commit 1b56e98990bcdbb20b9fab163654b9315bf158e8 upstream.
commit 15c34a760630ca2c803848fba90ca0646a9907dd upstream.
Global quota files are accessed from different nodes. Thus we cannot
cache offset of quota structure in the quota file after we drop our node
reference count to it because after that moment quota structure may be
freed and reallocated elsewhere by a different node resulting in
corruption of quota file.
Fix the problem by clearing dq_off when we are releasing dquot structure.
We also remove the DB_READ_B handling because it is useless -
DQ_ACTIVE_B is set iff DQ_READ_B is set.
Cc: Goldwyn Rodrigues <rgoldwyn@suse.de>
Reviewed-by: Mark Fasheh <mfasheh@suse.de>
commit 28e8be31803b19d0d8f76216cb11b480b8a98bec upstream.
Call fiemap ioctl(2) with given start offset as well as an desired mapping
range should show extents if possible. However, we somehow figure out the
end offset of mapping via 'mapping_end -= cpos' before iterating the
extent records which would cause problems if the given fiemap length is
too small to a cluster size, e.g,
Cluster size 4096:
debugfs.ocfs2 1.6.3
Block Size Bits: 12 Cluster Size Bits: 12
The extended fiemap test utility From David:
https://gist.github.com/anonymous/6172331
# dd if=/dev/urandom of=/ocfs2/test_file bs=1M count=1000
# ./fiemap /ocfs2/test_file 4096 10
start: 4096, length: 10
File /ocfs2/test_file has 0 extents:
# Logical Physical Length Flags
^^^^^ <-- No extent is shown
In this case, at ocfs2_fiemap(): cpos == mapping_end == 1. Hence the
loop of searching extent records was not executed at all.
This patch remove the in question 'mapping_end -= cpos', and loops
until the cpos is larger than the mapping_end as usual.
File /ocfs2/test_file has 1 extents:
0: 0000000000000000 0000000056a01000 0000000006a00000 0000
Signed-off-by: Jie Liu <jeff.liu@oracle.com>
Reported-by: David Weber <wb@munzinger.de>
Tested-by: David Weber <wb@munzinger.de>
Cc: Sunil Mushran <sunil.mushran@gmail.com>
Cc: Mark Fashen <mfasheh@suse.de>
commit ef962df057aaafd714f5c22ba3de1be459571fdf upstream.
Inlined xattr shared free space of inode block with inlined data or data
extent record, so the size of the later two should be adjusted when
inlined xattr is enabled. See ocfs2_xattr_ibody_init(). But this isn't
done well when reflink. For inode with inlined data, its max inlined
data size is adjusted in ocfs2_duplicate_inline_data(), no problem. But
for inode with data extent record, its record count isn't adjusted. Fix
it, or data extent record and inlined xattr may overwrite each other,
then cause data corruption or xattr failure.
One panic caused by this bug in our test environment is the following:
kernel BUG at fs/ocfs2/xattr.c:1435!
invalid opcode: 0000 [#1] SMP
Pid: 10871, comm: multi_reflink_t Not tainted 2.6.39-300.17.1.el5uek #1
RIP: ocfs2_xa_offset_pointer+0x17/0x20 [ocfs2]
RSP: e02b:ffff88007a587948 EFLAGS: 00010283
RAX: 0000000000000000 RBX: 0000000000000010 RCX: 00000000000051e4
RDX: ffff880057092060 RSI: 0000000000000f80 RDI: ffff88007a587a68
RBP: ffff88007a587948 R08: 00000000000062f4 R09: 0000000000000000
R10: 0000000000000000 R11: 0000000000000000 R12: 0000000000000010
R13: ffff88007a587a68 R14: 0000000000000001 R15: ffff88007a587c68
FS: 00007fccff7f06e0(0000) GS:ffff88007fc00000(0000) knlGS:0000000000000000
CS: e033 DS: 0000 ES: 0000 CR0: 000000008005003b
CR2: 00000000015cf000 CR3: 000000007aa76000 CR4: 0000000000000660
Process multi_reflink_t
Call Trace:
ocfs2_xa_reuse_entry+0x60/0x280 [ocfs2]
ocfs2_xa_prepare_entry+0x17e/0x2a0 [ocfs2]
ocfs2_xa_set+0xcc/0x250 [ocfs2]
ocfs2_xattr_ibody_set+0x98/0x230 [ocfs2]
__ocfs2_xattr_set_handle+0x4f/0x700 [ocfs2]
ocfs2_xattr_set+0x6c6/0x890 [ocfs2]
ocfs2_xattr_user_set+0x46/0x50 [ocfs2]
generic_setxattr+0x70/0x90
__vfs_setxattr_noperm+0x80/0x1a0
vfs_setxattr+0xa9/0xb0
setxattr+0xc3/0x120
sys_fsetxattr+0xa8/0xd0
system_call_fastpath+0x16/0x1b
Signed-off-by: Junxiao Bi <junxiao.bi@oracle.com>
Reviewed-by: Jie Liu <jeff.liu@oracle.com>
Acked-by: Joel Becker <jlbec@evilplan.org>
Cc: Mark Fasheh <mfasheh@suse.com>
commit b4ca2b4b577c3530e34dcfaafccb2cc680ce95d1 upstream.
Last time we found there is lock/unlock bug in ocfs2_file_aio_write, and
then we did a thorough search for all lock resources in
ocfs2_inode_info, including rw, inode and open lockres and found this
bug. My kernel version is 3.0.13, and it is also in the lastest version
3.9. In ocfs2_fiemap, once ocfs2_get_clusters_nocache failed, it should
goto out_unlock instead of out, because we need release buffer head, up
read alloc sem and unlock inode.
Signed-off-by: Joseph Qi <joseph.qi@huawei.com>
Acked-by: Sunil Mushran <sunil.mushran@gmail.com>
commit 309a85b6861fedbb48a22d45e0e079d1be993b3a upstream.
ocfs2_block_group_alloc_discontig() disables chain relink by setting
ac->ac_allow_chain_relink = 0 because it grabs clusters from multiple
cluster groups.
It doesn't keep the credits for all chain relink,but
ocfs2_claim_suballoc_bits overrides this in this call trace:
ocfs2_block_group_claim_bits()->ocfs2_claim_clusters()->
__ocfs2_claim_clusters()->ocfs2_claim_suballoc_bits()
ocfs2_claim_suballoc_bits set ac->ac_allow_chain_relink = 1; then call
ocfs2_search_chain() one time and disable it again, and then we run out
of credits.
Fix is to allow relink by default and disable it in
ocfs2_block_group_alloc_discontig.
Without this patch, End-users will run into a crash due to run out of
credits, backtrace like this:
RIP: 0010:[<ffffffffa0808b14>] [<ffffffffa0808b14>]
jbd2_journal_dirty_metadata+0x164/0x170 [jbd2]
RSP: 0018:ffff8801b919b5b8 EFLAGS: 00010246
RAX: 0000000000000000 RBX: ffff88022139ddc0 RCX: ffff880159f652d0
RDX: ffff880178aa3000 RSI: ffff880159f652d0 RDI: ffff880087f09bf8
RBP: ffff8801b919b5e8 R08: 0000000000000000 R09: 0000000000000000
R10: 0000000000001e00 R11: 00000000000150b0 R12: ffff880159f652d0
R13: ffff8801a0cae908 R14: ffff880087f09bf8 R15: ffff88018d177800
FS: 00007fc9b0b6b6e0(0000) GS:ffff88022fd40000(0000) knlGS:0000000000000000
CS: 0010 DS: 0000 ES: 0000 CR0: 000000008005003b
CR2: 000000000040819c CR3: 0000000184017000 CR4: 00000000000006e0
Process dd (pid: 9945, threadinfo ffff8801b919a000, task ffff880149a264c0)
Call Trace:
ocfs2_journal_dirty+0x2f/0x70 [ocfs2]
ocfs2_relink_block_group+0x111/0x480 [ocfs2]
ocfs2_search_chain+0x455/0x9a0 [ocfs2]
Signed-off-by: Xiaowei.Hu <xiaowei.hu@oracle.com>
Reviewed-by: Srinivas Eeda <srinivas.eeda@oracle.com>
commit 32918dd9f19e5960af4cdfa41190bb843fb2247b upstream.
We need to re-initialize the security for a new reflinked inode with its
parent dirs if it isn't specified to be preserved for ocfs2_reflink().
However, the code logic is broken at ocfs2_init_security_and_acl()
although ocfs2_init_security_get() succeed. As a result,
ocfs2_acl_init() does not involked and therefore the default ACL of
parent dir was missing on the new inode.
Note this was introduced by 9d8f13ba3 ("security: new
security_inode_init_security API adds function callback")
To reproduce:
set default ACL for the parent dir(ocfs2 in this case):
$ setfacl -m default:user:jeff:rwx ../ocfs2/
$ getfacl ../ocfs2/
# file: ../ocfs2/
# owner: jeff
# group: jeff
user::rwx
group::r-x
other::r-x
default:user::rwx
default:group::r-x
default:mask::rwx
default:other::r-x
$ touch a
$ getfacl a
# file: a
# owner: jeff
# group: jeff
user::rw-
group::rw-
other::r--
Before patching, create reflink file b from a, the user
default ACL entry(user:jeff:rwx)was missing:
$ ./ocfs2_reflink a b
$ getfacl b
# file: b
# owner: jeff
# group: jeff
user::rw-
group::rw-
other::r--
In this case, the end user can also observed an error message at syslog:
(ocfs2_reflink,3229,2):ocfs2_init_security_and_acl:7193 ERROR: status = 0
After applying this patch, create reflink file c from a:
$ ./ocfs2_reflink a c
$ getfacl c
# file: c
# owner: jeff
# group: jeff
user::rw-
user:jeff:rwx #effective:rw-
group::r-x #effective:r--
mask::rw-
other::r--
Test program:
/* Usage: reflink <source> <dest> */
#include <stdio.h>
#include <stdint.h>
#include <stdbool.h>
#include <string.h>
#include <errno.h>
#include <sys/types.h>
#include <sys/stat.h>
#include <fcntl.h>
#include <sys/ioctl.h>
static int
reflink_file(char const *src_name, char const *dst_name,
bool preserve_attrs)
int fd;
#ifndef REFLINK_ATTR_NONE
# define REFLINK_ATTR_NONE 0
#endif
#ifndef REFLINK_ATTR_PRESERVE
# define REFLINK_ATTR_PRESERVE 1
#endif
#ifndef OCFS2_IOC_REFLINK
struct reflink_arguments {
uint64_t old_path;
uint64_t new_path;
uint64_t preserve;
# define OCFS2_IOC_REFLINK _IOW ('o', 4, struct reflink_arguments)
#endif
struct reflink_arguments args = {
.old_path = (unsigned long) src_name,
.new_path = (unsigned long) dst_name,
.preserve = preserve_attrs ? REFLINK_ATTR_PRESERVE :
REFLINK_ATTR_NONE,
fd = open(src_name, O_RDONLY);
if (fd < 0) {
fprintf(stderr, "Failed to open %s: %s\n",
src_name, strerror(errno));
return -1;
if (ioctl(fd, OCFS2_IOC_REFLINK, &args) < 0) {
fprintf(stderr, "Failed to reflink %s to %s: %s\n",
src_name, dst_name, strerror(errno));
return -1;
int
main(int argc, char *argv[])
if (argc != 3) {
fprintf(stdout, "Usage: %s source dest\n", argv[0]);
return 1;
return reflink_file(argv[1], argv[2], 0);
Reviewed-by: Tao Ma <boyu.mt@taobao.com>
Cc: Mimi Zohar <zohar@linux.vnet.ibm.com>
commit 9b171e0c74ca0549d0610990a862dd895870f04a upstream.
Running AIO is pinning inode in memory using file reference. Once AIO
is completed using aio_complete(), file reference is put and inode can
be freed from memory. So we have to be sure that calling aio_complete()
is the last thing we do with the inode.
Acked-by: Jeff Moyer <jmoyer@redhat.com>
commit 3278bb748d2437eb1464765f36429e5d6aa91c38 upstream.
If lockres refresh failed, the super lock will never be released which
will cause some processes on other cluster nodes hung forever.
commit a4e08d001f2e50bb8b3c4eebadcf08e5535f02ee upstream.
As ocfs2_fallocate() will invoke __ocfs2_change_file_space() with a NULL
as the first parameter (file), it may trigger a NULL pointer dereferrence
due to a missing check.
Addresses http://bugs.launchpad.net/bugs/1006012
Signed-off-by: Luis Henriques <luis.henriques@canonical.com>
Reported-by: Bret Towe <magnade@gmail.com>
Tested-by: Bret Towe <magnade@gmail.com>
Cc: Sunil Mushran <sunil.mushran@oracle.com>
Acked-by: Mark Fasheh <mfasheh@suse.com>
commit 3e5d3c35a68c9a933bdbdd8685bd1a205b57e806 upstream.
The unaligned io flag is set in the kiocb when an unaligned
dio is issued, it should be cleared even when the dio fails,
or it may affect the following io which are using the same
kiocb.
Signed-off-by: Joel Becker <jlbec@evilplan.org>
le16, not le32...
le16, not le32...
it's le16, not le32 or le64...
It's le16, not le32...
Pull vfs pile 1 from Al Viro:
"This is _not_ all; in particular, Miklos' and Jan's stuff is not there
yet."
* 'for-linus' of git://git.kernel.org/pub/scm/linux/kernel/git/viro/vfs: (64 commits)
ext4: initialization of ext4_li_mtx needs to be done earlier
debugfs-related mode_t whack-a-mole
hfsplus: add an ioctl to bless files
hfsplus: change finder_info to u32
hfsplus: initialise userflags
qnx4: new helper - try_extent()
qnx4: get rid of qnx4_bread/qnx4_getblk
take removal of PF_FORKNOEXEC to flush_old_exec()
trim includes in inode.c
um: uml_dup_mmap() relies on ->mmap_sem being held, but activate_mm() doesn't hold it
um: embed ->stub_pages[] into mmu_context
gadgetfs: list_for_each_safe() misuse
ocfs2: fix leaks on failure exits in module_init
ecryptfs: make register_filesystem() the last potential failure exit
ntfs: forgets to unregister sysctls on register_filesystem() failure
logfs: missing cleanup on register_filesystem() failure
jfs: mising cleanup on register_filesystem() failure
make configfs_pin_fs() return root dentry on success
configfs: configfs_create_dir() has parent dentry in dentry->d_parent
configfs: sanitize configfs_create()
Signed-off-by: Cong Wang <amwang@redhat.com>
unfortunately, nlink_t may be smaller than 32 bits and ->i_nlink
on ocfs2 can grow up to 0xffffffff; storing it in nlink_t variable
will lose upper bits on such architectures. Needs to be made u32,
until we get kernel-side nlink_t uniformly 32bit...
git://git.kernel.org/pub/scm/linux/kernel/git/teigland/linux-dlm
* 'for-linus' of git://git.kernel.org/pub/scm/linux/kernel/git/teigland/linux-dlm:
dlm: add recovery callbacks
dlm: add node slots and generation
dlm: move recovery barrier calls
dlm: convert rsb list to rb_tree
* 'for-linus' of git://git.kernel.org/pub/scm/linux/kernel/git/jikos/trivial: (53 commits)
Kconfig: acpi: Fix typo in comment.
misc latin1 to utf8 conversions
devres: Fix a typo in devm_kfree comment
btrfs: free-space-cache.c: remove extra semicolon.
fat: Spelling s/obsolate/obsolete/g
SCSI, pmcraid: Fix spelling error in a pmcraid_err() call
tools/power turbostat: update fields in manpage
mac80211: drop spelling fix
types.h: fix comment spelling for 'architectures'
typo fixes: aera -> area, exntension -> extension
devices.txt: Fix typo of 'VMware'.
sis900: Fix enum typo 'sis900_rx_bufer_status'
decompress_bunzip2: remove invalid vi modeline
treewide: Fix comment and string typo 'bufer'
hyper-v: Update MAINTAINERS
treewide: Fix typos in various parts of the kernel, and fix some comments.
clockevents: drop unknown Kconfig symbol GENERIC_CLOCKEVENTS_MIGR
gpio: Kconfig: drop unknown symbol 'CS5535_GPIO'
leds: Kconfig: Fix typo 'D2NET_V2'
sound: Kconfig: drop unknown symbol ARCH_CLPS7500
Fix up trivial conflicts in arch/powerpc/platforms/40x/Kconfig (some new
kconfig additions, close to removed commented-out old ones)
These new callbacks notify the dlm user about lock recovery.
GFS2, and possibly others, need to be aware of when the dlm
will be doing lock recovery for a failed lockspace member.
In the past, this coordination has been done between dlm and
file system daemons in userspace, which then direct their
kernel counterparts. These callbacks allow the same
coordination directly, and more simply.
Signed-off-by: David Teigland <teigland@redhat.com>
don't open-code it...
vfs_create() ignores everything outside of 16bit subset of its
mode argument; switching it to umode_t is obviously equivalent
and it's the only caller of the method
vfs_mkdir() gets int, but immediately drops everything that might not
fit into umode_t and that's the only caller of ->mkdir()...
Seeing that just about every destructor got that INIT_LIST_HEAD() copied into
it, there is no point whatsoever keeping this INIT_LIST_HEAD in inode_init_once();
the cost of taking it into inode_init_always() will be negligible for pipes
and sockets and negative for everything else. Not to mention the removal of
boilerplate code from ->destroy_inode() instances...
new helper (wrapper around mnt_drop_write()) to be used in pair with
mnt_want_write_file().
it's both faster (in case when file has been opened for write) and cleaner.
The below patch fixes some typos in various parts of the kernel, as well as fixes some comments.
Please let me know if I missed anything, and I will try to get it changed and resent.
Acked-by: Randy Dunlap <rdunlap@xenotime.net>
git://git.kernel.org/pub/scm/linux/kernel/git/jlbec/ocfs2
* 'upstream-linus' of git://git.kernel.org/pub/scm/linux/kernel/git/jlbec/ocfs2: (31 commits)
ocfs2: avoid unaligned access to dqc_bitmap
ocfs2: Use filemap_write_and_wait() instead of write_inode_now()
ocfs2: honor O_(D)SYNC flag in fallocate
ocfs2: Add a missing journal credit in ocfs2_link_credits() -v2
ocfs2: send correct UUID to cleancache initialization
ocfs2: Commit transactions in error cases -v2
ocfs2: make direntry invalid when deleting it
fs/ocfs2/dlm/dlmlock.c: free kmem_cache_zalloc'd data using kmem_cache_free
ocfs2: Avoid livelock in ocfs2_readpage()
ocfs2: serialize unaligned aio
ocfs2: Implement llseek()
ocfs2: Fix ocfs2_page_mkwrite()
ocfs2: Add comment about orphan scanning
ocfs2: Clean up messages in the fs
ocfs2/cluster: Cluster up now includes network connections too
ocfs2/cluster: Add new function o2net_fill_node_map()
ocfs2/cluster: Fix output in file elapsed_time_in_ms
ocfs2/dlm: dlmlock_remote() needs to account for remastery
ocfs2/dlm: Take inflight reference count for remotely mastered resources too
ocfs2/dlm: Cleanup dlm_wait_for_node_death() and dlm_wait_for_node_recovery()
The dqc_bitmap field of struct ocfs2_local_disk_chunk is 32-bit aligned,
but not 64-bit aligned. The dqc_bitmap is accessed by ocfs2_set_bit(),
ocfs2_clear_bit(), ocfs2_test_bit(), or ocfs2_find_next_zero_bit(). These
are wrapper macros for ext2_*_bit() which need to take an unsigned long
aligned address (though some architectures are able to handle unaligned
address correctly)
So some 64bit architectures may not be able to access the dqc_bitmap
correctly.
This avoids such unaligned access by using another wrapper functions for
ext2_*_bit(). The code is taken from fs/ext4/mballoc.c which also need to
handle unaligned bitmap access.
Since ocfs2 has no ->write_inode method, there's no point in calling
write_inode_now() from ocfs2_cleanup_delete_inode(). Use
filemap_write_and_wait() instead. This helps us to cleanup inode writing
interfaces...
We need to sync the transaction which updates i_size if the file is marked
as needing sync semantics.
Signed-off-by: Mark Fasheh <mfasheh@suse.de>
With indexed_dir enabled, ocfs2 maintains a list of dirblocks having
space.
The credit calculation in ocfs2_link_credits() did not correctly account
for adding an entry that exactly fills a dirblock that triggers removing
that dirblock by changing the pointer in the previous block in the list.
The credit calculation did not account for that previous block.
To expose, do:
mkfs.ocfs2 -b 512 -M local /dev/sdX
mount /dev/sdX /ocfs2
mkdir /ocfs2/linkdir
touch /ocfs2/linkdir/file1
for i in `seq 1 29` ; do link /ocfs2/linkdir/file1
/ocfs2/linkdir/linklinklinklinklinklink$i; done
rm -f /ocfs2/linkdir/linklinklinklinklinklink10
sleep 8
/ocfs2/linkdir/linklinklinklinklinklinkaaaaaaaaaaaaaaaaaaaaaaaaaaaaaaaaaaaaaaaaaaaaaaaa
Note:
The link names have been crafted for a 512 byte blocksize. Reproducing
with a larger blocksize will require longer (or more) links. The sleep
is important. We want jbd2 to commit the transaction so that the missing
block does not piggy back on account of the previous transaction.
Signed-off-by: XiaoweiHu <xiaowei.hu at oracle.com>
Reviewed-by: WengangWang <wen.gang.wang at oracle.com>
Reviewed-by: Sunil.Mushran <sunil.mushran at oracle.com>
ocfs2: Fix cleancache initialization call to correctly pass uuid
As reported by Steven Whitehouse in https://lkml.org/lkml/2011/5/27/221
the ocfs2 volume UUID is incorrectly passed to cleancache.
As a result, shared-ephemeral tmem pools will not actually
be created; instead they will be private (unshared) which
misses out on a major benefit of tmem.
Reported-by: Steven Whitehouse <swhiteho@redhat.com>
Signed-off-by: Dan Magenheimer <dan.magenheimer@oracle.com>
There are three cases found that in error cases, journal transactions are not
committed nor aborted. We should take care of these case by committing the
transactions. Otherwise, there would left a journal handle which will lead to
, in same process context, the comming ocfs2_start_trans() gets wrong credits.
Signed-off-by: Wengang Wang <wen.gang.wang@oracle.com>
When we deleting a direntry from a directory, if it's the first in a block we
invalid it by setting inode to 0; otherwise, we merge the deleted one to the
prior and contiguous direntry. And we don't truncate directories.
There is a problem for the later case since inode is not set to 0.
This problem happens when the caller passes a file position as parameter to
ocfs2_dir_foreach_blk(). If the position happens to point to a stale(not
the first, deleted in betweens of ocfs2_dir_foreach_blk()s) direntry, we are
not able to recognize its staleness. So that we treat it as a live one wrongly.
The fix is to set inode to 0 in both cases indicating the direntry is stale.
This won't introduce additional IOs.
Memory allocated using kmem_cache_zalloc should be freed using
kmem_cache_free, not kfree.
The semantic patch that fixes this problem is as follows:
(http://coccinelle.lip6.fr/)
// <smpl>
expression x,e,e1,e2;
x = kmem_cache_zalloc(e1,e2)
... when != x = e
?-kfree(x)
+kmem_cache_free(e1,x)
// </smpl>
git://git.kernel.org/pub/scm/linux/kernel/git/paulg/linux
* 'modsplit-Oct31_2011' of git://git.kernel.org/pub/scm/linux/kernel/git/paulg/linux: (230 commits)
Revert "tracing: Include module.h in define_trace.h"
irq: don't put module.h into irq.h for tracking irqgen modules.
bluetooth: macroize two small inlines to avoid module.h
ip_vs.h: fix implicit use of module_get/module_put from module.h
nf_conntrack.h: fix up fallout from implicit moduleparam.h presence
include: replace linux/module.h with "struct module" wherever possible
include: convert various register fcns to macros to avoid include chaining
crypto.h: remove unused crypto_tfm_alg_modname() inline
uwb.h: fix implicit use of asm/page.h for PAGE_SIZE
pm_runtime.h: explicitly requires notifier.h
linux/dmaengine.h: fix implicit use of bitmap.h and asm/page.h
miscdevice.h: fix up implicit use of lists and types
stop_machine.h: fix implicit use of smp.h for smp_processor_id
of: fix implicit use of errno.h in include/linux/of.h
of_platform.h: delete needless include <linux/module.h>
acpi: remove module.h include from platform/aclinux.h
miscdevice.h: delete unnecessary inclusion of module.h
device_cgroup.h: delete needless include <linux/module.h>
net: sch_generic remove redundant use of <linux/module.h>
net: inet_timewait_sock doesnt need <linux/module.h>
Fix up trivial conflicts (other header files, and removal of the ab3550 mfd driver) in
- drivers/media/dvb/frontends/dibx000_common.c
- drivers/media/video/{mt9m111.c,ov6650.c}
- drivers/mfd/ab3550-core.c
- include/linux/dmaengine.h
Replace remaining direct i_nlink updates with a new set_nlink()
updater function.
Signed-off-by: Miklos Szeredi <mszeredi@suse.cz>
Tested-by: Toshiyuki Okajima <toshi.okajima@jp.fujitsu.com>
Replace direct i_nlink updates with the respective updater function
(inc_nlink, drop_nlink, clear_nlink, inode_dec_link_count).
alloc_inode() initializes i_nlink to 1. Remove unnecessary
re-initialization.
CC: Joel Becker <jlbec@evilplan.org>
CC: Mark Fasheh <mfasheh@suse.com>
Standardize the style for compiler based printf format verification.
Standardized the location of __printf too.
Done via script and a little typing.
$ grep -rPl --include=*.[ch] -w "__attribute__" * | \
grep -vP "^(tools|scripts|include/linux/compiler-gcc.h)" | \
xargs perl -n -i -e 'local $/; while (<>) { s/\b__attribute__\s*\(\s*\(\s*format\s*\(\s*printf\s*,\s*(.+)\s*,\s*(.+)\s*\)\s*\)\s*\)/__printf($1, $2)/g ; print; }'
[akpm@linux-foundation.org: revert arch bits]
Cc: "Kirill A. Shutemov" <kirill@shutemov.name>
