path: root/fs/omfs
2012-03-20switch open-coded instances of d_make_root() to new helperAl Viro
2012-01-03omfs: propagate umode_tAl Viro
2012-01-03switch ->create() to umode_tAl Viro
vfs_create() ignores everything outside of 16bit subset of its mode argument; switching it to umode_t is obviously equivalent and it's the only caller of the method Signed-off-by: Al Viro <viro@zeniv.linux.org.uk>
2012-01-03switch vfs_mkdir() and ->mkdir() to umode_tAl Viro
vfs_mkdir() gets int, but immediately drops everything that might not fit into umode_t and that's the only caller of ->mkdir()... Signed-off-by: Al Viro <viro@zeniv.linux.org.uk>
2011-07-26omfs: fix (mode & S_IFDIR) abuseAl Viro
granted, on a filesystem that has only regular files and directories it happens to work, but really should be S_ISDIR(mode)... Signed-off-by: Al Viro <viro@zeniv.linux.org.uk>
2011-06-24Remove unneeded version.h includes from fs/Jesper Juhl
It was pointed out by 'make versioncheck' that some includes of linux/version.h were not needed in fs/ (fs/btrfs/ctree.h and fs/omfs/file.c). This patch removes them. Signed-off-by: Jesper Juhl <jj@chaosbits.net> Acked-by: Bob Copeland <me@bobcopeland.com> Signed-off-by: Linus Torvalds <torvalds@linux-foundation.org>
2011-05-28omfs: remove unnecessary dentry_unhash on rmdir, dir rneameSage Weil
omfs does not have problems with references to unlinked directories. CC: Bob Copeland <me@bobcopeland.com> CC: linux-karma-devel@lists.sourceforge.net Signed-off-by: Sage Weil <sage@newdream.net> Signed-off-by: Al Viro <viro@zeniv.linux.org.uk>
2011-05-26vfs: push dentry_unhash on rename_dir into file systemsSage Weil
Only a few file systems need this. Start by pushing it down into each rename method (except gfs2 and xfs) so that it can be dealt with on a per-fs basis. Acked-by: Christoph Hellwig <hch@lst.de> Signed-off-by: Sage Weil <sage@newdream.net> Signed-off-by: Al Viro <viro@zeniv.linux.org.uk>
2011-05-26vfs: push dentry_unhash on rmdir into file systemsSage Weil
Only a few file systems need this. Start by pushing it down into each fs rmdir method (except gfs2 and xfs) so it can be dealt with on a per-fs basis. This does not change behavior for any in-tree file systems. Acked-by: Christoph Hellwig <hch@lst.de> Signed-off-by: Sage Weil <sage@newdream.net> Signed-off-by: Al Viro <viro@zeniv.linux.org.uk>
2011-03-24Merge branch 'for-2.6.39/core' of git://git.kernel.dk/linux-2.6-blockLinus Torvalds
* 'for-2.6.39/core' of git://git.kernel.dk/linux-2.6-block: (65 commits) Documentation/iostats.txt: bit-size reference etc. cfq-iosched: removing unnecessary think time checking cfq-iosched: Don't clear queue stats when preempt. blk-throttle: Reset group slice when limits are changed blk-cgroup: Only give unaccounted_time under debug cfq-iosched: Don't set active queue in preempt block: fix non-atomic access to genhd inflight structures block: attempt to merge with existing requests on plug flush block: NULL dereference on error path in __blkdev_get() cfq-iosched: Don't update group weights when on service tree fs: assign sb->s_bdi to default_backing_dev_info if the bdi is going away block: Require subsystems to explicitly allocate bio_set integrity mempool jbd2: finish conversion from WRITE_SYNC_PLUG to WRITE_SYNC and explicit plugging jbd: finish conversion from WRITE_SYNC_PLUG to WRITE_SYNC and explicit plugging fs: make fsync_buffers_list() plug mm: make generic_writepages() use plugging blk-cgroup: Add unaccounted time to timeslice_used. block: fixup plugging stubs for !CONFIG_BLOCK block: remove obsolete comments for blkdev_issue_zeroout. blktrace: Use rq->cmd_flags directly in blk_add_trace_rq. ... Fix up conflicts in fs/{aio.c,super.c}
2011-03-10block: remove per-queue pluggingJens Axboe
Code has been converted over to the new explicit on-stack plugging, and delay users have been converted to use the new API for that. So lets kill off the old plugging along with aops->sync_page(). Signed-off-by: Jens Axboe <jaxboe@fusionio.com>
2011-03-05omfs: make readdir stop when filldir says soAl Viro
filldir returning an error does *not* mean "skip this entry, try the next one"... Signed-off-by: Al Viro <viro@zeniv.linux.org.uk> Signed-off-by: Bob Copeland <me@bobcopeland.com>
2011-03-05omfs: merge unlink() and rmdir(), close leak in rename()Al Viro
In case of directory-overwriting rename(), omfs forgot to mark the victim doomed, so omfs_evict_inode() didn't free it. We could fix that by calling omfs_rmdir() for directory victims instead of doing omfs_unlink(), but it's easier to merge omfs_unlink() and omfs_rmdir() instead. Note that we have no hardlinks here. It also makes the checks in omfs_rename() go away - they fold into what omfs_remove() does when it runs into a directory. Signed-off-by: Al Viro <viro@zeniv.linux.org.uk> Signed-off-by: Bob Copeland <me@bobcopeland.com>
2011-03-05omfs: stop playing silly buggers with omfs_unlink() in ->rename()Al Viro
Since omfs directories are hashes of inodes and name is part of inode, we have to remove inode from old directory before we can put it into new one / under new name. So instead of bump i_nlink call omfs_unlink, which does omfs_delete_entry() decrement i_nlink and mark parent dirty in case of success decrement i_nlink if omfs_unlink failed and hadn't done it itself let's just call omfs_delete_entry() and dirty the parent ourselves... Signed-off-by: Al Viro <viro@zeniv.linux.org.uk> Signed-off-by: Bob Copeland <me@bobcopeland.com>
2011-03-05omfs: rename() needs to mark old_inode dirty after ctime updateAl Viro
we *do* mark it dirty before, but it doesn't guarantee that we don't get preempted just before assignment to ->i_ctime, with inode getting written out before we get CPU back... Signed-off-by: Al Viro <viro@zeniv.linux.org.uk> Signed-off-by: Bob Copeland <me@bobcopeland.com>
2010-10-29new helper: mount_bdev()Al Viro
... and switch of the obvious get_sb_bdev() users to ->mount() Signed-off-by: Al Viro <viro@zeniv.linux.org.uk>
2010-08-10Merge branch 'for-linus' of ↵Linus Torvalds
git://git.kernel.org/pub/scm/linux/kernel/git/bcopeland/omfs * 'for-linus' of git://git.kernel.org/pub/scm/linux/kernel/git/bcopeland/omfs: omfs: fix uninitialized variable warning omfs: sanity check cluster size omfs: refuse to mount if bitmap pointer is obviously wrong omfs: check bounds on block numbers before passing to sb_bread omfs: fix memory leak
2010-08-09switch omfs to ->evict_inode()Al Viro
2010-08-09remove inode_setattrChristoph Hellwig
Replace inode_setattr with opencoded variants of it in all callers. This moves the remaining call to vmtruncate into the filesystem methods where it can be replaced with the proper truncate sequence. In a few cases it was obvious that we would never end up calling vmtruncate so it was left out in the opencoded variant: spufs: explicitly checks for ATTR_SIZE earlier btrfs,hugetlbfs,logfs,dlmfs: explicitly clears ATTR_SIZE earlier ufs: contains an opencoded simple_seattr + truncate that sets the filesize just above In addition to that ncpfs called inode_setattr with handcrafted iattrs, which allowed to trim down the opencoded variant. Signed-off-by: Christoph Hellwig <hch@lst.de> Signed-off-by: Al Viro <viro@zeniv.linux.org.uk>
2010-08-09add missing setattr methodsChristoph Hellwig
For the new truncate sequence every filesystem that wants to truncate on-disk state needs a seattr method. Convert the remaining filesystems that implement the truncate inode operation to have its own setattr method. Signed-off-by: Christoph Hellwig <hch@lst.de> Signed-off-by: Al Viro <viro@zeniv.linux.org.uk>
2010-08-09get rid of block_write_begin_newtruncChristoph Hellwig
Move the call to vmtruncate to get rid of accessive blocks to the callers in preparation of the new truncate sequence and rename the non-truncating version to block_write_begin. While we're at it also remove several unused arguments to block_write_begin. Signed-off-by: Christoph Hellwig <hch@lst.de> Signed-off-by: Al Viro <viro@zeniv.linux.org.uk>
2010-08-08omfs: fix uninitialized variable warningBill Pemberton
quiet the warning: fs/omfs/file.c: In function 'omfs_get_block': fs/omfs/file.c:225: warning: 'new_block' may be used uninitialized in this function new_block is used properly by the call to omfs_grow_extent() Signed-off-by: Bill Pemberton <wfp5p@virginia.edu> Signed-off-by: Bob Copeland <me@bobcopeland.com>
2010-07-10omfs: sanity check cluster sizeBob Copeland
A corrupt filesystem could have a bad cluster size; this could result in the filesystem allocating too much space for files if too large, or getting stuck in omfs_allocate_block if too small. The proper range is 1-8 blocks. Reported-by: Eric Sesterhenn <snakebyte@gmx.de> Signed-off-by: Bob Copeland <me@bobcopeland.com>
2010-07-10omfs: refuse to mount if bitmap pointer is obviously wrongBob Copeland
If the free space bitmap pointer is corrupted such that it lies outside of the number of blocks in the filesystem, print a message and fail the mount so the user can fix it offline. Signed-off-by: Bob Copeland <me@bobcopeland.com>
2010-07-10omfs: check bounds on block numbers before passing to sb_breadBob Copeland
In case of filesystem corruption, passing unchecked block numbers into sb_bread can result in an infinite loop in __getblk(). Introduce a wrapper function omfs_sbread() to check the block numbers and to also perform the clus_to_blk() scaling. Signed-off-by: Bob Copeland <me@bobcopeland.com>
2010-07-06omfs: fix memory leakDavidlohr Bueso
In the error path of omfs_fill_super(), the FS super block info (sbi) is not being freed. Correct this. Signed-off-by: Davidlohr Bueso <dave@gnu.org> Signed-off-by: Bob Copeland <me@bobcopeland.com>
2010-05-27rename the generic fsync implementationsChristoph Hellwig
We don't name our generic fsync implementations very well currently. The no-op implementation for in-memory filesystems currently is called simple_sync_file which doesn't make too much sense to start with, the the generic one for simple filesystems is called simple_fsync which can lead to some confusion. This patch renames the generic file fsync method to generic_file_fsync to match the other generic_file_* routines it is supposed to be used with, and the no-op implementation to noop_fsync to make it obvious what to expect. In addition add some documentation for both methods. Signed-off-by: Christoph Hellwig <hch@lst.de> Signed-off-by: Al Viro <viro@zeniv.linux.org.uk>
2010-05-21omfs: replace inode uid,gid,mode initialization with helper functionDmitry Monakhov
Signed-off-by: Dmitry Monakhov <dmonakhov@openvz.org> Signed-off-by: Al Viro <viro@zeniv.linux.org.uk>
2010-04-23Merge branch 'master' into for-nextJiri Kosina
implicit slab.h inclusion from percpu.h percpu.h is included by sched.h and module.h and thus ends up being included when building most .c files. percpu.h includes slab.h which in turn includes gfp.h making everything defined by the two files universally available and complicating inclusion dependencies. percpu.h -> slab.h dependency is about to be removed. Prepare for this change by updating users of gfp and slab facilities include those headers directly instead of assuming availability. As this conversion needs to touch large number of source files, the following script is used as the basis of conversion. http://userweb.kernel.org/~tj/misc/slabh-sweep.py The script does the followings. * Scan files for gfp and slab usages and update includes such that only the necessary includes are there. ie. if only gfp is used, gfp.h, if slab is used, slab.h. * When the script inserts a new include, it looks at the include blocks and try to put the new include such that its order conforms to its surrounding. It's put in the include block which contains core kernel includes, in the same order that the rest are ordered - alphabetical, Christmas tree, rev-Xmas-tree or at the end if there doesn't seem to be any matching order. * If the script can't find a place to put a new include (mostly because the file doesn't have fitting include block), it prints out an error message indicating which .h file needs to be added to the file. The conversion was done in the following steps. 1. The initial automatic conversion of all .c files updated slightly over 4000 files, deleting around 700 includes and adding ~480 gfp.h and ~3000 slab.h inclusions. The script emitted errors for ~400 files. 2. Each error was manually checked. Some didn't need the inclusion, some needed manual addition while adding it to implementation .h or embedding .c file was more appropriate for others. This step added inclusions to around 150 files. 3. The script was run again and the output was compared to the edits from #2 to make sure no file was left behind. 4. Several build tests were done and a couple of problems were fixed. e.g. lib/decompress_*.c used malloc/free() wrappers around slab APIs requiring slab.h to be added manually. 5. The script was run on all .h files but without automatically editing them as sprinkling gfp.h and slab.h inclusions around .h files could easily lead to inclusion dependency hell. Most gfp.h inclusion directives were ignored as stuff from gfp.h was usually wildly available and often used in preprocessor macros. Each slab.h inclusion directive was examined and added manually as necessary. 6. percpu.h was updated not to include slab.h. 7. Build test were done on the following configurations and failures were fixed. CONFIG_GCOV_KERNEL was turned off for all tests (as my distributed build env didn't work with gcov compiles) and a few more options had to be turned off depending on archs to make things build (like ipr on powerpc/64 which failed due to missing writeq). * x86 and x86_64 UP and SMP allmodconfig and a custom test config. * powerpc and powerpc64 SMP allmodconfig * sparc and sparc64 SMP allmodconfig * ia64 SMP allmodconfig * s390 SMP allmodconfig * alpha SMP allmodconfig * um on x86_64 SMP allmodconfig 8. percpu.h modifications were reverted so that it could be applied as a separate patch and serve as bisection point. Given the fact that I had only a couple of failures from tests on step 6, I'm fairly confident about the coverage of this conversion patch. If there is a breakage, it's likely to be something in one of the arch headers which should be easily discoverable easily on most builds of the specific arch. Signed-off-by: Tejun Heo <tj@kernel.org> Guess-its-ok-by: Christoph Lameter <cl@linux-foundation.org> Cc: Ingo Molnar <mingo@redhat.com> Cc: Lee Schermerhorn <Lee.Schermerhorn@hp.com>
2010-03-15omfs: remove unused version.h includeHuang Weiyi
Signed-off-by: Huang Weiyi <weiyi.huang@gmail.com> Signed-off-by: Bob Copeland <me@bobcopeland.com> Signed-off-by: Jiri Kosina <jkosina@suse.cz>
2010-03-05pass writeback_control to ->write_inodeChristoph Hellwig
This gives the filesystem more information about the writeback that is happening. Trond requested this for the NFS unstable write handling, and other filesystems might benefit from this too by beeing able to distinguish between the different callers in more detail. Signed-off-by: Christoph Hellwig <hch@lst.de> Signed-off-by: Al Viro <viro@zeniv.linux.org.uk>
2009-12-04tree-wide: fix assorted typos all over the placeAndré Goddard Rosa
That is "success", "unknown", "through", "performance", "[re|un]mapping" , "access", "default", "reasonable", "[con]currently", "temperature" , "channel", "[un]used", "application", "example","hierarchy", "therefore" , "[over|under]flow", "contiguous", "threshold", "enough" and others. Signed-off-by: André Goddard Rosa <andre.goddard@gmail.com> Signed-off-by: Jiri Kosina <jkosina@suse.cz>
2009-10-01const: constify remaining file_operationsAlexey Dobriyan
[akpm@linux-foundation.org: fix KVM] Signed-off-by: Alexey Dobriyan <adobriyan@gmail.com> Acked-by: Mike Frysinger <vapier@gentoo.org> Signed-off-by: Andrew Morton <akpm@linux-foundation.org> Signed-off-by: Linus Torvalds <torvalds@linux-foundation.org>
2009-09-22const: mark remaining inode_operations as constAlexey Dobriyan
Signed-off-by: Alexey Dobriyan <adobriyan@gmail.com> Signed-off-by: Andrew Morton <akpm@linux-foundation.org> Signed-off-by: Linus Torvalds <torvalds@linux-foundation.org>
2009-09-22const: mark remaining address_space_operations constAlexey Dobriyan
2009-09-22const: mark remaining super_operations constAlexey Dobriyan
2009-06-11switch omfs to simple_fsync()Al Viro
2009-04-02Merge branch 'for-linus' of ↵Linus Torvalds
git://git.kernel.org/pub/scm/linux/kernel/git/viro/vfs-2.6 * 'for-linus' of git://git.kernel.org/pub/scm/linux/kernel/git/viro/vfs-2.6: Remove two unneeded exports and make two symbols static in fs/mpage.c Cleanup after commit 585d3bc06f4ca57f975a5a1f698f65a45ea66225 Trim includes of fdtable.h Don't crap into descriptor table in binfmt_som Trim includes in binfmt_elf Don't mess with descriptor table in load_elf_binary() Get rid of indirect include of fs_struct.h New helper - current_umask() check_unsafe_exec() doesn't care about signal handlers sharing New locking/refcounting for fs_struct Take fs_struct handling to new file (fs/fs_struct.c) Get rid of bumping fs_struct refcount in pivot_root(2) Kill unsharing fs_struct in __set_personality()
2009-04-02fs/omfs: return f_fsid for statfs(2)Coly Li
Make omfs return f_fsid info for statfs(2). Signed-off-by: Coly Li <coly.li@suse.de> Acked-by: Bob Copeland <me@bobcopeland.com> Signed-off-by: Andrew Morton <akpm@linux-foundation.org> Signed-off-by: Linus Torvalds <torvalds@linux-foundation.org>
2009-03-31New helper - current_umask()Al Viro
current->fs->umask is what most of fs_struct users are doing. Put that into a helper function. Signed-off-by: Al Viro <viro@zeniv.linux.org.uk>
2009-01-22fs/Kconfig: move omfs outAlexey Dobriyan
2009-01-05zero i_uid/i_gid on inode allocationAl Viro
... and don't bother in callers. Don't bother with zeroing i_blocks, while we are at it - it's already been zeroed. i_mode is not worth the effort; it has no common default value. Signed-off-by: Al Viro <viro@zeniv.linux.org.uk>
2008-11-14CRED: Wrap task credential accesses in the OMFS filesystemDavid Howells
Wrap access to task credentials so that they can be separated more easily from the task_struct during the introduction of COW creds. Change most current->(|e|s|fs)[ug]id to current_(|e|s|fs)[ug]id(). Change some task->e?[ug]id to task_e?[ug]id(). In some places it makes more sense to use RCU directly rather than a convenient wrapper; these will be addressed by later patches. Signed-off-by: David Howells <dhowells@redhat.com> Reviewed-by: James Morris <jmorris@namei.org> Acked-by: Serge Hallyn <serue@us.ibm.com> Cc: Bob Copeland <me@bobcopeland.com> Cc: linux-karma-devel@lists.sourceforge.net Signed-off-by: James Morris <jmorris@namei.org>
2008-10-23[PATCH] fix ->llseek for more directoriesChristoph Hellwig
With this patch all directory fops instances that have a readdir that doesn't take the BKL are switched to generic_file_llseek. Signed-off-by: Christoph Hellwig <hch@lst.de>
2008-10-13vfs: Use const for kernel parser tableSteven Whitehouse
This is a much better version of a previous patch to make the parser tables constant. Rather than changing the typedef, we put the "const" in all the various places where its required, allowing the __initconst exception for nfsroot which was the cause of the previous trouble. This was posted for review some time ago and I believe its been in -mm since then. Signed-off-by: Steven Whitehouse <swhiteho@redhat.com> Cc: Alexander Viro <aviro@redhat.com> Signed-off-by: Linus Torvalds <torvalds@linux-foundation.org>
2008-08-15omfs: fix oops when file metadata is corruptedBob Copeland
A fuzzed fileystem image failed with OMFS when the extent count was used in a loop without being checked against the max number of extents. It also provoked a signed division for an array index that was checked as if unsigned, leading to index by -1. omfsck will be updated to fix these cases, in the meantime bail out gracefully. Reported-by: Eric Sesterhenn <snakebyte@gmx.de> Signed-off-by: Bob Copeland <me@bobcopeland.com> Signed-off-by: Andrew Morton <akpm@linux-foundation.org> Signed-off-by: Linus Torvalds <torvalds@linux-foundation.org>
2008-08-15omfs: fix potential oops when directory size is corruptedBob Copeland
Testing with a modified fsfuzzer reveals a couple of locations in omfs where filesystem variables are ultimately used as loop counters with insufficient sanity checking. In this case, dir->i_size is used to compute the number of buckets in the directory hash. If too large, readdir will overrun a buffer. Since it's an invariant that dir->i_size is equal to the sysblock size, and we already sanity check that, just use that value instead. This fixes the following oops: BUG: unable to handle kernel paging request at c978e004 IP: [<c032298e>] omfs_readdir+0x18e/0x32f Oops: 0000 [#1] PREEMPT DEBUG_PAGEALLOC Modules linked in: Pid: 4796, comm: ls Not tainted (2.6.27-rc2 #12) EIP: 0060:[<c032298e>] EFLAGS: 00010287 CPU: 0 EIP is at omfs_readdir+0x18e/0x32f EAX: c978d000 EBX: 00000000 ECX: cbfcfaf8 EDX: cb2cf100 ESI: 00001000 EDI: 00000800 EBP: cb2d3f68 ESP: cb2d3f0c DS: 007b ES: 007b FS: 0000 GS: 0033 SS: 0068 Process ls (pid: 4796, ti=cb2d3000 task=cb175f40 task.ti=cb2d3000) Stack: 00000002 00000000 00000000 c018a820 cb2d3f94 cb2cf100 cbfb0000 ffffff10 cbfb3b80 cbfcfaf8 000001c9 00000a09 00000000 00000000 00000000 cbfcfbc8 c9697000 cbfb3b80 22222222 00001000 c08e6cd0 cb2cf100 cbfb3b80 cb2d3f88 Call Trace: [<c018a820>] ? filldir64+0x0/0xcd [<c018a9f2>] ? vfs_readdir+0x56/0x82 [<c018a820>] ? filldir64+0x0/0xcd [<c018aa7c>] ? sys_getdents64+0x5e/0xa0 [<c01038bd>] ? sysenter_do_call+0x12/0x31 ======================= Code: 00 89 f0 89 f3 0f ac f8 14 81 e3 ff ff 0f 00 48 8d 14 c5 b8 01 00 00 89 45 cc 89 55 f0 e9 8c 01 00 00 8b 4d c8 8b 75 f0 8b 41 18 <8b> 54 30 04 8b 04 30 31 f6 89 5d dc 89 d1 8b 55 b8 0f c8 0f c9 Reported-by: Eric Sesterhenn <snakebyte@gmx.de> Signed-off-by: Bob Copeland <me@bobcopeland.com> Signed-off-by: Andrew Morton <akpm@linux-foundation.org> Signed-off-by: Linus Torvalds <torvalds@linux-foundation.org>
2008-08-05omfs: fix warningAlexander Beregalov
fs/omfs/inode.c:495: warning: format '%llx' expects type 'long long unsigned int', but argument 2 has type 'u64' fs/omfs/inode.c:495: warning: format '%llx' expects type 'long long unsigned int', but argument 3 has type '__be64' Signed-off-by: Alexander Beregalov <a.beregalov@gmail.com> Acked-by: Bob Copeland <me@bobcopeland.com> Signed-off-by: Andrew Morton <akpm@linux-foundation.org> Signed-off-by: Linus Torvalds <torvalds@linux-foundation.org>
2008-07-30omfs: sparse annotationsHarvey Harrison
Missing cpu_to_be64 on some constant assignments. fs/omfs/dir.c:107:16: warning: incorrect type in assignment (different base types) fs/omfs/dir.c:107:16: expected restricted __be64 [usertype] i_sibling fs/omfs/dir.c:107:16: got unsigned long long fs/omfs/file.c:33:13: warning: incorrect type in assignment (different base types) fs/omfs/file.c:33:13: expected restricted __be64 [usertype] e_next fs/omfs/file.c:33:13: got unsigned long long fs/omfs/file.c:36:24: warning: incorrect type in assignment (different base types) fs/omfs/file.c:36:24: expected restricted __be64 [usertype] e_cluster fs/omfs/file.c:36:24: got unsigned long long fs/omfs/file.c:37:23: warning: incorrect type in assignment (different base types) fs/omfs/file.c:37:23: expected restricted __be64 [usertype] e_blocks fs/omfs/file.c:37:23: got unsigned long long fs/omfs/bitmap.c:74:18: warning: incorrect type in argument 2 (different signedness) fs/omfs/bitmap.c:74:18: expected unsigned long volatile *addr fs/omfs/bitmap.c:74:18: got long *<noident> fs/omfs/bitmap.c:77:20: warning: incorrect type in argument 2 (different signedness) fs/omfs/bitmap.c:77:20: expected unsigned long volatile *addr fs/omfs/bitmap.c:77:20: got long *<noident> fs/omfs/bitmap.c:112:17: warning: incorrect type in argument 2 (different signedness) fs/omfs/bitmap.c:112:17: expected unsigned long volatile *addr fs/omfs/bitmap.c:112:17: got long *<noident> Signed-off-by: Harvey Harrison <harvey.harrison@gmail.com> Acked-by: Bob Copeland <me@bobcopeland.com> Signed-off-by: Andrew Morton <akpm@linux-foundation.org> Signed-off-by: Linus Torvalds <torvalds@linux-foundation.org>
