commits) DocBook: update EXPORT_SYMBOL entry to point at export.h Documentation: update top level 00-INDEX file with new additions ARM: at91/ide: remove unsused at91-ide Kconfig entry percpu_counter.h: comment code for better readability x86, efi: fix comment typo in head_32.S IB: cxgb3: delay freeing mem untill entirely done with it net: mvneta: remove unneeded version.h include time: x86: report_lost_ticks doesn't exist any more pcmcia: avoid static analysis complaint about use-after-free fs/jfs: Fix typo in comment : 'how may' -> 'how many' of: add missing documentation for of_platform_populate() btrfs: remove unnecessary cur_trans set before goto loop in join_transaction sound: soc: Fix typo in sound/codecs treewide: Fix typo in various drivers btrfs: fix comment typos Update ibmvscsi module name in Kconfig. powerpc: fix typo (utilties -> utilities) of: fix spelling mistake in comment h8300: Fix home page URL in h8300/README xtensa: Fix home page URL in Kconfig ...
2013-02-21ocfs2: wait for page writeback to provide stable pagesJan Kara
When stable pages are required, we have to wait if the page is just going to disk and we want to modify it. Add proper callback to ocfs2_grab_pages_for_write(). Signed-off-by: Jan Kara <jack@suse.cz> Signed-off-by: Darrick J. Wong <darrick.wong@oracle.com> Acked-by: Joel Becker <jlbec@evilplan.org> Cc: Mark Fasheh <mfasheh@suse.com> Cc: Adrian Hunter <adrian.hunter@intel.com> Cc: Andy Lutomirski <luto@amacapital.net> Cc: Artem Bityutskiy <dedekind1@gmail.com> Cc: Steven Whitehouse <swhiteho@redhat.com> Cc: Jens Axboe <axboe@kernel.dk> Cc: Eric Van Hensbergen <ericvh@gmail.com> Cc: Ron Minnich <rminnich@sandia.gov> Cc: Latchesar Ionkov <lucho@ionkov.net> Signed-off-by: Andrew Morton <akpm@linux-foundation.org> Signed-off-by: Linus Torvalds <torvalds@linux-foundation.org>
2013-02-21ocfs2: unlock super lock if lockres refresh failedJunxiao Bi
If lockres refresh failed, the super lock will never be released which will cause some processes on other cluster nodes hung forever. Signed-off-by: Junxiao Bi <junxiao.bi@oracle.com> Cc: Joel Becker <jlbec@evilplan.org> Cc: Mark Fasheh <mfasheh@suse.com> Cc: <stable@vger.kernel.org> Signed-off-by: Andrew Morton <akpm@linux-foundation.org> Signed-off-by: Linus Torvalds <torvalds@linux-foundation.org>
2013-02-21ocfs2: remove kfree() redundant null checksTim Gardner
smatch analysis indicates a number of redundant NULL checks before calling kfree(), eg: fs/ocfs2/alloc.c:6138 ocfs2_begin_truncate_log_recovery() info: redundant null check on *tl_copy calling kfree() fs/ocfs2/alloc.c:6755 ocfs2_zero_range_for_truncate() info: redundant null check on pages calling kfree() etc.... [akpm@linux-foundation.org: revert dubious change in ocfs2_begin_truncate_log_recovery()] Signed-off-by: Tim Gardner <tim.gardner@canonical.com> Cc: Mark Fasheh <mfasheh@suse.com> Acked-by: Joel Becker <jlbec@evilplan.org> Signed-off-by: Andrew Morton <akpm@linux-foundation.org> Signed-off-by: Linus Torvalds <torvalds@linux-foundation.org>
2013-02-13ocfs2: Compare kuids and kgids using uid_eq and gid_eqEric W. Biederman
Cc: Mark Fasheh <mfasheh@suse.com> Cc: Joel Becker <jlbec@evilplan.org> Signed-off-by: "Eric W. Biederman" <ebiederm@xmission.com>
2013-02-13ocfs2: For tracing report the uid and gid values in the initial user namespaceEric W. Biederman
2013-02-13ocfs2: Convert uid and gids between in core and on disk inodesEric W. Biederman
2013-02-13ocfs2: convert between kuids and kgids and DLM locksEric W. Biederman
Convert between uid and gids stored in the on the wire format of dlm locks aka struct ocfs2_meta_lvb and kuids and kgids stored in inode->i_uid and inode->i_gid. Cc: Mark Fasheh <mfasheh@suse.com> Cc: Joel Becker <jlbec@evilplan.org> Signed-off-by: "Eric W. Biederman" <ebiederm@xmission.com>
2013-02-13ocfs2: Handle kuids and kgids in acl/xattr conversions.Eric W. Biederman
Explicitly deal with the different kinds of acls because they need different conversions. Cc: Mark Fasheh <mfasheh@suse.com> Cc: Joel Becker <jlbec@evilplan.org> Signed-off-by: "Eric W. Biederman" <ebiederm@xmission.com>
2013-01-29Merge branch 'master' into for-nextJiri Kosina
Conflicts: drivers/devfreq/exynos4_bus.c Sync with Linus' tree to be able to apply patches that are against newer code (mvneta).
2013-01-21ext3, ext4, ocfs2: remove unused macro NAMEI_RA_INDEXGuo Chao
This macro, initially introduced by ext2 in v0.99.15, does not have any users from the beginning. It has been removed in later ext2 version but still remains in the code of ext3, ext4, ocfs2. Remove this macro there. Cc: Jan Kara <jack@suse.cz> Cc: linux-ext4@vger.kernel.org Cc: ocfs2-devel@oss.oracle.com Acked-by: Mark Fasheh <mfasheh@suse.de> Acked-by: "Theodore Ts'o" <tytso@mit.edu> Signed-off-by: Guo Chao <yan@linux.vnet.ibm.com> Signed-off-by: Jan Kara <jack@suse.cz>
2013-01-09treewide: Fix typo in various driversMasanari Iida
Correct spelling typo in printk within various drivers. Signed-off-by: Masanari Iida <standby24x7@gmail.com> Signed-off-by: Jiri Kosina <jkosina@suse.cz>
2012-12-20ocfs2: drop vmtruncateMarco Stornelli
Removed vmtruncate Signed-off-by: Marco Stornelli <marco.stornelli@gmail.com> Signed-off-by: Al Viro <viro@zeniv.linux.org.uk>
2012-12-17lseek: the "whence" argument is called "whence"Andrew Morton
But the kernel decided to call it "origin" instead. Fix most of the sites. Acked-by: Hugh Dickins <hughd@google.com> Signed-off-by: Andrew Morton <akpm@linux-foundation.org> Signed-off-by: Linus Torvalds <torvalds@linux-foundation.org>
2012-12-11writeback: remove nr_pages_dirtied arg from balance_dirty_pages_ratelimited_nr()Namjae Jeon
There is no reason to pass the nr_pages_dirtied argument, because nr_pages_dirtied value from the caller is unused in balance_dirty_pages_ratelimited_nr(). Signed-off-by: Namjae Jeon <linkinjeon@gmail.com> Signed-off-by: Vivek Trivedi <vtrivedi018@gmail.com> Cc: Wu Fengguang <fengguang.wu@intel.com> Signed-off-by: Andrew Morton <akpm@linux-foundation.org> Signed-off-by: Linus Torvalds <torvalds@linux-foundation.org>
2012-10-09mm: kill vma flag VM_CAN_NONLINEARKonstantin Khlebnikov
Move actual pte filling for non-linear file mappings into the new special vma operation: ->remap_pages(). Filesystems must implement this method to get non-linear mapping support, if it uses filemap_fault() then generic_file_remap_pages() can be used. Now device drivers can implement this method and obtain nonlinear vma support. Signed-off-by: Konstantin Khlebnikov <khlebnikov@openvz.org> Cc: Alexander Viro <viro@zeniv.linux.org.uk> Cc: Carsten Otte <cotte@de.ibm.com> Cc: Chris Metcalf <cmetcalf@tilera.com> #arch/tile Cc: Cyrill Gorcunov <gorcunov@openvz.org> Cc: Eric Paris <eparis@redhat.com> Cc: H. Peter Anvin <hpa@zytor.com> Cc: Hugh Dickins <hughd@google.com> Cc: Ingo Molnar <mingo@redhat.com> Cc: James Morris <james.l.morris@oracle.com> Cc: Jason Baron <jbaron@redhat.com> Cc: Kentaro Takeda <takedakn@nttdata.co.jp> Cc: Matt Helsley <matthltc@us.ibm.com> Cc: Nick Piggin <npiggin@kernel.dk> Cc: Oleg Nesterov <oleg@redhat.com> Cc: Peter Zijlstra <a.p.zijlstra@chello.nl> Cc: Robert Richter <robert.richter@amd.com> Cc: Suresh Siddha <suresh.b.siddha@intel.com> Cc: Tetsuo Handa <penguin-kernel@I-love.SAKURA.ne.jp> Cc: Venkatesh Pallipadi <venki@google.com> Acked-by: Linus Torvalds <torvalds@linux-foundation.org> Signed-off-by: Andrew Morton <akpm@linux-foundation.org> Signed-off-by: Linus Torvalds <torvalds@linux-foundation.org>
2012-10-02Merge branch 'for-linus' of ↵Linus Torvalds
git://git.kernel.org/pub/scm/linux/kernel/git/viro/vfs Pull vfs update from Al Viro: - big one - consolidation of descriptor-related logics; almost all of that is moved to fs/file.c (BTW, I'm seriously tempted to rename the result to fd.c. As it is, we have a situation when file_table.c is about handling of struct file and file.c is about handling of descriptor tables; the reasons are historical - file_table.c used to be about a static array of struct file we used to have way back). A lot of stray ends got cleaned up and converted to saner primitives, disgusting mess in android/binder.c is still disgusting, but at least doesn't poke so much in descriptor table guts anymore. A bunch of relatively minor races got fixed in process, plus an ext4 struct file leak. - related thing - fget_light() partially unuglified; see fdget() in there (and yes, it generates the code as good as we used to have). - also related - bits of Cyrill's procfs stuff that got entangled into that work; _not_ all of it, just the initial move to fs/proc/fd.c and switch of fdinfo to seq_file. - Alex's fs/coredump.c spiltoff - the same story, had been easier to take that commit than mess with conflicts. The rest is a separate pile, this was just a mechanical code movement. - a few misc patches all over the place. Not all for this cycle, there'll be more (and quite a few currently sit in akpm's tree)." Fix up trivial conflicts in the android binder driver, and some fairly simple conflicts due to two different changes to the sock_alloc_file() interface ("take descriptor handling from sock_alloc_file() to callers" vs "net: Providing protocol type via system.sockprotoname xattr of /proc/PID/fd entries" adding a dentry name to the socket) * 'for-linus' of git://git.kernel.org/pub/scm/linux/kernel/git/viro/vfs: (72 commits) MAX_LFS_FILESIZE should be a loff_t compat: fs: Generic compat_sys_sendfile implementation fs: push rcu_barrier() from deactivate_locked_super() to filesystems btrfs: reada_extent doesn't need kref for refcount coredump: move core dump functionality into its own file coredump: prevent double-free on an error path in core dumper usb/gadget: fix misannotations fcntl: fix misannotations ceph: don't abuse d_delete() on failure exits hypfs: ->d_parent is never NULL or negative vfs: delete surplus inode NULL check switch simple cases of fget_light to fdget new helpers: fdget()/fdput() switch o2hb_region_dev_write() to fget_light() proc_map_files_readdir(): don't bother with grabbing files make get_file() return its argument vhost_set_vring(): turn pollstart/pollstop into bool switch prctl_set_mm_exe_file() to fget_light() switch xfs_find_handle() to fget_light() switch xfs_swapext() to fget_light() ...
2012-10-02fs: push rcu_barrier() from deactivate_locked_super() to filesystemsKirill A. Shutemov
There's no reason to call rcu_barrier() on every deactivate_locked_super(). We only need to make sure that all delayed rcu free inodes are flushed before we destroy related cache. Removing rcu_barrier() from deactivate_locked_super() affects some fast paths. E.g. on my machine exit_group() of a last process in IPC namespace takes 0.07538s. rcu_barrier() takes 0.05188s of that time. Signed-off-by: Kirill A. Shutemov <kirill.shutemov@linux.intel.com> Cc: Al Viro <viro@zeniv.linux.org.uk> Signed-off-by: Andrew Morton <akpm@linux-foundation.org> Signed-off-by: Al Viro <viro@zeniv.linux.org.uk>
